[PATCH v2 0/2] doc: usage: man-page for ums command
V2 for [1], after Heinrich remarks.
[1] doc: usage: man-page for ums command http://patchwork.ozlabs.org/project/uboot/list/?series=246862&archive=bo...
Changes in v2: - NEW: Add dependency for ums command - clarify description - add reference to <partitions> and align parameter name - correct information for partition = 0 (expose all partitions) - update dependency
Patrick Delaunay (2): cmd: Add dependency for ums command doc: usage: man-page for ums command
cmd/Kconfig | 5 +++- doc/usage/index.rst | 1 + doc/usage/ums.rst | 57 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 62 insertions(+), 1 deletion(-) create mode 100644 doc/usage/ums.rst
Add the missing dependency for the command ums: - CONFIG_BLK: call of blk_* functions in usb_mass_storage.c - CONFIG_USB_GADGET: required to select CONFIG_USB_FUNCTION_MASS_STORAGE
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
cmd/Kconfig | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index f962bb7141..a9fb4eead2 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1346,8 +1346,11 @@ config CMD_ROCKUSB config CMD_USB_MASS_STORAGE bool "UMS usb mass storage" select USB_FUNCTION_MASS_STORAGE + depends on BLK && USB_GADGET help - USB mass storage support + Enables the command "ums" and the USB mass storage support to the + export a block device: U-Boot, the USB device, acts as a simple + external hard drive plugged on the host USB port.
config CMD_PVBLOCK bool "Xen para-virtualized block device"
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Changes in v2:
- depends on BLK && USB_GADGET help
Provide a man-page for the ums command - USB Mass Storage.
Changes in v2: - clarify description - add reference to <partitions> and align parameter name - correct information for partition = 0 (expose all partitions) - update dependency
doc/usage/index.rst | 1 + doc/usage/ums.rst | 57 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 58 insertions(+) create mode 100644 doc/usage/ums.rst
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 41b247bc62..1bab6ae3e9 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -43,3 +43,4 @@ Shell commands scp03 size true + ums diff --git a/doc/usage/ums.rst b/doc/usage/ums.rst new file mode 100644 index 0000000000..19d2ebb4a6 --- /dev/null +++ b/doc/usage/ums.rst @@ -0,0 +1,57 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +ums command +=========== + +Synopsis +-------- + +:: + + <dev> [<interface>] <devnum[:partnum]> + +Description +----------- + +Use the USB Mass Storage class (also known as UMS) to make accessible an U-Boot +block device (fully or with :ref:`U-Boot's partition syntax <partitions>`) +to a USB host and to enable file transfers. U-Boot, the USB device, acts as a +simple external hard drive plugged on the host USB port. + +This command "ums" stays in the USB's treatment loop until user enters Ctrl-C. + +dev + USB gadget device number + +interface + interface for accessing the block device (mmc, sata, scsi, usb, ....) + defaults is "mmc" + +devnum + device number for selected interface + +partnum + partition number or 0 to expose all partitions, defaults to 0 + +Example +------- + +:: + + => ums 0 mmc 0 + => ums 0 usb 1:2 + +Configuration +------------- + +The ums command is only available if CONFIG_CMD_USB_MASS_STORAGE=y +and depends on CONFIG_USB_USB_GADGET and CONFIG_BLK. + +Return value +------------ + +The return value $? is set to 0 (true) when the USB stack was successfully +started and interrupted, with Ctrl-C or after USB cable issue (detection +timeout or cable removal). + +If an error occurs, the return value $? is set to 1 (false).
Changes in v2:
clarify description
update dependency
- ums
+Synopsis +--------
- <dev> [<interface>] <devnum[:partnum]>
ums missing. I can add it when merging.
Otherwise
+dev
- USB gadget device number
+interface
- interface for accessing the block device (mmc, sata, scsi, usb, ....)
- defaults is "mmc"
+devnum
- device number for selected interface
+partnum
- partition number or 0 to expose all partitions, defaults to 0
+Example +-------
- => ums 0 mmc 0
- => ums 0 usb 1:2
Patrick Delaunay
