[U-Boot] [PATCH v3 04/29] zynq: Cleanup on memory configs
Cleanup on memory configuration options: - Add comment - Re-order configs
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- V3: none V2: none
include/configs/zynq.h | 27 ++++++++++++++------------- 1 file changed, 14 insertions(+), 13 deletions(-)
diff --git a/include/configs/zynq.h b/include/configs/zynq.h index e34024d..8be52df 100644 --- a/include/configs/zynq.h +++ b/include/configs/zynq.h @@ -13,14 +13,6 @@ /* CPU clock */ #define CONFIG_CPU_FREQ_HZ 800000000
-/* Ram */ -#define CONFIG_NR_DRAM_BANKS 1 -#define CONFIG_SYS_TEXT_BASE 0 -#define CONFIG_SYS_SDRAM_BASE 0 -#define CONFIG_SYS_SDRAM_SIZE 0x40000000 -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x1000) - /* The following table includes the supported baudrates */ #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400} @@ -105,11 +97,6 @@ #define CONFIG_SYS_NO_FLASH
#define CONFIG_SYS_MALLOC_LEN 0x400000 -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_MALLOC_LEN -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE)
/* Miscellaneous configurable options */ #define CONFIG_SYS_PROMPT "zynq-uboot> " @@ -125,7 +112,21 @@
#define CONFIG_SYS_LOAD_ADDR 0
+/* Physical Memory map */ +#define CONFIG_SYS_TEXT_BASE 0
+#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0 +#define CONFIG_SYS_SDRAM_SIZE 0x40000000 + +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x1000) + +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_MALLOC_LEN +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) /* OF */ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */
