[U-Boot] [PATCH 0/3] Cleanup of boards.cfg
This series uses Fabio's patch as a prerequisite: "boards.cfg: Keep the entries sorted" http://patchwork.ozlabs.org/patch/305456/
Please apply it before this series.
Masahiro Yamada (3): cosmetic: boards.cfg: remove a trailing empty line boards.cfg: Place "-" in the 8th field if it is the same as 7th boards.cfg: Delete the equivalent entries
boards.cfg | 91 ++++++++++++++++++++++++++++---------------------------------- 1 file changed, 41 insertions(+), 50 deletions(-)
- Remove a trailing empty line - Add '#' to the empty line between two comment blocks
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
boards.cfg | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 0d655e4..5b6a150 100644 --- a/boards.cfg +++ b/boards.cfg @@ -31,7 +31,7 @@ # For any board without permanent maintainer, please contact # Wolfgang Denk wd@denx.de # And Cc: the u-boot@lists.denx.de mailing list. - +# # The list should be ordered according to the C locale. # # To keep the list formatted and sorted, script tools/reformat.py is available. @@ -1238,4 +1238,3 @@ Orphan powerpc mpc8xx - - genietv Orphan powerpc mpc8xx - - mbx8xx MBX - - Orphan powerpc mpc8xx - - mbx8xx MBX860T - - Orphan powerpc mpc8xx - - nx823 NX823 - - -
The 8th field of boards.cfg takes the form: <board config name>[:comma separated config options]
We should describe explicitely the 8th field only when it is necessary to do so. Specify "-" in the 8th field if it is the same as 7th field.
boards.cfg | 80 +++++++++++++++++++++++++++++++------------------------------- 1 file changed, 40 insertions(+), 40 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 5b6a150..cb049aa 100644 --- a/boards.cfg +++ b/boards.cfg @@ -59,11 +59,11 @@ Active arm arm720t - armltd integrator Active arm arm920t - armltd integrator integratorap_cm920t integratorap:CM920T Linus Walleij linus.walleij@linaro.org Active arm arm920t - armltd integrator integratorcp_cm920t integratorcp:CM920T Linus Walleij linus.walleij@linaro.org Active arm arm920t a320 faraday - a320evb - Po-Yu Chuang ratbert@faraday-tech.com -Active arm arm920t at91 atmel at91rm9200ek at91rm9200ek at91rm9200ek Andreas Bießmann andreas.devel@gmail.com +Active arm arm920t at91 atmel at91rm9200ek at91rm9200ek - Andreas Bießmann andreas.devel@gmail.com Active arm arm920t at91 atmel at91rm9200ek at91rm9200ek_ram at91rm9200ek:RAMBOOT Andreas Bießmann andreas.devel@gmail.com -Active arm arm920t at91 BuS eb_cpux9k2 eb_cpux9k2 eb_cpux9k2 Jens Scharsig esw@bus-elektronik.de +Active arm arm920t at91 BuS eb_cpux9k2 eb_cpux9k2 - Jens Scharsig esw@bus-elektronik.de Active arm arm920t at91 BuS eb_cpux9k2 eb_cpux9k2_ram eb_cpux9k2:RAMBOOT Jens Scharsig esw@bus-elektronik.de -Active arm arm920t at91 eukrea cpuat91 cpuat91 cpuat91 Eric Benard eric@eukrea.com +Active arm arm920t at91 eukrea cpuat91 cpuat91 - Eric Benard eric@eukrea.com Active arm arm920t at91 eukrea cpuat91 cpuat91_ram cpuat91:RAMBOOT Eric Benard eric@eukrea.com Active arm arm920t imx - - mx1ads - - Active arm arm920t imx - - scb9328 - Torsten Koschorrek koschorrek@synertronixx.de @@ -143,7 +143,7 @@ Active arm arm926ejs at91 siemens taurus Active arm arm926ejs at91 siemens taurus taurus taurus:AT91SAM9G20,MACH_TYPE=2067,BOARD_TAURUS Heiko Schocher hs@denx.de Active arm arm926ejs at91 taskit stamp9g20 portuxg20 stamp9g20:AT91SAM9G20,PORTUXG20 Markus Hubig mhubig@imko.de Active arm arm926ejs at91 taskit stamp9g20 stamp9g20 stamp9g20:AT91SAM9G20 Markus Hubig mhubig@imko.de -Active arm arm926ejs davinci ait cam_enc_4xx cam_enc_4xx cam_enc_4xx Heiko Schocher hs@denx.de +Active arm arm926ejs davinci ait cam_enc_4xx cam_enc_4xx - Heiko Schocher hs@denx.de Active arm arm926ejs davinci Barix ipam390 ipam390 - Heiko Schocher hs@denx.de Active arm arm926ejs davinci davinci da8xxevm da830evm - Nick Thompson nick.thompson@gefanuc.com Active arm arm926ejs davinci davinci da8xxevm da850_am18xxevm da850evm:DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50 Sudhakar Rajashekhara sudhakar.raj@ti.com @@ -203,15 +203,15 @@ Active arm arm926ejs mx25 syteco zmx25 Active arm arm926ejs mx27 armadeus apf27 apf27 - Philippe Reynes tremyfr@yahoo.fr:Eric Jarrige eric.jarrige@armadeus.org Active arm arm926ejs mx27 logicpd imx27lite imx27lite - Wolfgang Denk wd@denx.de Active arm arm926ejs mx27 logicpd imx27lite magnesium - Heiko Schocher hs@denx.de -Active arm arm926ejs mxs bluegiga apx4devkit apx4devkit apx4devkit Lauri Hintsala lauri.hintsala@bluegiga.com +Active arm arm926ejs mxs bluegiga apx4devkit apx4devkit - Lauri Hintsala lauri.hintsala@bluegiga.com Active arm arm926ejs mxs creative xfi3 xfi3 - Marek Vasut marek.vasut@gmail.com -Active arm arm926ejs mxs denx m28evk m28evk m28evk Marek Vasut marek.vasut@gmail.com -Active arm arm926ejs mxs freescale mx23evk mx23evk mx23evk Otavio Salvador otavio@ossystems.com.br +Active arm arm926ejs mxs denx m28evk m28evk - Marek Vasut marek.vasut@gmail.com +Active arm arm926ejs mxs freescale mx23evk mx23evk - Otavio Salvador otavio@ossystems.com.br Active arm arm926ejs mxs freescale mx28evk mx28evk mx28evk:ENV_IS_IN_MMC Fabio Estevam fabio.estevam@freescale.com Active arm arm926ejs mxs freescale mx28evk mx28evk_auart_console mx28evk:MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC Fabio Estevam fabio.estevam@freescale.com Active arm arm926ejs mxs freescale mx28evk mx28evk_nand mx28evk:ENV_IS_IN_NAND Fabio Estevam fabio.estevam@freescale.com -Active arm arm926ejs mxs olimex mx23_olinuxino mx23_olinuxino mx23_olinuxino Marek Vasut marek.vasut@gmail.com -Active arm arm926ejs mxs ppcag bg0900 bg0900 bg0900 Marek Vasut marex@denx.de +Active arm arm926ejs mxs olimex mx23_olinuxino mx23_olinuxino - Marek Vasut marek.vasut@gmail.com +Active arm arm926ejs mxs ppcag bg0900 bg0900 - Marek Vasut marex@denx.de Active arm arm926ejs mxs sandisk sansa_fuze_plus sansa_fuze_plus - Marek Vasut marek.vasut@gmail.com Active arm arm926ejs mxs schulercontrol sc_sps_1 sc_sps_1 - Marek Vasut marek.vasut@gmail.com Active arm arm926ejs nomadik st nhk8815 nhk8815 - Nomadik Linux Team STN_WMM_nomadik_linux@list.st.com:Alessandro Rubini rubini@unipv.it @@ -219,7 +219,7 @@ Active arm arm926ejs nomadik st nhk8815 Active arm arm926ejs omap ti - omap5912osk - Rishi Bhattacharya rishi@ti.com Active arm arm926ejs orion5x LaCie - edminiv2 - Albert ARIBAUD albert.u.boot@aribaud.net Active arm arm926ejs pantheon Marvell - dkb - Lei Wen leiwen@marvell.com -Active arm arm926ejs spear spear - x600 x600 Stefan Roese sr@denx.de +Active arm arm926ejs spear spear - x600 - Stefan Roese sr@denx.de Active arm arm926ejs spear spear spear300 spear300 spear3xx_evb:spear300 Vipin Kumar vipin.kumar@st.com Active arm arm926ejs spear spear spear300 spear300_nand spear3xx_evb:spear300,nand - Active arm arm926ejs spear spear spear300 spear300_usbtty spear3xx_evb:spear300,usbtty - @@ -248,7 +248,7 @@ Active arm arm946es - armltd integrator Active arm armv7 - armltd vexpress vexpress_ca15_tc2 - - Active arm armv7 - armltd vexpress vexpress_ca5x2 - Matt Waddel matt.waddel@linaro.org Active arm armv7 - armltd vexpress vexpress_ca9x4 - Matt Waddel matt.waddel@linaro.org -Active arm armv7 am33xx compulab cm_t335 cm_t335 cm_t335 Igor Grinberg grinberg@compulab.co.il +Active arm armv7 am33xx compulab cm_t335 cm_t335 - Igor Grinberg grinberg@compulab.co.il Active arm armv7 am33xx isee igep0033 am335x_igep0033 - Enric Balletbo i Serra eballetbo@iseebcn.com Active arm armv7 am33xx phytec pcm051 pcm051_rev1 pcm051:REV1 Lars Poeschel poeschel@lemonage.de Active arm armv7 am33xx phytec pcm051 pcm051_rev3 pcm051:REV3 Lars Poeschel poeschel@lemonage.de @@ -568,7 +568,7 @@ Active powerpc mpc5xxx - - icecube Active powerpc mpc5xxx - - icecube lite5200b IceCube:MPC5200_DDR,LITE5200B - Active powerpc mpc5xxx - - icecube lite5200b_LOWBOOT IceCube:MPC5200_DDR,LITE5200B,SYS_TEXT_BASE=0xFF000000 - Active powerpc mpc5xxx - - icecube lite5200b_PM IceCube:MPC5200_DDR,LITE5200B,LITE5200B_PM - -Active powerpc mpc5xxx - - mcc200 mcc200 mcc200 - +Active powerpc mpc5xxx - - mcc200 mcc200 - - Active powerpc mpc5xxx - - mcc200 mcc200_COM12 mcc200:CONSOLE_COM12 - Active powerpc mpc5xxx - - mcc200 mcc200_COM12_highboot mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000 - Active powerpc mpc5xxx - - mcc200 mcc200_COM12_highboot_SDRAM mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM - @@ -613,17 +613,17 @@ Active powerpc mpc5xxx - manroland - Active powerpc mpc5xxx - manroland - uc101 - Heiko Schocher hs@denx.de Active powerpc mpc5xxx - matrix_vision mvbc_p MVBC_P MVBC_P:MVBC_P Andre Schwarz andre.schwarz@matrix-vision.de Active powerpc mpc5xxx - matrix_vision mvsmr MVSMR - Andre Schwarz andre.schwarz@matrix-vision.de -Active powerpc mpc5xxx - phytec pcm030 pcm030 pcm030 Jon Smirl jonsmirl@gmail.com +Active powerpc mpc5xxx - phytec pcm030 pcm030 - Jon Smirl jonsmirl@gmail.com Active powerpc mpc5xxx - phytec pcm030 pcm030_LOWBOOT pcm030:SYS_TEXT_BASE=0xFF000000 Jon Smirl jonsmirl@gmail.com Active powerpc mpc5xxx - tqc tqm5200 aev - - Active powerpc mpc5xxx - tqc tqm5200 cam5200 TQM5200:CAM5200,TQM5200S,TQM5200_B - Active powerpc mpc5xxx - tqc tqm5200 cam5200_niosflash TQM5200:CAM5200,TQM5200S,TQM5200_B,CAM5200_NIOSFLASH - -Active powerpc mpc5xxx - tqc tqm5200 charon charon Heiko Schocher hs@denx.de +Active powerpc mpc5xxx - tqc tqm5200 charon - Heiko Schocher hs@denx.de Active powerpc mpc5xxx - tqc tqm5200 fo300 TQM5200:FO300 - Active powerpc mpc5xxx - tqc tqm5200 MiniFAP TQM5200:MINIFAP - Active powerpc mpc5xxx - tqc tqm5200 TB5200 - - Active powerpc mpc5xxx - tqc tqm5200 TB5200_B TB5200:TQM5200_B - -Active powerpc mpc5xxx - tqc tqm5200 TQM5200 TQM5200: - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200 - - Active powerpc mpc5xxx - tqc tqm5200 TQM5200_B TQM5200:TQM5200_B - Active powerpc mpc5xxx - tqc tqm5200 TQM5200_B_HIGHBOOT TQM5200:TQM5200_B,SYS_TEXT_BASE=0xFFF00000 - Active powerpc mpc5xxx - tqc tqm5200 TQM5200_STK100 TQM5200:STK52XX_REV100 - @@ -631,7 +631,7 @@ Active powerpc mpc5xxx - tqc tqm5200 Active powerpc mpc5xxx - tqc tqm5200 TQM5200S_HIGHBOOT TQM5200:TQM5200_B,TQM5200S,SYS_TEXT_BASE=0xFFF00000 - Active powerpc mpc824x - - - utx8245 - Greg Allen gallen@arlut.utexas.edu Active powerpc mpc824x - - a3000 A3000 - - -Active powerpc mpc824x - - cpc45 CPC45 CPC45 Josef Wagner Wagner@Microsys.de +Active powerpc mpc824x - - cpc45 CPC45 - Josef Wagner Wagner@Microsys.de Active powerpc mpc824x - - cpc45 CPC45_ROMBOOT CPC45:BOOT_ROM Josef Wagner Wagner@Microsys.de Active powerpc mpc824x - - cu824 CU824 - Wolfgang Denk wd@denx.de Active powerpc mpc824x - - eXalion eXalion - Torsten Demke torsten.demke@fci.com @@ -651,9 +651,9 @@ Active powerpc mpc8260 - - - Active powerpc mpc8260 - - - ppmc8260 - Brad Kemp Brad.Kemp@seranoa.com Active powerpc mpc8260 - - - sacsng - Jerry Van Baren gerald.vanbaren@smiths-aerospace.com Active powerpc mpc8260 - - cogent cogent_mpc8260 - Murray Jensen Murray.Jensen@csiro.au -Active powerpc mpc8260 - - cpu86 CPU86 CPU86 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - cpu86 CPU86 - Wolfgang Denk wd@denx.de Active powerpc mpc8260 - - cpu86 CPU86_ROMBOOT CPU86:BOOT_ROM Wolfgang Denk wd@denx.de -Active powerpc mpc8260 - - cpu87 CPU87 CPU87 - +Active powerpc mpc8260 - - cpu87 CPU87 - - Active powerpc mpc8260 - - cpu87 CPU87_ROMBOOT CPU87:BOOT_ROM - Active powerpc mpc8260 - - ep8248 ep8248 - Yuli Barcohen yuli@arabellasw.com Active powerpc mpc8260 - - ep8248 ep8248E ep8248 Yuli Barcohen yuli@arabellasw.com @@ -671,11 +671,11 @@ Active powerpc mpc8260 - - pm826 Active powerpc mpc8260 - - pm826 PM826_BIGFLASH PM826:FLASH_32MB,SYS_TEXT_BASE=0x40000000 Wolfgang Denk wd@denx.de Active powerpc mpc8260 - - pm826 PM826_ROMBOOT PM826:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de Active powerpc mpc8260 - - pm826 PM826_ROMBOOT_BIGFLASH PM826:BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de -Active powerpc mpc8260 - - pm828 PM828 PM828 - +Active powerpc mpc8260 - - pm828 PM828 - - Active powerpc mpc8260 - - pm828 PM828_PCI PM828:PCI - Active powerpc mpc8260 - - pm828 PM828_ROMBOOT PM828:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 - Active powerpc mpc8260 - - pm828 PM828_ROMBOOT_PCI PM828:PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000 - -Active powerpc mpc8260 - - rattler Rattler Rattler Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - rattler Rattler - Yuli Barcohen yuli@arabellasw.com Active powerpc mpc8260 - - rattler Rattler8248 Rattler:MPC8248 Yuli Barcohen yuli@arabellasw.com Active powerpc mpc8260 - - zpc1900 ZPC1900 - Yuli Barcohen yuli@arabellasw.com Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS Yuli Barcohen yuli@arabellasw.com @@ -711,21 +711,21 @@ Active powerpc mpc8260 - tqc tqm8260 Active powerpc mpc8260 - tqc tqm8260 TQM8265_AA TQM8260:MPC8265,300MHz,BUSMODE_60x Wolfgang Denk wd@denx.de Active powerpc mpc8260 - tqc tqm8272 TQM8272 - - Active powerpc mpc83xx - - - mpc8308_p1m - Ilya Yanok yanok@emcraft.com -Active powerpc mpc83xx - - sbc8349 sbc8349 sbc8349 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc83xx - - sbc8349 sbc8349 - Paul Gortmaker paul.gortmaker@windriver.com Active powerpc mpc83xx - - sbc8349 sbc8349_PCI_33 sbc8349:PCI,PCI_33M Paul Gortmaker paul.gortmaker@windriver.com Active powerpc mpc83xx - - sbc8349 sbc8349_PCI_66 sbc8349:PCI,PCI_66M Paul Gortmaker paul.gortmaker@windriver.com Active powerpc mpc83xx - - ve8313 ve8313 - Heiko Schocher hs@denx.de Active powerpc mpc83xx - esd vme8349 caddy2 vme8349:CADDY2 Reinhard Arlt reinhard.arlt@esd-electronics.com -Active powerpc mpc83xx - esd vme8349 vme8349 vme8349 Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc83xx - esd vme8349 vme8349 - Reinhard Arlt reinhard.arlt@esd-electronics.com Active powerpc mpc83xx - freescale mpc8308rdb MPC8308RDB - Ilya Yanok yanok@emcraft.com Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_33 MPC8313ERDB:SYS_33MHZ - Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_66 MPC8313ERDB:SYS_66MHZ - Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_NAND_33 MPC8313ERDB:SYS_33MHZ,NAND - Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_NAND_66 MPC8313ERDB:SYS_66MHZ,NAND - -Active powerpc mpc83xx - freescale mpc8315erdb MPC8315ERDB MPC8315ERDB Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8315erdb MPC8315ERDB - Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc8315erdb MPC8315ERDB_NAND MPC8315ERDB:NAND_U_BOOT Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc8323erdb MPC8323ERDB - Michael Barkowski michael.barkowski@freescale.com -Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS MPC832XEMDS: Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS - Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_ATM MPC832XEMDS:PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_HOST_33 MPC832XEMDS:PCI,PCI_33M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_HOST_66 MPC832XEMDS:PCI,PCI_66M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com @@ -744,10 +744,10 @@ Active powerpc mpc83xx - freescale mpc8360emds Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_HOST_33 MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_HOST_66 MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_SLAVE MPC8360EMDS:CLKIN_66MHZ,PCI,PCISLAVE Dave Liu daveliu@freescale.com -Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK MPC8360ERDK Anton Vorontsov avorontsov@ru.mvista.com +Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK - Anton Vorontsov avorontsov@ru.mvista.com Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK_33 MPC8360ERDK:CLKIN_33MHZ Anton Vorontsov avorontsov@ru.mvista.com Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK_66 MPC8360ERDK Anton Vorontsov avorontsov@ru.mvista.com -Active powerpc mpc83xx - freescale mpc837xemds MPC837XEMDS MPC837XEMDS Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc837xemds MPC837XEMDS - Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc837xemds MPC837XEMDS_HOST MPC837XEMDS:PCI Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc837xerdb MPC837XERDB - Joe D'Abbraccio ljd015@freescale.com Active powerpc mpc83xx - keymile km83xx kmcoge5ne km8360:KMCOGE5NE Holger Brunck holger.brunck@keymile.com @@ -763,7 +763,7 @@ Active powerpc mpc83xx - matrix_vision mvblm7 Active powerpc mpc83xx - sheldon simpc8313 SIMPC8313_LP SIMPC8313:NAND_LP Ron Madrid info@sheldoninst.com Active powerpc mpc83xx - sheldon simpc8313 SIMPC8313_SP SIMPC8313:NAND_SP Ron Madrid info@sheldoninst.com Active powerpc mpc83xx - tqc tqm834x TQM834x - - -Active powerpc mpc85xx - - sbc8548 sbc8548 sbc8548 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - sbc8548 sbc8548 - Paul Gortmaker paul.gortmaker@windriver.com Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_33 sbc8548:PCI,33 Paul Gortmaker paul.gortmaker@windriver.com Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_33_PCIE sbc8548:PCI,33,PCIE Paul Gortmaker paul.gortmaker@windriver.com Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_66 sbc8548:PCI,66 Paul Gortmaker paul.gortmaker@windriver.com @@ -812,26 +812,26 @@ Active powerpc mpc85xx - freescale corenet_ds Active powerpc mpc85xx - freescale corenet_ds P5040DS_NAND P5040DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - Active powerpc mpc85xx - freescale corenet_ds P5040DS_SDCARD P5040DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - Active powerpc mpc85xx - freescale corenet_ds P5040DS_SPIFLASH P5040DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - -Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS MPC8536DS - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS - - Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_36BIT MPC8536DS:36BIT - Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_NAND MPC8536DS:NAND - Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_SDCARD MPC8536DS:SDCARD - Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_SPIFLASH MPC8536DS:SPIFLASH - Active powerpc mpc85xx - freescale mpc8540ads MPC8540ADS - Kumar Gala kumar.gala@freescale.com -Active powerpc mpc85xx - freescale mpc8541cds MPC8541CDS MPC8541CDS Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8541cds MPC8541CDS - Kumar Gala kumar.gala@freescale.com Active powerpc mpc85xx - freescale mpc8541cds MPC8541CDS_legacy MPC8541CDS:LEGACY Kumar Gala kumar.gala@freescale.com Active powerpc mpc85xx - freescale mpc8544ds MPC8544DS - - -Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS MPC8548CDS - +Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS - - Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS_36BIT MPC8548CDS:36BIT - Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS_legacy MPC8548CDS:LEGACY - -Active powerpc mpc85xx - freescale mpc8555cds MPC8555CDS MPC8555CDS Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8555cds MPC8555CDS - Kumar Gala kumar.gala@freescale.com Active powerpc mpc85xx - freescale mpc8555cds MPC8555CDS_legacy MPC8555CDS:LEGACY Kumar Gala kumar.gala@freescale.com Active powerpc mpc85xx - freescale mpc8560ads MPC8560ADS - Kumar Gala kumar.gala@freescale.com Active powerpc mpc85xx - freescale mpc8568mds MPC8568MDS - - -Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS MPC8569MDS - +Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS - - Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS_ATM MPC8569MDS:ATM - Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS_NAND MPC8569MDS:NAND - -Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS MPC8572DS - +Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS - - Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS_36BIT MPC8572DS:36BIT - Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS_NAND MPC8572DS:NAND - Active powerpc mpc85xx - freescale p1010rdb P1010RDB-PA_36BIT_NAND P1010RDB:P1010RDB_PA,36BIT,NAND - @@ -870,8 +870,8 @@ Active powerpc mpc85xx - freescale p1022ds Active powerpc mpc85xx - freescale p1022ds P1022DS_NAND P1022DS:NAND Timur Tabi timur@freescale.com Active powerpc mpc85xx - freescale p1022ds P1022DS_SDCARD P1022DS:SDCARD Timur Tabi timur@freescale.com Active powerpc mpc85xx - freescale p1022ds P1022DS_SPIFLASH P1022DS:SPIFLASH Timur Tabi timur@freescale.com -Active powerpc mpc85xx - freescale p1023rdb P1023RDB P1023RDB - -Active powerpc mpc85xx - freescale p1023rds P1023RDS P1023RDS Roy Zang tie-fei.zang@freescale.com +Active powerpc mpc85xx - freescale p1023rdb P1023RDB - - +Active powerpc mpc85xx - freescale p1023rds P1023RDS - Roy Zang tie-fei.zang@freescale.com Active powerpc mpc85xx - freescale p1023rds P1023RDS_NAND P1023RDS:NAND Roy Zang tie-fei.zang@freescale.com Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB P1_P2_RDB:P1011RDB - Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_36BIT P1_P2_RDB:P1011RDB,36BIT - @@ -983,14 +983,14 @@ Active powerpc mpc85xx - gdsys p1022 Active powerpc mpc85xx - gdsys p1022 controlcenterd_TRAILBLAZER_DEVELOP controlcenterd:TRAILBLAZER,SPIFLASH,DEVELOP Dirk Eibach eibach@gdsys.de Active powerpc mpc85xx - keymile kmp204x kmlion1 kmp204x:KMLION1 Valentin Longchamp valentin.longchamp@keymile.com Active powerpc mpc85xx - stx stxgp3 stxgp3 - Dan Malek dan@embeddedalley.com -Active powerpc mpc85xx - stx stxssa stxssa stxssa Dan Malek dan@embeddedalley.com +Active powerpc mpc85xx - stx stxssa stxssa - Dan Malek dan@embeddedalley.com Active powerpc mpc85xx - stx stxssa stxssa_4M stxssa:STXSSA_4M Dan Malek dan@embeddedalley.com Active powerpc mpc85xx - xes - xpedite520x - - Active powerpc mpc85xx - xes - xpedite537x - - Active powerpc mpc85xx - xes - xpedite550x - - Active powerpc mpc86xx - - - sbc8641d - Paul Gortmaker paul.gortmaker@windriver.com Active powerpc mpc86xx - freescale mpc8610hpcd MPC8610HPCD - - -Active powerpc mpc86xx - freescale mpc8641hpcn MPC8641HPCN MPC8641HPCN Kumar Gala kumar.gala@freescale.com +Active powerpc mpc86xx - freescale mpc8641hpcn MPC8641HPCN - Kumar Gala kumar.gala@freescale.com Active powerpc mpc86xx - freescale mpc8641hpcn MPC8641HPCN_36BIT MPC8641HPCN:PHYS_64BIT Kumar Gala kumar.gala@freescale.com Active powerpc mpc86xx - xes - xpedite517x - - Active powerpc mpc8xx - - - hermes - Wolfgang Denk wd@denx.de @@ -1022,7 +1022,7 @@ Active powerpc mpc8xx - - ivm Active powerpc mpc8xx - - ivm IVMS8_256 IVMS8:IVMS8_64M Wolfgang Denk wd@denx.de Active powerpc mpc8xx - - netphone NETPHONE NETPHONE:NETPHONE_VERSION=1 - Active powerpc mpc8xx - - netphone NETPHONE_V2 NETPHONE:NETPHONE_VERSION=2 - -Active powerpc mpc8xx - - netta NETTA NETTA - +Active powerpc mpc8xx - - netta NETTA - - Active powerpc mpc8xx - - netta NETTA_6412 NETTA:NETTA_6412=1 - Active powerpc mpc8xx - - netta NETTA_6412_SWAPHOOK NETTA:NETTA_6412=1,NETTA_SWAPHOOK=1 - Active powerpc mpc8xx - - netta NETTA_ISDN NETTA:NETTA_ISDN=1 - @@ -1036,7 +1036,7 @@ Active powerpc mpc8xx - - netvia Active powerpc mpc8xx - - netvia NETVIA_V2 NETVIA:NETVIA_VERSION=2 Pantelis Antoniou panto@intracom.gr Active powerpc mpc8xx - - r360mpi R360MPI - Wolfgang Denk wd@denx.de Active powerpc mpc8xx - - rbc823 RBC823 - - -Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW RPXlite_DW - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW - - Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_64 RPXlite_DW:RPXlite_64MHz - Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_64_LCD RPXlite_DW:RPXlite_64MHz,LCD,NEC_NL6448BC20 - Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_LCD RPXlite_DW:LCD,NEC_NL6448BC20 - @@ -1223,7 +1223,7 @@ Active x86 x86 coreboot chromebook-x86 coreboot Orphan arm arm1136 mx31 - imx31_phycore imx31_phycore_eet imx31_phycore:IMX31_PHYCORE_EET (resigned) Guennadi Liakhovetski g.liakhovetski@gmx.de Orphan arm arm1136 mx31 freescale - mx31ads - (resigned) Guennadi Liakhovetski g.liakhovetski@gmx.de Orphan arm pxa - - - lubbock - (dead address) Kyle Harris kharris@nexus-tech.net -Orphan powerpc 74xx_7xx - - evb64260 EVB64260 EVB64260 - +Orphan powerpc 74xx_7xx - - evb64260 EVB64260 - - Orphan powerpc 74xx_7xx - - evb64260 EVB64260_750CX EVB64260 Eran Man eran@nbase.co.il Orphan powerpc mpc824x - - mousse MOUSSE - - Orphan powerpc mpc8260 - - - rsdproto - -
There are some entries which produce the same binaries as other entries: - Lite5200 is equivalent to icecube_5200 - Lite5200_LOWBOOT is equivalent to icecube_5200_LOWBOOT - Lite5200_LOWBOOT08 is equivalent to icecube_5200_LOWBOOT08 - ep8248E is equivalent to ep8248 - MPC8360ERDK_66 is equivalent to MPC8360ERDK - Adder87x/AdderUSB is equivalent to Adder - EVB64260_750CS is equivalent to EVB64260
boards.cfg | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/boards.cfg b/boards.cfg index cb049aa..0726fc3 100644 --- a/boards.cfg +++ b/boards.cfg @@ -562,9 +562,6 @@ Active powerpc mpc5xxx - - icecube Active powerpc mpc5xxx - - icecube icecube_5200_DDR_LOWBOOT08 IceCube:SYS_TEXT_BASE=0xFF800000,MPC5200_DDR - Active powerpc mpc5xxx - - icecube icecube_5200_LOWBOOT IceCube:SYS_TEXT_BASE=0xFF000000 - Active powerpc mpc5xxx - - icecube icecube_5200_LOWBOOT08 IceCube:SYS_TEXT_BASE=0xFF800000 - -Active powerpc mpc5xxx - - icecube Lite5200 IceCube - -Active powerpc mpc5xxx - - icecube Lite5200_LOWBOOT IceCube:SYS_TEXT_BASE=0xFF000000 - -Active powerpc mpc5xxx - - icecube Lite5200_LOWBOOT08 IceCube:SYS_TEXT_BASE=0xFF800000 - Active powerpc mpc5xxx - - icecube lite5200b IceCube:MPC5200_DDR,LITE5200B - Active powerpc mpc5xxx - - icecube lite5200b_LOWBOOT IceCube:MPC5200_DDR,LITE5200B,SYS_TEXT_BASE=0xFF000000 - Active powerpc mpc5xxx - - icecube lite5200b_PM IceCube:MPC5200_DDR,LITE5200B,LITE5200B_PM - @@ -656,7 +653,6 @@ Active powerpc mpc8260 - - cpu86 Active powerpc mpc8260 - - cpu87 CPU87 - - Active powerpc mpc8260 - - cpu87 CPU87_ROMBOOT CPU87:BOOT_ROM - Active powerpc mpc8260 - - ep8248 ep8248 - Yuli Barcohen yuli@arabellasw.com -Active powerpc mpc8260 - - ep8248 ep8248E ep8248 Yuli Barcohen yuli@arabellasw.com Active powerpc mpc8260 - - ids8247 IDS8247 - Heiko Schocher hs@denx.de Active powerpc mpc8260 - - iphase4539 IPHASE4539 - Wolfgang Grandegger wg@denx.de Active powerpc mpc8260 - - ispan ISPAN - Yuli Barcohen yuli@arabellasw.com @@ -746,7 +742,6 @@ Active powerpc mpc83xx - freescale mpc8360emds Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_SLAVE MPC8360EMDS:CLKIN_66MHZ,PCI,PCISLAVE Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK - Anton Vorontsov avorontsov@ru.mvista.com Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK_33 MPC8360ERDK:CLKIN_33MHZ Anton Vorontsov avorontsov@ru.mvista.com -Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK_66 MPC8360ERDK Anton Vorontsov avorontsov@ru.mvista.com Active powerpc mpc83xx - freescale mpc837xemds MPC837XEMDS - Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc837xemds MPC837XEMDS_HOST MPC837XEMDS:PCI Dave Liu daveliu@freescale.com Active powerpc mpc83xx - freescale mpc837xerdb MPC837XERDB - Joe D'Abbraccio ljd015@freescale.com @@ -1001,9 +996,7 @@ Active powerpc mpc8xx - - - Active powerpc mpc8xx - - - svm_sc8xx - John Zhan zhanz@sinovee.com Active powerpc mpc8xx - - - v37 - - Active powerpc mpc8xx - - adder Adder - Yuli Barcohen yuli@arabellasw.com -Active powerpc mpc8xx - - adder Adder87x Adder Yuli Barcohen yuli@arabellasw.com Active powerpc mpc8xx - - adder AdderII Adder:MPC852T Yuli Barcohen yuli@arabellasw.com -Active powerpc mpc8xx - - adder AdderUSB Adder Yuli Barcohen yuli@arabellasw.com Active powerpc mpc8xx - - cogent cogent_mpc8xx - Murray Jensen Murray.Jensen@csiro.au Active powerpc mpc8xx - - esteem192e ESTEEM192E - Conn Clark clark@esteem.com Active powerpc mpc8xx - - fads MPC86xADS - - @@ -1224,7 +1217,6 @@ Orphan arm arm1136 mx31 - imx31_phycore Orphan arm arm1136 mx31 freescale - mx31ads - (resigned) Guennadi Liakhovetski g.liakhovetski@gmx.de Orphan arm pxa - - - lubbock - (dead address) Kyle Harris kharris@nexus-tech.net Orphan powerpc 74xx_7xx - - evb64260 EVB64260 - - -Orphan powerpc 74xx_7xx - - evb64260 EVB64260_750CX EVB64260 Eran Man eran@nbase.co.il Orphan powerpc mpc824x - - mousse MOUSSE - - Orphan powerpc mpc8260 - - - rsdproto - - Orphan powerpc mpc8260 - - rpxsuper RPXsuper - -
Dear Masahiro Yamada,
In message 1389085642-28400-4-git-send-email-yamada.m@jp.panasonic.com you wrote:
I cannot comment for the other boards, but please do not delete the Lite5200* entries. This name is what is actually referenced in misc documentation, so we should keep it - very few users will actually remove the IceCube board today, and even fewer will know that they have to chose this name if they want to configure for a Lite5200 board.
Thanks.
Hello Wolfgang
Thanks for comments.
I posted version2.
Best Regards Masahiro Yamada
Masahiro Yamada
