Greetings,
Ive extended my bugsearching to find out why I cant get everything working on my hp jornada flashrom (sa1110 + sa1111).
Im testing exactly same kernel(2.6.34) for both bootloaders so I know the difference is in the bootloaders.
In short: Blob works perfectly fine with bootloader and booting the kernel
U-boot works perfect while booting kernel results in pcmcia not working at all, while the rest of the system works. If I instead drop the MCU (screen/keyboard/touchscreen) I get CF going.
Ive spent the weekend looking through datasheets and trying to merge blob memory setup into u-boot.
Pin settings are identical Memory registers are identical
So just looking for any quick info on where to look. Since I dont want to start rewriting everything to find the problem.
Best wishes Kristoffer Ericson
Kristoffer Ericson
