[U-Boot] [PATCH v2] Added arch_lmb_reserve to allow arch specific memory regions protection
Each architecture has different ways of determine what regions of memory might not be valid to get overwritten when we boot. This provides a hook to allow them to reserve any regions they care about. Currently only ppc, m68k and sparc need/use this.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
For some reason I had two commits in my tree and the cmd_bootm.c changes didn't make it out.
- k
common/cmd_bootm.c | 7 +++++++ lib_m68k/bootm.c | 29 ++++++++++++++++------------- lib_ppc/bootm.c | 50 ++++++++++++++++++++++++++++---------------------- lib_sparc/bootm.c | 16 +++++++++------- 4 files changed, 60 insertions(+), 42 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 897e9f6..e49d6f7 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -128,6 +128,12 @@ void __board_lmb_reserve(struct lmb *lmb) } void board_lmb_reserve(struct lmb *lmb) __attribute__((weak, alias("__board_lmb_reserve")));
+void __arch_lmb_reserve(struct lmb *lmb) +{ + /* please define platform specific arch_lmb_reserve() */ +} +void arch_lmb_reserve(struct lmb *lmb) __attribute__((weak, alias("__arch_lmb_reserve"))); + #if defined(__ARM__) #define IH_INITRD_ARCH IH_ARCH_ARM #elif defined(__avr32__) @@ -173,6 +179,7 @@ static int bootm_start(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
lmb_add(&images.lmb, (phys_addr_t)mem_start, mem_size);
+ arch_lmb_reserve(&images.lmb); board_lmb_reserve(&images.lmb);
/* get kernel image header, start address and length */ diff --git a/lib_m68k/bootm.c b/lib_m68k/bootm.c index 6504cc9..1d773d3 100644 --- a/lib_m68k/bootm.c +++ b/lib_m68k/bootm.c @@ -43,22 +43,10 @@ DECLARE_GLOBAL_DATA_PTR; static ulong get_sp (void); static void set_clocks_in_mhz (bd_t *kbd);
-int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) +void arch_lmb_reserve(struct lmb *lmb) { ulong sp;
- ulong rd_len; - ulong initrd_start, initrd_end; - int ret; - - ulong cmd_start, cmd_end; - ulong bootmap_base; - bd_t *kbd; - void (*kernel) (bd_t *, ulong, ulong, ulong, ulong); - struct lmb *lmb = &images->lmb; - - bootmap_base = getenv_bootm_low(); - /* * Booting a (Linux) kernel image * @@ -74,6 +62,21 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) /* adjust sp by 1K to be safe */ sp -= 1024; lmb_reserve(lmb, sp, (CFG_SDRAM_BASE + gd->ram_size - sp)); +} + +int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) +{ + ulong rd_len; + ulong initrd_start, initrd_end; + int ret; + + ulong cmd_start, cmd_end; + ulong bootmap_base; + bd_t *kbd; + void (*kernel) (bd_t *, ulong, ulong, ulong, ulong); + struct lmb *lmb = &images->lmb; + + bootmap_base = getenv_bootm_low();
/* allocate space and init command line */ ret = boot_get_cmdline (lmb, &cmd_start, &cmd_end, bootmap_base); diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index 5af25dd..99bb5db 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -55,30 +55,10 @@ static void set_clocks_in_mhz (bd_t *kbd); #define CFG_LINUX_LOWMEM_MAX_SIZE (768*1024*1024) #endif
-__attribute__((noinline)) -int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) +void arch_lmb_reserve(struct lmb *lmb) { - ulong sp; - - ulong initrd_start, initrd_end; - ulong rd_len; - ulong size; phys_size_t bootm_size; - - ulong cmd_start, cmd_end, bootmap_base; - bd_t *kbd; - void (*kernel)(bd_t *, ulong r4, ulong r5, ulong r6, - ulong r7, ulong r8, ulong r9); - int ret; - ulong of_size = images->ft_len; - struct lmb *lmb = &images->lmb; - -#if defined(CONFIG_OF_LIBFDT) - char *of_flat_tree = images->ft_addr; -#endif - - kernel = (void (*)(bd_t *, ulong, ulong, ulong, - ulong, ulong, ulong))images->ep; + ulong size, sp, bootmap_base;
bootmap_base = getenv_bootm_low(); bootm_size = getenv_bootm_size(); @@ -116,6 +96,32 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) sp -= 1024; lmb_reserve(lmb, sp, (CFG_SDRAM_BASE + get_effective_memsize() - sp));
+ return ; +} + +__attribute__((noinline)) +int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) +{ + ulong initrd_start, initrd_end; + ulong rd_len; + + ulong cmd_start, cmd_end, bootmap_base; + bd_t *kbd; + void (*kernel)(bd_t *, ulong r4, ulong r5, ulong r6, + ulong r7, ulong r8, ulong r9); + int ret; + ulong of_size = images->ft_len; + struct lmb *lmb = &images->lmb; + +#if defined(CONFIG_OF_LIBFDT) + char *of_flat_tree = images->ft_addr; +#endif + + kernel = (void (*)(bd_t *, ulong, ulong, ulong, + ulong, ulong, ulong))images->ep; + + bootmap_base = getenv_bootm_low(); + if (!of_size) { /* allocate space and init command line */ ret = boot_get_cmdline (lmb, &cmd_start, &cmd_end, bootmap_base); diff --git a/lib_sparc/bootm.c b/lib_sparc/bootm.c index 4e8c920..d6b2e98 100644 --- a/lib_sparc/bootm.c +++ b/lib_sparc/bootm.c @@ -81,6 +81,15 @@ struct __attribute__ ((packed)) { /* temporary initrd image holder */ image_header_t ihdr;
+void arch_lmb_reserve(struct lmb *lmb) +{ + /* Reserve the space used by PROM and stack. This is done + * to avoid that the RAM image is copied over stack or + * PROM. + */ + lmb_reserve(lmb, CFG_RELOC_MONITOR_BASE, CFG_RAM_END); +} + /* boot the linux kernel */ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t * images) { @@ -124,13 +133,6 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t * images) rd_len = images->rd_end - images->rd_start;
if (rd_len) { - - /* Reserve the space used by PROM and stack. This is done - * to avoid that the RAM image is copied over stack or - * PROM. - */ - lmb_reserve(lmb, CFG_RELOC_MONITOR_BASE, CFG_RAM_END); - ret = boot_ramdisk_high(lmb, images->rd_start, rd_len, &initrd_start, &initrd_end); if (ret) {
Dear Kumar Gala,
In message 1224078503-23785-1-git-send-email-galak@kernel.crashing.org you wrote:
- k
Tried to apply to "next" branch as requested, but this fails with non-trivial merge conflicts:
Applying Added arch_lmb_reserve to allow arch specific memory regions protection error: patch failed: lib_m68k/bootm.c:74 error: lib_m68k/bootm.c: patch does not apply error: patch failed: lib_ppc/bootm.c:55 error: lib_ppc/bootm.c: patch does not apply error: patch failed: lib_sparc/bootm.c:124 error: lib_sparc/bootm.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged common/cmd_bootm.c Auto-merged lib_m68k/bootm.c CONFLICT (content): Merge conflict in lib_m68k/bootm.c Auto-merged lib_ppc/bootm.c Auto-merged lib_sparc/bootm.c CONFLICT (content): Merge conflict in lib_sparc/bootm.c Failed to merge in the changes. Patch failed at 0001.
Kumar Gala
