[PATCH 1/2] ARM: imx: m53menlo: Do not fail boot on invalid splash screen
None of these splash screen loading errors are so critical as to justify complete failure to boot, so just print error message as needed and return 0, the boot can very likely continue without the splash.
Fix a couple of missing free(dst) instances as well.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- board/menlo/m53menlo/m53menlo.c | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/board/menlo/m53menlo/m53menlo.c b/board/menlo/m53menlo/m53menlo.c index 58a564ac31..d4288a2c57 100644 --- a/board/menlo/m53menlo/m53menlo.c +++ b/board/menlo/m53menlo/m53menlo.c @@ -353,24 +353,28 @@ int board_late_init(void)
ret = splash_screen_prepare(); if (ret < 0) - return ret; + goto splasherr;
len = CONFIG_SYS_VIDEO_LOGO_MAX_SIZE; ret = gunzip(dst + 2, CONFIG_SYS_VIDEO_LOGO_MAX_SIZE - 2, (uchar *)addr, &len); if (ret) { printf("Error: no valid bmp or bmp.gz image at %lx\n", addr); - free(dst); - return ret; + goto splasherr; }
ret = uclass_get_device(UCLASS_VIDEO, 0, &dev); if (ret) - return ret; + goto splasherr;
ret = video_bmp_display(dev, (ulong)dst + 2, xpos, ypos, true); if (ret) - return ret; + goto splasherr; + + return 0; + +splasherr: + free(dst); #endif return 0; }
Convert the board to DM_ETH instead of legacy networking. This requires a minor addition to the DT to satisfy the requirement for specifying a PHY node. No functional change from board user perspective.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/imx53-m53menlo.dts | 11 +++++++++++ configs/m53menlo_defconfig | 3 +++ 2 files changed, 14 insertions(+)
diff --git a/arch/arm/dts/imx53-m53menlo.dts b/arch/arm/dts/imx53-m53menlo.dts index a6805eca9d..3767dcaef4 100644 --- a/arch/arm/dts/imx53-m53menlo.dts +++ b/arch/arm/dts/imx53-m53menlo.dts @@ -86,8 +86,19 @@ &fec { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_fec>; + phy-handle = <ðphy0>; phy-mode = "rmii"; status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; + }; };
&i2c1 { diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index a65c21a139..5289899601 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -75,6 +75,9 @@ CONFIG_NAND_MXC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_ETH_PHY=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX5=y CONFIG_DM_REGULATOR=y
Convert the board to DM_ETH instead of legacy networking. This requires a minor addition to the DT to satisfy the requirement for specifying a PHY node. No functional change from board user perspective. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
None of these splash screen loading errors are so critical as to justify complete failure to boot, so just print error message as needed and return 0, the boot can very likely continue without the splash. Fix a couple of missing free(dst) instances as well. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de
sbabic@denx.de
