[U-Boot] [PATCH] Fix build errors after making flash_get_info() non-static
Fix for these build problems: error: static declaration of 'flash_get_info' follows non-static declaration
Signed-off-by: Wolfgang Denk wd@denx.de --- board/emk/common/flash.c | 3 +-- board/evb64260/flash.c | 3 +-- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/board/emk/common/flash.c b/board/emk/common/flash.c index 330978b..fe611bb 100644 --- a/board/emk/common/flash.c +++ b/board/emk/common/flash.c @@ -82,7 +82,6 @@ flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ static ulong flash_get_size(FPWV *addr, flash_info_t *info); static void flash_reset(flash_info_t *info); static int write_word_amd(flash_info_t *info, FPWV *dest, FPW data); -static flash_info_t *flash_get_info(ulong base);
/*----------------------------------------------------------------------- * flash_init() @@ -142,7 +141,7 @@ static void flash_reset(flash_info_t *info) /*----------------------------------------------------------------------- */
-static flash_info_t *flash_get_info(ulong base) +flash_info_t *flash_get_info(ulong base) { int i; flash_info_t * info; diff --git a/board/evb64260/flash.c b/board/evb64260/flash.c index 115e8cd..825bbaf 100644 --- a/board/evb64260/flash.c +++ b/board/evb64260/flash.c @@ -54,7 +54,6 @@ flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ static ulong flash_get_size (int portwidth, vu_long *addr, flash_info_t *info); static int write_word (flash_info_t *info, ulong dest, ulong data); static void flash_get_offsets (ulong base, flash_info_t *info); -static flash_info_t *flash_get_info(ulong base);
/*----------------------------------------------------------------------- */ @@ -178,7 +177,7 @@ flash_get_offsets (ulong base, flash_info_t *info) /*----------------------------------------------------------------------- */
