The following changes since commit e4fb863f6dec0002069d57422ebe3ce3af69a273:
dm: blk: Add tests for block devices (2016-03-17 21:27:39 -0600)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to 1b108880e6433e398681785f51b2a2dca983cd1b:
usb: xhci: Fix vendor command error if the request type is USB_REQ_SET_ADDRESS or USB_REQ_SET_CONFIGURATION. (2016-03-20 18:00:45 +0100)
---------------------------------------------------------------- Stefan Roese (4): usb: legacy_hub_port_reset(): Speedup hub reset handling usb: Remove 200 ms delay in usb_hub_port_connect_change() usb: Don't reset the USB hub a 2nd time usb: Change power-on / scanning timeout handling
Ted Chen (1): usb: xhci: Fix vendor command error if the request type is USB_REQ_SET_ADDRESS or USB_REQ_SET_CONFIGURATION.
common/usb.c | 13 +---- common/usb_hub.c | 329 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------- drivers/usb/host/xhci.c | 6 ++- include/usb.h | 4 ++ 4 files changed, 239 insertions(+), 113 deletions(-)
