[U-Boot] Pull request - arm/zynq v2
Hi Albert,
please pull these 3 zynq patches to your arm tree.
There is still pending the arm: lds: Remove libgcc eabi exception handling tables patch. Have you considered to also add it?
v2: - Changed email address, - There was incorrect rebase which I have fixed - correct sha1 now
Thanks. Michal
The following changes since commit a78dac79ede7fbb4c9e816abc879655540c3f076:
nds32: fix the missing COBJS-y change (2013-08-09 01:51:24 +0800)
git://www.denx.de/git/u-boot-microblaze.git zynq
for you to fetch changes up to 2d83d33a51926d6471eb9282d03d83783850d565:
zynq: Enable axi ethernet and emaclite driver initialization (2013-08-12 08:59:56 +0200)
---------------------------------------------------------------- Michal Simek (3): zynq: Add new ddrc driver for ECC support zynq: slcr: Wait 100ms till clk is properly setup zynq: Enable axi ethernet and emaclite driver initialization
arch/arm/cpu/armv7/zynq/Makefile | 1 + arch/arm/cpu/armv7/zynq/ddrc.c | 50 ++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/zynq/slcr.c | 2 +- arch/arm/include/asm/arch-zynq/hardware.h | 8 +++++ arch/arm/include/asm/arch-zynq/sys_proto.h | 1 + board/xilinx/zynq/board.c | 19 ++++++++++++ 6 files changed, 80 insertions(+), 1 deletion(-) create mode 100644 arch/arm/cpu/armv7/zynq/ddrc.c
Hi Michal,
On Mon, 12 Aug 2013 09:05:00 +0200, Michal Simek monstr@monstr.eu wrote:
Hi Albert,
v2:
Thanks. Michal
I cannot merge these three commits without merging a lot of nds32 stuff too, apparently, and I don't want to. If this stuff is not needed for the three commits, then please rebase them so that they don't pull anything else in.
Amicalement,
On Sat, Aug 17, 2013 at 05:42:22PM +0200, Albert ARIBAUD wrote:
Hi Michal,
Hi Albert,
v2:
Thanks. Michal
Alternatively, can I get a pull request for nds32? Thanks!
Albert ARIBAUD
Michal Simek
