[U-Boot] [PATCH v2 1/2] Revert "configs: Remove am335x_boneblack_defconfig"
Commit 8fa7f65dd02c ("configs: Remove am335x_boneblack_defconfig") removes defconfig for BeagleBone Black board, and it's advised to use am335x_evm_defconfig for all AM335x boards. But it's impossible to store environment in eMMC with am335x_evm_defconfig without modifications (NAND must be disabled, MMC enabled, etc). This is inconvenient for user to do such modifications via menuconfig (only developer knows what should be done). Furthermore, enabling MMC options in am335x_evm_defconfig leads to wrong pin-muxing scheme in board/ti/am335x/mux.c, because both NAND and MMC options are enabled in the config, so that pins are muxed for BBB with NAND cape, which in turn leads to non-functioning eMMC. There is no way to make the single defconfig working for both eMMC and NAND use-cases, because we can't figure out in run-time which board configuration is used by user (EVM, BBB, or BBB with NAND cape). Hence we rely on CONFIG options to figure out which configuration is used. Because of this we can't use single defconfig for AM335x EVM and BBB.
All that said, let's bring back am335x_boneblack_defconfig, because right now users are not able to use U-Boot for BBB. Further patch will update this defconfig by enabling Driver Model and pulling some other useful options from am335x_evm_defconfig.
Fixes: 8fa7f65dd02c ("configs: Remove am335x_boneblack_defconfig") Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- Changes in v2: - improve commit message by saying explicitly about eMMC env
configs/am335x_boneblack_defconfig | 50 ++++++++++++++++++++++++++++++ 1 file changed, 50 insertions(+) create mode 100644 configs/am335x_boneblack_defconfig
diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig new file mode 100644 index 0000000000..439d0cba05 --- /dev/null +++ b/configs/am335x_boneblack_defconfig @@ -0,0 +1,50 @@ +CONFIG_ARM=y +CONFIG_ARCH_OMAP2PLUS=y +CONFIG_TI_COMMON_CMD_OPTIONS=y +CONFIG_AM33XX=y +CONFIG_SPL=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" +CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_VERSION_VARIABLE=y +CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_MUSB_NEW_SUPPORT=y +# CONFIG_SPL_NAND_SUPPORT is not set +CONFIG_SPL_OS_BOOT=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_SPL=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_MMC_OMAP_HS=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_MII=y +CONFIG_DRIVER_TI_CPSW=y +CONFIG_SPI=y +CONFIG_OMAP3_SPI=y +CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y +CONFIG_USB_MUSB_GADGET=y +CONFIG_USB_MUSB_DSPS=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y +CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" +CONFIG_LZO=y +CONFIG_OF_LIBFDT=y
Old am335x_boneblack defconfig doesn't have Driver Model enabled. Pull DM options from am335x_evm, along with some others, like ones for shrinking SPL, making am335x_boneblack defconfig as close as possible to am335x_evm.
Main differences betweend am335x_boneblack and am335x_evm defconfigs: - eMMC related options are enabled - NAND related options are disabled - keep watchdog disabled for now, as it doesn't work properly (needs to be enabled once it's fixed) - keep log level at default value (4), as it's useful to see some errors, like "No USB device found"
Fixes: 8fa7f65dd02c ("configs: Remove am335x_boneblack_defconfig") Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- Changes in v2: - improve commit message - keep log level at default value (4)
configs/am335x_boneblack_defconfig | 36 ++++++++++++++++++++++++------ 1 file changed, 29 insertions(+), 7 deletions(-)
diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 439d0cba05..b8defc9d51 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -4,23 +4,32 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_AM33XX=y CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_FIT_IMAGE_TINY=y +CONFIG_SPL_ETH_SUPPORT=y +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MUSB_NEW_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set +CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET_VCI_STRING="AM335x U-Boot SPL" CONFIG_SPL_OS_BOOT=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_USB_ETHER=y CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="am335x-boneblack" +CONFIG_OF_LIST="am335x-boneblack am335x-bonegreen" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DFU_TFTP=y CONFIG_DFU_MMC=y @@ -29,22 +38,35 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_DSPS=y +CONFIG_USB_MUSB_TI=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y -CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" +# CONFIG_SPL_WDT is not set +CONFIG_DYNAMIC_CRC_TABLE=y +CONFIG_RSA=y CONFIG_LZO=y -CONFIG_OF_LIBFDT=y +# CONFIG_OF_LIBFDT_OVERLAY is not set
Hi Tom,
On Thu, Sep 12, 2019 at 8:50 PM Sam Protsenko semen.protsenko@linaro.org wrote:
As stated in the commit message, we can't use single defconfig for all AM335x boards. So I'm thinking, maybe it's a good idea to: 1. Rename am335x_evm_defconfig -> am335x_nand_defconfig 2. Rename am335x_boneblack_defconfig -> am335x_emmc_defconfig
because "evm" word only confuses the user, and we actually need multiple defconfigs for AM335x to cover all board configurations (eMMC/NAND/NOR).
What do you think?
Changes in v2:
+CONFIG_OF_LIBFDT=y
2.23.0
I did not understand why users are not able to use BBB using am335x_evm_defconfig? ENV is stored in FAT and is working properly. What is wrong with that? Is it that eMMC boot is failing?
Thanks and regards, Lokesh
Changes in v2:
Hi Lokesh,
The eMMC boot works. But with that config it's impossible to store ENV on eMMC. Some users prefer to use eMMC exclusively, with SD card removed. In that case the user won't be able to store U-Boot environment on eMMC. Furthermore, when enabling environment in eMMC by next two options:
1. CONFIG_ENV_IS_IN_MMC=y 2. CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT"
the boot will be broken due to wrong pin muxing when both CONFIG_NAND and CONFIG_EMMC_BOOT are enabled. And we can't fix pin muxing, because it relies on compile-time configuration, because we don't have means to figure out configurations like BBB + NAND cape in run-time. So the only way I see to provide a way to store ENV on eMMC is to keep separate config.
I agree that commit message should be fixed. Also, maybe we should rename configs like this:
- am335x_evm_defconfig -> am335x_nand_defconfig - am335x_boneblack_defconfig -> am335x_emmc_defconfig
Do you think it's correct way to do so? Or some better way exists?
Thanks!
Changes in v2:
On 16/09/19 4:53 PM, Sam Protsenko wrote:
Hi Lokesh,
Hmm..Creating a defconfig for supporting separate env storage doesn't sound right. U-boot has support for storing env in multiple places. Any chance you tried that option?
next two options:>
- CONFIG_ENV_IS_IN_MMC=y
- CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT"
- am335x_boneblack_defconfig -> am335x_emmc_defconfig> Do you think it's correct way to do so? Or some better way exists?
Thanks!
Changes in v2:
Hi Lokesh,
I tried to enable both CONFIG_ENV_IS_IN_MMC=y and CONFIG_ENV_IS_NAND=y, that's the case I'm describing above, hope that's what you mean by multiple env? The issue is pinmuxing, as I said, which can't be done differently (at least I don't see such options), which leads to broken pinmux configuration when enabling CONFIG_ENV_IS_IN_MMC=y along with CONFIG_ENV_IS_IN_NAND=y.
So basically I want the defconfig which I can use "as is" for BeagleBone Black with eMMC and SD card. am335x_boneblack_defconfig was such defconfig. With am335x_evm_defconfig I wasn't able to make U-Boot store env on eMMC (without disabling NAND).
Do you see by chance some better way around, other than creating new defconfig? Maybe pinmuxing can be done in other way, like probing current NAND/NOR/MMC configuration dynamically (can be hard for cases like BBB with NAND cape connected)?
Thanks!
next two options:>
Thanks!
Changes in v2:
Lokesh Vutla
Sam Protsenko
