[PATCH 0/1] i.MX9 thermal trip fixups
With recent introduction of i.MX93 silicone revision A1, the thermal grade fuses are properly set for the different CPU temperature grades (e.g. Industrial or Automotive grade).
Thus read thermal trips from fuses and fixup Linux device-tree temp trips accordingly to the CPU temp grade.
BR, Primoz
Primoz Fiser (1): imx: imx9: fixup thermal trips from fuses
arch/arm/mach-imx/imx9/soc.c | 45 ++++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
Read i.MX9 CPU temp grade from fuses and fixup thermal trips in Linux device-tree accordingly.
Based on commit 0543a1ed2787 ("imx8m: fixup thermal trips")
Signed-off-by: Primoz Fiser primoz.fiser@norik.com --- arch/arm/mach-imx/imx9/soc.c | 45 ++++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
diff --git a/arch/arm/mach-imx/imx9/soc.c b/arch/arm/mach-imx/imx9/soc.c index 86b45be3d804..f06339f13880 100644 --- a/arch/arm/mach-imx/imx9/soc.c +++ b/arch/arm/mach-imx/imx9/soc.c @@ -507,8 +507,53 @@ int print_cpuinfo(void) return 0; }
+static int fixup_thermal_trips(void *blob, const char *name) +{ + int minc, maxc; + int node, trip; + + node = fdt_path_offset(blob, "/thermal-zones"); + if (node < 0) + return node; + + node = fdt_subnode_offset(blob, node, name); + if (node < 0) + return node; + + node = fdt_subnode_offset(blob, node, "trips"); + if (node < 0) + return node; + + get_cpu_temp_grade(&minc, &maxc); + + fdt_for_each_subnode(trip, blob, node) { + const char *type; + int temp, ret; + + type = fdt_getprop(blob, trip, "type", NULL); + if (!type) + continue; + + temp = 0; + if (!strcmp(type, "critical")) + temp = 1000 * (maxc - 5); + else if (!strcmp(type, "passive")) + temp = 1000 * (maxc - 10); + if (temp) { + ret = fdt_setprop_u32(blob, trip, "temperature", temp); + if (ret) + return ret; + } + } + + return 0; +} + int ft_system_setup(void *blob, struct bd_info *bd) { + if (fixup_thermal_trips(blob, "cpu-thermal")) + printf("Failed to update cpu-thermal trip(s)"); + return 0; }
Applied, thanks.
Fabio Estevam
Primoz Fiser
