[U-Boot] [PATCH v2 1/5] spl: dm: disable SPI DM flash for non-DM SPL
This patch solves the problem that spiboot cannot be performed in non-DM SPL.
Signed-off-by: Pan Jiafei Jiafei.Pan@freescale.com Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- Changes in v2: - No change.
include/config_uncmd_spl.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/config_uncmd_spl.h b/include/config_uncmd_spl.h index c2f9735ce7..da94b3d9df 100644 --- a/include/config_uncmd_spl.h +++ b/include/config_uncmd_spl.h @@ -15,6 +15,7 @@ #undef CONFIG_DM_GPIO #undef CONFIG_DM_I2C #undef CONFIG_DM_SPI +#undef CONFIG_DM_SPI_FLASH #endif
#undef CONFIG_DM_WARN
Modify the Freescale ESPI driver to support the driver model. Also resolved the following problems:
===================== WARNING ====================== This board does not use CONFIG_DM_SPI. Please update the board before v2019.04 for no dm conversion and v2019.07 for partially dm converted drivers. Failure to update can lead to driver/board removal See doc/driver-model/MIGRATION.txt for more info. ==================================================== ===================== WARNING ====================== This board does not use CONFIG_DM_SPI_FLASH. Please update the board to use CONFIG_SPI_FLASH before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ====================================================
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- Changes in v2: - The fsl_espi driver support both OF_CONTROL and PLATDATA
drivers/spi/fsl_espi.c | 454 +++++++++++++++++++++++++++++------------ 1 file changed, 320 insertions(+), 134 deletions(-)
diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c index 7444ae1a06..a2f4027fca 100644 --- a/drivers/spi/fsl_espi.c +++ b/drivers/spi/fsl_espi.c @@ -4,17 +4,27 @@ * * Copyright 2010-2011 Freescale Semiconductor, Inc. * Author: Mingkai Hu (Mingkai.hu@freescale.com) + * Chuanhua Han (chuanhua.han@nxp.com) */
#include <common.h> - #include <malloc.h> #include <spi.h> #include <asm/immap_85xx.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> + +struct fsl_espi_platdata { + uint flags; + uint speed_hz; + uint num_chipselect; + fdt_addr_t regs_addr; +};
-struct fsl_spi_slave { - struct spi_slave slave; +struct fsl_espi_priv { ccsr_espi_t *espi; + u32 speed_hz; unsigned int div16; unsigned int pm; int tx_timeout; @@ -25,9 +35,18 @@ struct fsl_spi_slave { unsigned int max_transfer_length; };
+struct fsl_spi_slave { + struct spi_slave slave; + struct fsl_espi_priv priv; +}; + #define to_fsl_spi_slave(s) container_of(s, struct fsl_spi_slave, slave) +#define to_fsl_spi_priv(p) container_of(p, struct fsl_spi_slave, priv) #define US_PER_SECOND 1000000UL
+/* default SCK frequency, unit: HZ */ +#define FSL_ESPI_DEFAULT_SCK_FREQ 10000000 + #define ESPI_MAX_CS_NUM 4 #define ESPI_FIFO_WIDTH_BIT 32
@@ -62,121 +81,46 @@ struct fsl_spi_slave {
#define ESPI_MAX_DATA_TRANSFER_LEN 0xFFF0
-struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct fsl_spi_slave *fsl; - sys_info_t sysinfo; - unsigned long spibrg = 0; - unsigned long spi_freq = 0; - unsigned char pm = 0; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - fsl = spi_alloc_slave(struct fsl_spi_slave, bus, cs); - if (!fsl) - return NULL; - - fsl->espi = (void *)(CONFIG_SYS_MPC85xx_ESPI_ADDR); - fsl->mode = mode; - fsl->max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN; - - /* Set eSPI BRG clock source */ - get_sys_info(&sysinfo); - spibrg = sysinfo.freq_systembus / 2; - fsl->div16 = 0; - if ((spibrg / max_hz) > 32) { - fsl->div16 = ESPI_CSMODE_DIV16; - pm = spibrg / (max_hz * 16 * 2); - if (pm > 16) { - pm = 16; - debug("Requested speed is too low: %d Hz, %ld Hz " - "is used.\n", max_hz, spibrg / (32 * 16)); - } - } else - pm = spibrg / (max_hz * 2); - if (pm) - pm--; - fsl->pm = pm; - - if (fsl->div16) - spi_freq = spibrg / ((pm + 1) * 2 * 16); - else - spi_freq = spibrg / ((pm + 1) * 2); - - /* set tx_timeout to 10 times of one espi FIFO entry go out */ - fsl->tx_timeout = DIV_ROUND_UP((US_PER_SECOND * ESPI_FIFO_WIDTH_BIT - * 10), spi_freq); - - return &fsl->slave; -} - -void spi_free_slave(struct spi_slave *slave) +#ifndef CONFIG_DM_SPI +void spi_cs_activate(struct spi_slave *slave) { struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); - free(fsl); -} + ccsr_espi_t *espi = fsl->priv.espi; + unsigned int com = 0; + size_t data_len = fsl->priv.data_len;
-int spi_claim_bus(struct spi_slave *slave) + com &= ~(ESPI_COM_CS(0x3) | ESPI_COM_TRANLEN(0xFFFF)); + com |= ESPI_COM_CS(slave->cs); + com |= ESPI_COM_TRANLEN(data_len - 1); + out_be32(&espi->com, com); +} +#else +void fsl_spi_cs_activate(struct fsl_espi_priv *priv, uint cs) { - struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); - ccsr_espi_t *espi = fsl->espi; - unsigned char pm = fsl->pm; - unsigned int cs = slave->cs; - unsigned int mode = fsl->mode; - unsigned int div16 = fsl->div16; - int i; - - debug("%s: bus:%i cs:%i\n", __func__, slave->bus, cs); - - /* Enable eSPI interface */ - out_be32(&espi->mode, ESPI_MODE_RXTHR(3) - | ESPI_MODE_TXTHR(4) | ESPI_MODE_EN); - - out_be32(&espi->event, 0xffffffff); /* Clear all eSPI events */ - out_be32(&espi->mask, 0x00000000); /* Mask all eSPI interrupts */ - - /* Init CS mode interface */ - for (i = 0; i < ESPI_MAX_CS_NUM; i++) - out_be32(&espi->csmode[i], ESPI_CSMODE_INIT_VAL); - - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) & - ~(ESPI_CSMODE_PM(0xF) | ESPI_CSMODE_DIV16 - | ESPI_CSMODE_CI_INACTIVEHIGH | ESPI_CSMODE_CP_BEGIN_EDGCLK - | ESPI_CSMODE_REV_MSB_FIRST | ESPI_CSMODE_LEN(0xF))); - - /* Set eSPI BRG clock source */ - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_PM(pm) | div16); - - /* Set eSPI mode */ - if (mode & SPI_CPHA) - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_CP_BEGIN_EDGCLK); - if (mode & SPI_CPOL) - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_CI_INACTIVEHIGH); - - /* Character bit order: msb first */ - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_REV_MSB_FIRST); - - /* Character length in bits, between 0x3~0xf, i.e. 4bits~16bits */ - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_LEN(7)); + ccsr_espi_t *espi = priv->espi; + unsigned int com = 0; + size_t data_len = priv->data_len;
- return 0; + com &= ~(ESPI_COM_CS(0x3) | ESPI_COM_TRANLEN(0xFFFF)); + com |= ESPI_COM_CS(cs); + com |= ESPI_COM_TRANLEN(data_len - 1); + out_be32(&espi->com, com); } +#endif
-void spi_release_bus(struct spi_slave *slave) +void spi_cs_deactivate(struct spi_slave *slave) { + struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); + ccsr_espi_t *espi = fsl->priv.espi;
+ /* clear the RXCNT and TXCNT */ + out_be32(&espi->mode, in_be32(&espi->mode) & (~ESPI_MODE_EN)); + out_be32(&espi->mode, in_be32(&espi->mode) | ESPI_MODE_EN); }
-static void fsl_espi_tx(struct fsl_spi_slave *fsl, const void *dout) +static void fsl_espi_tx(struct fsl_espi_priv *priv, const void *dout) { - ccsr_espi_t *espi = fsl->espi; + ccsr_espi_t *espi = priv->espi; unsigned int tmpdout, event; int tmp_tx_timeout;
@@ -189,7 +133,7 @@ static void fsl_espi_tx(struct fsl_spi_slave *fsl, const void *dout) out_be32(&espi->event, ESPI_EV_TNF); debug("***spi_xfer:...%08x written\n", tmpdout);
- tmp_tx_timeout = fsl->tx_timeout; + tmp_tx_timeout = priv->tx_timeout; /* Wait for eSPI transmit to go out */ while (tmp_tx_timeout--) { event = in_be32(&espi->event); @@ -204,9 +148,10 @@ static void fsl_espi_tx(struct fsl_spi_slave *fsl, const void *dout) debug("***spi_xfer:...Tx timeout! event = %08x\n", event); }
-static int fsl_espi_rx(struct fsl_spi_slave *fsl, void *din, unsigned int bytes) +static int fsl_espi_rx(struct fsl_espi_priv *priv, void *din, + unsigned int bytes) { - ccsr_espi_t *espi = fsl->espi; + ccsr_espi_t *espi = priv->espi; unsigned int tmpdin, rx_times; unsigned char *buf, *p_cursor;
@@ -236,11 +181,12 @@ static int fsl_espi_rx(struct fsl_spi_slave *fsl, void *din, unsigned int bytes) return bytes; }
-int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, - void *data_in, unsigned long flags) +int espi_xfer(struct fsl_espi_priv *priv, uint cs, unsigned int bitlen, + const void *data_out, void *data_in, unsigned long flags) { - struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); - ccsr_espi_t *espi = fsl->espi; + struct fsl_spi_slave *fsl = to_fsl_spi_priv(priv); + struct spi_slave *slave = &fsl->slave; + ccsr_espi_t *espi = priv->espi; unsigned int event, rx_bytes; const void *dout = NULL; void *din = NULL; @@ -249,16 +195,17 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, int num_bytes; unsigned char *buffer = NULL; size_t buf_len; - u8 *cmd_buf = fsl->cmd_buf; - size_t cmd_len = fsl->cmd_len; + u8 *cmd_buf = priv->cmd_buf; + size_t cmd_len = priv->cmd_len; size_t data_len = bitlen / 8; size_t rx_offset = 0; int rf_cnt;
- max_tran_len = fsl->max_transfer_length; + max_tran_len = priv->max_transfer_length; switch (flags) { case SPI_XFER_BEGIN: - cmd_len = fsl->cmd_len = data_len; + cmd_len = data_len; + priv->cmd_len = cmd_len; memcpy(cmd_buf, data_out, cmd_len); return 0; case 0: @@ -303,8 +250,13 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, tran_len = min(data_len, (size_t)max_tran_len); num_blks = DIV_ROUND_UP(tran_len + cmd_len, 4); num_bytes = (tran_len + cmd_len) % 4; - fsl->data_len = tran_len + cmd_len; - spi_cs_activate(slave); + priv->data_len = tran_len + cmd_len; + #ifdef CONFIG_DM_SPI + fsl_spi_cs_activate(priv, cs); + #else + spi_cs_activate(slave); + #endif +
/* Clear all eSPI events */ out_be32(&espi->event , 0xffffffff); @@ -312,7 +264,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, while (num_blks) { event = in_be32(&espi->event); if (event & ESPI_EV_TNF) { - fsl_espi_tx(fsl, dout); + fsl_espi_tx(priv, dout); /* Set up the next iteration */ if (len > 4) { len -= 4; @@ -330,7 +282,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, rx_bytes = num_bytes; else continue; - if (fsl_espi_rx(fsl, din, rx_bytes) + if (fsl_espi_rx(priv, din, rx_bytes) == rx_bytes) { num_blks--; if (din) @@ -354,30 +306,264 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, return 0; }
+void espi_claim_bus(struct fsl_espi_priv *priv, unsigned int cs) +{ + ccsr_espi_t *espi = priv->espi; + unsigned char pm = priv->pm; + unsigned int mode = priv->mode; + unsigned int div16 = priv->div16; + int i; + + /* Enable eSPI interface */ + out_be32(&espi->mode, ESPI_MODE_RXTHR(3) + | ESPI_MODE_TXTHR(4) | ESPI_MODE_EN); + + out_be32(&espi->event, 0xffffffff); /* Clear all eSPI events */ + out_be32(&espi->mask, 0x00000000); /* Mask all eSPI interrupts */ + + /* Init CS mode interface */ + for (i = 0; i < ESPI_MAX_CS_NUM; i++) + out_be32(&espi->csmode[i], ESPI_CSMODE_INIT_VAL); + + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) & + ~(ESPI_CSMODE_PM(0xF) | ESPI_CSMODE_DIV16 + | ESPI_CSMODE_CI_INACTIVEHIGH | ESPI_CSMODE_CP_BEGIN_EDGCLK + | ESPI_CSMODE_REV_MSB_FIRST | ESPI_CSMODE_LEN(0xF))); + + /* Set eSPI BRG clock source */ + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_PM(pm) | div16); + + /* Set eSPI mode */ + if (mode & SPI_CPHA) + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_CP_BEGIN_EDGCLK); + if (mode & SPI_CPOL) + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_CI_INACTIVEHIGH); + + /* Character bit order: msb first */ + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_REV_MSB_FIRST); + + /* Character length in bits, between 0x3~0xf, i.e. 4bits~16bits */ + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_LEN(7)); +} + +void espi_setup_slave(struct fsl_espi_priv *priv) +{ + unsigned int max_hz; + sys_info_t sysinfo; + unsigned long spibrg = 0; + unsigned long spi_freq = 0; + unsigned char pm = 0; + + max_hz = priv->speed_hz; + + get_sys_info(&sysinfo); + spibrg = sysinfo.freq_systembus / 2; + priv->div16 = 0; + if ((spibrg / max_hz) > 32) { + priv->div16 = ESPI_CSMODE_DIV16; + pm = spibrg / (max_hz * 16 * 2); + if (pm > 16) { + pm = 16; + debug("max_hz is too low: %d Hz, %ld Hz is used.\n", + max_hz, spibrg / (32 * 16)); + } + } else { + pm = spibrg / (max_hz * 2); + } + if (pm) + pm--; + priv->pm = pm; + + if (priv->div16) + spi_freq = spibrg / ((pm + 1) * 2 * 16); + else + spi_freq = spibrg / ((pm + 1) * 2); + + /* set tx_timeout to 10 times of one espi FIFO entry go out */ + priv->tx_timeout = DIV_ROUND_UP((US_PER_SECOND * ESPI_FIFO_WIDTH_BIT + * 10), spi_freq);/* Set eSPI BRG clock source */ +} + +#ifndef CONFIG_DM_SPI int spi_cs_is_valid(unsigned int bus, unsigned int cs) { return bus == 0 && cs < ESPI_MAX_CS_NUM; }
-void spi_cs_activate(struct spi_slave *slave) +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct fsl_spi_slave *fsl; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + fsl = spi_alloc_slave(struct fsl_spi_slave, bus, cs); + if (!fsl) + return NULL; + + fsl->priv.espi = (void *)(CONFIG_SYS_MPC85xx_ESPI_ADDR); + fsl->priv.mode = mode; + fsl->priv.max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN; + fsl->priv.speed_hz = FSL_ESPI_DEFAULT_SCK_FREQ; + + espi_setup_slave(&fsl->priv); + + return &fsl->slave; +} + +void spi_free_slave(struct spi_slave *slave) { struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); - ccsr_espi_t *espi = fsl->espi; - unsigned int com = 0; - size_t data_len = fsl->data_len;
- com &= ~(ESPI_COM_CS(0x3) | ESPI_COM_TRANLEN(0xFFFF)); - com |= ESPI_COM_CS(slave->cs); - com |= ESPI_COM_TRANLEN(data_len - 1); - out_be32(&espi->com, com); + free(fsl); }
-void spi_cs_deactivate(struct spi_slave *slave) +int spi_claim_bus(struct spi_slave *slave) { struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); - ccsr_espi_t *espi = fsl->espi;
- /* clear the RXCNT and TXCNT */ - out_be32(&espi->mode, in_be32(&espi->mode) & (~ESPI_MODE_EN)); - out_be32(&espi->mode, in_be32(&espi->mode) | ESPI_MODE_EN); + espi_claim_bus(&fsl->priv, slave->cs); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + /* Nothing to do */ +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct fsl_spi_slave *espi = (struct fsl_spi_slave *)slave; + + return espi_xfer(&espi->priv, slave->cs, bitlen, dout, din, flags); +} +#else +static int fsl_espi_claim_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct dm_spi_slave_platdata *slave_plat = + dev_get_parent_platdata(dev); + + struct fsl_espi_priv *priv = dev_get_priv(bus); + + espi_claim_bus(priv, slave_plat->cs); + + return 0; +} + +static int fsl_espi_release_bus(struct udevice *dev) +{ + /* Nothing to do */ + return 0; +} + +static int fsl_espi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct fsl_espi_priv *priv; + struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); + struct udevice *bus; + + bus = dev->parent; + priv = dev_get_priv(bus); + return espi_xfer(priv, slave_plat->cs, bitlen, dout, din, flags); +} + +static int fsl_espi_set_speed(struct udevice *bus, uint speed) +{ + /* Nothing to do */ + return 0; +} + +static int fsl_espi_set_mode(struct udevice *bus, uint mode) +{ + /* Nothing to do */ + return 0; } + +static int fsl_espi_probe(struct udevice *bus) +{ + struct fsl_espi_platdata *plat = dev_get_platdata(bus); + struct fsl_espi_priv *priv = dev_get_priv(bus); + + priv->espi = (ccsr_espi_t *)((u32)plat->regs_addr); + priv->max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN; + priv->speed_hz = plat->speed_hz; + + espi_setup_slave(priv); + + debug("%s probe done, bus-num %d.\n", bus->name, bus->seq); + return 0; +} + +static int fsl_espi_child_pre_probe(struct udevice *dev) +{ + /* Nothing to do */ + return 0; +} + +static int fsl_espi_bind(struct udevice *bus) +{ + debug("%s assigned req_seq %d.\n", bus->name, bus->req_seq); + return 0; +} + +static const struct dm_spi_ops fsl_espi_ops = { + .claim_bus = fsl_espi_claim_bus, + .release_bus = fsl_espi_release_bus, + .xfer = fsl_espi_xfer, + .set_speed = fsl_espi_set_speed, + .set_mode = fsl_espi_set_mode, +}; + +#if !CONFIG_IS_ENABLED(OF_PLATDATA) +static int fsl_espi_ofdata_to_platdata(struct udevice *bus) +{ + fdt_addr_t addr; + struct fsl_espi_platdata *plat = bus->platdata; + const void *blob = gd->fdt_blob; + int node = dev_of_offset(bus); + + addr = dev_read_addr(bus); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->regs_addr = lower_32_bits(addr); + plat->speed_hz = fdtdec_get_int(blob, node, "spi-max-frequency", + FSL_ESPI_DEFAULT_SCK_FREQ); + + debug("ESPI: regs=%p, max-frequency=%d\n", + &plat->regs_addr, plat->speed_hz); + + return 0; +} + +static const struct udevice_id fsl_espi_ids[] = { + { .compatible = "fsl,mpc8536-espi" }, + { } +}; +#endif + +U_BOOT_DRIVER(fsl_espi) = { + .name = "fsl_espi", + .id = UCLASS_SPI, +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + .of_match = fsl_espi_ids, + .ofdata_to_platdata = fsl_espi_ofdata_to_platdata, +#endif + .ops = &fsl_espi_ops, + .platdata_auto_alloc_size = sizeof(struct fsl_espi_platdata), + .priv_auto_alloc_size = sizeof(struct fsl_espi_priv), + .probe = fsl_espi_probe, + .child_pre_probe = fsl_espi_child_pre_probe, + .bind = fsl_espi_bind, +}; +#endif
- Copyright 2010-2011 Freescale Semiconductor, Inc.
- Author: Mingkai Hu (Mingkai.hu@freescale.com)
#include <common.h>
Please sort the includes - this one should go at the end
uint flags;
uint speed_hz;
We shouldn't really need this. Can we just pass the containing stuct instead?
sys_info_t sysinfo;
return NULL;
if (!fsl)
return NULL;
fsl->mode = mode;
fsl->div16 = 0;
if (pm > 16) {
pm = 16;
} else
if (pm)
pm--;
fsl->pm = pm;
if (fsl->div16)
else
* 10), spi_freq);
return &fsl->slave;
It is more common to put #idef CONFIG_DM_SPI first with the old code last.
free(fsl);
int i;
/* Set eSPI mode */
} +#endif
Should this be static?
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: 2019年6月23日 3:10 To: Chuanhua Han chuanhua.han@nxp.com Cc: Jagan Teki jagan@openedev.com; Wolfgang Denk wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Yinbo Zhu yinbo.zhu@nxp.com; Bin Meng bmeng.cn@gmail.com; Jagdish Gediya jagdish.gediya@nxp.com Subject: [EXT] Re: [PATCH v2 2/5] dm: spi: Convert Freescale ESPI driver to driver model
Caution: EXT Email
does
does
#include <common.h>
uint flags;
uint speed_hz;
#define to_fsl_spi_slave(s) container_of(s, struct fsl_spi_slave, slave) +#define to_fsl_spi_priv(p) container_of(p, struct fsl_spi_slave, +priv)
sys_info_t sysinfo;
return NULL;
if (!fsl)
return NULL;
fsl->mode = mode;
fsl->div16 = 0;
if (pm > 16) {
pm = 16;
Hz "
} else
if (pm)
pm--;
fsl->pm = pm;
if (fsl->div16)
else
ESPI_FIFO_WIDTH_BIT
* 10), spi_freq);
return &fsl->slave;
free(fsl);
int i;
/* Set eSPI mode */
} +#endif
I have sent the fourth edition you see the new patchwork:
https://patchwork.ozlabs.org/project/uboot/list/?series=115242
Caution: EXT Email
does
does
#include <common.h>
The header file is also in this position before I modify this file. Is this necessary?
uint flags;
uint speed_hz;
This has been removed in the new version of the patch.
sys_info_t sysinfo;
return NULL;
if (!fsl)
return NULL;
fsl->mode = mode;
fsl->div16 = 0;
if (pm > 16) {
pm = 16;
Hz "
} else
if (pm)
pm--;
fsl->pm = pm;
if (fsl->div16)
else
ESPI_FIFO_WIDTH_BIT
* 10), spi_freq);
return &fsl->slave;
I have checked many files using #ifndef CONFIG_DM_SPI to separate DM code and non-dm code.
free(fsl);
int i;
/* Set eSPI mode */
} +#endif
This function may be called by the code of other files, so this function should not need to use static to limit it.
Add espi controller node to support t2080.
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- depends on: - https://patchwork.ozlabs.org/project/uboot/list/?series=99439
arch/powerpc/dts/t2080.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/powerpc/dts/t2080.dtsi b/arch/powerpc/dts/t2080.dtsi index d2bebb08b6..e3970d3590 100644 --- a/arch/powerpc/dts/t2080.dtsi +++ b/arch/powerpc/dts/t2080.dtsi @@ -69,6 +69,16 @@ voltage-ranges = <1800 1800 3300 3300>; };
+ espi0: spi@110000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,mpc8536-espi"; + reg = <0x110000 0x1000>; + interrupts = <53 0x2 0 0>; + fsl,espi-num-chipselects = <4>; + status = "disabled"; + }; + usb0: usb@210000 { compatible = "fsl-usb2-mph"; reg = <0x210000 0x1000>;
Add espi slave nodes to support t2080qds.
arch/powerpc/dts/t2080qds.dts | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/arch/powerpc/dts/t2080qds.dts b/arch/powerpc/dts/t2080qds.dts index 1819a081dd..5eebe26010 100644 --- a/arch/powerpc/dts/t2080qds.dts +++ b/arch/powerpc/dts/t2080qds.dts @@ -14,4 +14,37 @@ #address-cells = <2>; #size-cells = <2>; interrupt-parent = <&mpic>; + + aliases { + spi0 = &espi0; + }; +}; + +&espi0 { + + status = "okay"; + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "micron,n25q128a11", "jedec,spi-nor"; /* 16MB */ + reg = <0>; + spi-max-frequency = <40000000>; /* input clock */ + }; + + flash@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "sst,sst25wf040", "jedec,spi-nor"; + reg = <1>; + spi-max-frequency = <35000000>; + }; + + flash@2 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "eon,en25s64", "jedec,spi-nor"; + reg = <2>; + spi-max-frequency = <35000000>; + }; + };
This patch is to enable espi DM for T2080QDS in uboot
configs/T2080QDS_NAND_defconfig | 2 ++ configs/T2080QDS_SDCARD_defconfig | 2 ++ configs/T2080QDS_SECURE_BOOT_defconfig | 2 ++ configs/T2080QDS_SPIFLASH_defconfig | 2 ++ configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/T2080QDS_defconfig | 2 ++ 6 files changed, 12 insertions(+)
diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 72a6e8772b..1f8ae64294 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -66,3 +66,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 2e3a51aa0a..668a92b49c 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -65,3 +65,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 6cb36ebbb3..8e317d8e4e 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -58,3 +58,5 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 9d17a99198..5da8c3a060 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -66,3 +66,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 560ae143a1..2fa6ccc8d1 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -48,3 +48,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index 4d6314b1cf..8c5735aede 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -55,3 +55,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y
Changes in v2:
- No change.
Long term, this shows places where we need CONFIG_SPL_DM_xxx and code should be using CONFIG_IS_ENABLED(DM_xxx). Please update at least the DM_SPI_FLASH case you're finding to behave like that, thanks!
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: 2019年5月24日 22:24 To: Chuanhua Han chuanhua.han@nxp.com Cc: jagan@openedev.com; wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; Pan Jiafei Jiafei.Pan@freescale.com; u-boot@lists.denx.de; Jiafei Pan jiafei.pan@nxp.com; Yinbo Zhu yinbo.zhu@nxp.com Subject: [EXT] Re: [U-Boot] [PATCH v2 1/5] spl: dm: disable SPI DM flash for non-DM SPL
Changes in v2:
- No change.
I don't understand you very much. Are you saying to modify the spi-flash related code?
-- Tom
Changes in v2:
- No change.
Correct. include/config_uncmd_spl.h should be removed as there should, long term, be no cases of code in SPL that we can / should exclude not guarded by CONFIG_SPL_xxx instead.
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: 2019年5月31日 3:43 To: Chuanhua Han chuanhua.han@nxp.com Cc: jagan@openedev.com; wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; Pan Jiafei Jiafei.Pan@freescale.com; u-boot@lists.denx.de; Jiafei Pan jiafei.pan@nxp.com; Yinbo Zhu yinbo.zhu@nxp.com Subject: Re: [EXT] Re: [U-Boot] [PATCH v2 1/5] spl: dm: disable SPI DM flash for non-DM SPL
Changes in v2:
- No change.
related code?
Do you mean I should not add "#undef CONFIG_DM_SPI_FLASH" in include/config_uncmd_spl.h? What should I do? Is there any code or file for reference?
-- Tom
Changes in v2:
- No change.
related code?
You should fix whatever code is being linked in to SPL that should not be in SPL to use CONFIG_IS_ENABLED(DM_SPI_FLASH) and add a SPL_DM_SPI_FLASH symbol so that platforms which do need it can still enable it. Thanks!
Changes in v2:
- No change.
related code?
Do you mean include/config_uncmd_spl.h will be deleted in the future? Why did you start adding this file?
-- Tom
Changes in v2:
- No change.
related code?
The file config_uncmd_spl.h predates the CONFIG_IS_ENABLED() macro and whats left in that file should have code in question migrated to use CONFIG_IS_ENABLED(xxx) and as needed new CONFIG_SPL_xxx symbols added, in case some places _do_ need it.
I'm not asking you to do this migrated, but I don't want to see more technical debt added here. We can solve the problem you're seeing around CONFIG_DM_SPI_FLASH in another easier to maintain manner. Thanks!
Chuanhua Han
