[U-Boot] [PATCH][u-boot-85xx]The 32bit errata fix for 8572 for DDR2 (fwd)
This patch fixes the fix for 8572 SOC errata for 32bit DDR2. The earlier fix was trying to access the SDRAM_CFG register before initializing it. Now the SDRAM_CFG is initialized before. But the MEM_EN is set in the end.
Signed-off-by: Poonam Aggrwal-b10812 b10812@freescale.net Acked-by: Dave Liu daveliu@freescale.com --- cpu/mpc85xx/ddr-gen3.c | 9 ++++++++- include/asm-ppc/fsl_ddr_sdram.h | 17 +++++++++++++++++ 2 files changed, 25 insertions(+), 1 deletions(-)
diff --git a/cpu/mpc85xx/ddr-gen3.c b/cpu/mpc85xx/ddr-gen3.c index a2b45c5..b9cb4e6 100644 --- a/cpu/mpc85xx/ddr-gen3.c +++ b/cpu/mpc85xx/ddr-gen3.c @@ -19,6 +19,7 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, { unsigned int i; volatile ccsr_ddr_t *ddr; + u32 temp_sdram_cfg;
switch (ctrl_num) { case 0: @@ -78,6 +79,10 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, out_be32(&ddr->ddr_sdram_rcw_1, regs->ddr_sdram_rcw_1); out_be32(&ddr->ddr_sdram_rcw_2, regs->ddr_sdram_rcw_2);
+ /* Do not enable the memory */ + temp_sdram_cfg = in_be32(&ddr->sdram_cfg); + temp_sdram_cfg &= ~(SDRAM_CFG_MEM_EN); + out_be32(&ddr->sdram_cfg, temp_sdram_cfg); /* * For 8572 DDR1 erratum - DDR controller may enter illegal state * when operatiing in 32-bit bus mode with 4-beat bursts, @@ -99,7 +104,9 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, udelay(200); asm volatile("sync;isync");
- out_be32(&ddr->sdram_cfg, regs->ddr_sdram_cfg); + /* Let the controller go */ + temp_sdram_cfg = in_be32(&ddr->sdram_cfg); + out_be32(&ddr->sdram_cfg, temp_sdram_cfg | SDRAM_CFG_MEM_EN);
/* Poll DDR_SDRAM_CFG_2[D_INIT] bit until auto-data init is done. */ while (in_be32(&ddr->sdram_cfg_2) & 0x10) { diff --git a/include/asm-ppc/fsl_ddr_sdram.h b/include/asm-ppc/fsl_ddr_sdram.h index b213af3..6e3b255 100644 --- a/include/asm-ppc/fsl_ddr_sdram.h +++ b/include/asm-ppc/fsl_ddr_sdram.h @@ -51,6 +51,23 @@ typedef ddr3_spd_eeprom_t generic_spd_eeprom_t; #define FSL_DDR_BANK_INTERLEAVING 0x2 #define FSL_DDR_SUPERBANK_INTERLEAVING 0x3
+/* DDR_SDRAM_CFG - DDR SDRAM Control Configuration + */ +#define SDRAM_CFG_MEM_EN 0x80000000 +#define SDRAM_CFG_SREN 0x40000000 +#define SDRAM_CFG_ECC_EN 0x20000000 +#define SDRAM_CFG_RD_EN 0x10000000 +#define SDRAM_CFG_SDRAM_TYPE_DDR1 0x02000000 +#define SDRAM_CFG_SDRAM_TYPE_DDR2 0x03000000 +#define SDRAM_CFG_SDRAM_TYPE_MASK 0x07000000 +#define SDRAM_CFG_SDRAM_TYPE_SHIFT 24 +#define SDRAM_CFG_DYN_PWR 0x00200000 +#define SDRAM_CFG_32_BE 0x00080000 +#define SDRAM_CFG_8_BE 0x00040000 +#define SDRAM_CFG_NCAP 0x00020000 +#define SDRAM_CFG_2T_EN 0x00008000 +#define SDRAM_CFG_BI 0x00000001 + /* Record of register values computed */ typedef struct fsl_ddr_cfg_regs_s { struct {
Hi, I am using the MPC8572DS Eval from Freescale, and the u-boot-2008-10 release from denx, I've also tried freescales latest u-boot version for that eval release with all freescale patches. The EVAL works with a Buffered DDR2. I have to use Registered DDR2, and it doesn't work. u-boot, doesn't succeed in relocating to memory. Has anyone Gotton this to work? Thanks For the Help. Hamo
Hello James
Do you have any suggestions here?
Thanks Poonam
________________________________
From: hamoshame Lamoteku [mailto:hamoshame@yahoo.com] Sent: Friday, January 16, 2009 4:04 AM To: u-boot@lists.denx.de Cc: Aggrwal Poonam-B10812; Liu Dave-R63238 Subject: MPC8572DS Registered DDR2 support. Hi, I am using the MPC8572DS Eval from Freescale, and the u-boot-2008-10 release from denx, I've also tried freescales latest u-boot version for that eval release with all freescale patches. The EVAL works with a Buffered DDR2. I have to use Registered DDR2, and it doesn't work. u-boot, doesn't succeed in relocating to memory. Has anyone Gotton this to work? Thanks For the Help. Hamo
Aggrwal Poonam
hamoshame Lamoteku
Poonam_Aggrwal-b10812
