[U-Boot] [PATCH] net: eth_designware: select PHYLIB in Kconfig
Select PHYLIB in drivers/net/Kconfig. And remove CONFIG_PHYLIB from legacy board header files.
This fixed the warnings when both ALTERA_TSE and ETH_DESIGNWARE are selected.
Reported-by: Pavel Machek pavel@denx.de Signed-off-by: Thomas Chou thomas@wytron.com.tw --- drivers/net/Kconfig | 1 + include/configs/axs101.h | 1 - include/configs/bf609-ezkit.h | 1 - include/configs/galileo.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/spear-common.h | 1 - include/configs/stv0991.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/tb100.h | 1 - include/configs/x600.h | 1 - 10 files changed, 1 insertion(+), 9 deletions(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index a03a95d..4b04d09 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -88,6 +88,7 @@ config ETH_SANDBOX_RAW
config ETH_DESIGNWARE bool "Synopsys Designware Ethernet MAC" + select PHYLIB help This MAC is present in SoCs from various vendors. It supports 100Mbit and 1 Gbit operation. You must enable CONFIG_PHYLIB to diff --git a/include/configs/axs101.h b/include/configs/axs101.h index 650d97d..eeb2ae6 100644 --- a/include/configs/axs101.h +++ b/include/configs/axs101.h @@ -95,7 +95,6 @@ /* * Ethernet PHY configuration */ -#define CONFIG_PHYLIB #define CONFIG_MII #define CONFIG_PHY_GIGE
diff --git a/include/configs/bf609-ezkit.h b/include/configs/bf609-ezkit.h index 0e353b9..b5d4847 100644 --- a/include/configs/bf609-ezkit.h +++ b/include/configs/bf609-ezkit.h @@ -75,7 +75,6 @@ #define CONFIG_DW_ALTDESCRIPTOR #define CONFIG_CMD_MII #define CONFIG_MII -#define CONFIG_PHYLIB
/* i2c Settings */ #define CONFIG_SYS_I2C diff --git a/include/configs/galileo.h b/include/configs/galileo.h index eb16a5e..14a42b1 100644 --- a/include/configs/galileo.h +++ b/include/configs/galileo.h @@ -45,7 +45,6 @@ /* 10/100M Ethernet support */ #define CONFIG_DESIGNWARE_ETH #define CONFIG_DW_ALTDESCRIPTOR -#define CONFIG_PHYLIB
/* Environment configuration */ #define CONFIG_ENV_SECT_SIZE 0x1000 diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index b3f65b6..86eccba 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -105,7 +105,6 @@ #define CONFIG_DW_ALTDESCRIPTOR #define CONFIG_MII #define CONFIG_AUTONEG_TIMEOUT (15 * CONFIG_SYS_HZ) -#define CONFIG_PHYLIB #define CONFIG_PHY_GIGE #endif
diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 1d69477..d2630f4 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -17,7 +17,6 @@
/* Ethernet driver configuration */ #define CONFIG_MII -#define CONFIG_PHYLIB #define CONFIG_PHY_RESET_DELAY 10000 /* in usec */ #define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */
diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index 14c6a9e..f421321 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -53,7 +53,6 @@ /* GMAC related configs */
#define CONFIG_MII -#define CONFIG_PHYLIB #define CONFIG_DW_ALTDESCRIPTOR #define CONFIG_PHY_MICREL
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 98a2c74..31a68ac 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -312,7 +312,6 @@ extern int soft_i2c_gpio_scl; #define CONFIG_PHY_GIGE /* GMAC can use gigabit PHY */ #define CONFIG_PHY_ADDR 1 #define CONFIG_MII /* MII PHY management */ -#define CONFIG_PHYLIB #endif
#ifdef CONFIG_USB_EHCI_HCD diff --git a/include/configs/tb100.h b/include/configs/tb100.h index 8660ed4..e06484f 100644 --- a/include/configs/tb100.h +++ b/include/configs/tb100.h @@ -42,7 +42,6 @@ /* * Ethernet PHY configuration */ -#define CONFIG_PHYLIB #define CONFIG_PHY_GIGE
/* diff --git a/include/configs/x600.h b/include/configs/x600.h index 58f1aca..0263c50 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -77,7 +77,6 @@
/* Ethernet config options */ #define CONFIG_MII -#define CONFIG_PHYLIB #define CONFIG_PHY_RESET_DELAY 10000 /* in usec */ #define CONFIG_PHY_ADDR 0 /* PHY address */ #define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */
- select PHYLIB help This MAC is present in SoCs from various vendors. It supports 100Mbit and 1 Gbit operation. You must enable CONFIG_PHYLIB to
You should also remove the PHYLIB check in drivers/net/designware.c , otherwise looks good.
Best regards, Marek Vasut
HI Marek,
Yes, it will be removed. Thanks.
Best regards, Thomas
Hi Thomas,
- Ethernet PHY configuration
Please remove CONFIG_PHYLIB from galileo.h as well.
Regards, Bin
Hi Bin,
On 2015年12月07日 09:50, Bin Meng wrote:
Hi Thomas,
The CONFIG_PHYLIB is removed from galileo.h with this patch.
Hi Thomas,
On Mon, Dec 7, 2015 at 2:35 PM, Thomas Chou thomas@wytron.com.tw wrote:
Hi Bin,
Hi Thomas,
Ah, yes, I must be brain dead :)
Regards, Bin
Acked-by: Chin Liang See clsee@altera.com
Thanks Chin Liang
Acked-by: Pavel Machek pavel@denx.de Tested-by: Pavel Machek pavel@denx.de
Thanks! Pavel
Signed-off-by: Thomas Chou thomas@wytron.com.tw Reported-by: Pavel Machek pavel@denx.de Acked-by: Chin Liang See clsee@altera.com Acked-by: Pavel Machek pavel@denx.de Tested-by: Pavel Machek pavel@denx.de Reviewed-by: Bin Meng bmeng.cn@gmail.com --- v2 remove the PHYLIB check as suggested by Marek.
drivers/net/Kconfig | 1 + drivers/net/designware.c | 4 ---- include/configs/axs101.h | 1 - include/configs/bf609-ezkit.h | 1 - include/configs/galileo.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/spear-common.h | 1 - include/configs/stv0991.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/tb100.h | 1 - include/configs/x600.h | 1 - 11 files changed, 1 insertion(+), 13 deletions(-)
config ETH_DESIGNWARE bool "Synopsys Designware Ethernet MAC" + select PHYLIB help This MAC is present in SoCs from various vendors. It supports 100Mbit and 1 Gbit operation. You must enable CONFIG_PHYLIB to diff --git a/drivers/net/designware.c b/drivers/net/designware.c index a6c39c3..3af43b4 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -22,10 +22,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#if !defined(CONFIG_PHYLIB) -# error "DesignWare Ether MAC requires PHYLIB - missing CONFIG_PHYLIB" -#endif - static int dw_mdio_read(struct mii_dev *bus, int addr, int devad, int reg) { struct eth_mac_regs *mac_p = bus->priv; diff --git a/include/configs/axs101.h b/include/configs/axs101.h index 650d97d..eeb2ae6 100644 --- a/include/configs/axs101.h +++ b/include/configs/axs101.h @@ -95,7 +95,6 @@ /* * Ethernet PHY configuration */ -#define CONFIG_PHYLIB #define CONFIG_MII #define CONFIG_PHY_GIGE
Hi Marek,
Would you please pick this one? I didn't notice that it was delegated to me before I sent a PR for nios. Thanks.
On Saturday, December 19, 2015 at 04:56:38 AM, Thomas Chou wrote:
Hi Marek,
v2
You mean via socfpga ?
Hi Marek,
Hi Marek,
v2
Yes, please. It was reported on socfpga.
On Saturday, December 19, 2015 at 09:24:11 AM, Thomas Chou wrote:
Hi Marek,
Hi Marek,
v2
Applied, thanks!
participants (5)
Bin Meng
Chin Liang See
Pavel Machek
Thomas Chou
