[PATCH] rpi: Use OF_BOARD rather than OF_EMBED
The use of OF_EMBED isn't recommended for standard use and the OF_BOARD is actually a better fit for the Raspberry Pi as the prior firmware provides a DT that can be used by U-Boot and the subsequent OS too, but it still allows the loading of a DT from disk as well if users wish to use the upstream kernel DT.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- configs/rpi_0_w_defconfig | 2 +- configs/rpi_2_defconfig | 2 +- configs/rpi_3_32b_defconfig | 2 +- configs/rpi_3_b_plus_defconfig | 2 +- configs/rpi_3_defconfig | 2 +- configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_arm64_defconfig | 1 + configs/rpi_defconfig | 2 +- 9 files changed, 9 insertions(+), 6 deletions(-)
diff --git a/configs/rpi_0_w_defconfig b/configs/rpi_0_w_defconfig index 5249b29d76c..8c217848ca2 100644 --- a/configs/rpi_0_w_defconfig +++ b/configs/rpi_0_w_defconfig @@ -23,7 +23,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_FS_UUID=y -CONFIG_OF_EMBED=y +CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 154284765f4..bfc5679fb7e 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -24,7 +24,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_FS_UUID=y -CONFIG_OF_EMBED=y +CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index ef1f25d2ad7..54cdcee980a 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -23,7 +23,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_FS_UUID=y -CONFIG_OF_EMBED=y +CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/rpi_3_b_plus_defconfig b/configs/rpi_3_b_plus_defconfig index 154615d78a1..3008c7a1c18 100644 --- a/configs/rpi_3_b_plus_defconfig +++ b/configs/rpi_3_b_plus_defconfig @@ -22,7 +22,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_FS_UUID=y -CONFIG_OF_EMBED=y +CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index f0cf7f8e236..f7b9108ba00 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -22,7 +22,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_FS_UUID=y -CONFIG_OF_EMBED=y +CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index 713b2ee231c..fa20ab767fe 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_FS_UUID=y +CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 24f70b14fe8..741d4dbbbf4 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_FS_UUID=y +CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/rpi_arm64_defconfig b/configs/rpi_arm64_defconfig index 1d1ff12a58c..5e1195dd786 100644 --- a/configs/rpi_arm64_defconfig +++ b/configs/rpi_arm64_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_FS_UUID=y +CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_TFTP_TSIZE=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 28b92b14456..1504093eddf 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -23,7 +23,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_FS_UUID=y -CONFIG_OF_EMBED=y +CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y
My only concern is from when I did: https://patchwork.ozlabs.org/project/uboot/patch/20211224165704.2855211-1-tr... so I think you need to also drop the "imply OF_HAS_PRIOR_STAGE" from the Kconfig files and should probably move to select (do not allow the user to override this, it shall always be OF_EMBED now), or at least imply (sufficiently advanced users may want a different choice and should be able to make it).
This very old patch seems to have arrived in my queue. I am pleased to see it!
From my understanding the correct thing here is to 'imply
OF_HAS_PRIOR_STAGE' in the Kconfig, which is done for some rpi boards but not all. Then the OF_BOARD setting becomes the default.
We should not really 'select OF_HAS_PRIOR_STAGE' since it makes testing with a U-Boot-supplied DT impossible.
Peter Robinson
