[U-Boot] [PATCH v3 00/11] SF: Cadence QSPI driver fixes and clean up
This series has fixes, patches to clean the code up, and add support for specifying the sampling edge.
Main changes in v3: 1. Added "spi: cadence_qspi: Use spi mode at the point it is needed" to address comments for SPI pol/phase code. 2. "spi: cadence_qspi: Support specifying the sample edge used" has been split into 3 separate patches.
Phil Edworthy (11): spi: cadence_qspi: Fix clearing of pol/pha bits spi: cadence_qspi: Fix baud rate calculation spi: cadence_qspi: Better debug information on the SPI clock rate spi: cadence_qspi: Use #define for bits instead of bit shifts spi: cadence_qspi: Clean up the #define names spi: cadence_qspi: Use spi mode at the point it is needed spi: cadence_qspi: Remove returns from end of void functions spi: cadence_qspi: Fix CS timings spi: cadence_qspi: Move DT prop code to match layout spi: cadence_qspi: Change readdata_capture() arg to bool spi: cadence_qspi: Support specifying the sample edge used
doc/device-tree-bindings/spi/spi-cadence.txt | 2 + drivers/spi/cadence_qspi.c | 17 ++- drivers/spi/cadence_qspi.h | 6 +- drivers/spi/cadence_qspi_apb.c | 193 +++++++++++++-------------- 4 files changed, 106 insertions(+), 112 deletions(-)
Or'ing together bit positions is clearly wrong.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com Acked-by: Marek Vasut marek.vasut@gmail.com --- v3: - No change. v2: - No change. --- drivers/spi/cadence_qspi_apb.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index e285d3c..2403e71 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -311,8 +311,8 @@ void cadence_qspi_apb_set_clk_mode(void *reg_base,
cadence_qspi_apb_controller_disable(reg_base); reg = readl(reg_base + CQSPI_REG_CONFIG); - reg &= ~(1 << - (CQSPI_REG_CONFIG_CLK_POL_LSB | CQSPI_REG_CONFIG_CLK_PHA_LSB)); + reg &= ~(1 << CQSPI_REG_CONFIG_CLK_POL_LSB); + reg &= ~(1 << CQSPI_REG_CONFIG_CLK_PHA_LSB);
reg |= ((clk_pol & 0x1) << CQSPI_REG_CONFIG_CLK_POL_LSB); reg |= ((clk_pha & 0x1) << CQSPI_REG_CONFIG_CLK_PHA_LSB);
On Tue, Nov 29, 2016 at 6:28 PM, Phil Edworthy phil.edworthy@renesas.com wrote:
Reviewed-by: Jagan Teki jagan@openedev.com
thanks!
With the existing code, when the requested SPI clock rate is near to the lowest that can be achieved by the hardware (max divider of the ref clock is 32), the generated clock rate is wrong. For example, with a 50MHz ref clock, when asked for anything less than a 1.5MHz SPI clock, the code sets up the divider to generate 25MHz.
This change fixes the calculation.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- v3: - Use single line DIV_ROUND_UP instead of two v2: - Use the DIV_ROUND_UP macro --- drivers/spi/cadence_qspi_apb.c | 22 ++++++---------------- 1 file changed, 6 insertions(+), 16 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 2403e71..b5c664f 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -273,22 +273,12 @@ void cadence_qspi_apb_config_baudrate_div(void *reg_base, reg = readl(reg_base + CQSPI_REG_CONFIG); reg &= ~(CQSPI_REG_CONFIG_BAUD_MASK << CQSPI_REG_CONFIG_BAUD_LSB);
- div = ref_clk_hz / sclk_hz; - - if (div > 32) - div = 32; - - /* Check if even number. */ - if ((div & 1)) { - div = (div / 2); - } else { - if (ref_clk_hz % sclk_hz) - /* ensure generated SCLK doesn't exceed user - specified sclk_hz */ - div = (div / 2); - else - div = (div / 2) - 1; - } + /* + * The baud_div field in the config reg is 4 bits, and the ref clock is + * divided by 2 * (baud_div + 1). Round up the divider to ensure the + * SPI clock rate is less than or equal to the requested clock rate. + */ + div = DIV_ROUND_UP(ref_clk_hz, sclk_hz * 2) - 1;
debug("%s: ref_clk %dHz sclk %dHz Div 0x%x\n", __func__, ref_clk_hz, sclk_hz, div);
Perhaps you missed, Marek Acked-by tag on previous version, don't worry will add while applying if any.
thanks!
Show what the output clock rate actually is.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com Acked-by: Marek Vasut marek.vasut@gmail.com --- v3: - No change. v2: - No change. --- drivers/spi/cadence_qspi_apb.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index b5c664f..0a2963d 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -280,13 +280,13 @@ void cadence_qspi_apb_config_baudrate_div(void *reg_base, */ div = DIV_ROUND_UP(ref_clk_hz, sclk_hz * 2) - 1;
- debug("%s: ref_clk %dHz sclk %dHz Div 0x%x\n", __func__, - ref_clk_hz, sclk_hz, div); - /* ensure the baud rate doesn't exceed the max value */ if (div > CQSPI_REG_CONFIG_BAUD_MASK) div = CQSPI_REG_CONFIG_BAUD_MASK;
+ debug("%s: ref_clk %dHz sclk %dHz Div 0x%x, actual %dHz\n", __func__, + ref_clk_hz, sclk_hz, div, ref_clk_hz / (2 * (div + 1))); + reg |= (div << CQSPI_REG_CONFIG_BAUD_LSB); writel(reg, reg_base + CQSPI_REG_CONFIG);
thanks!
Most of the code already uses #defines for the bit value, rather than the shift required to get the value. This changes the remaining code over.
Whislt at it, fix the names of the "Rd Data Capture" register defs.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com Acked-by: Marek Vasut marek.vasut@gmail.com --- v3: - Remove brackets that aren't needed. v2: - No change. --- drivers/spi/cadence_qspi_apb.c | 37 +++++++++++++++++++------------------ 1 file changed, 19 insertions(+), 18 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 0a2963d..b41f36b 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -57,9 +57,9 @@ * Controller's configuration and status register (offset from QSPI_BASE) ****************************************************************************/ #define CQSPI_REG_CONFIG 0x00 -#define CQSPI_REG_CONFIG_CLK_POL_LSB 1 -#define CQSPI_REG_CONFIG_CLK_PHA_LSB 2 #define CQSPI_REG_CONFIG_ENABLE_MASK BIT(0) +#define CQSPI_REG_CONFIG_CLK_POL BIT(1) +#define CQSPI_REG_CONFIG_CLK_PHA BIT(2) #define CQSPI_REG_CONFIG_DIRECT_MASK BIT(7) #define CQSPI_REG_CONFIG_DECODE_MASK BIT(9) #define CQSPI_REG_CONFIG_XIP_IMM_MASK BIT(18) @@ -94,10 +94,10 @@ #define CQSPI_REG_DELAY_TSD2D_MASK 0xFF #define CQSPI_REG_DELAY_TSHSL_MASK 0xFF
-#define CQSPI_READLCAPTURE 0x10 -#define CQSPI_READLCAPTURE_BYPASS_LSB 0 -#define CQSPI_READLCAPTURE_DELAY_LSB 1 -#define CQSPI_READLCAPTURE_DELAY_MASK 0xF +#define CQSPI_REG_RD_DATA_CAPTURE 0x10 +#define CQSPI_REG_RD_DATA_CAPTURE_BYPASS BIT(0) +#define CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB 1 +#define CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK 0xF
#define CQSPI_REG_SIZE 0x14 #define CQSPI_REG_SIZE_ADDRESS_LSB 0 @@ -244,20 +244,20 @@ void cadence_qspi_apb_readdata_capture(void *reg_base, unsigned int reg; cadence_qspi_apb_controller_disable(reg_base);
- reg = readl(reg_base + CQSPI_READLCAPTURE); + reg = readl(reg_base + CQSPI_REG_RD_DATA_CAPTURE);
if (bypass) - reg |= (1 << CQSPI_READLCAPTURE_BYPASS_LSB); + reg |= CQSPI_REG_RD_DATA_CAPTURE_BYPASS; else - reg &= ~(1 << CQSPI_READLCAPTURE_BYPASS_LSB); + reg &= ~CQSPI_REG_RD_DATA_CAPTURE_BYPASS;
- reg &= ~(CQSPI_READLCAPTURE_DELAY_MASK - << CQSPI_READLCAPTURE_DELAY_LSB); + reg &= ~(CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK + << CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB);
- reg |= ((delay & CQSPI_READLCAPTURE_DELAY_MASK) - << CQSPI_READLCAPTURE_DELAY_LSB); + reg |= (delay & CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK) + << CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB;
- writel(reg, reg_base + CQSPI_READLCAPTURE); + writel(reg, reg_base + CQSPI_REG_RD_DATA_CAPTURE);
cadence_qspi_apb_controller_enable(reg_base); return; @@ -301,11 +301,12 @@ void cadence_qspi_apb_set_clk_mode(void *reg_base,
cadence_qspi_apb_controller_disable(reg_base); reg = readl(reg_base + CQSPI_REG_CONFIG); - reg &= ~(1 << CQSPI_REG_CONFIG_CLK_POL_LSB); - reg &= ~(1 << CQSPI_REG_CONFIG_CLK_PHA_LSB); + reg &= ~(CQSPI_REG_CONFIG_CLK_POL | CQSPI_REG_CONFIG_CLK_PHA);
- reg |= ((clk_pol & 0x1) << CQSPI_REG_CONFIG_CLK_POL_LSB); - reg |= ((clk_pha & 0x1) << CQSPI_REG_CONFIG_CLK_PHA_LSB); + if (clk_pol) + reg |= CQSPI_REG_CONFIG_CLK_POL; + if (clk_pha) + reg |= CQSPI_REG_CONFIG_CLK_PHA;
v3:
v2:
- No change.
- Controller's configuration and status register (offset from QSPI_BASE)
reg = readl(reg_base + CQSPI_REG_RD_DATA_CAPTURE); if (bypass)
writel(reg, reg_base + CQSPI_REG_RD_DATA_CAPTURE); cadence_qspi_apb_controller_enable(reg_base); return;
if (clk_pol)
if (clk_pha)
I've commented about this change [1]?
[1] https://www.mail-archive.com/u-boot@lists.denx.de/msg232120.html
thanks!
Hi Jagan,
v3:
v2:
- No change.
*reg_base,
*reg_base,
if (clk_pol)
if (clk_pha)
Yes, I fixed that in a separate patch, see https://www.mail-archive.com/u-boot@lists.denx.de/msg232489.html
I did it in a separate patch because this patch is purely about replacing the definitions of bit shifts with BIT(x).
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
Thanks Phil
On Wed, Nov 30, 2016 at 1:02 PM, Phil Edworthy phil.edworthy@renesas.com wrote:
Hi Jagan,
<snip>
thanks!
A lot of the #defines are for single bits in a register, where the name has _MASK on the end. Since this can be used for both a mask and the value, remove _MASK from them.
Whilst doing so, also remove the unnecessary brackets around the constants.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com Acked-by: Marek Vasut marek.vasut@gmail.com --- v3: - No change. v2: - No change. --- drivers/spi/cadence_qspi_apb.c | 86 +++++++++++++++++++++--------------------- 1 file changed, 43 insertions(+), 43 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index b41f36b..634a857 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -32,37 +32,37 @@ #include <spi.h> #include "cadence_qspi.h"
-#define CQSPI_REG_POLL_US (1) /* 1us */ -#define CQSPI_REG_RETRY (10000) -#define CQSPI_POLL_IDLE_RETRY (3) +#define CQSPI_REG_POLL_US 1 /* 1us */ +#define CQSPI_REG_RETRY 10000 +#define CQSPI_POLL_IDLE_RETRY 3
-#define CQSPI_FIFO_WIDTH (4) +#define CQSPI_FIFO_WIDTH 4
-#define CQSPI_REG_SRAM_THRESHOLD_WORDS (50) +#define CQSPI_REG_SRAM_THRESHOLD_WORDS 50
/* Transfer mode */ -#define CQSPI_INST_TYPE_SINGLE (0) -#define CQSPI_INST_TYPE_DUAL (1) -#define CQSPI_INST_TYPE_QUAD (2) +#define CQSPI_INST_TYPE_SINGLE 0 +#define CQSPI_INST_TYPE_DUAL 1 +#define CQSPI_INST_TYPE_QUAD 2
-#define CQSPI_STIG_DATA_LEN_MAX (8) - -#define CQSPI_DUMMY_CLKS_PER_BYTE (8) -#define CQSPI_DUMMY_BYTES_MAX (4) +#define CQSPI_STIG_DATA_LEN_MAX 8
+#define CQSPI_DUMMY_CLKS_PER_BYTE 8 +#define CQSPI_DUMMY_BYTES_MAX 4
#define CQSPI_REG_SRAM_FILL_THRESHOLD \ ((CQSPI_REG_SRAM_SIZE_WORD / 2) * CQSPI_FIFO_WIDTH) + /**************************************************************************** * Controller's configuration and status register (offset from QSPI_BASE) ****************************************************************************/ #define CQSPI_REG_CONFIG 0x00 -#define CQSPI_REG_CONFIG_ENABLE_MASK BIT(0) +#define CQSPI_REG_CONFIG_ENABLE BIT(0) #define CQSPI_REG_CONFIG_CLK_POL BIT(1) #define CQSPI_REG_CONFIG_CLK_PHA BIT(2) -#define CQSPI_REG_CONFIG_DIRECT_MASK BIT(7) -#define CQSPI_REG_CONFIG_DECODE_MASK BIT(9) -#define CQSPI_REG_CONFIG_XIP_IMM_MASK BIT(18) +#define CQSPI_REG_CONFIG_DIRECT BIT(7) +#define CQSPI_REG_CONFIG_DECODE BIT(9) +#define CQSPI_REG_CONFIG_XIP_IMM BIT(18) #define CQSPI_REG_CONFIG_CHIPSELECT_LSB 10 #define CQSPI_REG_CONFIG_BAUD_LSB 19 #define CQSPI_REG_CONFIG_IDLE_LSB 31 @@ -123,18 +123,18 @@ #define CQSPI_REG_IRQMASK 0x44
#define CQSPI_REG_INDIRECTRD 0x60 -#define CQSPI_REG_INDIRECTRD_START_MASK BIT(0) -#define CQSPI_REG_INDIRECTRD_CANCEL_MASK BIT(1) -#define CQSPI_REG_INDIRECTRD_INPROGRESS_MASK BIT(2) -#define CQSPI_REG_INDIRECTRD_DONE_MASK BIT(5) +#define CQSPI_REG_INDIRECTRD_START BIT(0) +#define CQSPI_REG_INDIRECTRD_CANCEL BIT(1) +#define CQSPI_REG_INDIRECTRD_INPROGRESS BIT(2) +#define CQSPI_REG_INDIRECTRD_DONE BIT(5)
#define CQSPI_REG_INDIRECTRDWATERMARK 0x64 #define CQSPI_REG_INDIRECTRDSTARTADDR 0x68 #define CQSPI_REG_INDIRECTRDBYTES 0x6C
#define CQSPI_REG_CMDCTRL 0x90 -#define CQSPI_REG_CMDCTRL_EXECUTE_MASK BIT(0) -#define CQSPI_REG_CMDCTRL_INPROGRESS_MASK BIT(1) +#define CQSPI_REG_CMDCTRL_EXECUTE BIT(0) +#define CQSPI_REG_CMDCTRL_INPROGRESS BIT(1) #define CQSPI_REG_CMDCTRL_DUMMY_LSB 7 #define CQSPI_REG_CMDCTRL_WR_BYTES_LSB 12 #define CQSPI_REG_CMDCTRL_WR_EN_LSB 15 @@ -150,10 +150,10 @@ #define CQSPI_REG_CMDCTRL_OPCODE_MASK 0xFF
#define CQSPI_REG_INDIRECTWR 0x70 -#define CQSPI_REG_INDIRECTWR_START_MASK BIT(0) -#define CQSPI_REG_INDIRECTWR_CANCEL_MASK BIT(1) -#define CQSPI_REG_INDIRECTWR_INPROGRESS_MASK BIT(2) -#define CQSPI_REG_INDIRECTWR_DONE_MASK BIT(5) +#define CQSPI_REG_INDIRECTWR_START BIT(0) +#define CQSPI_REG_INDIRECTWR_CANCEL BIT(1) +#define CQSPI_REG_INDIRECTWR_INPROGRESS BIT(2) +#define CQSPI_REG_INDIRECTWR_DONE BIT(5)
#define CQSPI_REG_INDIRECTWRWATERMARK 0x74 #define CQSPI_REG_INDIRECTWRSTARTADDR 0x78 @@ -197,7 +197,7 @@ void cadence_qspi_apb_controller_enable(void *reg_base) { unsigned int reg; reg = readl(reg_base + CQSPI_REG_CONFIG); - reg |= CQSPI_REG_CONFIG_ENABLE_MASK; + reg |= CQSPI_REG_CONFIG_ENABLE; writel(reg, reg_base + CQSPI_REG_CONFIG); return; } @@ -206,7 +206,7 @@ void cadence_qspi_apb_controller_disable(void *reg_base) { unsigned int reg; reg = readl(reg_base + CQSPI_REG_CONFIG); - reg &= ~CQSPI_REG_CONFIG_ENABLE_MASK; + reg &= ~CQSPI_REG_CONFIG_ENABLE; writel(reg, reg_base + CQSPI_REG_CONFIG); return; } @@ -327,9 +327,9 @@ void cadence_qspi_apb_chipselect(void *reg_base, reg = readl(reg_base + CQSPI_REG_CONFIG); /* docoder */ if (decoder_enable) { - reg |= CQSPI_REG_CONFIG_DECODE_MASK; + reg |= CQSPI_REG_CONFIG_DECODE; } else { - reg &= ~CQSPI_REG_CONFIG_DECODE_MASK; + reg &= ~CQSPI_REG_CONFIG_DECODE; /* Convert CS if without decoder. * CS0 to 4b'1110 * CS1 to 4b'1101 @@ -423,12 +423,12 @@ static int cadence_qspi_apb_exec_flash_cmd(void *reg_base, /* Write the CMDCTRL without start execution. */ writel(reg, reg_base + CQSPI_REG_CMDCTRL); /* Start execute */ - reg |= CQSPI_REG_CMDCTRL_EXECUTE_MASK; + reg |= CQSPI_REG_CMDCTRL_EXECUTE; writel(reg, reg_base + CQSPI_REG_CMDCTRL);
while (retry--) { reg = readl(reg_base + CQSPI_REG_CMDCTRL); - if ((reg & CQSPI_REG_CMDCTRL_INPROGRESS_MASK) == 0) + if ((reg & CQSPI_REG_CMDCTRL_INPROGRESS) == 0) break; udelay(1); } @@ -646,7 +646,7 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, writel(n_rx, plat->regbase + CQSPI_REG_INDIRECTRDBYTES);
/* Start the indirect read transfer */ - writel(CQSPI_REG_INDIRECTRD_START_MASK, + writel(CQSPI_REG_INDIRECTRD_START, plat->regbase + CQSPI_REG_INDIRECTRD);
while (remaining > 0) { @@ -675,21 +675,21 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat,
/* Check indirect done status */ ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_INDIRECTRD, - CQSPI_REG_INDIRECTRD_DONE_MASK, 1, 10, 0); + CQSPI_REG_INDIRECTRD_DONE, 1, 10, 0); if (ret) { printf("Indirect read completion error (%i)\n", ret); goto failrd; }
/* Clear indirect completion status */ - writel(CQSPI_REG_INDIRECTRD_DONE_MASK, + writel(CQSPI_REG_INDIRECTRD_DONE, plat->regbase + CQSPI_REG_INDIRECTRD);
failrd: /* Cancel the indirect read */ - writel(CQSPI_REG_INDIRECTRD_CANCEL_MASK, + writel(CQSPI_REG_INDIRECTRD_CANCEL, plat->regbase + CQSPI_REG_INDIRECTRD); return ret; } @@ -737,7 +737,7 @@ int cadence_qspi_apb_indirect_write_execute(struct cadence_spi_platdata *plat, writel(n_tx, plat->regbase + CQSPI_REG_INDIRECTWRBYTES);
/* Start the indirect write transfer */ - writel(CQSPI_REG_INDIRECTWR_START_MASK, + writel(CQSPI_REG_INDIRECTWR_START, plat->regbase + CQSPI_REG_INDIRECTWR);
while (remaining > 0) { @@ -762,20 +762,20 @@ int cadence_qspi_apb_indirect_write_execute(struct cadence_spi_platdata *plat,
/* Check indirect done status */ ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_INDIRECTWR, - CQSPI_REG_INDIRECTWR_DONE_MASK, 1, 10, 0); + CQSPI_REG_INDIRECTWR_DONE, 1, 10, 0); if (ret) { printf("Indirect write completion error (%i)\n", ret); goto failwr; }
/* Clear indirect completion status */ - writel(CQSPI_REG_INDIRECTWR_DONE_MASK, + writel(CQSPI_REG_INDIRECTWR_DONE, plat->regbase + CQSPI_REG_INDIRECTWR); return 0;
failwr: /* Cancel the indirect write */ - writel(CQSPI_REG_INDIRECTWR_CANCEL_MASK, + writel(CQSPI_REG_INDIRECTWR_CANCEL, plat->regbase + CQSPI_REG_INDIRECTWR); return ret; } @@ -786,9 +786,9 @@ void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy)
/* enter XiP mode immediately and enable direct mode */ reg = readl(reg_base + CQSPI_REG_CONFIG); - reg |= CQSPI_REG_CONFIG_ENABLE_MASK; - reg |= CQSPI_REG_CONFIG_DIRECT_MASK; - reg |= CQSPI_REG_CONFIG_XIP_IMM_MASK; + reg |= CQSPI_REG_CONFIG_ENABLE; + reg |= CQSPI_REG_CONFIG_DIRECT; + reg |= CQSPI_REG_CONFIG_XIP_IMM; writel(reg, reg_base + CQSPI_REG_CONFIG);
/* keep the XiP mode */
thanks!
Instead of extracting mode settings and passing them as separate args to another function, just pass the SPI mode as an arg.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- v3: - New patch introduced to address comments. --- drivers/spi/cadence_qspi.c | 4 +--- drivers/spi/cadence_qspi.h | 3 +-- drivers/spi/cadence_qspi_apb.c | 7 +++---- 3 files changed, 5 insertions(+), 9 deletions(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 1051afb..55192d6 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -170,14 +170,12 @@ static int cadence_spi_probe(struct udevice *bus) static int cadence_spi_set_mode(struct udevice *bus, uint mode) { struct cadence_spi_priv *priv = dev_get_priv(bus); - unsigned int clk_pol = (mode & SPI_CPOL) ? 1 : 0; - unsigned int clk_pha = (mode & SPI_CPHA) ? 1 : 0;
/* Disable QSPI */ cadence_qspi_apb_controller_disable(priv->regbase);
/* Set SPI mode */ - cadence_qspi_apb_set_clk_mode(priv->regbase, clk_pol, clk_pha); + cadence_qspi_apb_set_clk_mode(priv->regbase, mode);
/* Enable QSPI */ cadence_qspi_apb_controller_enable(priv->regbase); diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index a849f7b..d1927a4 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -63,8 +63,7 @@ int cadence_qspi_apb_indirect_write_execute(struct cadence_spi_platdata *plat,
void cadence_qspi_apb_chipselect(void *reg_base, unsigned int chip_select, unsigned int decoder_enable); -void cadence_qspi_apb_set_clk_mode(void *reg_base_addr, - unsigned int clk_pol, unsigned int clk_pha); +void cadence_qspi_apb_set_clk_mode(void *reg_base, uint mode); void cadence_qspi_apb_config_baudrate_div(void *reg_base, unsigned int ref_clk_hz, unsigned int sclk_hz); void cadence_qspi_apb_delay(void *reg_base, diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 634a857..e81d678 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -294,8 +294,7 @@ void cadence_qspi_apb_config_baudrate_div(void *reg_base, return; }
-void cadence_qspi_apb_set_clk_mode(void *reg_base, - unsigned int clk_pol, unsigned int clk_pha) +void cadence_qspi_apb_set_clk_mode(void *reg_base, uint mode) { unsigned int reg;
@@ -303,9 +302,9 @@ void cadence_qspi_apb_set_clk_mode(void *reg_base, reg = readl(reg_base + CQSPI_REG_CONFIG); reg &= ~(CQSPI_REG_CONFIG_CLK_POL | CQSPI_REG_CONFIG_CLK_PHA);
- if (clk_pol) + if (mode & SPI_CPOL) reg |= CQSPI_REG_CONFIG_CLK_POL; - if (clk_pha) + if (mode & SPI_CPHA) reg |= CQSPI_REG_CONFIG_CLK_PHA;
thanks!
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com Acked-by: Marek Vasut marek.vasut@gmail.com --- v3: - No change. v2: - No change. --- drivers/spi/cadence_qspi_apb.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index e81d678..39e31f6 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -199,7 +199,6 @@ void cadence_qspi_apb_controller_enable(void *reg_base) reg = readl(reg_base + CQSPI_REG_CONFIG); reg |= CQSPI_REG_CONFIG_ENABLE; writel(reg, reg_base + CQSPI_REG_CONFIG); - return; }
void cadence_qspi_apb_controller_disable(void *reg_base) @@ -208,7 +207,6 @@ void cadence_qspi_apb_controller_disable(void *reg_base) reg = readl(reg_base + CQSPI_REG_CONFIG); reg &= ~CQSPI_REG_CONFIG_ENABLE; writel(reg, reg_base + CQSPI_REG_CONFIG); - return; }
/* Return 1 if idle, otherwise return 0 (busy). */ @@ -260,7 +258,6 @@ void cadence_qspi_apb_readdata_capture(void *reg_base, writel(reg, reg_base + CQSPI_REG_RD_DATA_CAPTURE);
cadence_qspi_apb_controller_enable(reg_base); - return; }
void cadence_qspi_apb_config_baudrate_div(void *reg_base, @@ -291,7 +288,6 @@ void cadence_qspi_apb_config_baudrate_div(void *reg_base, writel(reg, reg_base + CQSPI_REG_CONFIG);
void cadence_qspi_apb_set_clk_mode(void *reg_base, uint mode) @@ -310,7 +306,6 @@ void cadence_qspi_apb_set_clk_mode(void *reg_base, uint mode) writel(reg, reg_base + CQSPI_REG_CONFIG);
void cadence_qspi_apb_chipselect(void *reg_base, @@ -345,7 +340,6 @@ void cadence_qspi_apb_chipselect(void *reg_base, writel(reg, reg_base + CQSPI_REG_CONFIG);
void cadence_qspi_apb_delay(void *reg_base, @@ -383,7 +377,6 @@ void cadence_qspi_apb_delay(void *reg_base, writel(reg, reg_base + CQSPI_REG_DELAY);
void cadence_qspi_apb_controller_init(struct cadence_spi_platdata *plat) @@ -411,7 +404,6 @@ void cadence_qspi_apb_controller_init(struct cadence_spi_platdata *plat) writel(0, plat->regbase + CQSPI_REG_IRQMASK);
cadence_qspi_apb_controller_enable(plat->regbase); - return; }
thanks!
The Cadence QSPI controller has specified overheads for the various CS times that are in addition to those programmed in to the Device Delay register. The overheads are different for the delays.
In addition, the existing code does not handle the case when the delay is less than a SCLK period.
This change accurately calculates the additional delays in Ref clocks.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- v3: - No change. v2: Was "spi: cadence_qspi: Fix CQSPI_CAL_DELAY calculation" Note only did the existing code not cope with the delay less than an SCLK period, but the calculation didn't round properly, and didn't take into account the delays that the QSPI Controller adds to those programmed into the Device Delay reg. --- drivers/spi/cadence_qspi_apb.c | 23 ++++++++++++----------- 1 file changed, 12 insertions(+), 11 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 39e31f6..df6a91f 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -169,9 +169,6 @@ ((readl(base + CQSPI_REG_CONFIG) >> \ CQSPI_REG_CONFIG_IDLE_LSB) & 0x1)
-#define CQSPI_CAL_DELAY(tdelay_ns, tref_ns, tsclk_ns) \ - ((((tdelay_ns) - (tsclk_ns)) / (tref_ns))) - #define CQSPI_GET_RD_SRAM_LEVEL(reg_base) \ (((readl(reg_base + CQSPI_REG_SDRAMLEVEL)) >> \ CQSPI_REG_SDRAMLEVEL_RD_LSB) & CQSPI_REG_SDRAMLEVEL_RD_MASK) @@ -355,16 +352,20 @@ void cadence_qspi_apb_delay(void *reg_base, cadence_qspi_apb_controller_disable(reg_base);
/* Convert to ns. */ - ref_clk_ns = (1000000000) / ref_clk; + ref_clk_ns = DIV_ROUND_UP(1000000000, ref_clk);
/* Convert to ns. */ - sclk_ns = (1000000000) / sclk_hz; - - /* Plus 1 to round up 1 clock cycle. */ - tshsl = CQSPI_CAL_DELAY(tshsl_ns, ref_clk_ns, sclk_ns) + 1; - tchsh = CQSPI_CAL_DELAY(tchsh_ns, ref_clk_ns, sclk_ns) + 1; - tslch = CQSPI_CAL_DELAY(tslch_ns, ref_clk_ns, sclk_ns) + 1; - tsd2d = CQSPI_CAL_DELAY(tsd2d_ns, ref_clk_ns, sclk_ns) + 1; + sclk_ns = DIV_ROUND_UP(1000000000, sclk_hz); + + /* The controller adds additional delay to that programmed in the reg */ + if (tshsl_ns >= sclk_ns + ref_clk_ns) + tshsl_ns -= sclk_ns + ref_clk_ns; + if (tchsh_ns >= sclk_ns + 3 * ref_clk_ns) + tchsh_ns -= sclk_ns + 3 * ref_clk_ns; + tshsl = DIV_ROUND_UP(tshsl_ns, ref_clk_ns); + tchsh = DIV_ROUND_UP(tchsh_ns, ref_clk_ns); + tslch = DIV_ROUND_UP(tslch_ns, ref_clk_ns); + tsd2d = DIV_ROUND_UP(tsd2d_ns, ref_clk_ns);
reg = ((tshsl & CQSPI_REG_DELAY_TSHSL_MASK) << CQSPI_REG_DELAY_TSHSL_LSB);
Move the code to read the "sram-size" property into the other code that reads properties from the node, rather than the SF subnode.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- v3: - New patch to split changes. --- drivers/spi/cadence_qspi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 55192d6..f16f90d 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -296,6 +296,7 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus)
plat->regbase = (void *)data[0]; plat->ahbbase = (void *)data[2]; + plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128);
/* All other paramters are embedded in the child node */ subnode = fdt_first_subnode(blob, node); @@ -315,7 +316,6 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) plat->tsd2d_ns = fdtdec_get_int(blob, subnode, "tsd2d-ns", 255); plat->tchsh_ns = fdtdec_get_int(blob, subnode, "tchsh-ns", 20); plat->tslch_ns = fdtdec_get_int(blob, subnode, "tslch-ns", 20); - plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128);
debug("%s: regbase=%p ahbbase=%p max-frequency=%d page-size=%d\n", __func__, plat->regbase, plat->ahbbase, plat->max_hz,
thanks!
This is in preparation for adding another arg.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- v3: - New patch to split changes. --- drivers/spi/cadence_qspi.c | 7 ++++--- drivers/spi/cadence_qspi.h | 2 +- drivers/spi/cadence_qspi_apb.c | 2 +- 3 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index f16f90d..1c4ed33 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -49,7 +49,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_spi_write_speed(bus, 1000000);
/* configure the read data capture delay register to 0 */ - cadence_qspi_apb_readdata_capture(base, 1, 0); + cadence_qspi_apb_readdata_capture(base, true, 0);
/* Enable QSPI */ cadence_qspi_apb_controller_enable(base); @@ -69,7 +69,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_disable(base);
/* reconfigure the read data capture delay register */ - cadence_qspi_apb_readdata_capture(base, 1, i); + cadence_qspi_apb_readdata_capture(base, true, i);
/* Enable back QSPI */ cadence_qspi_apb_controller_enable(base); @@ -105,7 +105,8 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_disable(base);
/* configure the final value for read data capture delay register */ - cadence_qspi_apb_readdata_capture(base, 1, (range_hi + range_lo) / 2); + cadence_qspi_apb_readdata_capture(base, true, + (range_hi + range_lo) / 2); debug("SF: Read data capture delay calibrated to %i (%i - %i)\n", (range_hi + range_lo) / 2, range_lo, range_hi);
diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index d1927a4..50c6e7c 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -72,6 +72,6 @@ void cadence_qspi_apb_delay(void *reg_base, unsigned int tchsh_ns, unsigned int tslch_ns); void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy); void cadence_qspi_apb_readdata_capture(void *reg_base, - unsigned int bypass, unsigned int delay); + bool bypass, unsigned int delay);
#endif /* __CADENCE_QSPI_H__ */ diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index df6a91f..f2cd852 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -234,7 +234,7 @@ static unsigned int cadence_qspi_wait_idle(void *reg_base) }
void cadence_qspi_apb_readdata_capture(void *reg_base, - unsigned int bypass, unsigned int delay) + bool bypass, unsigned int delay) { unsigned int reg; cadence_qspi_apb_controller_disable(reg_base);
?? proper reason for changing arg to bool.
thanks!
Hi Jagan,
Purely because the patch 11 adds another arg that is a bool (which is the natural type as it is read from a dtb). Then having this bypass arg as something other than a bool look a bit odd.
Thanks Phil
On Mon, Dec 5, 2016 at 11:07 AM, Phil Edworthy phil.edworthy@renesas.com wrote:
Hi Jagan,
Can't we make this as 11 and saying the reason for bool which is used/compatible with previous dt patch (I mean 11th patch in the current case)?
thanks!
Hi Jagan,
Hi Jagan,
Do you mean swap patches 10 and 11? Then this commit msg is basically to say it is changed to bool to match the other arg? If so, then sure, no problem.
Thanks Phil
thanks!
On 12/05/2016 11:33 AM, Phil Edworthy wrote:
Hi Jagan,
Hi Jagan,
I don't think it makes any sense to swap patches 10 and 11, they seem orthogonal to me.
Introduce a new DT property to specify whether the QSPI Controller samples the data on a rising edge. The default is falling edge. Some versions of the QSPI Controller do not implement this bit, in which case the property should be omitted.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- v3: - Patch split so this one only has code related to the subject. - Commit message updated. v2: - Change name of DT prop and provide details of what it does. Whilst at it, move the code to read the "sram-size" property into the other code that reads properties from the node, rather than the SF subnode.
Also change the code to use a bool for the bypass arg. --- doc/device-tree-bindings/spi/spi-cadence.txt | 2 ++ drivers/spi/cadence_qspi.c | 10 +++++++--- drivers/spi/cadence_qspi.h | 3 ++- drivers/spi/cadence_qspi_apb.c | 8 +++++++- 4 files changed, 18 insertions(+), 5 deletions(-)
diff --git a/doc/device-tree-bindings/spi/spi-cadence.txt b/doc/device-tree-bindings/spi/spi-cadence.txt index c1e2233..94c800b 100644 --- a/doc/device-tree-bindings/spi/spi-cadence.txt +++ b/doc/device-tree-bindings/spi/spi-cadence.txt @@ -26,3 +26,5 @@ connected flash properties select (n_ss_out). - tslch-ns : Delay in master reference clocks between setting n_ss_out low and first bit transfer +- sample-edge-rising : Data outputs from flash memory will be sampled on the + rising edge. Default is falling edge. diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 1c4ed33..6fa917d 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -39,8 +39,10 @@ static int cadence_spi_write_speed(struct udevice *bus, uint hz) /* Calibration sequence to determine the read data capture delay register */ static int spi_calibration(struct udevice *bus, uint hz) { + struct cadence_spi_platdata *plat = bus->platdata; struct cadence_spi_priv *priv = dev_get_priv(bus); void *base = priv->regbase; + bool edge = plat->sample_edge_rising; u8 opcode_rdid = 0x9F; unsigned int idcode = 0, temp = 0; int err = 0, i, range_lo = -1, range_hi = -1; @@ -49,7 +51,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_spi_write_speed(bus, 1000000);
/* configure the read data capture delay register to 0 */ - cadence_qspi_apb_readdata_capture(base, true, 0); + cadence_qspi_apb_readdata_capture(base, true, edge, 0);
/* Enable QSPI */ cadence_qspi_apb_controller_enable(base); @@ -69,7 +71,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_disable(base);
/* reconfigure the read data capture delay register */ - cadence_qspi_apb_readdata_capture(base, true, i); + cadence_qspi_apb_readdata_capture(base, true, edge, i);
/* Enable back QSPI */ cadence_qspi_apb_controller_enable(base); @@ -105,7 +107,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_disable(base);
/* configure the final value for read data capture delay register */ - cadence_qspi_apb_readdata_capture(base, true, + cadence_qspi_apb_readdata_capture(base, true, edge, (range_hi + range_lo) / 2); debug("SF: Read data capture delay calibrated to %i (%i - %i)\n", (range_hi + range_lo) / 2, range_lo, range_hi); @@ -317,6 +319,8 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) plat->tsd2d_ns = fdtdec_get_int(blob, subnode, "tsd2d-ns", 255); plat->tchsh_ns = fdtdec_get_int(blob, subnode, "tchsh-ns", 20); plat->tslch_ns = fdtdec_get_int(blob, subnode, "tslch-ns", 20); + plat->sample_edge_rising = fdtdec_get_bool(blob, subnode, + "sample-edge-rising");
debug("%s: regbase=%p ahbbase=%p max-frequency=%d page-size=%d\n", __func__, plat->regbase, plat->ahbbase, plat->max_hz, diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index 50c6e7c..897e5f0 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -26,6 +26,7 @@ struct cadence_spi_platdata { u32 tchsh_ns; u32 tslch_ns; u32 sram_size; + bool sample_edge_rising; };
struct cadence_spi_priv { @@ -72,6 +73,6 @@ void cadence_qspi_apb_delay(void *reg_base, unsigned int tchsh_ns, unsigned int tslch_ns); void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy); void cadence_qspi_apb_readdata_capture(void *reg_base, - bool bypass, unsigned int delay); + bool bypass, bool edge, unsigned int delay);
#endif /* __CADENCE_QSPI_H__ */ diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index f2cd852..4d1ee65 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -98,6 +98,7 @@ #define CQSPI_REG_RD_DATA_CAPTURE_BYPASS BIT(0) #define CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB 1 #define CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK 0xF +#define CQSPI_REG_RD_DATA_CAPTURE_EDGE BIT(5)
#define CQSPI_REG_SIZE 0x14 #define CQSPI_REG_SIZE_ADDRESS_LSB 0 @@ -234,7 +235,7 @@ static unsigned int cadence_qspi_wait_idle(void *reg_base) }
void cadence_qspi_apb_readdata_capture(void *reg_base, - bool bypass, unsigned int delay) + bool bypass, bool edge, unsigned int delay) { unsigned int reg; cadence_qspi_apb_controller_disable(reg_base); @@ -246,6 +247,11 @@ void cadence_qspi_apb_readdata_capture(void *reg_base, else reg &= ~CQSPI_REG_RD_DATA_CAPTURE_BYPASS;
+ if (edge) + reg |= CQSPI_REG_RD_DATA_CAPTURE_EDGE; + else + reg &= ~CQSPI_REG_RD_DATA_CAPTURE_EDGE; + reg &= ~(CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK << CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB);
v3:
v2:
Code look reasonable, but how Linux handling this with the same dt property, any idea? I couldn't find it either.
thanks!
Hi Jagan,
v3:
v2:
the
The Linux driver does not yet have this property. Is there a policy to add new props to Linux first?
Thanks Phil
On Mon, Dec 5, 2016 at 11:09 AM, Phil Edworthy phil.edworthy@renesas.com wrote:
Hi Jagan,
v3:
v2:
the
If the same/equal code used in Linux better to have the same property instead of another name used in U-boot?
thanks!
HI Jagan,
Hi Jagan,
v3:
v2:
the
Of course, but I cannot see this in Linux: https://git.kernel.org/cgit/linux/kernel/git/next/linux-next.git/tree/Docume...
BR Phil
thanks!
On Mon, Dec 5, 2016 at 11:31 AM, Phil Edworthy phil.edworthy@renesas.com wrote:
HI Jagan,
Hi Jagan,
v3:
v2:
the
Yeah, I saw this. Do you have any idea how Linux handling this sample edge?
thanks!
Hi Jagan,
HI Jagan,
Hi Jagan,
v3:
v2:
tree-
on
the
next.git/tree/Documentation/devicetree/bindings/spi/spi-cadence.txt
The same way U-Boot currently handles it, i.e. it does nothing with this. Intel/Altera (Chin Liang) said that they do not have this bit in their version of the Cadence QSPI Controller.
We are using a later version that has had this bit added.
BR Phil
thanks!
On 12/05/2016 11:46 AM, Phil Edworthy wrote:
Hi Jagan,
HI Jagan,
Hi Jagan,
On Tue, Nov 29, 2016 at 6:28 PM, Phil Edworthy phil.edworthy@renesas.com wrote: > Introduce a new DT property to specify whether the QSPI Controller > samples the data on a rising edge. The default is falling edge. > Some versions of the QSPI Controller do not implement this bit, in > which case the property should be omitted. > > Signed-off-by: Phil Edworthy phil.edworthy@renesas.com > --- > v3: > - Patch split so this one only has code related to the subject. > - Commit message updated. > v2: > - Change name of DT prop and provide details of what it does. > Whilst at it, move the code to read the "sram-size" property > into the other code that reads properties from the node, rather > than the SF subnode. > > Also change the code to use a bool for the bypass arg. > --- > doc/device-tree-bindings/spi/spi-cadence.txt | 2 ++ > drivers/spi/cadence_qspi.c | 10 +++++++--- > drivers/spi/cadence_qspi.h | 3 ++- > drivers/spi/cadence_qspi_apb.c | 8 +++++++- > 4 files changed, 18 insertions(+), 5 deletions(-) > > diff --git a/doc/device-tree-bindings/spi/spi-cadence.txt b/doc/device-
tree-
bindings/spi/spi-cadence.txt > index c1e2233..94c800b 100644 > --- a/doc/device-tree-bindings/spi/spi-cadence.txt > +++ b/doc/device-tree-bindings/spi/spi-cadence.txt > @@ -26,3 +26,5 @@ connected flash properties > select (n_ss_out). > - tslch-ns : Delay in master reference clocks between setting > n_ss_out low and first bit transfer > +- sample-edge-rising : Data outputs from flash memory will be sampled
on
the > + rising edge. Default is falling edge.
You were looking at the wrong bindings: https://git.kernel.org/cgit/linux/kernel/git/next/linux-next.git/tree/Docume...
but yes, Linux does not do support the data edge toggling. I think there was another QSPI patch in Linux which tried adding such property, so check linux-mtd for it. Generic one would be great.
And no, there is no policy for pushing new props to linux first. New DT props should ideally get approved via devicetree@vger though, but that's about it. Also, while I tried backporting the Linux CQSPI driver to U-Boot, but unfortunately, it turned out to be extremely difficult due significant differences between the Linux and U-Boot SPI NOR framework.
Hi Marek,
On 02 December 2016 14:23, Jagan Teki wrote: > On Tue, Nov 29, 2016 at 6:28 PM, Phil Edworthy > phil.edworthy@renesas.com wrote: >> Introduce a new DT property to specify whether the QSPI Controller >> samples the data on a rising edge. The default is falling edge. >> Some versions of the QSPI Controller do not implement this bit, in >> which case the property should be omitted. >> >> Signed-off-by: Phil Edworthy phil.edworthy@renesas.com >> --- >> v3: >> - Patch split so this one only has code related to the subject. >> - Commit message updated. >> v2: >> - Change name of DT prop and provide details of what it does. >> Whilst at it, move the code to read the "sram-size" property >> into the other code that reads properties from the node, rather >> than the SF subnode. >> >> Also change the code to use a bool for the bypass arg. >> --- >> doc/device-tree-bindings/spi/spi-cadence.txt | 2 ++ >> drivers/spi/cadence_qspi.c | 10 +++++++--- >> drivers/spi/cadence_qspi.h | 3 ++- >> drivers/spi/cadence_qspi_apb.c | 8 +++++++- >> 4 files changed, 18 insertions(+), 5 deletions(-) >> >> diff --git a/doc/device-tree-bindings/spi/spi-cadence.txt b/doc/device-
tree-
> bindings/spi/spi-cadence.txt >> index c1e2233..94c800b 100644 >> --- a/doc/device-tree-bindings/spi/spi-cadence.txt >> +++ b/doc/device-tree-bindings/spi/spi-cadence.txt >> @@ -26,3 +26,5 @@ connected flash properties >> select (n_ss_out). >> - tslch-ns : Delay in master reference clocks between setting >> n_ss_out low and first bit transfer >> +- sample-edge-rising : Data outputs from flash memory will be
sampled
on
> the >> + rising edge. Default is falling edge. > > Code look reasonable, but how Linux handling this with the same dt > property, any idea? I couldn't find it either. The Linux driver does not yet have this property. Is there a policy to add
new
Intel/Altera
QSPI
Controller.
You were looking at the wrong bindings: https://git.kernel.org/cgit/linux/kernel/git/next/linux- next.git/tree/Documentation/devicetree/bindings/mtd/cadence-quadspi.txt
Thanks for pointing that out!
I had a search around, but couldn't find anything.
OK, thanks for the information.
Thanks Phil
On 12/06/2016 11:25 AM, Phil Edworthy wrote:
Hi Marek,
On Mon, Dec 5, 2016 at 11:09 AM, Phil Edworthy phil.edworthy@renesas.com wrote: > On 02 December 2016 14:23, Jagan Teki wrote: >> On Tue, Nov 29, 2016 at 6:28 PM, Phil Edworthy >> phil.edworthy@renesas.com wrote: >>> Introduce a new DT property to specify whether the QSPI Controller >>> samples the data on a rising edge. The default is falling edge. >>> Some versions of the QSPI Controller do not implement this bit, in >>> which case the property should be omitted. >>> >>> Signed-off-by: Phil Edworthy phil.edworthy@renesas.com >>> --- >>> v3: >>> - Patch split so this one only has code related to the subject. >>> - Commit message updated. >>> v2: >>> - Change name of DT prop and provide details of what it does. >>> Whilst at it, move the code to read the "sram-size" property >>> into the other code that reads properties from the node, rather >>> than the SF subnode. >>> >>> Also change the code to use a bool for the bypass arg. >>> --- >>> doc/device-tree-bindings/spi/spi-cadence.txt | 2 ++ >>> drivers/spi/cadence_qspi.c | 10 +++++++--- >>> drivers/spi/cadence_qspi.h | 3 ++- >>> drivers/spi/cadence_qspi_apb.c | 8 +++++++- >>> 4 files changed, 18 insertions(+), 5 deletions(-) >>> >>> diff --git a/doc/device-tree-bindings/spi/spi-cadence.txt b/doc/device-
tree-
>> bindings/spi/spi-cadence.txt >>> index c1e2233..94c800b 100644 >>> --- a/doc/device-tree-bindings/spi/spi-cadence.txt >>> +++ b/doc/device-tree-bindings/spi/spi-cadence.txt >>> @@ -26,3 +26,5 @@ connected flash properties >>> select (n_ss_out). >>> - tslch-ns : Delay in master reference clocks between setting >>> n_ss_out low and first bit transfer >>> +- sample-edge-rising : Data outputs from flash memory will be
sampled
on
>> the >>> + rising edge. Default is falling edge. >> >> Code look reasonable, but how Linux handling this with the same dt >> property, any idea? I couldn't find it either. > The Linux driver does not yet have this property. Is there a policy to add
new
Intel/Altera
QSPI
Controller.
Look for negative_edge here: http://www.spinics.net/lists/devicetree/msg153582.html
Thanks Phil
Hi Jagan, Marek,
On 05 December 2016 10:26, Jagan Teki wrote: > On Mon, Dec 5, 2016 at 11:09 AM, Phil Edworthy > phil.edworthy@renesas.com wrote: >> On 02 December 2016 14:23, Jagan Teki wrote: >>> On Tue, Nov 29, 2016 at 6:28 PM, Phil Edworthy >>> phil.edworthy@renesas.com wrote: >>>> Introduce a new DT property to specify whether the QSPI Controller >>>> samples the data on a rising edge. The default is falling edge. >>>> Some versions of the QSPI Controller do not implement this bit, in >>>> which case the property should be omitted.
<snip>
>>> Code look reasonable, but how Linux handling this with the same dt >>> property, any idea? I couldn't find it either. >> The Linux driver does not yet have this property. Is there a policy to add
new
>> props to Linux first? > > If the same/equal code used in Linux better to have the same property > instead of another name used in U-boot? Of course, but I cannot see this in Linux: https://git.kernel.org/cgit/linux/kernel/git/next/linux-
edge?
Intel/Altera
QSPI
Controller.
Since it will take a bit more time to get a generic prop for the sample edge to be ack'd by devicetree@vger, would it make sense to drop it from this series, so we can get the rest in?
Thanks Phil
On Tue, Dec 6, 2016 at 6:00 PM, Phil Edworthy phil.edworthy@renesas.com wrote:
Hi Jagan, Marek,
On Mon, Dec 5, 2016 at 11:31 AM, Phil Edworthy phil.edworthy@renesas.com wrote: > On 05 December 2016 10:26, Jagan Teki wrote: >> On Mon, Dec 5, 2016 at 11:09 AM, Phil Edworthy >> phil.edworthy@renesas.com wrote: >>> On 02 December 2016 14:23, Jagan Teki wrote: >>>> On Tue, Nov 29, 2016 at 6:28 PM, Phil Edworthy >>>> phil.edworthy@renesas.com wrote: >>>>> Introduce a new DT property to specify whether the QSPI Controller >>>>> samples the data on a rising edge. The default is falling edge. >>>>> Some versions of the QSPI Controller do not implement this bit, in >>>>> which case the property should be omitted.
<snip>
>>>> Code look reasonable, but how Linux handling this with the same dt >>>> property, any idea? I couldn't find it either. >>> The Linux driver does not yet have this property. Is there a policy to add
new
>>> props to Linux first? >> >> If the same/equal code used in Linux better to have the same property >> instead of another name used in U-boot? > Of course, but I cannot see this in Linux: > https://git.kernel.org/cgit/linux/kernel/git/next/linux- next.git/tree/Documentation/devicetree/bindings/spi/spi-cadence.txt
edge?
Intel/Altera
QSPI
Controller.
I can drop 10 and 11 from the series, is that OK?
thanks!
Hi Jagan,
Hi Jagan, Marek,
On 05 December 2016 10:42, Jagan Teki wrote: > On Mon, Dec 5, 2016 at 11:31 AM, Phil Edworthy > phil.edworthy@renesas.com wrote: >> On 05 December 2016 10:26, Jagan Teki wrote: >>> On Mon, Dec 5, 2016 at 11:09 AM, Phil Edworthy >>> phil.edworthy@renesas.com wrote: >>>> On 02 December 2016 14:23, Jagan Teki wrote: >>>>> On Tue, Nov 29, 2016 at 6:28 PM, Phil Edworthy >>>>> phil.edworthy@renesas.com wrote: >>>>>> Introduce a new DT property to specify whether the QSPI
Controller
>>>>>> samples the data on a rising edge. The default is falling edge. >>>>>> Some versions of the QSPI Controller do not implement this bit, in >>>>>> which case the property should be omitted.
<snip>
dt
>>>>> property, any idea? I couldn't find it either. >>>> The Linux driver does not yet have this property. Is there a policy to
add
new
>>>> props to Linux first? >>> >>> If the same/equal code used in Linux better to have the same
property
>>> instead of another name used in U-boot? >> Of course, but I cannot see this in Linux: >> https://git.kernel.org/cgit/linux/kernel/git/next/linux- > next.git/tree/Documentation/devicetree/bindings/spi/spi-cadence.txt > > Yeah, I saw this. Do you have any idea how Linux handling this sample
edge?
Intel/Altera
Cadence
QSPI
Controller.
quadspi.txt
Yes please!
Thanks Phil
On Tue, Nov 29, 2016 at 1:58 PM, Phil Edworthy phil.edworthy@renesas.com wrote:
Main changes in v3:
- Added "spi: cadence_qspi: Use spi mode at the point it is needed" to address comments for SPI pol/phase code.
- "spi: cadence_qspi: Support specifying the sample edge used" has been split into 3 separate patches.
Applied to u-boot-spi/master
thanks!
Jagan Teki
Phil Edworthy
