[U-Boot] Please pull u-boot-marvell/master
Hi Tom,
please pull the following patches from the marvell git repository. I plan to send some other patches still under review a bit later - perhaps in a week or. As I'm off in Easter vacation starting tomorrow.
Thanks, Stefan
The following changes since commit d085ecd61b9956cda0d37b89b5c538f54440fe58:
ARM: uniphier: switch to raw U-Boot image (2016-03-24 01:45:41 +0900)
git://www.denx.de/git/u-boot-marvell.git
for you to fetch changes up to 7497a6a1f13eb86d68a936edecfd682bbad5752d:
tools: kwboot: Add xmodem timeout option (2016-03-24 10:08:49 +0100)
---------------------------------------------------------------- Andreas Färber (1): arm: mvebu: db-88f6820: Drop obsolete binary.0 placeholder
Dirk Eibach (1): arm: mvebu: Fix ddr3_init() cpu config
Kevin Smith (2): tools: kwboot: Clean up usage text tools: kwboot: Add xmodem timeout option
Peter Korsgaard (1): ARM: sheevaplug: correct nand partition layout
Stefan Roese (5): gpio: Add DM GPIO driver for Marvell MVEBU fpga: altera: Add StratixV support arm: mvebu: Add some SPI CS attributes arm: mvebu: spi.h: Add registers for direct write access arm: mvebu: theadorable: Add StratixV FPGA programming support
arch/arm/dts/armada-xp-theadorable.dts | 21 ++++ arch/arm/include/asm/arch-mvebu/spi.h | 3 + arch/arm/mach-mvebu/include/mach/cpu.h | 3 + board/Marvell/db-88f6820-gp/binary.0 | 16 --- board/theadorable/Makefile | 1 + board/theadorable/fpga.c | 179 +++++++++++++++++++++++++++++++++ board/theadorable/theadorable.c | 13 +++ board/theadorable/theadorable.h | 12 +++ configs/theadorable_debug_defconfig | 3 +- configs/theadorable_defconfig | 2 +- drivers/ddr/marvell/a38x/ddr3_init.c | 2 - drivers/fpga/Makefile | 1 + drivers/fpga/altera.c | 3 + drivers/fpga/stratixv.c | 103 +++++++++++++++++++ drivers/gpio/Kconfig | 7 ++ drivers/gpio/Makefile | 1 + drivers/gpio/mvebu_gpio.c | 119 ++++++++++++++++++++++ include/altera.h | 20 ++++ include/configs/sheevaplug.h | 6 +- include/configs/theadorable.h | 5 + tools/kwboot.c | 13 ++- 21 files changed, 507 insertions(+), 26 deletions(-) delete mode 100644 board/Marvell/db-88f6820-gp/binary.0 create mode 100644 board/theadorable/fpga.c create mode 100644 board/theadorable/theadorable.h create mode 100644 drivers/fpga/stratixv.c create mode 100644 drivers/gpio/mvebu_gpio.c
On Thu, Mar 24, 2016 at 11:09:19AM +0100, Stefan Roese wrote:
Hi Tom,
Thanks, Stefan
Stefan Roese
