[PATCH] fastboot: getvar: fix partition-size return value
The size returned by 'getvar partition-size' should be in bytes, not in blocks as fastboot uses that value to generate empty partition when running format [1].
[1] https://android.googlesource.com/platform/system/core/+/refs/heads/android10...
Signed-off-by: Gary Bisson gary.bisson@boundarydevices.com --- Hi,
Another test was to run 'fastboot getvar partition-size:system' on a shipping Android phone, it will give you the size in bytes as well.
Regards, Gary --- drivers/fastboot/fb_getvar.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/fastboot/fb_getvar.c b/drivers/fastboot/fb_getvar.c index 95cb434189..51a2bea86d 100644 --- a/drivers/fastboot/fb_getvar.c +++ b/drivers/fastboot/fb_getvar.c @@ -94,7 +94,7 @@ static const struct { * * @param[in] part_name Info for which partition name to look for * @param[in,out] response Pointer to fastboot response buffer - * @param[out] size If not NULL, will contain partition size (in blocks) + * @param[out] size If not NULL, will contain partition size * @return Partition number or negative value on error */ static int getvar_get_part_info(const char *part_name, char *response, @@ -108,13 +108,13 @@ static int getvar_get_part_info(const char *part_name, char *response, r = fastboot_mmc_get_part_info(part_name, &dev_desc, &part_info, response); if (r >= 0 && size) - *size = part_info.size; + *size = part_info.size * part_info.blksz; # elif CONFIG_IS_ENABLED(FASTBOOT_FLASH_NAND) struct part_info *part_info;
r = fastboot_nand_get_part_info(part_name, &part_info, response); if (r >= 0 && size) - *size = part_info->size; + *size = part_info->size * part_info.blksz; # else fastboot_fail("this storage is not supported in bootloader", response); r = -ENODEV;
Gentle ping on this patch. Anyone had a chance to review?
Regards, Gary
Regards, Gary
- @param[in] part_name Info for which partition name to look for
- @param[in,out] response Pointer to fastboot response buffer
- @param[out] size If not NULL, will contain partition size (in blocks)
- @return Partition number or negative value on error
# else fastboot_fail("this storage is not supported in bootloader", response); r = -ENODEV; -- 2.26.2
Gentle ping on this patch. Hopefully Sam's email won't bounce this time.
Let me know if you have any questions.
Regards, Gary
Regards, Gary
Regards, Gary
Hi Gary,
You couldn't have better timing than now :-)
I'm now testing PR for Tom [1] and your original patch was causing some issues (probably it was correct when it was posted, but it was my fault that I'm going to pull it in now - my apologizes).
I've fixed it [2] - please check if this fix is OK.
Now I'm hunting another issues with sandbox [3]. When fixed I will send the PR.
Links:
[1] - https://github.com/lmajewski/u-boot-dfu/commits/testing [2] - https://github.com/lmajewski/u-boot-dfu/commit/a2491ed5dd7bade94328f58ae0739... [3] - https://travis-ci.org/github/lmajewski/u-boot-dfu/jobs/641984520
Regards, Gary
Regards, Gary
Regards, Gary
blocks)
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Lukasz,
On Wed, Aug 26, 2020 at 11:36:51AM +0200, Lukasz Majewski wrote:
Hi Gary,
Actually it was wrong before too, thanks for catching it! Reason is that I didn't build with FASTBOOT_FLASH_NAND config enabled which I should have done to check the second part of the change...
Sounds good. Let me know if you need anything from me.
Regards, Gary
Hi Gary,
Hi Lukasz,
Hi Gary,
Ok. I've found another issue with this patch - it has some issues with sunxi:
drivers/fastboot/fb_getvar.c: In function 'getvar_get_part_info':
+drivers/fastboot/fb_getvar.c:118:38: error: 'struct part_info' has no member named 'blksz'
+ 118 | *size = part_info->size * part_info->blksz;
+make[3]: *** [drivers/fastboot/fb_getvar.o] Error 1
The whole CI run can be found here: https://travis-ci.org/github/lmajewski/u-boot-dfu/builds/721449368
I think that the best solution would be if I drop this patch from the series and send PR (after some CI testing) without it. If you manage to fix it ASAP, then I will pull it immediately.
Regards, Gary
Lukasz Majewski
Hi Lukasz,
On Thu, Aug 27, 2020 at 08:25:51AM +0200, Lukasz Majewski wrote:
Hi Gary,
Hi Lukasz,
Hi Gary,
Thanks, I'll take a look.
Sure let's do this, drop my patch for now, I'll re-submit when possible.
Regards, Gary
Gary Bisson
Lukasz Majewski
