[U-Boot] [PATCH 5/5] samsung: clean up checkpatch issues
This patch will fix these checkpatch issues.
CHECK: Alignment should match open parenthesis + printf("Enter: %s %s\n", mode_name[mode][0], + mode_info[mode]);
CHECK: Alignment should match open parenthesis + lcd_printf("\n\n\t%s %s\n", mode_name[mode][0], + mode_info[mode]);
CHECK: Alignment should match open parenthesis + lcd_printf("\t%s %s - %s\n\n", selection[i], + mode_name[i][0],
Signed-off-by: Minkyu Kang mk7.kang@samsung.com --- board/samsung/common/misc.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index e0e2c48..e46c6c6 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -256,9 +256,9 @@ static int mode_leave_menu(int mode) cmd = find_cmd(mode_name[mode][1]); if (cmd) { printf("Enter: %s %s\n", mode_name[mode][0], - mode_info[mode]); + mode_info[mode]); lcd_printf("\n\n\t%s %s\n", mode_name[mode][0], - mode_info[mode]); + mode_info[mode]); lcd_puts("\n\tDo not turn off device before finish!\n");
cmd_result = run_command(mode_cmd[mode], 0); @@ -315,8 +315,7 @@ static void display_download_menu(int mode)
for (i = 0; i <= BOOT_MODE_EXIT; i++) lcd_printf("\t%s %s - %s\n\n", selection[i], - mode_name[i][0], - mode_info[i]); + mode_name[i][0], mode_info[i]); }
static void download_menu(void)
mode_info[mode]);
mode_info[mode]);
mode_name[i][0],
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Minkyu Kang
