[PATCH v1 0/3] add FIT image support for broadcom NS3 soc
This is third patch set series prepared on top of second patch set ("add basic driver support for broadcom NS3 soc").
This patch set enables FIT config and add FIT image its files and keys.
Pramod Kumar (2): board: ns3: add FIT image its file board: ns3: add development keys used in FIT
Rayagonda Kokatanur (1): configs: ns3: enable FIT config
board/broadcom/bcmns3/fit/keys/dev.crt | 21 +++++++++ board/broadcom/bcmns3/fit/keys/dev.key | 28 ++++++++++++ board/broadcom/bcmns3/fit/multi.its | 59 ++++++++++++++++++++++++++ configs/bcm_ns3_defconfig | 5 +++ 4 files changed, 113 insertions(+) create mode 100644 board/broadcom/bcmns3/fit/keys/dev.crt create mode 100644 board/broadcom/bcmns3/fit/keys/dev.key create mode 100644 board/broadcom/bcmns3/fit/multi.its
Enable FIT config for NS3.
Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com --- configs/bcm_ns3_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/bcm_ns3_defconfig b/configs/bcm_ns3_defconfig index 3cb69eff9d..b52c6d7d93 100644 --- a/configs/bcm_ns3_defconfig +++ b/configs/bcm_ns3_defconfig @@ -5,6 +5,11 @@ CONFIG_SYS_TEXT_BASE=0xFF000000 CONFIG_ENV_SIZE=0x80000 CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_BOARD_SETUP=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_SIGNATURE_MAX_SIZE=0x20000000 +CONFIG_FIT_VERBOSE=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_LOGLEVEL=7 CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y
On Sun, 17 May 2020 at 02:25, Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com wrote:
Add FIT image its file.
Signed-off-by: Pramod Kumar pramod.kumar@broadcom.com Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com --- board/broadcom/bcmns3/fit/multi.its | 59 +++++++++++++++++++++++++++++ 1 file changed, 59 insertions(+) create mode 100644 board/broadcom/bcmns3/fit/multi.its
diff --git a/board/broadcom/bcmns3/fit/multi.its b/board/broadcom/bcmns3/fit/multi.its new file mode 100644 index 0000000000..a0ff4bc908 --- /dev/null +++ b/board/broadcom/bcmns3/fit/multi.its @@ -0,0 +1,59 @@ +/* + * U-Boot uImage source file with multiple kernels, ramdisks and FDT blobs + */ + +/dts-v1/; + +/ { + description = "Various kernels, ramdisks and FDT blobs"; + #address-cells = <1>; + + images { + kernel { + description = "Linux kernel Image"; + data = /incbin/("./Image"); + type = "kernel"; + arch = "arm64"; + os = "linux"; + compression = "none"; + load = <0x80080000>; + entry = <0x80080000>; + hash-1 { + algo = "sha1"; + }; + signature { + algo = "sha1,rsa2048"; + key-name-hint = "dev"; + }; + }; + + fdt-ns3 { + description = "FDT Blob"; + data = /incbin/("./dt-blob.bin"); + type = "flat_dt"; + arch = "arm64"; + compression = "none"; + hash-1 { + algo = "sha1"; + }; + signature { + algo = "sha1,rsa2048"; + key-name-hint = "dev"; + }; + }; + }; + + configurations { + default = "config-ns3"; + config-ns3 { + description = "FIT1 configuration"; + kernel = "kernel"; + fdt = "fdt-ns3"; + signature { + algo = "sha1,rsa2048"; + key-name-hint = "dev"; + sign-images = "fdt", "kernel"; + }; + }; + }; +};
Hi Rayagonda and Pramod,
Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com writes:
The .its file and dev keys seem generic. Are you intending to add to the .its file subsequently, e.g., to demonstrate FIT usage unique to the NS3?
Thomas
Hi Thomas,
This is generic and used for development. Specific keys will be used by Customer/Specific applications.
Regards, Pramod
On Wed, May 20, 2020 at 7:25 AM Thomas Fitzsimmons fitzsim@fitzsim.org wrote:
Thomas
Add development keys used in FIT.
Signed-off-by: Pramod Kumar pramod.kumar@broadcom.com Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com --- board/broadcom/bcmns3/fit/keys/dev.crt | 21 +++++++++++++++++++ board/broadcom/bcmns3/fit/keys/dev.key | 28 ++++++++++++++++++++++++++ 2 files changed, 49 insertions(+) create mode 100644 board/broadcom/bcmns3/fit/keys/dev.crt create mode 100644 board/broadcom/bcmns3/fit/keys/dev.key
diff --git a/board/broadcom/bcmns3/fit/keys/dev.crt b/board/broadcom/bcmns3/fit/keys/dev.crt new file mode 100644 index 0000000000..75b75db95c --- /dev/null +++ b/board/broadcom/bcmns3/fit/keys/dev.crt @@ -0,0 +1,21 @@ +-----BEGIN CERTIFICATE----- +MIIDXTCCAkWgAwIBAgIJAJgq/5aiJttEMA0GCSqGSIb3DQEBCwUAMEUxCzAJBgNV +BAYTAkFVMRMwEQYDVQQIDApTb21lLVN0YXRlMSEwHwYDVQQKDBhJbnRlcm5ldCBX +aWRnaXRzIFB0eSBMdGQwHhcNMTgwOTE5MDkzMzEwWhcNMTgxMDE5MDkzMzEwWjBF +MQswCQYDVQQGEwJBVTETMBEGA1UECAwKU29tZS1TdGF0ZTEhMB8GA1UECgwYSW50 +ZXJuZXQgV2lkZ2l0cyBQdHkgTHRkMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIB +CgKCAQEAzeMQ92YqrejtMCfxjDyHvDW34ATozXSlWsudR+AyCSuJVAIoHEenVh+/ +PuT0+/EMiwsUnLXYBeOsIXDW3k3eHgm88ccb+0g9J6mlHqMaN0tXP+Ua2GFEk2Wv +5Bj5QynorOPoaWL/ecWus2Bvkmyt2pvIpaTjmkUKZ9al3z8WyS6wFlFitXyOWFcK +7Xkl43cOHxYAfbny5loWYDCgpkV+dgYZOoCEmL+Y9HfrQ+uBKGducpzNKeQjX9bn +UT9cleCtHZx0uY4wSGNgfmUMy7oUyVZhFpmjlcfjcfNFcBcoVF6StluoL6v1KRbH +4xJDD/UCn2Uk0S6Zpd7TRc26faOtfwIDAQABo1AwTjAdBgNVHQ4EFgQUZk/KKaWG +p4BtksPdQ8FLzWL/gAIwHwYDVR0jBBgwFoAUZk/KKaWGp4BtksPdQ8FLzWL/gAIw +DAYDVR0TBAUwAwEB/zANBgkqhkiG9w0BAQsFAAOCAQEAPNveTvOC2bw91cUN1e+B +95qFp2Xd5XGiV35F10dT3VN/Iv2dzHlThq7xaJGkA53lHIXgLUUfnDTHJmoluw+t +UCpG8OWCxM0FbT8ZnXR4SmHK8k4yb7iZa7iu+Ey5B6F3247gJpEl+1iYxus0lqQW +E9dTwMf1YP9Jdf+dRoLKAAI0n5J1PMuseQkGdlRBNUcEg+kXqBSz5hq0xkuPRtey +GiAvpg3G93ft84Q4ov7IjAhJkY7whm6WktisU8mFPru3e9EouxjVtAvu6s9gQThm +pvn6hSL2/3gEOP3v9yBsH6//SOgNdVBGZIdX+HkvD8NZLftbIrDaeL/IfKUm/zXB +zA== +-----END CERTIFICATE----- diff --git a/board/broadcom/bcmns3/fit/keys/dev.key b/board/broadcom/bcmns3/fit/keys/dev.key new file mode 100644 index 0000000000..55b7033e9f --- /dev/null +++ b/board/broadcom/bcmns3/fit/keys/dev.key @@ -0,0 +1,28 @@ +-----BEGIN PRIVATE KEY----- +MIIEvwIBADANBgkqhkiG9w0BAQEFAASCBKkwggSlAgEAAoIBAQDN4xD3Ziqt6O0w +J/GMPIe8NbfgBOjNdKVay51H4DIJK4lUAigcR6dWH78+5PT78QyLCxSctdgF46wh +cNbeTd4eCbzxxxv7SD0nqaUeoxo3S1c/5RrYYUSTZa/kGPlDKeis4+hpYv95xa6z +YG+SbK3am8ilpOOaRQpn1qXfPxbJLrAWUWK1fI5YVwrteSXjdw4fFgB9ufLmWhZg +MKCmRX52Bhk6gISYv5j0d+tD64EoZ25ynM0p5CNf1udRP1yV4K0dnHS5jjBIY2B+ +ZQzLuhTJVmEWmaOVx+Nx80VwFyhUXpK2W6gvq/UpFsfjEkMP9QKfZSTRLpml3tNF +zbp9o61/AgMBAAECggEBAJ/TZClZk0ob5nyalWVS29/cJ5hs1zgfE/nu1HKmdNEv +jdS8M9z4Nsuhq3msjQ1Da4RInsCkXUT9H3N6QCKkeggBcT6TXYJs6qRuijLFVKWW +A+4i8PsGTxDJQIimZmGgF/KWnaWp5z7lmZ+//fzCBxgMFO+Zl+H7NH+1XmB2fj6/ +bfgnxLbiIqq/2oVJfdjA1Zs2ie3SE5U2hPNiE6TIajFS0PxUOGrojsSQ8z+gfqs3 +hyqo9msAqNQciT79vyXp+3HsxZo9rq5Tk5OtCEfgu0GED/d4/FHbDrZT3TorVYXr +Z3dADxvnnJfBdlQIMetCy/X8z2vKRRXaoWpqg1aiFVECgYEA7Ap5D4nvOie2NXgI +gMPzuYtpH4uF/cZMLGxTKZ3NG4RH6oVUdd4whETXfzBJdnJbIXDTphoHxjUhpGh8 +Ga+U1iqjp9c6Nd8ueVp/c5T1bD8/2RG0QM4iWgPbZDKtj1MqRg7vwAfpJ3kOIc/5 +bKJ4jAopNJMChL6vAZ9+ShPsRqkCgYEA30vbj6K7/giclJnyWkluQTqS8X/XjdAf +F5PkCBHGJnYxkDSzWPq7O5E1wYqTAou1U6nNNoUvZZdpRvo39NSrMCaagQ7GE+xA +j/h7tinD/lPlvoW9N4f4ddqWzsmf7I8OGZtP4IwVi9Pms+zPtrQ7TvuPT4UHTH2E +eE1hlJtic+cCgYEA6oKdNGr+WvEJfqX7DLOiej2f+89LGI7jL1+QYFB/b09FhCNj +fpd57G/ZCmyXEC8di2PlY6mI/8vZ2NZWNc7UONO0NRUIqG1MZxUae2MLUrikXq3Q +QHKMfpJGbo5LEZK29VPxrwAtDSKgf8d5MA1bZwbRWYKVhf1NMnebqU2R+cECgYEA +kOTKXhP85MR1xj928XtAnfcCLs8D8jOgWU5P46SU7ZQ4aRipYA2ivO5m8WWYK0i4 +qsc+MCiQLt3nJHVtJeNyCdai3yfVBEyDQGi+7d+AHGIYbF6f/46tfNwQi7JtobTa +M2eCl3SO7qLbytjZl/avnXrC7Zimuc2gzed4cFO7uPUCgYAo66MLtRWLdHqPDTaa +WhSQZkdKfZxlWNP6XIpBgHnYDIQGZddrjv+zZVFRxLCduh1v8xybbSDKwRkGuXVb +eTQHP2Nc5XsOopCSsDP0v0dUxaOu14C0jJJG2E+EhJsWJ2Eua7o40LEIX2WY7N7f +UqR3bLO5Qh/1OOwJj5WbpzkMwA== +-----END PRIVATE KEY-----
Pramod Kumar
Rayagonda Kokatanur
Thomas Fitzsimmons
