[PATCH] rockchip: rk35xx: expand space for decompressed kernel
An uncompressed 6.7.0-rc1 Linux kernel Image built with the arm64 defconfig is about 40MB. This does not fit in to the space between kernel_comp_addr_r and fdt_addr_r, so when uncompressing an Image.gz to this size, the FDT will be overwritten. Move fdt_addr_r and ramdisk_addr_r higher in memory to allow 96MB for uncompressing kernels.
Signed-off-by: Hugh Cole-Baker sigmaris@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Philipp Tomsich philipp.tomsich@vrull.eu Cc: Kever Yang kever.yang@rock-chips.com Cc: Jonas Karlman jonas@kwiboo.se --- include/configs/rk3568_common.h | 4 ++-- include/configs/rk3588_common.h | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index 1b7d3437b1..da5b38803e 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -20,10 +20,10 @@ "script_offset_f=0xffe000\0" \ "script_size_f=0x2000\0" \ "pxefile_addr_r=0x00e00000\0" \ - "fdt_addr_r=0x0a100000\0" \ + "fdt_addr_r=0x0e000000\0" \ "fdtoverlay_addr_r=0x02000000\0" \ "kernel_addr_r=0x02080000\0" \ - "ramdisk_addr_r=0x0a200000\0" \ + "ramdisk_addr_r=0x0e100000\0" \ "kernel_comp_addr_r=0x08000000\0" \ "kernel_comp_size=0x2000000\0"
diff --git a/include/configs/rk3588_common.h b/include/configs/rk3588_common.h index 46389d087d..5fdbdb6fd7 100644 --- a/include/configs/rk3588_common.h +++ b/include/configs/rk3588_common.h @@ -19,10 +19,10 @@ "script_offset_f=0xffe000\0" \ "script_size_f=0x2000\0" \ "pxefile_addr_r=0x00e00000\0" \ - "fdt_addr_r=0x0a100000\0" \ + "fdt_addr_r=0x0e000000\0" \ "fdtoverlay_addr_r=0x02000000\0" \ "kernel_addr_r=0x02080000\0" \ - "ramdisk_addr_r=0x0a200000\0" \ + "ramdisk_addr_r=0x0e100000\0" \ "kernel_comp_addr_r=0x08000000\0" \ "kernel_comp_size=0x2000000\0"
- "fdt_addr_r=0x0e000000\0" \ "fdtoverlay_addr_r=0x02000000\0" \ "kernel_addr_r=0x02080000\0" \
- "ramdisk_addr_r=0x0e100000\0" \ "kernel_comp_addr_r=0x08000000\0" \ "kernel_comp_size=0x2000000\0"
I think this shows the real problem is that the defaults here need to be re-thought with functional maximums in mind. There's a practical limit of 128MB for the kernel so we should have the kernel, then the kernel decompression buffer, then device tree and overlays space, then ramdisk at the end.
kernel_comp_size needs to be adjusted with this change
Hugh Cole-Baker
John Clark
