[U-Boot] [PATCH] powerpc/85xx: Rework MPC8536 SERDES is_serdes_configured support
Move serdes init until after we are in ram so we can keep track of a global static protocal map for the particular serdes config we are in. This makes is_serdes_configured() much simplier and not constantly reading registers to determine if a given device is enabled based on the protocol.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 12 ++--- arch/powerpc/cpu/mpc85xx/mpc8536_serdes.c | 66 ++++++++++++++-------------- arch/powerpc/include/asm/fsl_serdes.h | 1 + include/configs/MPC8536DS.h | 1 + 4 files changed, 40 insertions(+), 40 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index d491e2a..5d5b4c2 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -39,10 +39,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_MPC8536 -extern void fsl_serdes_init(void); -#endif - #ifdef CONFIG_QE extern qe_iop_conf_t qe_iop_conf_tab[]; extern void qe_config_iopin(u8 port, u8 pin, int dir, @@ -185,9 +181,6 @@ void cpu_init_f (void) /* Config QE ioports */ config_qe_ioports(); #endif -#if defined(CONFIG_MPC8536) - fsl_serdes_init(); -#endif #if defined(CONFIG_FSL_DMA) dma_init(); #endif @@ -332,6 +325,11 @@ int cpu_init_r(void) qe_reset(); #endif
+#if defined(CONFIG_SYS_HAS_SERDES) + /* needs to be in ram since code uses global static vars */ + fsl_serdes_init(); +#endif + #if defined(CONFIG_MP) setup_mp(); #endif diff --git a/arch/powerpc/cpu/mpc85xx/mpc8536_serdes.c b/arch/powerpc/cpu/mpc85xx/mpc8536_serdes.c index 7e72f5f..6dadeb8 100644 --- a/arch/powerpc/cpu/mpc85xx/mpc8536_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/mpc8536_serdes.c @@ -66,10 +66,11 @@ #define FSL_SRDSCR3_LANEE_SGMII 0x00000000 #define FSL_SRDSCR3_LANEE_SATA 0x00150005
- #define SRDS1_MAX_LANES 8 #define SRDS2_MAX_LANES 2
+static u32 serdes1_prtcl_map, serdes2_prtcl_map; + static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { [0x2] = {PCIE1, PCIE1, PCIE1, PCIE1, NONE, NONE, NONE, NONE}, [0x3] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1}, @@ -86,39 +87,12 @@ static u8 serdes2_cfg_tbl[][SRDS2_MAX_LANES] = {
int is_serdes_configured(enum srds_prtcl device) { - int i; - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 pordevsr = in_be32(&gur->pordevsr); - u32 srds1_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> - MPC85xx_PORDEVSR_IO_SEL_SHIFT; + int ret = (1 << device) & serdes1_prtcl_map;
- u32 srds2_cfg = (pordevsr & MPC85xx_PORDEVSR_SRDS2_IO_SEL) >> - GUTS_PORDEVSR_SERDES2_IO_SEL_SHIFT; - - debug("%s: dev = %d\n", __FUNCTION__, device); - debug("PORDEVSR[IO_SEL] = %x\n", srds1_cfg); - debug("PORDEVSR[SRDS2_IO_SEL] = %x\n", srds2_cfg); - - if (srds1_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { - printf("Invalid PORDEVSR[IO_SEL] = %d\n", srds1_cfg); - return 0; - } - - if (srds2_cfg > ARRAY_SIZE(serdes2_cfg_tbl)) { - printf("Invalid PORDEVSR[SRDS2_IO_SEL] = %d\n", srds2_cfg); - return 0; - } - - for (i = 0; i < SRDS1_MAX_LANES; i++) { - if (serdes1_cfg_tbl[srds1_cfg][i] == device) - return 1; - } - for (i = 0; i < SRDS2_MAX_LANES; i++) { - if (serdes2_cfg_tbl[srds2_cfg][i] == device) - return 1; - } + if (ret) + return ret;
- return 0; + return (1 << device) & serdes2_prtcl_map; }
void fsl_serdes_init(void) @@ -126,13 +100,20 @@ void fsl_serdes_init(void) void *guts = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); void *sd = (void *)CONFIG_SYS_MPC85xx_SERDES2_ADDR; u32 pordevsr = in_be32(guts + GUTS_PORDEVSR_OFFS); - u32 srds2_io_sel; + u32 srds1_io_sel, srds2_io_sel; u32 tmp; + int lane; + + srds1_io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> + MPC85xx_PORDEVSR_IO_SEL_SHIFT;
/* parse the SRDS2_IO_SEL of PORDEVSR */ srds2_io_sel = (pordevsr & GUTS_PORDEVSR_SERDES2_IO_SEL) >> GUTS_PORDEVSR_SERDES2_IO_SEL_SHIFT;
+ debug("PORDEVSR[SRDS1_IO_SEL] = %x\n", srds1_io_sel); + debug("PORDEVSR[SRDS2_IO_SEL] = %x\n", srds2_io_sel); + switch (srds2_io_sel) { case 1: /* Lane A - SATA1, Lane E - SATA2 */ /* CR 0 */ @@ -246,4 +227,23 @@ void fsl_serdes_init(void) default: break; } + + if (srds1_io_sel > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[SRDS1_IO_SEL] = %d\n", srds1_io_sel); + return; + } + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds1_io_sel][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } + + if (srds2_io_sel > ARRAY_SIZE(serdes2_cfg_tbl)) { + printf("Invalid PORDEVSR[SRDS2_IO_SEL] = %d\n", srds2_io_sel); + return; + } + + for (lane = 0; lane < SRDS2_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes2_cfg_tbl[srds2_io_sel][lane]; + serdes2_prtcl_map |= (1 << lane_prtcl); + } } diff --git a/arch/powerpc/include/asm/fsl_serdes.h b/arch/powerpc/include/asm/fsl_serdes.h index d4839f4..c7877b9 100644 --- a/arch/powerpc/include/asm/fsl_serdes.h +++ b/arch/powerpc/include/asm/fsl_serdes.h @@ -44,5 +44,6 @@ enum srds_prtcl { };
int is_serdes_configured(enum srds_prtcl device); +void fsl_serdes_init(void);
#endif /* __FSL_SERDES_H */ diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index a014ad0..953a463 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -65,6 +65,7 @@ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ #define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ +#define CONFIG_SYS_HAS_SERDES /* has SERDES */
#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ #define CONFIG_E1000 1 /* Defind e1000 pci Ethernet card*/
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/p1022_serdes.c | 38 ++++++++++++++++++++++--------- include/configs/P1022DS.h | 1 + 2 files changed, 28 insertions(+), 11 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/p1022_serdes.c b/arch/powerpc/cpu/mpc85xx/p1022_serdes.c index 6b0fbf2..e4c9c22 100644 --- a/arch/powerpc/cpu/mpc85xx/p1022_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/p1022_serdes.c @@ -17,6 +17,8 @@ #define SRDS1_MAX_LANES 4 #define SRDS2_MAX_LANES 2
+static u32 serdes1_prtcl_map, serdes2_prtcl_map; + static const u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { [0x00] = {NONE, NONE, NONE, NONE}, [0x01] = {NONE, NONE, NONE, NONE}, @@ -73,26 +75,40 @@ static const u8 serdes2_cfg_tbl[][SRDS2_MAX_LANES] = {
int is_serdes_configured(enum srds_prtcl device) { + int ret = (1 << device) & serdes1_prtcl_map; + + if (ret) + return ret; + + return (1 << device) & serdes2_prtcl_map; +} + +void fsl_serdes_init(void) +{ ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; u32 pordevsr = in_be32(&gur->pordevsr); u32 srds_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> MPC85xx_PORDEVSR_IO_SEL_SHIFT; - unsigned int i; + int lane;
- debug("%s: dev = %d\n", __FUNCTION__, device); - debug("PORDEVSR[IO_SEL] = 0x%x\n", srds_cfg); + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg);
if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { - printf("Invalid PORDEVSR[IO_SEL] = %d\n", srds_cfg); - return 0; + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); }
- for (i = 0; i < SRDS1_MAX_LANES; i++) { - if (serdes1_cfg_tbl[srds_cfg][i] == device) - return 1; - if (serdes2_cfg_tbl[srds_cfg][i] == device) - return 1; + if (srds_cfg > ARRAY_SIZE(serdes2_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; }
- return 0; + for (lane = 0; lane < SRDS2_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes2_cfg_tbl[srds_cfg][lane]; + serdes2_prtcl_map |= (1 << lane_prtcl); + } } diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index e444179..905f730 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -30,6 +30,7 @@ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ +#define CONFIG_SYS_HAS_SERDES /* has SERDES */
#define CONFIG_PHYS_64BIT #define CONFIG_ENABLE_36BIT_PHYS
applied to 85xx
- k
applied to 85xx
- k
Kumar Gala
