[PATCH] rockchip: rk3566-pinetab2: Migrate to OF_UPSTREAM
The device tree for Pine64 PineTab2 has been merged into dts/upstream with devicetree-rebasing v6.10-dts, migrate board to OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3566-pinetab2-v0.1.dts | 28 - arch/arm/dts/rk3566-pinetab2-v2.0.dts | 48 -- arch/arm/dts/rk3566-pinetab2.dtsi | 943 -------------------------- configs/pinetab2-rk3566_defconfig | 5 +- 4 files changed, 2 insertions(+), 1022 deletions(-) delete mode 100644 arch/arm/dts/rk3566-pinetab2-v0.1.dts delete mode 100644 arch/arm/dts/rk3566-pinetab2-v2.0.dts delete mode 100644 arch/arm/dts/rk3566-pinetab2.dtsi
diff --git a/arch/arm/dts/rk3566-pinetab2-v0.1.dts b/arch/arm/dts/rk3566-pinetab2-v0.1.dts deleted file mode 100644 index 5fe6ca5da9d3..000000000000 --- a/arch/arm/dts/rk3566-pinetab2-v0.1.dts +++ /dev/null @@ -1,28 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; - -#include "rk3566-pinetab2.dtsi" - -/ { - model = "Pine64 PineTab2 v0.1"; - compatible = "pine64,pinetab2-v0.1", "pine64,pinetab2", "rockchip,rk3566"; -}; - -&lcd { - reset-gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_pwren_h &lcd0_rst_l>; -}; - -&pinctrl { - lcd0 { - lcd0_rst_l: lcd0-rst-l { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdmmc1 { - vmmc-supply = <&vcc3v3_sys>; -}; diff --git a/arch/arm/dts/rk3566-pinetab2-v2.0.dts b/arch/arm/dts/rk3566-pinetab2-v2.0.dts deleted file mode 100644 index 9349541cbbd0..000000000000 --- a/arch/arm/dts/rk3566-pinetab2-v2.0.dts +++ /dev/null @@ -1,48 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; - -#include "rk3566-pinetab2.dtsi" - -/ { - model = "Pine64 PineTab2 v2.0"; - compatible = "pine64,pinetab2-v2.0", "pine64,pinetab2", "rockchip,rk3566"; -}; - -&gpio_keys { - pinctrl-0 = <&kb_id_det>, <&hall_int_l>; - - event-hall-sensor { - debounce-interval = <20>; - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; - label = "Hall Sensor"; - linux,code = <SW_LID>; - linux,input-type = <EV_SW>; - wakeup-event-action = <EV_ACT_DEASSERTED>; - wakeup-source; - }; -}; - -&lcd { - reset-gpios = <&gpio0 RK_PC6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_pwren_h &lcd0_rst_l>; -}; - -&pinctrl { - lcd0 { - lcd0_rst_l: lcd0-rst-l { - rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - hall { - hall_int_l: hall-int-l { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdmmc1 { - vmmc-supply = <&vcc_sys>; -}; diff --git a/arch/arm/dts/rk3566-pinetab2.dtsi b/arch/arm/dts/rk3566-pinetab2.dtsi deleted file mode 100644 index db40281eafbe..000000000000 --- a/arch/arm/dts/rk3566-pinetab2.dtsi +++ /dev/null @@ -1,943 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/gpio-keys.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include <dt-bindings/usb/pd.h> -#include "rk3566.dtsi" - -/ { - chassis-type = "tablet"; - - aliases { - mmc0 = &sdhci; - mmc1 = &sdmmc0; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 0>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1800000>; - poll-interval = <25>; - - button-vol-up { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - press-threshold-microvolt = <297500>; - }; - - button-vol-down { - label = "Volume Down"; - linux,code = <KEY_VOLUMEDOWN>; - press-threshold-microvolt = <1750>; - }; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - pwms = <&pwm4 0 25000 0>; - brightness-levels = <20 220>; - num-interpolated-steps = <200>; - default-brightness-level = <100>; - power-supply = <&vcc_sys>; - }; - - battery: battery { - compatible = "simple-battery"; - charge-full-design-microamp-hours = <6000000>; - charge-term-current-microamp = <300000>; - constant-charge-current-max-microamp = <2000000>; - constant-charge-voltage-max-microvolt = <4300000>; - voltage-max-design-microvolt = <4350000>; - voltage-min-design-microvolt = <3400000>; - - ocv-capacity-celsius = <20>; - ocv-capacity-table-0 = <4322000 100>, <4250000 95>, <4192000 90>, <4136000 85>, - <4080000 80>, <4022000 75>, <3972000 70>, <3928000 65>, - <3885000 60>, <3833000 55>, <3798000 50>, <3780000 45>, - <3776000 40>, <3773000 35>, <3755000 30>, <3706000 25>, - <3640000 20>, <3589000 15>, <3535000 10>, <3492000 5>, - <3400000 0>; - }; - - gpio_keys: gpio-keys { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&kb_id_det>; - - tablet-mode-switch { - debounce-interval = <20>; - gpios = <&gpio4 RK_PA4 GPIO_ACTIVE_HIGH>; - label = "Tablet Mode"; - linux,input-type = <EV_SW>; - linux,code = <SW_TABLET_MODE>; - }; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "d"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - led-0 { - compatible = "regulator-led"; - vled-supply = <&vcc5v0_flashled>; - color = <LED_COLOR_ID_WHITE>; - function = LED_FUNCTION_FLASH; - }; - - rk817-sound { - compatible = "simple-audio-card"; - pinctrl-names = "default"; - pinctrl-0 = <&hp_det_l>; - simple-audio-card,format = "i2s"; - simple-audio-card,name = "rk817_ext"; - simple-audio-card,mclk-fs = <256>; - - simple-audio-card,widgets = - "Microphone", "Mic Jack", - "Headphone", "Headphones", - "Speaker", "Internal Speakers"; - - simple-audio-card,routing = - "MICR", "Mic Jack", - "Headphones", "HPOL", - "Headphones", "HPOR", - "Internal Speakers", "Speaker Amplifier OUTL", - "Internal Speakers", "Speaker Amplifier OUTR", - "Speaker Amplifier INL", "HPOL", - "Speaker Amplifier INR", "HPOR"; - simple-audio-card,hp-det-gpio = <&gpio4 RK_PC6 GPIO_ACTIVE_LOW>; - simple-audio-card,aux-devs = <&speaker_amp>; - simple-audio-card,pin-switches = "Internal Speakers"; - - simple-audio-card,cpu { - sound-dai = <&i2s1_8ch>; - }; - - simple-audio-card,codec { - sound-dai = <&rk817>; - }; - }; - - speaker_amp: speaker-amplifier { - compatible = "simple-audio-amplifier"; - pinctrl-names = "default"; - pinctrl-0 = <&spk_ctl>; - enable-gpios = <&gpio4 RK_PC2 GPIO_ACTIVE_HIGH>; - sound-name-prefix = "Speaker Amplifier"; - VCC-supply = <&vcc_bat>; - }; - - vcc_3v3: vcc-3v3-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc3v3_minipcie: vcc3v3-minipcie-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PC3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_pwren_h>; - regulator-name = "vcc3v3_minipcie"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_sys>; - }; - - vcc3v3_sd: vcc3v3-sd-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwren_l>; - regulator-name = "vcc3v3_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc5v0_flashled: vcc5v0-flashled-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PA5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&flash_led_en_h>; - regulator-name = "vcc5v0_flashled"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v_midu>; - }; - - vcc5v0_usb_host0: vcc5v0-usb-host0-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PC4 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usb_host_pwren1_h>; - regulator-name = "vcc5v0_usb_host0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v_midu>; - }; - - vcc5v0_usb_host2: vcc5v0-usb-host2-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PC5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usb_host_pwren2_h>; - regulator-name = "vcc5v0_usb_host2"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v_midu>; - }; - - vcc_bat: vcc-bat-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_bat"; - regulator-always-on; - regulator-boot-on; - }; - - vcc_sys: vcc-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_bat>; - }; - - vdd1v2_dvp: vdd1v2-dvp-regulator { - compatible = "regulator-fixed"; - regulator-name = "vdd1v2_dvp"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - vin-supply = <&vcc_3v3>; - }; -}; - -&combphy1 { - status = "okay"; -}; - -&combphy2 { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&cru { - assigned-clocks = <&pmucru CLK_RTC_32K>, <&cru PLL_GPLL>, - <&pmucru PLL_PPLL>, <&cru PLL_VPLL>; - assigned-clock-rates = <32768>, <1200000000>, <200000000>, <500000000>; - assigned-clock-parents = <&pmucru CLK_RTC32K_FRAC>; -}; - -&csi_dphy { - status = "okay"; -}; - -&dsi0 { - status = "okay"; - clock-master; - #address-cells = <1>; - #size-cells = <0>; - - lcd: panel@0 { - compatible = "boe,th101mb31ig002-28a"; - reg = <0>; - backlight = <&backlight>; - enable-gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>; - rotation = <90>; - power-supply = <&vcc_3v3>; - - port@0 { - panel_in_dsi: endpoint@0 { - remote-endpoint = <&dsi0_out_con>; - }; - }; - }; -}; - -&dsi0_in { - dsi0_in_vp1: endpoint { - remote-endpoint = <&vp1_out_dsi0>; - }; -}; - -&dsi0_out { - dsi0_out_con: endpoint { - remote-endpoint = <&panel_in_dsi>; - }; -}; - -&dsi_dphy0 { - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu_npu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda_0v9_p>; - avdd-1v8-supply = <&vcc_1v8>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk817: pmic@20 { - compatible = "rockchip,rk817"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - assigned-clocks = <&cru I2S1_MCLKOUT_TX>; - assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; - clock-names = "mclk"; - clocks = <&cru I2S1_MCLKOUT_TX>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - #clock-cells = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>, <&i2s1m0_mclk>; - rockchip,system-power-controller; - #sound-dai-cells = <0>; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_sys>; - vcc9-supply = <&vcc5v_midu>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-name = "vdd_logic"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu_npu: DCDC_REG2 { - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-name = "vdd_gpu_npu"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-name = "vcc_ddr"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc3v3_sys: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-initial-mode = <0x2>; - regulator-name = "vcc3v3_sys"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcca1v8_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdda_0v9_p: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vdda_0v9_p"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vdda0v9_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_acodec"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc3v3_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_1v8"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_dvp: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc1v8_dvp"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc2v8_dvp: LDO_REG9 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-name = "vcc2v8_dvp"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc5v_midu: BOOST { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-name = "boost"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vbus: OTG_SWITCH { - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-name = "otg_switch"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - - charger { - monitored-battery = <&battery>; - rockchip,resistor-sense-micro-ohms = <10000>; - rockchip,sleep-enter-current-microamp = <300000>; - rockchip,sleep-filter-current-microamp = <100000>; - }; - }; -}; - -&i2c1 { - clock-frequency = <400000>; - status = "okay"; - - touchscreen@5d { - compatible = "goodix,gt911"; - reg = <0x5d>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PB0 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&tp_int_l_pmuio2>, <&tp_rst_l_pmuio2>; - AVDD28-supply = <&vcc3v3_pmu>; - VDDIO-supply = <&vcca1v8_pmu>; - irq-gpios = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>; - reset-gpios = <&gpio0 RK_PC2 GPIO_ACTIVE_HIGH>; - }; -}; - -&i2c2 { - clock-frequency = <400000>; - pinctrl-0 = <&i2c2m1_xfer>; - status = "okay"; - - vcm@c { - compatible = "dongwoon,dw9714"; - reg = <0x0c>; - vcc-supply = <&vcc1v8_dvp>; - }; - - camera@36 { - compatible = "ovti,ov5648"; - reg = <0x36>; - pinctrl-names = "default"; - pinctrl-0 = <&camerab_pdn_l &camerab_rst_l>; - - clocks = <&cru CLK_CIF_OUT>; - assigned-clocks = <&cru CLK_CIF_OUT>; - assigned-clock-rates = <24000000>; - - avdd-supply = <&vcc2v8_dvp>; - dvdd-supply = <&vdd1v2_dvp>; - dovdd-supply = <&vcc1v8_dvp>; - powerdown-gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_LOW>; - reset-gpios = <&gpio4 RK_PB1 GPIO_ACTIVE_LOW>; - - port { - endpoint { - data-lanes = <1 2>; - remote-endpoint = <0>; - link-frequencies = /bits/ 64 <210000000 168000000>; - }; - }; - }; -}; - -&i2c5 { - clock-frequency = <400000>; - status = "okay"; - - accelerometer@18 { - compatible = "silan,sc7a20"; - reg = <0x18>; - interrupt-parent = <&gpio3>; - interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&gsensor_int_l>; - st,drdy-int-pin = <1>; - vdd-supply = <&vcc_1v8>; - vddio-supply = <&vcc_1v8>; - mount-matrix = "1", "0", "0", - "0", "0", "1", - "0", "1", "0"; - }; -}; - -&i2s0_8ch { - status = "okay"; -}; - -&i2s1_8ch { - pinctrl-names = "default"; - pinctrl-0 = <&i2s1m0_sclktx - &i2s1m0_lrcktx - &i2s1m0_sdi0 - &i2s1m0_sdo0>; - rockchip,trcm-sync-tx-only; - status = "okay"; -}; - -&pcie2x1 { - pinctrl-names = "default"; - pinctrl-0 = <&pcie_reset_h>; - reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_minipcie>; - status = "okay"; -}; - -&pinctrl { - camerab { - camerab_pdn_l: camerab-pdn-l { - rockchip,pins = <4 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - camerab_rst_l: camerab-rst-l { - rockchip,pins = <4 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - cameraf { - cameraf_pdn_l: cameraf-pdn-l { - rockchip,pins = <4 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - cameraf_rst_l: cameraf-rst-l { - rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - flash { - flash_led_en_h: flash-led-en-h { - rockchip,pins = <4 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - fspi { - fspi_dual_io_pins: fspi-dual-io-pins { - rockchip,pins = - /* fspi_clk */ - <1 RK_PD0 1 &pcfg_pull_none>, - /* fspi_cs0n */ - <1 RK_PD3 1 &pcfg_pull_none>, - /* fspi_d0 */ - <1 RK_PD1 1 &pcfg_pull_none>, - /* fspi_d1 */ - <1 RK_PD2 1 &pcfg_pull_none>; - }; - }; - - gsensor { - gsensor_int_l: gsensor-int-l { - rockchip,pins = <3 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - kb { - kb_id_det: kb-id-det { - rockchip,pins = <4 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lcd { - lcd_pwren_h: lcd-pwren-h { - rockchip,pins = <0 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_pwren_h: pcie-pwren-h { - rockchip,pins = <4 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_reset_h: pcie-reset-h { - rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdmmc { - sdmmc_pwren_l: sdmmc-pwren-l { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sound { - hp_det_l: hp-det-l { - rockchip,pins = <4 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - spk_ctl: spk-ctl { - rockchip,pins = <4 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - tp { - tp_int_l_pmuio2: tp-int-l-pmuio2 { - rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - tp_rst_l_pmuio2: tp-rst-l-pmuio2 { - rockchip,pins = <0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - usbcc_int_l: usbcc-int-l { - rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - usb_host_pwren1_h: usb-host-pwren1-h { - rockchip,pins = <4 RK_PC4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - usb_host_pwren2_h: usb-host-pwren2-h { - rockchip,pins = <4 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - host_wake_wl: host-wake-wl { - rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wifi_wake_host_h: wifi-wake-host-h { - rockchip,pins = <0 RK_PC4 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcca1v8_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio2-supply = <&vcc_1v8>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_1v8>; - vccio6-supply = <&vcc1v8_dvp>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&pwm4 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - no-sdio; - no-sd; - non-removable; - max-frequency = <200000000>; - mmc-hs200-1_8v; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 - &emmc_clk - &emmc_cmd - &emmc_datastrobe - &emmc_rstnout>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdmmc0 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 - &sdmmc0_clk - &sdmmc0_cmd - &sdmmc0_det>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&sdmmc1 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc1_bus4 - &sdmmc1_cmd - &sdmmc1_clk>; - sd-uhs-sdr104; - vqmmc-supply = <&vcca1v8_pmu>; - status = "okay"; -}; - -&sfc { - pinctrl-names = "default"; - pinctrl-0 = <&fspi_dual_io_pins>; - status = "okay"; - #address-cells = <1>; - #size-cells = <0>; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <100000000>; - spi-rx-bus-width = <2>; - spi-tx-bus-width = <1>; - }; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host0_xhci { - status = "okay"; -}; - -&usb_host1_xhci { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb_host0>; - status = "okay"; -}; - -&usb2phy0_otg { - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&usb2phy1_otg { - phy-supply = <&vcc5v0_usb_host2>; - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; - -&vp1 { - vp1_out_dsi0: endpoint@ROCKCHIP_VOP2_EP_MIPI0 { - reg = <ROCKCHIP_VOP2_EP_MIPI0>; - remote-endpoint = <&dsi0_in_vp1>; - }; -}; diff --git a/configs/pinetab2-rk3566_defconfig b/configs/pinetab2-rk3566_defconfig index e46acf3a3b58..2d075d12174c 100644 --- a/configs/pinetab2-rk3566_defconfig +++ b/configs/pinetab2-rk3566_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SF_DEFAULT_MODE=0x1000 -CONFIG_DEFAULT_DEVICE_TREE="rk3566-pinetab2-v2.0" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-pinetab2-v2.0" CONFIG_ROCKCHIP_RK3568=y CONFIG_ROCKCHIP_RK8XX_DISABLE_BOOT_ON_POWERON=y CONFIG_ROCKCHIP_SPI_IMAGE=y @@ -47,8 +47,7 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -# CONFIG_OF_UPSTREAM is not set -CONFIG_OF_LIST="rk3566-pinetab2-v0.1 rk3566-pinetab2-v2.0" +CONFIG_OF_LIST="rockchip/rk3566-pinetab2-v0.1 rockchip/rk3566-pinetab2-v2.0" CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
-/dts-v1/;
-&lcd {
-&pinctrl {
- lcd0 {
-&sdmmc1 {
-/dts-v1/;
-&gpio_keys {
wakeup-source;
-&lcd {
-&pinctrl {
- lcd0 {
- hall {
-&sdmmc1 {
- aliases {
mmc0 = &sdhci;
mmc1 = &sdmmc0;
- chosen {
- adc-keys {
button-vol-up {
button-vol-down {
<3400000 0>;
- hdmi-connector {
type = "d";
port {
- led-0 {
- rk817-sound {
"MICR", "Mic Jack",
regulator-boot-on;
enable-active-high;
enable-active-high;
enable-active-high;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
-&combphy1 {
- status = "okay";
-&combphy2 {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&cru {
-&csi_dphy {
- status = "okay";
-&dsi0 {
- status = "okay";
- clock-master;
- lcd: panel@0 {
reg = <0>;
rotation = <90>;
port@0 {
-&dsi0_in {
-&dsi0_out {
-&dsi_dphy0 {
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x1c>;
regulator-boot-on;
- rk817: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: LDO_REG7 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc5v_midu: BOOST {
regulator-boot-on;
vbus: OTG_SWITCH {
charger {
-&i2c1 {
- status = "okay";
- touchscreen@5d {
reg = <0x5d>;
-&i2c2 {
- status = "okay";
- vcm@c {
reg = <0x0c>;
- camera@36 {
reg = <0x36>;
port {
endpoint {
data-lanes = <1 2>;
-&i2c5 {
- status = "okay";
reg = <0x18>;
"0", "0", "1",
"0", "1", "0";
-&i2s0_8ch {
- status = "okay";
-&i2s1_8ch {
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
- status = "okay";
-&pcie2x1 {
- status = "okay";
-&pinctrl {
- camerab {
- cameraf {
- flash {
- fspi {
rockchip,pins =
/* fspi_clk */
/* fspi_cs0n */
/* fspi_d0 */
/* fspi_d1 */
- gsensor {
- kb {
- lcd {
- pcie {
- pmic {
- sdmmc {
- sound {
spk_ctl: spk-ctl {
- tp {
- usb {
- wifi {
-&pmu_io_domains {
- status = "okay";
-&pwm4 {
- status = "okay";
-&saradc {
- status = "okay";
-&sdhci {
- bus-width = <8>;
- no-sdio;
- no-sd;
- non-removable;
- mmc-hs200-1_8v;
&emmc_clk
&emmc_cmd
&emmc_datastrobe
&emmc_rstnout>;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
&sdmmc0_clk
&sdmmc0_cmd
&sdmmc0_det>;
- sd-uhs-sdr104;
- status = "okay";
-&sdmmc1 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
&sdmmc1_cmd
&sdmmc1_clk>;
- sd-uhs-sdr104;
- status = "okay";
-&sfc {
- status = "okay";
- flash@0 {
reg = <0>;
-&tsadc {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&usb_host1_xhci {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_host {
- status = "okay";
-&usb2phy0_otg {
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
-&vp1 {
Jonas Karlman
Kever Yang
