[U-Boot] [PATCH v3] mx5:Use IMX_GPIO_NR macro
From 6cf58670aa251a33ecac6c53a8be88e6f4e444b7 Mon Sep 17 00:00:00 2001
From: Ashok Kumar Reddy ashokkourla2000@gmail.com Date: Tue, 28 Aug 2012 07:39:38 +0530 Subject: [PATCH v3] mx5:Use IMX_GPIO_NR macro
Signed-off-by: Ashok Kumar Reddy ashokkourla2000@gmail.com --- Changes from v1: -Remove checkpatch errors
Changes from v2: -Remove checkpatch errors
board/freescale/mx51evk/mx51evk.c | 12 ++++++------ board/freescale/mx53ard/mx53ard.c | 8 ++++---- board/freescale/mx53evk/mx53evk.c | 8 ++++---- board/freescale/mx53loco/mx53loco.c | 8 ++++---- board/freescale/mx53smd/mx53smd.c | 4 ++-- 5 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 514a7ac..f5db415 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -319,11 +319,11 @@ static void power_init(void) pmic_reg_write(p, REG_MODE_1, val);
mxc_request_iomux(MX51_PIN_EIM_A20, IOMUX_CONFIG_ALT1); - gpio_direction_output(46, 0); + gpio_direction_output(IMX_GPIO_NR(2, 14), 0);
udelay(500);
- gpio_set_value(46, 1); + gpio_set_value(IMX_GPIO_NR(2, 14), 1); }
#ifdef CONFIG_FSL_ESDHC @@ -333,14 +333,14 @@ int board_mmc_getcd(struct mmc *mmc) int ret;
mxc_request_iomux(MX51_PIN_GPIO1_0, IOMUX_CONFIG_ALT1); - gpio_direction_input(0); + gpio_direction_input(IMX_GPIO_NR(1, 0)); mxc_request_iomux(MX51_PIN_GPIO1_6, IOMUX_CONFIG_ALT0); - gpio_direction_input(6); + gpio_direction_input(IMX_GPIO_NR(1, 6));
if (cfg->esdhc_base == MMC_SDHC1_BASE_ADDR) - ret = !gpio_get_value(0); + ret = !gpio_get_value(IMX_GPIO_NR(1, 0)); else - ret = !gpio_get_value(6); + ret = !gpio_get_value(IMX_GPIO_NR(1, 6));
return ret; } diff --git a/board/freescale/mx53ard/mx53ard.c b/board/freescale/mx53ard/mx53ard.c index 2d21584..4f14a96 100644 --- a/board/freescale/mx53ard/mx53ard.c +++ b/board/freescale/mx53ard/mx53ard.c @@ -89,14 +89,14 @@ int board_mmc_getcd(struct mmc *mmc) int ret;
mxc_request_iomux(MX53_PIN_GPIO_1, IOMUX_CONFIG_ALT1); - gpio_direction_input(1); + gpio_direction_input(IMX_GPIO_NR(1, 1)); mxc_request_iomux(MX53_PIN_GPIO_4, IOMUX_CONFIG_ALT1); - gpio_direction_input(4); + gpio_direction_input(IMX_GPIO_NR(1, 4));
if (cfg->esdhc_base == MMC_SDHC1_BASE_ADDR) - ret = !gpio_get_value(1); /* GPIO1_1 */ + ret = !gpio_get_value(IMX_GPIO_NR(1, 1)); else - ret = !gpio_get_value(4); /* GPIO1_4 */ + ret = !gpio_get_value(IMX_GPIO_NR(1, 4));
return ret; } diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c index 8a6e31d..69bb600 100644 --- a/board/freescale/mx53evk/mx53evk.c +++ b/board/freescale/mx53evk/mx53evk.c @@ -214,14 +214,14 @@ int board_mmc_getcd(struct mmc *mmc) int ret;
mxc_request_iomux(MX53_PIN_EIM_DA11, IOMUX_CONFIG_ALT1); - gpio_direction_input(75); + gpio_direction_input(IMX_GPIO_NR(3, 11)); mxc_request_iomux(MX53_PIN_EIM_DA13, IOMUX_CONFIG_ALT1); - gpio_direction_input(77); + gpio_direction_input(IMX_GPIO_NR(3, 13));
if (cfg->esdhc_base == MMC_SDHC1_BASE_ADDR) - ret = !gpio_get_value(77); /* GPIO3_13 */ + ret = !gpio_get_value(IMX_GPIO_NR(3, 13)); else - ret = !gpio_get_value(75); /* GPIO3_11 */ + ret = !gpio_get_value(IMX_GPIO_NR(3, 11));
return ret; } diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index cbdcfad..f155c46 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -175,14 +175,14 @@ int board_mmc_getcd(struct mmc *mmc) int ret;
return ret; } diff --git a/board/freescale/mx53smd/mx53smd.c b/board/freescale/mx53smd/mx53smd.c index c237980..42f777b 100644 --- a/board/freescale/mx53smd/mx53smd.c +++ b/board/freescale/mx53smd/mx53smd.c @@ -135,8 +135,8 @@ struct fsl_esdhc_cfg esdhc_cfg[1] = { int board_mmc_getcd(struct mmc *mmc) { mxc_request_iomux(MX53_PIN_EIM_DA13, IOMUX_CONFIG_ALT1); - gpio_direction_input(77); - return !gpio_get_value(77); /* GPIO3_13 */ + gpio_direction_input(IMX_GPIO_NR(3, 13)); + return !gpio_get_value(IMX_GPIO_NR(3, 13)); }
int board_mmc_init(bd_t *bis)
On 28/08/2012 04:30, Ashok wrote:
From 6cf58670aa251a33ecac6c53a8be88e6f4e444b7 Mon Sep 17 00:00:00 2001 From: Ashok Kumar Reddy ashokkourla2000@gmail.com Date: Tue, 28 Aug 2012 07:39:38 +0530 Subject: [PATCH v3] mx5:Use IMX_GPIO_NR macro
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Ashok
Stefano Babic
