[PULL] u-boot-socfpga/master
The following changes since commit c0a1409d21e7b342566dccb9cc1d38209aabc5ff:
configs: Resync with savedefconfig (2022-05-23 13:56:21 -0400)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to 1b05136a6ca8387175ca7bf1aa66a9c40a153cc2:
arm: socfpga: Add the terasic de10-standard board (2022-05-23 21:28:07 +0200)
---------------------------------------------------------------- Humberto Naves (1): arm: socfpga: Add the terasic de10-standard board
arch/arm/dts/socfpga_cyclone5_de10_standard.dts | 86 +++++++++++ arch/arm/mach-socfpga/Kconfig | 7 + board/terasic/de10-standard/MAINTAINERS | 5 + board/terasic/de10-standard/Makefile | 6 + board/terasic/de10-standard/qts/iocsr_config.h | 659 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/terasic/de10-standard/qts/pinmux_config.h | 218 ++++++++++++++++++++++++++++ board/terasic/de10-standard/qts/pll_config.h | 84 +++++++++++ board/terasic/de10-standard/qts/sdram_config.h | 344 ++++++++++++++++++++++++++++++++++++++++++++ board/terasic/de10-standard/socfpga.c | 5 + configs/socfpga_de10_standard_defconfig | 66 +++++++++ include/configs/socfpga_de10_standard.h | 18 +++ 11 files changed, 1498 insertions(+) create mode 100644 arch/arm/dts/socfpga_cyclone5_de10_standard.dts create mode 100644 board/terasic/de10-standard/MAINTAINERS create mode 100644 board/terasic/de10-standard/Makefile create mode 100644 board/terasic/de10-standard/qts/iocsr_config.h create mode 100644 board/terasic/de10-standard/qts/pinmux_config.h create mode 100644 board/terasic/de10-standard/qts/pll_config.h create mode 100644 board/terasic/de10-standard/qts/sdram_config.h create mode 100644 board/terasic/de10-standard/socfpga.c create mode 100644 configs/socfpga_de10_standard_defconfig create mode 100644 include/configs/socfpga_de10_standard.h
