[U-Boot] [PATCH 0/8] Add rockchip Saradc support
The Saradc is used for adc keys and charging detect at uboot loader. Except for the rk3036 and rk3228 Socs, the others support the Saradc IP.
David Wu (8): adc: Add driver for Rockchip saradc configs: rockchip: Enable the ROCKCHIP_SARADC config clk: rockchip: Add rv1108 SARADC clock support clk: rockchip: Add SARADC clock support for rk3288 clk: rockchip: Add rk3328 SRAADC clock support clk: rockchip: Add rk3368 SARADC clock support clk: rockchip: Add rk3399 SARADC clock support arm: dts: rv1108: Add saradc node at dtsi level
arch/arm/dts/rv1108.dtsi | 11 ++ arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 5 + arch/arm/include/asm/arch-rockchip/cru_rv1108.h | 5 + configs/evb-rk3288_defconfig | 2 + configs/evb-rk3328_defconfig | 2 + configs/evb-rk3399_defconfig | 2 + configs/evb-rv1108_defconfig | 2 + configs/fennec-rk3288_defconfig | 2 + configs/firefly-rk3288_defconfig | 2 + configs/firefly-rk3399_defconfig | 2 + configs/lion-rk3368_defconfig | 2 + configs/miqi-rk3288_defconfig | 2 + configs/phycore-rk3288_defconfig | 2 + configs/popmetal-rk3288_defconfig | 2 + configs/puma-rk3399_defconfig | 2 + configs/sheep-rk3368_defconfig | 2 + configs/tinker-rk3288_defconfig | 2 + drivers/adc/Kconfig | 9 ++ drivers/adc/Makefile | 1 + drivers/adc/rockchip-saradc.c | 188 ++++++++++++++++++++++++ drivers/clk/rockchip/clk_rk3288.c | 45 ++++++ drivers/clk/rockchip/clk_rk3328.c | 37 +++++ drivers/clk/rockchip/clk_rk3368.c | 31 ++++ drivers/clk/rockchip/clk_rk3399.c | 33 +++++ drivers/clk/rockchip/clk_rv1108.c | 35 +++++ include/dt-bindings/clock/rv1108-cru.h | 2 + 26 files changed, 430 insertions(+) create mode 100644 drivers/adc/rockchip-saradc.c
The ADC can support some channels signal-ended some bits Successive Approximation Register (SAR) A/D Converter, like 6-channel and 10-bit. It converts the analog input signal into some bits binary digital codes.
Signed-off-by: David Wu david.wu@rock-chips.com --- drivers/adc/Kconfig | 9 ++ drivers/adc/Makefile | 1 + drivers/adc/rockchip-saradc.c | 188 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 198 insertions(+) create mode 100644 drivers/adc/rockchip-saradc.c
diff --git a/drivers/adc/Kconfig b/drivers/adc/Kconfig index e5335f7..830fe0f 100644 --- a/drivers/adc/Kconfig +++ b/drivers/adc/Kconfig @@ -20,6 +20,15 @@ config ADC_EXYNOS - 12-bit resolution - 600 KSPS of sample rate
+config SARADC_ROCKCHIP + bool "Enable Rockchip SARADC driver" + help + This enables driver for Rockchip SARADC. + It provides: + - 2~6 analog input channels + - 1O-bit resolution + - 1MSPS of sample rate + config ADC_SANDBOX bool "Enable Sandbox ADC test driver" help diff --git a/drivers/adc/Makefile b/drivers/adc/Makefile index cebf26d..4b5aa69 100644 --- a/drivers/adc/Makefile +++ b/drivers/adc/Makefile @@ -8,3 +8,4 @@ obj-$(CONFIG_ADC) += adc-uclass.o obj-$(CONFIG_ADC_EXYNOS) += exynos-adc.o obj-$(CONFIG_ADC_SANDBOX) += sandbox.o +obj-$(CONFIG_SARADC_ROCKCHIP) += rockchip-saradc.o diff --git a/drivers/adc/rockchip-saradc.c b/drivers/adc/rockchip-saradc.c new file mode 100644 index 0000000..5c7c3d9 --- /dev/null +++ b/drivers/adc/rockchip-saradc.c @@ -0,0 +1,188 @@ +/* + * (C) Copyright 2017, Fuzhou Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Rockchip Saradc driver for U-Boot + */ + +#include <asm/io.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <adc.h> + +#define SARADC_DATA 0x00 + +#define SARADC_STAS 0x04 +#define SARADC_STAS_BUSY BIT(0) + +#define SARADC_CTRL 0x08 +#define SARADC_CTRL_POWER_CTRL BIT(3) +#define SARADC_CTRL_CHN_MASK 0x7 +#define SARADC_CTRL_IRQ_STATUS BIT(6) +#define SARADC_CTRL_IRQ_ENABLE BIT(5) + +#define SARADC_DLY_PU_SOC 0x0c + +#define SARADC_TIMEOUT (100 * 1000) + +struct rockchip_saradc_data { + int num_bits; + int num_channels; + unsigned long clk_rate; +}; + +struct rockchip_saradc_priv { + fdt_addr_t regs; + int active_channel; + const struct rockchip_saradc_data *data; +}; + +int rockchip_saradc_channel_data(struct udevice *dev, int channel, + unsigned int *data) +{ + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + + if (channel != priv->active_channel) { + error("Requested channel is not active!"); + return -EINVAL; + } + + if ((readl(priv->regs + SARADC_CTRL) & SARADC_CTRL_IRQ_STATUS) != SARADC_CTRL_IRQ_STATUS) + return -EBUSY; + + /* Read value */ + *data = readl(priv->regs + SARADC_DATA); + *data &= (1 << priv->data->num_bits) - 1; + + /* Power down adc */ + writel(0, priv->regs + SARADC_CTRL); + + return 0; +} + +int rockchip_saradc_start_channel(struct udevice *dev, int channel) +{ + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + + if (channel < 0 || channel >= priv->data->num_channels) { + error("Requested channel is invalid!"); + return -EINVAL; + } + + /* 8 clock periods as delay between power up and start cmd */ + writel(8, priv->regs + SARADC_DLY_PU_SOC); + + /* Select the channel to be used and trigger conversion */ + writel(SARADC_CTRL_POWER_CTRL + | (channel & SARADC_CTRL_CHN_MASK) | SARADC_CTRL_IRQ_ENABLE, + priv->regs + SARADC_CTRL); + + priv->active_channel = channel; + + return 0; +} + +int rockchip_saradc_stop(struct udevice *dev) +{ + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + + /* Power down adc */ + writel(0, priv->regs + SARADC_CTRL); + + priv->active_channel = -1; + + return 0; +} + +int rockchip_saradc_probe(struct udevice *dev) +{ + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + struct clk clk; + int ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return ret; + + ret = clk_set_rate(&clk, priv->data->clk_rate); + if (IS_ERR_VALUE(ret)) + return ret; + + priv->active_channel = -1; + + return 0; +} + +int rockchip_saradc_ofdata_to_platdata(struct udevice *dev) +{ + struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev); + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + struct rockchip_saradc_data *data = + (struct rockchip_saradc_data *)dev_get_driver_data(dev); + + priv->regs = devfdt_get_addr(dev); + if (priv->regs == FDT_ADDR_T_NONE) { + error("Dev: %s - can't get address!", dev->name); + return -ENODATA; + } + + priv->data = data; + uc_pdata->data_mask = (1 << priv->data->num_bits) - 1;; + uc_pdata->data_format = ADC_DATA_FORMAT_BIN; + uc_pdata->data_timeout_us = SARADC_TIMEOUT / 5; + uc_pdata->channel_mask = (1 << priv->data->num_channels) - 1; + + return 0; +} + +static const struct adc_ops rockchip_saradc_ops = { + .start_channel = rockchip_saradc_start_channel, + .channel_data = rockchip_saradc_channel_data, + .stop = rockchip_saradc_stop, +}; + +static const struct rockchip_saradc_data saradc_data = { + .num_bits = 10, + .num_channels = 3, + .clk_rate = 1000000, +}; + +static const struct rockchip_saradc_data rk3066_tsadc_data = { + .num_bits = 12, + .num_channels = 2, + .clk_rate = 50000, +}; + +static const struct rockchip_saradc_data rk3399_saradc_data = { + .num_bits = 10, + .num_channels = 6, + .clk_rate = 1000000, +}; + +static const struct udevice_id rockchip_saradc_ids[] = { + { + .compatible = "rockchip,saradc", + .data = (ulong)&saradc_data, + }, + { + .compatible = "rockchip,rk3066-tsadc", + .data = (ulong)&rk3066_tsadc_data, + }, { + .compatible = "rockchip,rk3399-saradc", + .data = (ulong)&rk3399_saradc_data, + }, + { } +}; + +U_BOOT_DRIVER(rockchip_saradc) = { + .name = "rockchip_saradc", + .id = UCLASS_ADC, + .of_match = rockchip_saradc_ids, + .ops = &rockchip_saradc_ops, + .probe = rockchip_saradc_probe, + .ofdata_to_platdata = rockchip_saradc_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct rockchip_saradc_priv), +};
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Please see below for requested changes.
- bool "Enable Rockchip SARADC driver"
- help
It provides:
- 1O-bit resolution
Do you feel strongly about the "SARADC_ROCKCHIP" or would "ADC_ROCKCHIP" be correct as well? I don't care either way, but this is the first entry here that does not start with CONFIG_ADC_, so I am wondering...
- (C) Copyright 2017, Fuzhou Rockchip Electronics Co., Ltd
- Rockchip Saradc driver for U-Boot
Should this be SARADC (all uppercase)?
Please see https://www.denx.de/wiki/U-Boot/CodingStyle for the include order. Please revise.
@Simon: yes, I am quick study ;-)
Please see https://www.denx.de/wiki/U-Boot/CodingStyle for the guidelines on using structures for I/O accesses. Please revise.
- int num_bits;
- int num_channels;
- unsigned long clk_rate;
- fdt_addr_t regs;
- int active_channel;
- const struct rockchip_saradc_data *data;
unsigned int *data)
- struct rockchip_saradc_priv *priv = dev_get_priv(dev);
- if (channel != priv->active_channel) {
return -EINVAL;
- if ((readl(priv->regs + SARADC_CTRL) & SARADC_CTRL_IRQ_STATUS) != SARADC_CTRL_IRQ_STATUS)
return -EBUSY;
- /* Read value */
- *data = readl(priv->regs + SARADC_DATA);
- *data &= (1 << priv->data->num_bits) - 1;
This recomputes the data_mask (from below). Can we just use the data_mask again?
- /* Power down adc */
- writel(0, priv->regs + SARADC_CTRL);
- if (channel < 0 || channel >= priv->data->num_channels) {
return -EINVAL;
- /* 8 clock periods as delay between power up and start cmd */
- writel(8, priv->regs + SARADC_DLY_PU_SOC);
- /* Select the channel to be used and trigger conversion */
- writel(SARADC_CTRL_POWER_CTRL
This line does not match the style guideline: it is too wide and the operator should be before the line-break.
Did you run checkpatch or use patman?
- priv->active_channel = channel;
- priv->active_channel = -1;
- struct clk clk;
- int ret;
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret)
return ret;
- ret = clk_set_rate(&clk, priv->data->clk_rate);
- if (IS_ERR_VALUE(ret))
return ret;
- struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev);
- struct rockchip_saradc_data *data =
- priv->regs = devfdt_get_addr(dev);
Shouldn't this be dev_read_addr?
- if (priv->regs == FDT_ADDR_T_NONE) {
return -ENODATA;
- priv->data = data;
- uc_pdata->data_mask = (1 << priv->data->num_bits) - 1;;
- uc_pdata->data_format = ADC_DATA_FORMAT_BIN;
- uc_pdata->data_timeout_us = SARADC_TIMEOUT / 5;
- uc_pdata->channel_mask = (1 << priv->data->num_channels) - 1;
- .start_channel = rockchip_saradc_start_channel,
- .channel_data = rockchip_saradc_channel_data,
- .stop = rockchip_saradc_stop,
- .num_bits = 10,
- .num_channels = 3,
- .clk_rate = 1000000,
- .num_bits = 12,
- .num_channels = 2,
- .clk_rate = 50000,
- .num_bits = 10,
- .num_channels = 6,
- .name = "rockchip_saradc",
- .id = UCLASS_ADC,
- .of_match = rockchip_saradc_ids,
- .ops = &rockchip_saradc_ops,
- .probe = rockchip_saradc_probe,
- .ofdata_to_platdata = rockchip_saradc_ofdata_to_platdata,
- .priv_auto_alloc_size = sizeof(struct rockchip_saradc_priv),
Except for 3036 and 3228 Socs, which don't support Saradc, enable the ROCKCHIP_SARADC config at the other Socs' defconfig.
Signed-off-by: David Wu david.wu@rock-chips.com --- configs/evb-rk3288_defconfig | 2 ++ configs/evb-rk3328_defconfig | 2 ++ configs/evb-rk3399_defconfig | 2 ++ configs/evb-rv1108_defconfig | 2 ++ configs/fennec-rk3288_defconfig | 2 ++ configs/firefly-rk3288_defconfig | 2 ++ configs/firefly-rk3399_defconfig | 2 ++ configs/lion-rk3368_defconfig | 2 ++ configs/miqi-rk3288_defconfig | 2 ++ configs/phycore-rk3288_defconfig | 2 ++ configs/popmetal-rk3288_defconfig | 2 ++ configs/puma-rk3399_defconfig | 2 ++ configs/sheep-rk3368_defconfig | 2 ++ configs/tinker-rk3288_defconfig | 2 ++ 14 files changed, 28 insertions(+)
diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 5294ba9..f09b769 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -37,6 +37,8 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 7bec001..b44b029 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_TIME=y CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_MMC_DW=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 7a0bd4a..6d0d1a0 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -30,6 +30,8 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index ab4276a..3278104 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -13,6 +13,8 @@ CONFIG_CMD_TIME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 96a07de..913849e 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -40,6 +40,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 82da601..75f8cdb 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -40,6 +40,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 94b9209..e9e4324 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -30,6 +30,8 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index 45a12a8..5ef6d4b 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -52,6 +52,8 @@ CONFIG_TPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y CONFIG_TPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_TPL_CLK=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index b0437e1..7825467 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -40,6 +40,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 93ee353..911600d 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -42,6 +42,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 5e99f9c..9f5d78d 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -40,6 +40,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 1badf80..7929a69 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -41,6 +41,8 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/sheep-rk3368_defconfig b/configs/sheep-rk3368_defconfig index b862a14..d4877d3 100644 --- a/configs/sheep-rk3368_defconfig +++ b/configs/sheep-rk3368_defconfig @@ -10,6 +10,8 @@ CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_CMD_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 00e2d81..e7eba10 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -41,6 +41,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y
Please use an ‘imply’ in the Kconfig for the various SoCs (or possibly even the entire sub-architecture) or a "default y if …”.
Given that this is a DM-enabled driver, there is no harm in compiling it in, even if a given board does not use it. This should make defconfig changes unnecessary (unless someone really needs to override the implied setting).
diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 5294ba9..f09b769 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -37,6 +37,8 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 7bec001..b44b029 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_TIME=y CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_MMC_DW=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 7a0bd4a..6d0d1a0 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -30,6 +30,8 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index ab4276a..3278104 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -13,6 +13,8 @@ CONFIG_CMD_TIME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 96a07de..913849e 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -40,6 +40,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 82da601..75f8cdb 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -40,6 +40,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 94b9209..e9e4324 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -30,6 +30,8 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index 45a12a8..5ef6d4b 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -52,6 +52,8 @@ CONFIG_TPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y CONFIG_TPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_TPL_CLK=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index b0437e1..7825467 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -40,6 +40,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 93ee353..911600d 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -42,6 +42,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 5e99f9c..9f5d78d 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -40,6 +40,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 1badf80..7929a69 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -41,6 +41,8 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y diff --git a/configs/sheep-rk3368_defconfig b/configs/sheep-rk3368_defconfig index b862a14..d4877d3 100644 --- a/configs/sheep-rk3368_defconfig +++ b/configs/sheep-rk3368_defconfig @@ -10,6 +10,8 @@ CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_CMD_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 00e2d81..e7eba10 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -41,6 +41,8 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_SARADC_ROCKCHIP=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y -- 2.7.4
Signed-off-by: David Wu david.wu@rock-chips.com --- arch/arm/include/asm/arch-rockchip/cru_rv1108.h | 5 ++++ drivers/clk/rockchip/clk_rv1108.c | 35 +++++++++++++++++++++++++ include/dt-bindings/clock/rv1108-cru.h | 2 ++ 3 files changed, 42 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rv1108.h b/arch/arm/include/asm/arch-rockchip/cru_rv1108.h index 2a1ae69..b134559 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rv1108.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rv1108.h @@ -90,6 +90,11 @@ enum { CORE_CLK_DIV_SHIFT = 0, CORE_CLK_DIV_MASK = 0x1f << CORE_CLK_DIV_SHIFT,
+ /* CLKSEL_CON22 */ + CLK_SARADC_DIV_CON_SHIFT= 0, + CLK_SARADC_DIV_CON_MASK = 0x3ff << CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH= 10, + /* CLKSEL24_CON */ MAC_PLL_SEL_SHIFT = 12, MAC_PLL_SEL_MASK = 1 << MAC_PLL_SEL_SHIFT, diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index cf966bb..aa989c6 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -36,6 +36,11 @@ enum { #hz "Hz cannot be hit with PLL "\ "divisors on line " __stringify(__LINE__));
+static inline u32 extract_bits(u32 val, unsigned width, unsigned shift) +{ + return (val >> shift) & ((1 << width) - 1); +} + /* use interge mode*/ static inline int rv1108_pll_id(enum rk_clk_id clk_id) { @@ -130,6 +135,31 @@ static int rv1108_sfc_set_clk(struct rv1108_cru *cru, uint rate) return DIV_TO_RATE(pll_rate, div); }
+static ulong rv1108_saradc_get_clk(struct rv1108_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[22]); + div = extract_bits(val, CLK_SARADC_DIV_CON_WIDTH, + CLK_SARADC_DIV_CON_SHIFT); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rv1108_saradc_set_clk(struct rv1108_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->clksel_con[22], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rv1108_saradc_get_clk(cru); +} + static ulong rv1108_clk_get_rate(struct clk *clk) { struct rv1108_clk_priv *priv = dev_get_priv(clk->dev); @@ -137,6 +167,8 @@ static ulong rv1108_clk_get_rate(struct clk *clk) switch (clk->id) { case 0 ... 63: return rkclk_pll_get_rate(priv->cru, clk->id); + case SCLK_SARADC: + return rv1108_saradc_get_clk(priv->cru); default: return -ENOENT; } @@ -154,6 +186,9 @@ static ulong rv1108_clk_set_rate(struct clk *clk, ulong rate) case SCLK_SFC: new_rate = rv1108_sfc_set_clk(priv->cru, rate); break; + case SCLK_SARADC: + new_rate = rv1108_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; } diff --git a/include/dt-bindings/clock/rv1108-cru.h b/include/dt-bindings/clock/rv1108-cru.h index d2ad3bb..7defc6b 100644 --- a/include/dt-bindings/clock/rv1108-cru.h +++ b/include/dt-bindings/clock/rv1108-cru.h @@ -39,6 +39,7 @@ #define SCLK_MAC_TX 88 #define SCLK_MACREF 89 #define SCLK_MACREF_OUT 90 +#define SCLK_SARADC 91
/* aclk gates */ @@ -67,6 +68,7 @@ #define PCLK_TIMER 270 #define PCLK_PERI 271 #define PCLK_GMAC 272 +#define PCLK_SARADC 273
/* hclk gates */ #define HCLK_I2S0_8CH 320
- /* CLKSEL_CON22 */
- CLK_SARADC_DIV_CON_SHIFT= 0,
- CLK_SARADC_DIV_CON_MASK = 0x3ff << CLK_SARADC_DIV_CON_SHIFT,
Can we use GENMASK here?
- CLK_SARADC_DIV_CON_WIDTH= 10,
- /* CLKSEL24_CON */ MAC_PLL_SEL_SHIFT = 12, MAC_PLL_SEL_MASK = 1 << MAC_PLL_SEL_SHIFT,
- return (val >> shift) & ((1 << width) - 1);
The comment regarding bitfield.h applies again.
typo: integer
- u32 div, val;
- val = readl(&cru->clksel_con[22]);
- div = extract_bits(val, CLK_SARADC_DIV_CON_WIDTH,
- return DIV_TO_RATE(OSC_HZ, div);
- int src_clk_div;
- src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1;
- assert(src_clk_div < 128);
- rk_clrsetreg(&cru->clksel_con[22],
- return rv1108_saradc_get_clk(cru);
- case SCLK_SARADC:
default: return -ENOENT; }return rv1108_saradc_get_clk(priv->cru);
- case SCLK_SARADC:
default: return -ENOENT; }break;
Signed-off-by: David Wu david.wu@rock-chips.com --- drivers/clk/rockchip/clk_rk3288.c | 45 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index 478195b..29652b0 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -111,6 +111,15 @@ enum { PERI_ACLK_DIV_SHIFT = 0, PERI_ACLK_DIV_MASK = 0x1f << PERI_ACLK_DIV_SHIFT,
+ /* + * CLKSEL24 + * saradc_div_con: + * clk_saradc=24MHz/(saradc_div_con+1) + */ + CLK_SARADC_DIV_CON_SHIFT = 8, + CLK_SARADC_DIV_CON_MASK = 0xff << CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH = 8, + SOCSTS_DPLL_LOCK = 1 << 5, SOCSTS_APLL_LOCK = 1 << 6, SOCSTS_CPLL_LOCK = 1 << 7, @@ -131,6 +140,11 @@ static const struct pll_div apll_init_cfg = PLL_DIVISORS(APLL_HZ, 1, 1); static const struct pll_div gpll_init_cfg = PLL_DIVISORS(GPLL_HZ, 2, 2); static const struct pll_div cpll_init_cfg = PLL_DIVISORS(CPLL_HZ, 1, 2);
+static inline u32 extract_bits(u32 val, unsigned width, unsigned shift) +{ + return (val >> shift) & ((1 << width) - 1); +} + static int rkclk_set_pll(struct rk3288_cru *cru, enum rk_clk_id clk_id, const struct pll_div *div) { @@ -634,6 +648,31 @@ static ulong rockchip_spi_set_clk(struct rk3288_cru *cru, uint gclk_rate, return rockchip_spi_get_clk(cru, gclk_rate, periph); }
+static ulong rockchip_saradc_get_clk(struct rk3288_cru *cru) +{ + u32 div, val; + + val = readl(&cru->cru_clksel_con[24]); + div = extract_bits(val, CLK_SARADC_DIV_CON_WIDTH, + CLK_SARADC_DIV_CON_SHIFT); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rockchip_saradc_set_clk(struct rk3288_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->cru_clksel_con[24], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rockchip_saradc_get_clk(cru); +} + static ulong rk3288_clk_get_rate(struct clk *clk) { struct rk3288_clk_priv *priv = dev_get_priv(clk->dev); @@ -666,6 +705,9 @@ static ulong rk3288_clk_get_rate(struct clk *clk) return gclk_rate; case PCLK_PWM: return PD_BUS_PCLK_HZ; + case SCLK_SARADC: + new_rate = rockchip_saradc_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -756,6 +798,9 @@ static ulong rk3288_clk_set_rate(struct clk *clk, ulong rate) new_rate = rate; break; #endif + case SCLK_SARADC: + new_rate = rockchip_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; }
Please add a commit message.
See above and below for requested changes.
* CLKSEL24
* saradc_div_con:
- CLK_SARADC_DIV_CON_SHIFT = 8,
- CLK_SARADC_DIV_CON_MASK = 0xff << CLK_SARADC_DIV_CON_SHIFT,
- CLK_SARADC_DIV_CON_WIDTH = 8,
- SOCSTS_DPLL_LOCK = 1 << 5, SOCSTS_APLL_LOCK = 1 << 6, SOCSTS_CPLL_LOCK = 1 << 7,
Please reuse what’s already available in include/bitfield.h. This also applies to all call-sites for extract_bits below: they should directly use the already existing function.
- u32 div, val;
- val = readl(&cru->cru_clksel_con[24]);
- int src_clk_div;
- rk_clrsetreg(&cru->cru_clksel_con[24],
- return rockchip_saradc_get_clk(cru);
- case SCLK_SARADC:
- case SCLK_SARADC:
-- 2.7.4
Commit message?
* CLKSEL24
* saradc_div_con:
Same comments apply as for patch 3/8.
- u32 div, val;
- int src_clk_div;
- case SCLK_SARADC:
- case SCLK_SARADC:
-- 2.7.4
Signed-off-by: David Wu david.wu@rock-chips.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
The clk_saradc is dividing from the 24M, clk_saradc=24MHz/(saradc_div_con+1). Saradc integer divider control register is 10-bits width.
Signed-off-by: David Wu david.wu@rock-chips.com --- drivers/clk/rockchip/clk_rk3328.c | 37 +++++++++++++++++++++++++++++++++++++ 1 file changed, 37 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index c3a6650..e1ae7b2 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -115,6 +115,7 @@ enum { /* CLKSEL_CON23 */ CLK_SARADC_DIV_CON_SHIFT = 0, CLK_SARADC_DIV_CON_MASK = 0x3ff << CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH = 10,
/* CLKSEL_CON24 */ CLK_PWM_PLL_SEL_CPLL = 0, @@ -180,6 +181,11 @@ enum { #define PLL_DIV_MIN 16 #define PLL_DIV_MAX 3200
+static inline u32 extract_bits(u32 val, unsigned width, unsigned shift) +{ + return (val >> shift) & ((1 << width) - 1); +} + /* * How to calculate the PLL(from TRM V0.3 Part 1 Page 63): * Formulas also embedded within the Fractional PLL Verilog model: @@ -478,6 +484,31 @@ static ulong rk3328_pwm_set_clk(struct rk3328_cru *cru, uint hz) return DIV_TO_RATE(GPLL_HZ, div); }
+static ulong rk3328_saradc_get_clk(struct rk3328_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[23]); + div = extract_bits(val, CLK_SARADC_DIV_CON_WIDTH, + CLK_SARADC_DIV_CON_SHIFT); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rk3328_saradc_set_clk(struct rk3328_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->clksel_con[23], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rk3328_saradc_get_clk(cru); +} + static ulong rk3328_clk_get_rate(struct clk *clk) { struct rk3328_clk_priv *priv = dev_get_priv(clk->dev); @@ -501,6 +532,9 @@ static ulong rk3328_clk_get_rate(struct clk *clk) case SCLK_PWM: rate = rk3328_pwm_get_clk(priv->cru); break; + case SCLK_SARADC: + rate = rk3328_saradc_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -531,6 +565,9 @@ static ulong rk3328_clk_set_rate(struct clk *clk, ulong rate) case SCLK_PWM: ret = rk3328_pwm_set_clk(priv->cru, rate); break; + case SCLK_SARADC: + ret = rk3328_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; }
See below for comments.
Can we use the functions from bitfield.h, please?
- How to calculate the PLL(from TRM V0.3 Part 1 Page 63):
- Formulas also embedded within the Fractional PLL Verilog model:
- u32 div, val;
- val = readl(&cru->clksel_con[23]);
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[23],
- return rk3328_saradc_get_clk(cru);
- case SCLK_SARADC:
- case SCLK_SARADC:
The clk_saradc is dividing from the 24M, clk_saradc=24MHz/(saradc_div_con+1). Saradc integer divider control register is 8-bits width.
Signed-off-by: David Wu david.wu@rock-chips.com --- arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 5 ++++ drivers/clk/rockchip/clk_rk3368.c | 32 +++++++++++++++++++++++++ 2 files changed, 37 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h index 2b1197f..31f7685 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h @@ -89,6 +89,11 @@ enum { MCU_CLK_DIV_SHIFT = 0, MCU_CLK_DIV_MASK = GENMASK(4, 0),
+ /* CLKSEL_CON25 */ + CLK_SARADC_DIV_CON_SHIFT = 8, + CLK_SARADC_DIV_CON_MASK = 0xff << CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH = 8, + /* CLKSEL43_CON */ GMAC_MUX_SEL_EXTCLK = BIT(8),
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 2be1f57..2eedf77 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -12,6 +12,7 @@ #include <errno.h> #include <mapmem.h> #include <syscon.h> +#include <bitfield.h> #include <asm/arch/clock.h> #include <asm/arch/cru_rk3368.h> #include <asm/arch/hardware.h> @@ -397,6 +398,31 @@ static ulong rk3368_spi_set_clk(struct rk3368_cru *cru, ulong clk_id, uint hz) return rk3368_spi_get_clk(cru, clk_id); }
+static ulong rk3368_saradc_get_clk(struct rk3368_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[25]); + div = bitfield_extract(val, CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rk3368_saradc_set_clk(struct rk3368_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->clksel_con[25], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rk3368_saradc_get_clk(cru); +} + static ulong rk3368_clk_get_rate(struct clk *clk) { struct rk3368_clk_priv *priv = dev_get_priv(clk->dev); @@ -419,6 +445,9 @@ static ulong rk3368_clk_get_rate(struct clk *clk) rate = rk3368_mmc_get_clk(priv->cru, clk->id); break; #endif + case SCLK_SARADC: + rate = rk3368_saradc_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -453,6 +482,9 @@ static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate) ret = rk3368_gmac_set_clk(priv->cru, clk->id, rate); break; #endif + case SCLK_SARADC: + ret = rk3368_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; }
- /* CLKSEL_CON25 */
Please use GENMASK.
- /* CLKSEL43_CON */ GMAC_MUX_SEL_EXTCLK = BIT(8),
- u32 div, val;
- val = readl(&cru->clksel_con[25]);
- div = bitfield_extract(val, CLK_SARADC_DIV_CON_SHIFT,
Please reuse the functions from bitfield.h.
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[25],
- return rk3368_saradc_get_clk(cru);
- case SCLK_SARADC:
- case SCLK_SARADC:
On 13 Sep 2017, at 22:41, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Signed-off-by: David Wu <david.wu@rock-chips.com mailto:david.wu@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com>
Please use GENMASK.
- u32 div, val;
It’s apparently too late to do code reviews: please ignore this comment.
- int src_clk_div;
- case SCLK_SARADC:
- case SCLK_SARADC:
Signed-off-by: David Wu david.wu@rock-chips.com --- drivers/clk/rockchip/clk_rk3399.c | 34 ++++++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 3edafea..5efe2c2 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -12,6 +12,7 @@ #include <errno.h> #include <mapmem.h> #include <syscon.h> +#include <bitfield.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/cru_rk3399.h> @@ -182,6 +183,7 @@ enum { /* CLKSEL_CON26 */ CLK_SARADC_DIV_CON_SHIFT = 8, CLK_SARADC_DIV_CON_MASK = 0xff << CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH = 8,
/* CLKSEL_CON27 */ CLK_TSADC_SEL_X24M = 0x0, @@ -860,6 +862,32 @@ static ulong rk3399_ddr_set_clk(struct rk3399_cru *cru,
return set_rate; } + +static ulong rk3399_saradc_get_clk(struct rk3399_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[26]); + div = bitfield_extract(val, CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rk3399_saradc_set_clk(struct rk3399_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->clksel_con[26], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rk3399_saradc_get_clk(cru); +} + static ulong rk3399_clk_get_rate(struct clk *clk) { struct rk3399_clk_priv *priv = dev_get_priv(clk->dev); @@ -895,6 +923,9 @@ static ulong rk3399_clk_get_rate(struct clk *clk) break; case PCLK_EFUSE1024NS: break; + case SCLK_SARADC: + rate = rk3399_saradc_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -943,6 +974,9 @@ static ulong rk3399_clk_set_rate(struct clk *clk, ulong rate) break; case PCLK_EFUSE1024NS: break; + case SCLK_SARADC: + ret = rk3399_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; }
return set_rate; }
- u32 div, val;
- val = readl(&cru->clksel_con[26]);
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[26],
- return rk3399_saradc_get_clk(cru);
- case SCLK_SARADC:
- case SCLK_SARADC:
Signed-off-by: David Wu david.wu@rock-chips.com --- arch/arm/dts/rv1108.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/rv1108.dtsi b/arch/arm/dts/rv1108.dtsi index 77ca24e..d6927ee 100644 --- a/arch/arm/dts/rv1108.dtsi +++ b/arch/arm/dts/rv1108.dtsi @@ -126,6 +126,17 @@ reg = <0x10300000 0x1000>; };
+ saradc: saradc@1038c000 { + compatible = "rockchip,rv1108-saradc", "rockchip,rk3399-saradc"; + reg = <0x1038c000 0x100>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + #io-channel-cells = <1>; + clock-frequency = <1000000>; + clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; + clock-names = "saradc", "apb_pclk"; + status = "disabled"; + }; + pmugrf: syscon@20060000 { compatible = "rockchip,rv1108-pmugrf", "syscon"; reg = <0x20060000 0x1000>;
David Wu
Dr. Philipp Tomsich
Philipp Tomsich
