[U-Boot] [PATCH] mpc8536: fix board config file line length
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com ---
Changelog: According to Woflgang's comments, fixed the line length of the board config file.
include/configs/MPC8536DS.h | 147 +++++++++++++++++++++++-------------------- 1 files changed, 79 insertions(+), 68 deletions(-)
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index faca805..9d45648 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -86,8 +86,8 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ #endif
-#define CONFIG_SYS_MEMTEST_START 0x00010000 /* skip exception vectors */ -#define CONFIG_SYS_MEMTEST_END 0x1f000000 /* skip u-boot at top of RAM */ +#define CONFIG_SYS_MEMTEST_START 0x00010000 /* skip exception vectors */ +#define CONFIG_SYS_MEMTEST_END 0x1f000000 /* skip u-boot at top of RAM */ #define CONFIG_PANIC_HANG /* do not reset board on panic */
/* @@ -97,16 +97,16 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ #define CONFIG_SYS_CCSRBAR 0xffe00000 /* relocated CCSRBAR */ #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_CCSRBAR_PHYS 0xfffe00000ull /* physical addr of CCSRBAR */ +#define CONFIG_SYS_CCSRBAR_PHYS 0xfffe00000ull /* physical addr of CCSRBAR */ #else -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ +#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR #endif -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */
-#define CONFIG_SYS_PCI1_ADDR (CONFIG_SYS_CCSRBAR+0x8000) -#define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_CCSRBAR+0xa000) -#define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_CCSRBAR+0x9000) -#define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_CCSRBAR+0xb000) +#define CONFIG_SYS_PCI1_ADDR (CONFIG_SYS_CCSRBAR + 0x8000) +#define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_CCSRBAR + 0xa000) +#define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_CCSRBAR + 0x9000) +#define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_CCSRBAR + 0xb000)
/* DDR Setup */ #define CONFIG_VERY_BIG_RAM @@ -131,9 +131,9 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_SPD_BUS_NUM 1
/* These are used when DDR doesn't use SPD. */ -#define CONFIG_SYS_SDRAM_SIZE 256 /* DDR is 256MB */ +#define CONFIG_SYS_SDRAM_SIZE 256 /* DDR is 256MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x0000001F -#define CONFIG_SYS_DDR_CS0_CONFIG 0x80010102 /* Enable, no interleaving */ +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80010102 /* Enable, no interleaving */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 0x00260802 #define CONFIG_SYS_DDR_TIMING_1 0x3935d322 @@ -145,7 +145,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_DDR_CLK_CTRL 0x03800000 #define CONFIG_SYS_DDR_OCD_CTRL 0x00000000 #define CONFIG_SYS_DDR_OCD_STATUS 0x00000000 -#define CONFIG_SYS_DDR_CONTROL 0xC3008000 /* Type = DDR2 */ +#define CONFIG_SYS_DDR_CONTROL 0xC3008000 /* Type = DDR2 */ #define CONFIG_SYS_DDR_CONTROL2 0x04400010
#define CONFIG_SYS_DDR_ERR_INT_EN 0x0000000d @@ -190,21 +190,26 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE #endif
-#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) | BR_PS_16 | BR_V) +#define CONFIG_SYS_BR0_PRELIM \ + (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) \ + | BR_PS_16 | BR_V) #define CONFIG_SYS_OR0_PRELIM 0xf8000ff7
-#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | BR_PS_16 | BR_V) +#define CONFIG_SYS_BR1_PRELIM \ + (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_16 | BR_V) #define CONFIG_SYS_OR1_PRELIM 0xf8000ff7
-#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000, \ + CONFIG_SYS_FLASH_BASE_PHYS } #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ #undef CONFIG_SYS_FLASH_CHECKSUM -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
#define CONFIG_SYS_MONITOR_BASE TEXT_BASE /* start of monitor */
@@ -224,7 +229,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #endif
#define CONFIG_SYS_BR3_PRELIM (BR_PHYS_ADDR(PIXIS_BASE_PHYS) | BR_PS_8 | BR_V) -#define CONFIG_SYS_OR3_PRELIM 0xffffeff7 /* 32KB but only 4k mapped */ +#define CONFIG_SYS_OR3_PRELIM 0xffffeff7 /* 32KB but only 4k mapped */
#define PIXIS_ID 0x0 /* Board ID at offset 0 */ #define PIXIS_VER 0x1 /* Board version at offset 1 */ @@ -270,11 +275,12 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
-#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */ +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */
#define CONFIG_SYS_NAND_BASE 0xffa00000 #ifdef CONFIG_PHYS_64BIT @@ -293,42 +299,46 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024)
/* NAND flash config */ -#define CONFIG_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ - | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V) /* valid */ -#define CONFIG_NAND_OR_PRELIM (0xFFFC0000 /* length 256K */ \ - | OR_FCM_PGS /* Large Page*/ \ - | OR_FCM_CSCT \ - | OR_FCM_CST \ - | OR_FCM_CHT \ - | OR_FCM_SCY_1 \ - | OR_FCM_TRLX \ - | OR_FCM_EHTR) - -#define CONFIG_SYS_BR2_PRELIM CONFIG_NAND_BR_PRELIM /* NAND Base Address */ -#define CONFIG_SYS_OR2_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ - -#define CONFIG_SYS_BR4_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x40000))\ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ - | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR4_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ -#define CONFIG_SYS_BR5_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x80000))\ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ - | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR5_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ - -#define CONFIG_SYS_BR6_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0xc0000))\ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ - | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR6_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ +#define CONFIG_NAND_BR_PRELIM \ + (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_NAND_OR_PRELIM (0xFFFC0000 /* length 256K */ \ + | OR_FCM_PGS /* Large Page*/ \ + | OR_FCM_CSCT \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR) + +#define CONFIG_SYS_BR2_PRELIM CONFIG_NAND_BR_PRELIM /* NAND Base Address */ +#define CONFIG_SYS_OR2_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ + +#define CONFIG_SYS_BR4_PRELIM \ + (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x40000)) \ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR4_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ +#define CONFIG_SYS_BR5_PRELIM \ + (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x80000)) \ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR5_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ + +#define CONFIG_SYS_BR6_PRELIM \ + (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0xc0000)) \ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR6_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */
/* Serial Port - controlled on board with jumper J8 * open - index 2 @@ -344,8 +354,8 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200}
-#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600)
/* Use the HUSH parser */ #define CONFIG_SYS_HUSH_PARSER @@ -360,8 +370,8 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_OF_BOARD_SETUP 1 #define CONFIG_OF_STDOUT_VIA_ALIAS 1
-#define CONFIG_SYS_64BIT_STRTOUL 1 -#define CONFIG_SYS_64BIT_VSPRINTF 1 +#define CONFIG_SYS_64BIT_STRTOUL 1 +#define CONFIG_SYS_64BIT_VSPRINTF 1
/* @@ -617,7 +627,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ #define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ #define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ #if defined(CONFIG_CMD_KGDB) @@ -625,9 +635,10 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #else #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) + 16) /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ #define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
/* @@ -635,7 +646,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); * have to be in the first 16 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux */
/* * Internal Definitions @@ -671,7 +682,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_HOSTNAME unknown #define CONFIG_ROOTPATH /opt/nfsroot #define CONFIG_BOOTFILE uImage -#define CONFIG_UBOOTPATH u-boot.bin /* U-Boot image on TFTP server */ +#define CONFIG_UBOOTPATH u-boot.bin /* U-Boot image on TFTP server */
#define CONFIG_SERVERIP 192.168.1.1 #define CONFIG_GATEWAYIP 192.168.1.1
include/configs/MPC8536DS.h | 147 ++++++++++++++++++++++ +-------------------- 1 files changed, 79 insertions(+), 68 deletions(-)
applied to 85xx
- k
Kumar Gala
Mingkai Hu
