[PATCH] mpc8379erdb: Convert to DM_MMC
Signed-off-by: Sinan Akman sinan@writeme.com Cc: mario.six@gdsys.cc --- arch/powerpc/dts/Makefile | 1 + arch/powerpc/dts/mpc8379erdb.dts | 239 ++++++++++++++++++++++++++++++ board/freescale/mpc837xerdb/mpc837xerdb.c | 9 +- configs/MPC837XERDB_defconfig | 5 +- 4 files changed, 252 insertions(+), 2 deletions(-) create mode 100644 arch/powerpc/dts/mpc8379erdb.dts
diff --git a/arch/powerpc/dts/Makefile b/arch/powerpc/dts/Makefile index 3195351c9c..e3ec033096 100644 --- a/arch/powerpc/dts/Makefile +++ b/arch/powerpc/dts/Makefile @@ -1,5 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
+dtb-$(CONFIG_TARGET_MPC837XERDB) += mpc8379erdb.dtb dtb-$(CONFIG_TARGET_MPC8548CDS) += mpc8548cds.dtb mpc8548cds_36b.dtb dtb-$(CONFIG_TARGET_P1020RDB_PC) += p1020rdb-pc.dtb p1020rdb-pc_36b.dtb dtb-$(CONFIG_TARGET_P1020RDB_PD) += p1020rdb-pd.dtb diff --git a/arch/powerpc/dts/mpc8379erdb.dts b/arch/powerpc/dts/mpc8379erdb.dts new file mode 100644 index 0000000000..33afaf9a94 --- /dev/null +++ b/arch/powerpc/dts/mpc8379erdb.dts @@ -0,0 +1,239 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * MPC8379E RDB Device Tree Source + * + * Copyright 2020 NXP + */ + +/dts-v1/; + +/ { + compatible = "fsl,mpc8379erdb"; + + #address-cells = <1>; + #size-cells = <1>; + + aliases { + serial0 = &serial0; + serial1 = &serial1; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + PowerPC,8379@0 { + device_type = "cpu"; + reg = <0x0>; + d-cache-line-size = <32>; + i-cache-line-size = <32>; + d-cache-size = <32768>; + i-cache-size = <32768>; + timebase-frequency = <0>; + bus-frequency = <0>; + clock-frequency = <0>; + }; + }; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; // 256MB at 0 + }; + + localbus@e0005000 { + #address-cells = <2>; + #size-cells = <1>; + compatible = "fsl,elbc", "simple-bus"; + reg = <0xe0005000 0x1000>; + interrupts = <77 0x8>; + interrupt-parent = <&ipic>; + }; + + immr@e0000000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "soc"; + compatible = "simple-bus"; + ranges = <0 0xe0000000 0x00100000>; + reg = <0xe0000000 0x00000200>; + bus-frequency = <0>; + + wdt@200 { + device_type = "watchdog"; + compatible = "mpc83xx_wdt"; + reg = <0x200 0x100>; + }; + + gpio0: gpio@c00 { + #gpio-cells = <2>; + device_type = "gpio"; + compatible = "fsl,mpc8379-gpio", "fsl,mpc8349-gpio"; + reg = <0xc00 0x18>; + interrupts = <74 0x8>; + interrupt-parent = <&ipic>; + gpio-controller; + }; + + gpio2: gpio-controller@d00 { + #gpio-cells = <2>; + device_type = "gpio"; + compatible = "fsl,mpc8379-gpio", "fsl,mpc8349-gpio"; + reg = <0xd00 0x100>; + interrupts = <75 0x8>; + interrupt-parent = <&ipic>; + gpio-controller; + }; + + i2c@3000 { + #address-cells = <1>; + #size-cells = <0>; + cell-index = <0>; + compatible = "fsl-i2c"; + reg = <0x3000 0x100>; + interrupts = <14 0x8>; + interrupt-parent = <&ipic>; + dfsrr; + }; + + i2c@3100 { + #address-cells = <1>; + #size-cells = <0>; + cell-index = <1>; + compatible = "fsl-i2c"; + reg = <0x3100 0x100>; + interrupts = <15 0x8>; + interrupt-parent = <&ipic>; + dfsrr; + }; + + spi@7000 { + #address-cells = <1>; + #size-cells = <0>; + cell-index = <0>; + compatible = "fsl,spi"; + reg = <0x7000 0x1000>; + interrupts = <16 0x8>; + interrupt-parent = <&ipic>; + mode = "cpu"; + }; + + sdhc@2e000 { + compatible = "fsl,esdhc"; + reg = <0x2e000 0x1000>; + bus-width = <0x4>; + clock-frequency = <0>; + }; + + serial0: serial@4500 { + cell-index = <0>; + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550"; + reg = <0x4500 0x100>; + clock-frequency = <133333333>; + interrupts = <9 0x8>; + interrupt-parent = <&ipic>; + }; + + serial1: serial@4600 { + cell-index = <1>; + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550"; + reg = <0x4600 0x100>; + clock-frequency = <133333333>; + interrupts = <10 0x8>; + interrupt-parent = <&ipic>; + }; + + ipic: interrupt-controller@700 { + compatible = "fsl,ipic"; + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <2>; + reg = <0x700 0x100>; + device_type = "ipic"; + }; + + pmc: power@b00 { + compatible = "fsl,mpc8379-pmc", "fsl,mpc8349-pmc"; + reg = <0xb00 0x100 0xa00 0x100>; + interrupts = <80 0x8>; + interrupt-parent = <&ipic>; + }; + + usb@23000 { + compatible = "fsl-usb2-dr"; + reg = <0x23000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupt-parent = <&ipic>; + interrupts = <38 0x8>; + phy_type = "ulpi"; + sleep = <&pmc 0x00c00000>; + }; + + enet0: ethernet@24000 { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x24000 0x1000>; + + cell-index = <0>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar", "fsl,tsec"; + reg = <0x24000 0x1000>; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <32 0x8 33 0x8 34 0x8>; + interrupt-parent = <&ipic>; + tbi-handle = < &tbi0 >; + phy-handle = < &phy2 >; + fsl,magic-packet; + + mdio@520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-mdio"; + reg = <0x520 0x20>; + + phy2: ethernet-phy@2 { + interrupt-parent = <&ipic>; + interrupts = <17 0x8>; + reg = <0x2>; + device_type = "ethernet-phy"; + }; + tbi0: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + }; + + enet1: ethernet@25000 { + #address-cells = <1>; + #size-cells = <1>; + cell-index = <1>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar", "fsl,tsec"; + reg = <0x25000 0x1000>; + ranges = <0x0 0x25000 0x1000>; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <35 0x8 36 0x8 37 0x8>; + interrupt-parent = <&ipic>; + tbi-handle = <&tbi1>; + fsl,magic-packet; + + mdio@520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-tbi"; + reg = <0x520 0x20>; + + tbi1: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + }; + }; + +}; diff --git a/board/freescale/mpc837xerdb/mpc837xerdb.c b/board/freescale/mpc837xerdb/mpc837xerdb.c index 45038acf32..9321952674 100644 --- a/board/freescale/mpc837xerdb/mpc837xerdb.c +++ b/board/freescale/mpc837xerdb/mpc837xerdb.c @@ -136,8 +136,8 @@ int checkboard(void)
int board_early_init_f(void) { -#ifdef CONFIG_FSL_SERDES immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; +#ifdef CONFIG_FSL_SERDES u32 spridr = in_be32(&immr->sysconf.spridr);
/* we check only part num, and don't look for CPU revisions */ @@ -164,10 +164,16 @@ int board_early_init_f(void) break; } #endif /* CONFIG_FSL_SERDES */ + +#ifdef CONFIG_FSL_ESDHC + clrsetbits_be32(&immr->sysconf.sicrl, SICRL_USB_B, SICRL_USB_B_SD); + clrsetbits_be32(&immr->sysconf.sicrh, SICRH_SPI, SICRH_SPI_SD); +#endif return 0; }
#ifdef CONFIG_FSL_ESDHC +#if !(CONFIG_IS_ENABLED(DM_MMC)) int board_mmc_init(bd_t *bd) { struct immap __iomem *im = (struct immap __iomem *)CONFIG_SYS_IMMR; @@ -186,6 +192,7 @@ int board_mmc_init(bd_t *bd) return fsl_esdhc_mmc_init(bd); } #endif +#endif
/* * Miscellaneous late-boot configurations diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index fd8335ee4e..8ef193a6e5 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -160,7 +160,11 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="mpc8379erdb" CONFIG_ENV_ADDR=0xFE080000 +CONFIG_DM=y +CONFIG_DM_MMC=y CONFIG_FSL_SATA=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y @@ -174,4 +178,3 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y -- 2.14.5
HI,
On 4/4/20 6:36 AM, sinan@writeme.com wrote:
I'm not sure but its subject is strange. It's not only the converting to DM_MMC. you're adding mpc8397.dtb device-tree. I think you don't add device-tree for only mmc.
It's better to separate patches. "Add devicetree...", " Convert to DM_MMC". It's just my opinion.
Best Regards, Jaehoon Chung
- MPC8379E RDB Device Tree Source
- Copyright 2020 NXP
+/dts-v1/;
- compatible = "fsl,mpc8379erdb";
- #address-cells = <1>;
- #size-cells = <1>;
- aliases {
serial0 = &serial0;
serial1 = &serial1;
- cpus {
#size-cells = <0>;
PowerPC,8379@0 {
reg = <0x0>;
- memory {
- localbus@e0005000 {
#size-cells = <1>;
- immr@e0000000 {
#size-cells = <1>;
wdt@200 {
gpio0: gpio@c00 {
#gpio-cells = <2>;
reg = <0xc00 0x18>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
i2c@3000 {
#size-cells = <0>;
cell-index = <0>;
dfsrr;
i2c@3100 {
#size-cells = <0>;
cell-index = <1>;
dfsrr;
spi@7000 {
#size-cells = <0>;
cell-index = <0>;
mode = "cpu";
sdhc@2e000 {
bus-width = <0x4>;
cell-index = <0>;
cell-index = <1>;
pmc: power@b00 {
usb@23000 {
#size-cells = <0>;
phy_type = "ulpi";
#size-cells = <1>;
cell-index = <0>;
model = "eTSEC";
fsl,magic-packet;
mdio@520 {
#size-cells = <0>;
reg = <0x520 0x20>;
reg = <0x2>;
tbi0: tbi-phy@11 {
reg = <0x11>;
#size-cells = <1>;
cell-index = <1>;
model = "eTSEC";
fsl,magic-packet;
mdio@520 {
#size-cells = <0>;
reg = <0x520 0x20>;
tbi1: tbi-phy@11 {
reg = <0x11>;
- clrsetbits_be32(&immr->sysconf.sicrl, SICRL_USB_B, SICRL_USB_B_SD);
- clrsetbits_be32(&immr->sysconf.sicrh, SICRH_SPI, SICRH_SPI_SD);
+#endif return 0; }
- Miscellaneous late-boot configurations
-CONFIG_OF_LIBFDT=y
2.14.5
Hi Jehoon
On 2020-04-03 7:59 p.m., Jaehoon Chung wrote:
HI,
You are right. I will split the patch into two and for dts I will have only the related nodes.
Thanks for your comments.
Regards Sinan Akman
Signed-off-by: Sinan Akman sinan@writeme.com --- Changes for v2: - Split patches for device tree and DM_MMC
arch/powerpc/dts/Makefile | 1 + arch/powerpc/dts/mpc8379erdb.dts | 74 ++++++++++++++++++++++++++++++++++++++++ 2 files changed, 75 insertions(+) create mode 100644 arch/powerpc/dts/mpc8379erdb.dts
+dtb-$(CONFIG_TARGET_MPC837XERDB) += mpc8379erdb.dtb dtb-$(CONFIG_TARGET_MPC8548CDS) += mpc8548cds.dtb mpc8548cds_36b.dtb dtb-$(CONFIG_TARGET_P1020RDB_PC) += p1020rdb-pc.dtb p1020rdb-pc_36b.dtb dtb-$(CONFIG_TARGET_P1020RDB_PD) += p1020rdb-pd.dtb diff --git a/arch/powerpc/dts/mpc8379erdb.dts b/arch/powerpc/dts/mpc8379erdb.dts new file mode 100644 index 0000000000..b1881b161c --- /dev/null +++ b/arch/powerpc/dts/mpc8379erdb.dts @@ -0,0 +1,74 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * MPC8379E RDB Device Tree Source + * + * Copyright 2020 NXP + */ + +/dts-v1/; + +/ { + compatible = "fsl,mpc8379erdb"; + + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + PowerPC,8379@0 { + device_type = "cpu"; + reg = <0x0>; + d-cache-line-size = <32>; + i-cache-line-size = <32>; + d-cache-size = <32768>; + i-cache-size = <32768>; + timebase-frequency = <0>; + bus-frequency = <0>; + clock-frequency = <0>; + }; + }; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; // 256MB at 0 + }; + + localbus@e0005000 { + #address-cells = <2>; + #size-cells = <1>; + compatible = "fsl,elbc", "simple-bus"; + reg = <0xe0005000 0x1000>; + interrupts = <77 0x8>; + interrupt-parent = <&ipic>; + }; + + immr@e0000000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "soc"; + compatible = "simple-bus"; + ranges = <0 0xe0000000 0x00100000>; + reg = <0xe0000000 0x00000200>; + bus-frequency = <0>; + + sdhc@2e000 { + compatible = "fsl,esdhc"; + reg = <0x2e000 0x1000>; + bus-width = <0x4>; + clock-frequency = <0>; + }; + + ipic: interrupt-controller@700 { + compatible = "fsl,ipic"; + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <2>; + reg = <0x700 0x100>; + device_type = "ipic"; + }; + + }; + +}; -- 2.14.5
board/freescale/mpc837xerdb/mpc837xerdb.c | 9 ++++++++- configs/MPC837XERDB_defconfig | 5 ++++- 2 files changed, 12 insertions(+), 2 deletions(-)
Jaehoon Chung
Sinan Akman
sinan@writeme.com
