[U-Boot] [PATCH] patman: Do not Cc addresses included in To list
In case an address is listed in the To list, those will be skipped on Cc list or user might end with a duplicated message.
This fixes the case when a tag points to same address used as series destination thus avoiding duplicated sending.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- tools/patman/series.py | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/tools/patman/series.py b/tools/patman/series.py index eda1e9b..c338ccb 100644 --- a/tools/patman/series.py +++ b/tools/patman/series.py @@ -114,6 +114,12 @@ class Series(dict): cc_list += gitutil.BuildEmailList(commit.tags) cc_list += gitutil.BuildEmailList(commit.cc_list)
+ # Remove items on To list + try: + map(cc_list.remove, gitutil.BuildEmailList(self.to)) + except ValueError: + pass + for email in cc_list: if email == None: email = col.Color(col.YELLOW, "<alias '%s' not found>"
Hi Otavio,
On Wed, Aug 15, 2012 at 12:44 PM, Otavio Salvador otavio@ossystems.com.br wrote:
try:
except ValueError:
pass
I'm ok with this as is. But could you do something like:
if 'to' in self: map(cc_list.remove, gitutil.BuildEmailList(self.to))
-- 1.7.10.4
On Fri, Aug 17, 2012 at 6:30 PM, Simon Glass sjg@chromium.org wrote:
Hi Otavio,
try:
except ValueError:
pass
Why? I didn't get why this check would be need.
I can do that for sure but I'd like to understand.
Hi Otavio,
On Fri, Aug 17, 2012 at 2:32 PM, Otavio Salvador otavio@ossystems.com.br wrote:
Hi Otavio,
try:
except ValueError:
pass
Only that I think you don't need the exception stuff if you add that check, so it might be shorter.
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
Otavio Salvador
