[PATCH 1/2] mmc: renesas-sdhi: Always configure default SDnH clock rate to 800 MHz
The prior stage bootloader might have left the SDnCKCR register in completely arbitrary state before passing control to U-Boot, which includes the register being populated with incorrect values. Currently the SDHI driver will attempt to use clock framework to configure SDn clock, which may fail in case SDnCKCR contains invalid values for the SDnH clock, because the clock framework would not be able to determine SDnH clock rate and would get -EINVAL instead, which in turn would not allow the clock framework to determine the correct SDn clock divider ratio.
This failure occurs specifically in case SDnCKCR reads back 0x209 .
Correct the problem by first setting default SDnH clock rate to 800 MHz, thus assuring the SDnCKCR SDnH bits are correct, and only afterward set up the SDn clock rate to default 200 MHz.
Note that the SDHI driver may reconfigure SDnH clock later based on IOS settings obtained from the attached card, the 800 MHz set up here is only the default value.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Peng Fan peng.fan@nxp.com --- drivers/mmc/renesas-sdhi.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 4a1accebfcb..2473261f3c4 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -977,8 +977,16 @@ static int renesas_sdhi_probe(struct udevice *dev)
/* optional SDnH clock */ ret = clk_get_by_name(dev, "clkh", &priv->clkh); - if (ret < 0) + if (ret < 0) { dev_dbg(dev, "failed to get clkh\n"); + } else { + ret = clk_set_rate(&priv->clkh, 800000000); + if (ret < 0) { + dev_err(dev, "failed to set rate for SDnH clock\n"); + clk_free(&priv->clk); + return ret; + } + }
/* set to max rate */ ret = clk_set_rate(&priv->clk, 200000000);
In case one of the calls in probe fail, trigger a fail path and undo all the steps done in probe until the point of failure. The current implementation failed to stop controller clock and free claimed clock, so fix that. Furthermore, print return code in error prints for easier debugging.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Peng Fan peng.fan@nxp.com --- drivers/mmc/renesas-sdhi.c | 26 +++++++++++++++++--------- 1 file changed, 17 insertions(+), 9 deletions(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 2473261f3c4..34119f949aa 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -982,37 +982,45 @@ static int renesas_sdhi_probe(struct udevice *dev) } else { ret = clk_set_rate(&priv->clkh, 800000000); if (ret < 0) { - dev_err(dev, "failed to set rate for SDnH clock\n"); - clk_free(&priv->clk); - return ret; + dev_err(dev, "failed to set rate for SDnH clock (%d)\n", ret); + goto err_clk; } }
/* set to max rate */ ret = clk_set_rate(&priv->clk, 200000000); if (ret < 0) { - dev_err(dev, "failed to set rate for host clock\n"); - clk_free(&priv->clk); - return ret; + dev_err(dev, "failed to set rate for SDn clock (%d)\n", ret); + goto err_clkh; }
ret = clk_enable(&priv->clk); if (ret) { - dev_err(dev, "failed to enable host clock\n"); - return ret; + dev_err(dev, "failed to enable SDn clock (%d)\n", ret); + goto err_clkh; }
priv->quirks = quirks; ret = tmio_sd_probe(dev, quirks); + if (ret) + goto err_tmio_probe;
renesas_sdhi_filter_caps(dev);
#if CONFIG_IS_ENABLED(MMC_UHS_SUPPORT) || \ CONFIG_IS_ENABLED(MMC_HS200_SUPPORT) || \ CONFIG_IS_ENABLED(MMC_HS400_SUPPORT) - if (!ret && (priv->caps & TMIO_SD_CAP_RCAR_UHS)) + if (priv->caps & TMIO_SD_CAP_RCAR_UHS) renesas_sdhi_reset_tuning(priv); #endif + return 0; + +err_tmio_probe: + clk_disable(&priv->clk); +err_clkh: + clk_free(&priv->clkh); +err_clk: + clk_free(&priv->clk); return ret; }
