[U-Boot] [PATCH 1/4] buildman: Only print toolchain probing with -v
At present --list-tool-chains prints a lot of information about the toolchain-probing process. This is generally not very interesting. Update buildman to print this only if --list-tool-chains is given with -v.
tools/buildman/cmdline.py | 2 +- tools/buildman/control.py | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/buildman/cmdline.py b/tools/buildman/cmdline.py index e493b1ac4a0..a5376e1b365 100644 --- a/tools/buildman/cmdline.py +++ b/tools/buildman/cmdline.py @@ -64,7 +64,7 @@ def ParseArgs(): parser.add_option('-l', '--list-error-boards', action='store_true', default=False, help='Show a list of boards next to each error/warning') parser.add_option('--list-tool-chains', action='store_true', default=False, - help='List available tool chains') + help='List available tool chains (use -v to see probing detail)') parser.add_option('-n', '--dry-run', action='store_true', dest='dry_run', default=False, help="Do a dry run (describe actions, but do nothing)") parser.add_option('-N', '--no-subdirs', action='store_true', dest='no_subdirs', diff --git a/tools/buildman/control.py b/tools/buildman/control.py index bc0819784f8..0c0cf48d3cb 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -159,7 +159,7 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None,
if no_toolchains: toolchains.GetSettings() - toolchains.Scan(options.list_tool_chains) + toolchains.Scan(options.list_tool_chains and options.verbose) if options.list_tool_chains: toolchains.List() print
At present messages from the device-tree compiler like this:
arch/arm/dts/socfpga_arria10_socdk_sdmmc.dtb: Warning (avoid_unnecessary_addr_size): /clocks: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
are detected as errors since they don't match the gcc warning regex. Add a new one for dtc to fix this.
tools/buildman/builder.py | 4 +++- tools/buildman/test.py | 5 +++-- 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index 05f82995416..fc80705a455 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -290,6 +290,7 @@ class Builder: self._re_function = re.compile('(.*): In function.*') self._re_files = re.compile('In file included from.*') self._re_warning = re.compile('(.*):(\d*):(\d*): warning: .*') + self._re_dtb_warning = re.compile('(.*): Warning .*') self._re_note = re.compile('(.*):(\d*):(\d*): note: this is the location of the previous.*')
self.queue = Queue.Queue() @@ -788,7 +789,8 @@ class Builder: self._re_files.match(line)): last_func = line else: - is_warning = self._re_warning.match(line) + is_warning = (self._re_warning.match(line) or + self._re_dtb_warning.match(line)) is_note = self._re_note.match(line) if is_warning or (last_was_warning and is_note): if last_func: diff --git a/tools/buildman/test.py b/tools/buildman/test.py index e0c9d6da6a0..90ab35b1664 100644 --- a/tools/buildman/test.py +++ b/tools/buildman/test.py @@ -46,8 +46,9 @@ make[1]: *** [main.o] Error 1 make: *** [common/libcommon.o] Error 2 Make failed ''', - '''main.c: In function 'main_loop3': -main.c:280:6: warning: unused variable 'mary' [-Wunused-variable] + '''arch/arm/dts/socfpga_arria10_socdk_sdmmc.dtb: Warning \ +(avoid_unnecessary_addr_size): /clocks: unnecessary #address-cells/#size-cells \ +without "ranges" or child "reg" property ''', '''powerpc-linux-ld: warning: dot moved backwards before `.bss' powerpc-linux-ld: warning: dot moved backwards before `.bss'
Applied to u-boot-dm/master, thanks!
At present we don't distinguish between errors and warnings when printing the architecture summary. Rename the variables to better describe their purpose.
'Worse' at present means we got an error, so use that as the name.
tools/buildman/builder.py | 28 ++++++++++++++-------------- 1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index fc80705a455..d9d86ef6a39 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -1196,10 +1196,10 @@ class Builder: Print(' ' + line, newline=True, colour=col)
- better = [] # List of boards fixed since last commit - worse = [] # List of new broken boards since last commit - new = [] # List of boards that didn't exist last time - unknown = [] # List of boards that were not built + ok_boards = [] # List of boards fixed since last commit + err_boards = [] # List of new broken boards since last commit + new_boards = [] # List of boards that didn't exist last time + unknown_boards = [] # List of boards that were not built
for target in board_dict: if target not in board_selected: @@ -1210,13 +1210,13 @@ class Builder: base_outcome = self._base_board_dict[target].rc outcome = board_dict[target] if outcome.rc == OUTCOME_UNKNOWN: - unknown.append(target) + unknown_boards.append(target) elif outcome.rc < base_outcome: - better.append(target) + ok_boards.append(target) elif outcome.rc > base_outcome: - worse.append(target) + err_boards.append(target) else: - new.append(target) + new_boards.append(target)
# Get a list of errors that have appeared, and disappeared better_err, worse_err = _CalcErrorDelta(self._base_err_lines, @@ -1225,16 +1225,16 @@ class Builder: self._base_warn_line_boards, warn_lines, warn_line_boards, 'w')
# Display results by arch - if (better or worse or unknown or new or worse_err or better_err - or worse_warn or better_warn): + if any((ok_boards, err_boards, unknown_boards, new_boards, worse_err, + better_err, worse_warn, better_warn)): arch_list = {} - self.AddOutcome(board_selected, arch_list, better, '', + self.AddOutcome(board_selected, arch_list, ok_boards, '', self.col.GREEN) - self.AddOutcome(board_selected, arch_list, worse, '+', + self.AddOutcome(board_selected, arch_list, err_boards, '+', self.col.RED) - self.AddOutcome(board_selected, arch_list, new, '*', self.col.BLUE) + self.AddOutcome(board_selected, arch_list, new_boards, '*', self.col.BLUE) if self._show_unknown: - self.AddOutcome(board_selected, arch_list, unknown, '?', + self.AddOutcome(board_selected, arch_list, unknown_boards, '?', self.col.MAGENTA) for arch, target_list in arch_list.iteritems(): Print('%10s: %s' % (arch, target_list))
At present we should boards with warnings in the same way as those with errors. This is not ideal. Add a new 'warn' state and show these listed in yellow to match the actual warning lines printing with -e.
tools/buildman/builder.py | 17 +++++++++--- tools/buildman/test.py | 56 ++++++++++++++++++++++++++++----------- 2 files changed, 54 insertions(+), 19 deletions(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index d9d86ef6a39..6a6c83bf336 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -1197,6 +1197,7 @@ class Builder:
ok_boards = [] # List of boards fixed since last commit + warn_boards = [] # List of boards with warnings since last commit err_boards = [] # List of new broken boards since last commit new_boards = [] # List of boards that didn't exist last time unknown_boards = [] # List of boards that were not built @@ -1212,9 +1213,15 @@ class Builder: if outcome.rc == OUTCOME_UNKNOWN: unknown_boards.append(target) elif outcome.rc < base_outcome: - ok_boards.append(target) + if outcome.rc == OUTCOME_WARNING: + warn_boards.append(target) + else: + ok_boards.append(target) elif outcome.rc > base_outcome: - err_boards.append(target) + if outcome.rc == OUTCOME_WARNING: + warn_boards.append(target) + else: + err_boards.append(target) else: new_boards.append(target)
@@ -1225,11 +1232,13 @@ class Builder: self._base_warn_line_boards, warn_lines, warn_line_boards, 'w')
# Display results by arch - if any((ok_boards, err_boards, unknown_boards, new_boards, worse_err, - better_err, worse_warn, better_warn)): + if any((ok_boards, warn_boards, err_boards, unknown_boards, new_boards, + worse_err, better_err, worse_warn, better_warn)): arch_list = {} self.AddOutcome(board_selected, arch_list, ok_boards, '', self.col.GREEN) + self.AddOutcome(board_selected, arch_list, warn_boards, 'w+', + self.col.YELLOW) self.AddOutcome(board_selected, arch_list, err_boards, '+', self.col.RED) self.AddOutcome(board_selected, arch_list, new_boards, '*', self.col.BLUE) diff --git a/tools/buildman/test.py b/tools/buildman/test.py index 90ab35b1664..4ceb4cceb5a 100644 --- a/tools/buildman/test.py +++ b/tools/buildman/test.py @@ -97,6 +97,8 @@ boards = [
BASE_DIR = 'base'
+OUTCOME_OK, OUTCOME_WARN, OUTCOME_ERR = range(3) + class Options: """Class that holds build options""" pass @@ -166,9 +168,10 @@ class TestBuild(unittest.TestCase): result.combined = result.stdout + result.stderr return result
- def assertSummary(self, text, arch, plus, boards, ok=False): + def assertSummary(self, text, arch, plus, boards, outcome=OUTCOME_ERR): col = self._col - expected_colour = col.GREEN if ok else col.RED + expected_colour = (col.GREEN if outcome == OUTCOME_OK else + col.YELLOW if outcome == OUTCOME_WARN else col.RED) expect = '%10s: ' % arch # TODO(sjg@chromium.org): If plus is '', we shouldn't need this expect += ' ' + col.Color(expected_colour, plus) @@ -192,6 +195,8 @@ class TestBuild(unittest.TestCase): build.do_make = self.Make board_selected = self.boards.GetSelectedDict()
+ # Build the boards for the pre-defined commits and warnings/errors + # associated with each. This calls our Make() to inject the fake output. build.BuildBoards(self.commits, board_selected, keep_outputs=False, verbose=False) lines = terminal.GetPrintTestLines() @@ -207,33 +212,49 @@ class TestBuild(unittest.TestCase): build.ShowSummary(self.commits, board_selected) #terminal.EchoPrintTestLines() lines = terminal.GetPrintTestLines() + + # Upstream commit: no errors self.assertEqual(lines[0].text, '01: %s' % commits[0][1]) + + # Second commit: all archs should fail with warnings self.assertEqual(lines[1].text, '02: %s' % commits[1][1])
- # We expect all archs to fail col = terminal.Color() - self.assertSummary(lines[2].text, 'sandbox', '+', ['board4']) - self.assertSummary(lines[3].text, 'arm', '+', ['board1']) - self.assertSummary(lines[4].text, 'powerpc', '+', ['board2', 'board3']) - - # Now we should have the compiler warning + self.assertSummary(lines[2].text, 'sandbox', 'w+', ['board4'], + outcome=OUTCOME_WARN) + self.assertSummary(lines[3].text, 'arm', 'w+', ['board1'], + outcome=OUTCOME_WARN) + self.assertSummary(lines[4].text, 'powerpc', 'w+', ['board2', 'board3'], + outcome=OUTCOME_WARN) + + # Second commit: The warnings should be listed self.assertEqual(lines[5].text, 'w+%s' % errors[0].rstrip().replace('\n', '\nw+')) self.assertEqual(lines[5].colour, col.MAGENTA)
+ # Third commit: Still fails self.assertEqual(lines[6].text, '03: %s' % commits[2][1]) self.assertSummary(lines[7].text, 'sandbox', '+', ['board4']) - self.assertSummary(lines[8].text, 'arm', '', ['board1'], ok=True) + self.assertSummary(lines[8].text, 'arm', '', ['board1'], + outcome=OUTCOME_OK) self.assertSummary(lines[9].text, 'powerpc', '+', ['board2', 'board3'])
- # Compiler error + # Expect a compiler error self.assertEqual(lines[10].text, '+%s' % errors[1].rstrip().replace('\n', '\n+'))
+ # Fourth commit: Compile errors are fixed, just have warning for board3 self.assertEqual(lines[11].text, '04: %s' % commits[3][1]) - self.assertSummary(lines[12].text, 'sandbox', '', ['board4'], ok=True) - self.assertSummary(lines[13].text, 'powerpc', '', ['board2', 'board3'], - ok=True) + self.assertSummary(lines[12].text, 'sandbox', 'w+', ['board4'], + outcome=OUTCOME_WARN) + expect = '%10s: ' % 'powerpc' + expect += ' ' + col.Color(col.GREEN, '') + expect += ' ' + expect += col.Color(col.GREEN, ' %s' % 'board2') + expect += ' ' + col.Color(col.YELLOW, 'w+') + expect += ' ' + expect += col.Color(col.YELLOW, ' %s' % 'board3') + self.assertEqual(lines[13].text, expect)
# Compile error fixed self.assertEqual(lines[14].text, '-%s' % @@ -244,9 +265,11 @@ class TestBuild(unittest.TestCase): errors[2].rstrip().replace('\n', '\nw+')) self.assertEqual(lines[15].colour, col.MAGENTA)
+ # Fifth commit self.assertEqual(lines[16].text, '05: %s' % commits[4][1]) self.assertSummary(lines[17].text, 'sandbox', '+', ['board4']) - self.assertSummary(lines[18].text, 'powerpc', '', ['board3'], ok=True) + self.assertSummary(lines[18].text, 'powerpc', '', ['board3'], + outcome=OUTCOME_OK)
# The second line of errors[3] is a duplicate, so buildman will drop it expect = errors[3].rstrip().split('\n') @@ -257,8 +280,10 @@ class TestBuild(unittest.TestCase): self.assertEqual(lines[20].text, 'w-%s' % errors[2].rstrip().replace('\n', '\nw-'))
+ # Sixth commit self.assertEqual(lines[21].text, '06: %s' % commits[5][1]) - self.assertSummary(lines[22].text, 'sandbox', '', ['board4'], ok=True) + self.assertSummary(lines[22].text, 'sandbox', '', ['board4'], + outcome=OUTCOME_OK)
# The second line of errors[3] is a duplicate, so buildman will drop it expect = errors[3].rstrip().split('\n') @@ -269,6 +294,7 @@ class TestBuild(unittest.TestCase): self.assertEqual(lines[24].text, 'w-%s' % errors[0].rstrip().replace('\n', '\nw-'))
+ # Seventh commit self.assertEqual(lines[25].text, '07: %s' % commits[6][1]) self.assertSummary(lines[26].text, 'sandbox', '+', ['board4'])
sjg@google.com
