[U-Boot] [PATCH] board/ls2080ardb: Update board env based on SoC
As per current implemenetation, default value of board env is based on board filename i.e ls2080ardb.
With distro support changes, this env is used to decide upon kernel dtb which is different for other SoCs (ls2088a, ls2081a) combination supported with this board.
Add support to modify board env based on SoC type
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- board/freescale/ls2080ardb/ls2080ardb.c | 12 ++++++++++++ 1 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index d7122b3..ca9c047 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -247,6 +247,8 @@ int misc_init_r(void) char *env_hwconfig; u32 __iomem *dcfg_ccsr = (u32 __iomem *)DCFG_BASE; u32 val; + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 svr = gur_in32(&gur->svr);
val = in_le32(dcfg_ccsr + DCFG_RCWSR13 / 4);
@@ -274,6 +276,16 @@ int misc_init_r(void)
if (adjust_vdd(0)) printf("Warning: Adjusting core voltage failed.\n"); + /* + * Default value of board env is based on filename which is + * ls2080ardb. Modify board env for other supported SoCs + */ + if ((SVR_SOC_VER(svr) == SVR_LS2088A) || + (SVR_SOC_VER(svr) == SVR_LS2048A)) + setenv("board", "ls2088ardb"); + else if ((SVR_SOC_VER(svr) == SVR_LS2081A) || + (SVR_SOC_VER(svr) == SVR_LS2041A)) + setenv("board", "ls2081ardb");
return 0; }
Please point me to where environmental variable "board" is used for distro boot. I only see it for PXE.
- if ((SVR_SOC_VER(svr) == SVR_LS2088A) ||
- else if ((SVR_SOC_VER(svr) == SVR_LS2081A) ||
Please double check this. I think "setenv" has been replaced by "env_set" as of commit 382bee57f.
York
-----Original Message----- From: York Sun Sent: Thursday, August 24, 2017 8:26 PM To: Priyanka Jain priyanka.jain@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH] board/ls2080ardb: Update board env based on SoC
Please refer to file end part in "ENV_SETTINGS" section in file "include/configs/ls2080ardb.h", Linux boot commands like "nor_bootcmd" uses command "bootm $loadr_addr#$board" Depending upon board value, kernel dtb is chosen.
- struct ccsr_gur __iomem *gur = (void
York
Thanks, I will change "setenv" to "env_set"
Priyanka
I see. It is not a variable used by U-Boot itself. I wonder if you can use multiple configurations in FIT image to maximize the flexibility to load different device tree image.
York
-----Original Message----- From: York Sun Sent: Friday, August 25, 2017 8:53 PM To: Priyanka Jain priyanka.jain@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH] board/ls2080ardb: Update board env based on SoC
boot.
York
This is mainly useful when we are booting using separate images , not a FIT image. Example of use case: LS2080ARDB can supports ls2080a, ls2081a, ls2088a socs. Single flash image is build for the board which can support either combination of SoC. kernel is booted with same itb which is flex_installer_arm64.itb which depending on $board env selects dtb image on NOR flash. flex_installer_arm64.itb has configuration like: configurations { default = "ls2088ardb";
ls2080ardb { description = "config for ls2080ardb"; kernel = "kernel"; ramdisk = "initrd-installer"; fdt = "ls2080ardb-dtb"; };
ls2088ardb { description = "config for ls2088ardb"; kernel = "kernel"; ramdisk = "initrd-installer"; fdt = "ls2088ardb-dtb"; };
Priyanka
Priyanka Jain
York Sun
