Pull request: u-boot-imx u-boot-imx-20211020
Hi Tom,
this is a first PR for u-boot-imx. I have still a lot of patches in queue, so a second PR will follow. Simon's patches to improve buildman are merged here (thanks, else I had no idea how to discover the cause of crashes). CI ran with them.
The following changes since commit ea67f467a43e4c8852bd1ce1bb75f5dc6c3788d1:
Merge branch '2021-10-06-assorted-improvements' (2021-10-06 13:46:31 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git
for you to fetch changes up to f0045799c6957e374cc12a6146ac60881cd827d6:
imx8mm-cl-iot-gate-optee: align config with Kconfig (2021-10-20 12:13:44 +0200)
---------------------------------------------------------------- Andrej Rosano (2): imx53: usbarmory: Add card detect configuration imx53: usbarmory: Use ethernet driver model
Andrey Zhizhikin (1): tree: imx: remove old fit generator script
Fabio Estevam (4): imx8mm-cl-iot-gate: Split the defconfigs smegw01: Pass 'mmcpart' to the kernel command line smegw01: Add redundant environment support smegw01: Select IMX_HAB
Francesco Dolcini (2): colibri-imx6: use dynamic DDR calibration apalis-imx6: use dynamic DDR calibration
Frieder Schrempf (2): imx: imx6ul: Add support for Kontron Electronics SL/BL i.MX6UL/ULL boards (N63xx/N64xx) imx: imx8mm: Add support for Kontron Electronics SL/BL i.MX8M-Mini boards (N801x)
Haolin Li (1): mtd: nand: Fix typo in MXC Kconfig symbol description
Heiko Schocher (3): spl_fit. add hook to make fixes after fit header is loaded imx: spl: implement spl_load_simple_fit_fix_load imx: spl: fix imx8m secure boot
Heiko Thiery (1): rtc: rv8803: add epson,rx8803 and epson,rx8900 compatible
Jorge Ramirez-Ortiz (1): mmc: fsl_esdhc_imx: initialize data for imx7ulp
Marek Vasut (4): ARM: dts: imx8mm-verdin: Set PHY mode to RGMII-ID ARM: imx: mx5: Enable BMODE command on MX53 Menlo board ARM: imx: mx5: Enable Thumb2 build on MX53 Menlo board ARM: imx: mx5: Add altbootcmd and resets to M53Menlo
Matthias Schiffer (1): imx: mx7: spl: fix CONFIG_SPL_MAX_SIZE definition
Michael Scott (1): misc: ocotp: Allow disabling ocotp driver in SPL
Oleksandr Suvorov (5): imx8mm_evk: Increase CONFIG_SYS_BOOTM_LEN to 64MB imx8mq_evk: Increase CONFIG_SYS_BOOTM_LEN to 64MB imx8qm_mek: Increase CONFIG_SYS_BOOTM_LEN to 64MB ARM: dts: imx: use generic name bus mmc: sdhci-esdhc-imx: Add HS400 support for iMX7ULP
Peng Fan (2): tools: imx8mimage: not abort when mmap fail imx: makefile: drop the use of imx8mimage.sh
Ricardo Salveti (4): mx7ulp: Allow to enable CONFIG_IMX_HAB Kconfig: Don't use RSA_FREESCALE_EXP on MX7ULP ARM: dts: imx6-apalis: enable watchdog board: ea: mx7ulp_com: move setting CONFIG_BOOTCOMMAND to defconfig
Simon Glass (2): buildman: Write output even on fatal error buildman: Detect Kconfig loops
Stefano Babic (2): kontron-sl-mx8mm: fix missing configs and deadlock in CI imx8mm-cl-iot-gate-optee: align config with Kconfig
Teresa Remmet (1): arm: dts: imx8mp: Generate single bootable binary
Tim Harvey (15): board: gateworks: venice: display hwmon details by default board: gateworks: venice: do not overwrite serial# arm: dts: imx8mm-venice-gw700x: fix mp5416 pmic config board: gateworks: venice: update thermal temp thresholds per cpu grade arm: dts: imx8mm-venice*: remove thermal zone overrides imx: ventana: add part command imx: ventana: add U-Boot watchdog support imx: ventana: remove phy gpio reset from dt imx: ventana: enable additional USB ether devices imx: ventana: fix splash logo drawing imx: ventana: update LVDS support imx: ventana: fix USB hub reset arm64: dts: imx8mm-venice-gw700x: use imx8mm-venice-u-boot.dtsi arm64: dts: imx8mm-venice-gw7901: use imx8mm-venice-u-boot.dtsi arm64: dts: imx8mm-venice-gw7902: use imx8mm-venice-u-boot.dtsi
Ye Li (4): mmc: fsl_esdhc_imx: Fix clock disable issue arm: imx8m: Fix pad DSE issue for i.MX8MM/MN/MP mtd: nand: mxs_nand_spl: Add nand_spl_adjust_offset mx7ulp: Update wdog disable sequence
Ying-Chun Liu (PaulLiu) (2): imx8m: Restrict usable memory based on rom_pointer[0] arm: imx8m: imx8mm-cl-iot-gate: Add support for detect memory size
Makefile | 3 - arch/arm/dts/Makefile | 8 +- arch/arm/dts/imx53-m53menlo-u-boot.dtsi | 2 +- arch/arm/dts/imx53-usbarmory.dts | 1 + arch/arm/dts/imx53.dtsi | 4 +- arch/arm/dts/imx6-apalis-u-boot.dtsi | 11 ++ arch/arm/dts/imx6dl.dtsi | 4 +- arch/arm/dts/imx6q-display5-u-boot.dtsi | 2 +- arch/arm/dts/imx6q.dtsi | 2 +- arch/arm/dts/imx6qdl-gw53xx.dtsi | 11 +- arch/arm/dts/imx6qdl-gw54xx.dtsi | 11 +- arch/arm/dts/imx6qdl-gw552x.dtsi | 21 +++- arch/arm/dts/imx6qdl-gw560x.dtsi | 3 +- arch/arm/dts/imx6qdl-gw5904.dtsi | 11 +- arch/arm/dts/imx6qdl-gw5912.dtsi | 11 +- arch/arm/dts/imx6qdl-u-boot.dtsi | 4 +- arch/arm/dts/imx6qdl.dtsi | 4 +- arch/arm/dts/imx6qp.dtsi | 2 +- arch/arm/dts/imx6sl.dtsi | 4 +- arch/arm/dts/imx6sll.dtsi | 4 +- arch/arm/dts/imx6sx.dtsi | 6 +- arch/arm/dts/imx6ul-kontron-n631x-s-u-boot.dtsi | 7 ++ arch/arm/dts/imx6ul-kontron-n631x-s.dts | 17 +++ arch/arm/dts/imx6ul-kontron-n631x-som.dtsi | 14 +++ arch/arm/dts/imx6ul-kontron-n6x1x-s-u-boot.dtsi | 63 +++++++++++ arch/arm/dts/imx6ul-kontron-n6x1x-s.dts | 423 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6ul-kontron-n6x1x-s.dtsi | 420 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6ul-kontron-n6x1x-som-common.dtsi | 124 ++++++++++++++++++++++ arch/arm/dts/imx6ul.dtsi | 4 +- arch/arm/dts/imx6ull-kontron-n641x-s-u-boot.dtsi | 7 ++ arch/arm/dts/imx6ull-kontron-n641x-s.dts | 16 +++ arch/arm/dts/imx6ull-kontron-n641x-som.dtsi | 13 +++ arch/arm/dts/imx6ull.dtsi | 2 +- arch/arm/dts/imx7s.dtsi | 6 +- arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi | 255 ++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8mm-cl-iot-gate-optee.dts | 6 ++ arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 14 +-- arch/arm/dts/imx8mm-kontron-n801x-s-lvds.dts | 116 ++++++++++++++++++++ arch/arm/dts/imx8mm-kontron-n801x-s-u-boot.dtsi | 274 +++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8mm-kontron-n801x-s.dts | 388 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8mm-kontron-n801x-som.dtsi | 299 ++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi | 62 ++--------- arch/arm/dts/imx8mm-venice-gw700x.dtsi | 56 ++++++---- arch/arm/dts/imx8mm-venice-gw7901-u-boot.dtsi | 66 +----------- arch/arm/dts/imx8mm-venice-gw7901.dts | 12 --- arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi | 54 +--------- arch/arm/dts/imx8mm-venice-gw7902.dts | 12 --- arch/arm/dts/imx8mm-verdin.dts | 2 +- arch/arm/dts/imx8mp-u-boot.dtsi | 19 +++- arch/arm/dts/vf.dtsi | 4 +- arch/arm/include/asm/mach-imx/iomux-v3.h | 21 ++-- arch/arm/mach-imx/Kconfig | 2 +- arch/arm/mach-imx/Makefile | 13 +-- arch/arm/mach-imx/imx8m/Kconfig | 15 +++ arch/arm/mach-imx/imx8m/soc.c | 16 ++- arch/arm/mach-imx/mkimage_fit_atf.sh | 143 ------------------------- arch/arm/mach-imx/mx6/Kconfig | 10 ++ arch/arm/mach-imx/mx7ulp/soc.c | 33 ++++-- arch/arm/mach-imx/spl.c | 47 +++++++++ board/compulab/imx8mm-cl-iot-gate/Kconfig | 2 +- board/compulab/imx8mm-cl-iot-gate/MAINTAINERS | 1 + board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c | 25 +++++ board/freescale/imx8mp_evk/imximage-8mp-lpddr4.cfg | 2 +- board/gateworks/gw_ventana/gw_ventana.c | 102 +++++++++--------- board/gateworks/venice/gsc.c | 3 + board/gateworks/venice/imx8mm_venice.c | 21 +++- board/kontron/sl-mx6ul/Kconfig | 15 +++ board/kontron/sl-mx6ul/MAINTAINERS | 9 ++ board/kontron/sl-mx6ul/Makefile | 8 ++ board/kontron/sl-mx6ul/sl-mx6ul.c | 85 +++++++++++++++ board/kontron/sl-mx6ul/spl.c | 377 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/kontron/sl-mx8mm/Kconfig | 15 +++ board/kontron/sl-mx8mm/MAINTAINERS | 8 ++ board/kontron/sl-mx8mm/Makefile | 9 ++ board/kontron/sl-mx8mm/imximage.cfg | 9 ++ board/kontron/sl-mx8mm/lpddr4_timing.c | 1844 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/kontron/sl-mx8mm/sl-mx8mm.c | 99 +++++++++++++++++ board/kontron/sl-mx8mm/spl.c | 321 +++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/menlo/m53menlo/m53menlo.c | 5 + board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg | 2 +- board/toradex/apalis_imx6/apalis_imx6.c | 19 ++++ board/toradex/colibri_imx6/colibri_imx6.c | 22 ++++ common/spl/spl_fit.c | 18 +++- configs/apalis_imx6_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/gwventana_emmc_defconfig | 15 ++- configs/gwventana_gw5904_defconfig | 15 ++- configs/gwventana_nand_defconfig | 15 ++- configs/imx8mm-cl-iot-gate-optee_defconfig | 148 ++++++++++++++++++++++++++ configs/kontron-sl-mx6ul_defconfig | 109 +++++++++++++++++++ configs/kontron-sl-mx8mm_defconfig | 142 +++++++++++++++++++++++++ configs/m53menlo_defconfig | 2 +- configs/mx7ulp_com_defconfig | 2 + configs/smegw01_defconfig | 5 +- configs/usbarmory_defconfig | 1 + doc/board/kontron/index.rst | 2 + doc/board/kontron/sl-mx6ul.rst | 43 ++++++++ doc/board/kontron/sl-mx8mm.rst | 85 +++++++++++++++ doc/board/nxp/imx8mp_evk.rst | 1 - drivers/misc/Kconfig | 9 ++ drivers/misc/Makefile | 2 +- drivers/mmc/fsl_esdhc_imx.c | 17 ++- drivers/mtd/nand/raw/Kconfig | 2 +- drivers/mtd/nand/raw/mxs_nand_spl.c | 6 ++ drivers/rtc/rv8803.c | 2 + include/configs/gw_ventana.h | 1 + include/configs/imx7_spl.h | 20 ++-- include/configs/imx8mm_evk.h | 2 +- include/configs/imx8mq_evk.h | 2 +- include/configs/imx8qm_mek.h | 2 + include/configs/kontron-sl-mx6ul.h | 77 ++++++++++++++ include/configs/kontron-sl-mx8mm.h | 84 +++++++++++++++ include/configs/m53menlo.h | 15 ++- include/configs/mx7ulp_com.h | 5 - include/configs/smegw01.h | 3 +- include/fsl_esdhc_imx.h | 1 + include/spl.h | 8 ++ lib/rsa/Kconfig | 4 +- tools/buildman/builder.py | 43 +++++++- tools/buildman/builderthread.py | 12 +-- tools/imx8mimage.c | 3 +- tools/patman/command.py | 7 +- tools/patman/cros_subprocess.py | 10 +- 123 files changed, 6595 insertions(+), 534 deletions(-) create mode 100644 arch/arm/dts/imx6-apalis-u-boot.dtsi create mode 100644 arch/arm/dts/imx6ul-kontron-n631x-s-u-boot.dtsi create mode 100644 arch/arm/dts/imx6ul-kontron-n631x-s.dts create mode 100644 arch/arm/dts/imx6ul-kontron-n631x-som.dtsi create mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-s-u-boot.dtsi create mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-s.dts create mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-s.dtsi create mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-som-common.dtsi create mode 100644 arch/arm/dts/imx6ull-kontron-n641x-s-u-boot.dtsi create mode 100644 arch/arm/dts/imx6ull-kontron-n641x-s.dts create mode 100644 arch/arm/dts/imx6ull-kontron-n641x-som.dtsi create mode 100644 arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-cl-iot-gate-optee.dts create mode 100644 arch/arm/dts/imx8mm-kontron-n801x-s-lvds.dts create mode 100644 arch/arm/dts/imx8mm-kontron-n801x-s-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-kontron-n801x-s.dts create mode 100644 arch/arm/dts/imx8mm-kontron-n801x-som.dtsi delete mode 100755 arch/arm/mach-imx/mkimage_fit_atf.sh create mode 100644 board/kontron/sl-mx6ul/Kconfig create mode 100644 board/kontron/sl-mx6ul/MAINTAINERS create mode 100644 board/kontron/sl-mx6ul/Makefile create mode 100644 board/kontron/sl-mx6ul/sl-mx6ul.c create mode 100644 board/kontron/sl-mx6ul/spl.c create mode 100644 board/kontron/sl-mx8mm/Kconfig create mode 100644 board/kontron/sl-mx8mm/MAINTAINERS create mode 100644 board/kontron/sl-mx8mm/Makefile create mode 100644 board/kontron/sl-mx8mm/imximage.cfg create mode 100644 board/kontron/sl-mx8mm/lpddr4_timing.c create mode 100644 board/kontron/sl-mx8mm/sl-mx8mm.c create mode 100644 board/kontron/sl-mx8mm/spl.c create mode 100644 configs/imx8mm-cl-iot-gate-optee_defconfig create mode 100644 configs/kontron-sl-mx6ul_defconfig create mode 100644 configs/kontron-sl-mx8mm_defconfig create mode 100644 doc/board/kontron/sl-mx6ul.rst create mode 100644 doc/board/kontron/sl-mx8mm.rst create mode 100644 include/configs/kontron-sl-mx6ul.h create mode 100644 include/configs/kontron-sl-mx8mm.h
Best regards, Stefano
On 20.10.21 14:48, Stefano Babic wrote:
Hi Tom,
PR was tagged, I forget to copy it:
u-boot-imx-20211020 -------------------
First PR from u-boot-imx for 2022.01
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/9535
- new board: kontron-sl-mx8mm - imx8m: - fix secure boot - imx ESDHC: fixes - i.MX53: Support thum2, bmode and fixes for Menlo board usbarmory switch to Ethernet driver model - imx6 : - DDR calibration for Toradex boards - imx7: - Fixes - Updated gateworks boards (ventana / venice)
Regards, Stefano
On Wed, Oct 20, 2021 at 02:48:40PM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
