[PATCH 0/7] imx8mp: Enable PCIe/NVMe support
pcie_imx doesn't seem to share any useful code for iMX8MP SoC and it is rather tied to quite old port of pcie_designware driver from Linux which suffices only iMX6 specific needs.
But currently we have the common DWC specific bits which alligns pretty well with DW PCIe controller on iMX8MP SoC. So lets reuse those common bits instead as a new driver for iMX8 SoCs. It should be fairly easy to add support for other iMX8 variants to this driver.
iMX8MP SoC also comes up with standalone PCIe PHY support, so hence we can reuse the generic PHY infrastructure to power on PCIe PHY.
Patch #1: Adds PCIe clocks support. Patch #2: Adds i.MX8MP reset controller support. Patch #3: Extend i.MX8MP power domain driver with PCIe support Patch #4: Expose high performance PLL clock required for PCIe PHY on verdin board. Patch #5: Adds standalone PCIe PHY support for i.MX8MP SoC. Patch #6: Adds DW PCIe controller support for iMX8MP SoC. Patch #7: Enable PCIe/NVMe support for verdin board.
Testing with this patch-set included:
Verdin iMX8MP # pci enum PCIE-0: Link up (Gen1-x1, Bus0) Verdin iMX8MP # Verdin iMX8MP # nvme scan Verdin iMX8MP # Verdin iMX8MP # nvme info Device 0: Vendor: 0x126f Rev: T0828A0 Prod: AA000000000000000720 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) Verdin iMX8MP # Verdin iMX8MP # load nvme 0 $loadaddr <file-name>
Sumit Garg (7): clk: imx8mp: Add support for PCIe clocks reset: imx: Add support for i.MX8MP reset controller imx8mp: power-domain: Add PCIe support imx8mp: power-domain: Expose high performance PLL clock phy: phy-imx8m-pcie: Add support for i.MX8M{M/P} PCIe PHY pci: Add DW PCIe controller support for iMX8MP SoC verdin-imx8mp_defconfig: Enable PCIe/NVMe support
configs/verdin-imx8mp_defconfig | 9 + drivers/clk/imx/clk-imx8mp.c | 6 + drivers/pci/Kconfig | 8 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_imx8.c | 348 ++++++++++++++++++++++++++ drivers/phy/Kconfig | 9 + drivers/phy/Makefile | 1 + drivers/phy/phy-imx8m-pcie.c | 246 ++++++++++++++++++ drivers/power/domain/imx8mp-hsiomix.c | 121 ++++++++- drivers/reset/reset-imx7.c | 114 +++++++++ 10 files changed, 859 insertions(+), 4 deletions(-) create mode 100644 drivers/pci/pcie_dw_imx8.c create mode 100644 drivers/phy/phy-imx8m-pcie.c
Pre-requisite to enable PCIe support on iMX8MP SoC.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/clk/imx/clk-imx8mp.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/clk/imx/clk-imx8mp.c b/drivers/clk/imx/clk-imx8mp.c index a21a3ce34bb..7dfc829df2c 100644 --- a/drivers/clk/imx/clk-imx8mp.c +++ b/drivers/clk/imx/clk-imx8mp.c @@ -62,6 +62,10 @@ static const char *imx8mp_dram_apb_sels[] = {"clock-osc-24m", "sys_pll2_200m", " "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", "sys_pll2_250m", "audio_pll2_out", };
+static const char * const imx8mp_pcie_aux_sels[] = {"clock-osc-24m", "sys_pll2_200m", "sys_pll2_50m", + "sys_pll3_out", "sys_pll2_100m", "sys_pll1_80m", + "sys_pll1_160m", "sys_pll1_200m", }; + static const char *imx8mp_i2c5_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", "sys_pll3_out", "audio_pll1_out", "video_pll1_out", "audio_pll2_out", "sys_pll1_133m", }; @@ -272,6 +276,7 @@ static int imx8mp_clk_probe(struct udevice *dev)
clk_dm(IMX8MP_CLK_DRAM_ALT, imx8m_clk_composite("dram_alt", imx8mp_dram_alt_sels, base + 0xa000)); clk_dm(IMX8MP_CLK_DRAM_APB, imx8m_clk_composite_critical("dram_apb", imx8mp_dram_apb_sels, base + 0xa080)); + clk_dm(IMX8MP_CLK_PCIE_AUX, imx8m_clk_composite("pcie_aux", imx8mp_pcie_aux_sels, base + 0xa400)); clk_dm(IMX8MP_CLK_I2C5, imx8m_clk_composite("i2c5", imx8mp_i2c5_sels, base + 0xa480)); clk_dm(IMX8MP_CLK_I2C6, imx8m_clk_composite("i2c6", imx8mp_i2c6_sels, base + 0xa500)); clk_dm(IMX8MP_CLK_ENET_QOS, imx8m_clk_composite("enet_qos", imx8mp_enet_qos_sels, base + 0xa880)); @@ -322,6 +327,7 @@ static int imx8mp_clk_probe(struct udevice *dev) clk_dm(IMX8MP_CLK_I2C2_ROOT, imx_clk_gate4("i2c2_root_clk", "i2c2", base + 0x4180, 0)); clk_dm(IMX8MP_CLK_I2C3_ROOT, imx_clk_gate4("i2c3_root_clk", "i2c3", base + 0x4190, 0)); clk_dm(IMX8MP_CLK_I2C4_ROOT, imx_clk_gate4("i2c4_root_clk", "i2c4", base + 0x41a0, 0)); + clk_dm(IMX8MP_CLK_PCIE_ROOT, imx_clk_gate4("pcie_root_clk", "pcie_aux", base + 0x4250, 0)); clk_dm(IMX8MP_CLK_PWM1_ROOT, imx_clk_gate4("pwm1_root_clk", "pwm1", base + 0x4280, 0)); clk_dm(IMX8MP_CLK_PWM2_ROOT, imx_clk_gate4("pwm2_root_clk", "pwm2", base + 0x4290, 0)); clk_dm(IMX8MP_CLK_PWM3_ROOT, imx_clk_gate4("pwm3_root_clk", "pwm3", base + 0x42a0, 0));
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/reset/reset-imx7.c | 114 +++++++++++++++++++++++++++++++++++++ 1 file changed, 114 insertions(+)
diff --git a/drivers/reset/reset-imx7.c b/drivers/reset/reset-imx7.c index eaef2cc2cdf..c1de84dea8b 100644 --- a/drivers/reset/reset-imx7.c +++ b/drivers/reset/reset-imx7.c @@ -10,6 +10,7 @@ #include <dm.h> #include <dt-bindings/reset/imx7-reset.h> #include <dt-bindings/reset/imx8mq-reset.h> +#include <dt-bindings/reset/imx8mp-reset.h> #include <reset-uclass.h> #include <linux/bitops.h> #include <linux/delay.h> @@ -252,6 +253,115 @@ static int imx7_reset_assert_imx8mq(struct reset_ctl *rst) return 0; }
+enum imx8mp_src_registers { + SRC_SUPERMIX_RCR = 0x0018, + SRC_AUDIOMIX_RCR = 0x001c, + SRC_MLMIX_RCR = 0x0028, + SRC_GPU2D_RCR = 0x0038, + SRC_GPU3D_RCR = 0x003c, + SRC_VPU_G1_RCR = 0x0048, + SRC_VPU_G2_RCR = 0x004c, + SRC_VPUVC8KE_RCR = 0x0050, + SRC_NOC_RCR = 0x0054, +}; + +static const struct imx7_src_signal imx8mp_src_signals[IMX8MP_RESET_NUM] = { + [IMX8MP_RESET_A53_CORE_POR_RESET0] = { SRC_A53RCR0, BIT(0) }, + [IMX8MP_RESET_A53_CORE_POR_RESET1] = { SRC_A53RCR0, BIT(1) }, + [IMX8MP_RESET_A53_CORE_POR_RESET2] = { SRC_A53RCR0, BIT(2) }, + [IMX8MP_RESET_A53_CORE_POR_RESET3] = { SRC_A53RCR0, BIT(3) }, + [IMX8MP_RESET_A53_CORE_RESET0] = { SRC_A53RCR0, BIT(4) }, + [IMX8MP_RESET_A53_CORE_RESET1] = { SRC_A53RCR0, BIT(5) }, + [IMX8MP_RESET_A53_CORE_RESET2] = { SRC_A53RCR0, BIT(6) }, + [IMX8MP_RESET_A53_CORE_RESET3] = { SRC_A53RCR0, BIT(7) }, + [IMX8MP_RESET_A53_DBG_RESET0] = { SRC_A53RCR0, BIT(8) }, + [IMX8MP_RESET_A53_DBG_RESET1] = { SRC_A53RCR0, BIT(9) }, + [IMX8MP_RESET_A53_DBG_RESET2] = { SRC_A53RCR0, BIT(10) }, + [IMX8MP_RESET_A53_DBG_RESET3] = { SRC_A53RCR0, BIT(11) }, + [IMX8MP_RESET_A53_ETM_RESET0] = { SRC_A53RCR0, BIT(12) }, + [IMX8MP_RESET_A53_ETM_RESET1] = { SRC_A53RCR0, BIT(13) }, + [IMX8MP_RESET_A53_ETM_RESET2] = { SRC_A53RCR0, BIT(14) }, + [IMX8MP_RESET_A53_ETM_RESET3] = { SRC_A53RCR0, BIT(15) }, + [IMX8MP_RESET_A53_SOC_DBG_RESET] = { SRC_A53RCR0, BIT(20) }, + [IMX8MP_RESET_A53_L2RESET] = { SRC_A53RCR0, BIT(21) }, + [IMX8MP_RESET_SW_NON_SCLR_M7C_RST] = { SRC_M4RCR, BIT(0) }, + [IMX8MP_RESET_OTG1_PHY_RESET] = { SRC_USBOPHY1_RCR, BIT(0) }, + [IMX8MP_RESET_OTG2_PHY_RESET] = { SRC_USBOPHY2_RCR, BIT(0) }, + [IMX8MP_RESET_SUPERMIX_RESET] = { SRC_SUPERMIX_RCR, BIT(0) }, + [IMX8MP_RESET_AUDIOMIX_RESET] = { SRC_AUDIOMIX_RCR, BIT(0) }, + [IMX8MP_RESET_MLMIX_RESET] = { SRC_MLMIX_RCR, BIT(0) }, + [IMX8MP_RESET_PCIEPHY] = { SRC_PCIEPHY_RCR, BIT(2) }, + [IMX8MP_RESET_PCIEPHY_PERST] = { SRC_PCIEPHY_RCR, BIT(3) }, + [IMX8MP_RESET_PCIE_CTRL_APPS_EN] = { SRC_PCIEPHY_RCR, BIT(6) }, + [IMX8MP_RESET_PCIE_CTRL_APPS_TURNOFF] = { SRC_PCIEPHY_RCR, BIT(11) }, + [IMX8MP_RESET_HDMI_PHY_APB_RESET] = { SRC_HDMI_RCR, BIT(0) }, + [IMX8MP_RESET_MEDIA_RESET] = { SRC_DISP_RCR, BIT(0) }, + [IMX8MP_RESET_GPU2D_RESET] = { SRC_GPU2D_RCR, BIT(0) }, + [IMX8MP_RESET_GPU3D_RESET] = { SRC_GPU3D_RCR, BIT(0) }, + [IMX8MP_RESET_GPU_RESET] = { SRC_GPU_RCR, BIT(0) }, + [IMX8MP_RESET_VPU_RESET] = { SRC_VPU_RCR, BIT(0) }, + [IMX8MP_RESET_VPU_G1_RESET] = { SRC_VPU_G1_RCR, BIT(0) }, + [IMX8MP_RESET_VPU_G2_RESET] = { SRC_VPU_G2_RCR, BIT(0) }, + [IMX8MP_RESET_VPUVC8KE_RESET] = { SRC_VPUVC8KE_RCR, BIT(0) }, + [IMX8MP_RESET_NOC_RESET] = { SRC_NOC_RCR, BIT(0) }, +}; + +static int imx7_reset_assert_imx8mp(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + const struct imx7_src_signal *sig = imx8mp_src_signals; + u32 val; + + if (rst->id >= IMX8MP_RESET_NUM) + return -EINVAL; + + val = readl(priv->base + sig[rst->id].offset); + switch (rst->id) { + case IMX8MP_RESET_PCIE_CTRL_APPS_EN: + case IMX8MP_RESET_PCIEPHY_PERST: + val &= ~sig[rst->id].bit; + break; + default: + val |= sig[rst->id].bit; + break; + } + writel(val, priv->base + sig[rst->id].offset); + + return 0; +} + +static int imx7_reset_deassert_imx8mp(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + const struct imx7_src_signal *sig = imx8mp_src_signals; + u32 val; + + if (rst->id >= IMX8MP_RESET_NUM) + return -EINVAL; + + if (rst->id == IMX8MP_RESET_PCIEPHY) { + /* + * wait for more than 10us to release phy g_rst and + * btnrst + */ + udelay(10); + } + + val = readl(priv->base + sig[rst->id].offset); + switch (rst->id) { + case IMX8MP_RESET_PCIE_CTRL_APPS_EN: + case IMX8MP_RESET_PCIEPHY_PERST: + val |= sig[rst->id].bit; + break; + default: + val &= ~sig[rst->id].bit; + break; + } + writel(val, priv->base + sig[rst->id].offset); + + return 0; +} + static int imx7_reset_assert(struct reset_ctl *rst) { struct imx7_reset_priv *priv = dev_get_priv(rst->dev); @@ -272,6 +382,7 @@ static const struct reset_ops imx7_reset_reset_ops = { static const struct udevice_id imx7_reset_ids[] = { { .compatible = "fsl,imx7d-src" }, { .compatible = "fsl,imx8mq-src" }, + { .compatible = "fsl,imx8mp-src" }, { } };
@@ -289,6 +400,9 @@ static int imx7_reset_probe(struct udevice *dev) } else if (device_is_compatible(dev, "fsl,imx7d-src")) { priv->ops.rst_assert = imx7_reset_assert_imx7; priv->ops.rst_deassert = imx7_reset_deassert_imx7; + } else if (device_is_compatible(dev, "fsl,imx8mp-src")) { + priv->ops.rst_assert = imx7_reset_assert_imx8mp; + priv->ops.rst_deassert = imx7_reset_deassert_imx8mp; }
Please write a proper commit message .
- SRC_SUPERMIX_RCR = 0x0018,
- SRC_AUDIOMIX_RCR = 0x001c,
- SRC_MLMIX_RCR = 0x0028,
- SRC_GPU2D_RCR = 0x0038,
- SRC_GPU3D_RCR = 0x003c,
- SRC_VPU_G1_RCR = 0x0048,
- SRC_VPU_G2_RCR = 0x004c,
- SRC_VPUVC8KE_RCR = 0x0050,
- SRC_NOC_RCR = 0x0054,
This seems copied from Linux, include Linux commit ID as of which this was imported from in commit message.
How about the following?
Add support for i.MX8MP reset controller. It is required to enable PCIe support on the iMX8MP SoC.
Do you expect imx8mp_src_registers to change? I expect them to be the same, so does Linux commit ID add any value here?
-Sumit
The part about PCIe is not relevant, it is a reset controller and it is needed to reset various IPs. See e.g. Linux:
e08672c03981 ("reset: imx7: Add support for i.MX8MP SoC")
The import commit ID makes it easier to cherry-pick follow up patches or check for changes. If that commit ID is missing, that task is harder.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/power/domain/imx8mp-hsiomix.c | 50 +++++++++++++++++++++++++-- 1 file changed, 48 insertions(+), 2 deletions(-)
diff --git a/drivers/power/domain/imx8mp-hsiomix.c b/drivers/power/domain/imx8mp-hsiomix.c index e2d772c5ec7..62145e0261b 100644 --- a/drivers/power/domain/imx8mp-hsiomix.c +++ b/drivers/power/domain/imx8mp-hsiomix.c @@ -16,14 +16,19 @@ #define GPR_REG0 0x0 #define PCIE_CLOCK_MODULE_EN BIT(0) #define USB_CLOCK_MODULE_EN BIT(1) +#define PCIE_PHY_APB_RST BIT(4) +#define PCIE_PHY_INIT_RST BIT(5)
struct imx8mp_hsiomix_priv { void __iomem *base; struct clk clk_usb; + struct clk clk_pcie; struct power_domain pd_bus; struct power_domain pd_usb; + struct power_domain pd_pcie; struct power_domain pd_usb_phy1; struct power_domain pd_usb_phy2; + struct power_domain pd_pcie_phy; };
static int imx8mp_hsiomix_on(struct power_domain *power_domain) @@ -43,6 +48,10 @@ static int imx8mp_hsiomix_on(struct power_domain *power_domain) domain = &priv->pd_usb_phy1; } else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY2) { domain = &priv->pd_usb_phy2; + } else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) { + domain = &priv->pd_pcie; + } else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY) { + domain = &priv->pd_pcie_phy; } else { ret = -EINVAL; goto err_pd; @@ -54,14 +63,25 @@ static int imx8mp_hsiomix_on(struct power_domain *power_domain)
ret = clk_enable(&priv->clk_usb); if (ret) - goto err_clk; + goto err_clk_usb; + + ret = clk_enable(&priv->clk_pcie); + if (ret) + goto err_clk_pcie;
if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) setbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN); + else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) + setbits_le32(priv->base + GPR_REG0, PCIE_CLOCK_MODULE_EN); + else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY) + setbits_le32(priv->base + GPR_REG0, PCIE_PHY_APB_RST | + PCIE_PHY_INIT_RST);
-err_clk: +err_clk_pcie: + clk_disable(&priv->clk_usb); +err_clk_usb: power_domain_off(domain); err_pd: power_domain_off(&priv->pd_bus); @@ -75,8 +95,14 @@ static int imx8mp_hsiomix_off(struct power_domain *power_domain)
if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) clrbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN); + else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) + clrbits_le32(priv->base + GPR_REG0, PCIE_CLOCK_MODULE_EN); + else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY) + clrbits_le32(priv->base + GPR_REG0, PCIE_PHY_APB_RST | + PCIE_PHY_INIT_RST);
clk_disable(&priv->clk_usb); + clk_disable(&priv->clk_pcie);
if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) power_domain_off(&priv->pd_usb); @@ -84,6 +110,10 @@ static int imx8mp_hsiomix_off(struct power_domain *power_domain) power_domain_off(&priv->pd_usb_phy1); else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY2) power_domain_off(&priv->pd_usb_phy2); + else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) + power_domain_off(&priv->pd_usb_phy2); + else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY) + power_domain_off(&priv->pd_usb_phy2);
@@ -109,6 +139,10 @@ static int imx8mp_hsiomix_probe(struct udevice *dev) if (ret < 0) return ret;
+ ret = clk_get_by_name(dev, "pcie", &priv->clk_pcie); + if (ret < 0) + return ret; + ret = power_domain_get_by_name(dev, &priv->pd_bus, "bus"); if (ret < 0) return ret; @@ -125,8 +159,20 @@ static int imx8mp_hsiomix_probe(struct udevice *dev) if (ret < 0) goto err_pd_usb_phy2;
+ ret = power_domain_get_by_name(dev, &priv->pd_pcie, "pcie"); + if (ret < 0) + goto err_pd_pcie; + + ret = power_domain_get_by_name(dev, &priv->pd_pcie_phy, "pcie-phy"); + if (ret < 0) + goto err_pd_pcie_phy; + return 0;
+err_pd_pcie_phy: + power_domain_free(&priv->pd_pcie); +err_pd_pcie: + power_domain_free(&priv->pd_usb_phy2); err_pd_usb_phy2: power_domain_free(&priv->pd_usb_phy1); err_pd_usb_phy1:
This commit message is useless, write a proper one.
- } else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) {
- } else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY) {
} else { ret = -EINVAL; goto err_pd;domain = &priv->pd_pcie_phy;
goto err_clk;
goto err_clk_usb;
- ret = clk_enable(&priv->clk_pcie);
- if (ret)
goto err_clk_pcie;
Does this mean that when USB power domains get enabled, PCIe clock are also enabled ? Why ?
What if the PCIe clock enable fails, do USB clock remain enabled ?
- else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE)
- else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY)
PCIE_PHY_INIT_RST);
Shouldn't the reset bits be cleared here ?
Add support for GPCv2 power domains and clock handling for PCIe and PCIe PHY. It is required to enable PCIe support on the iMX8MP SoC.
goto err_clk;
goto err_clk_usb;
if (ret)
goto err_clk_pcie;
Let me gate them behind corresponding power domain IDs.
PCIE_PHY_INIT_RST);
Although I can't find their reference in the TRM, as per Linux commit [1], setting the reset bit is actually deassertion of PCIe PHY reset. You can think of it like an active low signal.
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i...
-Sumit
The second sentence is redundant.
goto err_clk;
goto err_clk_usb;
if (ret)
goto err_clk_pcie;
PCIE_PHY_INIT_RST);
Please add this ^ comment into the code.
PCIe PHY can use it when there is no external refclock provided.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/power/domain/imx8mp-hsiomix.c | 79 +++++++++++++++++++++++++-- 1 file changed, 73 insertions(+), 6 deletions(-)
diff --git a/drivers/power/domain/imx8mp-hsiomix.c b/drivers/power/domain/imx8mp-hsiomix.c index 62145e0261b..4cefe642724 100644 --- a/drivers/power/domain/imx8mp-hsiomix.c +++ b/drivers/power/domain/imx8mp-hsiomix.c @@ -9,6 +9,8 @@ #include <dm.h> #include <dm/device.h> #include <dm/device_compat.h> +#include <linux/bitfield.h> +#include <linux/delay.h> #include <power-domain-uclass.h>
#include <dt-bindings/power/imx8mp-power.h> @@ -18,6 +20,15 @@ #define USB_CLOCK_MODULE_EN BIT(1) #define PCIE_PHY_APB_RST BIT(4) #define PCIE_PHY_INIT_RST BIT(5) +#define GPR_REG1 0x4 +#define PLL_LOCK BIT(13) +#define GPR_REG2 0x8 +#define P_PLL_MASK GENMASK(5, 0) +#define M_PLL_MASK GENMASK(15, 6) +#define S_PLL_MASK GENMASK(18, 16) +#define GPR_REG3 0xc +#define PLL_CKE BIT(17) +#define PLL_RST BIT(31)
struct imx8mp_hsiomix_priv { void __iomem *base; @@ -31,6 +42,53 @@ struct imx8mp_hsiomix_priv { struct power_domain pd_pcie_phy; };
+static int hsio_pll_enable(struct udevice *dev) +{ + struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev); + unsigned long start; + u32 val; + + /* Setup HSIO PLL */ + val = readl(priv->base + GPR_REG2); + val &= ~(P_PLL_MASK | M_PLL_MASK | S_PLL_MASK); + val |= (FIELD_PREP(P_PLL_MASK, 12) | FIELD_PREP(M_PLL_MASK, 800) | + FIELD_PREP(S_PLL_MASK, 4)); + writel(val, priv->base + GPR_REG2); + + /* de-assert PLL reset */ + setbits_le32(priv->base + GPR_REG3, PLL_RST); + + /* enable PLL */ + setbits_le32(priv->base + GPR_REG3, PLL_CKE); + + /* Check if PLL is locked */ + start = get_timer(0); + for (;;) { + if (readl(priv->base + GPR_REG1) & PLL_LOCK) + break; + + if (get_timer(start) > 100) { + dev_err(dev, "failed to lock HSIO PLL\n"); + return -ETIMEDOUT; + } + + udelay(10); + } + + return 0; +} + +static void hsio_pll_disable(struct udevice *dev) +{ + struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev); + + /* de-assert PLL reset */ + clrbits_le32(priv->base + GPR_REG3, PLL_RST); + + /* enable PLL */ + clrbits_le32(priv->base + GPR_REG3, PLL_CKE); +} + static int imx8mp_hsiomix_on(struct power_domain *power_domain) { struct udevice *dev = power_domain->dev; @@ -69,16 +127,23 @@ static int imx8mp_hsiomix_on(struct power_domain *power_domain) if (ret) goto err_clk_pcie;
- if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) + if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) { setbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN); - else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) + } else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) { setbits_le32(priv->base + GPR_REG0, PCIE_CLOCK_MODULE_EN); - else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY) + } else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY) { setbits_le32(priv->base + GPR_REG0, PCIE_PHY_APB_RST | PCIE_PHY_INIT_RST);
+ ret = hsio_pll_enable(dev); + if (ret) + goto err_hsio_pll; + } + return 0;
+err_hsio_pll: + clk_disable(&priv->clk_pcie); err_clk_pcie: clk_disable(&priv->clk_usb); err_clk_usb: @@ -93,13 +158,15 @@ static int imx8mp_hsiomix_off(struct power_domain *power_domain) struct udevice *dev = power_domain->dev; struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev);
- if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) + if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) { clrbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN); - else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) + } else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) { clrbits_le32(priv->base + GPR_REG0, PCIE_CLOCK_MODULE_EN); - else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY) + } else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE_PHY) { clrbits_le32(priv->base + GPR_REG0, PCIE_PHY_APB_RST | PCIE_PHY_INIT_RST); + hsio_pll_disable(dev); + }
clk_disable(&priv->clk_usb); clk_disable(&priv->clk_pcie);
Commit message needs to be fixed.
- struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev);
- unsigned long start;
- u32 val;
- /* Setup HSIO PLL */
- val = readl(priv->base + GPR_REG2);
- val &= ~(P_PLL_MASK | M_PLL_MASK | S_PLL_MASK);
- val |= (FIELD_PREP(P_PLL_MASK, 12) | FIELD_PREP(M_PLL_MASK, 800) |
- writel(val, priv->base + GPR_REG2);
clrsetbits_le32()
- /* de-assert PLL reset */
- setbits_le32(priv->base + GPR_REG3, PLL_RST);
- /* enable PLL */
- setbits_le32(priv->base + GPR_REG3, PLL_CKE);
- /* Check if PLL is locked */
- start = get_timer(0);
wait_for_bit() or readl_poll_timeout()
- for (;;) {
break;
return -ETIMEDOUT;
udelay(10);
- clrbits_le32(priv->base + GPR_REG3, PLL_RST);
- /* enable PLL */
- clrbits_le32(priv->base + GPR_REG3, PLL_CKE);
- static int imx8mp_hsiomix_on(struct power_domain *power_domain) { struct udevice *dev = power_domain->dev;
- if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) { setbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN);
- } else if (power_domain->id == IMX8MP_HSIOBLK_PD_PCIE) { setbits_le32(priv->base + GPR_REG0, PCIE_CLOCK_MODULE_EN);
Is this how Linux handles this PLL ?
Seems like this should be either syscon or clock driver .
Expose high performance PLL clock, so the PCIe PHY can use it when there is no external refclock provided.
u32 val;
clrsetbits_le32()
Ack
/* enable PLL */
Let me use readl_poll_timeout() instead.
for (;;) {
break;
return -ETIMEDOUT;
udelay(10);
/* enable PLL */
It isn't similar to what Linux does but I can't find suitable infrastructure in U-Boot to expose it as a regular clock. Are there any APIs available similar to devm_of_clk_add_hw_provider() in Linux?
-Sumit
If this code is imported from Linux 2cbee26e5d59 ("soc: imx: imx8mp-blk-ctrl: expose high performance PLL clock") then just include that reference too .
Have a look at the very end of:
drivers/clk/renesas/clk-rcar-gen3.c
that registers clock and reset drivers for the same IP at the same address. In this case, you would register power domain and clock drivers instead .
Add initial support for i.MX8M{M/P} PCIe PHY. On i.MX8M{M/P} SoCs PCIe PHY initialization moved to this standalone PHY driver.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/phy/Kconfig | 9 ++ drivers/phy/Makefile | 1 + drivers/phy/phy-imx8m-pcie.c | 246 +++++++++++++++++++++++++++++++++++ 3 files changed, 256 insertions(+) create mode 100644 drivers/phy/phy-imx8m-pcie.c
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index 60138beca49..110ec8f5008 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -284,6 +284,15 @@ config PHY_IMX8MQ_USB help Support the USB3.0 PHY in NXP i.MX8MQ or i.MX8MP SoC
+config PHY_IMX8M_PCIE + bool "NXP i.MX8MM/i.MX8MP PCIe PHY Driver" + depends on PHY + depends on IMX8MM || IMX8MP + help + Support the PCIe PHY in NXP i.MX8MM or i.MX8MP SoC + + This PHY is found on i.MX8M devices supporting PCIe. + config PHY_XILINX_ZYNQMP tristate "Xilinx ZynqMP PHY driver" depends on PHY && ARCH_ZYNQMP diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index 2e8723186c0..7a2b764492b 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -38,6 +38,7 @@ obj-$(CONFIG_PHY_DA8XX_USB) += phy-da8xx-usb.o obj-$(CONFIG_PHY_MTK_TPHY) += phy-mtk-tphy.o obj-$(CONFIG_PHY_NPCM_USB) += phy-npcm-usb.o obj-$(CONFIG_PHY_IMX8MQ_USB) += phy-imx8mq-usb.o +obj-$(CONFIG_PHY_IMX8M_PCIE) += phy-imx8m-pcie.o obj-$(CONFIG_PHY_XILINX_ZYNQMP) += phy-zynqmp.o obj-y += cadence/ obj-y += ti/ diff --git a/drivers/phy/phy-imx8m-pcie.c b/drivers/phy/phy-imx8m-pcie.c new file mode 100644 index 00000000000..d1ad42ff339 --- /dev/null +++ b/drivers/phy/phy-imx8m-pcie.c @@ -0,0 +1,246 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2024 Linaro Ltd. + * + * Derived from Linux counterpart driver + */ + +#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <generic-phy.h> +#include <linux/bitfield.h> +#include <linux/clk-provider.h> +#include <linux/iopoll.h> +#include <syscon.h> +#include <regmap.h> +#include <reset.h> + +#include <dt-bindings/phy/phy-imx8-pcie.h> + +#define IMX8MM_PCIE_PHY_CMN_REG061 0x184 +#define ANA_PLL_CLK_OUT_TO_EXT_IO_EN BIT(0) +#define IMX8MM_PCIE_PHY_CMN_REG062 0x188 +#define ANA_PLL_CLK_OUT_TO_EXT_IO_SEL BIT(3) +#define IMX8MM_PCIE_PHY_CMN_REG063 0x18C +#define AUX_PLL_REFCLK_SEL_SYS_PLL GENMASK(7, 6) +#define IMX8MM_PCIE_PHY_CMN_REG064 0x190 +#define ANA_AUX_RX_TX_SEL_TX BIT(7) +#define ANA_AUX_RX_TERM_GND_EN BIT(3) +#define ANA_AUX_TX_TERM BIT(2) +#define IMX8MM_PCIE_PHY_CMN_REG065 0x194 +#define ANA_AUX_RX_TERM (BIT(7) | BIT(4)) +#define ANA_AUX_TX_LVL GENMASK(3, 0) +#define IMX8MM_PCIE_PHY_CMN_REG075 0x1D4 +#define ANA_PLL_DONE 0x3 +#define PCIE_PHY_TRSV_REG5 0x414 +#define PCIE_PHY_TRSV_REG6 0x418 + +#define IMX8MM_GPR_PCIE_REF_CLK_SEL GENMASK(25, 24) +#define IMX8MM_GPR_PCIE_REF_CLK_PLL FIELD_PREP(IMX8MM_GPR_PCIE_REF_CLK_SEL, 0x3) +#define IMX8MM_GPR_PCIE_REF_CLK_EXT FIELD_PREP(IMX8MM_GPR_PCIE_REF_CLK_SEL, 0x2) +#define IMX8MM_GPR_PCIE_AUX_EN BIT(19) +#define IMX8MM_GPR_PCIE_CMN_RST BIT(18) +#define IMX8MM_GPR_PCIE_POWER_OFF BIT(17) +#define IMX8MM_GPR_PCIE_SSC_EN BIT(16) +#define IMX8MM_GPR_PCIE_AUX_EN_OVERRIDE BIT(9) + +#define IOMUXC_GPR14_OFFSET 0x38 + +enum imx8_pcie_phy_type { + IMX8MM, + IMX8MP, +}; + +struct imx8_pcie_phy_drvdata { + const char *gpr; + enum imx8_pcie_phy_type variant; +}; + +struct imx8_pcie_phy { + ulong base; + struct regmap *iomuxc_gpr; + struct reset_ctl perst; + struct reset_ctl reset; + u32 refclk_pad_mode; + u32 tx_deemph_gen1; + u32 tx_deemph_gen2; + bool clkreq_unused; + const struct imx8_pcie_phy_drvdata *drvdata; +}; + +static int imx8_pcie_phy_power_on(struct phy *phy) +{ + int ret; + u32 val, pad_mode; + struct imx8_pcie_phy *imx8_phy = dev_get_priv(phy->dev); + + pad_mode = imx8_phy->refclk_pad_mode; + switch (imx8_phy->drvdata->variant) { + case IMX8MM: + reset_assert(&imx8_phy->reset); + + /* Tune PHY de-emphasis setting to pass PCIe compliance. */ + if (imx8_phy->tx_deemph_gen1) + writel(imx8_phy->tx_deemph_gen1, + imx8_phy->base + PCIE_PHY_TRSV_REG5); + if (imx8_phy->tx_deemph_gen2) + writel(imx8_phy->tx_deemph_gen2, + imx8_phy->base + PCIE_PHY_TRSV_REG6); + break; + case IMX8MP: /* Do nothing. */ + break; + } + + if (pad_mode == IMX8_PCIE_REFCLK_PAD_INPUT || + pad_mode == IMX8_PCIE_REFCLK_PAD_UNUSED) { + /* Configure the pad as input */ + val = readl(imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG061); + writel(val & ~ANA_PLL_CLK_OUT_TO_EXT_IO_EN, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG061); + } else { + /* Configure the PHY to output the refclock via pad */ + writel(ANA_PLL_CLK_OUT_TO_EXT_IO_EN, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG061); + } + + if (pad_mode == IMX8_PCIE_REFCLK_PAD_OUTPUT || + pad_mode == IMX8_PCIE_REFCLK_PAD_UNUSED) { + /* Source clock from SoC internal PLL */ + writel(ANA_PLL_CLK_OUT_TO_EXT_IO_SEL, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG062); + writel(AUX_PLL_REFCLK_SEL_SYS_PLL, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG063); + val = ANA_AUX_RX_TX_SEL_TX | ANA_AUX_TX_TERM; + writel(val | ANA_AUX_RX_TERM_GND_EN, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG064); + writel(ANA_AUX_RX_TERM | ANA_AUX_TX_LVL, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG065); + } + + /* Set AUX_EN_OVERRIDE 1'b0, when the CLKREQ# isn't hooked */ + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_AUX_EN_OVERRIDE, + imx8_phy->clkreq_unused ? + 0 : IMX8MM_GPR_PCIE_AUX_EN_OVERRIDE); + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_AUX_EN, + IMX8MM_GPR_PCIE_AUX_EN); + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_POWER_OFF, 0); + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_SSC_EN, 0); + + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_REF_CLK_SEL, + pad_mode == IMX8_PCIE_REFCLK_PAD_INPUT ? + IMX8MM_GPR_PCIE_REF_CLK_EXT : + IMX8MM_GPR_PCIE_REF_CLK_PLL); + udelay(200); + + /* Do the PHY common block reset */ + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_CMN_RST, + IMX8MM_GPR_PCIE_CMN_RST); + + switch (imx8_phy->drvdata->variant) { + case IMX8MP: + reset_deassert(&imx8_phy->perst); + fallthrough; + case IMX8MM: + reset_deassert(&imx8_phy->reset); + udelay(500); + break; + } + + /* Polling to check the phy is ready or not. */ + ret = readl_poll_timeout(imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG075, + val, val == ANA_PLL_DONE, 20000); + return ret; +} + +static const struct phy_ops imx8_pcie_phy_ops = { + .power_on = imx8_pcie_phy_power_on, +}; + +static const struct imx8_pcie_phy_drvdata imx8mm_drvdata = { + .gpr = "fsl,imx8mm-iomuxc-gpr", + .variant = IMX8MM, +}; + +static const struct imx8_pcie_phy_drvdata imx8mp_drvdata = { + .gpr = "fsl,imx8mp-iomuxc-gpr", + .variant = IMX8MP, +}; + +static const struct udevice_id imx8_pcie_phy_of_match[] = { + {.compatible = "fsl,imx8mm-pcie-phy", .data = (ulong)&imx8mm_drvdata, }, + {.compatible = "fsl,imx8mp-pcie-phy", .data = (ulong)&imx8mp_drvdata, }, + { }, +}; + +static int imx8_pcie_phy_probe(struct udevice *dev) +{ + struct imx8_pcie_phy *imx8_phy = dev_get_priv(dev); + ofnode gpr; + int ret = 0; + + imx8_phy->drvdata = (void *)dev_get_driver_data(dev); + imx8_phy->base = dev_read_addr(dev); + if (!imx8_phy->base) + return -EINVAL; + + /* get PHY refclk pad mode */ + dev_read_u32(dev, "fsl,refclk-pad-mode", &imx8_phy->refclk_pad_mode); + + if (dev_read_u32(dev, "fsl,tx-deemph-gen1", &imx8_phy->tx_deemph_gen1)) + imx8_phy->tx_deemph_gen1 = 0; + + if (dev_read_u32(dev, "fsl,tx-deemph-gen2", &imx8_phy->tx_deemph_gen2)) + imx8_phy->tx_deemph_gen2 = 0; + + if (dev_read_bool(dev, "fsl,clkreq-unsupported")) + imx8_phy->clkreq_unused = true; + else + imx8_phy->clkreq_unused = false; + + /* Grab GPR config register range */ + gpr = ofnode_by_compatible(ofnode_null(), imx8_phy->drvdata->gpr); + if (ofnode_equal(gpr, ofnode_null())) { + dev_err(dev, "unable to find GPR node\n"); + return -ENODEV; + } + + imx8_phy->iomuxc_gpr = syscon_node_to_regmap(gpr); + if (IS_ERR(imx8_phy->iomuxc_gpr)) { + dev_err(dev, "unable to find iomuxc registers\n"); + return PTR_ERR(imx8_phy->iomuxc_gpr); + } + + ret = reset_get_by_name(dev, "pciephy", &imx8_phy->reset); + if (ret) { + dev_err(dev, "Failed to get PCIEPHY reset control\n"); + return ret; + } + + if (imx8_phy->drvdata->variant == IMX8MP) { + ret = reset_get_by_name(dev, "perst", &imx8_phy->perst); + if (ret) { + dev_err(dev, + "Failed to get PCIEPHY PHY PERST control\n"); + return ret; + } + } + + return 0; +} + +U_BOOT_DRIVER(nxp_imx8_pcie_phy) = { + .name = "nxp_imx8_pcie_phy", + .id = UCLASS_PHY, + .of_match = imx8_pcie_phy_of_match, + .probe = imx8_pcie_phy_probe, + .ops = &imx8_pcie_phy_ops, + .priv_auto = sizeof(struct imx8_pcie_phy), +};
Is this based on Linux ? If so, include Linux commit ID from which the code was imported.
Yeah it is derived from the corresponding Linux driver (see header for phy-imx8m-pcie.c file). I can add the corresponding Linux version (v6.8-rc3) in the commit message.
-Sumit
Please do, this is useful for further synchronizations with Linux. I can imagine MX9x support will be one such synchronization.
pcie_imx doesn't seem to share any useful code for iMX8 SoC and it is tied to quite old port of pcie_designware driver from Linux which suffices only iMX6 specific needs.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/pci/Kconfig | 8 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_imx8.c | 348 +++++++++++++++++++++++++++++++++++++ 3 files changed, 357 insertions(+) create mode 100644 drivers/pci/pcie_dw_imx8.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 463ec47eb92..b7c7922b091 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -413,4 +413,12 @@ config PCIE_STARFIVE_JH7110 Say Y here if you want to enable PLDA XpressRich PCIe controller support on StarFive JH7110 SoC.
+config PCIE_DW_IMX8 + bool "i.MX8 PCIe support" + depends on ARCH_IMX8M + select PCIE_DW_COMMON + help + Say Y here if you want to enable DW PCIe controller support on + iMX8 SoCs. + endif diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 72ef8b4bc77..cddbb902095 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -53,3 +53,4 @@ obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o obj-$(CONFIG_PCIE_XILINX_NWL) += pcie-xilinx-nwl.o obj-$(CONFIG_PCIE_PLDA_COMMON) += pcie_plda_common.o obj-$(CONFIG_PCIE_STARFIVE_JH7110) += pcie_starfive_jh7110.o +obj-$(CONFIG_PCIE_DW_IMX8) += pcie_dw_imx8.o diff --git a/drivers/pci/pcie_dw_imx8.c b/drivers/pci/pcie_dw_imx8.c new file mode 100644 index 00000000000..b9921644765 --- /dev/null +++ b/drivers/pci/pcie_dw_imx8.c @@ -0,0 +1,348 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2024 Linaro Ltd. + * + * Author: Sumit Garg sumit.garg@linaro.org + */ + +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <generic-phy.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <log.h> +#include <pci.h> +#include <regmap.h> +#include <reset.h> +#include <syscon.h> +#include <time.h> + +#include "pcie_dw_common.h" + +#define PCIE_LINK_CAPABILITY 0x7c +#define TARGET_LINK_SPEED_MASK 0xf +#define LINK_SPEED_GEN_1 0x1 +#define LINK_SPEED_GEN_2 0x2 +#define LINK_SPEED_GEN_3 0x3 + +#define PCIE_MISC_CONTROL_1_OFF 0x8bc +#define PCIE_DBI_RO_WR_EN BIT(0) + +#define PCIE_PORT_DEBUG0 0x728 +#define PCIE_PORT_DEBUG1 0x72c +#define PCIE_PORT_DEBUG1_LINK_UP BIT(4) +#define PCIE_PORT_DEBUG1_LINK_IN_TRAINING BIT(29) + +#define PCIE_LINK_UP_TIMEOUT_MS 100 + +#define IOMUXC_GPR14_OFFSET 0x38 +#define IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE_EN BIT(10) +#define IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE BIT(11) + +struct pcie_dw_imx8 { + /* Must be first member of the struct */ + struct pcie_dw dw; + struct regmap *iomuxc_gpr; + struct clk pcie; + struct clk pcie_bus; + struct clk pcie_aux; + struct gpio_desc reset_gpio; + struct reset_ctl apps_reset; + struct phy phy; +}; + +static void pcie_dw_configure(struct pcie_dw_imx8 *priv, u32 cap_speed) +{ + u32 val; + + dw_pcie_dbi_write_enable(&priv->dw, true); + + val = readl(priv->dw.dbi_base + PCIE_LINK_CAPABILITY); + val &= ~TARGET_LINK_SPEED_MASK; + val |= cap_speed; + writel(val, priv->dw.dbi_base + PCIE_LINK_CAPABILITY); + + dw_pcie_dbi_write_enable(&priv->dw, false); +} + +static void imx8_pcie_ltssm_enable(struct pcie_dw_imx8 *priv) +{ + reset_deassert(&priv->apps_reset); +} + +static void imx8_pcie_ltssm_disable(struct pcie_dw_imx8 *priv) +{ + reset_assert(&priv->apps_reset); +} + +static int is_link_up(struct pcie_dw_imx8 *priv) +{ + u32 val; + + val = readl(priv->dw.dbi_base + PCIE_PORT_DEBUG1); + + return ((val & PCIE_PORT_DEBUG1_LINK_UP) && + (!(val & PCIE_PORT_DEBUG1_LINK_IN_TRAINING))); +} + +static int wait_link_up(struct pcie_dw_imx8 *priv) +{ + unsigned long timeout; + + timeout = get_timer(0) + PCIE_LINK_UP_TIMEOUT_MS; + while (!is_link_up(priv)) { + if (get_timer(0) > timeout) + return 0; + mdelay(10); + }; + + return 1; +} + +static int pcie_link_up(struct pcie_dw_imx8 *priv, u32 cap_speed) +{ + if (is_link_up(priv)) { + printf("PCI Link already up before configuration!\n"); + return 1; + } + + /* DW pre link configurations */ + pcie_dw_configure(priv, cap_speed); + + /* Initiate link training */ + imx8_pcie_ltssm_enable(priv); + + /* Check that link was established */ + if (!wait_link_up(priv)) { + imx8_pcie_ltssm_disable(priv); + return 0; + } + + return 1; +} + +static int imx8_pcie_assert_core_reset(struct pcie_dw_imx8 *priv) +{ + if (dm_gpio_is_valid(&priv->reset_gpio)) { + dm_gpio_set_value(&priv->reset_gpio, 1); + mdelay(20); + } + + return reset_assert(&priv->apps_reset); +} + +static int imx8_pcie_clk_enable(struct pcie_dw_imx8 *priv) +{ + int ret; + + ret = clk_enable(&priv->pcie); + if (ret) { + printf("unable to enable pcie clock\n"); + return ret; + } + + ret = clk_enable(&priv->pcie_bus); + if (ret) { + printf("unable to enable pcie_bus clock\n"); + goto err_pcie; + } + + ret = clk_enable(&priv->pcie_aux); + if (ret) { + printf("unable to enable pcie_aux clock\n"); + goto err_pcie_bus; + } + + /* + * Set the over ride low and enabled make sure that + * REF_CLK is turned on. + */ + regmap_update_bits(priv->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE, 0); + regmap_update_bits(priv->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE_EN, + IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE_EN); + + /* allow the clocks to stabilize */ + udelay(500); + + return 0; + +err_pcie_bus: + clk_disable(&priv->pcie_bus); +err_pcie: + clk_disable(&priv->pcie); + + return ret; +} + +static int imx8_pcie_deassert_core_reset(struct pcie_dw_imx8 *priv) +{ + if (dm_gpio_is_valid(&priv->reset_gpio)) { + mdelay(100); + dm_gpio_set_value(&priv->reset_gpio, 0); + /* Wait for 100ms after PERST# deassertion (PCIe r5.0, 6.6.1) */ + mdelay(100); + } + + return 0; +} + +static int pcie_dw_imx8_probe(struct udevice *dev) +{ + struct pcie_dw_imx8 *priv = dev_get_priv(dev); + struct udevice *ctlr = pci_get_controller(dev); + struct pci_controller *hose = dev_get_uclass_priv(ctlr); + int ret; + + ret = imx8_pcie_assert_core_reset(priv); + if (ret) { + dev_err(dev, "failed to assert core reset\n"); + return ret; + } + + ret = imx8_pcie_clk_enable(priv); + if (ret) { + dev_err(dev, "failed to enable clocks\n"); + return ret; + } + + generic_phy_init(&priv->phy); + generic_phy_power_on(&priv->phy); + + ret = imx8_pcie_deassert_core_reset(priv); + if (ret) { + dev_err(dev, "failed to assert core reset\n"); + return ret; + } + + priv->dw.first_busno = dev_seq(dev); + priv->dw.dev = dev; + + pcie_dw_setup_host(&priv->dw); + + if (!pcie_link_up(priv, LINK_SPEED_GEN_1)) { + printf("PCIE-%d: Link down\n", dev_seq(dev)); + return -ENODEV; + } + + printf("PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n", dev_seq(dev), + pcie_dw_get_link_speed(&priv->dw), + pcie_dw_get_link_width(&priv->dw), + hose->first_busno); + + pcie_dw_prog_outbound_atu_unroll(&priv->dw, PCIE_ATU_REGION_INDEX0, + PCIE_ATU_TYPE_MEM, + priv->dw.mem.phys_start, + priv->dw.mem.bus_start, priv->dw.mem.size); + + return 0; +} + +static int pcie_dw_imx8_remove(struct udevice *dev) +{ + struct pcie_dw_imx8 *priv = dev_get_priv(dev); + + imx8_pcie_assert_core_reset(priv); + + return 0; +} + +static int pcie_dw_imx8_of_to_plat(struct udevice *dev) +{ + struct pcie_dw_imx8 *priv = dev_get_priv(dev); + ofnode gpr; + int ret; + + /* Get the controller base address */ + priv->dw.dbi_base = (void *)dev_read_addr_name(dev, "dbi"); + if ((fdt_addr_t)priv->dw.dbi_base == FDT_ADDR_T_NONE) { + dev_err(dev, "failed to get dbi_base address\n"); + return -EINVAL; + } + + /* Get the config space base address and size */ + priv->dw.cfg_base = (void *)dev_read_addr_size_name(dev, "config", + &priv->dw.cfg_size); + if ((fdt_addr_t)priv->dw.cfg_base == FDT_ADDR_T_NONE) { + dev_err(dev, "failed to get cfg_base address\n"); + return -EINVAL; + } + + ret = clk_get_by_name(dev, "pcie_bus", &priv->pcie_bus); + if (ret) { + dev_err(dev, "failed to get pcie_bus clk\n"); + return ret; + } + + ret = clk_get_by_name(dev, "pcie", &priv->pcie); + if (ret) { + dev_err(dev, "failed to get pcie clk\n"); + return ret; + } + + ret = clk_get_by_name(dev, "pcie", &priv->pcie_aux); + if (ret) { + dev_err(dev, "failed to get pcie clk\n"); + return ret; + } + + ret = reset_get_by_name(dev, "apps", &priv->apps_reset); + if (ret) { + dev_err(dev, + "Failed to get PCIe apps reset control\n"); + return ret; + } + + ret = gpio_request_by_name(dev, "reset-gpio", 0, &priv->reset_gpio, + (GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE)); + if (ret) { + dev_err(dev, "unable to get reset-gpio\n"); + return ret; + } + + ret = generic_phy_get_by_name(dev, "pcie-phy", &priv->phy); + if (ret) { + dev_err(dev, "failed to get pcie phy\n"); + return ret; + } + + gpr = ofnode_by_compatible(ofnode_null(), "fsl,imx8mp-iomuxc-gpr"); + if (ofnode_equal(gpr, ofnode_null())) { + dev_err(dev, "unable to find GPR node\n"); + return -ENODEV; + } + + priv->iomuxc_gpr = syscon_node_to_regmap(gpr); + if (IS_ERR(priv->iomuxc_gpr)) { + dev_err(dev, "unable to find iomuxc registers\n"); + return PTR_ERR(priv->iomuxc_gpr); + } + + return 0; +} + +static const struct dm_pci_ops pcie_dw_imx8_ops = { + .read_config = pcie_dw_read_config, + .write_config = pcie_dw_write_config, +}; + +static const struct udevice_id pcie_dw_imx8_ids[] = { + { .compatible = "fsl,imx8mp-pcie" }, + { } +}; + +U_BOOT_DRIVER(pcie_dw_imx8) = { + .name = "pcie_dw_imx8", + .id = UCLASS_PCI, + .of_match = pcie_dw_imx8_ids, + .ops = &pcie_dw_imx8_ops, + .of_to_plat = pcie_dw_imx8_of_to_plat, + .probe = pcie_dw_imx8_probe, + .remove = pcie_dw_imx8_remove, + .priv_auto = sizeof(struct pcie_dw_imx8), +};
- bool "i.MX8 PCIe support"
- depends on ARCH_IMX8M
- select PCIE_DW_COMMON
- help
iMX8 SoCs.
- endif
- Copyright (C) 2024 Linaro Ltd.
- Author: Sumit Garg sumit.garg@linaro.org
- /* Must be first member of the struct */
- struct pcie_dw dw;
- struct regmap *iomuxc_gpr;
- struct clk pcie;
- struct clk pcie_bus;
- struct clk pcie_aux;
- struct gpio_desc reset_gpio;
- struct reset_ctl apps_reset;
- struct phy phy;
- u32 val;
- dw_pcie_dbi_write_enable(&priv->dw, true);
- val = readl(priv->dw.dbi_base + PCIE_LINK_CAPABILITY);
- val &= ~TARGET_LINK_SPEED_MASK;
- val |= cap_speed;
- writel(val, priv->dw.dbi_base + PCIE_LINK_CAPABILITY);
clrsetbits_le32()
- dw_pcie_dbi_write_enable(&priv->dw, false);
- reset_deassert(&priv->apps_reset);
- reset_assert(&priv->apps_reset);
- u32 val;
- val = readl(priv->dw.dbi_base + PCIE_PORT_DEBUG1);
- return ((val & PCIE_PORT_DEBUG1_LINK_UP) &&
- unsigned long timeout;
- timeout = get_timer(0) + PCIE_LINK_UP_TIMEOUT_MS;
wait_for_bit() or read_poll_timeout()
- while (!is_link_up(priv)) {
mdelay(10);
- return 1;
return -ETIMEDOUT ?
- if (is_link_up(priv)) {
return 1;
- /* DW pre link configurations */
- pcie_dw_configure(priv, cap_speed);
- /* Initiate link training */
- imx8_pcie_ltssm_enable(priv);
- /* Check that link was established */
- if (!wait_link_up(priv)) {
- return 1;
- if (dm_gpio_is_valid(&priv->reset_gpio)) {
mdelay(20);
- return reset_assert(&priv->apps_reset);
- int ret;
- ret = clk_enable(&priv->pcie);
Can you use clk_bulk functions here ?
Invert the match here and return early to reduce indent.
mdelay(100);
mdelay(100);
- struct pcie_dw_imx8 *priv = dev_get_priv(dev);
- struct udevice *ctlr = pci_get_controller(dev);
- struct pci_controller *hose = dev_get_uclass_priv(ctlr);
- int ret;
- ret = imx8_pcie_assert_core_reset(priv);
- if (ret) {
return ret;
- ret = imx8_pcie_clk_enable(priv);
- if (ret) {
This needs a fail path, else reset remains released on failure here .
return ret;
- generic_phy_init(&priv->phy);
- generic_phy_power_on(&priv->phy);
- ret = imx8_pcie_deassert_core_reset(priv);
- if (ret) {
return ret;
- priv->dw.first_busno = dev_seq(dev);
- priv->dw.dev = dev;
- pcie_dw_setup_host(&priv->dw);
- if (!pcie_link_up(priv, LINK_SPEED_GEN_1)) {
return -ENODEV;
- printf("PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n", dev_seq(dev),
hose->first_busno);
- pcie_dw_prog_outbound_atu_unroll(&priv->dw, PCIE_ATU_REGION_INDEX0,
PCIE_ATU_TYPE_MEM,
- imx8_pcie_assert_core_reset(priv);
help
iMX8 SoCs.
- endif
struct pcie_dw dw;
struct clk pcie;
struct phy phy;
u32 val;
val |= cap_speed;
clrsetbits_le32()
Ack.
u32 val;
They won't appropriately fit here as I would like to add delay in between consecutive polls too...
mdelay(10);
...here.
return 1;
return -ETIMEDOUT ?
Here 0 represents timeout and 1 represents success condition.
return 1;
return 1;
mdelay(20);
int ret;
Sure, I can try to use them.
Ack.
mdelay(100);
mdelay(100);
int ret;
if (ret) {
return ret;
if (ret) {
Ack, I will add that.
-Sumit
return ret;
if (ret) {
return ret;
priv->dw.dev = dev;
return -ENODEV;
hose->first_busno);
PCIE_ATU_TYPE_MEM,
mdelay(10);
...here.
include/linux/iopoll.h:#define read_poll_timeout(op, val, cond, sleep_us, timeout_us, args...) \
That's the "sleep_us" , is it not ?
return 1;
return -ETIMEDOUT ?
0 generally represents success, non-zero error, please fix.
Also, enable reset driver which is a prerequisite for PCIe support.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- configs/verdin-imx8mp_defconfig | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index 22b8a334dfa..d8bd644322b 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -185,3 +185,12 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_IMX_WATCHDOG=y CONFIG_HEXDUMP=y +CONFIG_DM_RESET=y +CONFIG_RESET_IMX=y +CONFIG_PCI=y +CONFIG_PCIE_DW_IMX8=y +CONFIG_PHY_IMX8M_PCIE=y +CONFIG_CMD_PCI=y +CONFIG_NVME=y +CONFIG_NVME_PCI=y +CONFIG_CMD_NVME=y
Let me reiterate the header here too.
Enable PCIe/NVMe support. Also, enable the reset driver which is a prerequisite for PCIe support.
-Sumit
Please don't group all these new config options at the end of the file.
Use 'make savedefconfig' and then 'cp defconfig configs/verdin-imx8mp_defconfig' to properly add these new config options.
That sounds better, I will do that for v2.
-Sumit
With the commit message improved ..
... and this change, feel free to add in v2
Acked-by: Francesco Dolcini francesco.dolcini@toradex.com
Francesco
Hello Sumit,
This will increase the u-boot proper size and marginally increase the boot time (because of a bigger binary to be read from the eMMC).
Apart of that do you expect any other impact on those changes? SPL binary size should not be affected, correct?
Asking this out loudly to confirm that nothing unexpected is going to happen because of these changes.
For my curiosity, care to share what's the use case? Do you plan to have the OS stored into an NVME device?
Francesco
Hi Sumit
On Wed, 2024-02-21 at 08:55 +0100, Francesco Dolcini wrote:
Hello Sumit,
Yes, I checked and it is actually slightly more than 32 K.
That was also my concern.
Other than that I actually gave it a quick try and PCIe/NVMe does indeed work and the regular boot is not affected (other than the slight size and boot time increase, of course).
For us the question is basically whether that use case does mandate enforcing such changes for each and every customer. Plus the regular expected maintenance effort any such change brings with it, of course.
Francesco
Cheers
Marcel
On Wed, 21 Feb 2024 at 10:19, Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
Hi Sumit
Hello Sumit,
@Francesco that's correct, we have the OS stored on NVME SSD. @Marcel wrt enforcing it, we can always fallback to have a config fragment for our customers builds. That's already the case, we fine tune the config and don't use U-Boot defconfig out of the box for shipping to end users.
Francesco
Cheers
Marcel
Cheers,
Hi Sumit
Hello Sumit,
Thanks for taking the time to test it. I suppose I can take that as a Tested-by tag.
From a PCIe maintenance point of view, I can add myself as a
maintainer for drivers added by this patch-set.
Marcel, Francesco,
If you folks still have worries about updating the defconfig then I can make it as a config fragment for mainline too. I suppose that should work for other boards too based on the iMX8MP SoC.
-Sumit
Francesco
Cheers
Marcel
Cheers,
Fathi Boudra
On 2/21/24 10:18, Marcel Ziswiler wrote:
Hi Sumit
Hello Sumit,
You can always enable this support on MX8MP EVK, it has M2 slot and this would add build coverage of this code too, without impacting Verdin.
Hi Sumit
Hello Sumit,
I would have chosen that as the base platform to enable but unfortunately I don't have that at my desk. However, if someone is willing to test this patch-set on MX8MP EVK then I am happy to extend corresponding defconfig too.
-Sumit
Hi Sumit
Hello Sumit,
I think we can surely find a platform on which this can be enabled by default and tested by people.
Hi Sumit
Hello Sumit,
My development machine crashed (my fault for running a pre-release OS),but I have an i.MX8M Plus and an NVMe drive that I can test once I get my machine running again.
adam
Hi Sumit
Hello Sumit,
On Tue, Feb 20, 2024 at 06:40:56PM +0530, Sumit Garg wrote: > Also, enable reset driver which is a prerequisite for PCIe support. > > Signed-off-by: Sumit Garg sumit.garg@linaro.org > --- > configs/verdin-imx8mp_defconfig | 9 +++++++++ > 1 file changed, 9 insertions(+) > > diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig > index 22b8a334dfa..d8bd644322b 100644 > --- a/configs/verdin-imx8mp_defconfig > +++ b/configs/verdin-imx8mp_defconfig > @@ -185,3 +185,12 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 > CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 > CONFIG_IMX_WATCHDOG=y > CONFIG_HEXDUMP=y > +CONFIG_DM_RESET=y > +CONFIG_RESET_IMX=y > +CONFIG_PCI=y > +CONFIG_PCIE_DW_IMX8=y > +CONFIG_PHY_IMX8M_PCIE=y > +CONFIG_CMD_PCI=y > +CONFIG_NVME=y > +CONFIG_NVME_PCI=y > +CONFIG_CMD_NVME=y
I can test right away, although I'll wait for V2 with all the fixes.
Marcel, given all you wrote here I would personally be fine on having this enabled in the verdin_imx8mp defconfig.
What's your idea? Are you good with it?
Francesco
Yes, I do agree.
Francesco
Cheers
Marcel
On 2/21/24 08:55, Francesco Dolcini wrote:
Hello Sumit,
Boot OS images from NVMe is useful if eMMC size no longer cuts it (because debug symbols or to collect logs over long periods of time).
Hello Sumit,
Yeah especially if one wants to run a fully fledged Linux distro image.
-Sumit
You can call this pcie_dw_imx.c , the imx6 support can be converted over to that driver too I guess ?
Yeah I suppose that should be possible, let me rename it as pcie_dw_imx.c.
-Sumit
Thanks
participants (7)
Adam Ford
Fabio Estevam
Fathi Boudra
Francesco Dolcini
Marcel Ziswiler
Sumit Garg
