[U-Boot] Pull request u-boot-marvell.git
Hi Albert
Please kindly pull
The following changes since commit 7b2fac7654f7420c2787f74ec3b1540fa3b343e9: Aneesh V (1): omap730p2: fix build breaks
u-boot-marvell.git next branch.
Holger Brunck (4): arm/kirkwood: if CONFIG_SOFT_I2C is set don't set CONFIG_I2C_MVTWSI arm/km: fix u-boot.kwb build breakage arm/km: remove unneeded define arm/km: replace suenx targets with km_kirkwood
Valentin Longchamp (3): arm/km: use board KM_ENV_BUS for CONFIG_I2C_ENV_EEPROM_BUS arm/km: ethernet support for mgcoge3un arm/km: add support for portl2 board
MAINTAINERS | 7 ++- MAKEALL | 3 +- arch/arm/include/asm/arch-kirkwood/config.h | 2 + board/keymile/km_arm/km_arm.c | 45 ++++++++++++++- boards.cfg | 5 +- include/configs/km/km_arm.h | 32 ++-------- include/configs/{suen3.h => km_kirkwood.h} | 18 ++++-- include/configs/mgcoge3un.h | 6 ++ include/configs/portl2.h | 81 +++++++++++++++++++++++++++ include/configs/suen8.h | 50 ---------------- 10 files changed, 161 insertions(+), 88 deletions(-) rename include/configs/{suen3.h => km_kirkwood.h} (77%) create mode 100644 include/configs/portl2.h delete mode 100644 include/configs/suen8.h
Regards.. Prafulla . .
(resent as this was not sent to the list, sorry Prafulla for the duplicate)
Hi Prafulla,
Le 16/06/2011 13:23, Prafulla Wadaskar a écrit :
Hi Albert
Please kindly pull
Are these meant for this release, i.e. should I pull that in u-boot-arm/master? If so, can you please rebase your master branch onto your next branch? Next is supposed to hold commits waiting for next merge window.
Also:
uboot@lilith:~/src/u-boot-arm$ git fetch u-boot-marvell remote: error: refs/remotes/origin/mkimage does not point to a valid object! remote: Counting objects: 88, done. remote: Compressing objects: 100% (38/38), done. remote: Total 68 (delta 51), reused 38 (delta 29) Unpacking objects: 100% (68/68), done. From git://git.denx.de/u-boot-marvell + 0b41af5...7b2fac7 master -> u-boot-marvell/master (forced update) + 02e1082...7e481f6 next -> u-boot-marvell/next (forced update) uboot@lilith:~/src/u-boot-arm$
Anyone know what the error message about refs/remote/origin/mkimage means?
Amicalement,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Saturday, June 18, 2011 11:16 AM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de Subject: Re: Pull request u-boot-marvell.git
Hi Prafulla,
Hi Albert
Please kindly pull
Hi Albert By default they should go in next release that's why I put them in next branch
Also:
- 0b41af5...7b2fac7 master -> u-boot-marvell/master (forced
update)
- 02e1082...7e481f6 next -> u-boot-marvell/next (forced update)
Amicalement,
Albert.
Hi Prafulla,
Hi Prafulla,
Hi Albert
Please kindly pull
Still not clear to me -- next release is 2011-06, but next merge window is for *after* 2011-06, and anyway, the U-Boot wiki clearly describes pull reqs as being done on master branches, not next. So:
- if you want these commits in for 2011-06, then please move your master to have them in, and send a pull req for master, not next.
- if you want them in after 2011-06, then simply wait for the merge window, then move them to your master and issue the pull request.
Which is it?
Sorry if I seem either convoluted or dense (or both).
Amicalement,
Albert ARIBAUD
Prafulla Wadaskar
