[U-Boot] [PATCH 0/3] i.mx6 (sabre auto) fixes for 2019.07
To make things easier i've split the `Enable usage of SDP for i.MX6 Sabre Auto Boards` patchset i sent yesterday up so it'll be hopefully easier to merge.
The first two are the same as yesterday (Thanks Peng for the review). The last one is new and fixes regressions in usb gadget usage of various mx6 board that were converted to DM_USB.
Sjoerd Simons (3): mx6sabreauto: Select pinctrl driver mx6sabreauto: set SYS_MALLOC_F for video arm: dts: imx6qdl-u-boot: Alias usb0 to usbotg
arch/arm/dts/imx6qdl-u-boot.dtsi | 4 ++++ configs/mx6sabreauto_defconfig | 4 +++- 2 files changed, 7 insertions(+), 1 deletion(-)
With the conversion to DM we should select the pinctrl driver.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Reviewed-by: Peng Fan peng.fan@nxp.com
configs/mx6sabreauto_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index d0f302e9d0..ef965a30e6 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -70,6 +70,8 @@ CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y CONFIG_DM_REGULATOR=y CONFIG_SPI=y CONFIG_DM_SPI=y
With the conversion to DM we should select the pinctrl driver. Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Reviewed-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Sabre Auto boards currently hang with: ``` U-Boot 2019.07-rc3-00057-gc41940c406 (Jun 03 2019 - 14:42:41 +0200)
CPU: Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz) CPU: Automotive temperature grade (-40C to 125C)Reset cause: WDOG Model: Freescale i.MX6 Quad Plus SABRE Automotive Board Board: MX6Q-Sabreauto revA I2C: ready DRAM: 2 GiB Video device 'ipu@2400000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Video device 'ipu@2800000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Some drivers failed to bind Error binding driver 'generic_simple_bus': -28 Some drivers failed to bind initcall sequence 8ffe00b8 failed at call 1780e93b (err=-28) ```
Set SYS_MALLOC_F_LEN to reserve_video to work.
This is similar to the change Peng Fan did for mx6sabresd (9002e735e717)
configs/mx6sabreauto_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index ef965a30e6..dc758d7aaf 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_MX6SABREAUTO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -11,7 +12,6 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_NXP_BOARD_REVISION=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y
U-Boot 2019.07-rc3-00057-gc41940c406 (Jun 03 2019 - 14:42:41 +0200) CPU: Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz) CPU: Automotive temperature grade (-40C to 125C)Reset cause: WDOG Model: Freescale i.MX6 Quad Plus SABRE Automotive Board Board: MX6Q-Sabreauto revA I2C: ready DRAM: 2 GiB Video device 'ipu@2400000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Video device 'ipu@2800000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Some drivers failed to bind Error binding driver 'generic_simple_bus': -28 Some drivers failed to bind initcall sequence 8ffe00b8 failed at call 1780e93b (err=-28)
Set SYS_MALLOC_F_LEN to reserve_video to work. This is similar to the change Peng Fan did for mx6sabresd (9002e735e717) Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Reviewed-by: Peng Fan peng.fan@nxp.com
All i.mx6 boards seems to have moved to DM_USB, however gadget support for mx6 is still pre-DM as CI_UDC isn't converted yet. To make this work the usb otg controller used for gadgets needs to be usb number 0. Add an alias for this directly in the main u-boot mx6qdl dtsi so it doesn't need to be done for each board separately.
This fixes regressions wrt. usb gadget functionality in several boards that have gadget functions enabled in their config, but no usb0 alias in their device-tree.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk ---
arch/arm/dts/imx6qdl-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/imx6qdl-u-boot.dtsi b/arch/arm/dts/imx6qdl-u-boot.dtsi index 0aa29e38b8..e161ebb9af 100644 --- a/arch/arm/dts/imx6qdl-u-boot.dtsi +++ b/arch/arm/dts/imx6qdl-u-boot.dtsi @@ -4,6 +4,10 @@ */
/ { + aliases { + usb0 = &usbotg; + }; + soc { u-boot,dm-spl;
All i.mx6 boards seems to have moved to DM_USB, however gadget support for mx6 is still pre-DM as CI_UDC isn't converted yet. To make this work the usb otg controller used for gadgets needs to be usb number 0. Add an alias for this directly in the main u-boot mx6qdl dtsi so it doesn't need to be done for each board separately. This fixes regressions wrt. usb gadget functionality in several boards that have gadget functions enabled in their config, but no usb0 alias in their device-tree. Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk
sbabic@denx.de
Sjoerd Simons
