[PATCH] tools: gitignore: Fix tools/generated path
'git status' shows 'tools/generated/' after running the build, which is wrong. The corresponding .gitignore rule was already added in commit c623642d29be ("Adjust gitignore for tools/generated/"), but because of superfluous 'tools/' part it wasn't in effect. Remove incorrect 'tools/' part to fix it.
While at it, remove tools/ path incorrectly added to the top-level .gitignore in commit 801c482207c7 (".gitignore: ignore misc include, simple-bin, and tools/generated build artifacts"), as it's required in the comment on the top of .gitignore:
# NOTE! Don't add files that are generated in specific # subdirectories here. Add them in the ".gitignore" file # in that subdirectory instead.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org Fixes: c623642d29be ("Adjust gitignore for tools/generated/") Fixes: 801c482207c7 (".gitignore: ignore misc include, simple-bin, and tools/generated build artifacts") --- .gitignore | 1 - tools/.gitignore | 2 +- 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/.gitignore b/.gitignore index a1a79e92feef..330148119264 100644 --- a/.gitignore +++ b/.gitignore @@ -61,7 +61,6 @@ fit-dtb.blob* # Generated files # /spl/ -/tools/generated/ /tpl/ /defconfig
diff --git a/tools/.gitignore b/tools/.gitignore index 941d38de212d..0108c567309b 100644 --- a/tools/.gitignore +++ b/tools/.gitignore @@ -34,7 +34,7 @@ /relocate-rela /spl_size_limit /sunxi-spl-image-builder -/tools/generated/**/*.c +/generated/**/*.c /update_octeon_header /version.h /xway-swap-bytes
Sam Protsenko
