[U-Boot] [PATCH 1/2] Add ntel PCIE PRO/1000 Network Driver support
Based on Intel PRO/1000 Network Driver 7.3.20-k2 Add Intel E1000 PCIE card support. The following cards are added: INTEL_82571EB_COPPER INTEL_82571EB_FIBER, INTEL_82571EB_SERDES INTEL_82571EB_QUAD_COPPER INTEL_82571PT_QUAD_COPPER INTEL_82571EB_QUAD_FIBER INTEL_82571EB_QUAD_COPPER_LOWPROFILE INTEL_82571EB_SERDES_DUAL INTEL_82571EB_SERDES_QUAD INTEL_82572EI_COPPER INTEL_82572EI_FIBER INTEL_82572EI_SERDES INTEL_82572EI INTEL_82573E INTEL_82573E_IAMT INTEL_82573L INTEL_82546GB_QUAD_COPPER_KSP3 INTEL_80003ES2LAN_COPPER_DPT INTEL_80003ES2LAN_SERDES_DPT INTEL_80003ES2LAN_COPPER_SPT INTEL_80003ES2LAN_SERDES_SPT
82571EB_COPPER dual ports, 82572EI single port, 82572EI_COPPER single port PCIE cards and 82545EM_COPPER, 82541GI_LF pci cards are tested on P2020 board, MPC8536DS and MPC8544DS boards.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com --- drivers/net/e1000.c | 3060 ++++++++++++++++++++++++++++++++++++++++++++------- drivers/net/e1000.h | 838 ++++++++++++++- include/pci_ids.h | 22 + 3 files changed, 3492 insertions(+), 428 deletions(-)
diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index a52749d..70c40df 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -51,7 +51,7 @@ tested on both gig copper and gig fiber boards #define bus_to_phys(devno, a) pci_mem_to_phys(devno, a) #define mdelay(n) udelay((n)*1000)
-#define E1000_DEFAULT_PBA 0x00000030 +#define E1000_DEFAULT_PBA 0x000a0026
/* NIC specific static variables go here */
@@ -82,6 +82,28 @@ static struct pci_device_id supported[] = { {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82540EM_LOM}, {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82541ER}, {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82541GI_LF}, + /* E1000 PCIe card */ + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82571EB_COPPER}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82571EB_FIBER }, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82571EB_SERDES }, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82571EB_QUAD_COPPER}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82571PT_QUAD_COPPER}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82571EB_QUAD_FIBER}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82571EB_QUAD_COPPER_LOWPROFILE}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82571EB_SERDES_DUAL}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82571EB_SERDES_QUAD}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82572EI_COPPER}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82572EI_FIBER}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82572EI_SERDES}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82572EI}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82573E}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82573E_IAMT}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82573L}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82546GB_QUAD_COPPER_KSP3}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_80003ES2LAN_COPPER_DPT}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_80003ES2LAN_SERDES_DPT}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_80003ES2LAN_COPPER_SPT}, + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_80003ES2LAN_SERDES_SPT}, {} };
@@ -95,16 +117,23 @@ static int e1000_config_mac_to_phy(struct e1000_hw *hw); static int e1000_config_fc_after_link_up(struct e1000_hw *hw); static int e1000_check_for_link(struct eth_device *nic); static int e1000_wait_autoneg(struct e1000_hw *hw); -static void e1000_get_speed_and_duplex(struct e1000_hw *hw, uint16_t * speed, +static int e1000_get_speed_and_duplex(struct e1000_hw *hw, uint16_t * speed, uint16_t * duplex); static int e1000_read_phy_reg(struct e1000_hw *hw, uint32_t reg_addr, uint16_t * phy_data); static int e1000_write_phy_reg(struct e1000_hw *hw, uint32_t reg_addr, uint16_t phy_data); -static void e1000_phy_hw_reset(struct e1000_hw *hw); +static int32_t e1000_phy_hw_reset(struct e1000_hw *hw); static int e1000_phy_reset(struct e1000_hw *hw); static int e1000_detect_gig_phy(struct e1000_hw *hw); - +static int32_t e1000_read_eeprom(struct e1000_hw *hw, uint16_t offset, + uint16_t words, + uint16_t *data); +static void e1000_put_hw_eeprom_semaphore(struct e1000_hw *hw); +static void e1000_set_media_type(struct e1000_hw *hw); + +static int32_t e1000_swfw_sync_acquire(struct e1000_hw *hw, uint16_t mask); +static int32_t e1000_check_phy_reset_block(struct e1000_hw *hw); #define E1000_WRITE_REG(a, reg, value) (writel((value), ((a)->hw_addr + E1000_##reg))) #define E1000_READ_REG(a, reg) (readl((a)->hw_addr + E1000_##reg)) #define E1000_WRITE_REG_ARRAY(a, reg, offset, value) (\ @@ -204,17 +233,17 @@ e1000_shift_out_ee_bits(struct e1000_hw *hw, uint16_t data, uint16_t count) * hw - Struct containing variables accessed by shared code *****************************************************************************/ static uint16_t -e1000_shift_in_ee_bits(struct e1000_hw *hw) +e1000_shift_in_ee_bits(struct e1000_hw *hw, uint16_t count) { uint32_t eecd; uint32_t i; uint16_t data;
- /* In order to read a register from the EEPROM, we need to shift 16 bits - * in from the EEPROM. Bits are "shifted in" by raising the clock input to - * the EEPROM (setting the SK bit), and then reading the value of the "DO" - * bit. During this "shifting in" process the "DI" bit should always be - * clear.. + /* In order to read a register from the EEPROM, we need to shift 'count' + * bits in from the EEPROM. Bits are "shifted in" by raising the clock + * input to the EEPROM (setting the SK bit), and then reading the + * value of the "DO" bit. During this "shifting in" process the + * "DI" bit should always be clear. */
eecd = E1000_READ_REG(hw, EECD); @@ -222,7 +251,7 @@ e1000_shift_in_ee_bits(struct e1000_hw *hw) eecd &= ~(E1000_EECD_DO | E1000_EECD_DI); data = 0;
- for (i = 0; i < 16; i++) { + for (i = 0; i < count; i++) { data = data << 1; e1000_raise_ee_clk(hw, &eecd);
@@ -239,213 +268,592 @@ e1000_shift_in_ee_bits(struct e1000_hw *hw) }
/****************************************************************************** - * Prepares EEPROM for access + * Returns EEPROM to a "standby" state * * hw - Struct containing variables accessed by shared code - * - * Lowers EEPROM clock. Clears input pin. Sets the chip select pin. This - * function should be called before issuing a command to the EEPROM. *****************************************************************************/ static void -e1000_setup_eeprom(struct e1000_hw *hw) +e1000_standby_eeprom(struct e1000_hw *hw) { + struct e1000_eeprom_info *eeprom = &hw->eeprom; uint32_t eecd;
- /* Clear SK and DI */ - eecd &= ~(E1000_EECD_SK | E1000_EECD_DI); - E1000_WRITE_REG(hw, EECD, eecd); + if (eeprom->type == e1000_eeprom_microwire) { + eecd &= ~(E1000_EECD_CS | E1000_EECD_SK); + E1000_WRITE_REG(hw, EECD, eecd); + E1000_WRITE_FLUSH(hw); + udelay(eeprom->delay_usec);
- /* Set CS */ - eecd |= E1000_EECD_CS; - E1000_WRITE_REG(hw, EECD, eecd); + /* Clock high */ + eecd |= E1000_EECD_SK; + E1000_WRITE_REG(hw, EECD, eecd); + E1000_WRITE_FLUSH(hw); + udelay(eeprom->delay_usec); + + /* Select EEPROM */ + eecd |= E1000_EECD_CS; + E1000_WRITE_REG(hw, EECD, eecd); + E1000_WRITE_FLUSH(hw); + udelay(eeprom->delay_usec); + + /* Clock low */ + eecd &= ~E1000_EECD_SK; + E1000_WRITE_REG(hw, EECD, eecd); + E1000_WRITE_FLUSH(hw); + udelay(eeprom->delay_usec); + } else if (eeprom->type == e1000_eeprom_spi) { + /* Toggle CS to flush commands */ + eecd |= E1000_EECD_CS; + E1000_WRITE_REG(hw, EECD, eecd); + E1000_WRITE_FLUSH(hw); + udelay(eeprom->delay_usec); + eecd &= ~E1000_EECD_CS; + E1000_WRITE_REG(hw, EECD, eecd); + E1000_WRITE_FLUSH(hw); + udelay(eeprom->delay_usec); + } +} + +/*************************************************************************** +* Description: Determines if the onboard NVM is FLASH or EEPROM. +* +* hw - Struct containing variables accessed by shared code +****************************************************************************/ +static boolean_t e1000_is_onboard_nvm_eeprom(struct e1000_hw *hw) +{ + uint32_t eecd = 0; + + DEBUGFUNC(); + + if (hw->mac_type == e1000_ich8lan) + return FALSE; + + if (hw->mac_type == e1000_82573) { + eecd = E1000_READ_REG(hw, EECD); + + /* Isolate bits 15 & 16 */ + eecd = ((eecd >> 15) & 0x03); + + /* If both bits are set, device is Flash type */ + if (eecd == 0x03) + return FALSE; + } + return TRUE; }
/****************************************************************************** - * Returns EEPROM to a "standby" state + * Prepares EEPROM for access * * hw - Struct containing variables accessed by shared code + * + * Lowers EEPROM clock. Clears input pin. Sets the chip select pin. This + * function should be called before issuing a command to the EEPROM. *****************************************************************************/ -static void -e1000_standby_eeprom(struct e1000_hw *hw) +static int32_t +e1000_acquire_eeprom(struct e1000_hw *hw) { - uint32_t eecd; + struct e1000_eeprom_info *eeprom = &hw->eeprom; + uint32_t eecd, i = 0; + + DEBUGOUT();
+ if (e1000_swfw_sync_acquire(hw, E1000_SWFW_EEP_SM)) + return -E1000_ERR_SWFW_SYNC; eecd = E1000_READ_REG(hw, EECD);
- /* Deselct EEPROM */ - eecd &= ~(E1000_EECD_CS | E1000_EECD_SK); - E1000_WRITE_REG(hw, EECD, eecd); - E1000_WRITE_FLUSH(hw); - udelay(50); + if (hw->mac_type != e1000_82573) { + /* Request EEPROM Access */ + if (hw->mac_type > e1000_82544) { + eecd |= E1000_EECD_REQ; + E1000_WRITE_REG(hw, EECD, eecd); + eecd = E1000_READ_REG(hw, EECD); + while ((!(eecd & E1000_EECD_GNT)) && + (i < E1000_EEPROM_GRANT_ATTEMPTS)) { + i++; + udelay(5); + eecd = E1000_READ_REG(hw, EECD); + } + if (!(eecd & E1000_EECD_GNT)) { + eecd &= ~E1000_EECD_REQ; + E1000_WRITE_REG(hw, EECD, eecd); + DEBUGOUT("Could not acquire EEPROM grant\n"); + return -E1000_ERR_EEPROM; + } + } + }
- /* Clock high */ - eecd |= E1000_EECD_SK; - E1000_WRITE_REG(hw, EECD, eecd); - E1000_WRITE_FLUSH(hw); - udelay(50); + /* Setup EEPROM for Read/Write */
- /* Select EEPROM */ - eecd |= E1000_EECD_CS; - E1000_WRITE_REG(hw, EECD, eecd); - E1000_WRITE_FLUSH(hw); - udelay(50); + if (eeprom->type == e1000_eeprom_microwire) { + /* Clear SK and DI */ + eecd &= ~(E1000_EECD_DI | E1000_EECD_SK); + E1000_WRITE_REG(hw, EECD, eecd);
- /* Clock low */ - eecd &= ~E1000_EECD_SK; - E1000_WRITE_REG(hw, EECD, eecd); - E1000_WRITE_FLUSH(hw); - udelay(50); + /* Set CS */ + eecd |= E1000_EECD_CS; + E1000_WRITE_REG(hw, EECD, eecd); + } else if (eeprom->type == e1000_eeprom_spi) { + /* Clear SK and CS */ + eecd &= ~(E1000_EECD_CS | E1000_EECD_SK); + E1000_WRITE_REG(hw, EECD, eecd); + udelay(1); + } + + return E1000_SUCCESS; }
/****************************************************************************** - * Reads a 16 bit word from the EEPROM. + * Sets up eeprom variables in the hw struct. Must be called after mac_type + * is configured. Additionally, if this is ICH8, the flash controller GbE + * registers must be mapped, or this will crash. * * hw - Struct containing variables accessed by shared code - * offset - offset of word in the EEPROM to read - * data - word read from the EEPROM *****************************************************************************/ -static int -e1000_read_eeprom(struct e1000_hw *hw, uint16_t offset, uint16_t * data) +static int32_t e1000_init_eeprom_params(struct e1000_hw *hw) { - uint32_t eecd; - uint32_t i = 0; - int large_eeprom = FALSE; + struct e1000_eeprom_info *eeprom = &hw->eeprom; + uint32_t eecd = E1000_READ_REG(hw, EECD); + int32_t ret_val = E1000_SUCCESS; + uint16_t eeprom_size;
- /* Request EEPROM Access */ - if (hw->mac_type > e1000_82544) { - eecd = E1000_READ_REG(hw, EECD); - if (eecd & E1000_EECD_SIZE) - large_eeprom = TRUE; - eecd |= E1000_EECD_REQ; - E1000_WRITE_REG(hw, EECD, eecd); - eecd = E1000_READ_REG(hw, EECD); - while ((!(eecd & E1000_EECD_GNT)) && (i < 100)) { - i++; - udelay(10); - eecd = E1000_READ_REG(hw, EECD); + DEBUGOUT(); + + switch (hw->mac_type) { + case e1000_82542_rev2_0: + case e1000_82542_rev2_1: + case e1000_82543: + case e1000_82544: + eeprom->type = e1000_eeprom_microwire; + eeprom->word_size = 64; + eeprom->opcode_bits = 3; + eeprom->address_bits = 6; + eeprom->delay_usec = 50; + eeprom->use_eerd = FALSE; + eeprom->use_eewr = FALSE; + break; + case e1000_82540: + case e1000_82545: + case e1000_82545_rev_3: + case e1000_82546: + case e1000_82546_rev_3: + eeprom->type = e1000_eeprom_microwire; + eeprom->opcode_bits = 3; + eeprom->delay_usec = 50; + if (eecd & E1000_EECD_SIZE) { + eeprom->word_size = 256; + eeprom->address_bits = 8; + } else { + eeprom->word_size = 64; + eeprom->address_bits = 6; + } + eeprom->use_eerd = FALSE; + eeprom->use_eewr = FALSE; + break; + case e1000_82541: + case e1000_82541_rev_2: + case e1000_82547: + case e1000_82547_rev_2: + if (eecd & E1000_EECD_TYPE) { + eeprom->type = e1000_eeprom_spi; + eeprom->opcode_bits = 8; + eeprom->delay_usec = 1; + if (eecd & E1000_EECD_ADDR_BITS) { + eeprom->page_size = 32; + eeprom->address_bits = 16; + } else { + eeprom->page_size = 8; + eeprom->address_bits = 8; + } + } else { + eeprom->type = e1000_eeprom_microwire; + eeprom->opcode_bits = 3; + eeprom->delay_usec = 50; + if (eecd & E1000_EECD_ADDR_BITS) { + eeprom->word_size = 256; + eeprom->address_bits = 8; + } else { + eeprom->word_size = 64; + eeprom->address_bits = 6; + } } - if (!(eecd & E1000_EECD_GNT)) { - eecd &= ~E1000_EECD_REQ; + eeprom->use_eerd = FALSE; + eeprom->use_eewr = FALSE; + break; + case e1000_82571: + case e1000_82572: + eeprom->type = e1000_eeprom_spi; + eeprom->opcode_bits = 8; + eeprom->delay_usec = 1; + if (eecd & E1000_EECD_ADDR_BITS) { + eeprom->page_size = 32; + eeprom->address_bits = 16; + } else { + eeprom->page_size = 8; + eeprom->address_bits = 8; + } + eeprom->use_eerd = FALSE; + eeprom->use_eewr = FALSE; + break; + case e1000_82573: + eeprom->type = e1000_eeprom_spi; + eeprom->opcode_bits = 8; + eeprom->delay_usec = 1; + if (eecd & E1000_EECD_ADDR_BITS) { + eeprom->page_size = 32; + eeprom->address_bits = 16; + } else { + eeprom->page_size = 8; + eeprom->address_bits = 8; + } + eeprom->use_eerd = TRUE; + eeprom->use_eewr = TRUE; + if (e1000_is_onboard_nvm_eeprom(hw) == FALSE) { + eeprom->type = e1000_eeprom_flash; + eeprom->word_size = 2048; + + /* Ensure that the Autonomous FLASH update bit is cleared due to + * Flash update issue on parts which use a FLASH for NVM. */ + eecd &= ~E1000_EECD_AUPDEN; E1000_WRITE_REG(hw, EECD, eecd); - DEBUGOUT("Could not acquire EEPROM grant\n"); - return -E1000_ERR_EEPROM; } - } - - /* Prepare the EEPROM for reading */ - e1000_setup_eeprom(hw); + break; + case e1000_80003es2lan: + eeprom->type = e1000_eeprom_spi; + eeprom->opcode_bits = 8; + eeprom->delay_usec = 1; + if (eecd & E1000_EECD_ADDR_BITS) { + eeprom->page_size = 32; + eeprom->address_bits = 16; + } else { + eeprom->page_size = 8; + eeprom->address_bits = 8; + } + eeprom->use_eerd = TRUE; + eeprom->use_eewr = FALSE; + break; + case e1000_ich8lan: + { +#if 0 + int32_t i = 0; + + eeprom->type = e1000_eeprom_ich8; + eeprom->use_eerd = FALSE; + eeprom->use_eewr = FALSE; + eeprom->word_size = E1000_SHADOW_RAM_WORDS; + uint32_t flash_size = E1000_READ_ICH_FLASH_REG(hw, + ICH_FLASH_GFPREG); + /* Zero the shadow RAM structure. But don't load it from NVM + * so as to save time for driver init */ + if (hw->eeprom_shadow_ram != NULL) { + for (i = 0; i < E1000_SHADOW_RAM_WORDS; i++) { + hw->eeprom_shadow_ram[i].modified = FALSE; + hw->eeprom_shadow_ram[i].eeprom_word = 0xFFFF; + } + }
- /* Send the READ command (opcode + addr) */ - e1000_shift_out_ee_bits(hw, EEPROM_READ_OPCODE, 3); - e1000_shift_out_ee_bits(hw, offset, (large_eeprom) ? 8 : 6); + hw->flash_base_addr = (flash_size & ICH_GFPREG_BASE_MASK) * + ICH_FLASH_SECTOR_SIZE;
- /* Read the data */ - *data = e1000_shift_in_ee_bits(hw); + hw->flash_bank_size = ((flash_size >> 16) + & ICH_GFPREG_BASE_MASK) + 1; + hw->flash_bank_size -= (flash_size & ICH_GFPREG_BASE_MASK);
- /* End this read operation */ - e1000_standby_eeprom(hw); + hw->flash_bank_size *= ICH_FLASH_SECTOR_SIZE;
- /* Stop requesting EEPROM access */ - if (hw->mac_type > e1000_82544) { - eecd = E1000_READ_REG(hw, EECD); - eecd &= ~E1000_EECD_REQ; - E1000_WRITE_REG(hw, EECD, eecd); + hw->flash_bank_size /= 2 * sizeof(uint16_t); +#endif + break; + } + default: + break; }
- return 0; + if (eeprom->type == e1000_eeprom_spi) { + /* eeprom_size will be an enum [0..8] that maps + * to eeprom sizes 128B to + * 32KB (incremented by powers of 2). + */ + if (hw->mac_type <= e1000_82547_rev_2) { + /* Set to default value for initial eeprom read. */ + eeprom->word_size = 64; + ret_val = e1000_read_eeprom(hw, EEPROM_CFG, 1, + &eeprom_size); + if (ret_val) + return ret_val; + eeprom_size = (eeprom_size & EEPROM_SIZE_MASK) + >> EEPROM_SIZE_SHIFT; + /* 256B eeprom size was not supported in earlier + * hardware, so we bump eeprom_size up one to + * ensure that "1" (which maps to 256B) is never + * the result used in the shifting logic below. */ + if (eeprom_size) + eeprom_size++; + } else { + eeprom_size = (uint16_t)((eecd & + E1000_EECD_SIZE_EX_MASK) >> + E1000_EECD_SIZE_EX_SHIFT); + } + + eeprom->word_size = 1 << (eeprom_size + EEPROM_WORD_SIZE_SHIFT); + } + return ret_val; }
-#if 0 -static void -e1000_eeprom_cleanup(struct e1000_hw *hw) +/****************************************************************************** + * Polls the status bit (bit 1) of the EERD to determine when the read is done. + * + * hw - Struct containing variables accessed by shared code + *****************************************************************************/ +static int32_t +e1000_poll_eerd_eewr_done(struct e1000_hw *hw, int eerd) { - uint32_t eecd; + uint32_t attempts = 100000; + uint32_t i, reg = 0; + int32_t done = E1000_ERR_EEPROM;
- eecd = E1000_READ_REG(hw, EECD); - eecd &= ~(E1000_EECD_CS | E1000_EECD_DI); - E1000_WRITE_REG(hw, EECD, eecd); - e1000_raise_ee_clk(hw, &eecd); - e1000_lower_ee_clk(hw, &eecd); + for (i = 0; i < attempts; i++) { + if (eerd == E1000_EEPROM_POLL_READ) + reg = E1000_READ_REG(hw, EERD); + else + reg = E1000_READ_REG(hw, EEWR); + + if (reg & E1000_EEPROM_RW_REG_DONE) { + done = E1000_SUCCESS; + break; + } + udelay(5); + } + + return done; }
-static uint16_t -e1000_wait_eeprom_done(struct e1000_hw *hw) +/****************************************************************************** + * Reads a 16 bit word from the EEPROM using the EERD register. + * + * hw - Struct containing variables accessed by shared code + * offset - offset of word in the EEPROM to read + * data - word read from the EEPROM + * words - number of words to read + *****************************************************************************/ +static int32_t +e1000_read_eeprom_eerd(struct e1000_hw *hw, + uint16_t offset, + uint16_t words, + uint16_t *data) { - uint32_t eecd; - uint32_t i; + uint32_t i, eerd = 0; + int32_t error = 0; + + for (i = 0; i < words; i++) { + eerd = ((offset+i) << E1000_EEPROM_RW_ADDR_SHIFT) + + E1000_EEPROM_RW_REG_START; + + E1000_WRITE_REG(hw, EERD, eerd); + error = e1000_poll_eerd_eewr_done(hw, E1000_EEPROM_POLL_READ); + + if (error) + break; + data[i] = (E1000_READ_REG(hw, EERD) >> + E1000_EEPROM_RW_REG_DATA);
- e1000_standby_eeprom(hw); - for (i = 0; i < 200; i++) { - eecd = E1000_READ_REG(hw, EECD); - if (eecd & E1000_EECD_DO) - return (TRUE); - udelay(5); } - return (FALSE); + + return error; }
-static int -e1000_write_eeprom(struct e1000_hw *hw, uint16_t Reg, uint16_t Data) +static void +e1000_release_eeprom(struct e1000_hw *hw) { uint32_t eecd; - int large_eeprom = FALSE; - int i = 0;
- /* Request EEPROM Access */ - if (hw->mac_type > e1000_82544) { - eecd = E1000_READ_REG(hw, EECD); - if (eecd & E1000_EECD_SIZE) - large_eeprom = TRUE; - eecd |= E1000_EECD_REQ; + DEBUGFUNC(); + + eecd = E1000_READ_REG(hw, EECD); + + if (hw->eeprom.type == e1000_eeprom_spi) { + eecd |= E1000_EECD_CS; /* Pull CS high */ + eecd &= ~E1000_EECD_SK; /* Lower SCK */ + E1000_WRITE_REG(hw, EECD, eecd); - eecd = E1000_READ_REG(hw, EECD); - while ((!(eecd & E1000_EECD_GNT)) && (i < 100)) { - i++; - udelay(5); - eecd = E1000_READ_REG(hw, EECD); - } - if (!(eecd & E1000_EECD_GNT)) { - eecd &= ~E1000_EECD_REQ; - E1000_WRITE_REG(hw, EECD, eecd); - DEBUGOUT("Could not acquire EEPROM grant\n"); - return FALSE; - } - } - e1000_setup_eeprom(hw); - e1000_shift_out_ee_bits(hw, EEPROM_EWEN_OPCODE, 5); - e1000_shift_out_ee_bits(hw, Reg, (large_eeprom) ? 6 : 4); - e1000_standby_eeprom(hw); - e1000_shift_out_ee_bits(hw, EEPROM_WRITE_OPCODE, 3); - e1000_shift_out_ee_bits(hw, Reg, (large_eeprom) ? 8 : 6); - e1000_shift_out_ee_bits(hw, Data, 16); - if (!e1000_wait_eeprom_done(hw)) { - return FALSE; + + udelay(hw->eeprom.delay_usec); + } else if (hw->eeprom.type == e1000_eeprom_microwire) { + /* cleanup eeprom */ + + /* CS on Microwire is active-high */ + eecd &= ~(E1000_EECD_CS | E1000_EECD_DI); + + E1000_WRITE_REG(hw, EECD, eecd); + + /* Rising edge of clock */ + eecd |= E1000_EECD_SK; + E1000_WRITE_REG(hw, EECD, eecd); + E1000_WRITE_FLUSH(hw); + udelay(hw->eeprom.delay_usec); + + /* Falling edge of clock */ + eecd &= ~E1000_EECD_SK; + E1000_WRITE_REG(hw, EECD, eecd); + E1000_WRITE_FLUSH(hw); + udelay(hw->eeprom.delay_usec); } - e1000_shift_out_ee_bits(hw, EEPROM_EWDS_OPCODE, 5); - e1000_shift_out_ee_bits(hw, Reg, (large_eeprom) ? 6 : 4); - e1000_eeprom_cleanup(hw);
/* Stop requesting EEPROM access */ if (hw->mac_type > e1000_82544) { - eecd = E1000_READ_REG(hw, EECD); eecd &= ~E1000_EECD_REQ; E1000_WRITE_REG(hw, EECD, eecd); } - i = 0; - eecd = E1000_READ_REG(hw, EECD); - while (((eecd & E1000_EECD_GNT)) && (i < 500)) { - i++; - udelay(10); - eecd = E1000_READ_REG(hw, EECD); - } - if ((eecd & E1000_EECD_GNT)) { - DEBUGOUT("Could not release EEPROM grant\n"); +} +/****************************************************************************** + * Reads a 16 bit word from the EEPROM. + * + * hw - Struct containing variables accessed by shared code + *****************************************************************************/ +static int32_t +e1000_spi_eeprom_ready(struct e1000_hw *hw) +{ + uint16_t retry_count = 0; + uint8_t spi_stat_reg; + + DEBUGFUNC(); + + /* Read "Status Register" repeatedly until the LSB is cleared. The + * EEPROM will signal that the command has been completed by clearing + * bit 0 of the internal status register. If it's not cleared within + * 5 milliseconds, then error out. + */ + retry_count = 0; + do { + e1000_shift_out_ee_bits(hw, EEPROM_RDSR_OPCODE_SPI, + hw->eeprom.opcode_bits); + spi_stat_reg = (uint8_t)e1000_shift_in_ee_bits(hw, 8); + if (!(spi_stat_reg & EEPROM_STATUS_RDY_SPI)) + break; + + udelay(5); + retry_count += 5; + + e1000_standby_eeprom(hw); + } while (retry_count < EEPROM_MAX_RETRY_SPI); + + /* ATMEL SPI write time could vary from 0-20mSec on 3.3V devices (and + * only 0-5mSec on 5V devices) + */ + if (retry_count >= EEPROM_MAX_RETRY_SPI) { + DEBUGOUT("SPI EEPROM Status error\n"); + return -E1000_ERR_EEPROM; } - return TRUE; + + return E1000_SUCCESS; } + +/****************************************************************************** + * Reads a 16 bit word from the EEPROM. + * + * hw - Struct containing variables accessed by shared code + * offset - offset of word in the EEPROM to read + * data - word read from the EEPROM + *****************************************************************************/ +static int32_t +e1000_read_eeprom(struct e1000_hw *hw, uint16_t offset, + uint16_t words, uint16_t *data) +{ + struct e1000_eeprom_info *eeprom = &hw->eeprom; + uint32_t i = 0; + + DEBUGFUNC(); + + /* If eeprom is not yet detected, do so now */ + if (eeprom->word_size == 0) + e1000_init_eeprom_params(hw); + + /* A check for invalid values: offset too large, too many words, + * and not enough words. + */ + if ((offset >= eeprom->word_size) || + (words > eeprom->word_size - offset) || + (words == 0)) { + DEBUGOUT(""words" parameter out of bounds." + "Words = %d, size = %d\n", offset, eeprom->word_size); + return -E1000_ERR_EEPROM; + } + + /* EEPROM's that don't use EERD to read require us to bit-bang the SPI + * directly. In this case, we need to acquire the EEPROM so that + * FW or other port software does not interrupt. + */ + if (e1000_is_onboard_nvm_eeprom(hw) == TRUE && + hw->eeprom.use_eerd == FALSE) { + + /* Prepare the EEPROM for bit-bang reading */ + if (e1000_acquire_eeprom(hw) != E1000_SUCCESS) + return -E1000_ERR_EEPROM; + } + + /* Eerd register EEPROM access requires no eeprom aquire/release */ + if (eeprom->use_eerd == TRUE) + return e1000_read_eeprom_eerd(hw, offset, words, data); +#if 0 + /* ICH EEPROM access is done via the ICH flash controller */ + if (eeprom->type == e1000_eeprom_ich8) + return e1000_read_eeprom_ich8(hw, offset, words, data); #endif + /* Set up the SPI or Microwire EEPROM for bit-bang reading. We have + * acquired the EEPROM at this point, so any returns should relase it */ + if (eeprom->type == e1000_eeprom_spi) { + uint16_t word_in; + uint8_t read_opcode = EEPROM_READ_OPCODE_SPI; + + if (e1000_spi_eeprom_ready(hw)) { + e1000_release_eeprom(hw); + return -E1000_ERR_EEPROM; + } + + e1000_standby_eeprom(hw); + + /* Some SPI eeproms use the 8th address bit embedded in + * the opcode */ + if ((eeprom->address_bits == 8) && (offset >= 128)) + read_opcode |= EEPROM_A8_OPCODE_SPI; + + /* Send the READ command (opcode + addr) */ + e1000_shift_out_ee_bits(hw, read_opcode, eeprom->opcode_bits); + e1000_shift_out_ee_bits(hw, (uint16_t)(offset*2), + eeprom->address_bits); + + /* Read the data. The address of the eeprom internally + * increments with each byte (spi) being read, saving on the + * overhead of eeprom setup and tear-down. The address + * counter will roll over if reading beyond the size of + * the eeprom, thus allowing the entire memory to be read + * starting from any offset. */ + for (i = 0; i < words; i++) { + word_in = e1000_shift_in_ee_bits(hw, 16); + data[i] = (word_in >> 8) | (word_in << 8); + } + } else if (eeprom->type == e1000_eeprom_microwire) { + for (i = 0; i < words; i++) { + /* Send the READ command (opcode + addr) */ + e1000_shift_out_ee_bits(hw, + EEPROM_READ_OPCODE_MICROWIRE, + eeprom->opcode_bits); + e1000_shift_out_ee_bits(hw, (uint16_t)(offset + i), + eeprom->address_bits); + + /* Read the data. For microwire, each word requires + * the overhead of eeprom setup and tear-down. */ + data[i] = e1000_shift_in_ee_bits(hw, 16); + e1000_standby_eeprom(hw); + } + } + + /* End this read operation */ + e1000_release_eeprom(hw); + + return E1000_SUCCESS; +}
/****************************************************************************** * Verifies that the EEPROM has a valid checksum @@ -466,7 +874,7 @@ e1000_validate_eeprom_checksum(struct eth_device *nic) DEBUGFUNC();
for (i = 0; i < (EEPROM_CHECKSUM_REG + 1); i++) { - if (e1000_read_eeprom(hw, i, &eeprom_data) < 0) { + if (e1000_read_eeprom(hw, i, 1, &eeprom_data) < 0) { DEBUGOUT("EEPROM Read Error\n"); return -E1000_ERR_EEPROM; } @@ -482,6 +890,169 @@ e1000_validate_eeprom_checksum(struct eth_device *nic) } #endif /* #ifndef CONFIG_AP1000 */
+/*************************************************************************** + * + * Obtaining software semaphore bit (SMBI) before resetting PHY. + * + * hw: Struct containing variables accessed by shared code + * + * returns: - E1000_ERR_RESET if fail to obtain semaphore. + * E1000_SUCCESS at any other case. + * + ***************************************************************************/ +static int32_t +e1000_get_software_semaphore(struct e1000_hw *hw) +{ + int32_t timeout = hw->eeprom.word_size + 1; + uint32_t swsm; + + DEBUGFUNC(); + + if (hw->mac_type != e1000_80003es2lan) + return E1000_SUCCESS; + + while (timeout) { + swsm = E1000_READ_REG(hw, SWSM); + /* If SMBI bit cleared, it is now set and we hold + * the semaphore */ + if (!(swsm & E1000_SWSM_SMBI)) + break; + mdelay(1); + timeout--; + } + + if (!timeout) { + DEBUGOUT("Driver can't access device - SMBI bit is set.\n"); + return -E1000_ERR_RESET; + } + + return E1000_SUCCESS; +} + +/*************************************************************************** + * This function clears HW semaphore bits. + * + * hw: Struct containing variables accessed by shared code + * + * returns: - None. + * + ***************************************************************************/ +static void +e1000_put_hw_eeprom_semaphore(struct e1000_hw *hw) +{ + uint32_t swsm; + + DEBUGFUNC(); + + if (!hw->eeprom_semaphore_present) + return; + + swsm = E1000_READ_REG(hw, SWSM); + if (hw->mac_type == e1000_80003es2lan) { + /* Release both semaphores. */ + swsm &= ~(E1000_SWSM_SMBI | E1000_SWSM_SWESMBI); + } else + swsm &= ~(E1000_SWSM_SWESMBI); + E1000_WRITE_REG(hw, SWSM, swsm); +} + +/*************************************************************************** + * + * Using the combination of SMBI and SWESMBI semaphore bits when resetting + * adapter or Eeprom access. + * + * hw: Struct containing variables accessed by shared code + * + * returns: - E1000_ERR_EEPROM if fail to access EEPROM. + * E1000_SUCCESS at any other case. + * + ***************************************************************************/ +static int32_t +e1000_get_hw_eeprom_semaphore(struct e1000_hw *hw) +{ + int32_t timeout; + uint32_t swsm; + + DEBUGFUNC(); + + if (!hw->eeprom_semaphore_present) + return E1000_SUCCESS; + + if (hw->mac_type == e1000_80003es2lan) { + /* Get the SW semaphore. */ + if (e1000_get_software_semaphore(hw) != E1000_SUCCESS) + return -E1000_ERR_EEPROM; + } + + /* Get the FW semaphore. */ + timeout = hw->eeprom.word_size + 1; + while (timeout) { + swsm = E1000_READ_REG(hw, SWSM); + swsm |= E1000_SWSM_SWESMBI; + E1000_WRITE_REG(hw, SWSM, swsm); + /* if we managed to set the bit we got the semaphore. */ + swsm = E1000_READ_REG(hw, SWSM); + if (swsm & E1000_SWSM_SWESMBI) + break; + + udelay(50); + timeout--; + } + + if (!timeout) { + /* Release semaphores */ + e1000_put_hw_eeprom_semaphore(hw); + DEBUGOUT("Driver can't access the Eeprom - " + "SWESMBI bit is set.\n"); + return -E1000_ERR_EEPROM; + } + + return E1000_SUCCESS; +} + +static int32_t +e1000_swfw_sync_acquire(struct e1000_hw *hw, uint16_t mask) +{ + uint32_t swfw_sync = 0; + uint32_t swmask = mask; + uint32_t fwmask = mask << 16; + int32_t timeout = 200; + + DEBUGFUNC(); +#if 0 + if (hw->swfwhw_semaphore_present) + return e1000_get_software_flag(hw); + + if (!hw->swfw_sync_present) + return e1000_get_hw_eeprom_semaphore(hw); +#endif + while (timeout) { + if (e1000_get_hw_eeprom_semaphore(hw)) + return -E1000_ERR_SWFW_SYNC; + + swfw_sync = E1000_READ_REG(hw, SW_FW_SYNC); + if (!(swfw_sync & (fwmask | swmask))) + break; + + /* firmware currently using resource (fwmask) */ + /* or other software thread currently using resource (swmask) */ + e1000_put_hw_eeprom_semaphore(hw); + mdelay(5); + timeout--; + } + + if (!timeout) { + DEBUGOUT("Driver can't access resource, SW_FW_SYNC timeout.\n"); + return -E1000_ERR_SWFW_SYNC; + } + + swfw_sync |= swmask; + E1000_WRITE_REG(hw, SW_FW_SYNC, swfw_sync); + + e1000_put_hw_eeprom_semaphore(hw); + return E1000_SUCCESS; +} + /****************************************************************************** * Reads the adapter's MAC address from the EEPROM and inverts the LSB for the * second function of dual function devices @@ -501,7 +1072,7 @@ e1000_read_mac_addr(struct eth_device *nic)
for (i = 0; i < NODE_ADDRESS_SIZE; i += 2) { offset = i >> 1; - if (e1000_read_eeprom(hw, offset, &eeprom_data) < 0) { + if (e1000_read_eeprom(hw, offset, 1, &eeprom_data) < 0) { DEBUGOUT("EEPROM Read Error\n"); return -E1000_ERR_EEPROM; } @@ -605,7 +1176,7 @@ e1000_clear_vfta(struct e1000_hw *hw) * * hw - Struct containing variables accessed by shared code *****************************************************************************/ -static int +int32_t e1000_set_mac_type(struct e1000_hw *hw) { DEBUGFUNC(); @@ -636,21 +1207,88 @@ e1000_set_mac_type(struct e1000_hw *hw) break; case E1000_DEV_ID_82540EM: case E1000_DEV_ID_82540EM_LOM: + case E1000_DEV_ID_82540EP: + case E1000_DEV_ID_82540EP_LOM: + case E1000_DEV_ID_82540EP_LP: hw->mac_type = e1000_82540; break; case E1000_DEV_ID_82545EM_COPPER: - case E1000_DEV_ID_82545GM_COPPER: case E1000_DEV_ID_82545EM_FIBER: hw->mac_type = e1000_82545; break; + case E1000_DEV_ID_82545GM_COPPER: + case E1000_DEV_ID_82545GM_FIBER: + case E1000_DEV_ID_82545GM_SERDES: + hw->mac_type = e1000_82545_rev_3; + break; case E1000_DEV_ID_82546EB_COPPER: case E1000_DEV_ID_82546EB_FIBER: + case E1000_DEV_ID_82546EB_QUAD_COPPER: hw->mac_type = e1000_82546; break; + case E1000_DEV_ID_82546GB_COPPER: + case E1000_DEV_ID_82546GB_FIBER: + case E1000_DEV_ID_82546GB_SERDES: + case E1000_DEV_ID_82546GB_PCIE: + case E1000_DEV_ID_82546GB_QUAD_COPPER: + case E1000_DEV_ID_82546GB_QUAD_COPPER_KSP3: + hw->mac_type = e1000_82546_rev_3; + break; + case E1000_DEV_ID_82541EI: + case E1000_DEV_ID_82541EI_MOBILE: + case E1000_DEV_ID_82541ER_LOM: + hw->mac_type = e1000_82541; + break; case E1000_DEV_ID_82541ER: + case E1000_DEV_ID_82541GI: case E1000_DEV_ID_82541GI_LF: + case E1000_DEV_ID_82541GI_MOBILE: hw->mac_type = e1000_82541_rev_2; break; + case E1000_DEV_ID_82547EI: + case E1000_DEV_ID_82547EI_MOBILE: + hw->mac_type = e1000_82547; + break; + case E1000_DEV_ID_82547GI: + hw->mac_type = e1000_82547_rev_2; + break; + case E1000_DEV_ID_82571EB_COPPER: + case E1000_DEV_ID_82571EB_FIBER: + case E1000_DEV_ID_82571EB_SERDES: + case E1000_DEV_ID_82571EB_SERDES_DUAL: + case E1000_DEV_ID_82571EB_SERDES_QUAD: + case E1000_DEV_ID_82571EB_QUAD_COPPER: + case E1000_DEV_ID_82571PT_QUAD_COPPER: + case E1000_DEV_ID_82571EB_QUAD_FIBER: + case E1000_DEV_ID_82571EB_QUAD_COPPER_LOWPROFILE: + hw->mac_type = e1000_82571; + break; + case E1000_DEV_ID_82572EI_COPPER: + case E1000_DEV_ID_82572EI_FIBER: + case E1000_DEV_ID_82572EI_SERDES: + case E1000_DEV_ID_82572EI: + hw->mac_type = e1000_82572; + break; + case E1000_DEV_ID_82573E: + case E1000_DEV_ID_82573E_IAMT: + case E1000_DEV_ID_82573L: + hw->mac_type = e1000_82573; + break; + case E1000_DEV_ID_80003ES2LAN_COPPER_SPT: + case E1000_DEV_ID_80003ES2LAN_SERDES_SPT: + case E1000_DEV_ID_80003ES2LAN_COPPER_DPT: + case E1000_DEV_ID_80003ES2LAN_SERDES_DPT: + hw->mac_type = e1000_80003es2lan; + break; + case E1000_DEV_ID_ICH8_IGP_M_AMT: + case E1000_DEV_ID_ICH8_IGP_AMT: + case E1000_DEV_ID_ICH8_IGP_C: + case E1000_DEV_ID_ICH8_IFE: + case E1000_DEV_ID_ICH8_IFE_GT: + case E1000_DEV_ID_ICH8_IFE_G: + case E1000_DEV_ID_ICH8_IGP_M: + hw->mac_type = e1000_ich8lan; + break; default: /* Should never have loaded on this device */ return -E1000_ERR_MAC_TYPE; @@ -677,8 +1315,7 @@ e1000_reset_hw(struct e1000_hw *hw) if (hw->mac_type == e1000_82542_rev2_0) { DEBUGOUT("Disabling MWI on 82542 rev 2.0\n"); pci_write_config_word(hw->pdev, PCI_COMMAND, - hw-> - pci_cmd_word & ~PCI_COMMAND_INVALIDATE); + hw->pci_cmd_word & ~PCI_COMMAND_INVALIDATE); }
/* Clear interrupt mask to stop board from generating interrupts */ @@ -746,6 +1383,127 @@ e1000_reset_hw(struct e1000_hw *hw) if (hw->mac_type == e1000_82542_rev2_0) { pci_write_config_word(hw->pdev, PCI_COMMAND, hw->pci_cmd_word); } + E1000_WRITE_REG(hw, PBA, E1000_DEFAULT_PBA); +} + +/****************************************************************************** + * + * Initialize a number of hardware-dependent bits + * + * hw: Struct containing variables accessed by shared code + * + * This function contains hardware limitation workarounds for PCI-E adapters + * + *****************************************************************************/ +static void +e1000_initialize_hardware_bits(struct e1000_hw *hw) +{ + if ((hw->mac_type >= e1000_82571) && + (!hw->initialize_hw_bits_disable)) { + /* Settings common to all PCI-express silicon */ + uint32_t reg_ctrl, reg_ctrl_ext; + uint32_t reg_tarc0, reg_tarc1; + uint32_t reg_tctl; + uint32_t reg_txdctl, reg_txdctl1; + + /* link autonegotiation/sync workarounds */ + reg_tarc0 = E1000_READ_REG(hw, TARC0); + reg_tarc0 &= ~((1 << 30)|(1 << 29)|(1 << 28)|(1 << 27)); + + /* Enable not-done TX descriptor counting */ + reg_txdctl = E1000_READ_REG(hw, TXDCTL); + reg_txdctl |= E1000_TXDCTL_COUNT_DESC; + E1000_WRITE_REG(hw, TXDCTL, reg_txdctl); + + reg_txdctl1 = E1000_READ_REG(hw, TXDCTL1); + reg_txdctl1 |= E1000_TXDCTL_COUNT_DESC; + E1000_WRITE_REG(hw, TXDCTL1, reg_txdctl1); + + switch (hw->mac_type) { + case e1000_82571: + case e1000_82572: + /* Clear PHY TX compatible mode bits */ + reg_tarc1 = E1000_READ_REG(hw, TARC1); + reg_tarc1 &= ~((1 << 30)|(1 << 29)); + + /* link autonegotiation/sync workarounds */ + reg_tarc0 |= ((1 << 26)|(1 << 25)|(1 << 24)|(1 << 23)); + + /* TX ring control fixes */ + reg_tarc1 |= ((1 << 26)|(1 << 25)|(1 << 24)); + + /* Multiple read bit is reversed polarity */ + reg_tctl = E1000_READ_REG(hw, TCTL); + if (reg_tctl & E1000_TCTL_MULR) + reg_tarc1 &= ~(1 << 28); + else + reg_tarc1 |= (1 << 28); + + E1000_WRITE_REG(hw, TARC1, reg_tarc1); + break; + case e1000_82573: + reg_ctrl_ext = E1000_READ_REG(hw, CTRL_EXT); + reg_ctrl_ext &= ~(1 << 23); + reg_ctrl_ext |= (1 << 22); + + /* TX byte count fix */ + reg_ctrl = E1000_READ_REG(hw, CTRL); + reg_ctrl &= ~(1 << 29); + + E1000_WRITE_REG(hw, CTRL_EXT, reg_ctrl_ext); + E1000_WRITE_REG(hw, CTRL, reg_ctrl); + break; + case e1000_80003es2lan: + /* improve small packet performace for fiber/serdes */ + if ((hw->media_type == e1000_media_type_fiber) + || (hw->media_type == + e1000_media_type_internal_serdes)) { + reg_tarc0 &= ~(1 << 20); + } + + /* Multiple read bit is reversed polarity */ + reg_tctl = E1000_READ_REG(hw, TCTL); + reg_tarc1 = E1000_READ_REG(hw, TARC1); + if (reg_tctl & E1000_TCTL_MULR) + reg_tarc1 &= ~(1 << 28); + else + reg_tarc1 |= (1 << 28); + + E1000_WRITE_REG(hw, TARC1, reg_tarc1); + break; + case e1000_ich8lan: + /* Reduce concurrent DMA requests to 3 from 4 */ + if ((hw->revision_id < 3) || + ((hw->device_id != E1000_DEV_ID_ICH8_IGP_M_AMT) && + (hw->device_id != E1000_DEV_ID_ICH8_IGP_M))) + reg_tarc0 |= ((1 << 29)|(1 << 28)); + + reg_ctrl_ext = E1000_READ_REG(hw, CTRL_EXT); + reg_ctrl_ext |= (1 << 22); + E1000_WRITE_REG(hw, CTRL_EXT, reg_ctrl_ext); + + /* workaround TX hang with TSO=on */ + reg_tarc0 |= ((1 << 27)|(1 << 26)|(1 << 24)|(1 << 23)); + + /* Multiple read bit is reversed polarity */ + reg_tctl = E1000_READ_REG(hw, TCTL); + reg_tarc1 = E1000_READ_REG(hw, TARC1); + if (reg_tctl & E1000_TCTL_MULR) + reg_tarc1 &= ~(1 << 28); + else + reg_tarc1 |= (1 << 28); + + /* workaround TX hang with TSO=on */ + reg_tarc1 |= ((1 << 30)|(1 << 26)|(1 << 24)); + + E1000_WRITE_REG(hw, TARC1, reg_tarc1); + break; + default: + break; + } + + E1000_WRITE_REG(hw, TARC0, reg_tarc0); + } }
/****************************************************************************** @@ -763,49 +1521,43 @@ static int e1000_init_hw(struct eth_device *nic) { struct e1000_hw *hw = nic->priv; - uint32_t ctrl, status; + uint32_t ctrl; uint32_t i; int32_t ret_val; uint16_t pcix_cmd_word; uint16_t pcix_stat_hi_word; uint16_t cmd_mmrbc; uint16_t stat_mmrbc; - e1000_bus_type bus_type = e1000_bus_type_unknown; - + uint32_t mta_size; + uint32_t reg_data; + uint32_t ctrl_ext; DEBUGFUNC(); -#if 0 - /* Initialize Identification LED */ - ret_val = e1000_id_led_init(hw); - if (ret_val < 0) { - DEBUGOUT("Error Initializing Identification LED\n"); - return ret_val; - } -#endif - /* Set the Media Type and exit with error if it is not valid. */ - if (hw->mac_type != e1000_82543) { - /* tbi_compatibility is only valid on 82543 */ - hw->tbi_compatibility_en = FALSE; + /* force full DMA clock frequency for 10/100 on ICH8 A0-B0 */ + if ((hw->mac_type == e1000_ich8lan) && + ((hw->revision_id < 3) || + ((hw->device_id != E1000_DEV_ID_ICH8_IGP_M_AMT) && + (hw->device_id != E1000_DEV_ID_ICH8_IGP_M)))) { + reg_data = E1000_READ_REG(hw, STATUS); + reg_data &= ~0x80000000; + E1000_WRITE_REG(hw, STATUS, reg_data); } + /* Do not need initialize Identification LED */
- if (hw->mac_type >= e1000_82543) { - status = E1000_READ_REG(hw, STATUS); - if (status & E1000_STATUS_TBIMODE) { - hw->media_type = e1000_media_type_fiber; - /* tbi_compatibility not valid on fiber */ - hw->tbi_compatibility_en = FALSE; - } else { - hw->media_type = e1000_media_type_copper; - } - } else { - /* This is an 82542 (fiber only) */ - hw->media_type = e1000_media_type_fiber; - } + /* Set the media type and TBI compatibility */ + e1000_set_media_type(hw); + + /* Must be called after e1000_set_media_type + * because media_type is used */ + e1000_initialize_hardware_bits(hw);
/* Disabling VLAN filtering. */ DEBUGOUT("Initializing the IEEE VLAN\n"); - E1000_WRITE_REG(hw, VET, 0); - - e1000_clear_vfta(hw); + /* VET hardcoded to standard value and VFTA removed in ICH8 LAN */ + if (hw->mac_type != e1000_ich8lan) { + if (hw->mac_type < e1000_82545_rev_3) + E1000_WRITE_REG(hw, VET, 0); + e1000_clear_vfta(hw); + }
/* For 82542 (rev 2.0), disable MWI and put the receiver into reset */ if (hw->mac_type == e1000_82542_rev2_0) { @@ -833,26 +1585,34 @@ e1000_init_hw(struct eth_device *nic)
/* Zero out the Multicast HASH table */ DEBUGOUT("Zeroing the MTA\n"); - for (i = 0; i < E1000_MC_TBL_SIZE; i++) + mta_size = E1000_MC_TBL_SIZE; + if (hw->mac_type == e1000_ich8lan) + mta_size = E1000_MC_TBL_SIZE_ICH8LAN; + for (i = 0; i < mta_size; i++) { E1000_WRITE_REG_ARRAY(hw, MTA, i, 0); + /* use write flush to prevent Memory Write Block (MWB) from + * occuring when accessing our register space */ + E1000_WRITE_FLUSH(hw); + }
#if 0 /* Set the PCI priority bit correctly in the CTRL register. This * determines if the adapter gives priority to receives, or if it - * gives equal priority to transmits and receives. + * gives equal priority to transmits and receives. Valid only on + * 82542 and 82543 silicon. */ - if (hw->dma_fairness) { + if (hw->dma_fairness && hw->mac_type <= e1000_82543) { ctrl = E1000_READ_REG(hw, CTRL); E1000_WRITE_REG(hw, CTRL, ctrl | E1000_CTRL_PRIOR); } #endif - if (hw->mac_type >= e1000_82543) { - status = E1000_READ_REG(hw, STATUS); - bus_type = (status & E1000_STATUS_PCIX_MODE) ? - e1000_bus_type_pcix : e1000_bus_type_pci; - } + switch (hw->mac_type) { + case e1000_82545_rev_3: + case e1000_82546_rev_3: + break; + default: /* Workaround for PCI-X problem when BIOS sets MMRBC incorrectly. */ - if (bus_type == e1000_bus_type_pcix) { + if (hw->bus_type == e1000_bus_type_pcix) { pci_read_config_word(hw->pdev, PCIX_COMMAND_REGISTER, &pcix_cmd_word); pci_read_config_word(hw->pdev, PCIX_STATUS_REGISTER_HI, @@ -872,6 +1632,12 @@ e1000_init_hw(struct eth_device *nic) pcix_cmd_word); } } + break; + } + + /* More time needed for PHY to initialize */ + if (hw->mac_type == e1000_ich8lan) + mdelay(15);
/* Call a subroutine to configure the link and setup flow control. */ ret_val = e1000_setup_link(nic); @@ -884,6 +1650,48 @@ e1000_init_hw(struct eth_device *nic) E1000_TXDCTL_FULL_TX_DESC_WB; E1000_WRITE_REG(hw, TXDCTL, ctrl); } + + switch (hw->mac_type) { + default: + break; + case e1000_80003es2lan: + /* Enable retransmit on late collisions */ + reg_data = E1000_READ_REG(hw, TCTL); + reg_data |= E1000_TCTL_RTLC; + E1000_WRITE_REG(hw, TCTL, reg_data); + + /* Configure Gigabit Carry Extend Padding */ + reg_data = E1000_READ_REG(hw, TCTL_EXT); + reg_data &= ~E1000_TCTL_EXT_GCEX_MASK; + reg_data |= DEFAULT_80003ES2LAN_TCTL_EXT_GCEX; + E1000_WRITE_REG(hw, TCTL_EXT, reg_data); + + /* Configure Transmit Inter-Packet Gap */ + reg_data = E1000_READ_REG(hw, TIPG); + reg_data &= ~E1000_TIPG_IPGT_MASK; + reg_data |= DEFAULT_80003ES2LAN_TIPG_IPGT_1000; + E1000_WRITE_REG(hw, TIPG, reg_data); + + reg_data = E1000_READ_REG_ARRAY(hw, FFLT, 0x0001); + reg_data &= ~0x00100000; + E1000_WRITE_REG_ARRAY(hw, FFLT, 0x0001, reg_data); + /* Fall through */ + case e1000_82571: + case e1000_82572: + case e1000_ich8lan: + ctrl = E1000_READ_REG(hw, TXDCTL1); + ctrl = (ctrl & ~E1000_TXDCTL_WTHRESH) + | E1000_TXDCTL_FULL_TX_DESC_WB; + E1000_WRITE_REG(hw, TXDCTL1, ctrl); + break; + } + + if (hw->mac_type == e1000_82573) { + uint32_t gcr = E1000_READ_REG(hw, GCR); + gcr |= E1000_GCR_L1_ACT_WITHOUT_L0S_RX; + E1000_WRITE_REG(hw, GCR, gcr); + } + #if 0 /* Clear all of the statistics registers (clear on read). It is * important that we do this after we have tried to establish link @@ -891,8 +1699,22 @@ e1000_init_hw(struct eth_device *nic) * is no link. */ e1000_clear_hw_cntrs(hw); + + /* ICH8 No-snoop bits are opposite polarity. + * Set to snoop by default after reset. */ + if (hw->mac_type == e1000_ich8lan) + e1000_set_pci_ex_no_snoop(hw, PCI_EX_82566_SNOOP_ALL); #endif
+ if (hw->device_id == E1000_DEV_ID_82546GB_QUAD_COPPER || + hw->device_id == E1000_DEV_ID_82546GB_QUAD_COPPER_KSP3) { + ctrl_ext = E1000_READ_REG(hw, CTRL_EXT); + /* Relaxed ordering must be disabled to avoid a parity + * error crash in a PCI slot. */ + ctrl_ext |= E1000_CTRL_EXT_RO_DIS; + E1000_WRITE_REG(hw, CTRL_EXT, ctrl_ext); + } + return ret_val; }
@@ -917,6 +1739,11 @@ e1000_setup_link(struct eth_device *nic)
DEBUGFUNC();
+ /* In the case of the phy reset being blocked, we already have a link. + * We do not have to set it up again. */ + if (e1000_check_phy_reset_block(hw)) + return E1000_SUCCESS; + #ifndef CONFIG_AP1000 /* Read and store word 0x0F of the EEPROM. This word contains bits * that determine the hardware's default PAUSE (flow control) mode, @@ -926,7 +1753,8 @@ e1000_setup_link(struct eth_device *nic) * control setting, then the variable hw->fc will * be initialized based on a value in the EEPROM. */ - if (e1000_read_eeprom(hw, EEPROM_INIT_CONTROL2_REG, &eeprom_data) < 0) { + if (e1000_read_eeprom(hw, EEPROM_INIT_CONTROL2_REG, 1, + &eeprom_data) < 0) { DEBUGOUT("EEPROM Read Error\n"); return -E1000_ERR_EEPROM; } @@ -937,13 +1765,31 @@ e1000_setup_link(struct eth_device *nic) #endif
if (hw->fc == e1000_fc_default) { - if ((eeprom_data & EEPROM_WORD0F_PAUSE_MASK) == 0) - hw->fc = e1000_fc_none; - else if ((eeprom_data & EEPROM_WORD0F_PAUSE_MASK) == - EEPROM_WORD0F_ASM_DIR) - hw->fc = e1000_fc_tx_pause; - else + switch (hw->mac_type) { + case e1000_ich8lan: + case e1000_82573: hw->fc = e1000_fc_full; + break; + default: +#ifndef CONFIG_AP1000 + ret_val = e1000_read_eeprom(hw, + EEPROM_INIT_CONTROL2_REG, 1, &eeprom_data); + if (ret_val) { + DEBUGOUT("EEPROM Read Error\n"); + return -E1000_ERR_EEPROM; + } +#else + eeprom_data = 0xb220; +#endif + if ((eeprom_data & EEPROM_WORD0F_PAUSE_MASK) == 0) + hw->fc = e1000_fc_none; + else if ((eeprom_data & EEPROM_WORD0F_PAUSE_MASK) == + EEPROM_WORD0F_ASM_DIR) + hw->fc = e1000_fc_tx_pause; + else + hw->fc = e1000_fc_full; + break; + } }
/* We want to save off the original Flow Control configuration just @@ -985,12 +1831,16 @@ e1000_setup_link(struct eth_device *nic) * control is disabled, because it does not hurt anything to * initialize these registers. */ - DEBUGOUT - ("Initializing the Flow Control address, type and timer regs\n"); + DEBUGOUT("Initializing the Flow Control address, type" + "and timer regs\n"); + + /* FCAL/H and FCT are hardcoded to standard values in e1000_ich8lan. */ + if (hw->mac_type != e1000_ich8lan) { + E1000_WRITE_REG(hw, FCT, FLOW_CONTROL_TYPE); + E1000_WRITE_REG(hw, FCAH, FLOW_CONTROL_ADDRESS_HIGH); + E1000_WRITE_REG(hw, FCAL, FLOW_CONTROL_ADDRESS_LOW); + }
- E1000_WRITE_REG(hw, FCAL, FLOW_CONTROL_ADDRESS_LOW); - E1000_WRITE_REG(hw, FCAH, FLOW_CONTROL_ADDRESS_HIGH); - E1000_WRITE_REG(hw, FCT, FLOW_CONTROL_TYPE); E1000_WRITE_REG(hw, FCTTV, hw->fc_pause_time);
/* Set the flow control receive threshold registers. Normally, @@ -1154,18 +2004,57 @@ e1000_setup_fiber_link(struct eth_device *nic) return 0; }
+/***************************************************************************** + * Set PHY to class A mode + * Assumes the following operations will follow to enable the new class mode. + * 1. Do a PHY soft reset + * 2. Restart auto-negotiation or force link. + * + * hw - Struct containing variables accessed by shared code + ****************************************************************************/ +static int32_t +e1000_set_phy_mode(struct e1000_hw *hw) +{ + int32_t ret_val; + uint16_t eeprom_data; + + DEBUGFUNC(); + + if ((hw->mac_type == e1000_82545_rev_3) && + (hw->media_type == e1000_media_type_copper)) { + ret_val = e1000_read_eeprom(hw, EEPROM_PHY_CLASS_WORD, + 1, &eeprom_data); + if (ret_val) + return ret_val; + + if ((eeprom_data != EEPROM_RESERVED_WORD) && + (eeprom_data & EEPROM_PHY_CLASS_A)) { + ret_val = e1000_write_phy_reg(hw, + M88E1000_PHY_PAGE_SELECT, 0x000B); + if (ret_val) + return ret_val; + ret_val = e1000_write_phy_reg(hw, + M88E1000_PHY_GEN_CONTROL, 0x8104); + if (ret_val) + return ret_val; + + hw->phy_reset_disable = FALSE; + } + } + + return E1000_SUCCESS; +} + /****************************************************************************** -* Detects which PHY is present and the speed and duplex +* Make sure we have a valid PHY and change PHY mode before link setup. * * hw - Struct containing variables accessed by shared code ******************************************************************************/ -static int -e1000_setup_copper_link(struct eth_device *nic) +static int32_t +e1000_copper_link_preconfig(struct e1000_hw *hw) { - struct e1000_hw *hw = nic->priv; uint32_t ctrl; int32_t ret_val; - uint16_t i; uint16_t phy_data;
DEBUGFUNC(); @@ -1180,28 +2069,688 @@ e1000_setup_copper_link(struct eth_device *nic) ctrl &= ~(E1000_CTRL_FRCSPD | E1000_CTRL_FRCDPX); E1000_WRITE_REG(hw, CTRL, ctrl); } else { - ctrl |= - (E1000_CTRL_FRCSPD | E1000_CTRL_FRCDPX | E1000_CTRL_SLU); + ctrl |= (E1000_CTRL_FRCSPD | E1000_CTRL_FRCDPX + | E1000_CTRL_SLU); E1000_WRITE_REG(hw, CTRL, ctrl); - e1000_phy_hw_reset(hw); + ret_val = e1000_phy_hw_reset(hw); + if (ret_val) + return ret_val; }
/* Make sure we have a valid PHY */ ret_val = e1000_detect_gig_phy(hw); - if (ret_val < 0) { + if (ret_val) { DEBUGOUT("Error, did not detect valid phy.\n"); return ret_val; } DEBUGOUT("Phy ID = %x \n", hw->phy_id);
- /* Enable CRS on TX. This must be set for half-duplex operation. */ - if (e1000_read_phy_reg(hw, M88E1000_PHY_SPEC_CTRL, &phy_data) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; +#ifndef CONFIG_AP1000 + /* Set PHY to class A mode (if necessary) */ + ret_val = e1000_set_phy_mode(hw); + if (ret_val) + return ret_val; +#endif + if ((hw->mac_type == e1000_82545_rev_3) || + (hw->mac_type == e1000_82546_rev_3)) { + ret_val = e1000_read_phy_reg(hw, M88E1000_PHY_SPEC_CTRL, + &phy_data); + phy_data |= 0x00000008; + ret_val = e1000_write_phy_reg(hw, M88E1000_PHY_SPEC_CTRL, + phy_data); } - phy_data |= M88E1000_PSCR_ASSERT_CRS_ON_TX;
+ if (hw->mac_type <= e1000_82543 || + hw->mac_type == e1000_82541 || hw->mac_type == e1000_82547 || + hw->mac_type == e1000_82541_rev_2 + || hw->mac_type == e1000_82547_rev_2) + hw->phy_reset_disable = FALSE; + + return E1000_SUCCESS; +} + +/***************************************************************************** + * + * This function sets the lplu state according to the active flag. When + * activating lplu this function also disables smart speed and vise versa. + * lplu will not be activated unless the device autonegotiation advertisment + * meets standards of either 10 or 10/100 or 10/100/1000 at all duplexes. + * hw: Struct containing variables accessed by shared code + * active - true to enable lplu false to disable lplu. + * + * returns: - E1000_ERR_PHY if fail to read/write the PHY + * E1000_SUCCESS at any other case. + * + ****************************************************************************/ + +static int32_t +e1000_set_d3_lplu_state(struct e1000_hw *hw, boolean_t active) +{ + uint32_t phy_ctrl = 0; + int32_t ret_val; + uint16_t phy_data; + DEBUGFUNC(); + + if (hw->phy_type != e1000_phy_igp && hw->phy_type != e1000_phy_igp_2 + && hw->phy_type != e1000_phy_igp_3) + return E1000_SUCCESS; + + /* During driver activity LPLU should not be used or it will attain link + * from the lowest speeds starting from 10Mbps. The capability is used + * for Dx transitions and states */ + if (hw->mac_type == e1000_82541_rev_2 + || hw->mac_type == e1000_82547_rev_2) { + ret_val = e1000_read_phy_reg(hw, IGP01E1000_GMII_FIFO, + &phy_data); + if (ret_val) + return ret_val; + } else if (hw->mac_type == e1000_ich8lan) { + /* MAC writes into PHY register based on the state transition + * and start auto-negotiation. SW driver can overwrite the + * settings in CSR PHY power control E1000_PHY_CTRL register. */ + phy_ctrl = E1000_READ_REG(hw, PHY_CTRL); + } else { + ret_val = e1000_read_phy_reg(hw, IGP02E1000_PHY_POWER_MGMT, + &phy_data); + if (ret_val) + return ret_val; + } + + if (!active) { + if (hw->mac_type == e1000_82541_rev_2 || + hw->mac_type == e1000_82547_rev_2) { + phy_data &= ~IGP01E1000_GMII_FLEX_SPD; + ret_val = e1000_write_phy_reg(hw, IGP01E1000_GMII_FIFO, + phy_data); + if (ret_val) + return ret_val; + } else { + if (hw->mac_type == e1000_ich8lan) { + phy_ctrl &= ~E1000_PHY_CTRL_NOND0A_LPLU; + E1000_WRITE_REG(hw, PHY_CTRL, phy_ctrl); + } else { + phy_data &= ~IGP02E1000_PM_D3_LPLU; + ret_val = e1000_write_phy_reg(hw, + IGP02E1000_PHY_POWER_MGMT, phy_data); + if (ret_val) + return ret_val; + } + } + + /* LPLU and SmartSpeed are mutually exclusive. LPLU is used during + * Dx states where the power conservation is most important. During + * driver activity we should enable SmartSpeed, so performance is + * maintained. */ + if (hw->smart_speed == e1000_smart_speed_on) { + ret_val = e1000_read_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, &phy_data); + if (ret_val) + return ret_val; + + phy_data |= IGP01E1000_PSCFR_SMART_SPEED; + ret_val = e1000_write_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, phy_data); + if (ret_val) + return ret_val; + } else if (hw->smart_speed == e1000_smart_speed_off) { + ret_val = e1000_read_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, &phy_data); + if (ret_val) + return ret_val; + + phy_data &= ~IGP01E1000_PSCFR_SMART_SPEED; + ret_val = e1000_write_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, phy_data); + if (ret_val) + return ret_val; + } + + } else if ((hw->autoneg_advertised == AUTONEG_ADVERTISE_SPEED_DEFAULT) + || (hw->autoneg_advertised == AUTONEG_ADVERTISE_10_ALL) || + (hw->autoneg_advertised == AUTONEG_ADVERTISE_10_100_ALL)) { + + if (hw->mac_type == e1000_82541_rev_2 || + hw->mac_type == e1000_82547_rev_2) { + phy_data |= IGP01E1000_GMII_FLEX_SPD; + ret_val = e1000_write_phy_reg(hw, + IGP01E1000_GMII_FIFO, phy_data); + if (ret_val) + return ret_val; + } else { + if (hw->mac_type == e1000_ich8lan) { + phy_ctrl |= E1000_PHY_CTRL_NOND0A_LPLU; + E1000_WRITE_REG(hw, PHY_CTRL, phy_ctrl); + } else { + phy_data |= IGP02E1000_PM_D3_LPLU; + ret_val = e1000_write_phy_reg(hw, + IGP02E1000_PHY_POWER_MGMT, phy_data); + if (ret_val) + return ret_val; + } + } + + /* When LPLU is enabled we should disable SmartSpeed */ + ret_val = e1000_read_phy_reg(hw, IGP01E1000_PHY_PORT_CONFIG, + &phy_data); + if (ret_val) + return ret_val; + + phy_data &= ~IGP01E1000_PSCFR_SMART_SPEED; + ret_val = e1000_write_phy_reg(hw, IGP01E1000_PHY_PORT_CONFIG, + phy_data); + if (ret_val) + return ret_val; + } + return E1000_SUCCESS; +} + +/***************************************************************************** + * + * This function sets the lplu d0 state according to the active flag. When + * activating lplu this function also disables smart speed and vise versa. + * lplu will not be activated unless the device autonegotiation advertisment + * meets standards of either 10 or 10/100 or 10/100/1000 at all duplexes. + * hw: Struct containing variables accessed by shared code + * active - true to enable lplu false to disable lplu. + * + * returns: - E1000_ERR_PHY if fail to read/write the PHY + * E1000_SUCCESS at any other case. + * + ****************************************************************************/ + +static int32_t +e1000_set_d0_lplu_state(struct e1000_hw *hw, boolean_t active) +{ + uint32_t phy_ctrl = 0; + int32_t ret_val; + uint16_t phy_data; + DEBUGFUNC(); + + if (hw->mac_type <= e1000_82547_rev_2) + return E1000_SUCCESS; + + if (hw->mac_type == e1000_ich8lan) { + phy_ctrl = E1000_READ_REG(hw, PHY_CTRL); + } else { + ret_val = e1000_read_phy_reg(hw, IGP02E1000_PHY_POWER_MGMT, + &phy_data); + if (ret_val) + return ret_val; + } + + if (!active) { + if (hw->mac_type == e1000_ich8lan) { + phy_ctrl &= ~E1000_PHY_CTRL_D0A_LPLU; + E1000_WRITE_REG(hw, PHY_CTRL, phy_ctrl); + } else { + phy_data &= ~IGP02E1000_PM_D0_LPLU; + ret_val = e1000_write_phy_reg(hw, + IGP02E1000_PHY_POWER_MGMT, phy_data); + if (ret_val) + return ret_val; + } + + /* LPLU and SmartSpeed are mutually exclusive. LPLU is used during + * Dx states where the power conservation is most important. During + * driver activity we should enable SmartSpeed, so performance is + * maintained. */ + if (hw->smart_speed == e1000_smart_speed_on) { + ret_val = e1000_read_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, &phy_data); + if (ret_val) + return ret_val; + + phy_data |= IGP01E1000_PSCFR_SMART_SPEED; + ret_val = e1000_write_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, phy_data); + if (ret_val) + return ret_val; + } else if (hw->smart_speed == e1000_smart_speed_off) { + ret_val = e1000_read_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, &phy_data); + if (ret_val) + return ret_val; + + phy_data &= ~IGP01E1000_PSCFR_SMART_SPEED; + ret_val = e1000_write_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, phy_data); + if (ret_val) + return ret_val; + } + + + } else { + + if (hw->mac_type == e1000_ich8lan) { + phy_ctrl |= E1000_PHY_CTRL_D0A_LPLU; + E1000_WRITE_REG(hw, PHY_CTRL, phy_ctrl); + } else { + phy_data |= IGP02E1000_PM_D0_LPLU; + ret_val = e1000_write_phy_reg(hw, + IGP02E1000_PHY_POWER_MGMT, phy_data); + if (ret_val) + return ret_val; + } + + /* When LPLU is enabled we should disable SmartSpeed */ + ret_val = e1000_read_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, &phy_data); + if (ret_val) + return ret_val; + + phy_data &= ~IGP01E1000_PSCFR_SMART_SPEED; + ret_val = e1000_write_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, phy_data); + if (ret_val) + return ret_val; + + } + return E1000_SUCCESS; +} + +/******************************************************************** +* Copper link setup for e1000_phy_igp series. +* +* hw - Struct containing variables accessed by shared code +*********************************************************************/ +static int32_t +e1000_copper_link_igp_setup(struct e1000_hw *hw) +{ + uint32_t led_ctrl; + int32_t ret_val; + uint16_t phy_data; + + DEBUGOUT(); + + if (hw->phy_reset_disable) + return E1000_SUCCESS; + + ret_val = e1000_phy_reset(hw); + if (ret_val) { + DEBUGOUT("Error Resetting the PHY\n"); + return ret_val; + } + + /* Wait 15ms for MAC to configure PHY from eeprom settings */ + mdelay(15); + if (hw->mac_type != e1000_ich8lan) { + /* Configure activity LED after PHY reset */ + led_ctrl = E1000_READ_REG(hw, LEDCTL); + led_ctrl &= IGP_ACTIVITY_LED_MASK; + led_ctrl |= (IGP_ACTIVITY_LED_ENABLE | IGP_LED3_MODE); + E1000_WRITE_REG(hw, LEDCTL, led_ctrl); + } + + /* The NVM settings will configure LPLU in D3 for IGP2 and IGP3 PHYs */ + if (hw->phy_type == e1000_phy_igp) { + /* disable lplu d3 during driver init */ + ret_val = e1000_set_d3_lplu_state(hw, FALSE); + if (ret_val) { + DEBUGOUT("Error Disabling LPLU D3\n"); + return ret_val; + } + } + + /* disable lplu d0 during driver init */ + ret_val = e1000_set_d0_lplu_state(hw, FALSE); + if (ret_val) { + DEBUGOUT("Error Disabling LPLU D0\n"); + return ret_val; + } + /* Configure mdi-mdix settings */ + ret_val = e1000_read_phy_reg(hw, IGP01E1000_PHY_PORT_CTRL, &phy_data); + if (ret_val) + return ret_val; + + if ((hw->mac_type == e1000_82541) || (hw->mac_type == e1000_82547)) { + hw->dsp_config_state = e1000_dsp_config_disabled; + /* Force MDI for earlier revs of the IGP PHY */ + phy_data &= ~(IGP01E1000_PSCR_AUTO_MDIX + | IGP01E1000_PSCR_FORCE_MDI_MDIX); + hw->mdix = 1; + + } else { + hw->dsp_config_state = e1000_dsp_config_enabled; + phy_data &= ~IGP01E1000_PSCR_AUTO_MDIX; + + switch (hw->mdix) { + case 1: + phy_data &= ~IGP01E1000_PSCR_FORCE_MDI_MDIX; + break; + case 2: + phy_data |= IGP01E1000_PSCR_FORCE_MDI_MDIX; + break; + case 0: + default: + phy_data |= IGP01E1000_PSCR_AUTO_MDIX; + break; + } + } + ret_val = e1000_write_phy_reg(hw, IGP01E1000_PHY_PORT_CTRL, phy_data); + if (ret_val) + return ret_val; + + /* set auto-master slave resolution settings */ + if (hw->autoneg) { + e1000_ms_type phy_ms_setting = hw->master_slave; + + if (hw->ffe_config_state == e1000_ffe_config_active) + hw->ffe_config_state = e1000_ffe_config_enabled; + + if (hw->dsp_config_state == e1000_dsp_config_activated) + hw->dsp_config_state = e1000_dsp_config_enabled; + + /* when autonegotiation advertisment is only 1000Mbps then we + * should disable SmartSpeed and enable Auto MasterSlave + * resolution as hardware default. */ + if (hw->autoneg_advertised == ADVERTISE_1000_FULL) { + /* Disable SmartSpeed */ + ret_val = e1000_read_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, &phy_data); + if (ret_val) + return ret_val; + phy_data &= ~IGP01E1000_PSCFR_SMART_SPEED; + ret_val = e1000_write_phy_reg(hw, + IGP01E1000_PHY_PORT_CONFIG, phy_data); + if (ret_val) + return ret_val; + /* Set auto Master/Slave resolution process */ + ret_val = e1000_read_phy_reg(hw, PHY_1000T_CTRL, + &phy_data); + if (ret_val) + return ret_val; + phy_data &= ~CR_1000T_MS_ENABLE; + ret_val = e1000_write_phy_reg(hw, PHY_1000T_CTRL, + phy_data); + if (ret_val) + return ret_val; + } + + ret_val = e1000_read_phy_reg(hw, PHY_1000T_CTRL, &phy_data); + if (ret_val) + return ret_val; + + /* load defaults for future use */ + hw->original_master_slave = (phy_data & CR_1000T_MS_ENABLE) ? + ((phy_data & CR_1000T_MS_VALUE) ? + e1000_ms_force_master : + e1000_ms_force_slave) : + e1000_ms_auto; + + switch (phy_ms_setting) { + case e1000_ms_force_master: + phy_data |= (CR_1000T_MS_ENABLE | CR_1000T_MS_VALUE); + break; + case e1000_ms_force_slave: + phy_data |= CR_1000T_MS_ENABLE; + phy_data &= ~(CR_1000T_MS_VALUE); + break; + case e1000_ms_auto: + phy_data &= ~CR_1000T_MS_ENABLE; + default: + break; + } + ret_val = e1000_write_phy_reg(hw, PHY_1000T_CTRL, phy_data); + if (ret_val) + return ret_val; + } + + return E1000_SUCCESS; +} + +/***************************************************************************** + * This function checks the mode of the firmware. + * + * returns - TRUE when the mode is IAMT or FALSE. + ****************************************************************************/ +boolean_t +e1000_check_mng_mode(struct e1000_hw *hw) +{ + uint32_t fwsm; + DEBUGFUNC(); + + fwsm = E1000_READ_REG(hw, FWSM); + + if (hw->mac_type == e1000_ich8lan) { + if ((fwsm & E1000_FWSM_MODE_MASK) == + (E1000_MNG_ICH_IAMT_MODE << E1000_FWSM_MODE_SHIFT)) + return TRUE; + } else if ((fwsm & E1000_FWSM_MODE_MASK) == + (E1000_MNG_IAMT_MODE << E1000_FWSM_MODE_SHIFT)) + return TRUE; + + return FALSE; +} + +static int32_t +e1000_write_kmrn_reg(struct e1000_hw *hw, uint32_t reg_addr, uint16_t data) +{ + uint32_t reg_val; + uint16_t swfw; + DEBUGFUNC(); + + if ((hw->mac_type == e1000_80003es2lan) && + (E1000_READ_REG(hw, STATUS) & E1000_STATUS_FUNC_1)) { + swfw = E1000_SWFW_PHY1_SM; + } else { + swfw = E1000_SWFW_PHY0_SM; + } + if (e1000_swfw_sync_acquire(hw, swfw)) + return -E1000_ERR_SWFW_SYNC; + + reg_val = ((reg_addr << E1000_KUMCTRLSTA_OFFSET_SHIFT) + & E1000_KUMCTRLSTA_OFFSET) | data; + E1000_WRITE_REG(hw, KUMCTRLSTA, reg_val); + udelay(2); + + return E1000_SUCCESS; +} + +static int32_t +e1000_read_kmrn_reg(struct e1000_hw *hw, uint32_t reg_addr, uint16_t *data) +{ + uint32_t reg_val; + uint16_t swfw; + DEBUGFUNC(); + + if ((hw->mac_type == e1000_80003es2lan) && + (E1000_READ_REG(hw, STATUS) & E1000_STATUS_FUNC_1)) { + swfw = E1000_SWFW_PHY1_SM; + } else { + swfw = E1000_SWFW_PHY0_SM; + } + if (e1000_swfw_sync_acquire(hw, swfw)) + return -E1000_ERR_SWFW_SYNC; + + /* Write register address */ + reg_val = ((reg_addr << E1000_KUMCTRLSTA_OFFSET_SHIFT) & + E1000_KUMCTRLSTA_OFFSET) | E1000_KUMCTRLSTA_REN; + E1000_WRITE_REG(hw, KUMCTRLSTA, reg_val); + udelay(2); + + /* Read the data returned */ + reg_val = E1000_READ_REG(hw, KUMCTRLSTA); + *data = (uint16_t)reg_val; + + return E1000_SUCCESS; +} + +/******************************************************************** +* Copper link setup for e1000_phy_gg82563 series. +* +* hw - Struct containing variables accessed by shared code +*********************************************************************/ +static int32_t +e1000_copper_link_ggp_setup(struct e1000_hw *hw) +{ + int32_t ret_val; + uint16_t phy_data; + uint32_t reg_data; + + DEBUGFUNC(); + + if (!hw->phy_reset_disable) { + /* Enable CRS on TX for half-duplex operation. */ + ret_val = e1000_read_phy_reg(hw, + GG82563_PHY_MAC_SPEC_CTRL, &phy_data); + if (ret_val) + return ret_val; + + phy_data |= GG82563_MSCR_ASSERT_CRS_ON_TX; + /* Use 25MHz for both link down and 1000BASE-T for Tx clock */ + phy_data |= GG82563_MSCR_TX_CLK_1000MBPS_25MHZ; + + ret_val = e1000_write_phy_reg(hw, + GG82563_PHY_MAC_SPEC_CTRL, phy_data); + if (ret_val) + return ret_val; + + /* Options: + * MDI/MDI-X = 0 (default) + * 0 - Auto for all speeds + * 1 - MDI mode + * 2 - MDI-X mode + * 3 - Auto for 1000Base-T only (MDI-X for 10/100Base-T modes) + */ + ret_val = e1000_read_phy_reg(hw, + GG82563_PHY_SPEC_CTRL, &phy_data); + if (ret_val) + return ret_val; + + phy_data &= ~GG82563_PSCR_CROSSOVER_MODE_MASK; + + switch (hw->mdix) { + case 1: + phy_data |= GG82563_PSCR_CROSSOVER_MODE_MDI; + break; + case 2: + phy_data |= GG82563_PSCR_CROSSOVER_MODE_MDIX; + break; + case 0: + default: + phy_data |= GG82563_PSCR_CROSSOVER_MODE_AUTO; + break; + } + + /* Options: + * disable_polarity_correction = 0 (default) + * Automatic Correction for Reversed Cable Polarity + * 0 - Disabled + * 1 - Enabled + */ + phy_data &= ~GG82563_PSCR_POLARITY_REVERSAL_DISABLE; #if 0 + (hw->disable_polarity_correction == 1) + phy_data |= GG82563_PSCR_POLARITY_REVERSAL_DISABLE; +#endif + ret_val = e1000_write_phy_reg(hw, + GG82563_PHY_SPEC_CTRL, phy_data); + + if (ret_val) + return ret_val; + + /* SW Reset the PHY so all changes take effect */ + ret_val = e1000_phy_reset(hw); + if (ret_val) { + DEBUGOUT("Error Resetting the PHY\n"); + return ret_val; + } + } /* phy_reset_disable */ + + if (hw->mac_type == e1000_80003es2lan) { + /* Bypass RX and TX FIFO's */ + ret_val = e1000_write_kmrn_reg(hw, + E1000_KUMCTRLSTA_OFFSET_FIFO_CTRL, + E1000_KUMCTRLSTA_FIFO_CTRL_RX_BYPASS + | E1000_KUMCTRLSTA_FIFO_CTRL_TX_BYPASS); + if (ret_val) + return ret_val; + + ret_val = e1000_read_phy_reg(hw, + GG82563_PHY_SPEC_CTRL_2, &phy_data); + if (ret_val) + return ret_val; + + phy_data &= ~GG82563_PSCR2_REVERSE_AUTO_NEG; + ret_val = e1000_write_phy_reg(hw, + GG82563_PHY_SPEC_CTRL_2, phy_data); + + if (ret_val) + return ret_val; + + reg_data = E1000_READ_REG(hw, CTRL_EXT); + reg_data &= ~(E1000_CTRL_EXT_LINK_MODE_MASK); + E1000_WRITE_REG(hw, CTRL_EXT, reg_data); + + ret_val = e1000_read_phy_reg(hw, + GG82563_PHY_PWR_MGMT_CTRL, &phy_data); + if (ret_val) + return ret_val; + + /* Do not init these registers when the HW is in IAMT mode, since the + * firmware will have already initialized them. We only initialize + * them if the HW is not in IAMT mode. + */ + if (e1000_check_mng_mode(hw) == FALSE) { + /* Enable Electrical Idle on the PHY */ + phy_data |= GG82563_PMCR_ENABLE_ELECTRICAL_IDLE; + ret_val = e1000_write_phy_reg(hw, + GG82563_PHY_PWR_MGMT_CTRL, phy_data); + if (ret_val) + return ret_val; + + ret_val = e1000_read_phy_reg(hw, + GG82563_PHY_KMRN_MODE_CTRL, &phy_data); + if (ret_val) + return ret_val; + + phy_data &= ~GG82563_KMCR_PASS_FALSE_CARRIER; + ret_val = e1000_write_phy_reg(hw, + GG82563_PHY_KMRN_MODE_CTRL, phy_data); + + if (ret_val) + return ret_val; + } + + /* Workaround: Disable padding in Kumeran interface in the MAC + * and in the PHY to avoid CRC errors. + */ + ret_val = e1000_read_phy_reg(hw, + GG82563_PHY_INBAND_CTRL, &phy_data); + if (ret_val) + return ret_val; + phy_data |= GG82563_ICR_DIS_PADDING; + ret_val = e1000_write_phy_reg(hw, + GG82563_PHY_INBAND_CTRL, phy_data); + if (ret_val) + return ret_val; + } + return E1000_SUCCESS; +} + +/******************************************************************** +* Copper link setup for e1000_phy_m88 series. +* +* hw - Struct containing variables accessed by shared code +*********************************************************************/ +static int32_t +e1000_copper_link_mgp_setup(struct e1000_hw *hw) +{ + int32_t ret_val; + uint16_t phy_data; + + DEBUGFUNC(); + + if (hw->phy_reset_disable) + return E1000_SUCCESS; + + /* Enable CRS on TX. This must be set for half-duplex operation. */ + ret_val = e1000_read_phy_reg(hw, M88E1000_PHY_SPEC_CTRL, &phy_data); + if (ret_val) + return ret_val; + + phy_data |= M88E1000_PSCR_ASSERT_CRS_ON_TX; + /* Options: * MDI/MDI-X = 0 (default) * 0 - Auto for all speeds @@ -1210,6 +2759,7 @@ e1000_setup_copper_link(struct eth_device *nic) * 3 - Auto for 1000Base-T only (MDI-X for 10/100Base-T modes) */ phy_data &= ~M88E1000_PSCR_AUTO_X_MODE; + switch (hw->mdix) { case 1: phy_data |= M88E1000_PSCR_MDI_MANUAL_MODE; @@ -1225,68 +2775,79 @@ e1000_setup_copper_link(struct eth_device *nic) phy_data |= M88E1000_PSCR_AUTO_X_MODE; break; } -#else - phy_data |= M88E1000_PSCR_AUTO_X_MODE; -#endif
-#if 0 /* Options: * disable_polarity_correction = 0 (default) - * Automatic Correction for Reversed Cable Polarity + * Automatic Correction for Reversed Cable Polarity * 0 - Disabled * 1 - Enabled */ phy_data &= ~M88E1000_PSCR_POLARITY_REVERSAL; +#if 0 if (hw->disable_polarity_correction == 1) phy_data |= M88E1000_PSCR_POLARITY_REVERSAL; -#else - phy_data &= ~M88E1000_PSCR_POLARITY_REVERSAL; #endif - if (e1000_write_phy_reg(hw, M88E1000_PHY_SPEC_CTRL, phy_data) < 0) { - DEBUGOUT("PHY Write Error\n"); - return -E1000_ERR_PHY; - } + ret_val = e1000_write_phy_reg(hw, M88E1000_PHY_SPEC_CTRL, phy_data); + if (ret_val) + return ret_val;
- /* Force TX_CLK in the Extended PHY Specific Control Register - * to 25MHz clock. - */ - if (e1000_read_phy_reg(hw, M88E1000_EXT_PHY_SPEC_CTRL, &phy_data) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; - } - phy_data |= M88E1000_EPSCR_TX_CLK_25; - /* Configure Master and Slave downshift values */ - phy_data &= ~(M88E1000_EPSCR_MASTER_DOWNSHIFT_MASK | - M88E1000_EPSCR_SLAVE_DOWNSHIFT_MASK); - phy_data |= (M88E1000_EPSCR_MASTER_DOWNSHIFT_1X | - M88E1000_EPSCR_SLAVE_DOWNSHIFT_1X); - if (e1000_write_phy_reg(hw, M88E1000_EXT_PHY_SPEC_CTRL, phy_data) < 0) { - DEBUGOUT("PHY Write Error\n"); - return -E1000_ERR_PHY; + if (hw->phy_revision < M88E1011_I_REV_4) { + /* Force TX_CLK in the Extended PHY Specific Control Register + * to 25MHz clock. + */ + ret_val = e1000_read_phy_reg(hw, + M88E1000_EXT_PHY_SPEC_CTRL, &phy_data); + if (ret_val) + return ret_val; + + phy_data |= M88E1000_EPSCR_TX_CLK_25; + + if ((hw->phy_revision == E1000_REVISION_2) && + (hw->phy_id == M88E1111_I_PHY_ID)) { + /* Vidalia Phy, set the downshift counter to 5x */ + phy_data &= ~(M88EC018_EPSCR_DOWNSHIFT_COUNTER_MASK); + phy_data |= M88EC018_EPSCR_DOWNSHIFT_COUNTER_5X; + ret_val = e1000_write_phy_reg(hw, + M88E1000_EXT_PHY_SPEC_CTRL, phy_data); + if (ret_val) + return ret_val; + } else { + /* Configure Master and Slave downshift values */ + phy_data &= ~(M88E1000_EPSCR_MASTER_DOWNSHIFT_MASK + | M88E1000_EPSCR_SLAVE_DOWNSHIFT_MASK); + phy_data |= (M88E1000_EPSCR_MASTER_DOWNSHIFT_1X + | M88E1000_EPSCR_SLAVE_DOWNSHIFT_1X); + ret_val = e1000_write_phy_reg(hw, + M88E1000_EXT_PHY_SPEC_CTRL, phy_data); + if (ret_val) + return ret_val; + } }
/* SW Reset the PHY so all changes take effect */ ret_val = e1000_phy_reset(hw); - if (ret_val < 0) { + if (ret_val) { DEBUGOUT("Error Resetting the PHY\n"); return ret_val; }
- /* Options: - * autoneg = 1 (default) - * PHY will advertise value(s) parsed from - * autoneg_advertised and fc - * autoneg = 0 - * PHY will be set to 10H, 10F, 100H, or 100F - * depending on value parsed from forced_speed_duplex. - */ + return E1000_SUCCESS; +} + +/******************************************************************** +* Setup auto-negotiation and flow control advertisements, +* and then perform auto-negotiation. +* +* hw - Struct containing variables accessed by shared code +*********************************************************************/ +static int32_t +e1000_copper_link_autoneg(struct e1000_hw *hw) +{ + int32_t ret_val; + uint16_t phy_data; + + DEBUGFUNC();
- /* Is autoneg enabled? This is enabled by default or by software override. - * If so, call e1000_phy_setup_autoneg routine to parse the - * autoneg_advertised and fc options. If autoneg is NOT enabled, then the - * user should have provided a speed/duplex override. If so, then call - * e1000_phy_force_speed_duplex to parse and set this up. - */ /* Perform some bounds checking on the hw->autoneg_advertised * parameter. If this variable is zero, then set it to the default. */ @@ -1298,9 +2859,13 @@ e1000_setup_copper_link(struct eth_device *nic) if (hw->autoneg_advertised == 0) hw->autoneg_advertised = AUTONEG_ADVERTISE_SPEED_DEFAULT;
+ /* IFE phy only supports 10/100 */ + if (hw->phy_type == e1000_phy_ife) + hw->autoneg_advertised &= AUTONEG_ADVERTISE_10_100_ALL; + DEBUGOUT("Reconfiguring auto-neg advertisement params\n"); ret_val = e1000_phy_setup_autoneg(hw); - if (ret_val < 0) { + if (ret_val) { DEBUGOUT("Error Setting up Auto-Negotiation\n"); return ret_val; } @@ -1309,82 +2874,188 @@ e1000_setup_copper_link(struct eth_device *nic) /* Restart auto-negotiation by setting the Auto Neg Enable bit and * the Auto Neg Restart bit in the PHY control register. */ - if (e1000_read_phy_reg(hw, PHY_CTRL, &phy_data) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; - } + ret_val = e1000_read_phy_reg(hw, PHY_CTRL, &phy_data); + if (ret_val) + return ret_val; + phy_data |= (MII_CR_AUTO_NEG_EN | MII_CR_RESTART_AUTO_NEG); - if (e1000_write_phy_reg(hw, PHY_CTRL, phy_data) < 0) { - DEBUGOUT("PHY Write Error\n"); - return -E1000_ERR_PHY; - } -#if 0 + ret_val = e1000_write_phy_reg(hw, PHY_CTRL, phy_data); + if (ret_val) + return ret_val; + /* Does the user want to wait for Auto-Neg to complete here, or * check at a later time (for example, callback routine). */ + /* If we do not wait for autonegtation to complete I + * do not see a valid link status. + * wait_autoneg_complete = 1 . + */ if (hw->wait_autoneg_complete) { ret_val = e1000_wait_autoneg(hw); - if (ret_val < 0) { - DEBUGOUT - ("Error while waiting for autoneg to complete\n"); + if (ret_val) { + DEBUGOUT("Error while waiting for autoneg" + "to complete\n"); return ret_val; } } -#else - /* If we do not wait for autonegtation to complete I - * do not see a valid link status. - */ - ret_val = e1000_wait_autoneg(hw); - if (ret_val < 0) { - DEBUGOUT("Error while waiting for autoneg to complete\n"); + + hw->get_link_status = TRUE; + + return E1000_SUCCESS; +} + +/****************************************************************************** +* Config the MAC and the PHY after link is up. +* 1) Set up the MAC to the current PHY speed/duplex +* if we are on 82543. If we +* are on newer silicon, we only need to configure +* collision distance in the Transmit Control Register. +* 2) Set up flow control on the MAC to that established with +* the link partner. +* 3) Config DSP to improve Gigabit link quality for some PHY revisions. +* +* hw - Struct containing variables accessed by shared code +******************************************************************************/ +static int32_t +e1000_copper_link_postconfig(struct e1000_hw *hw) +{ + int32_t ret_val; + DEBUGFUNC(); + + if (hw->mac_type >= e1000_82544) { + e1000_config_collision_dist(hw); + } else { + ret_val = e1000_config_mac_to_phy(hw); + if (ret_val) { + DEBUGOUT("Error configuring MAC to PHY settings\n"); + return ret_val; + } + } + ret_val = e1000_config_fc_after_link_up(hw); + if (ret_val) { + DEBUGOUT("Error Configuring Flow Control\n"); return ret_val; } + + /* Config DSP to improve Giga link quality */ +#if 0 + if (hw->phy_type == e1000_phy_igp) { + ret_val = e1000_config_dsp_after_link_change(hw, TRUE); + if (ret_val) { + DEBUGOUT("Error Configuring DSP after link up\n"); + return ret_val; + } + } #endif + return E1000_SUCCESS; +} + +/****************************************************************************** +* Detects which PHY is present and setup the speed and duplex +* +* hw - Struct containing variables accessed by shared code +******************************************************************************/ +static int +e1000_setup_copper_link(struct eth_device *nic) +{ + struct e1000_hw *hw = nic->priv; + int32_t ret_val; + uint16_t i; + uint16_t phy_data; + uint16_t reg_data; + + DEBUGFUNC(); + + switch (hw->mac_type) { + case e1000_80003es2lan: + case e1000_ich8lan: + /* Set the mac to wait the maximum time between each + * iteration and increase the max iterations when + * polling the phy; this fixes erroneous timeouts at 10Mbps. */ + ret_val = e1000_write_kmrn_reg(hw, + GG82563_REG(0x34, 4), 0xFFFF); + if (ret_val) + return ret_val; + ret_val = e1000_read_kmrn_reg(hw, + GG82563_REG(0x34, 9), ®_data); + if (ret_val) + return ret_val; + reg_data |= 0x3F; + ret_val = e1000_write_kmrn_reg(hw, + GG82563_REG(0x34, 9), reg_data); + if (ret_val) + return ret_val; + default: + break; + } + + /* Check if it is a valid PHY and set PHY mode if necessary. */ + ret_val = e1000_copper_link_preconfig(hw); + if (ret_val) + return ret_val; + switch (hw->mac_type) { + case e1000_80003es2lan: + /* Kumeran registers are written-only */ + reg_data = + E1000_KUMCTRLSTA_INB_CTRL_LINK_STATUS_TX_TIMEOUT_DEFAULT; + reg_data |= E1000_KUMCTRLSTA_INB_CTRL_DIS_PADDING; + ret_val = e1000_write_kmrn_reg(hw, + E1000_KUMCTRLSTA_OFFSET_INB_CTRL, reg_data); + if (ret_val) + return ret_val; + break; + default: + break; + } + + if (hw->phy_type == e1000_phy_igp || + hw->phy_type == e1000_phy_igp_3 || + hw->phy_type == e1000_phy_igp_2) { + ret_val = e1000_copper_link_igp_setup(hw); + if (ret_val) + return ret_val; + } else if (hw->phy_type == e1000_phy_m88) { + ret_val = e1000_copper_link_mgp_setup(hw); + if (ret_val) + return ret_val; + } else if (hw->phy_type == e1000_phy_gg82563) { + ret_val = e1000_copper_link_ggp_setup(hw); + if (ret_val) + return ret_val; + } + + /* always auto */ + /* Setup autoneg and flow control advertisement + * and perform autonegotiation */ + ret_val = e1000_copper_link_autoneg(hw); + if (ret_val) + return ret_val;
/* Check link status. Wait up to 100 microseconds for link to become * valid. */ for (i = 0; i < 10; i++) { - if (e1000_read_phy_reg(hw, PHY_STATUS, &phy_data) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; - } - if (e1000_read_phy_reg(hw, PHY_STATUS, &phy_data) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; - } + ret_val = e1000_read_phy_reg(hw, PHY_STATUS, &phy_data); + if (ret_val) + return ret_val; + ret_val = e1000_read_phy_reg(hw, PHY_STATUS, &phy_data); + if (ret_val) + return ret_val; + if (phy_data & MII_SR_LINK_STATUS) { - /* We have link, so we need to finish the config process: - * 1) Set up the MAC to the current PHY speed/duplex - * if we are on 82543. If we - * are on newer silicon, we only need to configure - * collision distance in the Transmit Control Register. - * 2) Set up flow control on the MAC to that established with - * the link partner. - */ - if (hw->mac_type >= e1000_82544) { - e1000_config_collision_dist(hw); - } else { - ret_val = e1000_config_mac_to_phy(hw); - if (ret_val < 0) { - DEBUGOUT - ("Error configuring MAC to PHY settings\n"); - return ret_val; - } - } - ret_val = e1000_config_fc_after_link_up(hw); - if (ret_val < 0) { - DEBUGOUT("Error Configuring Flow Control\n"); + /* Config the MAC and PHY after link is up */ + ret_val = e1000_copper_link_postconfig(hw); + if (ret_val) return ret_val; - } + DEBUGOUT("Valid link established!!!\n"); - return 0; + return E1000_SUCCESS; } udelay(10); }
DEBUGOUT("Unable to establish link!!!\n"); - return -E1000_ERR_NOLINK; + return E1000_SUCCESS; }
/****************************************************************************** @@ -1392,25 +3063,28 @@ e1000_setup_copper_link(struct eth_device *nic) * * hw - Struct containing variables accessed by shared code ******************************************************************************/ -static int +int32_t e1000_phy_setup_autoneg(struct e1000_hw *hw) { + int32_t ret_val; uint16_t mii_autoneg_adv_reg; uint16_t mii_1000t_ctrl_reg;
DEBUGFUNC();
/* Read the MII Auto-Neg Advertisement Register (Address 4). */ - if (e1000_read_phy_reg(hw, PHY_AUTONEG_ADV, &mii_autoneg_adv_reg) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; - } + ret_val = e1000_read_phy_reg(hw, PHY_AUTONEG_ADV, &mii_autoneg_adv_reg); + if (ret_val) + return ret_val;
- /* Read the MII 1000Base-T Control Register (Address 9). */ - if (e1000_read_phy_reg(hw, PHY_1000T_CTRL, &mii_1000t_ctrl_reg) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; - } + if (hw->phy_type != e1000_phy_ife) { + /* Read the MII 1000Base-T Control Register (Address 9). */ + ret_val = e1000_read_phy_reg(hw, PHY_1000T_CTRL, + &mii_1000t_ctrl_reg); + if (ret_val) + return ret_val; + } else + mii_1000t_ctrl_reg = 0;
/* Need to parse both autoneg_advertised and fc and set up * the appropriate PHY registers. First we will parse for @@ -1421,7 +3095,7 @@ e1000_phy_setup_autoneg(struct e1000_hw *hw)
/* First we clear all the 10/100 mb speed bits in the Auto-Neg * Advertisement Register (Address 4) and the 1000 mb speed bits in - * the 1000Base-T Control Register (Address 9). + * the 1000Base-T Control Register (Address 9). */ mii_autoneg_adv_reg &= ~REG4_SPEED_MASK; mii_1000t_ctrl_reg &= ~REG9_SPEED_MASK; @@ -1517,18 +3191,20 @@ e1000_phy_setup_autoneg(struct e1000_hw *hw) return -E1000_ERR_CONFIG; }
- if (e1000_write_phy_reg(hw, PHY_AUTONEG_ADV, mii_autoneg_adv_reg) < 0) { - DEBUGOUT("PHY Write Error\n"); - return -E1000_ERR_PHY; - } + ret_val = e1000_write_phy_reg(hw, PHY_AUTONEG_ADV, mii_autoneg_adv_reg); + if (ret_val) + return ret_val;
DEBUGOUT("Auto-Neg Advertising %x\n", mii_autoneg_adv_reg);
- if (e1000_write_phy_reg(hw, PHY_1000T_CTRL, mii_1000t_ctrl_reg) < 0) { - DEBUGOUT("PHY Write Error\n"); - return -E1000_ERR_PHY; + if (hw->phy_type != e1000_phy_ife) { + ret_val = e1000_write_phy_reg(hw, PHY_1000T_CTRL, + mii_1000t_ctrl_reg); + if (ret_val) + return ret_val; } - return 0; + + return E1000_SUCCESS; }
/****************************************************************************** @@ -1542,12 +3218,19 @@ e1000_phy_setup_autoneg(struct e1000_hw *hw) static void e1000_config_collision_dist(struct e1000_hw *hw) { - uint32_t tctl; + uint32_t tctl, coll_dist; + + DEBUGFUNC(); + + if (hw->mac_type < e1000_82543) + coll_dist = E1000_COLLISION_DISTANCE_82542; + else + coll_dist = E1000_COLLISION_DISTANCE;
tctl &= ~E1000_TCTL_COLD; - tctl |= E1000_COLLISION_DISTANCE << E1000_COLD_SHIFT; + tctl |= coll_dist << E1000_COLD_SHIFT;
E1000_WRITE_REG(hw, TCTL, tctl); E1000_WRITE_FLUSH(hw); @@ -1681,7 +3364,7 @@ e1000_force_mac_fc(struct e1000_hw *hw) * based on the flow control negotiated by the PHY. In TBI mode, the TFCE * and RFCE bits will be automaticaly set to the negotiated flow control mode. *****************************************************************************/ -static int +static int32_t e1000_config_fc_after_link_up(struct e1000_hw *hw) { int32_t ret_val; @@ -1697,7 +3380,11 @@ e1000_config_fc_after_link_up(struct e1000_hw *hw) * so we had to force link. In this case, we need to force the * configuration of the MAC to match the "fc" parameter. */ - if ((hw->media_type == e1000_media_type_fiber) && (hw->autoneg_failed)) { + if (((hw->media_type == e1000_media_type_fiber) && (hw->autoneg_failed)) + || ((hw->media_type == e1000_media_type_internal_serdes) + && (hw->autoneg_failed)) + || ((hw->media_type == e1000_media_type_copper) + && (!hw->autoneg))) { ret_val = e1000_force_mac_fc(hw); if (ret_val < 0) { DEBUGOUT("Error forcing flow control settings\n"); @@ -1881,7 +3568,7 @@ e1000_config_fc_after_link_up(struct e1000_hw *hw) ("Copper PHY and Auto Neg has not completed.\r\n"); } } - return 0; + return E1000_SUCCESS; }
/****************************************************************************** @@ -2070,17 +3757,92 @@ e1000_check_for_link(struct eth_device *nic) }
/****************************************************************************** +* Configure the MAC-to-PHY interface for 10/100Mbps +* +* hw - Struct containing variables accessed by shared code +******************************************************************************/ +static int32_t +e1000_configure_kmrn_for_10_100(struct e1000_hw *hw, uint16_t duplex) +{ + int32_t ret_val = E1000_SUCCESS; + uint32_t tipg; + uint16_t reg_data; + + DEBUGFUNC(); + + reg_data = E1000_KUMCTRLSTA_HD_CTRL_10_100_DEFAULT; + ret_val = e1000_write_kmrn_reg(hw, + E1000_KUMCTRLSTA_OFFSET_HD_CTRL, reg_data); + if (ret_val) + return ret_val; + + /* Configure Transmit Inter-Packet Gap */ + tipg = E1000_READ_REG(hw, TIPG); + tipg &= ~E1000_TIPG_IPGT_MASK; + tipg |= DEFAULT_80003ES2LAN_TIPG_IPGT_10_100; + E1000_WRITE_REG(hw, TIPG, tipg); + + ret_val = e1000_read_phy_reg(hw, GG82563_PHY_KMRN_MODE_CTRL, ®_data); + + if (ret_val) + return ret_val; + + if (duplex == HALF_DUPLEX) + reg_data |= GG82563_KMCR_PASS_FALSE_CARRIER; + else + reg_data &= ~GG82563_KMCR_PASS_FALSE_CARRIER; + + ret_val = e1000_write_phy_reg(hw, GG82563_PHY_KMRN_MODE_CTRL, reg_data); + + return ret_val; +} + +static int32_t +e1000_configure_kmrn_for_1000(struct e1000_hw *hw) +{ + int32_t ret_val = E1000_SUCCESS; + uint16_t reg_data; + uint32_t tipg; + + DEBUGFUNC(); + + reg_data = E1000_KUMCTRLSTA_HD_CTRL_1000_DEFAULT; + ret_val = e1000_write_kmrn_reg(hw, + E1000_KUMCTRLSTA_OFFSET_HD_CTRL, reg_data); + if (ret_val) + return ret_val; + + /* Configure Transmit Inter-Packet Gap */ + tipg = E1000_READ_REG(hw, TIPG); + tipg &= ~E1000_TIPG_IPGT_MASK; + tipg |= DEFAULT_80003ES2LAN_TIPG_IPGT_1000; + E1000_WRITE_REG(hw, TIPG, tipg); + + ret_val = e1000_read_phy_reg(hw, GG82563_PHY_KMRN_MODE_CTRL, ®_data); + + if (ret_val) + return ret_val; + + reg_data &= ~GG82563_KMCR_PASS_FALSE_CARRIER; + ret_val = e1000_write_phy_reg(hw, GG82563_PHY_KMRN_MODE_CTRL, reg_data); + + return ret_val; +} + +/****************************************************************************** * Detects the current speed and duplex settings of the hardware. * * hw - Struct containing variables accessed by shared code * speed - Speed of the connection * duplex - Duplex setting of the connection *****************************************************************************/ -static void -e1000_get_speed_and_duplex(struct e1000_hw *hw, - uint16_t * speed, uint16_t * duplex) +static int +e1000_get_speed_and_duplex(struct e1000_hw *hw, uint16_t *speed, + uint16_t *duplex) { uint32_t status; + int32_t ret_val; + uint16_t phy_data;
DEBUGFUNC();
@@ -2109,6 +3871,48 @@ e1000_get_speed_and_duplex(struct e1000_hw *hw, *speed = SPEED_1000; *duplex = FULL_DUPLEX; } + + /* IGP01 PHY may advertise full duplex operation after speed downgrade + * even if it is operating at half duplex. Here we set the duplex + * settings to match the duplex in the link partner's capabilities. + */ + if (hw->phy_type == e1000_phy_igp && hw->speed_downgraded) { + ret_val = e1000_read_phy_reg(hw, PHY_AUTONEG_EXP, &phy_data); + if (ret_val) + return ret_val; + + if (!(phy_data & NWAY_ER_LP_NWAY_CAPS)) + *duplex = HALF_DUPLEX; + else { + ret_val = e1000_read_phy_reg(hw, + PHY_LP_ABILITY, &phy_data); + if (ret_val) + return ret_val; + if ((*speed == SPEED_100 && + !(phy_data & NWAY_LPAR_100TX_FD_CAPS)) + || (*speed == SPEED_10 + && !(phy_data & NWAY_LPAR_10T_FD_CAPS))) + *duplex = HALF_DUPLEX; + } + } + + if ((hw->mac_type == e1000_80003es2lan) && + (hw->media_type == e1000_media_type_copper)) { + if (*speed == SPEED_1000) + ret_val = e1000_configure_kmrn_for_1000(hw); + else + ret_val = e1000_configure_kmrn_for_10_100(hw, *duplex); + if (ret_val) + return ret_val; + } +#if 0 + if ((hw->phy_type == e1000_phy_igp_3) && (*speed == SPEED_1000)) { + ret_val = e1000_kumeran_lock_loss_workaround(hw); + if (ret_val) + return ret_val; + } +#endif + return E1000_SUCCESS; }
/****************************************************************************** @@ -2429,30 +4233,132 @@ e1000_write_phy_reg(struct e1000_hw *hw, uint32_t reg_addr, uint16_t phy_data) }
/****************************************************************************** + * Checks if PHY reset is blocked due to SOL/IDER session, for example. + * Returning E1000_BLK_PHY_RESET isn't necessarily an error. But it's up to + * the caller to figure out how to deal with it. + * + * hw - Struct containing variables accessed by shared code + * + * returns: - E1000_BLK_PHY_RESET + * E1000_SUCCESS + * + *****************************************************************************/ +int32_t +e1000_check_phy_reset_block(struct e1000_hw *hw) +{ + uint32_t manc = 0; + uint32_t fwsm = 0; + + if (hw->mac_type == e1000_ich8lan) { + fwsm = E1000_READ_REG(hw, FWSM); + return (fwsm & E1000_FWSM_RSPCIPHY) ? E1000_SUCCESS + : E1000_BLK_PHY_RESET; + } + + if (hw->mac_type > e1000_82547_rev_2) + manc = E1000_READ_REG(hw, MANC); + return (manc & E1000_MANC_BLK_PHY_RST_ON_IDE) ? + E1000_BLK_PHY_RESET : E1000_SUCCESS; +} + +/*************************************************************************** + * Checks if the PHY configuration is done + * + * hw: Struct containing variables accessed by shared code + * + * returns: - E1000_ERR_RESET if fail to reset MAC + * E1000_SUCCESS at any other case. + * + ***************************************************************************/ +static int32_t +e1000_get_phy_cfg_done(struct e1000_hw *hw) +{ + int32_t timeout = PHY_CFG_TIMEOUT; + uint32_t cfg_mask = E1000_EEPROM_CFG_DONE; + + DEBUGFUNC(); + + switch (hw->mac_type) { + default: + mdelay(10); + break; + case e1000_80003es2lan: + /* Separate *_CFG_DONE_* bit for each port */ + if (E1000_READ_REG(hw, STATUS) & E1000_STATUS_FUNC_1) + cfg_mask = E1000_EEPROM_CFG_DONE_PORT_1; + /* Fall Through */ + case e1000_82571: + case e1000_82572: + while (timeout) { + if (E1000_READ_REG(hw, EEMNGCTL) & cfg_mask) + break; + else + mdelay(1); + timeout--; + } + if (!timeout) { + DEBUGOUT("MNG configuration cycle has not " + "completed.\n"); + return -E1000_ERR_RESET; + } + break; + } + + return E1000_SUCCESS; +} + +/****************************************************************************** * Returns the PHY to the power-on reset state * * hw - Struct containing variables accessed by shared code ******************************************************************************/ -static void +int32_t e1000_phy_hw_reset(struct e1000_hw *hw) { - uint32_t ctrl; - uint32_t ctrl_ext; + uint32_t ctrl, ctrl_ext; + uint32_t led_ctrl; + int32_t ret_val; + uint16_t swfw;
DEBUGFUNC();
+ /* In the case of the phy reset being blocked, it's not an error, we + * simply return success without performing the reset. */ + ret_val = e1000_check_phy_reset_block(hw); + if (ret_val) + return E1000_SUCCESS; + DEBUGOUT("Resetting Phy...\n");
if (hw->mac_type > e1000_82543) { + if ((hw->mac_type == e1000_80003es2lan) && + (E1000_READ_REG(hw, STATUS) & E1000_STATUS_FUNC_1)) { + swfw = E1000_SWFW_PHY1_SM; + } else { + swfw = E1000_SWFW_PHY0_SM; + } + if (e1000_swfw_sync_acquire(hw, swfw)) { + DEBUGOUT("Unable to acquire swfw sync\n"); + return -E1000_ERR_SWFW_SYNC; + } /* Read the device control register and assert the E1000_CTRL_PHY_RST * bit. Then, take it out of reset. */ ctrl = E1000_READ_REG(hw, CTRL); E1000_WRITE_REG(hw, CTRL, ctrl | E1000_CTRL_PHY_RST); E1000_WRITE_FLUSH(hw); - mdelay(10); + + if (hw->mac_type < e1000_82571) + udelay(10); + else + udelay(100); + E1000_WRITE_REG(hw, CTRL, ctrl); E1000_WRITE_FLUSH(hw); + + if (hw->mac_type >= e1000_82571) + mdelay(10); + } else { /* Read the Extended Device Control Register, assert the PHY_RESET_DIR * bit to put the PHY into reset. Then, take it out of reset. @@ -2468,6 +4374,127 @@ e1000_phy_hw_reset(struct e1000_hw *hw) E1000_WRITE_FLUSH(hw); } udelay(150); + + if ((hw->mac_type == e1000_82541) || (hw->mac_type == e1000_82547)) { + /* Configure activity LED after PHY reset */ + led_ctrl = E1000_READ_REG(hw, LEDCTL); + led_ctrl &= IGP_ACTIVITY_LED_MASK; + led_ctrl |= (IGP_ACTIVITY_LED_ENABLE | IGP_LED3_MODE); + E1000_WRITE_REG(hw, LEDCTL, led_ctrl); + } + + /* Wait for FW to finish PHY configuration. */ + ret_val = e1000_get_phy_cfg_done(hw); + if (ret_val != E1000_SUCCESS) + return ret_val; + + return ret_val; +} + +/****************************************************************************** + * IGP phy init script - initializes the GbE PHY + * + * hw - Struct containing variables accessed by shared code + *****************************************************************************/ +static void +e1000_phy_init_script(struct e1000_hw *hw) +{ + uint32_t ret_val; + uint16_t phy_saved_data; + DEBUGFUNC(); + + if (hw->phy_init_script) { + mdelay(20); + + /* Save off the current value of register 0x2F5B to be + * restored at the end of this routine. */ + ret_val = e1000_read_phy_reg(hw, 0x2F5B, &phy_saved_data); + + /* Disabled the PHY transmitter */ + e1000_write_phy_reg(hw, 0x2F5B, 0x0003); + + mdelay(20); + + e1000_write_phy_reg(hw, 0x0000, 0x0140); + + mdelay(5); + + switch (hw->mac_type) { + case e1000_82541: + case e1000_82547: + e1000_write_phy_reg(hw, 0x1F95, 0x0001); + + e1000_write_phy_reg(hw, 0x1F71, 0xBD21); + + e1000_write_phy_reg(hw, 0x1F79, 0x0018); + + e1000_write_phy_reg(hw, 0x1F30, 0x1600); + + e1000_write_phy_reg(hw, 0x1F31, 0x0014); + + e1000_write_phy_reg(hw, 0x1F32, 0x161C); + + e1000_write_phy_reg(hw, 0x1F94, 0x0003); + + e1000_write_phy_reg(hw, 0x1F96, 0x003F); + + e1000_write_phy_reg(hw, 0x2010, 0x0008); + break; + + case e1000_82541_rev_2: + case e1000_82547_rev_2: + e1000_write_phy_reg(hw, 0x1F73, 0x0099); + break; + default: + break; + } + + e1000_write_phy_reg(hw, 0x0000, 0x3300); + + mdelay(20); + + /* Now enable the transmitter */ + e1000_write_phy_reg(hw, 0x2F5B, phy_saved_data); + + if (hw->mac_type == e1000_82547) { + uint16_t fused, fine, coarse; + + /* Move to analog registers page */ + e1000_read_phy_reg(hw, + IGP01E1000_ANALOG_SPARE_FUSE_STATUS, &fused); + + if (!(fused & IGP01E1000_ANALOG_SPARE_FUSE_ENABLED)) { + e1000_read_phy_reg(hw, + IGP01E1000_ANALOG_FUSE_STATUS, &fused); + + fine = fused & IGP01E1000_ANALOG_FUSE_FINE_MASK; + coarse = fused + & IGP01E1000_ANALOG_FUSE_COARSE_MASK; + + if (coarse > + IGP01E1000_ANALOG_FUSE_COARSE_THRESH) { + coarse -= + IGP01E1000_ANALOG_FUSE_COARSE_10; + fine -= IGP01E1000_ANALOG_FUSE_FINE_1; + } else if (coarse + == IGP01E1000_ANALOG_FUSE_COARSE_THRESH) + fine -= IGP01E1000_ANALOG_FUSE_FINE_10; + + fused = (fused + & IGP01E1000_ANALOG_FUSE_POLY_MASK) | + (fine + & IGP01E1000_ANALOG_FUSE_FINE_MASK) | + (coarse + & IGP01E1000_ANALOG_FUSE_COARSE_MASK); + + e1000_write_phy_reg(hw, + IGP01E1000_ANALOG_FUSE_CONTROL, fused); + e1000_write_phy_reg(hw, + IGP01E1000_ANALOG_FUSE_BYPASS, + IGP01E1000_ANALOG_FUSE_ENABLE_SW_CONTROL); + } + } + } }
/****************************************************************************** @@ -2475,26 +4502,49 @@ e1000_phy_hw_reset(struct e1000_hw *hw) * * hw - Struct containing variables accessed by shared code * -* Sets bit 15 of the MII Control regiser +* Sets bit 15 of the MII Control register ******************************************************************************/ -static int +int32_t e1000_phy_reset(struct e1000_hw *hw) { + int32_t ret_val; uint16_t phy_data;
DEBUGFUNC();
- if (e1000_read_phy_reg(hw, PHY_CTRL, &phy_data) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; - } - phy_data |= MII_CR_RESET; - if (e1000_write_phy_reg(hw, PHY_CTRL, phy_data) < 0) { - DEBUGOUT("PHY Write Error\n"); - return -E1000_ERR_PHY; + /* In the case of the phy reset being blocked, it's not an error, we + * simply return success without performing the reset. */ + ret_val = e1000_check_phy_reset_block(hw); + if (ret_val) + return E1000_SUCCESS; + + switch (hw->phy_type) { + case e1000_phy_igp: + case e1000_phy_igp_2: + case e1000_phy_igp_3: + case e1000_phy_ife: + ret_val = e1000_phy_hw_reset(hw); + if (ret_val) + return ret_val; + break; + default: + ret_val = e1000_read_phy_reg(hw, PHY_CTRL, &phy_data); + if (ret_val) + return ret_val; + + phy_data |= MII_CR_RESET; + ret_val = e1000_write_phy_reg(hw, PHY_CTRL, phy_data); + if (ret_val) + return ret_val; + + udelay(1); + break; } - udelay(1); - return 0; + + if (hw->phy_type == e1000_phy_igp || hw->phy_type == e1000_phy_igp_2) + e1000_phy_init_script(hw); + + return E1000_SUCCESS; }
static int e1000_set_phy_type (struct e1000_hw *hw) @@ -2508,12 +4558,29 @@ static int e1000_set_phy_type (struct e1000_hw *hw) case M88E1000_E_PHY_ID: case M88E1000_I_PHY_ID: case M88E1011_I_PHY_ID: + case M88E1111_I_PHY_ID: hw->phy_type = e1000_phy_m88; break; case IGP01E1000_I_PHY_ID: if (hw->mac_type == e1000_82541 || - hw->mac_type == e1000_82541_rev_2) { + hw->mac_type == e1000_82541_rev_2 || + hw->mac_type == e1000_82547 || + hw->mac_type == e1000_82547_rev_2) { hw->phy_type = e1000_phy_igp; + hw->phy_type = e1000_phy_igp; + break; + } + case IGP03E1000_E_PHY_ID: + hw->phy_type = e1000_phy_igp_3; + break; + case IFE_E_PHY_ID: + case IFE_PLUS_E_PHY_ID: + case IFE_C_E_PHY_ID: + hw->phy_type = e1000_phy_ife; + break; + case GG82563_E_PHY_ID: + if (hw->mac_type == e1000_80003es2lan) { + hw->phy_type = e1000_phy_gg82563; break; } /* Fall Through */ @@ -2531,27 +4598,47 @@ static int e1000_set_phy_type (struct e1000_hw *hw) * * hw - Struct containing variables accessed by shared code ******************************************************************************/ -static int +static int32_t e1000_detect_gig_phy(struct e1000_hw *hw) { - int32_t phy_init_status; + int32_t phy_init_status, ret_val; uint16_t phy_id_high, phy_id_low; - int match = FALSE; + boolean_t match = FALSE;
DEBUGFUNC();
- /* Read the PHY ID Registers to identify which PHY is onboard. */ - if (e1000_read_phy_reg(hw, PHY_ID1, &phy_id_high) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; + /* The 82571 firmware may still be configuring the PHY. In this + * case, we cannot access the PHY until the configuration is done. So + * we explicitly set the PHY values. */ + if (hw->mac_type == e1000_82571 || + hw->mac_type == e1000_82572) { + hw->phy_id = IGP01E1000_I_PHY_ID; + hw->phy_type = e1000_phy_igp_2; + return E1000_SUCCESS; } + + /* ESB-2 PHY reads require e1000_phy_gg82563 to be set because of a + * work- around that forces PHY page 0 to be set or the reads fail. + * The rest of the code in this routine uses e1000_read_phy_reg to + * read the PHY ID. So for ESB-2 we need to have this set so our + * reads won't fail. If the attached PHY is not a e1000_phy_gg82563, + * the routines below will figure this out as well. */ + if (hw->mac_type == e1000_80003es2lan) + hw->phy_type = e1000_phy_gg82563; + + /* Read the PHY ID Registers to identify which PHY is onboard. */ + ret_val = e1000_read_phy_reg(hw, PHY_ID1, &phy_id_high); + if (ret_val) + return ret_val; + hw->phy_id = (uint32_t) (phy_id_high << 16); - udelay(2); - if (e1000_read_phy_reg(hw, PHY_ID2, &phy_id_low) < 0) { - DEBUGOUT("PHY Read Error\n"); - return -E1000_ERR_PHY; - } + udelay(20); + ret_val = e1000_read_phy_reg(hw, PHY_ID2, &phy_id_low); + if (ret_val) + return ret_val; + hw->phy_id |= (uint32_t) (phy_id_low & PHY_REVISION_MASK); + hw->phy_revision = (uint32_t) phy_id_low & ~PHY_REVISION_MASK;
switch (hw->mac_type) { case e1000_82543: @@ -2564,15 +4651,38 @@ e1000_detect_gig_phy(struct e1000_hw *hw) break; case e1000_82540: case e1000_82545: + case e1000_82545_rev_3: case e1000_82546: + case e1000_82546_rev_3: if (hw->phy_id == M88E1011_I_PHY_ID) match = TRUE; break; + case e1000_82541: case e1000_82541_rev_2: + case e1000_82547: + case e1000_82547_rev_2: if(hw->phy_id == IGP01E1000_I_PHY_ID) match = TRUE;
break; + case e1000_82573: + if (hw->phy_id == M88E1111_I_PHY_ID) + match = TRUE; + break; + case e1000_80003es2lan: + if (hw->phy_id == GG82563_E_PHY_ID) + match = TRUE; + break; + case e1000_ich8lan: + if (hw->phy_id == IGP03E1000_E_PHY_ID) + match = TRUE; + if (hw->phy_id == IFE_E_PHY_ID) + match = TRUE; + if (hw->phy_id == IFE_PLUS_E_PHY_ID) + match = TRUE; + if (hw->phy_id == IFE_C_E_PHY_ID) + match = TRUE; + break; default: DEBUGOUT("Invalid MAC type %d\n", hw->mac_type); return -E1000_ERR_CONFIG; @@ -2588,6 +4698,60 @@ e1000_detect_gig_phy(struct e1000_hw *hw) return -E1000_ERR_PHY; }
+/***************************************************************************** + * Set media type and TBI compatibility. + * + * hw - Struct containing variables accessed by shared code + * **************************************************************************/ +void +e1000_set_media_type(struct e1000_hw *hw) +{ + uint32_t status; + + DEBUGFUNC(); + + if (hw->mac_type != e1000_82543) { + /* tbi_compatibility is only valid on 82543 */ + hw->tbi_compatibility_en = FALSE; + } + + switch (hw->device_id) { + case E1000_DEV_ID_82545GM_SERDES: + case E1000_DEV_ID_82546GB_SERDES: + case E1000_DEV_ID_82571EB_SERDES: + case E1000_DEV_ID_82571EB_SERDES_DUAL: + case E1000_DEV_ID_82571EB_SERDES_QUAD: + case E1000_DEV_ID_82572EI_SERDES: + case E1000_DEV_ID_80003ES2LAN_SERDES_DPT: + hw->media_type = e1000_media_type_internal_serdes; + break; + default: + switch (hw->mac_type) { + case e1000_82542_rev2_0: + case e1000_82542_rev2_1: + hw->media_type = e1000_media_type_fiber; + break; + case e1000_ich8lan: + case e1000_82573: + /* The STATUS_TBIMODE bit is reserved or reused + * for the this device. + */ + hw->media_type = e1000_media_type_copper; + break; + default: + status = E1000_READ_REG(hw, STATUS); + if (status & E1000_STATUS_TBIMODE) { + hw->media_type = e1000_media_type_fiber; + /* tbi_compatibility not valid on fiber */ + hw->tbi_compatibility_en = FALSE; + } else { + hw->media_type = e1000_media_type_copper; + } + break; + } + } +} + /** * e1000_sw_init - Initialize general software structures (struct e1000_adapter) * @@ -2619,6 +4783,17 @@ e1000_sw_init(struct eth_device *nic, int cardnum) return result; }
+ switch (hw->mac_type) { + default: + break; + case e1000_82541: + case e1000_82547: + case e1000_82541_rev_2: + case e1000_82547_rev_2: + hw->phy_init_script = 1; + break; + } + /* lan a vs. lan b settings */ if (hw->mac_type == e1000_82546) /*this also works w/ multiple 82546 cards */ @@ -2634,6 +4809,7 @@ e1000_sw_init(struct eth_device *nic, int cardnum) hw->fc_send_xon = 1;
/* Media type - copper or fiber */ + e1000_set_media_type(hw);
if (hw->mac_type >= e1000_82543) { uint32_t status = E1000_READ_REG(hw, STATUS); @@ -2649,14 +4825,9 @@ e1000_sw_init(struct eth_device *nic, int cardnum) hw->media_type = e1000_media_type_fiber; }
- if (hw->mac_type < e1000_82543) - hw->report_tx_early = 0; - else - hw->report_tx_early = 1; - hw->tbi_compatibility_en = TRUE; + hw->wait_autoneg_complete = TRUE; #if 0 - hw->wait_autoneg_complete = FALSE; hw->adaptive_ifs = TRUE;
/* Copper options */ @@ -2665,6 +4836,11 @@ e1000_sw_init(struct eth_device *nic, int cardnum) hw->disable_polarity_correction = FALSE; } #endif + if (hw->mac_type < e1000_82543) + hw->report_tx_early = 0; + else + hw->report_tx_early = 1; + return E1000_SUCCESS; }
@@ -2693,7 +4869,8 @@ e1000_configure_tx(struct e1000_hw *hw) { unsigned long ptr; unsigned long tctl; - unsigned long tipg; + unsigned long tipg, tarc; + uint32_t ipgr1, ipgr2;
ptr = (u32) tx_pool; if (ptr & 0xf) @@ -2712,21 +4889,32 @@ e1000_configure_tx(struct e1000_hw *hw) tx_tail = 0;
/* Set the default values for the Tx Inter Packet Gap timer */ + if (hw->mac_type <= e1000_82547_rev_2 && + (hw->media_type == e1000_media_type_fiber || + hw->media_type == e1000_media_type_internal_serdes)) + tipg = DEFAULT_82543_TIPG_IPGT_FIBER; + else + tipg = DEFAULT_82543_TIPG_IPGT_COPPER; + + /* Set the default values for the Tx Inter Packet Gap timer */ switch (hw->mac_type) { case e1000_82542_rev2_0: case e1000_82542_rev2_1: tipg = DEFAULT_82542_TIPG_IPGT; - tipg |= DEFAULT_82542_TIPG_IPGR1 << E1000_TIPG_IPGR1_SHIFT; - tipg |= DEFAULT_82542_TIPG_IPGR2 << E1000_TIPG_IPGR2_SHIFT; + ipgr1 = DEFAULT_82542_TIPG_IPGR1; + ipgr2 = DEFAULT_82542_TIPG_IPGR2; + break; + case e1000_80003es2lan: + ipgr1 = DEFAULT_82543_TIPG_IPGR1; + ipgr2 = DEFAULT_80003ES2LAN_TIPG_IPGR2; break; default: - if (hw->media_type == e1000_media_type_fiber) - tipg = DEFAULT_82543_TIPG_IPGT_FIBER; - else - tipg = DEFAULT_82543_TIPG_IPGT_COPPER; - tipg |= DEFAULT_82543_TIPG_IPGR1 << E1000_TIPG_IPGR1_SHIFT; - tipg |= DEFAULT_82543_TIPG_IPGR2 << E1000_TIPG_IPGR2_SHIFT; + ipgr1 = DEFAULT_82543_TIPG_IPGR1; + ipgr2 = DEFAULT_82543_TIPG_IPGR2; + break; } + tipg |= ipgr1 << E1000_TIPG_IPGR1_SHIFT; + tipg |= ipgr2 << E1000_TIPG_IPGR2_SHIFT; E1000_WRITE_REG(hw, TIPG, tipg); #if 0 /* Set the Tx Interrupt Delay register */ @@ -2739,18 +4927,32 @@ e1000_configure_tx(struct e1000_hw *hw) tctl &= ~E1000_TCTL_CT; tctl |= E1000_TCTL_EN | E1000_TCTL_PSP | (E1000_COLLISION_THRESHOLD << E1000_CT_SHIFT); - E1000_WRITE_REG(hw, TCTL, tctl); + + if (hw->mac_type == e1000_82571 || hw->mac_type == e1000_82572) { + tarc = E1000_READ_REG(hw, TARC0); + /* set the speed mode bit, we'll clear it if we're not at + * gigabit link later */ + /* git bit can be set to 1*/ + } else if (hw->mac_type == e1000_80003es2lan) { + tarc = E1000_READ_REG(hw, TARC0); + tarc |= 1; + E1000_WRITE_REG(hw, TARC0, tarc); + tarc = E1000_READ_REG(hw, TARC1); + tarc |= 1; + E1000_WRITE_REG(hw, TARC1, tarc); + } +
e1000_config_collision_dist(hw); -#if 0 - /* Setup Transmit Descriptor Settings for this adapter */ - adapter->txd_cmd = E1000_TXD_CMD_IFCS | E1000_TXD_CMD_IDE; + /* Setup Transmit Descriptor Settings for eop descriptor */ + hw->txd_cmd = E1000_TXD_CMD_EOP | E1000_TXD_CMD_IFCS;
- if (adapter->hw.report_tx_early == 1) - adapter->txd_cmd |= E1000_TXD_CMD_RS; + /* Need to set up RS bit */ + if (hw->mac_type < e1000_82543) + hw->txd_cmd |= E1000_TXD_CMD_RPS; else - adapter->txd_cmd |= E1000_TXD_CMD_RPS; -#endif + hw->txd_cmd |= E1000_TXD_CMD_RS; + E1000_WRITE_REG(hw, TCTL, tctl); }
/** @@ -2766,8 +4968,9 @@ e1000_setup_rctl(struct e1000_hw *hw)
rctl &= ~(3 << E1000_RCTL_MO_SHIFT);
- rctl |= E1000_RCTL_EN | E1000_RCTL_BAM | E1000_RCTL_LBM_NO | E1000_RCTL_RDMTS_HALF; /* | - (hw.mc_filter_type << E1000_RCTL_MO_SHIFT); */ + rctl |= E1000_RCTL_EN | E1000_RCTL_BAM | E1000_RCTL_LBM_NO + | E1000_RCTL_RDMTS_HALF; /* | + (hw.mc_filter_type << E1000_RCTL_MO_SHIFT); */
if (hw->tbi_compatibility_on == 1) rctl |= E1000_RCTL_SBP; @@ -2808,7 +5011,7 @@ static void e1000_configure_rx(struct e1000_hw *hw) { unsigned long ptr; - unsigned long rctl; + unsigned long rctl, ctrl_ext; #if 0 unsigned long rxcsum; #endif @@ -2832,6 +5035,13 @@ e1000_configure_rx(struct e1000_hw *hw) E1000_WRITE_REG(hw, ITR, DEFAULT_ITR); }
+ if (hw->mac_type >= e1000_82571) { + ctrl_ext = E1000_READ_REG(hw, CTRL_EXT); + /* Reset delay timers after every interrupt */ + ctrl_ext |= E1000_CTRL_EXT_INT_TIMER_CLR; + E1000_WRITE_REG(hw, CTRL_EXT, ctrl_ext); + E1000_WRITE_FLUSH(hw); + } /* Setup the Base and Length of the Rx Descriptor Ring */ ptr = (u32) rx_pool; if (ptr & 0xf) @@ -2891,11 +5101,11 @@ e1000_transmit(struct eth_device *nic, volatile void *packet, int length) tx_tail = (tx_tail + 1) % 8;
txp->buffer_addr = cpu_to_le64(virt_to_bus(packet)); - txp->lower.data = cpu_to_le32(E1000_TXD_CMD_RPS | E1000_TXD_CMD_EOP | - E1000_TXD_CMD_IFCS | length); + txp->lower.data = cpu_to_le32(hw->txd_cmd | length); txp->upper.data = 0; E1000_WRITE_REG(hw, TDT, tx_tail);
+ E1000_WRITE_FLUSH(hw); while (!(le32_to_cpu(txp->upper.data) & E1000_TXD_STAT_DD)) { if (i++ > TOUT_LOOP) { DEBUGOUT("e1000: tx timeout\n"); @@ -2972,6 +5182,37 @@ e1000_init(struct eth_device *nic, bd_t * bis) return 1; }
+/****************************************************************************** + * Gets the current PCI bus type of hardware + * + * hw - Struct containing variables accessed by shared code + *****************************************************************************/ +void e1000_get_bus_type(struct e1000_hw *hw) +{ + uint32_t status; + + switch (hw->mac_type) { + case e1000_82542_rev2_0: + case e1000_82542_rev2_1: + hw->bus_type = e1000_bus_type_pci; + break; + case e1000_82571: + case e1000_82572: + case e1000_82573: + case e1000_80003es2lan: + hw->bus_type = e1000_bus_type_pci_express; + break; + case e1000_ich8lan: + hw->bus_type = e1000_bus_type_pci_express; + break; + default: + status = E1000_READ_REG(hw, STATUS); + hw->bus_type = (status & E1000_STATUS_PCIX_MODE) ? + e1000_bus_type_pcix : e1000_bus_type_pci; + break; + } +} + /************************************************************************** PROBE - Look for an adapter, this routine's visible to the outside You should omit the last argument struct pci_device * for a non-PCI NIC @@ -3025,6 +5266,7 @@ e1000_initialize(bd_t * bis) hw->original_fc = e1000_fc_default; #endif hw->autoneg_failed = 0; + hw->autoneg = 1; hw->get_link_status = TRUE; hw->hw_addr = (typeof(hw->hw_addr)) iobase; hw->mac_type = e1000_undefined; @@ -3035,7 +5277,16 @@ e1000_initialize(bd_t * bis) free(nic); return 0; } + if (e1000_check_phy_reset_block(hw)) + printf("phy reset block error \n"); + e1000_reset_hw(hw); #if !(defined(CONFIG_AP1000) || defined(CONFIG_MVBC_1G)) + if (e1000_init_eeprom_params(hw)) { + printf("The EEPROM Checksum Is Not Valid\n"); + free(hw); + free(nic); + return 0; + } if (e1000_validate_eeprom_checksum(nic) < 0) { printf("The EEPROM Checksum Is Not Valid\n"); free(hw); @@ -3045,7 +5296,8 @@ e1000_initialize(bd_t * bis) #endif e1000_read_mac_addr(nic);
- E1000_WRITE_REG(hw, PBA, E1000_DEFAULT_PBA); + /* get the bus type information */ + e1000_get_bus_type(hw);
printf("e1000: %02x:%02x:%02x:%02x:%02x:%02x\n", nic->enetaddr[0], nic->enetaddr[1], nic->enetaddr[2], diff --git a/drivers/net/e1000.h b/drivers/net/e1000.h index 08042a8..3bf745a 100644 --- a/drivers/net/e1000.h +++ b/drivers/net/e1000.h @@ -44,6 +44,7 @@
#ifdef E1000_DEBUG #define E1000_DBG(args...) printf("e1000: " args) +#define E1000_DBG_ROY(args...) printf("roy:e1000: " args) #define DEBUGOUT(fmt,args...) printf(fmt ,##args) #define DEBUGFUNC() printf("%s\n", __FUNCTION__); #else @@ -71,9 +72,18 @@ typedef enum { e1000_82544, e1000_82540, e1000_82545, + e1000_82545_rev_3, e1000_82546, + e1000_82546_rev_3, e1000_82541, e1000_82541_rev_2, + e1000_82547, + e1000_82547_rev_2, + e1000_82571, + e1000_82572, + e1000_82573, + e1000_80003es2lan, + e1000_ich8lan, e1000_num_macs } e1000_mac_type;
@@ -81,10 +91,21 @@ typedef enum { typedef enum { e1000_media_type_copper = 0, e1000_media_type_fiber = 1, + e1000_media_type_internal_serdes = 2, e1000_num_media_types } e1000_media_type;
typedef enum { + e1000_eeprom_uninitialized = 0, + e1000_eeprom_spi, + e1000_eeprom_microwire, + e1000_eeprom_flash, + e1000_eeprom_ich8, + e1000_eeprom_none, /* No NVM support */ + e1000_num_eeprom_types +} e1000_eeprom_type; + +typedef enum { e1000_10_half = 0, e1000_10_full = 1, e1000_100_half = 2, @@ -109,7 +130,9 @@ typedef enum { typedef enum { e1000_bus_type_unknown = 0, e1000_bus_type_pci, - e1000_bus_type_pcix + e1000_bus_type_pcix, + e1000_bus_type_pci_express, + e1000_bus_type_reserved } e1000_bus_type;
/* PCI bus speeds */ @@ -172,10 +195,13 @@ typedef enum { } e1000_1000t_rx_status;
typedef enum { - e1000_phy_m88 = 0, - e1000_phy_igp, - e1000_phy_igp_2, - e1000_phy_undefined = 0xFF + e1000_phy_m88 = 0, + e1000_phy_igp, + e1000_phy_igp_2, + e1000_phy_gg82563, + e1000_phy_igp_3, + e1000_phy_ife, + e1000_phy_undefined = 0xFF } e1000_phy_type;
struct e1000_phy_info { @@ -207,6 +233,7 @@ struct e1000_phy_stats { #define E1000_ERR_MASTER_REQUESTS_PENDING 10 #define E1000_ERR_HOST_INTERFACE_COMMAND 11 #define E1000_BLK_PHY_RESET 12 +#define E1000_ERR_SWFW_SYNC 13
/* PCI Device IDs */ #define E1000_DEV_ID_82542 0x1000 @@ -217,14 +244,151 @@ struct e1000_phy_stats { #define E1000_DEV_ID_82544GC_COPPER 0x100C #define E1000_DEV_ID_82544GC_LOM 0x100D #define E1000_DEV_ID_82540EM 0x100E -#define E1000_DEV_ID_82540EM_LOM 0x1015 -#define E1000_DEV_ID_82545GM_COPPER 0x1026 -#define E1000_DEV_ID_82545EM_COPPER 0x100F -#define E1000_DEV_ID_82545EM_FIBER 0x1011 -#define E1000_DEV_ID_82546EB_COPPER 0x1010 -#define E1000_DEV_ID_82546EB_FIBER 0x1012 -#define E1000_DEV_ID_82541ER 0x1078 -#define E1000_DEV_ID_82541GI_LF 0x107C +#define E1000_DEV_ID_82540EM_LOM 0x1015 +#define E1000_DEV_ID_82540EP_LOM 0x1016 +#define E1000_DEV_ID_82540EP 0x1017 +#define E1000_DEV_ID_82540EP_LP 0x101E +#define E1000_DEV_ID_82545EM_COPPER 0x100F +#define E1000_DEV_ID_82545EM_FIBER 0x1011 +#define E1000_DEV_ID_82545GM_COPPER 0x1026 +#define E1000_DEV_ID_82545GM_FIBER 0x1027 +#define E1000_DEV_ID_82545GM_SERDES 0x1028 +#define E1000_DEV_ID_82546EB_COPPER 0x1010 +#define E1000_DEV_ID_82546EB_FIBER 0x1012 +#define E1000_DEV_ID_82546EB_QUAD_COPPER 0x101D +#define E1000_DEV_ID_82541EI 0x1013 +#define E1000_DEV_ID_82541EI_MOBILE 0x1018 +#define E1000_DEV_ID_82541ER_LOM 0x1014 +#define E1000_DEV_ID_82541ER 0x1078 +#define E1000_DEV_ID_82547GI 0x1075 +#define E1000_DEV_ID_82541GI 0x1076 +#define E1000_DEV_ID_82541GI_MOBILE 0x1077 +#define E1000_DEV_ID_82541GI_LF 0x107C +#define E1000_DEV_ID_82546GB_COPPER 0x1079 +#define E1000_DEV_ID_82546GB_FIBER 0x107A +#define E1000_DEV_ID_82546GB_SERDES 0x107B +#define E1000_DEV_ID_82546GB_PCIE 0x108A +#define E1000_DEV_ID_82546GB_QUAD_COPPER 0x1099 +#define E1000_DEV_ID_82547EI 0x1019 +#define E1000_DEV_ID_82547EI_MOBILE 0x101A +#define E1000_DEV_ID_82571EB_COPPER 0x105E +#define E1000_DEV_ID_82571EB_FIBER 0x105F +#define E1000_DEV_ID_82571EB_SERDES 0x1060 +#define E1000_DEV_ID_82571EB_QUAD_COPPER 0x10A4 +#define E1000_DEV_ID_82571PT_QUAD_COPPER 0x10D5 +#define E1000_DEV_ID_82571EB_QUAD_FIBER 0x10A5 +#define E1000_DEV_ID_82571EB_QUAD_COPPER_LOWPROFILE 0x10BC +#define E1000_DEV_ID_82571EB_SERDES_DUAL 0x10D9 +#define E1000_DEV_ID_82571EB_SERDES_QUAD 0x10DA +#define E1000_DEV_ID_82572EI_COPPER 0x107D +#define E1000_DEV_ID_82572EI_FIBER 0x107E +#define E1000_DEV_ID_82572EI_SERDES 0x107F +#define E1000_DEV_ID_82572EI 0x10B9 +#define E1000_DEV_ID_82573E 0x108B +#define E1000_DEV_ID_82573E_IAMT 0x108C +#define E1000_DEV_ID_82573L 0x109A +#define E1000_DEV_ID_82546GB_QUAD_COPPER_KSP3 0x10B5 +#define E1000_DEV_ID_80003ES2LAN_COPPER_DPT 0x1096 +#define E1000_DEV_ID_80003ES2LAN_SERDES_DPT 0x1098 +#define E1000_DEV_ID_80003ES2LAN_COPPER_SPT 0x10BA +#define E1000_DEV_ID_80003ES2LAN_SERDES_SPT 0x10BB + +#define E1000_DEV_ID_ICH8_IGP_M_AMT 0x1049 +#define E1000_DEV_ID_ICH8_IGP_AMT 0x104A +#define E1000_DEV_ID_ICH8_IGP_C 0x104B +#define E1000_DEV_ID_ICH8_IFE 0x104C +#define E1000_DEV_ID_ICH8_IFE_GT 0x10C4 +#define E1000_DEV_ID_ICH8_IFE_G 0x10C5 +#define E1000_DEV_ID_ICH8_IGP_M 0x104D + +#define IGP03E1000_E_PHY_ID 0x02A80390 +#define IFE_E_PHY_ID 0x02A80330 /* 10/100 PHY */ +#define IFE_PLUS_E_PHY_ID 0x02A80320 +#define IFE_C_E_PHY_ID 0x02A80310 + +#define IFE_PHY_EXTENDED_STATUS_CONTROL 0x10 /* 100BaseTx Extended Status, + Control and Address */ +#define IFE_PHY_SPECIAL_CONTROL 0x11 /* 100BaseTx PHY special + control register */ +#define IFE_PHY_RCV_FALSE_CARRIER 0x13 /* 100BaseTx Receive False + Carrier Counter */ +#define IFE_PHY_RCV_DISCONNECT 0x14 /* 100BaseTx Receive Disconnet + Counter */ +#define IFE_PHY_RCV_ERROT_FRAME 0x15 /* 100BaseTx Receive Error + Frame Counter */ +#define IFE_PHY_RCV_SYMBOL_ERR 0x16 /* Receive Symbol Error + Counter */ +#define IFE_PHY_PREM_EOF_ERR 0x17 /* 100BaseTx Receive + Premature End Of Frame + Error Counter */ +#define IFE_PHY_RCV_EOF_ERR 0x18 /* 10BaseT Receive End Of + Frame Error Counter */ +#define IFE_PHY_TX_JABBER_DETECT 0x19 /* 10BaseT Transmit Jabber + Detect Counter */ +#define IFE_PHY_EQUALIZER 0x1A /* PHY Equalizer Control and + Status */ +#define IFE_PHY_SPECIAL_CONTROL_LED 0x1B /* PHY special control and + LED configuration */ +#define IFE_PHY_MDIX_CONTROL 0x1C /* MDI/MDI-X Control register */ +#define IFE_PHY_HWI_CONTROL 0x1D /* Hardware Integrity Control + (HWI) */ + +#define IFE_PESC_REDUCED_POWER_DOWN_DISABLE 0x2000 /* Defaut 1 = Disable auto + reduced power down */ +#define IFE_PESC_100BTX_POWER_DOWN 0x0400 /* Indicates the power + state of 100BASE-TX */ +#define IFE_PESC_10BTX_POWER_DOWN 0x0200 /* Indicates the power + state of 10BASE-T */ +#define IFE_PESC_POLARITY_REVERSED 0x0100 /* Indicates 10BASE-T + polarity */ +#define IFE_PESC_PHY_ADDR_MASK 0x007C /* Bit 6:2 for sampled PHY + address */ +#define IFE_PESC_SPEED 0x0002 /* Auto-negotiation speed + result 1=100Mbs, 0=10Mbs */ +#define IFE_PESC_DUPLEX 0x0001 /* Auto-negotiation + duplex result 1=Full, 0=Half */ +#define IFE_PESC_POLARITY_REVERSED_SHIFT 8 + +#define IFE_PSC_DISABLE_DYNAMIC_POWER_DOWN 0x0100 /* 1 = Dyanmic Power Down + disabled */ +#define IFE_PSC_FORCE_POLARITY 0x0020 /* 1=Reversed Polarity, + 0=Normal */ +#define IFE_PSC_AUTO_POLARITY_DISABLE 0x0010 /* 1=Auto Polarity + Disabled, 0=Enabled */ +#define IFE_PSC_JABBER_FUNC_DISABLE 0x0001 /* 1=Jabber Disabled, + 0=Normal Jabber Operation */ +#define IFE_PSC_FORCE_POLARITY_SHIFT 5 +#define IFE_PSC_AUTO_POLARITY_DISABLE_SHIFT 4 + +#define IFE_PMC_AUTO_MDIX 0x0080 /* 1=enable MDI/MDI-X + feature, default 0=disabled */ +#define IFE_PMC_FORCE_MDIX 0x0040 /* 1=force MDIX-X, + 0=force MDI */ +#define IFE_PMC_MDIX_STATUS 0x0020 /* 1=MDI-X, 0=MDI */ +#define IFE_PMC_AUTO_MDIX_COMPLETE 0x0010 /* Resolution algorithm + is completed */ +#define IFE_PMC_MDIX_MODE_SHIFT 6 +#define IFE_PHC_MDIX_RESET_ALL_MASK 0x0000 /* Disable auto MDI-X */ + +#define IFE_PHC_HWI_ENABLE 0x8000 /* Enable the HWI + feature */ +#define IFE_PHC_ABILITY_CHECK 0x4000 /* 1= Test Passed, + 0=failed */ +#define IFE_PHC_TEST_EXEC 0x2000 /* PHY launch test pulses + on the wire */ +#define IFE_PHC_HIGHZ 0x0200 /* 1 = Open Circuit */ +#define IFE_PHC_LOWZ 0x0400 /* 1 = Short Circuit */ +#define IFE_PHC_LOW_HIGH_Z_MASK 0x0600 /* Mask for indication + type of problem on the line */ +#define IFE_PHC_DISTANCE_MASK 0x01FF /* Mask for distance to + the cable problem, in 80cm granularity */ +#define IFE_PHC_RESET_ALL_MASK 0x0000 /* Disable HWI */ +#define IFE_PSCL_PROBE_MODE 0x0020 /* LED Probe mode */ +#define IFE_PSCL_PROBE_LEDS_OFF 0x0006 /* Force LEDs 0 and 2 + off */ +#define IFE_PSCL_PROBE_LEDS_ON 0x0007 /* Force LEDs 0 and 2 on */ + + #define NUM_DEV_IDS 16
#define NODE_ADDRESS_SIZE 6 @@ -235,6 +399,10 @@ struct e1000_phy_stats {
#define E1000_82542_2_0_REV_ID 2 #define E1000_82542_2_1_REV_ID 3 +#define E1000_REVISION_0 0 +#define E1000_REVISION_1 1 +#define E1000_REVISION_2 2 +#define E1000_REVISION_3 3
#define SPEED_10 10 #define SPEED_100 100 @@ -522,11 +690,27 @@ struct e1000_ffvt_entry { #define E1000_TXCW 0x00178 /* TX Configuration Word - RW */ #define E1000_RXCW 0x00180 /* RX Configuration Word - RO */ #define E1000_TCTL 0x00400 /* TX Control - RW */ +#define E1000_TCTL_EXT 0x00404 /* Extended TX Control - RW */ #define E1000_TIPG 0x00410 /* TX Inter-packet gap -RW */ #define E1000_TBT 0x00448 /* TX Burst Timer - RW */ #define E1000_AIT 0x00458 /* Adaptive Interframe Spacing Throttle - RW */ #define E1000_LEDCTL 0x00E00 /* LED Control - RW */ +#define E1000_EXTCNF_CTRL 0x00F00 /* Extended Configuration Control */ +#define E1000_EXTCNF_SIZE 0x00F08 /* Extended Configuration Size */ +#define E1000_PHY_CTRL 0x00F10 /* PHY Control Register in CSR */ +#define FEXTNVM_SW_CONFIG 0x0001 #define E1000_PBA 0x01000 /* Packet Buffer Allocation - RW */ +#define E1000_PBS 0x01008 /* Packet Buffer Size */ +#define E1000_EEMNGCTL 0x01010 /* MNG EEprom Control */ +#define E1000_FLASH_UPDATES 1000 +#define E1000_EEARBC 0x01024 /* EEPROM Auto Read Bus Control */ +#define E1000_FLASHT 0x01028 /* FLASH Timer Register */ +#define E1000_EEWR 0x0102C /* EEPROM Write Register - RW */ +#define E1000_FLSWCTL 0x01030 /* FLASH control register */ +#define E1000_FLSWDATA 0x01034 /* FLASH data register */ +#define E1000_FLSWCNT 0x01038 /* FLASH Access Counter */ +#define E1000_FLOP 0x0103C /* FLASH Opcode Register */ +#define E1000_ERT 0x02008 /* Early Rx Threshold - RW */ #define E1000_FCRTL 0x02160 /* Flow Control Receive Threshold Low - RW */ #define E1000_FCRTH 0x02168 /* Flow Control Receive Threshold High - RW */ #define E1000_RDBAL 0x02800 /* RX Descriptor Base Address Low - RW */ @@ -539,6 +723,11 @@ struct e1000_ffvt_entry { #define E1000_RADV 0x0282C /* RX Interrupt Absolute Delay Timer - RW */ #define E1000_RSRPD 0x02C00 /* RX Small Packet Detect - RW */ #define E1000_TXDMAC 0x03000 /* TX DMA Control - RW */ +#define E1000_TDFH 0x03410 /* TX Data FIFO Head - RW */ +#define E1000_TDFT 0x03418 /* TX Data FIFO Tail - RW */ +#define E1000_TDFHS 0x03420 /* TX Data FIFO Head Saved - RW */ +#define E1000_TDFTS 0x03428 /* TX Data FIFO Tail Saved - RW */ +#define E1000_TDFPC 0x03430 /* TX Data FIFO Packet Count - RW */ #define E1000_TDBAL 0x03800 /* TX Descriptor Base Address Low - RW */ #define E1000_TDBAH 0x03804 /* TX Descriptor Base Address High - RW */ #define E1000_TDLEN 0x03808 /* TX Descriptor Length - RW */ @@ -548,6 +737,14 @@ struct e1000_ffvt_entry { #define E1000_TXDCTL 0x03828 /* TX Descriptor Control - RW */ #define E1000_TADV 0x0382C /* TX Interrupt Absolute Delay Val - RW */ #define E1000_TSPMT 0x03830 /* TCP Segmentation PAD & Min Threshold - RW */ +#define E1000_TARC0 0x03840 /* TX Arbitration Count (0) */ +#define E1000_TDBAL1 0x03900 /* TX Desc Base Address Low (1) - RW */ +#define E1000_TDBAH1 0x03904 /* TX Desc Base Address High (1) - RW */ +#define E1000_TDLEN1 0x03908 /* TX Desc Length (1) - RW */ +#define E1000_TDH1 0x03910 /* TX Desc Head (1) - RW */ +#define E1000_TDT1 0x03918 /* TX Desc Tail (1) - RW */ +#define E1000_TXDCTL1 0x03928 /* TX Descriptor Control (1) - RW */ +#define E1000_TARC1 0x03940 /* TX Arbitration Count (1) */ #define E1000_CRCERRS 0x04000 /* CRC Error Count - R/clr */ #define E1000_ALGNERRC 0x04004 /* Alignment Error Count - R/clr */ #define E1000_SYMERRS 0x04008 /* Symbol Error Count - R/clr */ @@ -812,6 +1009,44 @@ struct e1000_hw_stats { uint64_t tsctfc; };
+struct e1000_eeprom_info { + e1000_eeprom_type type; + uint16_t word_size; + uint16_t opcode_bits; + uint16_t address_bits; + uint16_t delay_usec; + uint16_t page_size; + boolean_t use_eerd; + boolean_t use_eewr; +}; + +typedef enum { + e1000_smart_speed_default = 0, + e1000_smart_speed_on, + e1000_smart_speed_off +} e1000_smart_speed; + +typedef enum { + e1000_dsp_config_disabled = 0, + e1000_dsp_config_enabled, + e1000_dsp_config_activated, + e1000_dsp_config_undefined = 0xFF +} e1000_dsp_config; + +typedef enum { + e1000_ms_hw_default = 0, + e1000_ms_force_master, + e1000_ms_force_slave, + e1000_ms_auto +} e1000_ms_type; + +typedef enum { + e1000_ffe_config_enabled = 0, + e1000_ffe_config_active, + e1000_ffe_config_blocked +} e1000_ffe_config; + + /* Structure containing variables used by the shared code (e1000_hw.c) */ struct e1000_hw { pci_dev_t pdev; @@ -819,16 +1054,26 @@ struct e1000_hw { e1000_mac_type mac_type; e1000_phy_type phy_type; uint32_t phy_init_script; + uint32_t txd_cmd; e1000_media_type media_type; e1000_lan_loc lan_loc; e1000_fc_type fc; + e1000_bus_type bus_type; #if 0 e1000_bus_speed bus_speed; e1000_bus_width bus_width; - e1000_bus_type bus_type; uint32_t io_base; #endif + uint32_t asf_firmware_present; + uint32_t eeprom_semaphore_present; + uint32_t swfw_sync_present; + uint32_t swfwhw_semaphore_present; + struct e1000_eeprom_info eeprom; + e1000_ms_type master_slave; + e1000_ms_type original_master_slave; + e1000_ffe_config ffe_config_state; uint32_t phy_id; + uint32_t phy_revision; uint32_t phy_addr; uint32_t original_fc; uint32_t txcw; @@ -861,31 +1106,45 @@ struct e1000_hw { uint16_t subsystem_id; uint16_t subsystem_vendor_id; uint8_t revision_id; -#if 0 uint8_t autoneg; uint8_t mdix; uint8_t forced_speed_duplex; uint8_t wait_autoneg_complete; uint8_t dma_fairness; -#endif #if 0 uint8_t perm_mac_addr[NODE_ADDRESS_SIZE]; - boolean_t disable_polarity_correction; #endif + boolean_t disable_polarity_correction; + boolean_t speed_downgraded; boolean_t get_link_status; boolean_t tbi_compatibility_en; boolean_t tbi_compatibility_on; + boolean_t fc_strict_ieee; boolean_t fc_send_xon; boolean_t report_tx_early; + boolean_t phy_reset_disable; + boolean_t initialize_hw_bits_disable; #if 0 boolean_t adaptive_ifs; boolean_t ifs_params_forced; boolean_t in_ifs_mode; #endif + e1000_smart_speed smart_speed; + e1000_dsp_config dsp_config_state; };
#define E1000_EEPROM_SWDPIN0 0x0001 /* SWDPIN 0 EEPROM Value */ #define E1000_EEPROM_LED_LOGIC 0x0020 /* Led Logic Word */ +#define E1000_EEPROM_RW_REG_DATA 16 /* Offset to data in EEPROM + read/write registers */ +#define E1000_EEPROM_RW_REG_DONE 2 /* Offset to READ/WRITE done bit */ +#define E1000_EEPROM_RW_REG_START 1 /* First bit for telling part to start + operation */ +#define E1000_EEPROM_RW_ADDR_SHIFT 2 /* Shift to the address bits */ +#define E1000_EEPROM_POLL_WRITE 1 /* Flag for polling for write + complete */ +#define E1000_EEPROM_POLL_READ 0 /* Flag for polling for read complete */ +#define EEPROM_RESERVED_WORD 0xFFFF
/* Register Bit Masks */ /* Device Control */ @@ -957,6 +1216,30 @@ struct e1000_hw { #define E1000_EECD_REQ 0x00000040 /* EEPROM Access Request */ #define E1000_EECD_GNT 0x00000080 /* EEPROM Access Grant */ #define E1000_EECD_PRES 0x00000100 /* EEPROM Present */ +#define E1000_EECD_ADDR_BITS 0x00000400 /* EEPROM Addressing bits based on type + * (0-small, 1-large) */ + +#define E1000_EECD_TYPE 0x00002000 /* EEPROM Type (1-SPI, 0-Microwire) */ +#ifndef E1000_EEPROM_GRANT_ATTEMPTS +#define E1000_EEPROM_GRANT_ATTEMPTS 1000 /* EEPROM # attempts to gain grant */ +#endif +#define E1000_EECD_AUTO_RD 0x00000200 /* EEPROM Auto Read done */ +#define E1000_EECD_SIZE_EX_MASK 0x00007800 /* EEprom Size */ +#define E1000_EECD_SIZE_EX_SHIFT 11 +#define E1000_EECD_NVADDS 0x00018000 /* NVM Address Size */ +#define E1000_EECD_SELSHAD 0x00020000 /* Select Shadow RAM */ +#define E1000_EECD_INITSRAM 0x00040000 /* Initialize Shadow RAM */ +#define E1000_EECD_FLUPD 0x00080000 /* Update FLASH */ +#define E1000_EECD_AUPDEN 0x00100000 /* Enable Autonomous FLASH update */ +#define E1000_EECD_SHADV 0x00200000 /* Shadow RAM Data Valid */ +#define E1000_EECD_SEC1VAL 0x00400000 /* Sector One Valid */ +#define E1000_EECD_SECVAL_SHIFT 22 +#define E1000_STM_OPCODE 0xDB00 +#define E1000_HICR_FW_RESET 0xC0 + +#define E1000_SHADOW_RAM_WORDS 2048 +#define E1000_ICH_NVM_SIG_WORD 0x13 +#define E1000_ICH_NVM_SIG_MASK 0xC0
/* EEPROM Read */ #define E1000_EERD_START 0x00000001 /* Start Read */ @@ -966,14 +1249,62 @@ struct e1000_hw { #define E1000_EERD_DATA_SHIFT 16 #define E1000_EERD_DATA_MASK 0xFFFF0000 /* Read Data */
+/* EEPROM Commands - Microwire */ +#define EEPROM_READ_OPCODE_MICROWIRE 0x6 /* EEPROM read opcode */ +#define EEPROM_WRITE_OPCODE_MICROWIRE 0x5 /* EEPROM write opcode */ +#define EEPROM_ERASE_OPCODE_MICROWIRE 0x7 /* EEPROM erase opcode */ +#define EEPROM_EWEN_OPCODE_MICROWIRE 0x13 /* EEPROM erase/write enable */ +#define EEPROM_EWDS_OPCODE_MICROWIRE 0x10 /* EEPROM erast/write disable */ + +/* EEPROM Commands - SPI */ +#define EEPROM_MAX_RETRY_SPI 5000 /* Max wait of 5ms, for RDY signal */ +#define EEPROM_READ_OPCODE_SPI 0x03 /* EEPROM read opcode */ +#define EEPROM_WRITE_OPCODE_SPI 0x02 /* EEPROM write opcode */ +#define EEPROM_A8_OPCODE_SPI 0x08 /* opcode bit-3 = address bit-8 */ +#define EEPROM_WREN_OPCODE_SPI 0x06 /* EEPROM set Write Enable latch */ +#define EEPROM_WRDI_OPCODE_SPI 0x04 /* EEPROM reset Write Enable latch */ +#define EEPROM_RDSR_OPCODE_SPI 0x05 /* EEPROM read Status register */ +#define EEPROM_WRSR_OPCODE_SPI 0x01 /* EEPROM write Status register */ +#define EEPROM_ERASE4K_OPCODE_SPI 0x20 /* EEPROM ERASE 4KB */ +#define EEPROM_ERASE64K_OPCODE_SPI 0xD8 /* EEPROM ERASE 64KB */ +#define EEPROM_ERASE256_OPCODE_SPI 0xDB /* EEPROM ERASE 256B */ + +/* EEPROM Size definitions */ +#define EEPROM_WORD_SIZE_SHIFT 6 +#define EEPROM_SIZE_SHIFT 10 +#define EEPROM_SIZE_MASK 0x1C00 + +/* EEPROM Word Offsets */ +#define EEPROM_COMPAT 0x0003 +#define EEPROM_ID_LED_SETTINGS 0x0004 +#define EEPROM_VERSION 0x0005 +#define EEPROM_SERDES_AMPLITUDE 0x0006 /* For SERDES output amplitude + adjustment. */ +#define EEPROM_PHY_CLASS_WORD 0x0007 +#define EEPROM_INIT_CONTROL1_REG 0x000A +#define EEPROM_INIT_CONTROL2_REG 0x000F +#define EEPROM_SWDEF_PINS_CTRL_PORT_1 0x0010 +#define EEPROM_INIT_CONTROL3_PORT_B 0x0014 +#define EEPROM_INIT_3GIO_3 0x001A +#define EEPROM_SWDEF_PINS_CTRL_PORT_0 0x0020 +#define EEPROM_INIT_CONTROL3_PORT_A 0x0024 +#define EEPROM_CFG 0x0012 +#define EEPROM_FLASH_VERSION 0x0032 +#define EEPROM_CHECKSUM_REG 0x003F + +#define E1000_EEPROM_CFG_DONE 0x00040000 /* MNG config cycle done */ +#define E1000_EEPROM_CFG_DONE_PORT_1 0x00080000 /* ...for second port */ + /* Extended Device Control */ #define E1000_CTRL_EXT_GPI0_EN 0x00000001 /* Maps SDP4 to GPI0 */ #define E1000_CTRL_EXT_GPI1_EN 0x00000002 /* Maps SDP5 to GPI1 */ #define E1000_CTRL_EXT_PHYINT_EN E1000_CTRL_EXT_GPI1_EN #define E1000_CTRL_EXT_GPI2_EN 0x00000004 /* Maps SDP6 to GPI2 */ #define E1000_CTRL_EXT_GPI3_EN 0x00000008 /* Maps SDP7 to GPI3 */ -#define E1000_CTRL_EXT_SDP4_DATA 0x00000010 /* Value of SW Defineable Pin 4 */ -#define E1000_CTRL_EXT_SDP5_DATA 0x00000020 /* Value of SW Defineable Pin 5 */ +#define E1000_CTRL_EXT_SDP4_DATA 0x00000010 /* Value of SW Defineable + Pin 4 */ +#define E1000_CTRL_EXT_SDP5_DATA 0x00000020 /* Value of SW Defineable + Pin 5 */ #define E1000_CTRL_EXT_PHY_INT E1000_CTRL_EXT_SDP5_DATA #define E1000_CTRL_EXT_SDP6_DATA 0x00000040 /* Value of SW Defineable Pin 6 */ #define E1000_CTRL_EXT_SWDPIN6 0x00000040 /* SWDPIN 6 value */ @@ -989,6 +1320,7 @@ struct e1000_hw { #define E1000_CTRL_EXT_EE_RST 0x00002000 /* Reinitialize from EEPROM */ #define E1000_CTRL_EXT_IPS 0x00004000 /* Invert Power State */ #define E1000_CTRL_EXT_SPD_BYPS 0x00008000 /* Speed Select Bypass */ +#define E1000_CTRL_EXT_RO_DIS 0x00020000 /* Relaxed Ordering disable */ #define E1000_CTRL_EXT_LINK_MODE_MASK 0x00C00000 #define E1000_CTRL_EXT_LINK_MODE_GMII 0x00000000 #define E1000_CTRL_EXT_LINK_MODE_TBI 0x00C00000 @@ -1010,6 +1342,12 @@ struct e1000_hw { #define E1000_MDIC_INT_EN 0x20000000 #define E1000_MDIC_ERROR 0x40000000
+#define E1000_PHY_CTRL_SPD_EN 0x00000001 +#define E1000_PHY_CTRL_D0A_LPLU 0x00000002 +#define E1000_PHY_CTRL_NOND0A_LPLU 0x00000004 +#define E1000_PHY_CTRL_NOND0A_GBE_DISABLE 0x00000008 +#define E1000_PHY_CTRL_GBE_DISABLE 0x00000040 +#define E1000_PHY_CTRL_B2B_EN 0x00000080 /* LED Control */ #define E1000_LEDCTL_LED0_MODE_MASK 0x0000000F #define E1000_LEDCTL_LED0_MODE_SHIFT 0 @@ -1153,6 +1491,12 @@ struct e1000_hw { #define E1000_RCTL_PMCF 0x00800000 /* pass MAC control frames */ #define E1000_RCTL_BSEX 0x02000000 /* Buffer size extension */
+/* SW_W_SYNC definitions */ +#define E1000_SWFW_EEP_SM 0x0001 +#define E1000_SWFW_PHY0_SM 0x0002 +#define E1000_SWFW_PHY1_SM 0x0004 +#define E1000_SWFW_MAC_CSR_SM 0x0008 + /* Receive Descriptor */ #define E1000_RDT_DELAY 0x0000ffff /* Delay timer (1=1024us) */ #define E1000_RDT_FPDB 0x80000000 /* Flush descriptor block */ @@ -1173,12 +1517,14 @@ struct e1000_hw { #define E1000_RXDCTL_GRAN 0x01000000 /* RXDCTL Granularity */
/* Transmit Descriptor Control */ -#define E1000_TXDCTL_PTHRESH 0x000000FF /* TXDCTL Prefetch Threshold */ -#define E1000_TXDCTL_HTHRESH 0x0000FF00 /* TXDCTL Host Threshold */ -#define E1000_TXDCTL_WTHRESH 0x00FF0000 /* TXDCTL Writeback Threshold */ +#define E1000_TXDCTL_PTHRESH 0x0000003F /* TXDCTL Prefetch Threshold */ +#define E1000_TXDCTL_HTHRESH 0x00003F00 /* TXDCTL Host Threshold */ +#define E1000_TXDCTL_WTHRESH 0x003F0000 /* TXDCTL Writeback Threshold */ #define E1000_TXDCTL_GRAN 0x01000000 /* TXDCTL Granularity */ #define E1000_TXDCTL_LWTHRESH 0xFE000000 /* TXDCTL Low Threshold */ #define E1000_TXDCTL_FULL_TX_DESC_WB 0x01010000 /* GRAN=1, WTHRESH=1 */ +#define E1000_TXDCTL_COUNT_DESC 0x00400000 /* Enable the counting of desc. + still to be processed. */
/* Transmit Configuration Word */ #define E1000_TXCW_FD 0x00000020 /* TXCW full duplex */ @@ -1212,6 +1558,7 @@ struct e1000_hw { #define E1000_TCTL_PBE 0x00800000 /* Packet Burst Enable */ #define E1000_TCTL_RTLC 0x01000000 /* Re-transmit on late collision */ #define E1000_TCTL_NRTU 0x02000000 /* No Re-transmit on underrun */ +#define E1000_TCTL_MULR 0x10000000 /* Multiple request support */
/* Receive Checksum Control */ #define E1000_RXCSUM_PCSS_MASK 0x000000FF /* Packet Checksum Start */ @@ -1349,9 +1696,10 @@ struct e1000_hw { #define PBA_SIZE 4
/* Collision related configuration parameters */ -#define E1000_COLLISION_THRESHOLD 16 +#define E1000_COLLISION_THRESHOLD 0xF #define E1000_CT_SHIFT 4 -#define E1000_COLLISION_DISTANCE 64 +#define E1000_COLLISION_DISTANCE 63 +#define E1000_COLLISION_DISTANCE_82542 64 #define E1000_FDX_COLLISION_DISTANCE E1000_COLLISION_DISTANCE #define E1000_HDX_COLLISION_DISTANCE E1000_COLLISION_DISTANCE #define E1000_GB_HDX_COLLISION_DISTANCE 512 @@ -1376,6 +1724,7 @@ struct e1000_hw {
#define DEFAULT_82542_TIPG_IPGR2 10 #define DEFAULT_82543_TIPG_IPGR2 6 +#define DEFAULT_80003ES2LAN_TIPG_IPGR2 7 #define E1000_TIPG_IPGR2_SHIFT 20
#define E1000_TXDMAC_DPP 0x00000001 @@ -1396,6 +1745,7 @@ struct e1000_hw { /* PBA constants */ #define E1000_PBA_16K 0x0010 /* 16KB, default TX allocation */ #define E1000_PBA_24K 0x0018 +#define E1000_PBA_38K 0x0026 #define E1000_PBA_40K 0x0028 #define E1000_PBA_48K 0x0030 /* 48KB, default RX allocation */
@@ -1537,8 +1887,22 @@ struct e1000_hw { #define M88E1000_EXT_PHY_SPEC_CTRL 0x14 /* Extended PHY Specific Control */ #define M88E1000_RX_ERR_CNTR 0x15 /* Receive Error Counter */
+#define M88E1000_PHY_PAGE_SELECT 0x1D /* Reg 29 for page number setting */ +#define M88E1000_PHY_GEN_CONTROL 0x1E /* Its meaning depends on reg 29 */ + #define MAX_PHY_REG_ADDRESS 0x1F /* 5 bit address bus (0-0x1F) */
+/* M88EC018 Rev 2 specific DownShift settings */ +#define M88EC018_EPSCR_DOWNSHIFT_COUNTER_MASK 0x0E00 +#define M88EC018_EPSCR_DOWNSHIFT_COUNTER_1X 0x0000 +#define M88EC018_EPSCR_DOWNSHIFT_COUNTER_2X 0x0200 +#define M88EC018_EPSCR_DOWNSHIFT_COUNTER_3X 0x0400 +#define M88EC018_EPSCR_DOWNSHIFT_COUNTER_4X 0x0600 +#define M88EC018_EPSCR_DOWNSHIFT_COUNTER_5X 0x0800 +#define M88EC018_EPSCR_DOWNSHIFT_COUNTER_6X 0x0A00 +#define M88EC018_EPSCR_DOWNSHIFT_COUNTER_7X 0x0C00 +#define M88EC018_EPSCR_DOWNSHIFT_COUNTER_8X 0x0E00 + /* IGP01E1000 specifics */ #define IGP01E1000_IEEE_REGS_PAGE 0x0000 #define IGP01E1000_IEEE_RESTART_AUTONEG 0x3300 @@ -1554,6 +1918,290 @@ struct e1000_hw { #define IGP02E1000_PHY_POWER_MGMT 0x19 #define IGP01E1000_PHY_PAGE_SELECT 0x1F /* PHY Page Select Core Register */
+/* IGP01E1000 AGC Registers - stores the cable length values*/ +#define IGP01E1000_PHY_AGC_A 0x1172 +#define IGP01E1000_PHY_AGC_B 0x1272 +#define IGP01E1000_PHY_AGC_C 0x1472 +#define IGP01E1000_PHY_AGC_D 0x1872 + +/* IGP01E1000 Specific Port Config Register - R/W */ +#define IGP01E1000_PSCFR_AUTO_MDIX_PAR_DETECT 0x0010 +#define IGP01E1000_PSCFR_PRE_EN 0x0020 +#define IGP01E1000_PSCFR_SMART_SPEED 0x0080 +#define IGP01E1000_PSCFR_DISABLE_TPLOOPBACK 0x0100 +#define IGP01E1000_PSCFR_DISABLE_JABBER 0x0400 +#define IGP01E1000_PSCFR_DISABLE_TRANSMIT 0x2000 +/* IGP02E1000 AGC Registers for cable length values */ +#define IGP02E1000_PHY_AGC_A 0x11B1 +#define IGP02E1000_PHY_AGC_B 0x12B1 +#define IGP02E1000_PHY_AGC_C 0x14B1 +#define IGP02E1000_PHY_AGC_D 0x18B1 + +#define IGP02E1000_PM_SPD 0x0001 /* Smart Power Down */ +#define IGP02E1000_PM_D3_LPLU 0x0004 /* Enable LPLU in + non-D0a modes */ +#define IGP02E1000_PM_D0_LPLU 0x0002 /* Enable LPLU in + D0a mode */ + +/* IGP01E1000 DSP Reset Register */ +#define IGP01E1000_PHY_DSP_RESET 0x1F33 +#define IGP01E1000_PHY_DSP_SET 0x1F71 +#define IGP01E1000_PHY_DSP_FFE 0x1F35 + +#define IGP01E1000_PHY_CHANNEL_NUM 4 +#define IGP02E1000_PHY_CHANNEL_NUM 4 + +#define IGP01E1000_PHY_AGC_PARAM_A 0x1171 +#define IGP01E1000_PHY_AGC_PARAM_B 0x1271 +#define IGP01E1000_PHY_AGC_PARAM_C 0x1471 +#define IGP01E1000_PHY_AGC_PARAM_D 0x1871 + +#define IGP01E1000_PHY_EDAC_MU_INDEX 0xC000 +#define IGP01E1000_PHY_EDAC_SIGN_EXT_9_BITS 0x8000 + +#define IGP01E1000_PHY_ANALOG_TX_STATE 0x2890 +#define IGP01E1000_PHY_ANALOG_CLASS_A 0x2000 +#define IGP01E1000_PHY_FORCE_ANALOG_ENABLE 0x0004 +#define IGP01E1000_PHY_DSP_FFE_CM_CP 0x0069 + +#define IGP01E1000_PHY_DSP_FFE_DEFAULT 0x002A +/* IGP01E1000 PCS Initialization register - stores the polarity status when + * speed = 1000 Mbps. */ +#define IGP01E1000_PHY_PCS_INIT_REG 0x00B4 +#define IGP01E1000_PHY_PCS_CTRL_REG 0x00B5 + +#define IGP01E1000_ANALOG_REGS_PAGE 0x20C0 + +/* IGP01E1000 GMII FIFO Register */ +#define IGP01E1000_GMII_FLEX_SPD 0x10 /* Enable flexible speed + * on Link-Up */ +#define IGP01E1000_GMII_SPD 0x20 /* Enable SPD */ + +/* IGP01E1000 Analog Register */ +#define IGP01E1000_ANALOG_SPARE_FUSE_STATUS 0x20D1 +#define IGP01E1000_ANALOG_FUSE_STATUS 0x20D0 +#define IGP01E1000_ANALOG_FUSE_CONTROL 0x20DC +#define IGP01E1000_ANALOG_FUSE_BYPASS 0x20DE + +#define IGP01E1000_ANALOG_FUSE_POLY_MASK 0xF000 +#define IGP01E1000_ANALOG_FUSE_FINE_MASK 0x0F80 +#define IGP01E1000_ANALOG_FUSE_COARSE_MASK 0x0070 +#define IGP01E1000_ANALOG_SPARE_FUSE_ENABLED 0x0100 +#define IGP01E1000_ANALOG_FUSE_ENABLE_SW_CONTROL 0x0002 + +#define IGP01E1000_ANALOG_FUSE_COARSE_THRESH 0x0040 +#define IGP01E1000_ANALOG_FUSE_COARSE_10 0x0010 +#define IGP01E1000_ANALOG_FUSE_FINE_1 0x0080 +#define IGP01E1000_ANALOG_FUSE_FINE_10 0x0500 + +/* IGP01E1000 Specific Port Control Register - R/W */ +#define IGP01E1000_PSCR_TP_LOOPBACK 0x0010 +#define IGP01E1000_PSCR_CORRECT_NC_SCMBLR 0x0200 +#define IGP01E1000_PSCR_TEN_CRS_SELECT 0x0400 +#define IGP01E1000_PSCR_FLIP_CHIP 0x0800 +#define IGP01E1000_PSCR_AUTO_MDIX 0x1000 +#define IGP01E1000_PSCR_FORCE_MDI_MDIX 0x2000 /* 0-MDI, 1-MDIX */ +/* GG82563 PHY Specific Status Register (Page 0, Register 16 */ +#define GG82563_PSCR_DISABLE_JABBER 0x0001 /* 1=Disable Jabber */ +#define GG82563_PSCR_POLARITY_REVERSAL_DISABLE 0x0002 /* 1=Polarity Reversal + Disabled */ +#define GG82563_PSCR_POWER_DOWN 0x0004 /* 1=Power Down */ +#define GG82563_PSCR_COPPER_TRANSMITER_DISABLE 0x0008 /* 1=Transmitter + Disabled */ +#define GG82563_PSCR_CROSSOVER_MODE_MASK 0x0060 +#define GG82563_PSCR_CROSSOVER_MODE_MDI 0x0000 /* 00=Manual MDI + configuration */ +#define GG82563_PSCR_CROSSOVER_MODE_MDIX 0x0020 /* 01=Manual MDIX + configuration */ +#define GG82563_PSCR_CROSSOVER_MODE_AUTO 0x0060 /* 11=Automatic + crossover */ +#define GG82563_PSCR_ENALBE_EXTENDED_DISTANCE 0x0080 /* 1=Enable Extended + Distance */ +#define GG82563_PSCR_ENERGY_DETECT_MASK 0x0300 +#define GG82563_PSCR_ENERGY_DETECT_OFF 0x0000 /* 00,01=Off */ +#define GG82563_PSCR_ENERGY_DETECT_RX 0x0200 /* 10=Sense on Rx only + (Energy Detect) */ +#define GG82563_PSCR_ENERGY_DETECT_RX_TM 0x0300 /* 11=Sense and Tx NLP */ +#define GG82563_PSCR_FORCE_LINK_GOOD 0x0400 /* 1=Force Link Good */ +#define GG82563_PSCR_DOWNSHIFT_ENABLE 0x0800 /* 1=Enable Downshift */ +#define GG82563_PSCR_DOWNSHIFT_COUNTER_MASK 0x7000 +#define GG82563_PSCR_DOWNSHIFT_COUNTER_SHIFT 12 + +/* PHY Specific Status Register (Page 0, Register 17) */ +#define GG82563_PSSR_JABBER 0x0001 /* 1=Jabber */ +#define GG82563_PSSR_POLARITY 0x0002 /* 1=Polarity Reversed */ +#define GG82563_PSSR_LINK 0x0008 /* 1=Link is Up */ +#define GG82563_PSSR_ENERGY_DETECT 0x0010 /* 1=Sleep, 0=Active */ +#define GG82563_PSSR_DOWNSHIFT 0x0020 /* 1=Downshift */ +#define GG82563_PSSR_CROSSOVER_STATUS 0x0040 /* 1=MDIX, 0=MDI */ +#define GG82563_PSSR_RX_PAUSE_ENABLED 0x0100 /* 1=Receive Pause Enabled */ +#define GG82563_PSSR_TX_PAUSE_ENABLED 0x0200 /* 1=Transmit Pause Enabled */ +#define GG82563_PSSR_LINK_UP 0x0400 /* 1=Link Up */ +#define GG82563_PSSR_SPEED_DUPLEX_RESOLVED 0x0800 /* 1=Resolved */ +#define GG82563_PSSR_PAGE_RECEIVED 0x1000 /* 1=Page Received */ +#define GG82563_PSSR_DUPLEX 0x2000 /* 1-Full-Duplex */ +#define GG82563_PSSR_SPEED_MASK 0xC000 +#define GG82563_PSSR_SPEED_10MBPS 0x0000 /* 00=10Mbps */ +#define GG82563_PSSR_SPEED_100MBPS 0x4000 /* 01=100Mbps */ +#define GG82563_PSSR_SPEED_1000MBPS 0x8000 /* 10=1000Mbps */ + +/* PHY Specific Status Register 2 (Page 0, Register 19) */ +#define GG82563_PSSR2_JABBER 0x0001 /* 1=Jabber */ +#define GG82563_PSSR2_POLARITY_CHANGED 0x0002 /* 1=Polarity Changed */ +#define GG82563_PSSR2_ENERGY_DETECT_CHANGED 0x0010 /* 1=Energy Detect Changed */ +#define GG82563_PSSR2_DOWNSHIFT_INTERRUPT 0x0020 /* 1=Downshift Detected */ +#define GG82563_PSSR2_MDI_CROSSOVER_CHANGE 0x0040 /* 1=Crossover Changed */ +#define GG82563_PSSR2_FALSE_CARRIER 0x0100 /* 1=False Carrier */ +#define GG82563_PSSR2_SYMBOL_ERROR 0x0200 /* 1=Symbol Error */ +#define GG82563_PSSR2_LINK_STATUS_CHANGED 0x0400 /* 1=Link Status Changed */ +#define GG82563_PSSR2_AUTO_NEG_COMPLETED 0x0800 /* 1=Auto-Neg Completed */ +#define GG82563_PSSR2_PAGE_RECEIVED 0x1000 /* 1=Page Received */ +#define GG82563_PSSR2_DUPLEX_CHANGED 0x2000 /* 1=Duplex Changed */ +#define GG82563_PSSR2_SPEED_CHANGED 0x4000 /* 1=Speed Changed */ +#define GG82563_PSSR2_AUTO_NEG_ERROR 0x8000 /* 1=Auto-Neg Error */ + +/* PHY Specific Control Register 2 (Page 0, Register 26) */ +#define GG82563_PSCR2_10BT_POLARITY_FORCE 0x0002 /* 1=Force Negative + Polarity */ +#define GG82563_PSCR2_1000MB_TEST_SELECT_MASK 0x000C +#define GG82563_PSCR2_1000MB_TEST_SELECT_NORMAL 0x0000 /* 00,01=Normal + Operation */ +#define GG82563_PSCR2_1000MB_TEST_SELECT_112NS 0x0008 /* 10=Select 112ns + Sequence */ +#define GG82563_PSCR2_1000MB_TEST_SELECT_16NS 0x000C /* 11=Select 16ns + Sequence */ +#define GG82563_PSCR2_REVERSE_AUTO_NEG 0x2000 /* 1=Reverse + Auto-Negotiation */ +#define GG82563_PSCR2_1000BT_DISABLE 0x4000 /* 1=Disable + 1000BASE-T */ +#define GG82563_PSCR2_TRANSMITER_TYPE_MASK 0x8000 +#define GG82563_PSCR2_TRANSMITTER_TYPE_CLASS_B 0x0000 /* 0=Class B */ +#define GG82563_PSCR2_TRANSMITTER_TYPE_CLASS_A 0x8000 /* 1=Class A */ + +/* MAC Specific Control Register (Page 2, Register 21) */ +/* Tx clock speed for Link Down and 1000BASE-T for the following speeds */ +#define GG82563_MSCR_TX_CLK_MASK 0x0007 +#define GG82563_MSCR_TX_CLK_10MBPS_2_5MHZ 0x0004 +#define GG82563_MSCR_TX_CLK_100MBPS_25MHZ 0x0005 +#define GG82563_MSCR_TX_CLK_1000MBPS_2_5MHZ 0x0006 +#define GG82563_MSCR_TX_CLK_1000MBPS_25MHZ 0x0007 + +#define GG82563_MSCR_ASSERT_CRS_ON_TX 0x0010 /* 1=Assert */ + +/* DSP Distance Register (Page 5, Register 26) */ +#define GG82563_DSPD_CABLE_LENGTH 0x0007 /* 0 = <50M; + 1 = 50-80M; + 2 = 80-110M; + 3 = 110-140M; + 4 = >140M */ + +/* Kumeran Mode Control Register (Page 193, Register 16) */ +#define GG82563_KMCR_PHY_LEDS_EN 0x0020 /* 1=PHY LEDs, + 0=Kumeran Inband LEDs */ +#define GG82563_KMCR_FORCE_LINK_UP 0x0040 /* 1=Force Link Up */ +#define GG82563_KMCR_SUPPRESS_SGMII_EPD_EXT 0x0080 +#define GG82563_KMCR_MDIO_BUS_SPEED_SELECT_MASK 0x0400 +#define GG82563_KMCR_MDIO_BUS_SPEED_SELECT 0x0400 /* 1=6.25MHz, + 0=0.8MHz */ +#define GG82563_KMCR_PASS_FALSE_CARRIER 0x0800 + +/* Power Management Control Register (Page 193, Register 20) */ +#define GG82563_PMCR_ENABLE_ELECTRICAL_IDLE 0x0001 /* 1=Enalbe SERDES + Electrical Idle */ +#define GG82563_PMCR_DISABLE_PORT 0x0002 /* 1=Disable Port */ +#define GG82563_PMCR_DISABLE_SERDES 0x0004 /* 1=Disable SERDES */ +#define GG82563_PMCR_REVERSE_AUTO_NEG 0x0008 /* 1=Enable Reverse + Auto-Negotiation */ +#define GG82563_PMCR_DISABLE_1000_NON_D0 0x0010 /* 1=Disable 1000Mbps + Auto-Neg in non D0 */ +#define GG82563_PMCR_DISABLE_1000 0x0020 /* 1=Disable 1000Mbps + Auto-Neg Always */ +#define GG82563_PMCR_REVERSE_AUTO_NEG_D0A 0x0040 /* 1=Enable D0a + Reverse Auto-Negotiation */ +#define GG82563_PMCR_FORCE_POWER_STATE 0x0080 /* 1=Force Power State */ +#define GG82563_PMCR_PROGRAMMED_POWER_STATE_MASK 0x0300 +#define GG82563_PMCR_PROGRAMMED_POWER_STATE_DR 0x0000 /* 00=Dr */ +#define GG82563_PMCR_PROGRAMMED_POWER_STATE_D0U 0x0100 /* 01=D0u */ +#define GG82563_PMCR_PROGRAMMED_POWER_STATE_D0A 0x0200 /* 10=D0a */ +#define GG82563_PMCR_PROGRAMMED_POWER_STATE_D3 0x0300 /* 11=D3 */ + +/* In-Band Control Register (Page 194, Register 18) */ +#define GG82563_ICR_DIS_PADDING 0x0010 /* Disable Padding Use */ + + +/* Bits... + * 15-5: page + * 4-0: register offset + */ +#define GG82563_PAGE_SHIFT 5 +#define GG82563_REG(page, reg) \ + (((page) << GG82563_PAGE_SHIFT) | ((reg) & MAX_PHY_REG_ADDRESS)) +#define GG82563_MIN_ALT_REG 30 + +/* GG82563 Specific Registers */ +#define GG82563_PHY_SPEC_CTRL \ + GG82563_REG(0, 16) /* PHY Specific Control */ +#define GG82563_PHY_SPEC_STATUS \ + GG82563_REG(0, 17) /* PHY Specific Status */ +#define GG82563_PHY_INT_ENABLE \ + GG82563_REG(0, 18) /* Interrupt Enable */ +#define GG82563_PHY_SPEC_STATUS_2 \ + GG82563_REG(0, 19) /* PHY Specific Status 2 */ +#define GG82563_PHY_RX_ERR_CNTR \ + GG82563_REG(0, 21) /* Receive Error Counter */ +#define GG82563_PHY_PAGE_SELECT \ + GG82563_REG(0, 22) /* Page Select */ +#define GG82563_PHY_SPEC_CTRL_2 \ + GG82563_REG(0, 26) /* PHY Specific Control 2 */ +#define GG82563_PHY_PAGE_SELECT_ALT \ + GG82563_REG(0, 29) /* Alternate Page Select */ +#define GG82563_PHY_TEST_CLK_CTRL \ + GG82563_REG(0, 30) /* Test Clock Control (use reg. 29 to select) */ + +#define GG82563_PHY_MAC_SPEC_CTRL \ + GG82563_REG(2, 21) /* MAC Specific Control Register */ +#define GG82563_PHY_MAC_SPEC_CTRL_2 \ + GG82563_REG(2, 26) /* MAC Specific Control 2 */ + +#define GG82563_PHY_DSP_DISTANCE \ + GG82563_REG(5, 26) /* DSP Distance */ + +/* Page 193 - Port Control Registers */ +#define GG82563_PHY_KMRN_MODE_CTRL \ + GG82563_REG(193, 16) /* Kumeran Mode Control */ +#define GG82563_PHY_PORT_RESET \ + GG82563_REG(193, 17) /* Port Reset */ +#define GG82563_PHY_REVISION_ID \ + GG82563_REG(193, 18) /* Revision ID */ +#define GG82563_PHY_DEVICE_ID \ + GG82563_REG(193, 19) /* Device ID */ +#define GG82563_PHY_PWR_MGMT_CTRL \ + GG82563_REG(193, 20) /* Power Management Control */ +#define GG82563_PHY_RATE_ADAPT_CTRL \ + GG82563_REG(193, 25) /* Rate Adaptation Control */ + +/* Page 194 - KMRN Registers */ +#define GG82563_PHY_KMRN_FIFO_CTRL_STAT \ + GG82563_REG(194, 16) /* FIFO's Control/Status */ +#define GG82563_PHY_KMRN_CTRL \ + GG82563_REG(194, 17) /* Control */ +#define GG82563_PHY_INBAND_CTRL \ + GG82563_REG(194, 18) /* Inband Control */ +#define GG82563_PHY_KMRN_DIAGNOSTIC \ + GG82563_REG(194, 19) /* Diagnostic */ +#define GG82563_PHY_ACK_TIMEOUTS \ + GG82563_REG(194, 20) /* Acknowledge Timeouts */ +#define GG82563_PHY_ADV_ABILITY \ + GG82563_REG(194, 21) /* Advertised Ability */ +#define GG82563_PHY_LINK_PARTNER_ADV_ABILITY \ + GG82563_REG(194, 23) /* Link Partner Advertised Ability */ +#define GG82563_PHY_ADV_NEXT_PAGE \ + GG82563_REG(194, 24) /* Advertised Next Page */ +#define GG82563_PHY_LINK_PARTNER_ADV_NEXT_PAGE \ + GG82563_REG(194, 25) /* Link Partner Advertised Next page */ +#define GG82563_PHY_KMRN_MISC \ + GG82563_REG(194, 26) /* Misc. */ + /* PHY Control Register */ #define MII_CR_SPEED_SELECT_MSB 0x0040 /* bits 6,13: 10=1000, 01=100, 00=10 */ #define MII_CR_COLL_TEST_ENABLE 0x0080 /* Collision test enable */ @@ -1765,6 +2413,10 @@ struct e1000_hw { #define M88E1000_12_PHY_ID M88E1000_E_PHY_ID #define M88E1000_14_PHY_ID M88E1000_E_PHY_ID #define IGP01E1000_I_PHY_ID 0x02A80380 +#define M88E1011_I_REV_4 0x04 +#define M88E1111_I_PHY_ID 0x01410CC0 +#define L1LXT971A_PHY_ID 0x001378E0 +#define GG82563_E_PHY_ID 0x01410CA0
/* Miscellaneous PHY bit definitions. */ #define PHY_PREAMBLE 0xFFFFFFFF @@ -1791,4 +2443,142 @@ struct e1000_hw { #define ADVERTISE_1000_FULL 0x0020 #define AUTONEG_ADVERTISE_SPEED_DEFAULT 0x002F /* Everything but 1000-Half */
+#define ICH_FLASH_GFPREG 0x0000 +#define ICH_FLASH_HSFSTS 0x0004 +#define ICH_FLASH_HSFCTL 0x0006 +#define ICH_FLASH_FADDR 0x0008 +#define ICH_FLASH_FDATA0 0x0010 +#define ICH_FLASH_FRACC 0x0050 +#define ICH_FLASH_FREG0 0x0054 +#define ICH_FLASH_FREG1 0x0058 +#define ICH_FLASH_FREG2 0x005C +#define ICH_FLASH_FREG3 0x0060 +#define ICH_FLASH_FPR0 0x0074 +#define ICH_FLASH_FPR1 0x0078 +#define ICH_FLASH_SSFSTS 0x0090 +#define ICH_FLASH_SSFCTL 0x0092 +#define ICH_FLASH_PREOP 0x0094 +#define ICH_FLASH_OPTYPE 0x0096 +#define ICH_FLASH_OPMENU 0x0098 + +#define ICH_FLASH_REG_MAPSIZE 0x00A0 +#define ICH_FLASH_SECTOR_SIZE 4096 +#define ICH_GFPREG_BASE_MASK 0x1FFF +#define ICH_FLASH_LINEAR_ADDR_MASK 0x00FFFFFF + +#define E1000_EEWR 0x0102C /* EEPROM Write Register - RW */ +#define E1000_SW_FW_SYNC 0x05B5C /* Software-Firmware Synchronization - RW */ + +/* SPI EEPROM Status Register */ +#define EEPROM_STATUS_RDY_SPI 0x01 +#define EEPROM_STATUS_WEN_SPI 0x02 +#define EEPROM_STATUS_BP0_SPI 0x04 +#define EEPROM_STATUS_BP1_SPI 0x08 +#define EEPROM_STATUS_WPEN_SPI 0x80 + +/* SW Semaphore Register */ +#define E1000_SWSM_SMBI 0x00000001 /* Driver Semaphore bit */ +#define E1000_SWSM_SWESMBI 0x00000002 /* FW Semaphore bit */ +#define E1000_SWSM_WMNG 0x00000004 /* Wake MNG Clock */ +#define E1000_SWSM_DRV_LOAD 0x00000008 /* Driver Loaded Bit */ + +/* FW Semaphore Register */ +#define E1000_FWSM_MODE_MASK 0x0000000E /* FW mode */ +#define E1000_FWSM_MODE_SHIFT 1 +#define E1000_FWSM_FW_VALID 0x00008000 /* FW established a valid mode */ + +#define E1000_FWSM_RSPCIPHY 0x00000040 /* Reset PHY on PCI reset */ +#define E1000_FWSM_DISSW 0x10000000 /* FW disable SW Write Access */ +#define E1000_FWSM_SKUSEL_MASK 0x60000000 /* LAN SKU select */ +#define E1000_FWSM_SKUEL_SHIFT 29 +#define E1000_FWSM_SKUSEL_EMB 0x0 /* Embedded SKU */ +#define E1000_FWSM_SKUSEL_CONS 0x1 /* Consumer SKU */ +#define E1000_FWSM_SKUSEL_PERF_100 0x2 /* Perf & Corp 10/100 SKU */ +#define E1000_FWSM_SKUSEL_PERF_GBE 0x3 /* Perf & Copr GbE SKU */ + +#define E1000_GCR 0x05B00 /* PCI-Ex Control */ +#define E1000_GSCL_1 0x05B10 /* PCI-Ex Statistic Control #1 */ +#define E1000_GSCL_2 0x05B14 /* PCI-Ex Statistic Control #2 */ +#define E1000_GSCL_3 0x05B18 /* PCI-Ex Statistic Control #3 */ +#define E1000_GSCL_4 0x05B1C /* PCI-Ex Statistic Control #4 */ +#define E1000_FACTPS 0x05B30 /* Function Active and Power State to MNG */ +#define E1000_SWSM 0x05B50 /* SW Semaphore */ +#define E1000_FWSM 0x05B54 /* FW Semaphore */ +#define E1000_FFLT_DBG 0x05F04 /* Debug Register */ +#define E1000_HICR 0x08F00 /* Host Inteface Control */ + +#define IGP_ACTIVITY_LED_MASK 0xFFFFF0FF +#define IGP_ACTIVITY_LED_ENABLE 0x0300 +#define IGP_LED3_MODE 0x07000000 + +/* Mask bit for PHY class in Word 7 of the EEPROM */ +#define EEPROM_PHY_CLASS_A 0x8000 +#define AUTONEG_ADVERTISE_SPEED_DEFAULT 0x002F /* Everything but 1000-Half */ +#define AUTONEG_ADVERTISE_10_100_ALL 0x000F /* All 10/100 speeds*/ +#define AUTONEG_ADVERTISE_10_ALL 0x0003 /* 10Mbps Full & Half speeds*/ + +#define E1000_KUMCTRLSTA_MASK 0x0000FFFF +#define E1000_KUMCTRLSTA_OFFSET 0x001F0000 +#define E1000_KUMCTRLSTA_OFFSET_SHIFT 16 +#define E1000_KUMCTRLSTA_REN 0x00200000 + +#define E1000_KUMCTRLSTA_OFFSET_FIFO_CTRL 0x00000000 +#define E1000_KUMCTRLSTA_OFFSET_CTRL 0x00000001 +#define E1000_KUMCTRLSTA_OFFSET_INB_CTRL 0x00000002 +#define E1000_KUMCTRLSTA_OFFSET_DIAG 0x00000003 +#define E1000_KUMCTRLSTA_OFFSET_TIMEOUTS 0x00000004 +#define E1000_KUMCTRLSTA_OFFSET_INB_PARAM 0x00000009 +#define E1000_KUMCTRLSTA_OFFSET_HD_CTRL 0x00000010 +#define E1000_KUMCTRLSTA_OFFSET_M2P_SERDES 0x0000001E +#define E1000_KUMCTRLSTA_OFFSET_M2P_MODES 0x0000001F + +/* FIFO Control */ +#define E1000_KUMCTRLSTA_FIFO_CTRL_RX_BYPASS 0x00000008 +#define E1000_KUMCTRLSTA_FIFO_CTRL_TX_BYPASS 0x00000800 + +/* In-Band Control */ +#define E1000_KUMCTRLSTA_INB_CTRL_LINK_STATUS_TX_TIMEOUT_DEFAULT 0x00000500 +#define E1000_KUMCTRLSTA_INB_CTRL_DIS_PADDING 0x00000010 + +/* Half-Duplex Control */ +#define E1000_KUMCTRLSTA_HD_CTRL_10_100_DEFAULT 0x00000004 +#define E1000_KUMCTRLSTA_HD_CTRL_1000_DEFAULT 0x00000000 + +#define E1000_KUMCTRLSTA_OFFSET_K0S_CTRL 0x0000001E + +#define E1000_KUMCTRLSTA_DIAG_FELPBK 0x2000 +#define E1000_KUMCTRLSTA_DIAG_NELPBK 0x1000 + +#define E1000_KUMCTRLSTA_K0S_100_EN 0x2000 +#define E1000_KUMCTRLSTA_K0S_GBE_EN 0x1000 +#define E1000_KUMCTRLSTA_K0S_ENTRY_LATENCY_MASK 0x0003 + +#define E1000_MNG_ICH_IAMT_MODE 0x2 +#define E1000_MNG_IAMT_MODE 0x3 +#define E1000_MANC_BLK_PHY_RST_ON_IDE 0x00040000 /* Block phy resets */ +#define E1000_KUMCTRLSTA 0x00034 /* MAC-PHY interface - RW */ +/* Number of milliseconds we wait for PHY configuration done after MAC reset */ +#define PHY_CFG_TIMEOUT 100 +#define DEFAULT_80003ES2LAN_TIPG_IPGT_10_100 0x00000009 +#define DEFAULT_80003ES2LAN_TIPG_IPGT_1000 0x00000008 +#define E1000_TXDMAC_DPP 0x00000001 +#define AUTO_ALL_MODES 0 + +#ifndef E1000_MASTER_SLAVE +/* Switch to override PHY master/slave setting */ +#define E1000_MASTER_SLAVE e1000_ms_hw_default +#endif +/* Extended Transmit Control */ +#define E1000_TCTL_EXT_BST_MASK 0x000003FF /* Backoff Slot Time */ +#define E1000_TCTL_EXT_GCEX_MASK 0x000FFC00 /* Gigabit Carry Extend Padding */ + +#define DEFAULT_80003ES2LAN_TCTL_EXT_GCEX 0x00010000 + +#define PCI_EX_82566_SNOOP_ALL PCI_EX_NO_SNOOP_ALL + +#define E1000_GCR_L1_ACT_WITHOUT_L0S_RX 0x08000000 +#define E1000_MC_TBL_SIZE_ICH8LAN 32 + +#define E1000_CTRL_EXT_INT_TIMER_CLR 0x20000000 /* Clear Interrupt timers + after IMS clear */ #endif /* _E1000_HW_H_ */ diff --git a/include/pci_ids.h b/include/pci_ids.h index ae642b1..77f571b 100644 --- a/include/pci_ids.h +++ b/include/pci_ids.h @@ -1832,6 +1832,28 @@
#define PCI_DEVICE_ID_INTEL_82562ET 0x1031
+#define PCI_DEVICE_ID_INTEL_82571EB_COPPER 0x105E +#define PCI_DEVICE_ID_INTEL_82571EB_FIBER 0x105F +#define PCI_DEVICE_ID_INTEL_82571EB_SERDES 0x1060 +#define PCI_DEVICE_ID_INTEL_82571EB_QUAD_COPPER 0x10A4 +#define PCI_DEVICE_ID_INTEL_82571PT_QUAD_COPPER 0x10D5 +#define PCI_DEVICE_ID_INTEL_82571EB_QUAD_FIBER 0x10A5 +#define PCI_DEVICE_ID_INTEL_82571EB_QUAD_COPPER_LOWPROFILE 0x10BC +#define PCI_DEVICE_ID_INTEL_82571EB_SERDES_DUAL 0x10D9 +#define PCI_DEVICE_ID_INTEL_82571EB_SERDES_QUAD 0x10DA +#define PCI_DEVICE_ID_INTEL_82572EI_COPPER 0x107D +#define PCI_DEVICE_ID_INTEL_82572EI_FIBER 0x107E +#define PCI_DEVICE_ID_INTEL_82572EI_SERDES 0x107F +#define PCI_DEVICE_ID_INTEL_82572EI 0x10B9 +#define PCI_DEVICE_ID_INTEL_82573E 0x108B +#define PCI_DEVICE_ID_INTEL_82573E_IAMT 0x108C +#define PCI_DEVICE_ID_INTEL_82573L 0x109A +#define PCI_DEVICE_ID_INTEL_82546GB_QUAD_COPPER_KSP3 0x10B5 +#define PCI_DEVICE_ID_INTEL_80003ES2LAN_COPPER_DPT 0x1096 +#define PCI_DEVICE_ID_INTEL_80003ES2LAN_SERDES_DPT 0x1098 +#define PCI_DEVICE_ID_INTEL_80003ES2LAN_COPPER_SPT 0x10BA +#define PCI_DEVICE_ID_INTEL_80003ES2LAN_SERDES_SPT 0x10BB + #define PCI_DEVICE_ID_INTEL_82815_MC 0x1130
#define PCI_DEVICE_ID_INTEL_82559ER 0x1209
On Wed, Jul 8, 2009 at 3:18 AM, Roy Zangtie-fei.zang@freescale.com wrote:
From: Roy Zang Based on Intel PRO/1000 Network Driver 7.3.20-k2 Add Intel E1000 PCIE card support
Any comments from anyone on this patch? I'd like to add this functionality to an internal repository of mine, but only after it's been approved here.
It's a big patch and I have to do a lot of context switching. Will try to complete review tonight.
regards, Ben
Hi Roy, Roy Zang wrote:
Based on Intel PRO/1000 Network Driver 7.3.20-k2 Add Intel E1000 PCIE card support. The following cards are added: INTEL_82571EB_COPPER INTEL_82571EB_FIBER, INTEL_82571EB_SERDES INTEL_82571EB_QUAD_COPPER INTEL_82571PT_QUAD_COPPER INTEL_82571EB_QUAD_FIBER INTEL_82571EB_QUAD_COPPER_LOWPROFILE INTEL_82571EB_SERDES_DUAL INTEL_82571EB_SERDES_QUAD INTEL_82572EI_COPPER INTEL_82572EI_FIBER INTEL_82572EI_SERDES INTEL_82572EI INTEL_82573E INTEL_82573E_IAMT INTEL_82573L INTEL_82546GB_QUAD_COPPER_KSP3 INTEL_80003ES2LAN_COPPER_DPT INTEL_80003ES2LAN_SERDES_DPT INTEL_80003ES2LAN_COPPER_SPT INTEL_80003ES2LAN_SERDES_SPT
82571EB_COPPER dual ports, 82572EI single port, 82572EI_COPPER single port PCIE cards and 82545EM_COPPER, 82541GI_LF pci cards are tested on P2020 board, MPC8536DS and MPC8544DS boards.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com
I have no objections to any of the content. A few themes, though:
1. Please ensure that the multi-line comments are formatted correctly. Lines 2+ should have a space in the first character. 2. If you insist on including dead code (i.e. #if 0), please provide a comment on why it's there 3. I have a hard time believing that most of this is necessary. Sure it's a complicated chip and you're pulling it from Intel's driver, but 3000+ lines is too much. Please try to remove stuff that's not needed.
regards, Ben
-----Original Message----- From: Ben Warren [mailto:biggerbadderben@gmail.com] Sent: Tuesday, July 21, 2009 14:17 PM To: Zang Roy-R61911 Cc: Kumar Gala; U-Boot-Denx Subject: Re: [U-Boot] [PATCH 1/2] Add ntel PCIE PRO/1000 Network Driver support
- Please ensure that the multi-line comments are formatted
Do you find this issue in the patch?
- If you insist on including dead code (i.e. #if 0), please
Thanks for the understanding. The dead code in the previous file helped me track the code. That is why I left them. I will add the comment and remove the unnecessary one.
- I have a hard time believing that most of this is necessary. Sure
I will double check it. Do not believe Intel's code. It take me two days to clean the code style. I will resend it after the code is ready. Thanks. Roy
Ben Warren
Roy Zang
Timur Tabi
Zang Roy-R61911
