[PATCH] ARM: dts: uniphier: resync DT with Linux 5.9-rc1
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/dts/uniphier-ld11-global.dts | 2 +- arch/arm/dts/uniphier-ld11-ref.dts | 8 +- arch/arm/dts/uniphier-ld20-global.dts | 2 +- arch/arm/dts/uniphier-ld20-ref.dts | 8 +- arch/arm/dts/uniphier-ld20.dtsi | 2 + arch/arm/dts/uniphier-ld4-ref.dts | 6 +- arch/arm/dts/uniphier-ld6b-ref.dts | 7 +- arch/arm/dts/uniphier-pinctrl.dtsi | 5 + arch/arm/dts/uniphier-pro4-ace.dts | 2 +- arch/arm/dts/uniphier-pro4-ref.dts | 8 +- arch/arm/dts/uniphier-pro4-sanji.dts | 3 +- arch/arm/dts/uniphier-pro5.dtsi | 190 +++++++++++++++++++++--- arch/arm/dts/uniphier-pxs2-gentil.dts | 2 +- arch/arm/dts/uniphier-pxs2-vodka.dts | 2 +- arch/arm/dts/uniphier-pxs3-ref.dts | 10 +- arch/arm/dts/uniphier-pxs3.dtsi | 2 + arch/arm/dts/uniphier-sld8-ref.dts | 6 +- arch/arm/dts/uniphier-support-card.dtsi | 31 ++-- 18 files changed, 235 insertions(+), 61 deletions(-)
diff --git a/arch/arm/dts/uniphier-ld11-global.dts b/arch/arm/dts/uniphier-ld11-global.dts index 670e1a76db..644ffb9707 100644 --- a/arch/arm/dts/uniphier-ld11-global.dts +++ b/arch/arm/dts/uniphier-ld11-global.dts @@ -157,7 +157,7 @@ };
&mdio { - ethphy: ethphy@1 { + ethphy: ethernet-phy@1 { reg = <1>; }; }; diff --git a/arch/arm/dts/uniphier-ld11-ref.dts b/arch/arm/dts/uniphier-ld11-ref.dts index 693171f82f..617d2b1e9b 100644 --- a/arch/arm/dts/uniphier-ld11-ref.dts +++ b/arch/arm/dts/uniphier-ld11-ref.dts @@ -20,7 +20,7 @@
aliases { serial0 = &serial0; - serial1 = &serial1; + serial1 = &serialsc; serial2 = &serial2; serial3 = &serial3; i2c0 = &i2c0; @@ -42,6 +42,10 @@ interrupts = <0 8>; };
+&serialsc { + interrupts = <0 8>; +}; + &serial0 { status = "okay"; }; @@ -76,7 +80,7 @@ };
&mdio { - ethphy: ethphy@1 { + ethphy: ethernet-phy@1 { reg = <1>; }; }; diff --git a/arch/arm/dts/uniphier-ld20-global.dts b/arch/arm/dts/uniphier-ld20-global.dts index 2c00008266..a01579cb3b 100644 --- a/arch/arm/dts/uniphier-ld20-global.dts +++ b/arch/arm/dts/uniphier-ld20-global.dts @@ -141,7 +141,7 @@ };
&mdio { - ethphy: ethphy@1 { + ethphy: ethernet-phy@1 { reg = <1>; }; }; diff --git a/arch/arm/dts/uniphier-ld20-ref.dts b/arch/arm/dts/uniphier-ld20-ref.dts index eeb976e789..39ee279a1e 100644 --- a/arch/arm/dts/uniphier-ld20-ref.dts +++ b/arch/arm/dts/uniphier-ld20-ref.dts @@ -20,7 +20,7 @@
+&serialsc { + interrupts = <0 8>; +}; + &serial0 { status = "okay"; }; @@ -64,7 +68,7 @@ };
&mdio { - ethphy: ethphy@0 { + ethphy: ethernet-phy@0 { reg = <0>; }; }; diff --git a/arch/arm/dts/uniphier-ld20.dtsi b/arch/arm/dts/uniphier-ld20.dtsi index a5cd026838..5e7143ed01 100644 --- a/arch/arm/dts/uniphier-ld20.dtsi +++ b/arch/arm/dts/uniphier-ld20.dtsi @@ -955,7 +955,9 @@ compatible = "socionext,uniphier-ld20-pcie-phy"; reg = <0x66038000 0x4000>; #phy-cells = <0>; + clock-names = "link"; clocks = <&sys_clk 24>; + reset-names = "link"; resets = <&sys_rst 24>; socionext,syscon = <&soc_glue>; }; diff --git a/arch/arm/dts/uniphier-ld4-ref.dts b/arch/arm/dts/uniphier-ld4-ref.dts index 3aaca10f66..03fe696668 100644 --- a/arch/arm/dts/uniphier-ld4-ref.dts +++ b/arch/arm/dts/uniphier-ld4-ref.dts @@ -20,7 +20,7 @@
aliases { serial0 = &serial0; - serial1 = &serial1; + serial1 = &serialsc; serial2 = &serial2; serial3 = &serial3; i2c0 = &i2c0; @@ -39,6 +39,10 @@ interrupts = <1 8>; };
+&serialsc { + interrupts = <1 8>; +}; + &serial0 { status = "okay"; }; diff --git a/arch/arm/dts/uniphier-ld6b-ref.dts b/arch/arm/dts/uniphier-ld6b-ref.dts index f1a3b29bac..08943aa376 100644 --- a/arch/arm/dts/uniphier-ld6b-ref.dts +++ b/arch/arm/dts/uniphier-ld6b-ref.dts @@ -22,6 +22,7 @@ serial0 = &serial0; serial1 = &serial1; serial2 = &serial2; + serial3 = &serialsc; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; @@ -42,6 +43,10 @@ interrupts = <4 8>; };
+&serialsc { + interrupts = <4 8>; +}; + &serial0 { status = "okay"; }; @@ -76,7 +81,7 @@ };
&mdio { - ethphy: ethphy@0 { + ethphy: ethernet-phy@0 { reg = <0>; }; }; diff --git a/arch/arm/dts/uniphier-pinctrl.dtsi b/arch/arm/dts/uniphier-pinctrl.dtsi index bfdfb764b2..c0fd029b37 100644 --- a/arch/arm/dts/uniphier-pinctrl.dtsi +++ b/arch/arm/dts/uniphier-pinctrl.dtsi @@ -126,6 +126,11 @@ function = "nand"; };
+ pinctrl_pcie: pcie { + groups = "pcie"; + function = "pcie"; + }; + pinctrl_sd: sd { groups = "sd"; function = "sd"; diff --git a/arch/arm/dts/uniphier-pro4-ace.dts b/arch/arm/dts/uniphier-pro4-ace.dts index 64246fad32..27ff2b7b9d 100644 --- a/arch/arm/dts/uniphier-pro4-ace.dts +++ b/arch/arm/dts/uniphier-pro4-ace.dts @@ -87,7 +87,7 @@ };
&mdio { - ethphy: ethphy@1 { + ethphy: ethernet-phy@1 { reg = <1>; }; }; diff --git a/arch/arm/dts/uniphier-pro4-ref.dts b/arch/arm/dts/uniphier-pro4-ref.dts index 4967db58c5..3e1bc1275a 100644 --- a/arch/arm/dts/uniphier-pro4-ref.dts +++ b/arch/arm/dts/uniphier-pro4-ref.dts @@ -22,7 +22,7 @@ serial0 = &serial0; serial1 = &serial1; serial2 = &serial2; - serial3 = &serial3; + serial3 = &serialsc; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; @@ -43,6 +43,10 @@ interrupts = <2 8>; };
+&serialsc { + interrupts = <2 8>; +}; + &serial0 { status = "okay"; }; @@ -85,7 +89,7 @@ };
&mdio { - ethphy: ethphy@0 { + ethphy: ethernet-phy@0 { reg = <0>; }; }; diff --git a/arch/arm/dts/uniphier-pro4-sanji.dts b/arch/arm/dts/uniphier-pro4-sanji.dts index 3b68a7c605..e7c122de29 100644 --- a/arch/arm/dts/uniphier-pro4-sanji.dts +++ b/arch/arm/dts/uniphier-pro4-sanji.dts @@ -25,6 +25,7 @@ i2c3 = &i2c3; i2c5 = &i2c5; i2c6 = &i2c6; + ethernet0 = ð };
memory@80000000 { @@ -81,7 +82,7 @@ };
&mdio { - ethphy: ethphy@1 { + ethphy: ethernet-phy@1 { reg = <1>; }; }; diff --git a/arch/arm/dts/uniphier-pro5.dtsi b/arch/arm/dts/uniphier-pro5.dtsi index 8fc8433a3c..19848e36fa 100644 --- a/arch/arm/dts/uniphier-pro5.dtsi +++ b/arch/arm/dts/uniphier-pro5.dtsi @@ -465,40 +465,182 @@ }; };
- usb0: usb@65b00000 { - compatible = "socionext,uniphier-pro5-dwc3"; + usb0: usb@65a00000 { + compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; - reg = <0x65b00000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; + reg = <0x65a00000 0xcd00>; + interrupt-names = "host"; + interrupts = <0 134 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>; - dwc3@65a00000 { - compatible = "snps,dwc3"; - reg = <0x65a00000 0x10000>; - interrupts = <0 134 4>; - dr_mode = "host"; - tx-fifo-resize; - }; + clock-names = "ref", "bus_early", "suspend"; + clocks = <&sys_clk 12>, <&sys_clk 12>, <&sys_clk 12>; + resets = <&usb0_rst 15>; + phys = <&usb0_hsphy0>, <&usb0_ssphy0>; + dr_mode = "host"; };
- usb1: usb@65d00000 { - compatible = "socionext,uniphier-pro5-dwc3"; - status = "disabled"; - reg = <0x65d00000 0x1000>; + usb-glue@65b00000 { + compatible = "socionext,uniphier-pro5-dwc3-glue", + "simple-mfd"; #address-cells = <1>; #size-cells = <1>; - ranges; + ranges = <0 0x65b00000 0x400>; + + usb0_rst: reset@0 { + compatible = "socionext,uniphier-pro5-usb3-reset"; + reg = <0x0 0x4>; + #reset-cells = <1>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 14>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 14>; + }; + + usb0_vbus0: regulator@100 { + compatible = "socionext,uniphier-pro5-usb3-regulator"; + reg = <0x100 0x10>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 14>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 14>; + }; + + usb0_hsphy0: hs-phy@280 { + compatible = "socionext,uniphier-pro5-usb3-hsphy"; + reg = <0x280 0x10>; + #phy-cells = <0>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 14>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 14>; + vbus-supply = <&usb0_vbus0>; + }; + + usb0_ssphy0: ss-phy@380 { + compatible = "socionext,uniphier-pro5-usb3-ssphy"; + reg = <0x380 0x10>; + #phy-cells = <0>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 14>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 14>; + vbus-supply = <&usb0_vbus0>; + }; + }; + + usb1: usb@65c00000 { + compatible = "socionext,uniphier-dwc3", "snps,dwc3"; + status = "disabled"; + reg = <0x65c00000 0xcd00>; + interrupt-names = "host"; + interrupts = <0 137 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb2>; - dwc3@65c00000 { - compatible = "snps,dwc3"; - reg = <0x65c00000 0x10000>; - interrupts = <0 137 4>; - dr_mode = "host"; - tx-fifo-resize; + clock-names = "ref", "bus_early", "suspend"; + clocks = <&sys_clk 12>, <&sys_clk 12>, <&sys_clk 12>; + resets = <&usb1_rst 15>; + phys = <&usb1_hsphy0>, <&usb1_hsphy1>, <&usb1_ssphy0>; + dr_mode = "host"; + }; + + usb-glue@65d00000 { + compatible = "socionext,uniphier-pro5-dwc3-glue", + "simple-mfd"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x65d00000 0x400>; + + usb1_rst: reset@0 { + compatible = "socionext,uniphier-pro5-usb3-reset"; + reg = <0x0 0x4>; + #reset-cells = <1>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 15>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 15>; }; + + usb1_vbus0: regulator@100 { + compatible = "socionext,uniphier-pro5-usb3-regulator"; + reg = <0x100 0x10>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 15>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 15>; + }; + + usb1_vbus1: regulator@110 { + compatible = "socionext,uniphier-pro5-usb3-regulator"; + reg = <0x110 0x10>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 15>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 15>; + }; + + usb1_hsphy0: hs-phy@280 { + compatible = "socionext,uniphier-pro5-usb3-hsphy"; + reg = <0x280 0x10>; + #phy-cells = <0>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 15>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 15>; + vbus-supply = <&usb1_vbus0>; + }; + + usb1_hsphy1: hs-phy@290 { + compatible = "socionext,uniphier-pro5-usb3-hsphy"; + reg = <0x290 0x10>; + #phy-cells = <0>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 15>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 15>; + vbus-supply = <&usb1_vbus1>; + }; + + usb1_ssphy0: ss-phy@380 { + compatible = "socionext,uniphier-pro5-usb3-ssphy"; + reg = <0x380 0x10>; + #phy-cells = <0>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 15>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 15>; + vbus-supply = <&usb1_vbus0>; + }; + }; + + pcie_ep: pcie-ep@66000000 { + compatible = "socionext,uniphier-pro5-pcie-ep", + "snps,dw-pcie-ep"; + status = "disabled"; + reg-names = "dbi", "dbi2", "link", "addr_space"; + reg = <0x66000000 0x1000>, <0x66001000 0x1000>, + <0x66010000 0x10000>, <0x67000000 0x400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 24>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 24>; + num-ib-windows = <16>; + num-ob-windows = <16>; + num-lanes = <4>; + phy-names = "pcie-phy"; + phys = <&pcie_phy>; + }; + + pcie_phy: phy@66038000 { + compatible = "socionext,uniphier-pro5-pcie-phy"; + reg = <0x66038000 0x4000>; + #phy-cells = <0>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 24>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 24>; };
nand: nand-controller@68000000 { diff --git a/arch/arm/dts/uniphier-pxs2-gentil.dts b/arch/arm/dts/uniphier-pxs2-gentil.dts index 8e9ac579aa..759384b606 100644 --- a/arch/arm/dts/uniphier-pxs2-gentil.dts +++ b/arch/arm/dts/uniphier-pxs2-gentil.dts @@ -87,7 +87,7 @@ };
&mdio { - ethphy: ethphy@1 { + ethphy: ethernet-phy@1 { reg = <1>; }; }; diff --git a/arch/arm/dts/uniphier-pxs2-vodka.dts b/arch/arm/dts/uniphier-pxs2-vodka.dts index 8eacc7bdec..7e08a459f7 100644 --- a/arch/arm/dts/uniphier-pxs2-vodka.dts +++ b/arch/arm/dts/uniphier-pxs2-vodka.dts @@ -88,7 +88,7 @@ };
&mdio { - ethphy: ethphy@1 { + ethphy: ethernet-phy@1 { reg = <1>; }; }; diff --git a/arch/arm/dts/uniphier-pxs3-ref.dts b/arch/arm/dts/uniphier-pxs3-ref.dts index 1dacbf4fb0..1a80cd91d2 100644 --- a/arch/arm/dts/uniphier-pxs3-ref.dts +++ b/arch/arm/dts/uniphier-pxs3-ref.dts @@ -19,7 +19,7 @@
aliases { serial0 = &serial0; - serial1 = &serial1; + serial1 = &serialsc; serial2 = &serial2; serial3 = &serial3; i2c0 = &i2c0; @@ -43,6 +43,10 @@ interrupts = <4 8>; };
+&serialsc { + interrupts = <4 8>; +}; + &spi0 { status = "okay"; }; @@ -97,7 +101,7 @@ };
&mdio0 { - ethphy0: ethphy@0 { + ethphy0: ethernet-phy@0 { reg = <0>; }; }; @@ -108,7 +112,7 @@ };
&mdio1 { - ethphy1: ethphy@0 { + ethphy1: ethernet-phy@0 { reg = <0>; }; }; diff --git a/arch/arm/dts/uniphier-pxs3.dtsi b/arch/arm/dts/uniphier-pxs3.dtsi index bf3b1eae87..c4344926d9 100644 --- a/arch/arm/dts/uniphier-pxs3.dtsi +++ b/arch/arm/dts/uniphier-pxs3.dtsi @@ -871,7 +871,9 @@ compatible = "socionext,uniphier-pxs3-pcie-phy"; reg = <0x66038000 0x4000>; #phy-cells = <0>; + clock-names = "link"; clocks = <&sys_clk 24>; + reset-names = "link"; resets = <&sys_rst 24>; socionext,syscon = <&soc_glue>; }; diff --git a/arch/arm/dts/uniphier-sld8-ref.dts b/arch/arm/dts/uniphier-sld8-ref.dts index 01bf94c6b9..22898df39c 100644 --- a/arch/arm/dts/uniphier-sld8-ref.dts +++ b/arch/arm/dts/uniphier-sld8-ref.dts @@ -20,7 +20,7 @@
aliases { serial0 = &serial0; - serial1 = &serial1; + serial1 = &serialsc; serial2 = &serial2; serial3 = &serial3; i2c0 = &i2c0; @@ -39,6 +39,10 @@ interrupts = <0 8>; };
+&serialsc { + interrupts = <0 8>; +}; + &serial0 { status = "okay"; }; diff --git a/arch/arm/dts/uniphier-support-card.dtsi b/arch/arm/dts/uniphier-support-card.dtsi index bf441c2eff..444802fee9 100644 --- a/arch/arm/dts/uniphier-support-card.dtsi +++ b/arch/arm/dts/uniphier-support-card.dtsi @@ -8,26 +8,19 @@ &system_bus { status = "okay"; ranges = <1 0x00000000 0x42000000 0x02000000>; + interrupt-parent = <&gpio>;
- support_card: support-card@1,1f00000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x00000000 1 0x01f00000 0x00100000>; - interrupt-parent = <&gpio>; - - ethsc: ethernet@0 { - compatible = "smsc,lan9118", "smsc,lan9115"; - reg = <0x00000000 0x1000>; - phy-mode = "mii"; - reg-io-width = <4>; - }; + ethsc: ethernet@1,1f00000 { + compatible = "smsc,lan9118", "smsc,lan9115"; + reg = <1 0x01f00000 0x1000>; + phy-mode = "mii"; + reg-io-width = <4>; + };
- serialsc: uart@b0000 { - compatible = "ns16550a"; - reg = <0x000b0000 0x20>; - clock-frequency = <12288000>; - reg-shift = <1>; - }; + serialsc: serial@1,1fb0000 { + compatible = "ns16550a"; + reg = <1 0x01fb0000 0x20>; + clock-frequency = <12288000>; + reg-shift = <1>; }; };
Masahiro Yamada
