[PULL] u-boot-atmel-fixes-2021.01-a
Hello Tom,
Please pull tag u-boot-atmel-fixes-2021.01-a , the first set of atmel fixes for 2021.01 cycle.
This specific feature set includes the patches for DT required to fix the warnings for newer DTC version (1.6.0+), i2c and spi bus unit address.
Thanks !
Eugen
The following changes since commit 81a659e10a10020cfb03abd4794103194add1f3a:
Prepare v2021.01-rc1 (2020-10-28 16:30:06 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-atmel.git tags/u-boot-atmel-fixes-2021.01-a
for you to fetch changes up to ef8f34aea56465e1584ab60b6ae3f3340aab55de:
ARM: dts: at91: sama5d3xmb_cmp: fix SPI bus unit address (2020-11-02 08:58:38 +0200)
---------------------------------------------------------------- First set of u-boot-atmel fixes for 2021.01 cycle
---------------------------------------------------------------- Eugen Hristev (9): ARM: dts: at91: vinco: fix I2C warning bus unit address ARM: dts: at91: at91sam9261ek: fix SPI unit address warning ARM: dts: at91: at91sam9g20-taurus: fix SPI bus unit address ARM: dts: at91: at91sam9g20ek_common: fix SPI bus unit address ARM: dts: at91: at91sam9g25ek: fix I2C bus unit address ARM: dts: at91: gurnard: fix SPI bus unit address ARM: dts: at91: sama5d3xmb: fix I2C bus unit address ARM: dts: at91: sam9260ek: fix SPI bus unit address ARM: dts: at91: sama5d3xmb_cmp: fix SPI bus unit address
arch/arm/dts/at91-vinco.dts | 2 +- arch/arm/dts/at91sam9260ek.dts | 2 +- arch/arm/dts/at91sam9261ek.dts | 2 +- arch/arm/dts/at91sam9g20-taurus.dts | 2 +- arch/arm/dts/at91sam9g20ek_common.dtsi | 2 +- arch/arm/dts/at91sam9g25ek.dts | 2 +- arch/arm/dts/at91sam9g45-gurnard.dts | 2 +- arch/arm/dts/sama5d3xmb.dtsi | 2 +- arch/arm/dts/sama5d3xmb_cmp.dtsi | 2 +- 9 files changed, 9 insertions(+), 9 deletions(-)
On Mon, Nov 02, 2020 at 11:01:51AM +0000, Eugen.Hristev@microchip.com wrote:
Hello Tom,
Thanks !
Eugen
