[PATCH 5/8] net: dc2114x: remove unused lines and change the var and print types
This commit fixes a problem that even though the network card does not report any issues in transmitting a setup frame, the driver prints the error status every time. Let's set it for debug use.
Signed-off-by: Hanyuan Zhao zhaohy22@mails.tsinghua.edu.cn --- drivers/net/dc2114x.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 0b3000cc1d..8a285742a1 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -311,7 +311,7 @@ static void send_setup_frame(struct dc2114x_priv *priv) }
priv->tx_ring[priv->tx_new].buf = cpu_to_le32(phys_to_bus(priv->devno, - (u32)&setup_frame[0])); + (phys_addr_t)&setup_frame[0])); priv->tx_ring[priv->tx_new].des1 = cpu_to_le32(TD_TER | TD_SET | SETUP_FRAME_LEN); priv->tx_ring[priv->tx_new].status = cpu_to_le32(T_OWN);
@@ -326,7 +326,7 @@ static void send_setup_frame(struct dc2114x_priv *priv) }
if (le32_to_cpu(priv->tx_ring[priv->tx_new].status) != 0x7FFFFFFF) { - printf("TX error status2 = 0x%08X\n", + debug("TX error status2 = 0x%08X\n", le32_to_cpu(priv->tx_ring[priv->tx_new].status)); }
@@ -355,7 +355,7 @@ static int dc21x4x_send_common(struct dc2114x_priv *priv, void *packet, int leng flush_dcache_range((phys_addr_t)packet, (phys_addr_t)(packet + RX_BUFF_SZ));
priv->tx_ring[priv->tx_new].buf = cpu_to_le32(phys_to_bus(priv->devno, - (u32)packet)); + (phys_addr_t)packet)); priv->tx_ring[priv->tx_new].des1 = cpu_to_le32(TD_TER | TD_LS | TD_FS | length); priv->tx_ring[priv->tx_new].status = cpu_to_le32(T_OWN);
@@ -426,7 +426,7 @@ static int dc21x4x_init_common(struct dc2114x_priv *priv) priv->rx_ring[i].status = cpu_to_le32(R_OWN); priv->rx_ring[i].des1 = cpu_to_le32(RX_BUFF_SZ); priv->rx_ring[i].buf = cpu_to_le32(phys_to_bus(priv->devno, - (u32)net_rx_packets[i])); + (phys_addr_t)net_rx_packets[i])); priv->rx_ring[i].next = 0; }
@@ -445,9 +445,9 @@ static int dc21x4x_init_common(struct dc2114x_priv *priv) priv->tx_ring[priv->tx_ring_size - 1].des1 |= cpu_to_le32(TD_TER);
/* Tell the adapter where the TX/RX rings are located. */ - dc2114x_outl(priv, phys_to_bus(priv->devno, (u32)&priv->rx_ring), + dc2114x_outl(priv, phys_to_bus(priv->devno, (phys_addr_t)priv->rx_ring), DE4X5_RRBA); - dc2114x_outl(priv, phys_to_bus(priv->devno, (u32)&priv->tx_ring), + dc2114x_outl(priv, phys_to_bus(priv->devno, (phys_addr_t)priv->tx_ring), DE4X5_TRBA);
start_de4x5(priv); @@ -493,7 +493,6 @@ static struct pci_device_id supported[] = {
static int dc2114x_start(struct udevice *dev) { - struct eth_pdata *plat = dev_get_plat(dev); struct dc2114x_priv *priv = dev_get_priv(dev); int rval;
Hanyuan Zhao
