i'm new to u-boot and new to embedded linux, and i have some questions ? :-)
i am using the virtex4-fx12- minimodul with integrated powerpc. booting linux from systemAce works fine and now i try to boot from flash. i want u-boot as bootloader/firmware.
Does anyone use this combination ? if not, i think i have to create my own u-boot config ? where is the place to start on this issue ? I've the ELDK installed and read the README :)
Thanks Georg
----------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------- Forschungszentrum Jülich GmbH 52425 Jülich
Sitz der Gesellschaft: Jülich Eingetragen im Handelsregister des Amtsgerichts Düren Nr. HR B 3498 Vorsitzende des Aufsichtsrats: MinDirig'in Bärbel Brumme-Bothe Geschäftsführung: Prof. Dr. Achim Bachem (Vorsitzender), Dr. Ulrich Krafft (stellv. Vorsitzender) ----------------------------------------------------------------------------------------- -----------------------------------------------------------------------------------------
U-boot does work for the Virtex platforms, but you'll probably need to create a new u-boot config for your board and u-boot does not yet have a driver for the TEMAC ethernet device. One needs to be written.
Cheers, g.
Cheers, g.
Is there a hotwo or something else, to make a new config ?
Georg
Grant Likely
schardt
