[PATCH] arm64: zynqmp: Remove unused USB DT properties
xlnx,usb-polarity, xlnx,usb-reset-mode and snps,mask_phy_reset are not documented in dt binding and also there is no code associated with them that's why remove them.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynqmp-dlc21-revA.dts | 4 ---- arch/arm/dts/zynqmp-g-a2197-00-revA.dts | 2 -- arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 4 ---- arch/arm/dts/zynqmp-m-a2197-02-revA.dts | 4 ---- arch/arm/dts/zynqmp-m-a2197-03-revA.dts | 4 ---- arch/arm/dts/zynqmp-p-a2197-00-revA.dts | 4 ---- 6 files changed, 22 deletions(-)
diff --git a/arch/arm/dts/zynqmp-dlc21-revA.dts b/arch/arm/dts/zynqmp-dlc21-revA.dts index 0461219ca3e7..bf0d89a5fcbe 100644 --- a/arch/arm/dts/zynqmp-dlc21-revA.dts +++ b/arch/arm/dts/zynqmp-dlc21-revA.dts @@ -154,8 +154,6 @@
&usb0 { status = "okay"; - xlnx,usb-polarity = <0>; - xlnx,usb-reset-mode = <0>; };
&dwc3_0 { @@ -170,8 +168,6 @@
&usb1 { status = "disabled"; /* Any unknown issue with USB-C */ - xlnx,usb-polarity = <0>; - xlnx,usb-reset-mode = <0>; };
&dwc3_1 { diff --git a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts index e00428351cbf..02d2427809d5 100644 --- a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts @@ -303,8 +303,6 @@
&usb0 { /* USB0 MIO52-63 */ status = "okay"; - xlnx,usb-polarity = <0>; - xlnx,usb-reset-mode = <0>; };
&dwc3_0 { diff --git a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts index 1fa023ffb13c..2d7fe592c8f9 100644 --- a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -461,8 +461,6 @@
&dwc3_0 { @@ -474,8 +472,6 @@
&usb1 { status = "disabled"; /* not at mem board */ - xlnx,usb-polarity = <0>; - xlnx,usb-reset-mode = <0>; };
&dwc3_1 { diff --git a/arch/arm/dts/zynqmp-m-a2197-02-revA.dts b/arch/arm/dts/zynqmp-m-a2197-02-revA.dts index 2271a6a49065..e46748d32c03 100644 --- a/arch/arm/dts/zynqmp-m-a2197-02-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-02-revA.dts @@ -463,8 +463,6 @@
&dwc3_0 { @@ -476,8 +474,6 @@
&dwc3_1 { diff --git a/arch/arm/dts/zynqmp-m-a2197-03-revA.dts b/arch/arm/dts/zynqmp-m-a2197-03-revA.dts index a89046a818fd..f564817e2c84 100644 --- a/arch/arm/dts/zynqmp-m-a2197-03-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-03-revA.dts @@ -457,8 +457,6 @@
&dwc3_0 { @@ -470,8 +468,6 @@
&dwc3_1 { diff --git a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts index b3fe42faeee8..d63deb83e3c6 100644 --- a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts @@ -543,8 +543,6 @@
&usb0 { status = "okay"; - xlnx,usb-polarity = <0>; - xlnx,usb-reset-mode = <0>; phy-names = "usb3-phy"; phys = <&psgtr 1 PHY_TYPE_USB3 0 1>; }; @@ -559,8 +557,6 @@
&usb1 { status = "okay"; - xlnx,usb-polarity = <0>; - xlnx,usb-reset-mode = <0>; };
&dwc3_1 {
&dwc3_0 {
@@ -170,8 +168,6 @@
&dwc3_1 {
&dwc3_0 {
&dwc3_0 {
@@ -474,8 +472,6 @@
&dwc3_1 {
&dwc3_0 {
@@ -476,8 +474,6 @@
&dwc3_1 {
&dwc3_0 {
@@ -470,8 +468,6 @@
&dwc3_1 {
@@ -559,8 +557,6 @@
&dwc3_1 {
Applied. M
Michal Simek
