[PATCH v3 1/5] boot: fdt: Change type of env_get_bootm_low() to phys_addr_t
Change type of ulong env_get_bootm_low() to phys_addr_t env_get_bootm_low(). The PPC/LS systems already treat env_get_bootm_low() result as phys_addr_t, while the function itself still returns ulong. This is potentially dangerous on 64bit systems, where ulong might not be large enough to hold the content of "bootm_low" environment variable. Fix it by using phys_addr_t, similar to what env_get_bootm_size() does, which returns phys_size_t .
Reviewed-by: Laurent Pinchart laurent.pinchart@ideasonboard.com Reported-by: Laurent Pinchart laurent.pinchart@ideasonboard.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Kuninori Morimoto kuninori.morimoto.gx@renesas.com Cc: Laurent Pinchart laurent.pinchart@ideasonboard.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V2: - Drop now unnecessary conversion in boot_start_lmb() lmb_init_and_reserve_range() - Drop tmp variable in env_get_bootm_low() - Print initrd_high as u64/%llx - Add RB from Laurent V3: No change --- boot/bootm.c | 4 ++-- boot/image-board.c | 14 ++++++-------- boot/image-fdt.c | 9 +++++---- include/image.h | 2 +- 4 files changed, 14 insertions(+), 15 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index d071537d692..032f5a4a160 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -242,13 +242,13 @@ static int boot_get_kernel(const char *addr_fit, struct bootm_headers *images, #ifdef CONFIG_LMB static void boot_start_lmb(struct bootm_headers *images) { - ulong mem_start; + phys_addr_t mem_start; phys_size_t mem_size;
mem_start = env_get_bootm_low(); mem_size = env_get_bootm_size();
- lmb_init_and_reserve_range(&images->lmb, (phys_addr_t)mem_start, + lmb_init_and_reserve_range(&images->lmb, mem_start, mem_size, NULL); } #else diff --git a/boot/image-board.c b/boot/image-board.c index 75f6906cd56..3263497a1d5 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -107,14 +107,12 @@ static int on_loadaddr(const char *name, const char *value, enum env_op op, } U_BOOT_ENV_CALLBACK(loadaddr, on_loadaddr);
-ulong env_get_bootm_low(void) +phys_addr_t env_get_bootm_low(void) { char *s = env_get("bootm_low");
- if (s) { - ulong tmp = hextoul(s, NULL); - return tmp; - } + if (s) + return simple_strtoull(s, NULL, 16);
#if defined(CFG_SYS_SDRAM_BASE) return CFG_SYS_SDRAM_BASE; @@ -538,7 +536,7 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, ulong *initrd_start, ulong *initrd_end) { char *s; - ulong initrd_high; + phys_addr_t initrd_high; int initrd_copy_to_ram = 1;
s = env_get("initrd_high"); @@ -553,8 +551,8 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, initrd_high = env_get_bootm_mapsize() + env_get_bootm_low(); }
- debug("## initrd_high = 0x%08lx, copy_to_ram = %d\n", - initrd_high, initrd_copy_to_ram); + debug("## initrd_high = 0x%llx, copy_to_ram = %d\n", + (u64)initrd_high, initrd_copy_to_ram);
if (rd_data) { if (!initrd_copy_to_ram) { /* zero-copy ramdisk support */ diff --git a/boot/image-fdt.c b/boot/image-fdt.c index 5e4aa9de0d2..c2571b22244 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -160,9 +160,10 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) { void *fdt_blob = *of_flat_tree; void *of_start = NULL; - u64 start, size, usable; + phys_addr_t start, size, usable; char *fdt_high; - ulong mapsize, low; + phys_addr_t low; + phys_size_t mapsize; ulong of_len = 0; int bank; int err; @@ -217,7 +218,7 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) if (start + size < low) continue;
- usable = min(start + size, (u64)(low + mapsize)); + usable = min(start + size, low + mapsize);
/* * At least part of this DRAM bank is usable, try @@ -233,7 +234,7 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) * Reduce the mapping size in the next bank * by the size of attempt in current bank. */ - mapsize -= usable - max(start, (u64)low); + mapsize -= usable - max(start, low); if (!mapsize) break; } diff --git a/include/image.h b/include/image.h index 21de70f0c9e..acffd17e0df 100644 --- a/include/image.h +++ b/include/image.h @@ -946,7 +946,7 @@ static inline void image_set_name(struct legacy_img_hdr *hdr, const char *name) int image_check_hcrc(const struct legacy_img_hdr *hdr); int image_check_dcrc(const struct legacy_img_hdr *hdr); #ifndef USE_HOSTCC -ulong env_get_bootm_low(void); +phys_addr_t env_get_bootm_low(void); phys_size_t env_get_bootm_size(void); phys_size_t env_get_bootm_mapsize(void); #endif
Reduce tmp variable use and remove unnecessary type cast in env_get_bootm_size(). This aligns the env variable parsing with env_get_bootm_low(). No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Kuninori Morimoto kuninori.morimoto.gx@renesas.com Cc: Laurent Pinchart laurent.pinchart@ideasonboard.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V2: - New patch V3: - Reword commit message --- boot/image-board.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/boot/image-board.c b/boot/image-board.c index 3263497a1d5..e3d63745299 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -129,10 +129,8 @@ phys_size_t env_get_bootm_size(void) phys_addr_t start; char *s = env_get("bootm_size");
- if (s) { - tmp = (phys_size_t)simple_strtoull(s, NULL, 16); - return tmp; - } + if (s) + return simple_strtoull(s, NULL, 16);
start = gd->ram_base; size = gd->ram_size; @@ -142,7 +140,7 @@ phys_size_t env_get_bootm_size(void)
s = env_get("bootm_low"); if (s) - tmp = (phys_size_t)simple_strtoull(s, NULL, 16); + tmp = simple_strtoull(s, NULL, 16); else tmp = start;
Reduce tmp variable use and remove unnecessary type cast in env_get_bootm_mapsize(). This aligns the env variable parsing with env_get_bootm_low(). No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Kuninori Morimoto kuninori.morimoto.gx@renesas.com Cc: Laurent Pinchart laurent.pinchart@ideasonboard.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V3: - New patch --- boot/image-board.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/boot/image-board.c b/boot/image-board.c index e3d63745299..b036ed764f8 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -149,13 +149,10 @@ phys_size_t env_get_bootm_size(void)
phys_size_t env_get_bootm_mapsize(void) { - phys_size_t tmp; char *s = env_get("bootm_mapsize");
#if defined(CFG_SYS_BOOTMAPSZ) return CFG_SYS_BOOTMAPSZ;
The lmb_alloc_base() returns phys_addr_t , map_sysmem() accepts phys_addr_t as first parameter. Declare 'addr' as phys_addr_t and get rid of the casts.
Reviewed-by: Laurent Pinchart laurent.pinchart@ideasonboard.com Reported-by: Laurent Pinchart laurent.pinchart@ideasonboard.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Kuninori Morimoto kuninori.morimoto.gx@renesas.com Cc: Laurent Pinchart laurent.pinchart@ideasonboard.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V2: - Replace $addr with 'addr' to somehow delimit the variable name V3: - Add RB from Laurent --- boot/image-fdt.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/boot/image-fdt.c b/boot/image-fdt.c index c2571b22244..c37442c9130 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -162,6 +162,7 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) void *of_start = NULL; phys_addr_t start, size, usable; char *fdt_high; + phys_addr_t addr; phys_addr_t low; phys_size_t mapsize; ulong of_len = 0; @@ -186,7 +187,6 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) fdt_high = env_get("fdt_high"); if (fdt_high) { ulong desired_addr = hextoul(fdt_high, NULL); - ulong addr;
if (desired_addr == ~0UL) { /* All ones means use fdt in place */ @@ -224,8 +224,8 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) * At least part of this DRAM bank is usable, try * using it for LMB allocation. */ - of_start = map_sysmem((ulong)lmb_alloc_base(lmb, - of_len, 0x1000, usable), of_len); + addr = lmb_alloc_base(lmb, of_len, 0x1000, usable); + of_start = map_sysmem(addr, of_len); /* Allocation succeeded, use this block. */ if (of_start != NULL) break;
Move the variable below comment which explains what the variable means. Update the comment. No functional change.
Reviewed-by: Laurent Pinchart laurent.pinchart@ideasonboard.com Suggested-by: Laurent Pinchart laurent.pinchart@ideasonboard.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Kuninori Morimoto kuninori.morimoto.gx@renesas.com Cc: Laurent Pinchart laurent.pinchart@ideasonboard.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V2: - Update the comment, s@the the@the@ and quote 'usable' - Add RB from Laurent V3: No change --- boot/image-fdt.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/boot/image-fdt.c b/boot/image-fdt.c index c37442c9130..2b92bdaff16 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -218,12 +218,12 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) if (start + size < low) continue;
- usable = min(start + size, low + mapsize); - /* * At least part of this DRAM bank is usable, try - * using it for LMB allocation. + * using the DRAM bank up to 'usable' address limit + * for LMB allocation. */ + usable = min(start + size, low + mapsize); addr = lmb_alloc_base(lmb, of_len, 0x1000, usable); of_start = map_sysmem(addr, of_len); /* Allocation succeeded, use this block. */
