[U-Boot] U-boot support for Non Console board
Hi , We have a custom board based on coldfire (MCF5484) Similar to MCF5484 Kitlite The board runs Coldfire as PCI agent , 64MB of SDRAM, 4 MB of Bootflash and the PCI bus as a slave (no serial port->no console) I can flash U-boot using the JTAG . Can you let know how can i pass the Commands over PCI . I do not have a Console to do that ?
Please let me know the inputs ?
Thanks and Regards Rajeev S
Dear rajeev s,
Well, somebody who designed this system must also have had some plan how to operate the board?
Not having a console port sounds like a really stupid thing to me.
If you have ethenret on your board, you can try netconsole. But it will be no fun to port U-Boot to such hardware.
I suggest you bring the board back to the hardware guys and ask for a serial console port, at least for bring-up and debugging.
Wolfgang Denk wrote:
Dear rajeev s,
On the u-boot side, you can write a "fake uart" that... TX: Takes bytes and puts them in a "TX" queue in shared PCI memory. RX: Looks at the "RX" queue in shared PCI memory for new characters.
Then on the host side, you write a custom fake uart driver to do the opposite (taking advantage of the OS's capabilities and support programs) or write a custom terminal program that implements the fake uart handling directly (simpler to get running, much less flexible and more maintenance long term).
The queue can be a simple /n/ byte array (I would set /n/ to 256 or some larger power of 2 since size doesn't matter ;-) with head and tail indexes. The writer puts a byte in queue[head++] and the reader checks "if (head != tail) return queue[tail++]". Note that there is only one writer to "head" and one to "tail" so you don't have any race condition/locking issues (assuming your r/w access is atomic and you don't code any bugs into your algorithm).
Details glossed over: * head and tail must be incremented modulo the queue length * You *NEVER* want to set head or tail to be equal to the queue length in the shared memory (that would be out-of-bounds on the array). "head = (head + 1) % sizeof(queue);" should be save (check the assembly code, compiled with optimization!). If you use "head = ++head % sizeof(queue);", the compiler will write head++ with with wrong value 256 every 256 bytes (see the next bullet) and then do the modulo and re-write head with the correct value (0). * You need to make all the shared variables "volatile" * You need to prevent head from overtaking tail. For instance, if (head + 1) == tail (check *before* writing the byte to the queue), you have an overflow condition and will have to drop the byte.
I have not googled, I'm sure many people have done this before. Maybe you will get lucky and someone will have published source under a GPL (compatible) license.
Best regards, gvb
Dear rajeev s,
- head and tail must be incremented modulo the queue length
- You *NEVER* want to set head or tail to be equal to the queue length in the shared memory (that would be out-of-bounds on the array). "head = (head + 1) % sizeof(queue);" should be save (check the assembly code, compiled with optimization!). If you use "head = ++head % sizeof(queue);", the compiler will write head++ with with wrong value 256 every 256 bytes (see the next bullet) and then do the modulo and re-write head with the correct value (0).
- You need to make all the shared variables "volatile"
- You need to prevent head from overtaking tail. For instance, if (head + 1) == tail (check *before* writing the byte to the queue), you have an overflow condition and will have to drop the byte.
IIRC I've seen this in the Prism54 driver
Best Regards, J.
On Fri, Oct 31, 2008 at 01:25:14PM +0100, Jean-Christophe PLAGNIOL-VILLARD wrote:
Dear rajeev s,
[snip]
I'm currently working on a custom board based on MPC8349EMDS. It works in PCI agent mode.
I have written a Linux driver that implements both ethernet and a uart over the PCI bus. I don't think it would be hard to port to your board. Search the linuxppc-dev or LKML archives for the patch. The subject is "net: add PCINet driver".
I'm currently trying to get the driver merged into Linux. I have also written U-Boot drivers that offer the same functionality. I can "see" the U-Boot prompt over PCI, and tftp + nfs boot over PCI. It is very convenient.
I was going to post up the U-Boot drivers after I get the Linux driver merged, just in case there are changes. I've inlined the patches below. The first adds ethernet, the second adds a serial port.
Please note that they are MPC8349EMDS specific right now, but they might provide inspiration. Showing your support of the PCINet driver on LKML might help get it reviewed. Noone has taken much interest.
Ira
From 356297a295bb2a5ee7c0bc736b838f144939376d Mon Sep 17 00:00:00 2001
From: Ira W. Snyder iws@ovro.caltech.edu Date: Mon, 18 Aug 2008 15:40:40 -0700 Subject: [PATCH] Add PCINet Driver
This adds a virtual network interface that uses the PCI bus for communication. This is extremely useful for boards in PCISLAVE mode, so you do not need extra cables to communicate with them.
There is a corresponding Linux driver to be run on the host system.
Signed-off-by: Ira W. Snyder iws@ovro.caltech.edu --- cpu/mpc83xx/cpu.c | 4 +- drivers/net/Makefile | 1 + drivers/net/pcinet.c | 503 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/pcinet.h | 73 ++++++++ 4 files changed, 580 insertions(+), 1 deletions(-) create mode 100644 drivers/net/pcinet.c create mode 100644 drivers/net/pcinet.h
diff --git a/cpu/mpc83xx/cpu.c b/cpu/mpc83xx/cpu.c index aa9b18d..79c0363 100644 --- a/cpu/mpc83xx/cpu.c +++ b/cpu/mpc83xx/cpu.c @@ -364,6 +364,8 @@ int cpu_eth_init(bd_t *bis) #if defined(CONFIG_TSEC_ENET) tsec_standard_init(bis); #endif - +#ifdef CONFIG_PCINET_ETHERNET + pcinet_initialize(bis, 0, "PCINET"); +#endif return 0; } diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 439c354..2435e63 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -52,6 +52,7 @@ COBJS-$(CONFIG_NETCONSOLE) += netconsole.o COBJS-$(CONFIG_DRIVER_NS7520_ETHERNET) += ns7520_eth.o COBJS-$(CONFIG_NS8382X) += ns8382x.o COBJS-$(CONFIG_DRIVER_NS9750_ETHERNET) += ns9750_eth.o +COBJS-$(CONFIG_PCINET_ETHERNET) += pcinet.o COBJS-$(CONFIG_PCNET) += pcnet.o COBJS-$(CONFIG_PLB2800_ETHER) += plb2800_eth.o COBJS-$(CONFIG_DRIVER_RTL8019) += rtl8019.o diff --git a/drivers/net/pcinet.c b/drivers/net/pcinet.c new file mode 100644 index 0000000..b86383f --- /dev/null +++ b/drivers/net/pcinet.c @@ -0,0 +1,503 @@ +/* + * PCINet Virtual Ethernet over PCI driver + * + * This software may be used and distributed according to the + * terms of the GNU General Public License, Version 2, incorporated + * herein by reference. + * + * Copyright (c) 2008, Ira W. Snyder iws@ovro.caltech.edu + */ + +#include <config.h> +#include <common.h> +#include <malloc.h> +#include <net.h> +#include <command.h> +#include <asm/io.h> +#include <asm/errno.h> + +#include <asm/mmu.h> +#include <mpc83xx.h> +#include <asm/mpc8349_pci.h> + +#include "pcinet.h" + +struct wqt_dev; +typedef void (*wqt_irqhandler_t)(struct wqt_dev *); + +struct wqt_dev { + wqt_irqhandler_t net_rx_packet_handler; + wqt_irqhandler_t net_tx_complete_handler; + int state; + + void *netregs; + + cbd_t *rx_base; + cbd_t *tx_base; + + cbd_t *cur_rx; + cbd_t *cur_tx; + cbd_t *dirty_tx; + int tx_free; +}; + +#define W32(addr, b) out_le32((volatile u32 *)(addr), (b)) +#define R32(addr) in_le32((volatile u32 *)(addr)) + +#define W32BE(addr, b) out_be32((volatile u32 *)(addr), (b)) +#define R32BE(addr) in_be32((volatile u32 *)(addr)) + +/*----------------------------------------------------------------------------*/ +/* Status Bits */ +/*----------------------------------------------------------------------------*/ + +static void status_setbit(u32 bit) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + W32(&dma->omr1, R32(&dma->omr1) | bit); +} + +static void status_clrbit(u32 bit) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + W32(&dma->omr1, R32(&dma->omr1) & ~bit); +} + +static u32 status_remote_testbit(u32 bit) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + return R32(&dma->imr1) & bit; +} + +/*----------------------------------------------------------------------------*/ +/* Doorbell */ +/*----------------------------------------------------------------------------*/ + +static void doorbell_set(u32 bit) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + W32(&dma->odr, bit); +} + +/*----------------------------------------------------------------------------*/ +/* DMA */ +/*----------------------------------------------------------------------------*/ + +/* + * Set up a 1GB outbound window starting at PCI address 0x0 + */ +static void setup_outbound_window(void) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile law83xx_t *pci_law = immr->sysconf.pcilaw; + volatile pot83xx_t *pci_pot = immr->ios.pot; + + W32BE(&pci_law[0].ar, LAWAR_EN | LAWAR_SIZE_1G); + W32BE(&pci_pot[0].pocmr, POCMR_EN | POCMR_PREFETCH_EN + | (POCMR_CM_1G & POCMR_CM_MASK)); + W32BE(&pci_pot[0].potar, 0x0); +} + +static void dma_pci_to_buf(u32 dst, u32 src, size_t len) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + /* Wait for the DMA controller to become free */ + while (R32(&dma->dmasr0) & DMA_CHANNEL_BUSY) + udelay(100); + + /* Program the DMA controller */ + W32(&dma->dmasar0, 0x80000000 + src); + W32(&dma->dmadar0, dst); + W32(&dma->dmabcr0, len); + + /* Start the transfer */ + W32(&dma->dmamr0, DMA_CHANNEL_TRANSFER_MODE_DIRECT | DMA_CHANNEL_SNOOP); + W32(&dma->dmamr0, DMA_CHANNEL_TRANSFER_MODE_DIRECT | DMA_CHANNEL_SNOOP + | DMA_CHANNEL_START); + + while (R32(&dma->dmasr0) & DMA_CHANNEL_BUSY) + udelay(100); +} + +static void dma_buf_to_pci(u32 dst, u32 src, size_t len) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + /* Wait for the DMA controller to become free */ + while (R32(&dma->dmasr0) & DMA_CHANNEL_BUSY) + udelay(100); + + /* Program the DMA controller */ + W32(&dma->dmasar0, src); + W32(&dma->dmadar0, 0x80000000 + dst); + W32(&dma->dmabcr0, len); + + /* Start the transfer */ + W32(&dma->dmamr0, DMA_CHANNEL_TRANSFER_MODE_DIRECT | DMA_CHANNEL_SNOOP); + W32(&dma->dmamr0, DMA_CHANNEL_TRANSFER_MODE_DIRECT | DMA_CHANNEL_SNOOP + | DMA_CHANNEL_START); + + while (R32(&dma->dmasr0) & DMA_CHANNEL_BUSY) + udelay(100); +} + +/*----------------------------------------------------------------------------*/ +/* Helper Functions */ +/*----------------------------------------------------------------------------*/ + +static int pcinet_init_netregs(struct wqt_dev *priv) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile pcictrl83xx_t *pci_ctrl = &immr->pci_ctrl[0]; + u32 val; + + /* Check the PCI Inbound Window Attributes Register 0 for a 4k window + * This is PCI BAR1, and will be used as network device registers */ + val = R32BE(&pci_ctrl->piwar0) & (PIWAR_EN | PIWAR_IWS_4K); + + if (val != (PIWAR_EN | PIWAR_IWS_4K)) { + printf("PIWAR0 set up incorrectly (was %x should be %x)\n", + val, (PIWAR_EN | PIWAR_IWS_4K)); + return -ENODEV; + } + + /* Allocate the 4k of registers, 4k aligned */ + priv->netregs = memalign(4096, 4096); + + if (!priv->netregs) + return -ENOMEM; + + memset(priv->netregs, 0, 4096); + + /* Write the address into the inbound window address register */ + W32BE(&pci_ctrl->pitar0, (u32)priv->netregs >> 12); + + return 0; +} + +/*----------------------------------------------------------------------------*/ +/* Interrupt Handling */ +/*----------------------------------------------------------------------------*/ + +static void net_rx_packet_handler(struct wqt_dev *priv); +static void net_tx_complete_handler(struct wqt_dev *priv); +static void empty_handler(struct wqt_dev *priv); + +static void do_reinitialize_ring_pointers(struct wqt_dev *priv) +{ + priv->cur_rx = priv->rx_base; + priv->cur_tx = priv->tx_base; + priv->dirty_tx = priv->tx_base; + priv->tx_free = PH_RING_SIZE; +} + +static void do_start_queues(struct wqt_dev *priv) +{ + priv->net_rx_packet_handler = net_rx_packet_handler; + priv->net_tx_complete_handler = net_tx_complete_handler; +} + +static void do_stop_queues(struct wqt_dev *priv) +{ + priv->net_rx_packet_handler = empty_handler; + priv->net_tx_complete_handler = empty_handler; +} + +static void empty_handler(struct wqt_dev *priv) +{ +} + +static void net_start_handler(struct wqt_dev *priv) +{ + if (priv->state == NET_STATE_RUNNING) + return; + + do_reinitialize_ring_pointers(priv); + do_start_queues(priv); + + priv->state = NET_STATE_RUNNING; +} + +static void net_stop_handler(struct wqt_dev *priv) +{ + if (priv->state == NET_STATE_STOPPED) + return; + + do_stop_queues(priv); + + priv->state = NET_STATE_STOPPED; +} + +static void net_rx_packet_handler(struct wqt_dev *priv) +{ + cbd_t *bdp; + int dirty_idx; + u32 pkt_len, src_addr; + uchar *pkt; + + bdp = priv->cur_rx; + + while (CBDR_SC(bdp) == BD_MEM_DIRTY) { + dirty_idx = bdp - priv->rx_base; + + pkt_len = CBDR_LEN(bdp); + src_addr = CBDR_ADDR(bdp); + + pkt = malloc(pkt_len); + + if (pkt != NULL) { + dma_pci_to_buf((u32)pkt, src_addr, pkt_len); + NetReceive(pkt, pkt_len); + free(pkt); + } + + CBDW_SC(bdp, BD_MEM_FREE); + + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->rx_base; + else + bdp++; + } + + priv->cur_rx = bdp; + + doorbell_set(NET_TX_COMPLETE_DBELL); +} + +static void net_tx_complete_handler(struct wqt_dev *priv) +{ + cbd_t *bdp; + int dirty_idx; + + bdp = priv->dirty_tx; + + while (CBDR_SC(bdp) == BD_MEM_FREE) { + dirty_idx = bdp - priv->tx_base; + + priv->tx_free++; + CBDW_SC(bdp, BD_MEM_READY); + + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->tx_base; + else + bdp++; + } + + priv->dirty_tx = bdp; +} + +static void pcinet_interrupt(struct wqt_dev *priv) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + u32 idr; + + idr = R32(&dma->idr); + + /* Clear all of the network doorbells */ + W32(&dma->idr, NET_START_REQ_DBELL | NET_START_ACK_DBELL + | NET_STOP_REQ_DBELL | NET_STOP_ACK_DBELL + | NET_RX_PACKET_DBELL | NET_TX_COMPLETE_DBELL); + + if (idr & NET_START_REQ_DBELL) { + net_start_handler(priv); + doorbell_set(NET_START_ACK_DBELL); + } + + if (idr & NET_START_ACK_DBELL) + net_start_handler(priv); + + if (idr & NET_STOP_REQ_DBELL) { + net_stop_handler(priv); + doorbell_set(NET_STOP_ACK_DBELL); + } + + if (idr & NET_STOP_ACK_DBELL) + net_stop_handler(priv); + + if (idr & NET_RX_PACKET_DBELL) + priv->net_rx_packet_handler(priv); + + if (idr & NET_TX_COMPLETE_DBELL) + priv->net_tx_complete_handler(priv); + + /* This slows down the interrupt routine a bit, since we don't need + * to be running it as absolutely fast as the CPU can handle */ + udelay(250); +} + +/*----------------------------------------------------------------------------*/ +/* Ethernet Device Functions */ +/*----------------------------------------------------------------------------*/ + +/* Initializes data structures and registers for the controller, + * and brings the interface up. Returns the link status, meaning: + * SUCCESS if the link is up + * FAILURE otherwise + * + * This allows u-boot to find the first active controller + */ +static int pcinet_open(struct eth_device *dev, bd_t *bd) +{ + struct wqt_dev *priv = dev->priv; + int i; + + status_setbit(PCINET_NET_STATUS_RUNNING); + do_stop_queues(priv); + + /* If the other side is not running, there isn't much we can do. It's not like we + * can just magically start it */ + if (!status_remote_testbit(PCINET_NET_STATUS_RUNNING)) + return 0; + + /* Notify the other side to start */ + doorbell_set(NET_START_REQ_DBELL); + + /* Wait for 5 seconds to start */ + for (i=0; priv->state == NET_STATE_STOPPED && i<5000; ++i) { + pcinet_interrupt(priv); + udelay(1000); + } + + if (priv->state == NET_STATE_RUNNING) + return 1; + + return 0; +} + +/* Stop the interface completely */ +static void pcinet_stop(struct eth_device *dev) +{ + struct wqt_dev *priv = dev->priv; + int i; + + status_clrbit(PCINET_NET_STATUS_RUNNING); + do_stop_queues(priv); + + if (priv->state == NET_STATE_RUNNING) { + doorbell_set(NET_STOP_REQ_DBELL); + + /* Wait 5 seconds to stop */ + for (i=0; priv->state == NET_STATE_RUNNING && i<5000; ++i) { + pcinet_interrupt(priv); + udelay(1000); + } + } +} + +static int pcinet_xmit(struct eth_device *dev, volatile void *packet, int length) +{ + struct wqt_dev *priv = dev->priv; + u32 dst_addr; + int dirty_idx; + cbd_t *bdp; + + bdp = priv->cur_tx; + dirty_idx = bdp - priv->tx_base; + + if (priv->state == NET_STATE_STOPPED) + return 1; + + /* Check for no free TX slots */ + if (priv->tx_free == 0 || CBDR_SC(bdp) != BD_MEM_READY) + return 1; + + dst_addr = CBDR_ADDR(bdp); + + /* DMA the packet into the remote memory */ + dma_buf_to_pci(dst_addr, (u32)packet, length); + + CBDW_LEN(bdp, length); + CBDW_SC(bdp, BD_MEM_DIRTY); + + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->tx_base; + else + bdp++; + + priv->cur_tx = bdp; + priv->tx_free--; + + if (!status_remote_testbit(PCINET_NET_RXINT_OFF)) + doorbell_set(NET_RX_PACKET_DBELL); + + return 0; +} + +static int pcinet_recv(struct eth_device *dev) +{ + struct wqt_dev *priv = dev->priv; + pcinet_interrupt(priv); + return -1; +} + +/* Called from net/eth.c to start the ethernet controller */ +int pcinet_initialize(bd_t *bis, int index, char *devname) +{ + struct eth_device *dev; + struct wqt_dev *priv; + int ret; + + /* Allocate the ethernet device and driver-private data */ + dev = malloc(sizeof(*dev)); + + if (!dev) + goto out_alloc_eth_device; + + priv = malloc(sizeof(*priv)); + + if (!priv) + goto out_alloc_priv; + + memset(dev, 0, sizeof(*dev)); + memset(priv, 0, sizeof(*priv)); + + /* Allocate and setup network registers */ + ret = pcinet_init_netregs(priv); + + if (ret) + goto out_init_netregs; + + status_setbit(PCINET_NET_REGISTERS_VALID); + priv->rx_base = priv->netregs + PCINET_TXBD_BASE; + priv->tx_base = priv->netregs + PCINET_RXBD_BASE; + + /* Set up the outbound window */ + setup_outbound_window(); + + /* Setup ethernet device */ + sprintf (dev->name, devname); + dev->iobase = 0; + dev->priv = priv; + dev->init = pcinet_open; + dev->halt = pcinet_stop; + dev->send = pcinet_xmit; + dev->recv = pcinet_recv; + + /* Tell u-boot to get the addr from the env */ + memset(dev->enetaddr, 0, 6); + + eth_register (dev); + + return 1; + +out_init_netregs: + free(priv); +out_alloc_priv: + free(dev); +out_alloc_eth_device: + return 0; +} + +/* vim: set ts=8 sts=8 sw=8 noet tw=92: */ diff --git a/drivers/net/pcinet.h b/drivers/net/pcinet.h new file mode 100644 index 0000000..b1851fe --- /dev/null +++ b/drivers/net/pcinet.h @@ -0,0 +1,73 @@ +/* + * ONE-LINE DESCRIPTION + * + * Copyright (c) 2008 Ira W. Snyder iws@ovro.caltech.edu + * + * Heavily inspired by the drivers/net/fs_enet driver + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#ifndef PCINET_H +#define PCINET_H + +//#define PH_MAX_MTU (1508) +//#define PH_MAX_MTU (4082) +//#define PH_MAX_MTU (8178) +//#define PH_MAX_MTU (16370) +//#define PH_MAX_MTU (32754) +#define PH_MAX_MTU (65522) +//#define PH_MAX_MTU (131058) +#define PH_MAX_FRSIZE (PH_MAX_MTU+ETHER_HDR_SIZE) + +#define PH_RING_SIZE 64 + +struct circ_buf_desc { + u32 sc; + u32 len; + u32 addr; +} __attribute__((__packed__)); +typedef struct circ_buf_desc cbd_t; + +/* Buffer Descriptor Accessors */ +#define CBDW_SC(_cbd, _sc) out_le32((volatile u32 *)&(_cbd)->sc, (_sc)) +#define CBDW_LEN(_cbd, _len) out_le32((volatile u32 *)&(_cbd)->len, (_len)) +#define CBDW_ADDR(_cbd, _addr) out_le32((volatile u32 *)&(_cbd)->addr, (_addr)) + +#define CBDR_SC(_cbd) in_le32((volatile u32 *)&(_cbd)->sc) +#define CBDR_LEN(_cbd) in_le32((volatile u32 *)&(_cbd)->len) +#define CBDR_ADDR(_cbd) in_le32((volatile u32 *)&(_cbd)->addr) + +/* Buffer Descriptor Registers */ +#define PCINET_TXBD_BASE 0x400 +#define PCINET_RXBD_BASE 0x800 + +/* Buffer Descriptor Status */ +#define BD_MEM_READY 0x1 +#define BD_MEM_DIRTY 0x2 +#define BD_MEM_FREE 0x3 + +#define PCINET_UART_RX_ENABLED (1<<0) +#define PCINET_NET_STATUS_RUNNING (1<<1) +#define PCINET_NET_RXINT_OFF (1<<2) +#define PCINET_NET_REGISTERS_VALID (1<<3) + +/* Driver State Bits */ +#define NET_STATE_STOPPED 0 +#define NET_STATE_RUNNING 1 + +/* Doorbell Registers */ +#define UART_RX_READY_DBELL (1<<0) +#define UART_TX_EMPTY_DBELL (1<<1) +#define NET_RX_PACKET_DBELL (1<<2) +#define NET_TX_COMPLETE_DBELL (1<<3) +#define NET_START_REQ_DBELL (1<<4) +#define NET_START_ACK_DBELL (1<<5) +#define NET_STOP_REQ_DBELL (1<<6) +#define NET_STOP_ACK_DBELL (1<<7) + +#endif /* PCINET_H */ + +/* vim: set ts=8 sts=8 sw=8 noet tw=92: */
hi Ira Snyder, Thanks for the respone. The solution mentioned looks feasible..
Could you please send the U-boot patch in the current shape .. Shall test the same patch with modifications as required to support our board.
Thanks again . Rajeev S
Ira Snyder iws@ovro.caltech.edu wrote: On Fri, Oct 31, 2008 at 01:25:14PM +0100, Jean-Christophe PLAGNIOL-VILLARD wrote:
Dear rajeev s,
[snip]
Ira
From: Ira W. Snyder Date: Mon, 18 Aug 2008 15:40:40 -0700 Subject: [PATCH] Add PCINet Driver
Signed-off-by: Ira W. Snyder --- cpu/mpc83xx/cpu.c | 4 +- drivers/net/Makefile | 1 + drivers/net/pcinet.c | 503 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/pcinet.h | 73 ++++++++ 4 files changed, 580 insertions(+), 1 deletions(-) create mode 100644 drivers/net/pcinet.c create mode 100644 drivers/net/pcinet.h
diff --git a/cpu/mpc83xx/cpu.c b/cpu/mpc83xx/cpu.c index aa9b18d..79c0363 100644 --- a/cpu/mpc83xx/cpu.c +++ b/cpu/mpc83xx/cpu.c @@ -364,6 +364,8 @@ int cpu_eth_init(bd_t *bis) #if defined(CONFIG_TSEC_ENET) tsec_standard_init(bis); #endif - +#ifdef CONFIG_PCINET_ETHERNET + pcinet_initialize(bis, 0, "PCINET"); +#endif return 0; } diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 439c354..2435e63 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -52,6 +52,7 @@ COBJS-$(CONFIG_NETCONSOLE) += netconsole.o COBJS-$(CONFIG_DRIVER_NS7520_ETHERNET) += ns7520_eth.o COBJS-$(CONFIG_NS8382X) += ns8382x.o COBJS-$(CONFIG_DRIVER_NS9750_ETHERNET) += ns9750_eth.o +COBJS-$(CONFIG_PCINET_ETHERNET) += pcinet.o COBJS-$(CONFIG_PCNET) += pcnet.o COBJS-$(CONFIG_PLB2800_ETHER) += plb2800_eth.o COBJS-$(CONFIG_DRIVER_RTL8019) += rtl8019.o diff --git a/drivers/net/pcinet.c b/drivers/net/pcinet.c new file mode 100644 index 0000000..b86383f --- /dev/null +++ b/drivers/net/pcinet.c @@ -0,0 +1,503 @@ +/* + * PCINet Virtual Ethernet over PCI driver + * + * This software may be used and distributed according to the + * terms of the GNU General Public License, Version 2, incorporated + * herein by reference. + * + * Copyright (c) 2008, Ira W. Snyder + */ + +#include +#include +#include +#include +#include +#include +#include + +#include +#include +#include + +#include "pcinet.h" + +struct wqt_dev; +typedef void (*wqt_irqhandler_t)(struct wqt_dev *); + +struct wqt_dev { + wqt_irqhandler_t net_rx_packet_handler; + wqt_irqhandler_t net_tx_complete_handler; + int state; + + void *netregs; + + cbd_t *rx_base; + cbd_t *tx_base; + + cbd_t *cur_rx; + cbd_t *cur_tx; + cbd_t *dirty_tx; + int tx_free; +}; + +#define W32(addr, b) out_le32((volatile u32 *)(addr), (b)) +#define R32(addr) in_le32((volatile u32 *)(addr)) + +#define W32BE(addr, b) out_be32((volatile u32 *)(addr), (b)) +#define R32BE(addr) in_be32((volatile u32 *)(addr)) + +/*----------------------------------------------------------------------------*/ +/* Status Bits */ +/*----------------------------------------------------------------------------*/ + +static void status_setbit(u32 bit) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + W32(&dma->omr1, R32(&dma->omr1) | bit); +} + +static void status_clrbit(u32 bit) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + W32(&dma->omr1, R32(&dma->omr1) & ~bit); +} + +static u32 status_remote_testbit(u32 bit) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + return R32(&dma->imr1) & bit; +} + +/*----------------------------------------------------------------------------*/ +/* Doorbell */ +/*----------------------------------------------------------------------------*/ + +static void doorbell_set(u32 bit) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + W32(&dma->odr, bit); +} + +/*----------------------------------------------------------------------------*/ +/* DMA */ +/*----------------------------------------------------------------------------*/ + +/* + * Set up a 1GB outbound window starting at PCI address 0x0 + */ +static void setup_outbound_window(void) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile law83xx_t *pci_law = immr->sysconf.pcilaw; + volatile pot83xx_t *pci_pot = immr->ios.pot; + + W32BE(&pci_law[0].ar, LAWAR_EN | LAWAR_SIZE_1G); + W32BE(&pci_pot[0].pocmr, POCMR_EN | POCMR_PREFETCH_EN + | (POCMR_CM_1G & POCMR_CM_MASK)); + W32BE(&pci_pot[0].potar, 0x0); +} + +static void dma_pci_to_buf(u32 dst, u32 src, size_t len) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + /* Wait for the DMA controller to become free */ + while (R32(&dma->dmasr0) & DMA_CHANNEL_BUSY) + udelay(100); + + /* Program the DMA controller */ + W32(&dma->dmasar0, 0x80000000 + src); + W32(&dma->dmadar0, dst); + W32(&dma->dmabcr0, len); + + /* Start the transfer */ + W32(&dma->dmamr0, DMA_CHANNEL_TRANSFER_MODE_DIRECT | DMA_CHANNEL_SNOOP); + W32(&dma->dmamr0, DMA_CHANNEL_TRANSFER_MODE_DIRECT | DMA_CHANNEL_SNOOP + | DMA_CHANNEL_START); + + while (R32(&dma->dmasr0) & DMA_CHANNEL_BUSY) + udelay(100); +} + +static void dma_buf_to_pci(u32 dst, u32 src, size_t len) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + + /* Wait for the DMA controller to become free */ + while (R32(&dma->dmasr0) & DMA_CHANNEL_BUSY) + udelay(100); + + /* Program the DMA controller */ + W32(&dma->dmasar0, src); + W32(&dma->dmadar0, 0x80000000 + dst); + W32(&dma->dmabcr0, len); + + /* Start the transfer */ + W32(&dma->dmamr0, DMA_CHANNEL_TRANSFER_MODE_DIRECT | DMA_CHANNEL_SNOOP); + W32(&dma->dmamr0, DMA_CHANNEL_TRANSFER_MODE_DIRECT | DMA_CHANNEL_SNOOP + | DMA_CHANNEL_START); + + while (R32(&dma->dmasr0) & DMA_CHANNEL_BUSY) + udelay(100); +} + +/*----------------------------------------------------------------------------*/ +/* Helper Functions */ +/*----------------------------------------------------------------------------*/ + +static int pcinet_init_netregs(struct wqt_dev *priv) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile pcictrl83xx_t *pci_ctrl = &immr->pci_ctrl[0]; + u32 val; + + /* Check the PCI Inbound Window Attributes Register 0 for a 4k window + * This is PCI BAR1, and will be used as network device registers */ + val = R32BE(&pci_ctrl->piwar0) & (PIWAR_EN | PIWAR_IWS_4K); + + if (val != (PIWAR_EN | PIWAR_IWS_4K)) { + printf("PIWAR0 set up incorrectly (was %x should be %x)\n", + val, (PIWAR_EN | PIWAR_IWS_4K)); + return -ENODEV; + } + + /* Allocate the 4k of registers, 4k aligned */ + priv->netregs = memalign(4096, 4096); + + if (!priv->netregs) + return -ENOMEM; + + memset(priv->netregs, 0, 4096); + + /* Write the address into the inbound window address register */ + W32BE(&pci_ctrl->pitar0, (u32)priv->netregs >> 12); + + return 0; +} + +/*----------------------------------------------------------------------------*/ +/* Interrupt Handling */ +/*----------------------------------------------------------------------------*/ + +static void net_rx_packet_handler(struct wqt_dev *priv); +static void net_tx_complete_handler(struct wqt_dev *priv); +static void empty_handler(struct wqt_dev *priv); + +static void do_reinitialize_ring_pointers(struct wqt_dev *priv) +{ + priv->cur_rx = priv->rx_base; + priv->cur_tx = priv->tx_base; + priv->dirty_tx = priv->tx_base; + priv->tx_free = PH_RING_SIZE; +} + +static void do_start_queues(struct wqt_dev *priv) +{ + priv->net_rx_packet_handler = net_rx_packet_handler; + priv->net_tx_complete_handler = net_tx_complete_handler; +} + +static void do_stop_queues(struct wqt_dev *priv) +{ + priv->net_rx_packet_handler = empty_handler; + priv->net_tx_complete_handler = empty_handler; +} + +static void empty_handler(struct wqt_dev *priv) +{ +} + +static void net_start_handler(struct wqt_dev *priv) +{ + if (priv->state == NET_STATE_RUNNING) + return; + + do_reinitialize_ring_pointers(priv); + do_start_queues(priv); + + priv->state = NET_STATE_RUNNING; +} + +static void net_stop_handler(struct wqt_dev *priv) +{ + if (priv->state == NET_STATE_STOPPED) + return; + + do_stop_queues(priv); + + priv->state = NET_STATE_STOPPED; +} + +static void net_rx_packet_handler(struct wqt_dev *priv) +{ + cbd_t *bdp; + int dirty_idx; + u32 pkt_len, src_addr; + uchar *pkt; + + bdp = priv->cur_rx; + + while (CBDR_SC(bdp) == BD_MEM_DIRTY) { + dirty_idx = bdp - priv->rx_base; + + pkt_len = CBDR_LEN(bdp); + src_addr = CBDR_ADDR(bdp); + + pkt = malloc(pkt_len); + + if (pkt != NULL) { + dma_pci_to_buf((u32)pkt, src_addr, pkt_len); + NetReceive(pkt, pkt_len); + free(pkt); + } + + CBDW_SC(bdp, BD_MEM_FREE); + + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->rx_base; + else + bdp++; + } + + priv->cur_rx = bdp; + + doorbell_set(NET_TX_COMPLETE_DBELL); +} + +static void net_tx_complete_handler(struct wqt_dev *priv) +{ + cbd_t *bdp; + int dirty_idx; + + bdp = priv->dirty_tx; + + while (CBDR_SC(bdp) == BD_MEM_FREE) { + dirty_idx = bdp - priv->tx_base; + + priv->tx_free++; + CBDW_SC(bdp, BD_MEM_READY); + + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->tx_base; + else + bdp++; + } + + priv->dirty_tx = bdp; +} + +static void pcinet_interrupt(struct wqt_dev *priv) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile dma83xx_t *dma = &immr->dma; + u32 idr; + + idr = R32(&dma->idr); + + /* Clear all of the network doorbells */ + W32(&dma->idr, NET_START_REQ_DBELL | NET_START_ACK_DBELL + | NET_STOP_REQ_DBELL | NET_STOP_ACK_DBELL + | NET_RX_PACKET_DBELL | NET_TX_COMPLETE_DBELL); + + if (idr & NET_START_REQ_DBELL) { + net_start_handler(priv); + doorbell_set(NET_START_ACK_DBELL); + } + + if (idr & NET_START_ACK_DBELL) + net_start_handler(priv); + + if (idr & NET_STOP_REQ_DBELL) { + net_stop_handler(priv); + doorbell_set(NET_STOP_ACK_DBELL); + } + + if (idr & NET_STOP_ACK_DBELL) + net_stop_handler(priv); + + if (idr & NET_RX_PACKET_DBELL) + priv->net_rx_packet_handler(priv); + + if (idr & NET_TX_COMPLETE_DBELL) + priv->net_tx_complete_handler(priv); + + /* This slows down the interrupt routine a bit, since we don't need + * to be running it as absolutely fast as the CPU can handle */ + udelay(250); +} + +/*----------------------------------------------------------------------------*/ +/* Ethernet Device Functions */ +/*----------------------------------------------------------------------------*/ + +/* Initializes data structures and registers for the controller, + * and brings the interface up. Returns the link status, meaning: + * SUCCESS if the link is up + * FAILURE otherwise + * + * This allows u-boot to find the first active controller + */ +static int pcinet_open(struct eth_device *dev, bd_t *bd) +{ + struct wqt_dev *priv = dev->priv; + int i; + + status_setbit(PCINET_NET_STATUS_RUNNING); + do_stop_queues(priv); + + /* If the other side is not running, there isn't much we can do. It's not like we + * can just magically start it */ + if (!status_remote_testbit(PCINET_NET_STATUS_RUNNING)) + return 0; + + /* Notify the other side to start */ + doorbell_set(NET_START_REQ_DBELL); + + /* Wait for 5 seconds to start */ + for (i=0; priv->state == NET_STATE_STOPPED && i<5000; ++i) { + pcinet_interrupt(priv); + udelay(1000); + } + + if (priv->state == NET_STATE_RUNNING) + return 1; + + return 0; +} + +/* Stop the interface completely */ +static void pcinet_stop(struct eth_device *dev) +{ + struct wqt_dev *priv = dev->priv; + int i; + + status_clrbit(PCINET_NET_STATUS_RUNNING); + do_stop_queues(priv); + + if (priv->state == NET_STATE_RUNNING) { + doorbell_set(NET_STOP_REQ_DBELL); + + /* Wait 5 seconds to stop */ + for (i=0; priv->state == NET_STATE_RUNNING && i<5000; ++i) { + pcinet_interrupt(priv); + udelay(1000); + } + } +} + +static int pcinet_xmit(struct eth_device *dev, volatile void *packet, int length) +{ + struct wqt_dev *priv = dev->priv; + u32 dst_addr; + int dirty_idx; + cbd_t *bdp; + + bdp = priv->cur_tx; + dirty_idx = bdp - priv->tx_base; + + if (priv->state == NET_STATE_STOPPED) + return 1; + + /* Check for no free TX slots */ + if (priv->tx_free == 0 || CBDR_SC(bdp) != BD_MEM_READY) + return 1; + + dst_addr = CBDR_ADDR(bdp); + + /* DMA the packet into the remote memory */ + dma_buf_to_pci(dst_addr, (u32)packet, length); + + CBDW_LEN(bdp, length); + CBDW_SC(bdp, BD_MEM_DIRTY); + + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->tx_base; + else + bdp++; + + priv->cur_tx = bdp; + priv->tx_free--; + + if (!status_remote_testbit(PCINET_NET_RXINT_OFF)) + doorbell_set(NET_RX_PACKET_DBELL); + + return 0; +} + +static int pcinet_recv(struct eth_device *dev) +{ + struct wqt_dev *priv = dev->priv; + pcinet_interrupt(priv); + return -1; +} + +/* Called from net/eth.c to start the ethernet controller */ +int pcinet_initialize(bd_t *bis, int index, char *devname) +{ + struct eth_device *dev; + struct wqt_dev *priv; + int ret; + + /* Allocate the ethernet device and driver-private data */ + dev = malloc(sizeof(*dev)); + + if (!dev) + goto out_alloc_eth_device; + + priv = malloc(sizeof(*priv)); + + if (!priv) + goto out_alloc_priv; + + memset(dev, 0, sizeof(*dev)); + memset(priv, 0, sizeof(*priv)); + + /* Allocate and setup network registers */ + ret = pcinet_init_netregs(priv); + + if (ret) + goto out_init_netregs; + + status_setbit(PCINET_NET_REGISTERS_VALID); + priv->rx_base = priv->netregs + PCINET_TXBD_BASE; + priv->tx_base = priv->netregs + PCINET_RXBD_BASE; + + /* Set up the outbound window */ + setup_outbound_window(); + + /* Setup ethernet device */ + sprintf (dev->name, devname); + dev->iobase = 0; + dev->priv = priv; + dev->init = pcinet_open; + dev->halt = pcinet_stop; + dev->send = pcinet_xmit; + dev->recv = pcinet_recv; + + /* Tell u-boot to get the addr from the env */ + memset(dev->enetaddr, 0, 6); + + eth_register (dev); + + return 1; + +out_init_netregs: + free(priv); +out_alloc_priv: + free(dev); +out_alloc_eth_device: + return 0; +} + +/* vim: set ts=8 sts=8 sw=8 noet tw=92: */ diff --git a/drivers/net/pcinet.h b/drivers/net/pcinet.h new file mode 100644 index 0000000..b1851fe --- /dev/null +++ b/drivers/net/pcinet.h @@ -0,0 +1,73 @@ +/* + * ONE-LINE DESCRIPTION + * + * Copyright (c) 2008 Ira W. Snyder + * + * Heavily inspired by the drivers/net/fs_enet driver + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#ifndef PCINET_H +#define PCINET_H + +//#define PH_MAX_MTU (1508) +//#define PH_MAX_MTU (4082) +//#define PH_MAX_MTU (8178) +//#define PH_MAX_MTU (16370) +//#define PH_MAX_MTU (32754) +#define PH_MAX_MTU (65522) +//#define PH_MAX_MTU (131058) +#define PH_MAX_FRSIZE (PH_MAX_MTU+ETHER_HDR_SIZE) + +#define PH_RING_SIZE 64 + +struct circ_buf_desc { + u32 sc; + u32 len; + u32 addr; +} __attribute__((__packed__)); +typedef struct circ_buf_desc cbd_t; + +/* Buffer Descriptor Accessors */ +#define CBDW_SC(_cbd, _sc) out_le32((volatile u32 *)&(_cbd)->sc, (_sc)) +#define CBDW_LEN(_cbd, _len) out_le32((volatile u32 *)&(_cbd)->len, (_len)) +#define CBDW_ADDR(_cbd, _addr) out_le32((volatile u32 *)&(_cbd)->addr, (_addr)) + +#define CBDR_SC(_cbd) in_le32((volatile u32 *)&(_cbd)->sc) +#define CBDR_LEN(_cbd) in_le32((volatile u32 *)&(_cbd)->len) +#define CBDR_ADDR(_cbd) in_le32((volatile u32 *)&(_cbd)->addr) + +/* Buffer Descriptor Registers */ +#define PCINET_TXBD_BASE 0x400 +#define PCINET_RXBD_BASE 0x800 + +/* Buffer Descriptor Status */ +#define BD_MEM_READY 0x1 +#define BD_MEM_DIRTY 0x2 +#define BD_MEM_FREE 0x3 + +#define PCINET_UART_RX_ENABLED (1<<0) +#define PCINET_NET_STATUS_RUNNING (1<<1) +#define PCINET_NET_RXINT_OFF (1<<2) +#define PCINET_NET_REGISTERS_VALID (1<<3) + +/* Driver State Bits */ +#define NET_STATE_STOPPED 0 +#define NET_STATE_RUNNING 1 + +/* Doorbell Registers */ +#define UART_RX_READY_DBELL (1<<0) +#define UART_TX_EMPTY_DBELL (1<<1) +#define NET_RX_PACKET_DBELL (1<<2) +#define NET_TX_COMPLETE_DBELL (1<<3) +#define NET_START_REQ_DBELL (1<<4) +#define NET_START_ACK_DBELL (1<<5) +#define NET_STOP_REQ_DBELL (1<<6) +#define NET_STOP_ACK_DBELL (1<<7) + +#endif /* PCINET_H */ + +/* vim: set ts=8 sts=8 sw=8 noet tw=92: */
The two U-Boot patches (one for ethernet, one for serial) were inlined into my last message to this thread. I haven't changed them since that post.
I've inlined the Linux patch below. I've posted it to the lkml, linux-netdev, and linux-ppcdev lists, but I haven't gotten much feedback other than "Wow, that's cool. We could really use that." I'm not sure if nobody is interested, or if they are just ignoring me.
Ira
From 09357d1cfa4664f1c50aa6becb6ccbf8aecc28e1 Mon Sep 17 00:00:00 2001
From: Ira W. Snyder iws@ovro.caltech.edu Date: Thu, 16 Oct 2008 16:04:06 -0700 Subject: [PATCH] net: add PCINet driver
This adds support to Linux for a virtual ethernet interface which uses the PCI bus as its transport mechanism. It creates a simple, familiar, and fast method of communication for two devices connected by a PCI interface.
I have implemented client support for the Freescale MPC8349EMDS board, which is capable of running in PCI Agent mode (It acts like a PCI card, but is a complete PowerPC computer, running Linux). It is almost certainly trivially ported to any MPC83xx system.
It was developed to work in a CompactPCI crate of computers, one of which is a relatively standard x86 system (acting as the host) and many PowerPC systems (acting as clients).
RFC v2 -> RFC v3pre: * replace typedef cbd_t with struct circ_buf_desc * use get_immrbase() to get IMMR register offsets
RFC v1 -> RFC v2: * remove vim modelines * use net_device->name in request_irq(), for irqbalance * remove unneccesary wqt_get_stats(), use default get_stats() instead * use dev_printk() and friends * add message unit to MPC8349EMDS dts file
Signed-off-by: Ira W. Snyder iws@ovro.caltech.edu --- arch/powerpc/boot/dts/mpc834x_mds.dts | 7 + drivers/net/Kconfig | 34 + drivers/net/Makefile | 3 + drivers/net/pcinet.h | 74 ++ drivers/net/pcinet_fsl.c | 1354 ++++++++++++++++++++++++++++++++ drivers/net/pcinet_host.c | 1383 +++++++++++++++++++++++++++++++++ drivers/net/pcinet_hw.h | 77 ++ 7 files changed, 2932 insertions(+), 0 deletions(-) create mode 100644 drivers/net/pcinet.h create mode 100644 drivers/net/pcinet_fsl.c create mode 100644 drivers/net/pcinet_host.c create mode 100644 drivers/net/pcinet_hw.h
diff --git a/arch/powerpc/boot/dts/mpc834x_mds.dts b/arch/powerpc/boot/dts/mpc834x_mds.dts index c986c54..3bc8975 100644 --- a/arch/powerpc/boot/dts/mpc834x_mds.dts +++ b/arch/powerpc/boot/dts/mpc834x_mds.dts @@ -104,6 +104,13 @@ mode = "cpu"; };
+ message-unit@8030 { + compatible = "fsl,mpc8349-mu"; + reg = <0x8030 0xd0>; + interrupts = <69 0x8>; + interrupt-parent = <&ipic>; + }; + dma@82a8 { #address-cells = <1>; #size-cells = <1>; diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index f749b40..eef7af7 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -2279,6 +2279,40 @@ config UGETH_TX_ON_DEMAND bool "Transmit on Demand support" depends on UCC_GETH
+config PCINET_FSL + tristate "PCINet Virtual Ethernet over PCI support (Freescale)" + depends on MPC834x_MDS && !PCI + select DMA_ENGINE + select FSL_DMA + help + When running as a PCI Agent, this driver will create a virtual + ethernet link running over the PCI bus, allowing simplified + communication with the host system. The host system will need + to use the corresponding driver. + + If in doubt, say N. + +config PCINET_HOST + tristate "PCINet Virtual Ethernet over PCI support (Host)" + depends on PCI + help + This driver will let you communicate with a PCINet client device + using a virtual ethernet link running over the PCI bus. This + allows simplified communication with the client system. + + This is inteded for use in a system that has a crate full of + computers running Linux, all connected by a PCI backplane. + + If in doubt, say N. + +config PCINET_DISABLE_CHECKSUM + bool "Disable packet checksumming" + depends on PCINET_FSL || PCINET_HOST + default n + help + Disable packet checksumming on packets received by the PCINet + driver. This gives a possible speed boost. + config MV643XX_ETH tristate "Marvell Discovery (643XX) and Orion ethernet support" depends on MV64360 || MV64X60 || (PPC_MULTIPLATFORM && PPC32) || PLAT_ORION diff --git a/drivers/net/Makefile b/drivers/net/Makefile index f19acf8..c6fbafc 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -30,6 +30,9 @@ gianfar_driver-objs := gianfar.o \ obj-$(CONFIG_UCC_GETH) += ucc_geth_driver.o ucc_geth_driver-objs := ucc_geth.o ucc_geth_mii.o ucc_geth_ethtool.o
+obj-$(CONFIG_PCINET_FSL) += pcinet_fsl.o +obj-$(CONFIG_PCINET_HOST) += pcinet_host.o + # # link order important here # diff --git a/drivers/net/pcinet.h b/drivers/net/pcinet.h new file mode 100644 index 0000000..054a0ee --- /dev/null +++ b/drivers/net/pcinet.h @@ -0,0 +1,74 @@ +/* + * Shared Definitions for the PCINet / PCISerial drivers + * + * Copyright (c) 2008 Ira W. Snyder iws@ovro.caltech.edu + * + * Heavily inspired by the drivers/net/fs_enet driver + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#ifndef PCINET_H +#define PCINET_H + +#include <linux/kernel.h> +#include <linux/if_ether.h> + +/* Ring and Frame size -- these must match between the drivers */ +#define PH_RING_SIZE (64) +#define PH_MAX_FRSIZE (64 * 1024) +#define PH_MAX_MTU (PH_MAX_FRSIZE - ETH_HLEN) + +struct circ_buf_desc { + __le32 sc; + __le32 len; + __le32 addr; +} __attribute__((__packed__)); + +/* Buffer Descriptor Accessors */ +#define CBDW_SC(_cbd, _sc) iowrite32((_sc), &(_cbd)->sc) +#define CBDW_LEN(_cbd, _len) iowrite32((_len), &(_cbd)->len) +#define CBDW_ADDR(_cbd, _addr) iowrite32((_addr), &(_cbd)->addr) + +#define CBDR_SC(_cbd) ioread32(&(_cbd)->sc) +#define CBDR_LEN(_cbd) ioread32(&(_cbd)->len) +#define CBDR_ADDR(_cbd) ioread32(&(_cbd)->addr) + +/* Buffer Descriptor Registers */ +#define PCINET_TXBD_BASE 0x400 +#define PCINET_RXBD_BASE 0x800 + +/* Buffer Descriptor Status */ +#define BD_MEM_READY 0x1 +#define BD_MEM_DIRTY 0x2 +#define BD_MEM_FREE 0x3 + +/* IMMR Accessor Helpers */ +#define IMMR_R32(_off) ioread32(priv->immr+(_off)) +#define IMMR_W32(_off, _val) iowrite32((_val), priv->immr+(_off)) +#define IMMR_R32BE(_off) ioread32be(priv->immr+(_off)) +#define IMMR_W32BE(_off, _val) iowrite32be((_val), priv->immr+(_off)) + +/* Status Register Bits */ +#define PCINET_UART_RX_ENABLED (1<<0) +#define PCINET_NET_STATUS_RUNNING (1<<1) +#define PCINET_NET_RXINT_OFF (1<<2) +#define PCINET_NET_REGISTERS_VALID (1<<3) + +/* Driver State Bits */ +#define NET_STATE_STOPPED 0 +#define NET_STATE_RUNNING 1 + +/* Doorbell Registers */ +#define UART_RX_READY_DBELL (1<<0) +#define UART_TX_EMPTY_DBELL (1<<1) +#define NET_RX_PACKET_DBELL (1<<2) +#define NET_TX_COMPLETE_DBELL (1<<3) +#define NET_START_REQ_DBELL (1<<4) +#define NET_START_ACK_DBELL (1<<5) +#define NET_STOP_REQ_DBELL (1<<6) +#define NET_STOP_ACK_DBELL (1<<7) + +#endif /* PCINET_H */ diff --git a/drivers/net/pcinet_fsl.c b/drivers/net/pcinet_fsl.c new file mode 100644 index 0000000..a6262fe --- /dev/null +++ b/drivers/net/pcinet_fsl.c @@ -0,0 +1,1354 @@ +/* + * PCINet and PCISerial Driver for Freescale MPC8349EMDS + * + * Copyright (c) 2008 Ira W. Snyder iws@ovro.caltech.edu + * + * Heavily inspired by the drivers/net/fs_enet driver + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#include <linux/kernel.h> +#include <linux/module.h> +#include <linux/init.h> +#include <linux/of_platform.h> +#include <linux/sched.h> +#include <linux/wait.h> +#include <linux/interrupt.h> +#include <linux/irqreturn.h> +#include <linux/delay.h> +#include <linux/io.h> +#include <linux/serial.h> +#include <linux/serial_core.h> +#include <linux/etherdevice.h> +#include <linux/mutex.h> +#include <linux/dmaengine.h> + +/* MPC8349EMDS specific get_immrbase() */ +#include <sysdev/fsl_soc.h> + +#include "pcinet.h" +#include "pcinet_hw.h" + +static const char driver_name[] = "wqt"; + +static void wqtuart_rx_char(struct uart_port *port, const char ch); +static void wqtuart_stop_tx(struct uart_port *port); + +struct wqt_dev; +typedef void (*wqt_irqhandler_t)(struct wqt_dev *); + +struct wqt_irqhandlers { + wqt_irqhandler_t net_start_req_handler; + wqt_irqhandler_t net_start_ack_handler; + wqt_irqhandler_t net_stop_req_handler; + wqt_irqhandler_t net_stop_ack_handler; + wqt_irqhandler_t net_rx_packet_handler; + wqt_irqhandler_t net_tx_complete_handler; + wqt_irqhandler_t uart_rx_ready_handler; + wqt_irqhandler_t uart_tx_empty_handler; +}; + +struct wqt_dev { + /*--------------------------------------------------------------------*/ + /* OpenFirmware Infrastructure */ + /*--------------------------------------------------------------------*/ + struct of_device *op; + struct device *dev; + int irq; + void __iomem *immr; + + struct mutex irq_mutex; + int interrupt_count; + + spinlock_t irq_lock; + struct wqt_irqhandlers handlers; + + /*--------------------------------------------------------------------*/ + /* UART Device Infrastructure */ + /*--------------------------------------------------------------------*/ + struct uart_port port; + bool uart_rx_enabled; + bool uart_open; + + struct workqueue_struct *wq; + struct work_struct uart_tx_work; + wait_queue_head_t uart_tx_wait; /* sleep for uart_tx_ready */ + bool uart_tx_ready; /* transmitter state */ + + /*--------------------------------------------------------------------*/ + /* Ethernet Device Infrastructure */ + /*--------------------------------------------------------------------*/ + struct net_device *ndev; + void __iomem *netregs; + dma_addr_t netregs_addr; + + /* Outstanding SKB */ + struct sk_buff *tx_skbs[PH_RING_SIZE]; + + /* Circular Buffer Descriptor base */ + struct circ_buf_desc __iomem *rx_base; + struct circ_buf_desc __iomem *tx_base; + + /* Current SKB index */ + struct circ_buf_desc __iomem *cur_rx; + struct circ_buf_desc __iomem *cur_tx; + struct circ_buf_desc __iomem *dirty_tx; + int tx_free; + + struct tasklet_struct tx_complete_tasklet; + spinlock_t net_lock; + + struct mutex net_mutex; + int net_state; + struct work_struct net_start_work; + struct work_struct net_stop_work; + struct completion net_start_completion; + struct completion net_stop_completion; + struct napi_struct napi; + + struct dma_client client; + struct dma_chan *chan; +}; + +/*----------------------------------------------------------------------------*/ +/* Status Register Helper Operations */ +/*----------------------------------------------------------------------------*/ + +static DEFINE_SPINLOCK(status_lock); + +static void wqtstatus_setbit(struct wqt_dev *priv, u32 bit) +{ + unsigned long flags; + + spin_lock_irqsave(&status_lock, flags); + IMMR_W32(OMR1_OFFSET, IMMR_R32(OMR1_OFFSET) | bit); + spin_unlock_irqrestore(&status_lock, flags); +} + +static void wqtstatus_clrbit(struct wqt_dev *priv, u32 bit) +{ + unsigned long flags; + + spin_lock_irqsave(&status_lock, flags); + IMMR_W32(OMR1_OFFSET, IMMR_R32(OMR1_OFFSET) & ~bit); + spin_unlock_irqrestore(&status_lock, flags); +} + +static int wqtstatus_remote_testbit(struct wqt_dev *priv, u32 bit) +{ + return IMMR_R32(IMR1_OFFSET) & bit; +} + +/*----------------------------------------------------------------------------*/ +/* Message Sending and Processing Operations */ +/*----------------------------------------------------------------------------*/ + +static irqreturn_t wqt_interrupt(int irq, void *dev_id) +{ + struct wqt_dev *priv = dev_id; + u32 imisr, idr; + unsigned long flags; + + imisr = IMMR_R32(IMISR_OFFSET); + idr = IMMR_R32(IDR_OFFSET); + + if (!(imisr & 0x8)) + return IRQ_NONE; + + /* Clear all of the interrupt sources, we'll handle them next */ + IMMR_W32(IDR_OFFSET, idr); + + /* Lock over all of the handlers, so they cannot get called when + * the code doesn't expect them to be called */ + spin_lock_irqsave(&priv->irq_lock, flags); + + if (idr & UART_RX_READY_DBELL) + priv->handlers.uart_rx_ready_handler(priv); + + if (idr & UART_TX_EMPTY_DBELL) + priv->handlers.uart_tx_empty_handler(priv); + + if (idr & NET_RX_PACKET_DBELL) + priv->handlers.net_rx_packet_handler(priv); + + if (idr & NET_TX_COMPLETE_DBELL) + priv->handlers.net_tx_complete_handler(priv); + + if (idr & NET_START_REQ_DBELL) + priv->handlers.net_start_req_handler(priv); + + if (idr & NET_START_ACK_DBELL) + priv->handlers.net_start_ack_handler(priv); + + if (idr & NET_STOP_REQ_DBELL) + priv->handlers.net_stop_req_handler(priv); + + if (idr & NET_STOP_ACK_DBELL) + priv->handlers.net_stop_ack_handler(priv); + + spin_unlock_irqrestore(&priv->irq_lock, flags); + + return IRQ_HANDLED; +} + +/* Send a character through the mbox when it becomes available + * Blocking, must not be called with any spinlocks held */ +static int do_send_message(struct wqt_dev *priv, const char ch) +{ + struct uart_port *port = &priv->port; + bool tmp; + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + while (priv->uart_tx_ready != true) { + spin_unlock_irqrestore(&priv->irq_lock, flags); + wait_event_timeout(priv->uart_tx_wait, priv->uart_tx_ready, HZ); + + spin_lock_irqsave(&port->lock, flags); + tmp = priv->uart_open; + spin_unlock_irqrestore(&port->lock, flags); + + if (!tmp) + return -EIO; + + spin_lock_irqsave(&priv->irq_lock, flags); + } + + /* Now the transmitter is free, send the message */ + IMMR_W32(OMR0_OFFSET, ch); + IMMR_W32(ODR_OFFSET, UART_RX_READY_DBELL); + + /* Mark the transmitter busy */ + priv->uart_tx_ready = false; + spin_unlock_irqrestore(&priv->irq_lock, flags); + return 0; +} + +/* Grab a character out of the uart tx buffer and send it */ +static void uart_tx_work_fn(struct work_struct *work) +{ + struct wqt_dev *priv = container_of(work, struct wqt_dev, uart_tx_work); + struct uart_port *port = &priv->port; + struct circ_buf *xmit = &port->info->xmit; + char ch; + unsigned long flags; + + spin_lock_irqsave(&port->lock, flags); + while (true) { + + /* Check for XON/XOFF (high priority) */ + if (port->x_char) { + ch = port->x_char; + port->x_char = 0; + spin_unlock_irqrestore(&port->lock, flags); + + if (do_send_message(priv, ch)) + return; + + spin_lock_irqsave(&port->lock, flags); + continue; + } + + /* If we're out of chars or the port is stopped, we're done */ + if (uart_circ_empty(xmit) || uart_tx_stopped(port)) { + wqtuart_stop_tx(port); + break; + } + + /* Grab the next char out of the buffer and send it */ + ch = xmit->buf[xmit->tail]; + xmit->tail = (xmit->tail + 1) & (UART_XMIT_SIZE - 1); + spin_unlock_irqrestore(&port->lock, flags); + + if (do_send_message(priv, ch)) + return; + + spin_lock_irqsave(&port->lock, flags); + } + + if (uart_circ_chars_pending(xmit) < WAKEUP_CHARS) + uart_write_wakeup(port); + + if (uart_circ_empty(xmit)) + wqtuart_stop_tx(port); + + spin_unlock_irqrestore(&port->lock, flags); +} + +/*----------------------------------------------------------------------------*/ +/* Interrupt Handlers */ +/*----------------------------------------------------------------------------*/ + +/* NOTE: All handlers are called with priv->irq_lock held */ + +static void empty_handler(struct wqt_dev *priv) +{ + /* Intentionally left empty */ +} + +static void net_start_req_handler(struct wqt_dev *priv) +{ + schedule_work(&priv->net_start_work); +} + +static void net_start_ack_handler(struct wqt_dev *priv) +{ + complete(&priv->net_start_completion); +} + +static void net_stop_req_handler(struct wqt_dev *priv) +{ + schedule_work(&priv->net_stop_work); +} + +static void net_stop_ack_handler(struct wqt_dev *priv) +{ + complete(&priv->net_stop_completion); +} + +static void net_tx_complete_handler(struct wqt_dev *priv) +{ + tasklet_schedule(&priv->tx_complete_tasklet); +} + +static void net_rx_packet_handler(struct wqt_dev *priv) +{ + wqtstatus_setbit(priv, PCINET_NET_RXINT_OFF); + netif_rx_schedule(priv->ndev, &priv->napi); +} + +static void uart_rx_ready_handler(struct wqt_dev *priv) +{ + wqtuart_rx_char(&priv->port, IMMR_R32(IMR0_OFFSET) & 0xff); + IMMR_W32(ODR_OFFSET, UART_TX_EMPTY_DBELL); +} + +static void uart_tx_empty_handler(struct wqt_dev *priv) +{ + priv->uart_tx_ready = true; + wake_up(&priv->uart_tx_wait); +} + +/*----------------------------------------------------------------------------*/ +/* Interrupt Request / Free Helpers */ +/*----------------------------------------------------------------------------*/ + +static void do_enable_net_startstop_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.net_start_req_handler = net_start_req_handler; + priv->handlers.net_start_ack_handler = net_start_ack_handler; + priv->handlers.net_stop_req_handler = net_stop_req_handler; + priv->handlers.net_stop_ack_handler = net_stop_ack_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); + + wqtstatus_setbit(priv, PCINET_NET_STATUS_RUNNING); +} + +static void do_disable_net_startstop_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + wqtstatus_clrbit(priv, PCINET_NET_STATUS_RUNNING); + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.net_start_req_handler = empty_handler; + priv->handlers.net_start_ack_handler = empty_handler; + priv->handlers.net_stop_req_handler = empty_handler; + priv->handlers.net_stop_ack_handler = empty_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static void do_enable_net_rxtx_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.net_rx_packet_handler = net_rx_packet_handler; + priv->handlers.net_tx_complete_handler = net_tx_complete_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static void do_disable_net_rxtx_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.net_rx_packet_handler = empty_handler; + priv->handlers.net_tx_complete_handler = empty_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static void do_enable_uart_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.uart_rx_ready_handler = uart_rx_ready_handler; + priv->handlers.uart_tx_empty_handler = uart_tx_empty_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static void do_disable_uart_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.uart_rx_ready_handler = empty_handler; + priv->handlers.uart_tx_empty_handler = empty_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static int wqt_request_irq(struct wqt_dev *priv) +{ + int ret = 0; + + mutex_lock(&priv->irq_mutex); + + if (priv->interrupt_count > 0) + goto out_unlock; + + /* Force all handlers to be disabled before attaching the handler */ + do_disable_net_startstop_handlers(priv); + do_disable_net_rxtx_handlers(priv); + do_disable_uart_handlers(priv); + + ret = request_irq(priv->irq, + wqt_interrupt, + IRQF_SHARED, + priv->ndev->name, + priv); + +out_unlock: + priv->interrupt_count++; + mutex_unlock(&priv->irq_mutex); + + return ret; +} + +static void wqt_free_irq(struct wqt_dev *priv) +{ + mutex_lock(&priv->irq_mutex); + priv->interrupt_count--; + + if (priv->interrupt_count > 0) + goto out_unlock; + + free_irq(priv->irq, priv); + +out_unlock: + mutex_unlock(&priv->irq_mutex); +} + +/*----------------------------------------------------------------------------*/ +/* Network Startup and Shutdown Helpers */ +/*----------------------------------------------------------------------------*/ + +/* NOTE: All helper functions prefixed with "do" must be called only from + * process context, with priv->net_mutex held. They are expected to sleep */ + +static void do_net_start_queues(struct wqt_dev *priv) +{ + if (priv->net_state == NET_STATE_RUNNING) + return; + + dev_dbg(priv->dev, "resetting buffer positions\n"); + priv->cur_rx = priv->rx_base; + priv->cur_tx = priv->tx_base; + priv->dirty_tx = priv->tx_base; + priv->tx_free = PH_RING_SIZE; + + dev_dbg(priv->dev, "enabling NAPI queue\n"); + napi_enable(&priv->napi); + + dev_dbg(priv->dev, "enabling tx_complete() tasklet\n"); + tasklet_enable(&priv->tx_complete_tasklet); + + dev_dbg(priv->dev, "enabling TX queue\n"); + netif_start_queue(priv->ndev); + + dev_dbg(priv->dev, "carrier on!\n"); + netif_carrier_on(priv->ndev); + + /* Enable the RX_PACKET and TX_COMPLETE interrupt handlers */ + do_enable_net_rxtx_handlers(priv); + + priv->net_state = NET_STATE_RUNNING; +} + +static void do_net_stop_queues(struct wqt_dev *priv) +{ + if (priv->net_state == NET_STATE_STOPPED) + return; + + /* Disable the RX_PACKET and TX_COMPLETE interrupt handlers */ + do_disable_net_rxtx_handlers(priv); + + dev_dbg(priv->dev, "disabling NAPI queue\n"); + napi_disable(&priv->napi); + + dev_dbg(priv->dev, "disabling tx_complete() tasklet\n"); + tasklet_disable(&priv->tx_complete_tasklet); + + dev_dbg(priv->dev, "disabling TX queue\n"); + netif_tx_disable(priv->ndev); + + dev_dbg(priv->dev, "carrier off!\n"); + netif_carrier_off(priv->ndev); + + priv->net_state = NET_STATE_STOPPED; +} + +/* Called when we get a request to start our queues and acknowledge */ +static void wqtnet_start_work_fn(struct work_struct *work) +{ + struct wqt_dev *priv = container_of(work, struct wqt_dev, + net_start_work); + + mutex_lock(&priv->net_mutex); + + do_net_start_queues(priv); + IMMR_W32(ODR_OFFSET, NET_START_ACK_DBELL); + + mutex_unlock(&priv->net_mutex); +} + +/* Called when we get a request to stop our queues and acknowledge */ +static void wqtnet_stop_work_fn(struct work_struct *work) +{ + struct wqt_dev *priv = container_of(work, struct wqt_dev, + net_stop_work); + + mutex_lock(&priv->net_mutex); + + do_net_stop_queues(priv); + IMMR_W32(ODR_OFFSET, NET_STOP_ACK_DBELL); + + mutex_unlock(&priv->net_mutex); +} + +/*----------------------------------------------------------------------------*/ +/* DMA Operation Helpers */ +/*----------------------------------------------------------------------------*/ + +/* Setup a static 1GB window starting at PCI address 0x0 + * + * This means that all DMA must be within the first 1GB of the other side's + * memory, which shouldn't be a problem + */ +static int wqtdma_setup_outbound_window(struct wqt_dev *priv) +{ + IMMR_W32BE(LAWAR0_OFFSET, LAWAR0_ENABLE | 0x1d); + IMMR_W32BE(POCMR0_OFFSET, POCMR0_ENABLE | 0xc0000); + IMMR_W32BE(POTAR0_OFFSET, 0x0); + + return 0; +} + +static enum dma_state_client dmatest_event(struct dma_client *client, + struct dma_chan *chan, + enum dma_state state) +{ + struct wqt_dev *priv = container_of(client, struct wqt_dev, client); + enum dma_state_client ack = DMA_NAK; + + switch (state) { + case DMA_RESOURCE_AVAILABLE: + if (chan == priv->chan) + ack = DMA_DUP; + else if (priv->chan) + ack = DMA_NAK; + else { + priv->chan = chan; + ack = DMA_ACK; + } + + break; + + case DMA_RESOURCE_REMOVED: + priv->chan = NULL; + ack = DMA_ACK; + break; + + default: + dev_dbg(priv->dev, "unhandled DMA event %u (%s)\n", + state, chan->dev.bus_id); + break; + } + + return ack; +} + +static dma_cookie_t dma_async_memcpy_raw_to_buf(struct dma_chan *chan, + void *dest, + dma_addr_t src, + size_t len) +{ + struct dma_device *dev = chan->device; + struct dma_async_tx_descriptor *tx; + dma_addr_t dma_dest, dma_src; + dma_cookie_t cookie; + int cpu; + + dma_src = src; + dma_dest = dma_map_single(dev->dev, dest, len, DMA_FROM_DEVICE); + tx = dev->device_prep_dma_memcpy(chan, dma_dest, dma_src, len, + DMA_CTRL_ACK); + + if (!tx) { + dma_unmap_single(dev->dev, dma_dest, len, DMA_FROM_DEVICE); + return -ENOMEM; + } + + tx->callback = NULL; + cookie = tx->tx_submit(tx); + + cpu = get_cpu(); + per_cpu_ptr(chan->local, cpu)->bytes_transferred += len; + per_cpu_ptr(chan->local, cpu)->memcpy_count++; + put_cpu(); + + return cookie; +} + +static dma_cookie_t dma_async_memcpy_buf_to_raw(struct dma_chan *chan, + dma_addr_t dest, + void *src, + size_t len) +{ + struct dma_device *dev = chan->device; + struct dma_async_tx_descriptor *tx; + dma_addr_t dma_dest, dma_src; + dma_cookie_t cookie; + int cpu; + + dma_src = dma_map_single(dev->dev, src, len, DMA_TO_DEVICE); + dma_dest = dest; + tx = dev->device_prep_dma_memcpy(chan, dma_dest, dma_src, len, + DMA_CTRL_ACK); + + if (!tx) { + dma_unmap_single(dev->dev, dma_src, len, DMA_TO_DEVICE); + return -ENOMEM; + } + + tx->callback = NULL; + cookie = tx->tx_submit(tx); + + cpu = get_cpu(); + per_cpu_ptr(chan->local, cpu)->bytes_transferred += len; + per_cpu_ptr(chan->local, cpu)->memcpy_count++; + put_cpu(); + + return cookie; +} + +/*----------------------------------------------------------------------------*/ +/* Network Device Operations */ +/*----------------------------------------------------------------------------*/ + +static int wqt_open(struct net_device *dev) +{ + struct wqt_dev *priv = netdev_priv(dev); + int ret; + + /* Pretend the cable is unplugged until we are up and running */ + netif_carrier_off(dev); + + mutex_lock(&priv->net_mutex); + + ret = wqt_request_irq(priv); + + if (ret) + goto out_unlock; + + /* Enable only the network start/stop interrupts */ + do_enable_net_startstop_handlers(priv); + + /* Check if the other side is running, if not, it will start us. + * Without the interrupt handler installed, there's no way it can + * respond to us anyway */ + if (!wqtstatus_remote_testbit(priv, PCINET_NET_STATUS_RUNNING)) { + ret = 0; + goto out_unlock; + } + + IMMR_W32(ODR_OFFSET, NET_START_REQ_DBELL); + ret = wait_for_completion_timeout(&priv->net_start_completion, 5*HZ); + + if (!ret) { + /* Our start request timed out, therefore, the other + * side will start us when it comes back up */ + dev_dbg(priv->dev, "start timed out\n"); + } else { + do_net_start_queues(priv); + ret = 0; + } + +out_unlock: + mutex_unlock(&priv->net_mutex); + return ret; +} + +static int wqt_stop(struct net_device *dev) +{ + struct wqt_dev *priv = netdev_priv(dev); + int ret; + + mutex_lock(&priv->net_mutex); + + do_net_stop_queues(priv); + + IMMR_W32(ODR_OFFSET, NET_STOP_REQ_DBELL); + ret = wait_for_completion_timeout(&priv->net_stop_completion, 5*HZ); + + if (!ret) + dev_warn(priv->dev, "other side did not stop on time!\n"); + else + ret = 0; + + do_disable_net_startstop_handlers(priv); + wqt_free_irq(priv); + + mutex_unlock(&priv->net_mutex); + return 0; +} + +static int wqt_change_mtu(struct net_device *dev, int new_mtu) +{ + if ((new_mtu < 68) || (new_mtu > PH_MAX_MTU)) + return -EINVAL; + + dev->mtu = new_mtu; + return 0; +} + +static int wqt_hard_start_xmit(struct sk_buff *skb, struct net_device *dev) +{ + struct wqt_dev *priv = netdev_priv(dev); + dma_cookie_t cookie; + enum dma_status status; + struct circ_buf_desc __iomem *bdp; + int dirty_idx; + + spin_lock_bh(&priv->net_lock); + + bdp = priv->cur_tx; + dirty_idx = bdp - priv->tx_base; + + /* This should not happen, the queue should be stopped */ + if (priv->tx_free == 0 || CBDR_SC(bdp) != BD_MEM_READY) { + netif_stop_queue(dev); + spin_unlock_bh(&priv->net_lock); + return NETDEV_TX_BUSY; + } + + cookie = dma_async_memcpy_buf_to_raw(priv->chan, + (dma_addr_t)(0x80000000 + CBDR_ADDR(bdp)), + skb->data, + skb->len); + + if (dma_submit_error(cookie)) { + dev_warn(priv->dev, "DMA submit error\n"); + spin_unlock_bh(&priv->net_lock); + return -ENOMEM; + } + + status = dma_sync_wait(priv->chan, cookie); + + if (status == DMA_ERROR) { + dev_warn(priv->dev, "DMA error\n"); + spin_unlock_bh(&priv->net_lock); + return -EIO; + } + + CBDW_LEN(bdp, skb->len); + CBDW_SC(bdp, BD_MEM_DIRTY); + + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->tx_base; + else + bdp++; + + priv->tx_skbs[dirty_idx] = skb; + priv->cur_tx = bdp; + priv->tx_free--; + dev->trans_start = jiffies; + + if (priv->tx_free == 0) + netif_stop_queue(dev); + + if (!wqtstatus_remote_testbit(priv, PCINET_NET_RXINT_OFF)) + IMMR_W32(ODR_OFFSET, NET_RX_PACKET_DBELL); + + spin_unlock_bh(&priv->net_lock); + return NETDEV_TX_OK; +} + +static void wqt_tx_timeout(struct net_device *dev) +{ + struct wqt_dev *priv = netdev_priv(dev); + + dev->stats.tx_errors++; + IMMR_W32(ODR_OFFSET, NET_RX_PACKET_DBELL); +} + +static void wqt_tx_complete(unsigned long data) +{ + struct net_device *dev = (struct net_device *)data; + struct wqt_dev *priv = netdev_priv(dev); + struct sk_buff *skb; + struct circ_buf_desc __iomem *bdp; + int do_wake, dirty_idx; + + spin_lock_bh(&priv->net_lock); + + bdp = priv->dirty_tx; + do_wake = 0; + + while (CBDR_SC(bdp) == BD_MEM_FREE) { + dirty_idx = bdp - priv->tx_base; + + skb = priv->tx_skbs[dirty_idx]; + + BUG_ON(skb == NULL); + + dev->stats.tx_bytes += skb->len; + dev->stats.tx_packets++; + + dev_kfree_skb_irq(skb); + + priv->tx_skbs[dirty_idx] = NULL; + + /* Mark the BDP as ready */ + CBDW_SC(bdp, BD_MEM_READY); + + /* Update the bdp */ + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->tx_base; + else + bdp++; + + if (!priv->tx_free++) + do_wake = 1; + } + + priv->dirty_tx = bdp; + + spin_unlock_bh(&priv->net_lock); + + if (do_wake) + netif_wake_queue(dev); +} + +static int wqt_rx_napi(struct napi_struct *napi, int budget) +{ + struct wqt_dev *priv = container_of(napi, struct wqt_dev, napi); + struct net_device *dev = priv->ndev; + int received = 0; + struct sk_buff *skb; + dma_addr_t remote_addr; + dma_cookie_t cookie; + enum dma_status status; + int pkt_len, dirty_idx; + struct circ_buf_desc __iomem *bdp; + + bdp = priv->cur_rx; + + while (CBDR_SC(bdp) == BD_MEM_DIRTY) { + dirty_idx = bdp - priv->rx_base; + + pkt_len = CBDR_LEN(bdp); + remote_addr = CBDR_ADDR(bdp); + + /* Allocate a packet for the data */ + skb = dev_alloc_skb(pkt_len + NET_IP_ALIGN); + + if (skb == NULL) { + dev->stats.rx_dropped++; + goto out_err; + } + + skb_reserve(skb, NET_IP_ALIGN); + + cookie = dma_async_memcpy_raw_to_buf(priv->chan, + skb->data, + (dma_addr_t)(0x80000000 + remote_addr), + pkt_len); + + if (dma_submit_error(cookie)) { + dev_warn(priv->dev, "DMA submit error\n"); + dev_kfree_skb_irq(skb); + dev->stats.rx_dropped++; + goto out_err; + } + + status = dma_sync_wait(priv->chan, cookie); + + if (status == DMA_ERROR) { + dev_warn(priv->dev, "DMA error\n"); + dev_kfree_skb_irq(skb); + dev->stats.rx_dropped++; + goto out_err; + } + + /* Push the packet into the network stack */ + skb_put(skb, pkt_len); + skb->protocol = eth_type_trans(skb, dev); +#ifdef CONFIG_PCINET_DISABLE_CHECKSUM + skb->ip_summed = CHECKSUM_UNNECESSARY; +#else + skb->ip_summed = CHECKSUM_NONE; +#endif + netif_receive_skb(skb); + received++; + dev->stats.rx_bytes += pkt_len; + dev->stats.rx_packets++; + +out_err: + CBDW_SC(bdp, BD_MEM_FREE); + + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->rx_base; + else + bdp++; + + if (received >= budget) + break; + } + + priv->cur_rx = bdp; + + /* We have processed all packets that the adapter had, but it + * was less than our budget, stop polling */ + if (received < budget) { + netif_rx_complete(dev, napi); + wqtstatus_clrbit(priv, PCINET_NET_RXINT_OFF); + } + + IMMR_W32(ODR_OFFSET, NET_TX_COMPLETE_DBELL); + + return received; +} + +/*----------------------------------------------------------------------------*/ +/* UART Device Operations */ +/*----------------------------------------------------------------------------*/ + +static unsigned int wqtuart_tx_empty(struct uart_port *port) +{ + return TIOCSER_TEMT; +} + +static void wqtuart_set_mctrl(struct uart_port *port, unsigned int mctrl) +{ +} + +static unsigned int wqtuart_get_mctrl(struct uart_port *port) +{ + return TIOCM_CAR | TIOCM_DSR | TIOCM_CTS; +} + +static void wqtuart_stop_tx(struct uart_port *port) +{ +} + +static void wqtuart_start_tx(struct uart_port *port) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + + queue_work(priv->wq, &priv->uart_tx_work); +} + +static void wqtuart_stop_rx(struct uart_port *port) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + + do_disable_uart_handlers(priv); + priv->uart_rx_enabled = false; + wqtstatus_clrbit(priv, PCINET_UART_RX_ENABLED); +} + +static void wqtuart_enable_ms(struct uart_port *port) +{ +} + +static void wqtuart_break_ctl(struct uart_port *port, int break_state) +{ +} + +static int wqtuart_startup(struct uart_port *port) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + int ret; + + ret = wqt_request_irq(priv); + + if (ret) + return ret; + + do_enable_uart_handlers(priv); + + /* Mark the transmitter and receiver ready */ + priv->uart_tx_ready = true; + priv->uart_rx_enabled = true; + wqtstatus_setbit(priv, PCINET_UART_RX_ENABLED); + + /* Let the other side know that we are ready to receive chars now */ + IMMR_W32(ODR_OFFSET, UART_TX_EMPTY_DBELL); + priv->uart_open = true; + return 0; +} + +static void wqtuart_shutdown(struct uart_port *port) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + + wqt_free_irq(priv); + + /* Make sure the uart_tx_work_fn() exits cleanly */ + priv->uart_open = false; + wake_up(&priv->uart_tx_wait); +} + +static void wqtuart_set_termios(struct uart_port *port, + struct ktermios *termios, + struct ktermios *old) +{ +} + +static const char *wqtuart_type(struct uart_port *port) +{ + return "WQTUART"; +} + +static int wqtuart_request_port(struct uart_port *port) +{ + return 0; +} + +static void wqtuart_config_port(struct uart_port *port, int flags) +{ +} + +static void wqtuart_release_port(struct uart_port *port) +{ +} + +static int wqtuart_verify_port(struct uart_port *port, + struct serial_struct *ser) +{ + return 0; +} + +static void wqtuart_rx_char(struct uart_port *port, const char ch) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + struct tty_struct *tty; + unsigned long flags; + + spin_lock_irqsave(&port->lock, flags); + + if (priv->uart_rx_enabled) { + tty = port->info->port.tty; + tty_insert_flip_char(tty, ch, TTY_NORMAL); + tty_flip_buffer_push(tty); + } + + spin_unlock_irqrestore(&port->lock, flags); +} + +static struct uart_ops wqtuart_ops = { + .tx_empty = wqtuart_tx_empty, + .set_mctrl = wqtuart_set_mctrl, + .get_mctrl = wqtuart_get_mctrl, + .stop_tx = wqtuart_stop_tx, + .start_tx = wqtuart_start_tx, + .stop_rx = wqtuart_stop_rx, + .enable_ms = wqtuart_enable_ms, + .break_ctl = wqtuart_break_ctl, + .startup = wqtuart_startup, + .shutdown = wqtuart_shutdown, + .set_termios = wqtuart_set_termios, + .type = wqtuart_type, + .release_port = wqtuart_release_port, + .request_port = wqtuart_request_port, + .config_port = wqtuart_config_port, + .verify_port = wqtuart_verify_port, +}; + +static struct uart_driver wqtuart_driver = { + .owner = THIS_MODULE, + .driver_name = driver_name, + .dev_name = "ttyPCI", + .major = 240, + .minor = 0, + .nr = 1, +}; + +/*----------------------------------------------------------------------------*/ +/* Network Registers */ +/*----------------------------------------------------------------------------*/ + +static void wqt_free_netregs(struct wqt_dev *priv) +{ + BUG_ON(priv->netregs == NULL); + BUG_ON(priv->netregs_addr == 0x0); + + dma_free_coherent(priv->dev, + PAGE_SIZE, + priv->netregs, + priv->netregs_addr); + + priv->netregs = NULL; + priv->netregs_addr = 0x0; +} + +static int wqt_init_netregs(struct wqt_dev *priv) +{ + u32 val; + + BUG_ON(priv->netregs != NULL); + BUG_ON(priv->netregs_addr != 0x0); + + /* Check the PCI Inbound Window Attributes Register 0 for a 4k window + * This is PCI BAR1, and will be used as network device registers */ + val = IMMR_R32BE(PIWAR0_OFFSET); + val = val & (PIWAR0_ENABLED | PIWAR0_IWS_4K); + + if (val != (PIWAR0_ENABLED | PIWAR0_IWS_4K)) { + dev_dbg(priv->dev, "PIWAR0 set up incorrectly\n"); + return -ENODEV; + } + + priv->netregs = dma_alloc_coherent(priv->dev, + PAGE_SIZE, + &priv->netregs_addr, + GFP_KERNEL); + + if (!priv->netregs) { + dev_dbg(priv->dev, "Unable to allocate netregs\n"); + return -ENOMEM; + } + + /* Write the page address into the address register */ + IMMR_W32BE(PITAR0_OFFSET, priv->netregs_addr >> 12); + return 0; +} + +/*----------------------------------------------------------------------------*/ +/* OpenFirmware Device Subsystem */ +/*----------------------------------------------------------------------------*/ + +static int wqt_probe(struct of_device *op, const struct of_device_id *match) +{ + struct net_device *ndev; + struct wqt_dev *priv; + int ret; + + ndev = alloc_etherdev(sizeof(*priv)); + + if (!ndev) { + ret = -ENOMEM; + goto out_alloc_ndev; + } + + dev_set_drvdata(&op->dev, ndev); + priv = netdev_priv(ndev); + priv->op = op; + priv->dev = &op->dev; + priv->ndev = ndev; + + spin_lock_init(&priv->irq_lock); + mutex_init(&priv->irq_mutex); + + /* Hardware Initialization */ + priv->irq = irq_of_parse_and_map(op->node, 0); + priv->immr = ioremap(get_immrbase(), 0x100000); + + if (!priv->immr) { + ret = -ENOMEM; + goto out_ioremap_immr; + } + + ret = wqt_init_netregs(priv); + + if (ret) + goto out_init_netregs; + + /* NOTE: Yes, this is correct. Everything was written as if this + * NOTE: side *is* a network card. So the place the card is + * NOTE: receiving from is the other side's TX buffers */ + priv->rx_base = priv->netregs + PCINET_TXBD_BASE; + priv->tx_base = priv->netregs + PCINET_RXBD_BASE; + wqtstatus_setbit(priv, PCINET_NET_REGISTERS_VALID); + + /* DMA Client */ + wqtdma_setup_outbound_window(priv); + priv->client.event_callback = dmatest_event; + dma_cap_set(DMA_MEMCPY, priv->client.cap_mask); + dma_async_client_register(&priv->client); + dma_async_client_chan_request(&priv->client); + + /* Initialize private data */ + priv->wq = create_singlethread_workqueue(driver_name); + + if (!priv->wq) { + ret = -ENOMEM; + goto out_create_workqueue; + } + + INIT_WORK(&priv->uart_tx_work, uart_tx_work_fn); + init_waitqueue_head(&priv->uart_tx_wait); + priv->uart_tx_ready = true; + + tasklet_init(&priv->tx_complete_tasklet, wqt_tx_complete, + (unsigned long)ndev); + tasklet_disable(&priv->tx_complete_tasklet); + spin_lock_init(&priv->net_lock); + + mutex_init(&priv->net_mutex); + priv->net_state = NET_STATE_STOPPED; + INIT_WORK(&priv->net_start_work, wqtnet_start_work_fn); + INIT_WORK(&priv->net_stop_work, wqtnet_stop_work_fn); + init_completion(&priv->net_start_completion); + init_completion(&priv->net_stop_completion); + + /* Mask all of the MBOX interrupts */ + IMMR_W32(IMIMR_OFFSET, 0x1 | 0x2); + + /* Network Device */ + random_ether_addr(ndev->dev_addr); + + ndev->open = wqt_open; + ndev->stop = wqt_stop; + ndev->change_mtu = wqt_change_mtu; + ndev->hard_start_xmit = wqt_hard_start_xmit; + ndev->tx_timeout = wqt_tx_timeout; + ndev->watchdog_timeo = HZ/4; + ndev->flags &= ~IFF_MULTICAST; /* No multicast support */ +#ifdef CONFIG_PCINET_DISABLE_CHECKSUM + ndev->features |= NETIF_F_NO_CSUM; /* No checksum needed */ +#endif + ndev->mtu = PH_MAX_MTU; + netif_napi_add(ndev, &priv->napi, wqt_rx_napi, PH_RING_SIZE); + + ret = register_netdev(ndev); + + if (ret) + goto out_register_netdev; + + /* UART Device */ + priv->port.ops = &wqtuart_ops; + priv->port.type = PORT_16550A; + priv->port.dev = &op->dev; + priv->port.line = 0; + spin_lock_init(&priv->port.lock); + + ret = uart_add_one_port(&wqtuart_driver, &priv->port); + + if (ret) + goto out_add_uart_port; + + dev_info(priv->dev, "using ethernet device %s\n", ndev->name); + dev_info(priv->dev, "using serial device %s%d\n", + wqtuart_driver.dev_name, priv->port.line); + return 0; + +out_add_uart_port: + unregister_netdev(ndev); +out_register_netdev: + destroy_workqueue(priv->wq); +out_create_workqueue: + wqt_free_netregs(priv); +out_init_netregs: + iounmap(priv->immr); +out_ioremap_immr: + free_netdev(ndev); +out_alloc_ndev: + return ret; +} + +static int wqt_remove(struct of_device *op) +{ + struct net_device *ndev = dev_get_drvdata(&op->dev); + struct wqt_dev *priv = netdev_priv(ndev); + + uart_remove_one_port(&wqtuart_driver, &priv->port); + unregister_netdev(priv->ndev); + + flush_workqueue(priv->wq); + destroy_workqueue(priv->wq); + + wqtstatus_clrbit(priv, PCINET_NET_REGISTERS_VALID); + wqt_free_netregs(priv); + + dma_async_client_unregister(&priv->client); + + iounmap(priv->immr); + + free_netdev(ndev); + + return 0; +} + +static struct of_device_id wqt_match[] = { + { .compatible = "fsl,mpc8349-mu", }, + {}, +}; + +static struct of_platform_driver wqt_of_driver = { + .owner = THIS_MODULE, + .name = driver_name, + .match_table = wqt_match, + .probe = wqt_probe, + .remove = wqt_remove, +}; + +/*----------------------------------------------------------------------------*/ +/* DMA Client Infrastructure */ +/*----------------------------------------------------------------------------*/ + +/*----------------------------------------------------------------------------*/ +/* Module Init / Exit */ +/*----------------------------------------------------------------------------*/ + +static int __init wqt_init(void) +{ + int ret; + + ret = uart_register_driver(&wqtuart_driver); + + if (ret) + goto out_uart_register_driver; + + ret = of_register_platform_driver(&wqt_of_driver); + + if (ret) + goto out_of_register_platform_driver; + + return 0; + +out_of_register_platform_driver: + uart_unregister_driver(&wqtuart_driver); +out_uart_register_driver: + return ret; +} + +static void __exit wqt_exit(void) +{ + of_unregister_platform_driver(&wqt_of_driver); + uart_unregister_driver(&wqtuart_driver); +} + +MODULE_AUTHOR("Ira W. Snyder iws@ovro.caltech.edu"); +MODULE_DESCRIPTION("PCINet/PCISerial Driver for MPC8349EMDS"); +MODULE_LICENSE("GPL"); + +module_init(wqt_init); +module_exit(wqt_exit); diff --git a/drivers/net/pcinet_host.c b/drivers/net/pcinet_host.c new file mode 100644 index 0000000..378ab91 --- /dev/null +++ b/drivers/net/pcinet_host.c @@ -0,0 +1,1383 @@ +/* + * PCINet and PCISerial Driver for Freescale MPC8349EMDS (Host side) + * + * Copyright (c) 2008 Ira W. Snyder iws@ovro.caltech.edu + * + * Heavily inspired by the drivers/net/fs_enet driver + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#include <linux/kernel.h> +#include <linux/module.h> +#include <linux/init.h> +#include <linux/sched.h> +#include <linux/wait.h> +#include <linux/interrupt.h> +#include <linux/irqreturn.h> +#include <linux/pci.h> +#include <linux/serial.h> +#include <linux/serial_core.h> +#include <linux/etherdevice.h> +#include <linux/mutex.h> + +#include "pcinet.h" +#include "pcinet_hw.h" + +static const char driver_name[] = "wqt"; + +static void wqtuart_rx_char(struct uart_port *port, const char ch); +static void wqtuart_stop_tx(struct uart_port *port); + +struct wqt_dev; +typedef void (*wqt_irqhandler_t)(struct wqt_dev *); + +struct wqt_irqhandlers { + wqt_irqhandler_t net_start_req_handler; + wqt_irqhandler_t net_start_ack_handler; + wqt_irqhandler_t net_stop_req_handler; + wqt_irqhandler_t net_stop_ack_handler; + wqt_irqhandler_t net_rx_packet_handler; + wqt_irqhandler_t net_tx_complete_handler; + wqt_irqhandler_t uart_rx_ready_handler; + wqt_irqhandler_t uart_tx_empty_handler; +}; + +struct wqt_dev { + /*--------------------------------------------------------------------*/ + /* PCI Infrastructure */ + /*--------------------------------------------------------------------*/ + struct pci_dev *pdev; + struct device *dev; + void __iomem *immr; + + struct mutex irq_mutex; + int interrupt_count; + + spinlock_t irq_lock; + struct wqt_irqhandlers handlers; + + /*--------------------------------------------------------------------*/ + /* UART Device Infrastructure */ + /*--------------------------------------------------------------------*/ + struct uart_port port; + bool uart_rx_enabled; + bool uart_open; + + struct workqueue_struct *wq; + struct work_struct uart_tx_work; + wait_queue_head_t uart_tx_wait; /* sleep for uart_tx_ready */ + bool uart_tx_ready; /* transmitter state */ + + /*--------------------------------------------------------------------*/ + /* Ethernet Device Infrastructure */ + /*--------------------------------------------------------------------*/ + struct net_device *ndev; + void __iomem *netregs; + + /* Outstanding SKB */ + struct sk_buff *rx_skbs[PH_RING_SIZE]; + struct sk_buff *tx_skbs[PH_RING_SIZE]; + dma_addr_t rx_skb_addrs[PH_RING_SIZE]; + dma_addr_t tx_skb_addrs[PH_RING_SIZE]; + + /* Circular Buffer Descriptor base */ + struct circ_buf_desc __iomem *rx_base; + struct circ_buf_desc __iomem *tx_base; + + /* Current SKB index */ + struct circ_buf_desc __iomem *cur_rx; + struct circ_buf_desc __iomem *cur_tx; + struct circ_buf_desc __iomem *dirty_tx; + int tx_free; + + struct tasklet_struct tx_complete_tasklet; + spinlock_t net_lock; + + struct mutex net_mutex; + int net_state; + struct work_struct net_start_work; + struct work_struct net_stop_work; + struct completion net_start_completion; + struct completion net_stop_completion; + struct napi_struct napi; +}; + +/*----------------------------------------------------------------------------*/ +/* Status Register Helper Operations */ +/*----------------------------------------------------------------------------*/ + +static DEFINE_SPINLOCK(status_lock); + +static void wqtstatus_setbit(struct wqt_dev *priv, u32 bit) +{ + unsigned long flags; + + spin_lock_irqsave(&status_lock, flags); + IMMR_W32(IMR1_OFFSET, IMMR_R32(IMR1_OFFSET) | bit); + spin_unlock_irqrestore(&status_lock, flags); +} + +static void wqtstatus_clrbit(struct wqt_dev *priv, u32 bit) +{ + unsigned long flags; + + spin_lock_irqsave(&status_lock, flags); + IMMR_W32(IMR1_OFFSET, IMMR_R32(IMR1_OFFSET) & ~bit); + spin_unlock_irqrestore(&status_lock, flags); +} + +static int wqtstatus_remote_testbit(struct wqt_dev *priv, u32 bit) +{ + return IMMR_R32(OMR1_OFFSET) & bit; +} + +/*----------------------------------------------------------------------------*/ +/* Message Sending and Processing Operations */ +/*----------------------------------------------------------------------------*/ + +static irqreturn_t wqt_interrupt(int irq, void *dev_id) +{ + struct wqt_dev *priv = dev_id; + u32 omisr, odr; + unsigned long flags; + + omisr = IMMR_R32(OMISR_OFFSET); + odr = IMMR_R32(ODR_OFFSET); + + if (!(omisr & 0x8)) + return IRQ_NONE; + + /* Clear all of the interrupt sources, we'll handle them next */ + IMMR_W32(ODR_OFFSET, odr); + + /* Lock over all of the handlers, so they cannot get called when + * the code doesn't expect them to be called */ + spin_lock_irqsave(&priv->irq_lock, flags); + + if (odr & UART_RX_READY_DBELL) + priv->handlers.uart_rx_ready_handler(priv); + + if (odr & UART_TX_EMPTY_DBELL) + priv->handlers.uart_tx_empty_handler(priv); + + if (odr & NET_RX_PACKET_DBELL) + priv->handlers.net_rx_packet_handler(priv); + + if (odr & NET_TX_COMPLETE_DBELL) + priv->handlers.net_tx_complete_handler(priv); + + if (odr & NET_START_REQ_DBELL) + priv->handlers.net_start_req_handler(priv); + + if (odr & NET_START_ACK_DBELL) + priv->handlers.net_start_ack_handler(priv); + + if (odr & NET_STOP_REQ_DBELL) + priv->handlers.net_stop_req_handler(priv); + + if (odr & NET_STOP_ACK_DBELL) + priv->handlers.net_stop_ack_handler(priv); + + spin_unlock_irqrestore(&priv->irq_lock, flags); + + return IRQ_HANDLED; +} + +/* Send a character through the mbox when it becomes available + * Blocking, must not be called with any spinlocks held */ +static int do_send_message(struct wqt_dev *priv, const char ch) +{ + struct uart_port *port = &priv->port; + bool tmp; + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + while (priv->uart_tx_ready != true) { + spin_unlock_irqrestore(&priv->irq_lock, flags); + wait_event_timeout(priv->uart_tx_wait, priv->uart_tx_ready, HZ); + + spin_lock_irqsave(&port->lock, flags); + tmp = priv->uart_open; + spin_unlock_irqrestore(&port->lock, flags); + + if (!tmp) + return -EIO; + + spin_lock_irqsave(&priv->irq_lock, flags); + } + + /* Now the transmitter is free, send the message */ + IMMR_W32(IMR0_OFFSET, ch); + IMMR_W32(IDR_OFFSET, UART_RX_READY_DBELL); + + /* Mark the transmitter busy */ + priv->uart_tx_ready = false; + spin_unlock_irqrestore(&priv->irq_lock, flags); + return 0; +} + +/* Grab a character out of the uart tx buffer and send it */ +static void uart_tx_work_fn(struct work_struct *work) +{ + struct wqt_dev *priv = container_of(work, struct wqt_dev, uart_tx_work); + struct uart_port *port = &priv->port; + struct circ_buf *xmit = &port->info->xmit; + char ch; + unsigned long flags; + + spin_lock_irqsave(&port->lock, flags); + while (true) { + + /* Check for XON/XOFF (high priority) */ + if (port->x_char) { + ch = port->x_char; + port->x_char = 0; + spin_unlock_irqrestore(&port->lock, flags); + + if (do_send_message(priv, ch)) + return; + + spin_lock_irqsave(&port->lock, flags); + continue; + } + + /* If we're out of chars or the port is stopped, we're done */ + if (uart_circ_empty(xmit) || uart_tx_stopped(port)) { + wqtuart_stop_tx(port); + break; + } + + /* Grab the next char out of the buffer and send it */ + ch = xmit->buf[xmit->tail]; + xmit->tail = (xmit->tail + 1) & (UART_XMIT_SIZE - 1); + spin_unlock_irqrestore(&port->lock, flags); + + if (do_send_message(priv, ch)) + return; + + spin_lock_irqsave(&port->lock, flags); + } + + if (uart_circ_chars_pending(xmit) < WAKEUP_CHARS) + uart_write_wakeup(port); + + if (uart_circ_empty(xmit)) + wqtuart_stop_tx(port); + + spin_unlock_irqrestore(&port->lock, flags); +} + +/*----------------------------------------------------------------------------*/ +/* Interrupt Handlers */ +/*----------------------------------------------------------------------------*/ + +/* NOTE: All handlers are called with priv->irq_lock held */ + +static void empty_handler(struct wqt_dev *priv) +{ + /* Intentionally left empty */ +} + +static void net_start_req_handler(struct wqt_dev *priv) +{ + schedule_work(&priv->net_start_work); +} + +static void net_start_ack_handler(struct wqt_dev *priv) +{ + complete(&priv->net_start_completion); +} + +static void net_stop_req_handler(struct wqt_dev *priv) +{ + schedule_work(&priv->net_stop_work); +} + +static void net_stop_ack_handler(struct wqt_dev *priv) +{ + complete(&priv->net_stop_completion); +} + +static void net_tx_complete_handler(struct wqt_dev *priv) +{ + tasklet_schedule(&priv->tx_complete_tasklet); +} + +static void net_rx_packet_handler(struct wqt_dev *priv) +{ + wqtstatus_setbit(priv, PCINET_NET_RXINT_OFF); + netif_rx_schedule(priv->ndev, &priv->napi); +} + +static void uart_rx_ready_handler(struct wqt_dev *priv) +{ + wqtuart_rx_char(&priv->port, IMMR_R32(OMR0_OFFSET) & 0xff); + IMMR_W32(IDR_OFFSET, UART_TX_EMPTY_DBELL); +} + +static void uart_tx_empty_handler(struct wqt_dev *priv) +{ + priv->uart_tx_ready = true; + wake_up(&priv->uart_tx_wait); +} + +/*----------------------------------------------------------------------------*/ +/* Interrupt Request / Free Helpers */ +/*----------------------------------------------------------------------------*/ + +static void do_enable_net_startstop_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.net_start_req_handler = net_start_req_handler; + priv->handlers.net_start_ack_handler = net_start_ack_handler; + priv->handlers.net_stop_req_handler = net_stop_req_handler; + priv->handlers.net_stop_ack_handler = net_stop_ack_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); + + wqtstatus_setbit(priv, PCINET_NET_STATUS_RUNNING); +} + +static void do_disable_net_startstop_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + wqtstatus_clrbit(priv, PCINET_NET_STATUS_RUNNING); + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.net_start_req_handler = empty_handler; + priv->handlers.net_start_ack_handler = empty_handler; + priv->handlers.net_stop_req_handler = empty_handler; + priv->handlers.net_stop_ack_handler = empty_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static void do_enable_net_rxtx_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.net_rx_packet_handler = net_rx_packet_handler; + priv->handlers.net_tx_complete_handler = net_tx_complete_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static void do_disable_net_rxtx_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.net_rx_packet_handler = empty_handler; + priv->handlers.net_tx_complete_handler = empty_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static void do_enable_uart_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.uart_rx_ready_handler = uart_rx_ready_handler; + priv->handlers.uart_tx_empty_handler = uart_tx_empty_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static void do_disable_uart_handlers(struct wqt_dev *priv) +{ + unsigned long flags; + + spin_lock_irqsave(&priv->irq_lock, flags); + priv->handlers.uart_rx_ready_handler = empty_handler; + priv->handlers.uart_tx_empty_handler = empty_handler; + spin_unlock_irqrestore(&priv->irq_lock, flags); +} + +static int wqt_request_irq(struct wqt_dev *priv) +{ + int ret = 0; + + mutex_lock(&priv->irq_mutex); + + if (priv->interrupt_count > 0) + goto out_unlock; + + /* Force all handlers to be disabled before attaching the handler */ + do_disable_net_startstop_handlers(priv); + do_disable_net_rxtx_handlers(priv); + do_disable_uart_handlers(priv); + + ret = request_irq(priv->pdev->irq, + wqt_interrupt, + IRQF_SHARED, + priv->ndev->name, + priv); + +out_unlock: + priv->interrupt_count++; + mutex_unlock(&priv->irq_mutex); + + return ret; +} + +static void wqt_free_irq(struct wqt_dev *priv) +{ + mutex_lock(&priv->irq_mutex); + priv->interrupt_count--; + + if (priv->interrupt_count > 0) + goto out_unlock; + + free_irq(priv->pdev->irq, priv); + +out_unlock: + mutex_unlock(&priv->irq_mutex); +} + +/*----------------------------------------------------------------------------*/ +/* Network Startup and Shutdown Helpers */ +/*----------------------------------------------------------------------------*/ + +/* NOTE: All helper functions prefixed with "do" must be called only from + * process context, with priv->net_mutex held. They are expected to sleep */ + +/* NOTE: queues must be stopped before initializing and uninitializing */ + +static void do_net_initialize_board(struct wqt_dev *priv) +{ + int i; + struct circ_buf_desc __iomem *bdp; + + BUG_ON(!wqtstatus_remote_testbit(priv, PCINET_NET_REGISTERS_VALID)); + + /* Fill in RX ring */ + for (i = 0, bdp = priv->rx_base; i < PH_RING_SIZE; bdp++, i++) { + CBDW_SC(bdp, BD_MEM_READY); + CBDW_LEN(bdp, PH_MAX_FRSIZE); + CBDW_ADDR(bdp, priv->rx_skb_addrs[i]); + } + + /* Fill in TX ring */ + for (i = 0, bdp = priv->tx_base; i < PH_RING_SIZE; bdp++, i++) { + CBDW_SC(bdp, BD_MEM_READY); + CBDW_LEN(bdp, 0); + CBDW_ADDR(bdp, 0x0); + } +} + +static void do_net_uninitialize_board(struct wqt_dev *priv) +{ + struct sk_buff *skb; + dma_addr_t skb_addr; + struct circ_buf_desc __iomem *bdp; + int i; + + /* Reset TX ring */ + for (i = 0, bdp = priv->tx_base; i < PH_RING_SIZE; bdp++, i++) { + if (priv->tx_skbs[i]) { + skb = priv->tx_skbs[i]; + skb_addr = priv->tx_skb_addrs[i]; + + dma_unmap_single(priv->dev, + skb_addr, + skb->len, + DMA_TO_DEVICE); + + dev_kfree_skb(skb); + + priv->tx_skbs[i] = NULL; + priv->tx_skb_addrs[i] = 0x0; + } + + CBDW_SC(bdp, BD_MEM_READY); + CBDW_LEN(bdp, 0); + CBDW_ADDR(bdp, 0x0); + } +} + +static void do_net_start_queues(struct wqt_dev *priv) +{ + if (priv->net_state == NET_STATE_RUNNING) + return; + + dev_dbg(priv->dev, "resetting buffer positions\n"); + priv->cur_rx = priv->rx_base; + priv->cur_tx = priv->tx_base; + priv->dirty_tx = priv->tx_base; + priv->tx_free = PH_RING_SIZE; + + dev_dbg(priv->dev, "enabling NAPI queue\n"); + napi_enable(&priv->napi); + + dev_dbg(priv->dev, "enabling tx_complete() tasklet\n"); + tasklet_enable(&priv->tx_complete_tasklet); + + dev_dbg(priv->dev, "enabling TX queue\n"); + netif_start_queue(priv->ndev); + + dev_dbg(priv->dev, "carrier on!\n"); + netif_carrier_on(priv->ndev); + + /* Enable the RX_PACKET and TX_COMPLETE interrupt handlers */ + do_enable_net_rxtx_handlers(priv); + + priv->net_state = NET_STATE_RUNNING; +} + +static void do_net_stop_queues(struct wqt_dev *priv) +{ + if (priv->net_state == NET_STATE_STOPPED) + return; + + /* Disable the RX_PACKET and TX_COMPLETE interrupt handlers */ + do_disable_net_rxtx_handlers(priv); + + dev_dbg(priv->dev, "disabling NAPI queue\n"); + napi_disable(&priv->napi); + + dev_dbg(priv->dev, "disabling tx_complete() tasklet\n"); + tasklet_disable(&priv->tx_complete_tasklet); + + dev_dbg(priv->dev, "disabling TX queue\n"); + netif_tx_disable(priv->ndev); + + dev_dbg(priv->dev, "carrier off!\n"); + netif_carrier_off(priv->ndev); + + priv->net_state = NET_STATE_STOPPED; +} + +/* Called when we get a request to start our queues and acknowledge */ +static void wqtnet_start_work_fn(struct work_struct *work) +{ + struct wqt_dev *priv = container_of(work, struct wqt_dev, + net_start_work); + + mutex_lock(&priv->net_mutex); + + do_net_initialize_board(priv); + do_net_start_queues(priv); + IMMR_W32(IDR_OFFSET, NET_START_ACK_DBELL); + + mutex_unlock(&priv->net_mutex); +} + +/* Called when we get a request to stop our queues and acknowledge */ +static void wqtnet_stop_work_fn(struct work_struct *work) +{ + struct wqt_dev *priv = container_of(work, struct wqt_dev, + net_stop_work); + + mutex_lock(&priv->net_mutex); + + do_net_stop_queues(priv); + do_net_uninitialize_board(priv); + IMMR_W32(IDR_OFFSET, NET_STOP_ACK_DBELL); + + mutex_unlock(&priv->net_mutex); +} + +/*----------------------------------------------------------------------------*/ +/* SKB Allocation Helpers */ +/*----------------------------------------------------------------------------*/ + +static void wqt_cleanup_skbs(struct wqt_dev *priv) +{ + struct sk_buff *skb; + dma_addr_t skb_addr; + int i; + + /* TX ring */ + for (i = 0; i < PH_RING_SIZE; ++i) { + if (priv->tx_skbs[i]) { + skb = priv->tx_skbs[i]; + skb_addr = priv->tx_skb_addrs[i]; + + dma_unmap_single(priv->dev, + skb_addr, + skb->len, + DMA_TO_DEVICE); + + dev_kfree_skb(skb); + + priv->tx_skbs[i] = NULL; + priv->tx_skb_addrs[i] = 0x0; + } + } + + /* RX ring */ + for (i = 0; i < PH_RING_SIZE; ++i) { + if (priv->rx_skbs[i]) { + skb = priv->rx_skbs[i]; + skb_addr = priv->rx_skb_addrs[i]; + + dma_unmap_single(priv->dev, + skb_addr, + PH_MAX_FRSIZE, + DMA_FROM_DEVICE); + + dev_kfree_skb(skb); + + priv->rx_skbs[i] = NULL; + priv->rx_skb_addrs[i] = 0x0; + } + } +} + +static int wqt_alloc_skbs(struct wqt_dev *priv) +{ + struct sk_buff *skb; + dma_addr_t skb_addr; + int i; + + /* RX ring */ + for (i = 0; i < PH_RING_SIZE; ++i) { + /* Paranoia check */ + BUG_ON(priv->rx_skbs[i] != NULL); + BUG_ON(priv->rx_skb_addrs[i] != 0x0); + + /* Allocate the skb */ + skb = dev_alloc_skb(PH_MAX_FRSIZE + NET_IP_ALIGN); + + if (skb == NULL) + goto out_err; + + skb_reserve(skb, NET_IP_ALIGN); + + /* DMA map the skb */ + skb_addr = dma_map_single(priv->dev, + skb->data, + PH_MAX_FRSIZE, + DMA_FROM_DEVICE); + + if (dma_mapping_error(skb_addr)) { + dev_kfree_skb(skb); + goto out_err; + } + + priv->rx_skbs[i] = skb; + priv->rx_skb_addrs[i] = skb_addr; + } + + /* TX ring */ + for (i = 0; i < PH_RING_SIZE; ++i) { + /* Paranoia check */ + BUG_ON(priv->tx_skbs[i] != NULL); + BUG_ON(priv->tx_skb_addrs[i] != 0x0); + } + + /* NOTE: the actual initialization of the board happens + * NOTE: in ph_initialize_board(), once the board has + * NOTE: requested to be initialized */ + + return 0; + +out_err: + wqt_cleanup_skbs(priv); + return -ENOMEM; +} + +/*----------------------------------------------------------------------------*/ +/* Network Device Operations */ +/*----------------------------------------------------------------------------*/ + +static int wqt_open(struct net_device *dev) +{ + struct wqt_dev *priv = netdev_priv(dev); + int ret; + + /* Check that the other side has registers */ + if (!wqtstatus_remote_testbit(priv, PCINET_NET_REGISTERS_VALID)) { + dev_err(priv->dev, "no driver installed at the other end\n"); + dev_err(priv->dev, "cowardly refusing to open\n"); + return -ENOTCONN; /* Transport endpoint is not connected */ + } + + /* Pretend the cable is unplugged until we are up and running */ + netif_carrier_off(dev); + + mutex_lock(&priv->net_mutex); + + ret = wqt_alloc_skbs(priv); + + if (ret) + goto out_err; + + do_net_initialize_board(priv); + + ret = wqt_request_irq(priv); + + if (ret) + goto out_err; + + /* Enable only the network start/stop interrupts */ + do_enable_net_startstop_handlers(priv); + + /* Check if the other side is running, if not, it will start us. + * Without the interrupt handler installed, there's no way it can + * respond to us anyway */ + if (!wqtstatus_remote_testbit(priv, PCINET_NET_STATUS_RUNNING)) + goto out_unlock; + + do_net_initialize_board(priv); + + IMMR_W32(IDR_OFFSET, NET_START_REQ_DBELL); + ret = wait_for_completion_timeout(&priv->net_start_completion, 5*HZ); + + if (!ret) { + /* Our start request timed out, therefore, the other + * side will start us when it comes back up */ + dev_dbg(priv->dev, "start timed out\n"); + } else { + do_net_start_queues(priv); + ret = 0; + } + +out_unlock: + mutex_unlock(&priv->net_mutex); + return 0; + +out_err: + wqt_cleanup_skbs(priv); + mutex_unlock(&priv->net_mutex); + return ret; +} + +static int wqt_stop(struct net_device *dev) +{ + struct wqt_dev *priv = netdev_priv(dev); + int ret; + + mutex_lock(&priv->net_mutex); + + do_net_stop_queues(priv); + + IMMR_W32(IDR_OFFSET, NET_STOP_REQ_DBELL); + ret = wait_for_completion_timeout(&priv->net_stop_completion, 5*HZ); + + if (!ret) + dev_warn(priv->dev, "other side did not stop on time!\n"); + else + ret = 0; + + do_disable_net_startstop_handlers(priv); + wqt_free_irq(priv); + do_net_uninitialize_board(priv); + wqt_cleanup_skbs(priv); + + mutex_unlock(&priv->net_mutex); + return 0; +} + +static int wqt_change_mtu(struct net_device *dev, int new_mtu) +{ + if ((new_mtu < 68) || (new_mtu > PH_MAX_MTU)) + return -EINVAL; + + dev->mtu = new_mtu; + return 0; +} + +static int wqt_hard_start_xmit(struct sk_buff *skb, struct net_device *dev) +{ + struct wqt_dev *priv = netdev_priv(dev); + dma_addr_t skb_addr; + struct circ_buf_desc __iomem *bdp; + int dirty_idx; + + spin_lock_bh(&priv->net_lock); + + bdp = priv->cur_tx; + dirty_idx = bdp - priv->tx_base; + + /* This should not happen, the queue should be stopped */ + if (priv->tx_free == 0 || CBDR_SC(bdp) != BD_MEM_READY) { + netif_stop_queue(dev); + spin_unlock_bh(&priv->net_lock); + return NETDEV_TX_BUSY; + } + + skb_addr = dma_map_single(priv->dev, + skb->data, + skb->len, + DMA_TO_DEVICE); + + if (dma_mapping_error(skb_addr)) { + dev_warn(priv->dev, "DMA mapping error\n"); + spin_unlock_bh(&priv->net_lock); + return -ENOMEM; + } + + BUG_ON(priv->tx_skbs[dirty_idx] != NULL); + BUG_ON(priv->tx_skb_addrs[dirty_idx] != 0x0); + + priv->tx_skbs[dirty_idx] = skb; + priv->tx_skb_addrs[dirty_idx] = skb_addr; + + CBDW_LEN(bdp, skb->len); + CBDW_ADDR(bdp, skb_addr); + CBDW_SC(bdp, BD_MEM_DIRTY); + + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->tx_base; + else + bdp++; + + priv->cur_tx = bdp; + priv->tx_free--; + dev->trans_start = jiffies; + + if (priv->tx_free == 0) + netif_stop_queue(dev); + + if (!wqtstatus_remote_testbit(priv, PCINET_NET_RXINT_OFF)) + IMMR_W32(IDR_OFFSET, NET_RX_PACKET_DBELL); + + spin_unlock_bh(&priv->net_lock); + return NETDEV_TX_OK; +} + +static void wqt_tx_timeout(struct net_device *dev) +{ + struct wqt_dev *priv = netdev_priv(dev); + + dev->stats.tx_errors++; + IMMR_W32(IDR_OFFSET, NET_RX_PACKET_DBELL); +} + +static void wqt_tx_complete(unsigned long data) +{ + struct net_device *dev = (struct net_device *)data; + struct wqt_dev *priv = netdev_priv(dev); + struct sk_buff *skb; + dma_addr_t skb_addr; + struct circ_buf_desc __iomem *bdp; + int do_wake, dirty_idx; + + spin_lock_bh(&priv->net_lock); + + bdp = priv->dirty_tx; + do_wake = 0; + + while (CBDR_SC(bdp) == BD_MEM_FREE) { + dirty_idx = bdp - priv->tx_base; + + skb = priv->tx_skbs[dirty_idx]; + skb_addr = priv->tx_skb_addrs[dirty_idx]; + + BUG_ON(skb == NULL); + BUG_ON(skb_addr == 0x0); + + dev->stats.tx_bytes += skb->len; + dev->stats.tx_packets++; + + /* Unmap and free the transmitted skb */ + dma_unmap_single(priv->dev, + skb_addr, + skb->len, + DMA_TO_DEVICE); + dev_kfree_skb_irq(skb); + + priv->tx_skbs[dirty_idx] = NULL; + priv->tx_skb_addrs[dirty_idx] = 0x0; + + /* Invalidate the buffer descriptor */ + CBDW_LEN(bdp, 0); + CBDW_ADDR(bdp, 0x0); + CBDW_SC(bdp, BD_MEM_READY); + + /* Update the bdp */ + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->tx_base; + else + bdp++; + + if (!priv->tx_free++) + do_wake = 1; + } + + priv->dirty_tx = bdp; + + spin_unlock_bh(&priv->net_lock); + + if (do_wake) + netif_wake_queue(dev); +} + +static int wqt_rx_napi(struct napi_struct *napi, int budget) +{ + struct wqt_dev *priv = container_of(napi, struct wqt_dev, napi); + struct net_device *dev = priv->ndev; + int received = 0; + struct sk_buff *skb, *skbn; + dma_addr_t skb_addr, skbn_addr; + int pkt_len, dirty_idx; + struct circ_buf_desc __iomem *bdp; + + bdp = priv->cur_rx; + + while (CBDR_SC(bdp) == BD_MEM_DIRTY) { + dirty_idx = bdp - priv->rx_base; + + skb = priv->rx_skbs[dirty_idx]; + skb_addr = priv->rx_skb_addrs[dirty_idx]; + + BUG_ON(skb == NULL); + BUG_ON(skb_addr == 0x0); + + /* Allocate the next rx skb and DMA map it */ + skbn = dev_alloc_skb(PH_MAX_FRSIZE + NET_IP_ALIGN); + + if (skbn == NULL) { + skbn = skb; + skbn_addr = skb_addr; + dev->stats.rx_dropped++; + goto out_noalloc; + } + + skb_reserve(skbn, NET_IP_ALIGN); + + skbn_addr = dma_map_single(priv->dev, + skbn->data, + PH_MAX_FRSIZE, + DMA_FROM_DEVICE); + + if (dma_mapping_error(skbn_addr)) { + dev_kfree_skb_irq(skbn); + skbn = skb; + skbn_addr = skb_addr; + dev->stats.rx_dropped++; + goto out_noalloc; + } + + /* DMA unmap the old skb and pass it up */ + dma_unmap_single(priv->dev, + skb_addr, + PH_MAX_FRSIZE, + DMA_FROM_DEVICE); + + pkt_len = CBDR_LEN(bdp); + skb_put(skb, pkt_len); + skb->protocol = eth_type_trans(skb, dev); +#ifdef CONFIG_PCINET_DISABLE_CHECKSUM + skb->ip_summed = CHECKSUM_UNNECESSARY; +#else + skb->ip_summed = CHECKSUM_NONE; +#endif + netif_receive_skb(skb); + received++; + dev->stats.rx_bytes += pkt_len; + dev->stats.rx_packets++; + +out_noalloc: + /* Write the new skb into the buffer descriptor */ + CBDW_LEN(bdp, PH_MAX_FRSIZE); + CBDW_ADDR(bdp, skbn_addr); + CBDW_SC(bdp, BD_MEM_FREE); + + priv->rx_skbs[dirty_idx] = skbn; + priv->rx_skb_addrs[dirty_idx] = skbn_addr; + + /* Update the bdp */ + if (dirty_idx == PH_RING_SIZE - 1) + bdp = priv->rx_base; + else + bdp++; + + if (received >= budget) + break; + } + + priv->cur_rx = bdp; + + /* We have processed all packets that the adapter had, but it + * was less than our budget, stop polling */ + if (received < budget) { + netif_rx_complete(dev, napi); + wqtstatus_clrbit(priv, PCINET_NET_RXINT_OFF); + } + + IMMR_W32(IDR_OFFSET, NET_TX_COMPLETE_DBELL); + + return received; +} + +/*----------------------------------------------------------------------------*/ +/* UART Device Operations */ +/*----------------------------------------------------------------------------*/ + +static unsigned int wqtuart_tx_empty(struct uart_port *port) +{ + return TIOCSER_TEMT; +} + +static void wqtuart_set_mctrl(struct uart_port *port, unsigned int mctrl) +{ +} + +static unsigned int wqtuart_get_mctrl(struct uart_port *port) +{ + return TIOCM_CAR | TIOCM_DSR | TIOCM_CTS; +} + +static void wqtuart_stop_tx(struct uart_port *port) +{ +} + +static void wqtuart_start_tx(struct uart_port *port) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + + queue_work(priv->wq, &priv->uart_tx_work); +} + +static void wqtuart_stop_rx(struct uart_port *port) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + + do_disable_uart_handlers(priv); + priv->uart_rx_enabled = false; + wqtstatus_clrbit(priv, PCINET_UART_RX_ENABLED); +} + +static void wqtuart_enable_ms(struct uart_port *port) +{ +} + +static void wqtuart_break_ctl(struct uart_port *port, int break_state) +{ +} + +static int wqtuart_startup(struct uart_port *port) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + int ret; + + ret = wqt_request_irq(priv); + + if (ret) + return ret; + + do_enable_uart_handlers(priv); + + /* Mark the transmitter and receiver ready */ + priv->uart_tx_ready = true; + priv->uart_rx_enabled = true; + wqtstatus_setbit(priv, PCINET_UART_RX_ENABLED); + + /* Let the other side know that we are ready to receive chars now */ + IMMR_W32(IDR_OFFSET, UART_TX_EMPTY_DBELL); + priv->uart_open = true; + return 0; +} + +static void wqtuart_shutdown(struct uart_port *port) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + + wqt_free_irq(priv); + + /* Make sure the uart_tx_work_fn() exits cleanly */ + priv->uart_open = false; + wake_up(&priv->uart_tx_wait); +} + +static void wqtuart_set_termios(struct uart_port *port, + struct ktermios *termios, + struct ktermios *old) +{ +} + +static const char *wqtuart_type(struct uart_port *port) +{ + return "WQTUART"; +} + +static int wqtuart_request_port(struct uart_port *port) +{ + return 0; +} + +static void wqtuart_config_port(struct uart_port *port, int flags) +{ +} + +static void wqtuart_release_port(struct uart_port *port) +{ +} + +static int wqtuart_verify_port(struct uart_port *port, + struct serial_struct *ser) +{ + return 0; +} + +static void wqtuart_rx_char(struct uart_port *port, const char ch) +{ + struct wqt_dev *priv = container_of(port, struct wqt_dev, port); + struct tty_struct *tty; + unsigned long flags; + + spin_lock_irqsave(&port->lock, flags); + + if (priv->uart_rx_enabled) { + tty = port->info->port.tty; + tty_insert_flip_char(tty, ch, TTY_NORMAL); + tty_flip_buffer_push(tty); + } + + spin_unlock_irqrestore(&port->lock, flags); +} + +static struct uart_ops wqtuart_ops = { + .tx_empty = wqtuart_tx_empty, + .set_mctrl = wqtuart_set_mctrl, + .get_mctrl = wqtuart_get_mctrl, + .stop_tx = wqtuart_stop_tx, + .start_tx = wqtuart_start_tx, + .stop_rx = wqtuart_stop_rx, + .enable_ms = wqtuart_enable_ms, + .break_ctl = wqtuart_break_ctl, + .startup = wqtuart_startup, + .shutdown = wqtuart_shutdown, + .set_termios = wqtuart_set_termios, + .type = wqtuart_type, + .release_port = wqtuart_release_port, + .request_port = wqtuart_request_port, + .config_port = wqtuart_config_port, + .verify_port = wqtuart_verify_port, +}; + +static struct uart_driver wqtuart_driver = { + .owner = THIS_MODULE, + .driver_name = driver_name, + .dev_name = "ttyPCI", + .major = 240, + .minor = 0, + .nr = 1, +}; + +/*----------------------------------------------------------------------------*/ +/* PCI Subsystem */ +/*----------------------------------------------------------------------------*/ + +static int wqt_probe(struct pci_dev *dev, const struct pci_device_id *id) +{ + struct net_device *ndev; + struct wqt_dev *priv; + int ret; + + ndev = alloc_etherdev(sizeof(*priv)); + + if (!ndev) { + ret = -ENOMEM; + goto out_alloc_ndev; + } + + pci_set_drvdata(dev, ndev); + priv = netdev_priv(ndev); + priv->pdev = dev; + priv->dev = &dev->dev; + priv->ndev = ndev; + + mutex_init(&priv->irq_mutex); + spin_lock_init(&priv->irq_lock); + + /* Hardware Initialization */ + ret = pci_enable_device(dev); + + if (ret) + goto out_pci_enable_dev; + + pci_set_master(dev); + + ret = pci_request_regions(dev, driver_name); + + if (ret) + goto out_pci_request_regions; + + priv->immr = pci_iomap(dev, 0, 0); + + if (!priv->immr) { + ret = -ENOMEM; + goto out_iomap_immr; + } + + priv->netregs = pci_iomap(dev, 1, 0); + + if (!priv->netregs) { + ret = -ENOMEM; + goto out_iomap_netregs; + } + + priv->rx_base = priv->netregs + PCINET_RXBD_BASE; + priv->tx_base = priv->netregs + PCINET_TXBD_BASE; + + ret = dma_set_mask(&dev->dev, 0xcfffffff); + + if (ret) { + dev_err(&dev->dev, "Unable to set DMA mask\n"); + ret = -ENODEV; + goto out_set_dma_mask; + } + + /* Initialize private data */ + priv->wq = create_singlethread_workqueue(driver_name); + + if (!priv->wq) { + ret = -ENOMEM; + goto out_create_workqueue; + } + + INIT_WORK(&priv->uart_tx_work, uart_tx_work_fn); + init_waitqueue_head(&priv->uart_tx_wait); + priv->uart_tx_ready = true; + + tasklet_init(&priv->tx_complete_tasklet, wqt_tx_complete, + (unsigned long)ndev); + tasklet_disable(&priv->tx_complete_tasklet); + spin_lock_init(&priv->net_lock); + + mutex_init(&priv->net_mutex); + priv->net_state = NET_STATE_STOPPED; + INIT_WORK(&priv->net_start_work, wqtnet_start_work_fn); + INIT_WORK(&priv->net_stop_work, wqtnet_stop_work_fn); + init_completion(&priv->net_start_completion); + init_completion(&priv->net_stop_completion); + + /* Mask all of the MBOX interrupts */ + IMMR_W32(OMIMR_OFFSET, 0x1 | 0x2); + + /* Network Device */ + random_ether_addr(ndev->dev_addr); + + ndev->open = wqt_open; + ndev->stop = wqt_stop; + ndev->change_mtu = wqt_change_mtu; + ndev->hard_start_xmit = wqt_hard_start_xmit; + ndev->tx_timeout = wqt_tx_timeout; + ndev->watchdog_timeo = HZ/4; + ndev->flags &= ~IFF_MULTICAST; /* No multicast support */ +#ifdef CONFIG_PCINET_DISABLE_CHECKSUM + ndev->features |= NETIF_F_NO_CSUM; /* No checksum needed */ +#endif + ndev->mtu = PH_MAX_MTU; + netif_napi_add(ndev, &priv->napi, wqt_rx_napi, PH_RING_SIZE); + + ret = register_netdev(ndev); + + if (ret) + goto out_register_netdev; + + /* UART Device */ + priv->port.ops = &wqtuart_ops; + priv->port.type = PORT_16550A; + priv->port.dev = &dev->dev; + priv->port.line = 0; + spin_lock_init(&priv->port.lock); + + ret = uart_add_one_port(&wqtuart_driver, &priv->port); + + if (ret) + goto out_add_uart_port; + + dev_info(priv->dev, "using ethernet device %s\n", ndev->name); + dev_info(priv->dev, "using serial device %s%d\n", + wqtuart_driver.dev_name, priv->port.line); + return 0; + +out_add_uart_port: + unregister_netdev(ndev); +out_register_netdev: + destroy_workqueue(priv->wq); +out_create_workqueue: +out_set_dma_mask: + pci_iounmap(dev, priv->netregs); +out_iomap_netregs: + pci_iounmap(dev, priv->immr); +out_iomap_immr: + pci_release_regions(dev); +out_pci_request_regions: + pci_disable_device(dev); +out_pci_enable_dev: + free_netdev(ndev); +out_alloc_ndev: + return ret; +} + +static void wqt_remove(struct pci_dev *dev) +{ + struct net_device *ndev = pci_get_drvdata(dev); + struct wqt_dev *priv = netdev_priv(ndev); + + uart_remove_one_port(&wqtuart_driver, &priv->port); + unregister_netdev(priv->ndev); + + flush_workqueue(priv->wq); + destroy_workqueue(priv->wq); + + pci_iounmap(dev, priv->netregs); + pci_iounmap(dev, priv->immr); + pci_release_regions(dev); + pci_disable_device(dev); + + free_netdev(ndev); +} + +#define PCI_DEVID_FSL_MPC8349EMDS 0x0080 + +/* The list of devices that this module will support */ +static struct pci_device_id wqt_ids[] = { + { PCI_DEVICE(PCI_VENDOR_ID_FREESCALE, PCI_DEVID_FSL_MPC8349EMDS), }, + { 0, } +}; +MODULE_DEVICE_TABLE(pci, wqt_ids); + +static struct pci_driver wqt_pci_driver = { + .name = (char *)driver_name, + .id_table = wqt_ids, + .probe = wqt_probe, + .remove = wqt_remove, +}; + +/*----------------------------------------------------------------------------*/ +/* Module Init / Exit */ +/*----------------------------------------------------------------------------*/ + +static int __init wqt_init(void) +{ + int ret; + + ret = uart_register_driver(&wqtuart_driver); + + if (ret) + goto out_uart_register_driver; + + ret = pci_register_driver(&wqt_pci_driver); + + if (ret) + goto out_pci_register_driver; + + return 0; + +out_pci_register_driver: + uart_unregister_driver(&wqtuart_driver); +out_uart_register_driver: + return ret; +} + +static void __exit wqt_exit(void) +{ + pci_unregister_driver(&wqt_pci_driver); + uart_unregister_driver(&wqtuart_driver); +} + +MODULE_AUTHOR("Ira W. Snyder iws@ovro.caltech.edu"); +MODULE_DESCRIPTION("PCINet/PCISerial Driver for MPC8349EMDS (Host side)"); +MODULE_LICENSE("GPL"); + +module_init(wqt_init); +module_exit(wqt_exit); diff --git a/drivers/net/pcinet_hw.h b/drivers/net/pcinet_hw.h new file mode 100644 index 0000000..499ba61 --- /dev/null +++ b/drivers/net/pcinet_hw.h @@ -0,0 +1,77 @@ +/* + * Register offsets for the MPC8349EMDS Message Unit from the IMMR base address + * + * Copyright (c) 2008 Ira W. Snyder iws@ovro.caltech.edu + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#ifndef PCINET_HW_H +#define PCINET_HW_H + +/* mpc8349emds message unit register offsets */ +#define OMISR_OFFSET 0x8030 +#define OMIMR_OFFSET 0x8034 +#define IMR0_OFFSET 0x8050 +#define IMR1_OFFSET 0x8054 +#define OMR0_OFFSET 0x8058 +#define OMR1_OFFSET 0x805C +#define ODR_OFFSET 0x8060 +#define IDR_OFFSET 0x8068 +#define IMISR_OFFSET 0x8080 +#define IMIMR_OFFSET 0x8084 + + +/* mpc8349emds pci and local access window register offsets */ +#define LAWAR0_OFFSET 0x0064 +#define LAWAR0_ENABLE (1<<31) + +#define POCMR0_OFFSET 0x8410 +#define POCMR0_ENABLE (1<<31) + +#define POTAR0_OFFSET 0x8400 + +#define LAWAR1_OFFSET 0x006c +#define LAWAR1_ENABLE (1<<31) + +#define POCMR1_OFFSET 0x8428 +#define POCMR1_ENABLE (1<<31) + +#define POTAR1_OFFSET 0x8418 + + +/* mpc8349emds dma controller register offsets */ +#define DMAMR0_OFFSET 0x8100 +#define DMASR0_OFFSET 0x8104 +#define DMASAR0_OFFSET 0x8110 +#define DMADAR0_OFFSET 0x8118 +#define DMABCR0_OFFSET 0x8120 + +#define DMA_CHANNEL_BUSY (1<<2) + +#define DMA_DIRECT_MODE_SNOOP (1<<20) +#define DMA_CHANNEL_MODE_DIRECT (1<<2) +#define DMA_CHANNEL_START (1<<0) + + +/* mpc8349emds pci and local access window register offsets */ +#define LAWAR0_OFFSET 0x0064 +#define LAWAR0_ENABLE (1<<31) + +#define POCMR0_OFFSET 0x8410 +#define POCMR0_ENABLE (1<<31) + +#define POTAR0_OFFSET 0x8400 + + +/* mpc8349emds pci and inbound window register offsets */ +#define PITAR0_OFFSET 0x8568 +#define PIWAR0_OFFSET 0x8578 + +#define PIWAR0_ENABLED (1<<31) +#define PIWAR0_PREFETCH (1<<29) +#define PIWAR0_IWS_4K 0xb + +#endif /* PCINET_HW_H */
participants (5)
Ira Snyder
Jean-Christophe PLAGNIOL-VILLARD
Jerry Van Baren
rajeev s
