[U-Boot] [PATCH] dts/Makefile: Turn off system-/gcc-specific predefined macros
Add '-undef' to DTS_CPPFLAGS to avoid unwanted expansion of dts content that matches system-specific or gcc-specific predefined macros.
Example: A number of PowerPC related *.dts files in the kernel define a property named 'linux,network-index' which (w/o '-undef') is expanded to '1,network-index' by the preprocessor because of '#define linux 1.'
With '-undef' in place only the standard predefined macros are visible:
$ gcc -dM -E -undef - </dev/null #define __STDC_HOSTED__ 1 #define __STDC__ 1
Signed-off-by: Horst Kronstorfer hkronsto@frequentis.com --- dts/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/dts/Makefile b/dts/Makefile index 402dfe1..3c6bc18 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -36,7 +36,7 @@ $(error Your architecture does not have device tree support enabled. \ Please define CONFIG_ARCH_DEVICE_TREE))
# We preprocess the device tree file provide a useful define -DTS_CPPFLAGS := -DARCH_CPU_DTS="$(SRCTREE)/arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi" +DTS_CPPFLAGS := -undef -DARCH_CPU_DTS="$(SRCTREE)/arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi"
all: $(obj).depend $(LIB)
i think you should use -ansi instead. that's what we use in other places for the same reason. -mike
this would increase the probability of a name clash.
-h
no idea what you're talking about. have you actually looked at the output of `gcc -E -dD -ansi` ? -mike
$ gcc -E -dM -ansi - </dev/null | wc -l 229 $ gcc -E -dM -undef - </dev/null | wc -l 2
-h
-mike
and ? did you *look* at the output ? they're all of the form __foo__. do any device trees really use __foo__ names ? i don't think so. -mike
i already considered that.
is there any drawback using '-undef' in this particular case besides "we use -ansi in other places for the same reason"?
-h
-mike
On Friday 13 July 2012 09:03:40 Horst Kronstorfer wrote: > Add '-undef' to DTS_CPPFLAGS to avoid unwanted expansion of dts > content that matches system-specific or gcc-specific predefined > macros. > > Example: A number of PowerPC related *.dts files in the kernel > define a property named 'linux,network-index' which (w/o '-undef') > is expanded to '1,network-index' by the preprocessor because of > '#define linux 1.'
we use -ansi because it's more portable and has known behavior in the build system -mike
Add '-ansi' to DTS_CPPFLAGS to avoid unwanted expansion of dts content that matches some predefined macros.
Example: A number of PowerPC related *.dts files in the kernel define a property named 'linux,network-index' which (w/o '-ansi') is expanded to '1,network-index' by the preprocessor because of '#define linux 1.'
Signed-off-by: Horst Kronstorfer hkronsto@frequentis.com --- Changes in v2: - Use '-ansi' instead of '-undef.'
# We preprocess the device tree file provide a useful define -DTS_CPPFLAGS := -DARCH_CPU_DTS="$(SRCTREE)/arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi" +DTS_CPPFLAGS := -ansi -DARCH_CPU_DTS="$(SRCTREE)/arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi"
Dear Horst Kronstorfer,
In message 1343337995-1291-1-git-send-email-hkronsto@frequentis.com you wrote:
Changes in v2:
Applied this one instead, thanks.
In message 1342184620-31448-1-git-send-email-hkronsto@frequentis.com you wrote:
Applied, thanks.
Horst Kronstorfer
Horst Kronstorfer
Mike Frysinger
