[PATCH 1/3] sysinfo: rcar3: Fix Draak and Eagle board code
Correct the board code ID based on the hardware documentation
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Tam Nguyen tam.nguyen.xa@renesas.com Signed-off-by: Hai Pham hai.pham.ud@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- drivers/sysinfo/rcar3.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/sysinfo/rcar3.c b/drivers/sysinfo/rcar3.c index c2f4ddfbbe3..c0afc92f675 100644 --- a/drivers/sysinfo/rcar3.c +++ b/drivers/sysinfo/rcar3.c @@ -16,12 +16,12 @@ #define BOARD_SALVATOR_X 0x0 #define BOARD_KRIEK 0x1 #define BOARD_STARTER_KIT 0x2 +#define BOARD_EAGLE 0x3 #define BOARD_SALVATOR_XS 0x4 +#define BOARD_DRAAK 0x7 #define BOARD_EBISU 0x8 #define BOARD_STARTER_KIT_PRE 0xB #define BOARD_EBISU_4D 0xD -#define BOARD_DRAAK 0xE -#define BOARD_EAGLE 0xF
/** * struct sysinfo_rcar_priv - sysinfo private data
Add new sysinfo IDs for R-Car V3H Condor/Condor-I .
Enable support for sysinfo on R-Car V3H Condor/Condor-I. The sysinfo is used e.g. to access and decode board-specific information and then in turn used by board-info to print those information.
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Tam Nguyen tam.nguyen.xa@renesas.com Signed-off-by: Hai Pham hai.pham.ud@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org [Marek: Drop compatible from I2C node, this is in r8a77980.dtsi already. Drop status = "okay" from EEPROM node. Add dts: tag. Update the commit message, note the new sysinfo IDs. Fix Kconfig EEPROM address to be 0x50 and match the DT, sync config.] --- arch/arm/dts/r8a77980-condor-u-boot.dts | 17 +++++++++++++++++ configs/r8a77980_condor_defconfig | 5 +++++ drivers/sysinfo/rcar3.c | 15 +++++++++++++++ 3 files changed, 37 insertions(+)
diff --git a/arch/arm/dts/r8a77980-condor-u-boot.dts b/arch/arm/dts/r8a77980-condor-u-boot.dts index 576a74e6030..530abdb72bc 100644 --- a/arch/arm/dts/r8a77980-condor-u-boot.dts +++ b/arch/arm/dts/r8a77980-condor-u-boot.dts @@ -12,6 +12,23 @@ aliases { spi0 = &rpc; }; + + sysinfo { + compatible = "renesas,rcar-sysinfo"; + i2c-eeprom = <&sysinfo_eeprom>; + u-boot,dm-pre-reloc; + }; +}; + +&i2c0 { + u-boot,dm-pre-reloc; + + sysinfo_eeprom: eeprom@50 { + compatible = "rohm,br24t01", "atmel,24c01"; + reg = <0x50>; + pagesize = <8>; + u-boot,dm-pre-reloc; + }; };
&rpc { diff --git a/configs/r8a77980_condor_defconfig b/configs/r8a77980_condor_defconfig index 0c3493cdf8d..e1b3dc5d38a 100644 --- a/configs/r8a77980_condor_defconfig +++ b/configs/r8a77980_condor_defconfig @@ -33,6 +33,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2068 CONFIG_CMD_BOOTZ=y +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y @@ -64,6 +65,9 @@ CONFIG_DFU_SF=y CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y @@ -84,6 +88,7 @@ CONFIG_SCIF_CONSOLE=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_RENESAS_RPC_SPI=y +CONFIG_SYSINFO=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y diff --git a/drivers/sysinfo/rcar3.c b/drivers/sysinfo/rcar3.c index c0afc92f675..7b127986da7 100644 --- a/drivers/sysinfo/rcar3.c +++ b/drivers/sysinfo/rcar3.c @@ -18,10 +18,12 @@ #define BOARD_STARTER_KIT 0x2 #define BOARD_EAGLE 0x3 #define BOARD_SALVATOR_XS 0x4 +#define BOARD_CONDOR 0x6 #define BOARD_DRAAK 0x7 #define BOARD_EBISU 0x8 #define BOARD_STARTER_KIT_PRE 0xB #define BOARD_EBISU_4D 0xD +#define BOARD_CONDOR_I 0x10
/** * struct sysinfo_rcar_priv - sysinfo private data @@ -65,6 +67,7 @@ static void sysinfo_rcar_parse(struct sysinfo_rcar_priv *priv) const u8 board_rev = priv->val & BOARD_REV_MASK; bool salvator_xs = false; bool ebisu_4d = false; + bool condor_i = false; char rev_major = '?'; char rev_minor = '?';
@@ -138,6 +141,18 @@ static void sysinfo_rcar_parse(struct sysinfo_rcar_priv *priv) "Renesas Kriek board rev %c.%c", rev_major, rev_minor); return; + case BOARD_CONDOR_I: + condor_i = true; + fallthrough; + case BOARD_CONDOR: + if (!board_rev) { /* Only rev 0 is valid */ + rev_major = '1'; + rev_minor = '0'; + } + snprintf(priv->boardmodel, sizeof(priv->boardmodel), + "Renesas Condor%s board rev %c.%c", + condor_i ? "-I" : "", rev_major, rev_minor); + return; default: snprintf(priv->boardmodel, sizeof(priv->boardmodel), "Renesas -Unknown- board rev ?.?");
Enable support for sysinfo on R-Car D3 Draak board. The sysinfo is used e.g. to access and decode board-specific information and then in turn used by board-info to print those information.
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Tam Nguyen tam.nguyen.xa@renesas.com Signed-off-by: Hai Pham hai.pham.ud@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org [Marek: Drop compatible from I2C node, this is in r8a77995.dtsi already. Drop status = "okay" from EEPROM node. Add dts: tag. Fix Kconfig EEPROM address to be 0x50 and match the DT, sync config.] --- arch/arm/dts/r8a77995-draak-u-boot.dts | 19 +++++++++++++++++++ configs/r8a77995_draak_defconfig | 5 +++++ 2 files changed, 24 insertions(+)
diff --git a/arch/arm/dts/r8a77995-draak-u-boot.dts b/arch/arm/dts/r8a77995-draak-u-boot.dts index 0ea2570c1dc..260bc5da19f 100644 --- a/arch/arm/dts/r8a77995-draak-u-boot.dts +++ b/arch/arm/dts/r8a77995-draak-u-boot.dts @@ -8,6 +8,25 @@ #include "r8a77995-draak.dts" #include "r8a77995-u-boot.dtsi"
+/ { + sysinfo { + compatible = "renesas,rcar-sysinfo"; + i2c-eeprom = <&sysinfo_eeprom>; + u-boot,dm-pre-reloc; + }; +}; + +&i2c0 { + u-boot,dm-pre-reloc; + + sysinfo_eeprom: eeprom@50 { + compatible = "rohm,br24t01", "atmel,24c01"; + reg = <0x50>; + pagesize = <8>; + u-boot,dm-pre-reloc; + }; +}; + &rpc { reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; status = "disabled"; diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 4ddb66aef9c..a09b33e7740 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -33,6 +33,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2068 CONFIG_CMD_BOOTZ=y +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y @@ -65,6 +66,9 @@ CONFIG_DFU_SF=y CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y @@ -94,6 +98,7 @@ CONFIG_SCIF_CONSOLE=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_RENESAS_RPC_SPI=y +CONFIG_SYSINFO=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y
