[U-Boot] Pull request for u-boot-marvell.git
Hi Albert Please pull The following changes since commit d0a755e860362ca35c6d6e4fa8a7a0d5fc7e3ea6: Michael Walle (1): kirkwood: define CONFIG_SYS_CACHELINE_SIZE
u-boot-marvell.git master branch.
Holger Brunck (4): arm/km: add boardid and hwkey to kernel command line arm/km: trigger reconfiguration for the Xilinx FPGA arm/km: enable jffs2 cmds arm/km: adapt bootcounter evaluation
Lei Wen (2): pantheon: define CONFIG_SYS_CACHELINE_SIZE armada100: define CONFIG_SYS_CACHELINE_SIZE
Simon Guinot (2): netspace_v2: fix SDRAM configuration netspace_v2: enable I2C EEPROM support
Thomas Herzmann (1): arm/km: portl2 environment address update to P1B
Valentin Longchamp (1): ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards
arch/arm/include/asm/arch-armada100/config.h | 2 + arch/arm/include/asm/arch-pantheon/config.h | 2 + board/LaCie/netspace_v2/kwbimage-is2.cfg | 162 ++++++++++++++++++++++++++ board/LaCie/netspace_v2/kwbimage.cfg | 4 +- board/keymile/km_arm/km_arm.c | 44 +++++-- boards.cfg | 2 +- include/configs/km/km_arm.h | 9 +- include/configs/km_kirkwood.h | 3 + include/configs/netspace_v2.h | 18 +++- include/configs/portl2.h | 6 +- 10 files changed, 234 insertions(+), 18 deletions(-) create mode 100644 board/LaCie/netspace_v2/kwbimage-is2.cfg
Regards.. Prafulla . . .
Hi Prafulla,
Applied to u-boot-arm/master, thanks.
Note that I get the following errors when fetching u-boot-marvell:
remote: error: refs/remotes/origin/mkimage does not point to a valid object! remote: error: refs/tags/2009.01-rc2 does not point to a valid object!
The second one means you have a bigus tag, which should disappear with a
git push ssh://gu-marvell@git.denx.de/u-boot-marvell.git :2009.01-rc2
The first one seems more complex, as it is a bogus branch name in a *remote* of u-boot-marvell -- I guess this can only be handled directly by Wolfgang.
Amicalement,
Dear Albert ARIBAUD,
I fixed both these.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Friday, November 04, 2011 12:33 AM To: Albert ARIBAUD Cc: Prafulla Wadaskar; u-boot@lists.denx.de; Ashish Karkare; Prabhanjan Sarnaik Subject: Re: Pull request for u-boot-marvell.git
marvell:
a valid object!
valid object!
disappear with a
:2009.01-rc2
name in a
handled directly
by Wolfgang.
I fixed both these.
Hi Wolfgang I hope I don't need to do anything specific now. I hope I can continue with my usual activities (git fetch, git rebase and git push).
Please ack.
Albert ARIBAUD
Prafulla Wadaskar
