[U-Boot] [PATCH v2] ARM: at91: sama5: change the environment address to 0x6000
As sama5 board has 32k sram size, so the at91bootstrap and spl for sama5 boards is bigger than 16k (0x4000). That will overlap the U-Boot environment. So I move environment to 0x6000. And reduce its size as well.
Following shows the size of the spl binaries (v2015.04 vs v2015.07):
% ls v2015.04/*spi*spl.bin -l | awk '{print $5,$(NF)}' 15540 v2015.04/at91sam9n12ek_spiflash_defconfig_u-boot-spl.bin 15704 v2015.04/at91sam9x5ek_spiflash_defconfig_u-boot-spl.bin 16064 v2015.04/sama5d3xek_spiflash_defconfig_u-boot-spl.bin 16304 v2015.04/sama5d4ek_spiflash_defconfig_u-boot-spl.bin 16304 v2015.04/sama5d4_xplained_spiflash_defconfig_u-boot-spl.bin
% ls v2015.07/*spi*spl.bin -l | awk '{print $5,$(NF)}' 16136 v2015.07/at91sam9n12ek_spiflash_defconfig_u-boot-spl.bin 16300 v2015.07/at91sam9x5ek_spiflash_defconfig_u-boot-spl.bin 16664 v2015.07/sama5d3xek_spiflash_defconfig_u-boot-spl.bin 16904 v2015.07/sama5d4ek_spiflash_defconfig_u-boot-spl.bin 16904 v2015.07/sama5d4_xplained_spiflash_defconfig_u-boot-spl.bin
The gcc version is: gcc 4.7.3 (Ubuntu/Linaro 4.7.3-12ubuntu1)
Signed-off-by: Josh Wu josh.wu@atmel.com Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com Acked-by: Bo Shen voice.shen@gmail.com ---
Changes in v2: - add more information (spl size) to the commit log
include/configs/at91-sama5_common.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index a5990ce..0b60f0b 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -98,8 +98,8 @@ #elif CONFIG_SYS_USE_SERIALFLASH /* u-boot env in serial flash, by default is bus 0 and cs 0 */ #define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_OFFSET 0x4000 -#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_OFFSET 0x6000 +#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x1000 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x21000000 0x60000 0xc000; " \
Dear Josh Wu,
Josh Wu josh.wu@atmel.com writes:
Changes in v2:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Josh Wu
