[U-Boot] [PATCH v2 0/2] mpc85xx: support for Freescale COM Express P2020
This is a cleaned up version of the U-Boot port provided with the BSP for the Freescale COM Express P2020 evaluation kit.
Changes v1 -> v2: - fix checkpatch warnings - remove references to NAND (this board lacks NAND) - disable CCSR relocation
Ira W. Snyder (2): mpc85xx: support board-specific reset function mpc85xx: support for Freescale COM Express P2020
MAINTAINERS | 4 + arch/powerpc/cpu/mpc85xx/cpu.c | 17 +- arch/powerpc/include/asm/immap_85xx.h | 1 + board/freescale/p2020come/Makefile | 46 +++ board/freescale/p2020come/ddr.c | 245 ++++++++++++++ board/freescale/p2020come/law.c | 36 ++ board/freescale/p2020come/p2020come.c | 401 +++++++++++++++++++++++ board/freescale/p2020come/tlb.c | 100 ++++++ boards.cfg | 2 + include/configs/P2020COME.h | 566 +++++++++++++++++++++++++++++++++ 10 files changed, 1417 insertions(+), 1 deletions(-) create mode 100644 board/freescale/p2020come/Makefile create mode 100644 board/freescale/p2020come/ddr.c create mode 100644 board/freescale/p2020come/law.c create mode 100644 board/freescale/p2020come/p2020come.c create mode 100644 board/freescale/p2020come/tlb.c create mode 100644 include/configs/P2020COME.h
This is useful for boards which cannot be reset in the usual way for the 85xx CPU. An example is a board which can only be reset by a hardware watchdog.
Signed-off-by: Ira W. Snyder iws@ovro.caltech.edu ---
Unchanged from v1.
arch/powerpc/cpu/mpc85xx/cpu.c | 17 ++++++++++++++++- 1 files changed, 16 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 49c0551..c1815e8 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -42,6 +42,16 @@
DECLARE_GLOBAL_DATA_PTR;
+/* + * Default board reset function + */ +static void +__board_reset(void) +{ + /* Do nothing */ +} +void board_reset(void) __attribute__((weak, alias("__board_reset"))); + int checkcpu (void) { sys_info_t sysinfo; @@ -215,7 +225,12 @@ int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) mtspr(DBCR0,val); #else volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - out_be32(&gur->rstcr, 0x2); /* HRESET_REQ */ + + /* Attempt board-specific reset */ + board_reset(); + + /* Next try asserting HRESET_REQ */ + out_be32(&gur->rstcr, 0x2); udelay(100); #endif
This adds support for the Freescale COM Express P2020 board. This board is similar to the P1_P2_RDB, but has some extra (as well as missing) peripherals.
Unlike all other mpc85xx boards, it uses a watchdog timeout to reset. Using the HRESET_REQ register does not work.
This board has no NOR flash, and can only be booted via SD or SPI. This procedure is documented in Freescale Document Number AN3659 "Booting from On-Chip RAM (eSDHC or eSPI)." Some alternative documentation is provided in Freescale Document Number P2020RM "P2020 QorIQ Integrated Processor Reference Manual" (section 4.5).
Changes v1 -> v2: - fix checkpatch warnings - remove all references to NAND - update to top of tree U-Boot - remove CCSR relocation (top of tree code doesn't work)
I wish I could debug the CCSR relocation issue on this board, but I don't have a JTAG setup which is capable of debugging this issue.
MAINTAINERS | 4 + arch/powerpc/include/asm/immap_85xx.h | 1 + board/freescale/p2020come/Makefile | 46 +++ board/freescale/p2020come/ddr.c | 245 ++++++++++++++ board/freescale/p2020come/law.c | 36 ++ board/freescale/p2020come/p2020come.c | 401 +++++++++++++++++++++++ board/freescale/p2020come/tlb.c | 100 ++++++ boards.cfg | 2 + include/configs/P2020COME.h | 566 +++++++++++++++++++++++++++++++++ 9 files changed, 1401 insertions(+), 0 deletions(-) create mode 100644 board/freescale/p2020come/Makefile create mode 100644 board/freescale/p2020come/ddr.c create mode 100644 board/freescale/p2020come/law.c create mode 100644 board/freescale/p2020come/p2020come.c create mode 100644 board/freescale/p2020come/tlb.c create mode 100644 include/configs/P2020COME.h
diff --git a/MAINTAINERS b/MAINTAINERS index 030fe4a..b689a88 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -454,6 +454,10 @@ Jon Smirl jonsmirl@gmail.com
pcm030 MPC5200
+Ira W. Snyder iws@ovro.caltech.edu + + P2020COME P2020 + Timur Tabi timur@freescale.com
MPC8349E-mITX MPC8349 diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 99fe97d..9b08cb8 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2420,6 +2420,7 @@ struct ccsr_rman { #define CONFIG_SYS_MPC85xx_L2_OFFSET 0x20000 #define CONFIG_SYS_MPC85xx_DMA_OFFSET 0x21000 #define CONFIG_SYS_MPC85xx_USB_OFFSET 0x22000 +#define CONFIG_SYS_MPC85xx_USB2_OFFSET 0x23000 #ifdef CONFIG_TSECV2 #define CONFIG_SYS_TSEC1_OFFSET 0xB0000 #else diff --git a/board/freescale/p2020come/Makefile b/board/freescale/p2020come/Makefile new file mode 100644 index 0000000..ba87904 --- /dev/null +++ b/board/freescale/p2020come/Makefile @@ -0,0 +1,46 @@ +# +# Copyright 2009 Freescale Semiconductor, Inc. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += ddr.o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/p2020come/ddr.c b/board/freescale/p2020come/ddr.c new file mode 100644 index 0000000..dd2a4dd --- /dev/null +++ b/board/freescale/p2020come/ddr.c @@ -0,0 +1,245 @@ +/* + * Copyright 2009, 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/processor.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/io.h> +#include <asm/fsl_law.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000003F +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014202 +#define CONFIG_SYS_DDR_CS0_CONFIG_2 0x00000000 +#define CONFIG_SYS_DDR_INIT_ADDR 0x00000000 +#define CONFIG_SYS_DDR_INIT_EXT_ADDR 0x00000000 +#define CONFIG_SYS_DDR_MODE_CONTROL 0x00000000 +#define CONFIG_SYS_DDR_ZQ_CONTROL 0x00000000 +#define CONFIG_SYS_DDR_WRLVL_CONTROL 0x00000000 +#define CONFIG_SYS_DDR_SR_CNTR 0x00000000 +#define CONFIG_SYS_DDR_RCW_1 0x00000000 +#define CONFIG_SYS_DDR_RCW_2 0x00000000 +#define CONFIG_SYS_DDR_CONTROL 0x43000000 /* Type = DDR2*/ +#define CONFIG_SYS_DDR_CONTROL_2 0x24401000 +#define CONFIG_SYS_DDR_TIMING_4 0x00000000 +#define CONFIG_SYS_DDR_TIMING_5 0x00000000 + +#define CONFIG_SYS_DDR_TIMING_3_400 0x00010000 +#define CONFIG_SYS_DDR_TIMING_0_400 0x00260802 +#define CONFIG_SYS_DDR_TIMING_1_400 0x39355322 +#define CONFIG_SYS_DDR_TIMING_2_400 0x1f9048ca +#define CONFIG_SYS_DDR_CLK_CTRL_400 0x02800000 +#define CONFIG_SYS_DDR_MODE_1_400 0x00480432 +#define CONFIG_SYS_DDR_MODE_2_400 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL_400 0x06180100 + +#define CONFIG_SYS_DDR_TIMING_3_533 0x00020000 +#define CONFIG_SYS_DDR_TIMING_0_533 0x00260802 +#define CONFIG_SYS_DDR_TIMING_1_533 0x4c47c432 +#define CONFIG_SYS_DDR_TIMING_2_533 0x0f9848ce +#define CONFIG_SYS_DDR_CLK_CTRL_533 0x02800000 +#define CONFIG_SYS_DDR_MODE_1_533 0x00040642 +#define CONFIG_SYS_DDR_MODE_2_533 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL_533 0x08200100 + +#define CONFIG_SYS_DDR_TIMING_3_667 0x00030000 +#define CONFIG_SYS_DDR_TIMING_0_667 0x55770802 +#define CONFIG_SYS_DDR_TIMING_1_667 0x5f599543 +#define CONFIG_SYS_DDR_TIMING_2_667 0x0fa074d1 +#define CONFIG_SYS_DDR_CLK_CTRL_667 0x03000000 +#define CONFIG_SYS_DDR_MODE_1_667 0x00040852 +#define CONFIG_SYS_DDR_MODE_2_667 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL_667 0x0a280100 + +#define CONFIG_SYS_DDR_TIMING_3_800 0x00040000 +#define CONFIG_SYS_DDR_TIMING_0_800 0x00770802 +#define CONFIG_SYS_DDR_TIMING_1_800 0x6f6b6543 +#define CONFIG_SYS_DDR_TIMING_2_800 0x0fa074d1 +#define CONFIG_SYS_DDR_CLK_CTRL_800 0x02800000 +#define CONFIG_SYS_DDR_MODE_1_800 0x00040852 +#define CONFIG_SYS_DDR_MODE_2_800 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL_800 0x0c300100 + +fsl_ddr_cfg_regs_t ddr_cfg_regs_400 = { + .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, + .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, + .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, + .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_400, + .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_400, + .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_400, + .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_400, + .ddr_sdram_cfg = CONFIG_SYS_DDR_CONTROL, + .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2, + .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_400, + .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_400, + .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, + .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_400, + .ddr_data_init = CONFIG_MEM_INIT_VALUE, + .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_400, + .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, + .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, + .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, + .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, + .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CONTROL, + .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CONTROL, + .ddr_sr_cntr = CONFIG_SYS_DDR_SR_CNTR, + .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, + .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 +}; + +fsl_ddr_cfg_regs_t ddr_cfg_regs_533 = { + .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, + .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, + .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, + .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_533, + .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_533, + .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_533, + .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_533, + .ddr_sdram_cfg = CONFIG_SYS_DDR_CONTROL, + .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2, + .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_533, + .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_533, + .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, + .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_533, + .ddr_data_init = CONFIG_MEM_INIT_VALUE, + .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_533, + .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, + .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, + .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, + .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, + .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CONTROL, + .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CONTROL, + .ddr_sr_cntr = CONFIG_SYS_DDR_SR_CNTR, + .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, + .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 +}; + +fsl_ddr_cfg_regs_t ddr_cfg_regs_667 = { + .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, + .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, + .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, + .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_667, + .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_667, + .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_667, + .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_667, + .ddr_sdram_cfg = CONFIG_SYS_DDR_CONTROL, + .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2, + .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_667, + .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_667, + .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, + .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_667, + .ddr_data_init = CONFIG_MEM_INIT_VALUE, + .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_667, + .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, + .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, + .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, + .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, + .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CONTROL, + .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CONTROL, + .ddr_sr_cntr = CONFIG_SYS_DDR_SR_CNTR, + .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, + .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 +}; + +fsl_ddr_cfg_regs_t ddr_cfg_regs_800 = { + .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, + .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, + .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, + .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_800, + .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_800, + .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_800, + .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_800, + .ddr_sdram_cfg = CONFIG_SYS_DDR_CONTROL, + .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2, + .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_800, + .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_800, + .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, + .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_800, + .ddr_data_init = CONFIG_MEM_INIT_VALUE, + .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_800, + .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, + .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, + .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, + .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, + .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CONTROL, + .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CONTROL, + .ddr_sr_cntr = CONFIG_SYS_DDR_SR_CNTR, + .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, + .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 +}; + +/* + * Fixed sdram init -- doesn't use serial presence detect. + */ + +phys_size_t fixed_sdram(void) +{ + char buf[32]; + fsl_ddr_cfg_regs_t ddr_cfg_regs; + size_t ddr_size; + struct cpu_type *cpu; + ulong ddr_freq, ddr_freq_mhz; + + cpu = gd->cpu; + /* P1020 and it's derivatives support max 32bit DDR width */ + if (cpu->soc_ver == SVR_P1020 || cpu->soc_ver == SVR_P1020_E || + cpu->soc_ver == SVR_P1011 || cpu->soc_ver == SVR_P1011_E) { + ddr_size = (CONFIG_SYS_SDRAM_SIZE * 1024 * 1024 / 2); + } else { + ddr_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; + } +#if defined(CONFIG_SYS_RAMBOOT) + return ddr_size; +#endif + ddr_freq = get_ddr_freq(0); + ddr_freq_mhz = ddr_freq / 1000000; + + printf("Configuring DDR for %s MT/s data rate\n", + strmhz(buf, ddr_freq)); + + if (ddr_freq_mhz <= 400) + memcpy(&ddr_cfg_regs, &ddr_cfg_regs_400, sizeof(ddr_cfg_regs)); + else if (ddr_freq_mhz <= 533) + memcpy(&ddr_cfg_regs, &ddr_cfg_regs_533, sizeof(ddr_cfg_regs)); + else if (ddr_freq_mhz <= 667) + memcpy(&ddr_cfg_regs, &ddr_cfg_regs_667, sizeof(ddr_cfg_regs)); + else if (ddr_freq_mhz <= 800) + memcpy(&ddr_cfg_regs, &ddr_cfg_regs_800, sizeof(ddr_cfg_regs)); + else + panic("Unsupported DDR data rate %s MT/s data rate\n", + strmhz(buf, ddr_freq)); + + /* P1020 and it's derivatives support max 32bit DDR width */ + if (cpu->soc_ver == SVR_P1020 || cpu->soc_ver == SVR_P1020_E || + cpu->soc_ver == SVR_P1011 || cpu->soc_ver == SVR_P1011_E) { + ddr_cfg_regs.ddr_sdram_cfg |= SDRAM_CFG_32_BE; + ddr_cfg_regs.cs[0].bnds = 0x0000001F; + } + + fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0); + + set_ddr_laws(0, ddr_size, LAW_TRGT_IF_DDR_1); + return ddr_size; +} diff --git a/board/freescale/p2020come/law.c b/board/freescale/p2020come/law.c new file mode 100644 index 0000000..56508db --- /dev/null +++ b/board/freescale/p2020come/law.c @@ -0,0 +1,36 @@ +/* + * Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_1), + SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_1), + SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_2), + SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_2), + SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_3), + SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_3), +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/p2020come/p2020come.c b/board/freescale/p2020come/p2020come.c new file mode 100644 index 0000000..2e334cf --- /dev/null +++ b/board/freescale/p2020come/p2020come.c @@ -0,0 +1,401 @@ +/* + * Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <hwconfig.h> +#include <command.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <fsl_mdio.h> +#include <tsec.h> +#include <vsc7385.h> +#include <netdev.h> +#include <mmc.h> +#include <malloc.h> +#include <i2c.h> + +#if defined(CONFIG_PCI) +#include <asm/fsl_pci.h> +#include <pci.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +#if defined(CONFIG_PCI) +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} + +void ft_pci_board_setup(void *blob) +{ + FT_FSL_PCI_SETUP; +} +#endif + +/* + * GPIO + * 0 - 3: CarryBoard Input; + * 4 - 7: CarryBoard Output; + * 8 : Mux as SDHC_CD (card detection) + * 9 : Mux as SDHC_WP + * 10 : Clear Watchdog timer + * 11 : LED Input + * 12 : Output to 1 + * 13 : Open Drain + * 14 : LED Output + * 15 : Switch Input + */ +#define GPIO_DIR 0x0f3a0000 +#define GPIO_ODR 0x00000000 + +#define BOARD_PERI_RST_SET (VSC7385_RST_SET | SLIC_RST_SET | \ + SGMII_PHY_RST_SET | PCIE_RST_SET | \ + RGMII_PHY_RST_SET) + +#define SYSCLK_MASK 0x00200000 +#define BOARDREV_MASK 0x10100000 +#define BOARDREV_B 0x10100000 +#define BOARDREV_C 0x00100000 +#define BOARDREV_D 0x00000000 + +#define SYSCLK_66 66666666 +#define SYSCLK_50 50000000 +#define SYSCLK_100 100000000 + +unsigned long get_board_sys_clk(ulong dummy) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 ddr_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_DDR_RATIO; + + ddr_ratio >>= MPC85xx_PORPLLSR_DDR_RATIO_SHIFT; + switch (ddr_ratio) { + case 0x0C: + return SYSCLK_66; + case 0x0A: + case 0x08: + return SYSCLK_100; + default: + puts("ERROR: unknown DDR ratio\n"); + return SYSCLK_100; + } +} + +unsigned long get_board_ddr_clk(ulong dummy) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 ddr_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_DDR_RATIO; + + ddr_ratio >>= MPC85xx_PORPLLSR_DDR_RATIO_SHIFT; + switch (ddr_ratio) { + case 0x0C: + case 0x0A: + return SYSCLK_66; + case 0x08: + return SYSCLK_100; + default: + puts("ERROR: unknown DDR ratio\n"); + return SYSCLK_100; + } +} + +#ifdef CONFIG_MMC +int board_early_init_f(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + setbits_be32(&gur->pmuxcr, + (MPC85xx_PMUXCR_SDHC_CD | + MPC85xx_PMUXCR_SDHC_WP)); + + /* All the device are enable except for SRIO12 */ + setbits_be32(&gur->devdisr, 0x80000); + return 0; +} +#endif + +int checkboard(void) +{ + ccsr_gpio_t *pgpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR + 0xC00); + + /* + * GPIO + * 0 - 3: CarryBoard Input; + * 4 - 7: CarryBoard Output; + * 8 : Mux as SDHC_CD (card detection) + * 9 : Mux as SDHC_WP + * 10 : Clear Watchdog timer + * 11 : LED Input + * 12 : Output to 1 + * 13 : Open Drain + * 14 : LED Output + * 15 : Switch Input + * + * Set GPIOs 11, 12, 14 to 1. + */ + out_be32(&pgpio->gpdir, GPIO_DIR); + out_be32(&pgpio->gpodr, GPIO_ODR); + out_be32(&pgpio->gpdat, 0x001A0000); + + puts("Board: Freescale COM Express P2020\n"); + return 0; +} + +#define M41ST85W_ERROR(fmt, args...) printf("ERROR: M41ST85W: " fmt, ##args) + +static void m41st85w_clear_bit(u8 reg, u8 mask, const char *name) +{ + u8 data; + + if (i2c_read(0x68, reg, 1, &data, 1)) { + M41ST85W_ERROR("unable to read %s bit\n", name); + return; + } + + if (data & mask) { + data &= ~mask; + if (i2c_write(0x68, reg, 1, &data, 1)) { + M41ST85W_ERROR("unable to clear %s bit\n", name); + return; + } + } +} + +/* + * The P2020COME board has a STMicro M41ST85W RTC/watchdog + * at i2c bus 1 address 0x68. + */ +static void start_rtc(void) +{ + unsigned int bus = i2c_get_bus_num(); + + if (i2c_set_bus_num(1)) { + M41ST85W_ERROR("unable to set i2c bus\n"); + goto out; + } + + /* ensure ST (stop) and HT (halt update) bits are cleared */ + m41st85w_clear_bit(0x1, 0x80, "ST"); + m41st85w_clear_bit(0xc, 0x40, "HT"); + +out: + /* reset the i2c bus */ + i2c_set_bus_num(bus); +} + +int board_early_init_r(void) +{ + start_rtc(); + return 0; +} + +void board_reset(void) +{ + u8 data = (1 << 2) | 0x82; + + /* set the hardware watchdog timeout to 1 second, then hang */ + i2c_set_bus_num(1); + i2c_write(0x68, 9, 1, &data, 1); + + while (1) + /* hang */; +} + +#ifdef CONFIG_TSEC_ENET +int board_eth_init(bd_t *bis) +{ + struct fsl_pq_mdio_info mdio_info; + struct tsec_info_struct tsec_info[4]; + int num = 0; + +#ifdef CONFIG_TSEC1 + SET_STD_TSEC_INFO(tsec_info[num], 1); + num++; +#endif +#ifdef CONFIG_TSEC2 + SET_STD_TSEC_INFO(tsec_info[num], 2); + num++; +#endif +#ifdef CONFIG_TSEC3 + SET_STD_TSEC_INFO(tsec_info[num], 3); + if (is_serdes_configured(SGMII_TSEC3)) { + puts("eTSEC3 is in sgmii mode."); + tsec_info[num].flags |= TSEC_SGMII; + } + num++; +#endif + if (!num) { + printf("No TSECs initialized\n"); + return 0; + } + + mdio_info.regs = (struct tsec_mii_mng *)CONFIG_SYS_MDIO_BASE_ADDR; + mdio_info.name = DEFAULT_MII_NAME; + fsl_pq_mdio_init(bis, &mdio_info); + + tsec_eth_init(bis, tsec_info, num); + + return pci_eth_init(bis); +} +#endif + +#if defined(CONFIG_OF_BOARD_SETUP) +void fdt_fixup_add_2nd_usb(void *blob, int agent) +{ + const char *soc_compat = "fsl,p2020-immr"; + const char *lbc_compat = "fsl,p2020-elbc"; + const u32 *addrcell, *sizecell, *ph; + int off, lbcoff, len, err; + u32 *regbuf = NULL; + u32 *irqbuf = NULL; + + off = fdt_node_offset_by_compatible(blob, -1, soc_compat); + if (off < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + soc_compat, fdt_strerror(off)); + return; + } + + lbcoff = fdt_node_offset_by_compatible(blob, -1, lbc_compat); + if (lbcoff < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + lbc_compat, fdt_strerror(lbcoff)); + return; + } + + addrcell = fdt_getprop(blob, off, "#address-cells", NULL); + sizecell = fdt_getprop(blob, off, "#size-cells", NULL); + + off = fdt_add_subnode(blob, off, "usb@23000"); + if (off < 0) { + printf("WARNING: could not add 2nd usb node %s.\n", + fdt_strerror(off)); + return; + } + + err = fdt_setprop_cell(blob, off, "#address-cells", 1); + if (err < 0) + printf("WARNING: could not set #address-cell property: %s\n", + fdt_strerror(err)); + + err = fdt_setprop_cell(blob, off, "#size-cells", 0); + if (err < 0) + printf("WARNING: could not set #size-cells property: %s\n", + fdt_strerror(err)); + + err = fdt_setprop_string(blob, off, "compatible", "fsl-usb2-dr"); + if (err < 0) + printf("WARNING: could not set compatible property: %s\n", + fdt_strerror(err)); + + err = fdt_setprop_string(blob, off, "phy_type", "ulpi"); + if (err < 0) + printf("WARNING: could not set phy_type property: %s\n", + fdt_strerror(err)); + + if (agent) { + err = fdt_setprop_string(blob, off, "dr_mode", "peripheral"); + if (err < 0) + printf("WARNING: could not set dr_mode property: %s\n", + fdt_strerror(err)); + } + + if (addrcell && *addrcell == 2) { + regbuf[0] = 0; + regbuf[1] = CONFIG_SYS_MPC85xx_USB2_OFFSET; + len = 2; + } else { + regbuf[0] = CONFIG_SYS_MPC85xx_USB2_OFFSET; + len = 1; + } + + if (sizecell && *sizecell == 2) { + regbuf[len] = 0; + regbuf[len + 1] = 0x1000; + len = 2; + } else { + regbuf[len] = 0x1000; + len++; + } + + err = fdt_setprop(blob, off, "reg", regbuf, len * sizeof(u32)); + if (err < 0) + printf("WARNING: could not set <%s> %s\n", + "reg", fdt_strerror(err)); + + irqbuf[0] = 0x2e; + irqbuf[1] = 0x2; + + err = fdt_setprop(blob, off, "interrupts", irqbuf, 2 * sizeof(u32)); + if (err < 0) + printf("WARNING: could not set %s %s\n", + "interrupts", fdt_strerror(err)); + + ph = fdt_getprop(blob, lbcoff, "interrupt-parent", 0); + if (!ph) { + printf("WARNING: could not read interrupt-parent property\n"); + return; + } + + err = fdt_setprop(blob, off, "interrupt-parent", ph, sizeof(u32)); + if (err < 0) + printf("WARNING: could not set %s %s\n", + "interrupt-parent", fdt_strerror(err)); +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + int agent; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + +#if defined(CONFIG_PCI) + ft_pci_board_setup(blob); +#endif + + fdt_fixup_memory(blob, (u64)base, (u64)size); + + if (!hwconfig("usb2")) + return; + + agent = hwconfig_subarg_cmp("usb2", "dr_mode", "peripheral"); + + /* + * Add the 2nd usb node and enable it. eLBC will + * now be disabled since it is MUXed with USB2 + */ + + fdt_fixup_add_2nd_usb(blob, agent); +} +#endif diff --git a/board/freescale/p2020come/tlb.c b/board/freescale/p2020come/tlb.c new file mode 100644 index 0000000..e1dd056 --- /dev/null +++ b/board/freescale/p2020come/tlb.c @@ -0,0 +1,100 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, + CONFIG_SYS_INIT_RAM_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024 , + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024 , + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024 , + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Covers boot page */ + SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_4K, 1), + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + +#if defined(CONFIG_PCI) + /* *I*G* - PCI3 - PCI2 0x8000,0000 - 0xbfff,ffff, size = 1G */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT, CONFIG_SYS_PCIE3_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_1G, 1), + + /* *I*G* - PCI1 0xC000,0000 - 0xcfff,ffff, size = 256M */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_VIRT, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + + + /* *I*G* - PCI1 0xD000,0000 - 0xDFFF,FFFF, size = 256M */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT + 0x10000000, + CONFIG_SYS_PCIE1_MEM_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_256M, 1), + + /* + * *I*G* - PCI I/O + * + * PCI3 => 0xFFC10000 + * PCI2 => 0xFFC2,0000 + * PCI1 => 0xFFC3,0000 + */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_IO_VIRT, CONFIG_SYS_PCIE3_IO_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_256K, 1), +#endif /* #if defined(CONFIG_PCI) */ + +#if defined(CONFIG_SYS_RAMBOOT) + /* *I*G - DDR3 2G Part 1: 0 - 0x3fff,ffff , size = 1G */ + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_1G, 1), + + /* DDR3 2G Part 2: 0x4000,0000 - 0x7fff,ffff , size = 1G */ + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, + CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 7, BOOKE_PAGESZ_1G, 1), +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 8b7a03b..4e1f663 100644 --- a/boards.cfg +++ b/boards.cfg @@ -714,6 +714,8 @@ P2020RDB-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freesca P2020RDB-PC_36BIT_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT,NAND P2020RDB-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT,SDCARD P2020RDB-PC_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT,SPIFLASH +P2020COME_SDCARD powerpc mpc85xx p2020come freescale - P2020COME:SDCARD +P2020COME_SPIFLASH powerpc mpc85xx p2020come freescale - P2020COME:SPIFLASH P2041RDB powerpc mpc85xx p2041rdb freescale P2041RDB_SDCARD powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P2041RDB_SECURE_BOOT powerpc mpc85xx p2041rdb freescale - P2041RDB:SECURE_BOOT diff --git a/include/configs/P2020COME.h b/include/configs/P2020COME.h new file mode 100644 index 0000000..10955b6 --- /dev/null +++ b/include/configs/P2020COME.h @@ -0,0 +1,566 @@ +/* + * Copyright 2009-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* The P2020COME board is only booted via RAM */ +#define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC + +#define CONFIG_SYS_TEXT_BASE 0x11000000 +#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc + +#ifdef CONFIG_SDCARD +#define CONFIG_RAMBOOT_SDCARD 1 +#endif + +#ifdef CONFIG_SPIFLASH +#define CONFIG_RAMBOOT_SPIFLASH 1 +#endif + +#ifndef CONFIG_SYS_MONITOR_BASE +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE 1 /* BOOKE */ +#define CONFIG_E500 1 /* BOOKE e500 family */ +#define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48/P1020/P2020,etc*/ +#define CONFIG_P2020 1 +#define CONFIG_P2020COME 1 +#define CONFIG_FSL_ELBC 1 /* Enable eLBC Support */ +#define CONFIG_MP + +#define CONFIG_PCI 1 /* Enable PCI/PCIE */ +#if defined(CONFIG_PCI) +#define CONFIG_PCIE1 1 /* PCIE controller 1 (slot 1) */ +#define CONFIG_PCIE2 1 /* PCIE controller 2 (slot 2) */ +#define CONFIG_PCIE3 1 /* PCIE controller 3 (slot 3) */ + +#define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ +#define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ +#endif /* #if defined(CONFIG_PCI) */ +#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ +#define CONFIG_TSEC_ENET /* tsec ethernet support */ +#define CONFIG_ENV_OVERWRITE + +#if defined(CONFIG_PCI) +#define CONFIG_E1000 1 /* E1000 pci Ethernet card */ +#endif + +#ifndef __ASSEMBLY__ +extern unsigned long get_board_sys_clk(unsigned long dummy); +#endif + +/* + * For P2020COME DDRCLK and SYSCLK are from the same oscillator + * For DA phase the SYSCLK is 66MHz + * For EA phase the SYSCLK is 100MHz + */ +#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk(0) +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk(0) + +#define CONFIG_HWCONFIG + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE /* toggle L2 cache */ +#define CONFIG_BTB /* toggle branch prediction */ + +#define CONFIG_ADDR_STREAMING /* toggle addr streaming */ + +#define CONFIG_ENABLE_36BIT_PHYS 1 + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_ADDR_MAP 1 +#define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif + +#define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x1fffffff +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + + + + + + + + /* + * Config the L2 Cache as L2 SRAM + */ +#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_INIT_L2_ADDR_PHYS 0xff8f80000ull +#else +#define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR +#endif +#define CONFIG_SYS_L2_SIZE (512 << 10) +#define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR \ + + CONFIG_SYS_L2_SIZE) + +/* DDR Setup */ +#define CONFIG_FSL_DDR2 +#undef CONFIG_FSL_DDR_INTERACTIVE +#undef CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup */ + +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef + +#define CONFIG_SYS_SDRAM_SIZE 2048ULL /* DDR size on P2020COME */ +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL 1 + +#define CONFIG_SYS_DDR_ERR_INT_EN 0x0000000d +#define CONFIG_SYS_DDR_ERR_DIS 0x00000000 +#define CONFIG_SYS_DDR_SBE 0x00FF0000 + +/* + * Memory map + * + * 0x0000_0000 0x7fff_ffff DDR3 2G Cacheable + * 0x8000_0000 0x9fff_ffff PCI Express 3 Mem 1G non-cacheable + * 0xa000_0000 0xbfff_ffff PCI Express 2 Mem 1G non-cacheable + * 0xc000_0000 0xdfff_ffff PCI Express 1 Mem 1G non-cacheable + * 0xffc1_0000 0xffc1_ffff PCI Express 3 IO 64K non-cacheable + * 0xffc2_0000 0xffc2_ffff PCI Express 2 IO 64K non-cacheable + * 0xffc3_0000 0xffc3_ffff PCI Express 1 IO 64K non-cacheable + * + * 0xffd0_0000 0xffd0_3fff L1 for stack 16K Cacheable TLB0 + * 0xffe0_0000 0xffef_ffff CCSR 1M non-cacheable + */ + +/* + * Local Bus Definitions + */ + +/* There is no NOR Flash on P2020COME */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ +#define CONFIG_HWCONFIG + +#define CONFIG_SYS_INIT_RAM_LOCK 1 +#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* stack in RAM */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR +/* the assembler doesn't like typecast */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ + ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ + CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) +#else +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS CONFIG_SYS_INIT_RAM_ADDR +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS +#endif +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ + - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) + +/* Serial Port - controlled on board with jumper J8 + * open - index 2 + * shorted - index 1 + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SERIAL_MULTI 1 /* Enable both serial ports */ +#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +/* + * Pass open firmware flat tree + */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + +/* new uImage format support */ +#define CONFIG_FIT 1 +#define CONFIG_FIT_VERBOSE 1 + +/* I2C */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_CMD_TREE +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address*/ +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x29} } +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* + * I2C2 EEPROM + */ +#define CONFIG_ID_EEPROM +#ifdef CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#endif +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_I2C_EEPROM_ADDR2 0x18 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ + +/* + * eSPI - Enhanced SPI + */ +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ +#if defined(CONFIG_PCI) + +/* controller 3, Slot 3, tgtid 3, Base address 8000 */ +#define CONFIG_SYS_PCIE3_MEM_VIRT 0x80000000 +#define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE3_MEM_PHYS 0x80000000 +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE3_IO_VIRT 0xffc10000 +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_PHYS 0xffc10000 +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ + +/* controller 2, Slot 2, tgtid 2, Base address 9000 */ +#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_VIRT 0xffc20000 +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_PHYS 0xffc20000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ + +/* controller 1, Slot 1, tgtid 1, Base address a000 */ +#define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xffc30000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_PHYS 0xffc30000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ + +#define CONFIG_PCI_PNP /* do pci plug-and-play */ + +#undef CONFIG_EEPRO100 +#undef CONFIG_TULIP +#undef CONFIG_RTL8139 + +#ifdef CONFIG_RTL8139 +/* This macro is used by RTL8139 but not defined in PPC architecture */ +#define KSEG1ADDR(x) (x) +#define _IO_BASE 0x00000000 +#endif + + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_DOS_PARTITION + +#endif /* CONFIG_PCI */ + +#if defined(CONFIG_TSEC_ENET) +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ +#define CONFIG_TSEC1 1 +#define CONFIG_TSEC1_NAME "eTSEC1" +#define CONFIG_TSEC2 1 +#define CONFIG_TSEC2_NAME "eTSEC2" +#define CONFIG_TSEC3 1 +#define CONFIG_TSEC3_NAME "eTSEC3" + +#define TSEC1_PHY_ADDR 0 +#define TSEC2_PHY_ADDR 2 +#define TSEC3_PHY_ADDR 1 + +#undef CONFIG_VSC7385_ENET + +#define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +#define TSEC1_PHYIDX 0 +#define TSEC2_PHYIDX 0 +#define TSEC3_PHYIDX 0 + +#define CONFIG_ETHPRIME "eTSEC1" + +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ + +#endif /* CONFIG_TSEC_ENET */ + +/* + * Environment + */ +#if defined(CONFIG_RAMBOOT_SDCARD) + #define CONFIG_ENV_IS_IN_MMC 1 + #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_SYS_MMC_ENV_DEV 0 +#elif defined(CONFIG_RAMBOOT_SPIFLASH) + #define CONFIG_ENV_IS_IN_SPI_FLASH + #define CONFIG_ENV_SPI_BUS 0 + #define CONFIG_ENV_SPI_CS 0 + #define CONFIG_ENV_SPI_MAX_HZ 10000000 + #define CONFIG_ENV_SPI_MODE 0 + #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ + #define CONFIG_ENV_SECT_SIZE 0x10000 + #define CONFIG_ENV_SIZE 0x2000 +#endif + +#define CONFIG_LOADS_ECHO 1 +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_REGINFO + +#if defined(CONFIG_PCI) +#define CONFIG_CMD_NET +#define CONFIG_CMD_PCI +#endif + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +#define CONFIG_MMC 1 + +#ifdef CONFIG_MMC +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ +#define CONFIG_CMD_MMC +#define CONFIG_DOS_PARTITION +#define CONFIG_FSL_ESDHC +#define CONFIG_GENERIC_MMC +#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR +#define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT +#endif /* CONFIG_MMC */ + +#define CONFIG_USB_EHCI + +#ifdef CONFIG_USB_EHCI +#define CONFIG_CMD_USB +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_USB_EHCI_FSL +#define CONFIG_USB_STORAGE +#define CONFIG_HAS_FSL_DR_USB +#endif + +#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +/* Misc Extra Settings */ +#define CONFIG_SYS_64BIT_VSPRINTF 1 +#define CONFIG_SYS_64BIT_STRTOUL 1 +#define CONFIG_CMD_DHCP 1 + +#define CONFIG_CMD_DATE 1 +#define CONFIG_RTC_M41T62 1 +#define CONFIG_SYS_RTC_BUS_NUM 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) + /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms tick */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) +#define CONFIG_SYS_BOOTM_LEN (64 << 20) + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ + +/* The mac addresses for all ethernet interface */ +#if defined(CONFIG_TSEC_ENET) +#define CONFIG_HAS_ETH0 +#define CONFIG_HAS_ETH1 +#define CONFIG_HAS_ETH2 +#define CONFIG_HAS_ETH3 +#endif + +#define CONFIG_HOSTNAME unknown +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH u-boot.bin + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs */ + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootcmd=run sdboot\0" \ + "sdboot=setenv bootargs root=/dev/mmcblk0p2 rw " \ + "rootdelay=$rootdelaysecond console=$consoledev,$baudrate "\ + "$othbootargs; mmcinfo; " \ + "ext2load mmc 0:2 $loadaddr /boot/$bootfile; " \ + "ext2load mmc 0:2 $fdtaddr /boot/$fdtfile; " \ + "bootm $loadaddr - $fdtaddr\0" \ + "sdfatboot=setenv bootargs root=/dev/ram rw " \ + "rootdelay=$rootdelaysecond console=$consoledev,$baudrate "\ + "$othbootargs; mmcinfo; " \ + "fatload mmc 0:1 $loadaddr $bootfile; " \ + "fatload mmc 0:1 $fdtaddr $fdtfile; " \ + "fatload mmc 0:1 $ramdiskaddr $ramdiskfile; " \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0" \ + "usbboot=setenv bootargs root=/dev/sda1 rw " \ + "rootdelay=$rootdelaysecond console=$consoledev,$baudrate "\ + "$othbootargs; " \ + "usb start; " \ + "ext2load usb 0:1 $loadaddr /boot/$bootfile; " \ + "ext2load usb 0:1 $fdtaddr /boot/$fdtfile; " \ + "bootm $loadaddr - $fdtaddr\0" \ + "usbfatboot=setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs; " \ + "usb start; " \ + "fatload usb 0:2 $loadaddr $bootfile; " \ + "fatload usb 0:2 $fdtaddr $fdtfile; " \ + "fatload usb 0:2 $ramdiskaddr $ramdiskfile; " \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0" \ + "usbext2boot=setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs; " \ + "usb start; " \ + "ext2load usb 0:4 $loadaddr $bootfile; " \ + "ext2load usb 0:4 $fdtaddr $fdtfile; " \ + "ext2load usb 0:4 $ramdiskaddr $ramdiskfile; " \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0" \ + "upgradespi=sf probe 0; " \ + "setenv startaddr 0; " \ + "setenv erasesize a0000; " \ + "tftp 1000000 $tftppath/$uboot_spi; " \ + "sf erase $startaddr $erasesize; " \ + "sf write 1000000 $startaddr $filesize; " \ + "sf erase 100000 120000\0" \ + "clearspienv=sf probe 0;sf erase 100000 20000\0" \ + "othbootargs=ramdisk_size=700000 cache-sram-size=0x10000\0" \ + "netdev=eth0\0" \ + "rootdelaysecond=15\0" \ + "uboot_nor=u-boot-nor.bin\0" \ + "uboot_spi=u-boot-p2020.spi\0" \ + "uboot_sd=u-boot-p2020.bin\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=rootfs-dev.ext2.img\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=uImage-2.6.32-p2020.dtb\0" \ + "tftppath=p2020\0" + +#define CONFIG_HDBOOT \ + "setenv bootargs root=/dev/$bdev rw rootdelay=30 " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "usb start;" \ + "ext2load usb 0:1 $loadaddr /boot/$bootfile;" \ + "ext2load usb 0:1 $fdtaddr /boot/$fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off "\ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $tftppath/$bootfile;" \ + "tftp $fdtaddr $tftppath/$fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $tftppath/$ramdiskfile;" \ + "tftp $loadaddr $tftppath/$bootfile;" \ + "tftp $fdtaddr $tftppath/$fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_HDBOOT + +#endif /* __CONFIG_H */
Ira W. Snyder
